Oh no, not again ,… nope … trying your side of things.
Recognizing the limitations of using an IR thermometer, but also acknowledging that there are things which they can be used for in investigating things, I purchased a reasonably lower priced (<$40) IR thermometer from O’Reilly’s which has a 12:1 cone.
The 12:1 cone means that if I point the laser at a surface 4" away, the reading circle is approximately 3/8" if reading perpendicular to the surface (or close to perpendicular to it). If trying to read the temperature of a surface, which has a flat area of less than least 1", from 12" away, and not close to perpendicular … well, the reading is not going to be very accurate as the reading is including other areas and their temperatures.
That said, though, I did some experimenting with the IR thermometer for what it is good for: comparisons of similar items, shapes, and surfaces.
Starting from overnight setting, I shot the IR at both thermostat housing, with the laser about 4" from the thermostat housing, with the laser pointer about 3/8" from the mounting flanges, for a measurement area of 3/8" diameter circle, reading 65.7F each side … engine cold.
After starting the engine, I made additional IR readings on the A side and then the B side, and looked at the temperature gauge needle.
It only took a few minutes for the B side to read higher than the A side, and after about 10 minutes or so, the difference when to 25-30F higher on the B side than on the A side. and basically followed 30F higher all they up until the A side was around 179F and the B side was 201F.
Eventually, the A side stabilized at around 189F+/-3 and the B side stabilized at around 203F+/-4.
I also noticed that the temperature gauge barely rose above C until the temperatures were well over 160F, and even at the stabilized temperatures, the gauge was well below the N.
The car was in the garage (exhausts facing out the garage door) the entire time as this eliminated other factors, such as air flowing in while driving.
The temperature gauge sensor is on the A side, so it is reading the lower temperature between the two banks.
There must be something inherent in the cooling system, even before the thermostats open, which allows the B bank to heat up faster and hotter, and remain slightly hotter even after the thermostats open.
I found that I still have two brand new, in the boxes, Calorstat thermostats, complete with gaskets and seals, thermostat model TH1514.81J. I looked those up and the temperature rating is only 81C (177,7F, likely considered as being 180F).
I don’t know what temperature rating thermostats are in there now as my mechanic swapped thermostats a few times to get ones which kept it right around N on the temperature gauge in the hot Florida summers. Having driven it a few times here the past several weeks and it never even gets close to N on the gauge, yet the IR thermometer, reading the metal and not the water, shows the temperature is around 195F+/-5 (average A&B sides).
How far off is the IR at those thermostat housing points? I would think within 5 degrees or so of the water temperature inside.
I would think that should put the gauge right around the N?
My gauge does not read in degrees, just C … N … H.
