Hi, can anyone tell me where this cable should go? XJ40 -92
have a problem with when you press the brake, the brake light comes on! could this be something belonging to the error?
Depends what the light is thats coming on.
Only the red brake light comes on when the pedal is pressed.
could it be that the cable that is off goes to an abs sensor left up to the wheel hub.
the red light on the dash if illuminated when you hit the brakes means the pad wear sensor is letting you know the brake pad is getting low
Low brake fluid? Any message (such as PAD) on the VCM?
