Good after noon to you all.
How heavy is a 4.2 engine with out the gearbox?
With flywheel, 605 lbs.
Looks like I need a new engine stand then!!!
We weighed the engine with flywheel, clutch, pressure plate, bell housing, transmission and starter attached at Coventry West when I picked it up after the rebuild. The exhaust manifolds and intake system was not installed. It weighed 671 lbs sitting on a pallet and tire that probably weighed around 30 lbs. So say 640 for the assembled engine and transmission without intake or exhaust.
