I started out this morning with a simple project, or so I thought. I just bought a 79 Series 2 FHC on Saturday and I noticed the the steering wheel was tilted towards the drivers door. I planned on loosening the two bolts that hold it under the dash and straightening it out. However, what I found out was the the ignition switch metal bracket attached to the right side of the steering column was already tight up against the aftermarket AC and the left side of the AC unit was not level with the rest of the unit because of how tight it was up against the ignition. See Pic below
Additionally the PO butchered the panel by drilling another hole for a momentary switch to replace the horn button on the turn signal because apparently it stopped working. Here is a pic of the switch panel now.
My automotive OCD will not allow this to continue, so I pulled the ignition switch panel, removed the horn button, ordered a new turn signal, yes I tried taking the horn button apart and servicing it to no avail. I will chase down the wiring and undo the ridiculous button in favor of a new turn signal/horn box.
But I have been unable to find a part number or part to replace this panel to hold the ignition.
This is a pic of the steering column and metal bracket that held the ignition panel, there is a ground wire attached there temporarily as I was chasing the wiring for the horn button. The control section of the aftermarket AC unit is on the left, now leveled since the ignition panel has been removed, you can see the ignition barrel hanging in this pic.
Holy crap X 2. It was a total stroke of luck that I came across that part in my searches just yesterday. I wasnât even looking for anything like that but happened across it and it caught my eye for some reason.
Like a mother who recognizes her own babyâs cry amid all others in the ward⌠I immediately recognize my ignition switch in that photo. Yeah, I feel like a proud parent.
I see two versions on the SNG page - you might want to confirm the difference. The one in my photo is heavy metal, not plastic â it doesnât just cover the switch but supports it. Not saying that the lower priced SNG one is plastic but their photo looks like it might be,
Unfortunately I suffered through a similar experience with my 1969 Series 2 OTS when I removed my under-dash AC (ugly) unit. Like yours the ignition switch was held on by a flat bracket that was attached to the AC unit with nothing behind it. And just like you I simply could not let that go and wanted it to be âas originally intendedâ
So I embarked on a three month search for the metal bracket (that is pictured from Geoâs car) but the only thing I found is the same ignition switch cover shown here (sold by XKs Unlimited and SNG Barratt). In a hopeful moment I bought that cover but it turned out to be plastic that was too thin to securely hold the ignition switch as it is only intended to be a cover over the metal bracket. So my search continued. Apparently itâs a bracket that was only installed in a relatively few S2 cars between the time that Jaguar switched from the S1 ignition switch in the center console to one mounted next to the steering column. It was replaced a very short time later with a steering column locking version as required by Federal Regulations.
Parts suppliers I contacted (in the USA, England and even Australia) told me I was searching for a Unicorn. I even sent some pictures of one with a ruler next to it I got from another Jaguar owner he took during his restoration to a friend of mine in the computer industry in the hopes of having a 3-D printing made of it. However, there wasnât enough detail in the photo to make that possible. (I can try to find those pictures and send them to you if needed)
In the end, my search was rewarded in the sense that I found one in England but it was attached to a steering column and the seller refused to sell it separately. So I ended up buying the entire column just to get that bracket. Certainly one of the more expensive âsmall partsâ Iâve bought for my carâŚbut in a perverse wayâŚone of the more satisfying!
It bolted right in and I installed that plastic cover over the metal bracket as intended.
Itâs possible that you will have an easier time finding the bracket than I did (itâs been two years since I found mine) and there actually was one on Ebay when I started looking but it had already been sold when I saw itâŚ
Donât give upâŚIâm sure there is one out there!
If I can help you with any additional information please donât hesitate to ask.
@NaplesGuy thank you for the story, that helps out. Pressing my luck, but do you have a pic of the part or even the part number?
In the short run, I may be forced to shorten the hacked up part that I showed above my second pic. If I shortened it by 1/4 inch and put a plastic plug in the hole that the PO drilled for the horn button, it would work while I set out on the same quest as you.
Just to confuse you more, this is the way it should look on a '69 with factory A/C:
The switch was moved to a plate on the A/C unit. The plate is held down by the nut that holds the A/C switch in place. Since yours is an aftermarket A/C unit, I bet it never ever fit correctly. Your best bet may be to fabricate something yourself.
More data, but maybe not any information that helps youâŚ
Digging around about this late yesterday I ran across an earlier post. This one describes the ignition column mount for a '68 S1.5, which is basically a collar around the steering column with grub screws to attach -
Here are some pictures of the switch mount in my non-A/C '68 S1.5, which seems to match the above description. It doesnât seem to accommodate the ignition cover weâve been discussing, but I canât say for certain that what Iâve got is factory. Is this setup unique to the S1.5?
If you read the other posts in the link I just sent, Doug references a part number (C28567) from a '68 IPL, but my Google searches for that number donât turn anything up.
Thereâs were 4 or 5 versions during the Series 1 1/2 into series 2
Later was franks picture to a/c
Early a bracket around the column
I used the serie 1 1/2 2+2 metal one and used the STANDARD key swith, eliminated the barrel lock and 15 pounds of junk.
@ryaskovic It truly seems to be a mystery part. I went back and read the entire thread, its good to know Iâm not crazy and that others are searching for it to, although disappointing that it hasnât been located yet.
