Hello, Jag forums members,
I come to you with a familiar problem a 1985 Australian delivered series 3 that will not start! I’m a long time Jaguar fan. grew up watching “the big steal” as a favorite movie and my family are mechanics and have had many Jags/Daimler on and off over the years the one that remained in the family is Nans tidy from new daily driver xj6 series 2 that has factory series 3 quirks. But the one I call on your wealth of knowledge today is a recent acquisition 1985 xj6 series 3 that has fuel injection that is not playing nicely So ill lay it out as clearly as I can.
So the facts in no particular order
The car was a runner 10+ years ago supposedly got hot and was parked. We purchased it 2 months ago it’s in amazing condition for the age, and was garaged the whole time.
The car runs on Ether or Spray (this rules out many faults) it runs as long as you keep spraying where there is the spark clearly in the car.
There is fuel on the rail and plenty of it. (fuel pump is new as it had failed)
Cold start injector works and makes the car cough on start but won’t fire. (tested with NOID light)
Main and Fuel relay are new also have tried a few “red” pectron diode relays all seem to work and keep fuel to the rail.
We have tested the Injector pulse wire and seem to get volts to go up and down via test lamp flash. We have confirmed this all the way to the ECU speed pin in the boot.
The 3 earths wires have been cleaned up and are back to metal. (the main one on back of block near firewall)
The Ecu seemingly has power and connections are good, the power goes all the way back to the other side of the injectors, meaning the ballast is also ok, we have tested a second ballast unit also.
The injectors when you pull the plug on one have the 12v on either side of the plug as they should as the ECU is what grounds out the one side of the injector to make it fire.
We have Bypassed the bump switch in the passenger side footwell to rule it out. also the temp switch on the block above the injectors
We have manually fired a few injectors with direct wiring of 12v and they seem to click.
Turning the ignition on there is no injector click for starting.
There doesn’t seem to be a “cranking signal” on pin 4 to the ECU but this may be unrelated to the issue of no start - as there is a “speed” pulse in Pin 1 of the ECU.
The battery in car is new
The amplifier and distributor seem to be working and sending the pulse done the black/white ecu plug. altho Im not sure it gets to 0 volts down the signal to the ecu.
When the ignition is on the Power via injectors all the way to the ecu seems to be there for all 6
Noid light has confirmed the injectors are not firing so it would seem to me there is no earth signal coming out of the ECU to ground them and make them fire?
Noid light works on the cold start injector fine.
we tested a second amplifier (condition unknown) and also earthed this with jumper leads to ensure good earthing.
We pulled the dizzy open and while it was not new it didn’t look broken some would say normal.
20 . Have swapped out with another ECU that we were told is working from a repair shop.
So My Questions
Does the Ecu signal wire go all the way to 0v when its pulsing or does it float down in volts? as its my understanding the amp is designed to send an earth down that signal as a pulse
Has anyone tested the earths on an ECU if so how? (power on injectors both sides indicate power to the ecu?)
Next steps
Earthing the pins on the ECU end to fire the injectors manually?
Thankyou and if anyone can offer advice it would be great.
Please help me get this solved I have read so many forums on this subject that I actually have dreamed of Jaguars not starting.
Thank you for the excellent write up, I had such dreams before… good testing, you have fuel and spark but no injector pulse.
My first test is easy and it tests the whole system: if you make and brake the signal wire at the coil or the bullet connector at the water rail, the injectors should pulse with the ignition on, engine off of course.
If they don’t pulse every third time and it runs on ether (spark), revisit the actual fuel pressure in the rail and ecu power. Not much more I have to add.
Just like Doug, I am wondering about your ground wires. Is the large braided ground wire beneath the car between the transmission and chassis present, in good condition, and properly connected? Is the small braided ground wire between the rear cylinder head stud and a rear coolant rail bolt (area circled in green in the attached picture) present, in good shape, and properly connected?
Yes the car was stored for 10 plus years and I had been reading about the stuck injectors and bad fuel threads the fuel pump was definitely gone from sitting for so long.
We are going to remove the injectors today and see what they look like, one thing that gets me thinking it can’t be stuck injectors is when we tested the NOID light on the injectors connection there is no pulse at all - this would imply that the injectors could fire but there is no signal to do so.?
I’m leaning to the earth is no good also, that bundle is the one I am referring to. When I say three the car had three looped eyes with multiple wires out of them onto the back of the block.
It’s my understanding this is also the earth for the ecu.
We are going to put the car on a hoist today and see if we can find anything suspicious and look to clean any earth connections we find.
I have read if the power on the ecu is there but it’s a bit flakey due to bad power or bad earth that the ecu does not have enough grunt to fire the injectors.
Mark,
Normal XJ6 fuel rail pressure, as measured at the Cold Start Injector hose for convenience, is about 36 PSI as regulated by the fuel pressure regulator. I don’t believe the fuel injectors have any idea what the fuel pressure is and when they open and close on command from the EFI ECU. I have seen fuel pressure rise to about 40 PSI under certain conditions including when charging the fuel rail with the engine not running.
You might have an electrical problem if Carl is wrong and the injectors are not gummed up - which would be possible. If the clicking does not work, try a short tap of 12 or better, 9v to the injector: they‘ll click regardless off fuel pressure.
The ground points are important, I recall two eyes at the back of the water rail. Try a pulse first. Thanks for testing. No noid might mean no pulse, but the ECU is regarded as bulletproof.
Thankyou for all who commented this morning… I am very happy to report the car is now running! After many different fault tests we finally come to the conclusion that All the injectors had ceased up solid and would not fire even when 12v was applied directly to them and that also the lucas amplifier attached to the engine block after tripple checking all the wires to both the coil and the distributor. Was seemingly working intermittently. Replacing both the stuck injectors and the amplifier from a donar car luckily purchased last week in a desperate attempt to get this car running. Resulted in this car runninng again and me being able to sleep tonight. I mentioned the noid light not flashing during tests but after we got the car running testing the noid light a second time on the injector wiring showed a flash as expected. We think the intital non noid light was the amplifier not working at that POINT. although we had tested the second amplifier that eventually worked also with no noid light action, so we think it may have been a combination of things we solved, maybe one like cleaning earth’s and wires we were not aware the impact of. We run the car on the original amplifier but it failed after a short time. And we reverted back to the donar one…and she fired right back up, I’ll post a YouTube video I have made that summarises parts around the engine linked to this problem, jag experts feel free to contact or correct me and I’ll make another vid later if I have got something wrong. But hopefully it helps someone one day who is pulling their hair out trying to make a series 3 jag run. Those who said it’s not the ECU were spot on we tested 2 other ECU once the car was running and all 3 worked and ran the car fine, I hear the word bulletproof thrown about with these and I’m inclined to agree. I may comment also a bit of a summary of things to check or edit my original post to help others in future. But in summary she runs and we could not be happier. YouTube video here, don’t mind my voice lol.
Mark, well done on the investigation and final success, just a suggestion, it is ok to reply to any and all posters in the one posting, to save saying the same thing too many times
It’s always a bit awkward not knowing what fixed it - for future references, Mark…
Certainly, if the injectors were gummed up to the extent they did not even ‘click’ with 12V applied (very briefly!!); there would be no petrol delivered - no run. However, this would not interfere with the injector ‘noid’ signal - noid would pulse during cranking irrespective of blocked injectors…
So you could indeed have had an independent ign amp fault, possibly intermittent in addition - as demonstrated by the later testing. Or indeed some bad connections - cleaned up. 10 years standing takes its toll - use it or lose it.
Moral (for future reference): No injector noid - amplifier/pick-up/connections. Noid signal, but no injector action - injectors themselves. injector action, but no start - fuel pressure.
As a PS. Using ether or start gas is fraught; weak ignition may still fire the easily ignited ether - and may cause an almighty bang if it backfires in the air duct…
That said; you went way above and beyond duty - and well deserve success!
Definition: Euphoria - ‘yoo for eee ahh’
Noun; From Anglo Saxon Coventry region - “Thank you for all who commented this morning… I am very happy to report the car is now running!”
