I’m putting our old xj6vdp back on the road after a long time sitting. The engine rolls over nicely but there is no spark. The battery is 650cca and fully charged. Is that enough juice? Where do I go from here?
Could be a multitude of things but I would start with the crank position sensor. You can sometimes (but not always reliably) tell if it’s working but seeing if the Rev counter has a reading whilst cranking.
They are easy to change and not to expensive.
Thanks! I’m following a thread which points that way. I discounted it because I figured, ‘What the heck, no moving parts and it was never touched.’ That’s where I’ll go next. Once I get this solved I’m going to post about info on repair of the roof panel rusting from the inside out. I haven’t been on this sight for a long time. It’s good to be back.
Wellcome back Will be interesting to hear about you roof adventures!
Coil packs as well
But for 1995 make sure your getting fuel!
Good luck
