I have tried a visual setting putting the rotor near the #6 cyl. plug wire on the dist cap and then twisting the dist. to line up with the dist pick up protrusion and the nearest stator arm while the timing mark of the front pulley is at 8 deg. advanced. Is there a way to use a test light or multi meter? I cannot get the engine to run well enough to use a timing light. It barely starts at all. Something is severely wrong
On the right side the wires are 4,2,6 from the top and those extending to the left are 1,5,3 from the top (CC from the top left #1 wire the wires are 1,5,3,6,2,4)My problems started with an occasional no start no spark condition which would “go away” completely in 10 min. or so and run perfect for days I was looking into the problem when it became a permanent no spark. I found the dist pick up was an open circuit and replaced it (new one tests at 2.4 ohms). I took the amp apart and tested it according to the instructions: all was OK
I went through the checklist :
Every item checked off OK but i’m not sure I understand item 2: coil + and - were both 12.8V and the - coil “-” post went to 12.6V with the amp wire disconnected from the coil “-”. The test says “More than 2V means the amplifier is faulty”. So should the reading be exactly 2V when both coil and amp are OK?
I have checked continuity of all ignition wiring and replaced cap and rotor and plugs (Champion N11YC). I tried a different coil to dist cap HT lead and still the engine barely runs and will not increase rpm even when the pedal is pressed down. Releasing the pedal it just dies, The coil is a Valeo 245000 It measures 1.7 ohms primary and 7.3K secondary with a 1.1 ohm ballast resistor. A spark plug set into the coil HT lead sparks a small blue and yellow continual sparking when the engine is cranked. A test light between coil “-” and ground dims and flickers when the engine is cranked.
I have ordered new plug wires. Should I get a new coil at this point too? I have on hand a used Lucas Super BYS 15P6 45336A it measures 1.7 / 5.0K On this one is a resistor actually needed? I am running the same Lucas Super on a 84 XJ6 with no external resistor for years with no problems.
I’ve read the advice to shift all the wires to one tower over on the dist. cap but if the rotor is already pointing at the #1 or #6 dist tower how would this help?
