Good evening everybody,
after well over 12 years during which the Jag never let me down I experienced a sudden and intermittent problem last summer. Every now and then the car would lose power, sometimes drastically, hardly pulling away from a stop, sometimes less with just a feel of being restricted. Everytime the engine went back to work after some time and there was no tendency of the whole thing getting worse. There was no problem during winter, but the thing started again some weeks ago …
As the phenomenon only occurs with higher ambient temps it was general consensus on the list that it might be either the coil or something weird going on in the carbs. As you might have guessed I started with the easy and inexpensive solution, bought a new coil and fitted it last Saturday.
The good thing first: even though access (without removal of the air filter box) is somewhat restricted, replacement was straightforward and the car now starts and runs just fine. I even did a 20-mile test run with temperatures in the 80s and, at least for the moment, there were no more issues. Touch wood that the coil really was the culprit.
Now the strange thing: running on the new coil water temps were significantly lower than before. Before the swap the car would run at “n” of “normal” and with higher ambient temps and either serious action (motorway + 65 mph) or city traffic rise to vertical and a needle width above. With the new coilthe needle was far right from the “n” during regular operation and approached it only in city driving.
Most certainly, some fiddle factor is involved - in fact, on the first run the water temp needle wouldn’t move at all. Only upon opening the hood and shuffling things about it went back into operation. Apart from that, could a coil ever influence operation temp of the engine? Plugs, sure, distributor and advance mechanism, sure, but a simple coil?
For the facts: I replaced what appears to be the original Lucas coil with a replacement part that was sold as “Lucas” and has a paper sticker on the mount reading “Lucas”, but no “Lucas” embossed in the black plastic top. It is much smaller and has inverted + and - connectors. The coil is connected to a 1-2-3 ignition, as was the original coil.
Final trivia: I’d like to keep the original coil which still looks good. Beyond the standard test measuring resistance between + and - and between primary and secondary circuit, is there any generally accepted procedure to test and exclude internal failures that may or may not result in malfunction?
As always, thank you all
Jochen
75 XJ6L 4.2 auto (UK spec)
