List:
I’ve had a 12 volt car battery that I don’t need right now.
What is the best way to preserve it for future use?
Thanks
Lou
List:
Thanks
Lou
Out of freezing, with a smart charger on it.
Fully charged and in your basement, what I do. Maintains its full charge over the winter anyway.
They say that leaving a bare battery on the concrete floor draining a battery is bunk, never made much sense to me.
Let me see if I understand. You recommend storing it in a environment above freezing and attached to a smart charger.
Thanks
Lou
I guess I should ask: lead-acid, or AGM? How long will the battery be stored?
As for the old story of it leaking electricity onto concrete? That went out with tar-case batteries.
Stick in a well-ventilated space, with the smart charger on it, and Bob’s yer uncle!
List
I don’t know if it’s lead acid or AGM but will check tomorrow.
And, short of connecting it to a vehicle and cranking, is there any way to determine its condition?
Thanks
Lou
A battery hydrometer will indicate the level of charge (if cells are accessible) but it won’t reveal high internal resistance.
A battery load tester is similar to testing it on a car. It’s a voltmeter together with a load resistor that you use for a very short time so that the resistor doesn’t melt.
Most repair shops should have a battery tester that they will be able to test the battery, do that then you can proceed with the best option for you, sell or place on a CTEK battery maintainer.
The battery in my daily driver 2000 S-Type went dead a few months ago, and after replacing it, I put a low-priced trickle charger on it. Success, it was back in charge a month later and starting another car.
I’m with Jerry. Sell it, cheap. Buy another, if and when needed.
But, other comments are valid. charge as needed. Slow is best.
I have an old one on my bench. Durn post “melted”. A weakness of side post batteries. I sed it for a time as a bench battery. I am reasonably sure it is 'dead". Just for the heck of it, I might put my smart charger on it…
Carl
Agree with a trickle charger / smart charger. Best to charge it fully first with a regular charger if possible. I have my XJS battery off to the side in storage this way. I use it here and there while working out electrical issues during the XJS’s refurbishment or testing items on the bench. If I don’t drive my XJ6 for more then a week or so, I throw one on it as well. Never had an issue, and the XJS battery is going strong for over a year or two. If you won’t need it for a few years, better to just sell it if possible.
