Help please. How do I remove the centre consul trim over the gearbox tunnel on a 1967 S type?
I’ve found the two screws at the rear between the seats.
I’ve found the 4 nuts on studs at the wooden piece at dash shelf level where the heater is controlled but it still is anchored at the front. Clearly I’m missing something???
I’d have to go out and double check, its been about 2 years since I removed mine to cut a hole for the gear lever. Its midnight here so in the morning.
