Hi David
The speaker is inside the steering column cover
It is quite tricky to get to and even harder to remove, but there is an easier way to check it
Remove the trim panel in front of the driver’s knees
Remove the lower steering column cover
The speaker is inside a metal bracket to the right of the column directly above the ignition switch
The easiest way to test is to disconnect the plug/socket in the speaker lead
Get a small radio or phone and use a 3.5mm jack plug lead, strip the other end and connect 2 pins to touch on the plug contacts
Play some music to test the speaker
Also on the right is a black box like a relay, that makes the sound for the headlights on, see photo. Check connection and soldering
Remove the cover panel below the glove box.
You will see numerous relays, ECUs etc
There is an audible warning device, see attached photo
The large connection from this had a loose pin on mine.
Switch the indicators on and try wiggling the connections
Also check the earth screw, see attached photo, as this was loose
It is easy to remove the device and check the solder connections are good
Good luck
Best Regards
Jeff Wickham
DATA Registered Health & Safety Consultant
Accredited Trainer for Creo 2
BOHS P601 LEV Test and Examination
Onside Consultants
Mob 07881 923542
Office 01268 456048
www.onsideconsultants.co.uk
