Hi Philbert, my 123 has 16 settings. I picked a curve by laying each option over the workshop upper and lower settings (there are two “knee points” if you graph the workshop table). I picked a setting on the 123 by picking a 123 curve that fell between the workshop curves. My 3.8 has 10 degrees initial advance - set this whilst the vacuum port is disconnected as is done for a standard dizzy, this applies at normal idle. Don’t know the setting for a 4.2 E type. The 123 will stick to the curve setting that you select - you could check with a dial back timing light, I haven’t bothered. I can send the 3.8 graph tonight. Paul
