Thank you all again very much.
Again, excuse delayā¦no computer.
Iām not one of those who adks questions and disappears.
Iām right with all of youā¦completely get it and understand.
Thank you.
Actually Iāve never had a problem with the xk not idling smoothly.
And Iāve had them in different displacements from the 50s to 80sā¦
And Iām a perfectionist, and do nothing halfway.
I wish i could hope it wasnāt a rod bearing or crankā¦i can think of no other reason if sound goes away when plug detached?
Only possibility was some sort of pre ignition, but after taking much time coaxing patiently and soaking valves in seafoam, marvel, running it through for days, it is running cleaner, stoppedsmokingā¦i replaced plugs with a highly recommended hotter plug etype guys recommend after removing the cheap new plugs used for testing.
They run much cleaner.
But no, still there.
I see messy gasket sealant around sumpā¦someone f**ked with it.
Yes, these sounds are difficult to discern.
Hose to ear revealed only noise at sump, at #5. Other areas no sound.
I do recall a thread replied to on jaguarforum by some experienced australian fellow mentioning loose damper?
Anyway, yes i replaced thermostat, but it has no hole at the top and i want to drill one.
Canāt recall wher i read, some xk engine page online discussing block and overheating issuesā¦youād find it w a search.
He stated drilling 3 of the small holes would aid in even cooling during warm up which caused block cracking issues.
Anyway, i had filled up on white vinegar, let it sit a week, and draining it all seemed clear until i notice rust stained driveway now.
Then i notice some hard deposit at opening of upper hose.
Try wiping inside with rag, it is hard.
So for first time i squeeze hoseā¦crunch crunch.
Bottom 2 as well, crunch crunchā¦
Water pump to intake jacketā¦same.
F**k
All hoses coated with hardened crap.
So i am not doing anything more until all hoses are replaced, and water pump.
Poor thing.
Then flush again.
So perhaps sludge was this crap lining the hoses, and who knows where, not head gasket symptom.
Ir maybe head gasket was replaced and all not flushed wellā¦
I donāt knowā¦u hate people that donāt take care of things or do them well.
Better not to do anything!
Iāve brought old jaguars back to life after sitting for many years when just abandoned or left aloneā¦and they were fine after doing what i doā¦sigh.
Cobsidering donor car or just rebuild myself. Parts are cheapā¦but i found a 72 s1 locally, needing resto. It depends though, why is it better than mine?
At least i could bring motor back to originalā¦if that is even a good thing?
Anyway getting off topic here. May require its own thread.
Thank you allā¦any thought very much appreciated.
PS tach doesnt work, but i can feel it from past experience that at low idle 700 it is unstable, louder squeak, bit of knock, then at abour 1500 it is more stableā¦goes away, revs well otherwise, has great power driving.
Letting off suddenly as suggested yielded no knock.
Will experiment again when new hoses and pump arrive as weather is getting warmer.
Such a difficult thing to discern. So vagie i must always return to remind myself.
I just donāt have the space or time Iām afraid.
