Has anyone used an EZcarlift to raise a S3 E-type and if so, how was the result. Is the lift long enough to support and raise the car by the front and rear wishbones or do you need to use the 4 jacking points?
Wayne
I don’t have an EZCarlift but rather an asymmetric 2-post lift
Even with minimal rust on my car I don’t the jacking points
Not sure if my lifting points are longer or shorter than he spacing on the jacking points, but – for your consideration:
Up front, I use the mounting braces for the torsion bars
Out back – the large radius bushings for the trailing arms
HTH
Craig
