Going on what is fitted to my MK9, It looks like the heater pipe.
It starts off near the distributor, the brackets bolt to the engine block and then it runs along the firewall.
It is certainly a heater pipe, but it doesn’t look like the picture in the XK150 Spare Parts Catalogue. I am inclined to suspect it is from a saloon model.
quite simple this is the pipe on an early XK150 that takes vacuum to the booster ie from RH side of motor to LH side then there is a hose the rest of the way
Best to make one out of soft copper pipe.
Andy
metal body parts are available for mounting the servo under the wing, also to house the servo tank from Jolly Roger
I’m currently on brakes and suspension. There are so many parts that you just haemorrhage money! Plus I’m thinking of pushing the boat out and buying the top & bottom ball joints plus trackrod ends from UK specialist Amsteer.
So, to offset this splurge I’m looking at going for the Powertune LE10117 servo at £96 with free delivery from the David Manners Group on eBay https://www.ebay.co.uk/itm/264180279383. The ratio is 1:3 and it should fit above a battery box. However, I don’t know whether its designed to work on its own or with a vacuum tank as per the original setup. Any ideas?
