do you happen to know what diameter and pitch and thread type goes in that
hole?
Bill B
At 08:22 AM 1/2/2002 -0700, you wrote:>Mine has the type that screws into the block. Look under the front carb,
and there is a plug, about 1" in diameter that takes a 5/8" allen key
(if I rememebr right). Remove the plug, and screw in the block heater. I
think mine is 1500 watts, and it works quite well.
I use it anytime the garage is below 50 degrees and the car starts
noticably better after being plugged in for an hour. I doubt that a 200
watt heater would do much good, given the size of the XK block.
The screw in heaters are available up here for about $25 CDN/$16 US. I
can send you one if you can’t find one down there.
The weather in New England this fall/winter has been wonderful so far.
It
has just gotten cold but the roads in my part of the world are still
sand and
salt free and I am reluctant to stop driving.
Has anyone fitted an engine heater and if so what type is preferred?
My
local auto parts place has 2 types: a magnetic one designed to stick
to the
block or one designed to go into the lower radiator hose. The
magnetic
variety is only 200 watts and the hose mount is 600 watts.
type goes in that
hole?
Bill B
The thread is 1" NPT, 11.5 TPI.
The maker is Phillips and Temro Industries, Winnipeg, Manitoba.
The application chart that came with it is an odd collection of cars:
Jaguar all 6 cyl 1952-94, V12 1971-94
Eagle 88-89 2.2 L
Jeep 84-87 2.1 L diesel
Renault 84-86 2.2 L
GMC Forward tiltmaster truck, 84-92
Along with assorted tractors!
Hopefully this helps,
Craig
64 OTS
Calgary, Canada (not needing a block heater right now!)
Eagle 88-89 2.2 L
Renault 84-86 2.2 L
I take it you have never read the application sheet for the oil filter?
This is from the Kleen-Pak brand GFE101:
“This cartridge replaces most Ferguson and Fordson Major Diesel tractor
filters.”
The outside of the box lists most Jaguars including the XKE…61-69 and
XKE 4.2…70-71.
George Cohn
70 Ferguson Tractor…oops, I mean '70 OTS
filters.”
George Cohn
No, I’ve never seen that brand. I buy my filters from the dealer now. I used
to get the Fram’s but they have changed recently and don’t include the O
ring anymore, instead there is a cork gasket.
filters.”
George Cohn
Craig
64 OTS
I got those from XK’s. They come packed with two different cork gaskets
and two different “O” rings, one of which fits the e-type.
I have 3 or 4 of them but I switched to the spin on type adapter so now
it uses conventional type filters.
At 07:37 PM 1/4/2002 -0700, you wrote:>At Fri, 04 Jan 2002 17:14:59 -0500 , you wrote:
type goes in that
hole?
Bill B
Eagle 88-89 2.2 L
Renault 84-86 2.2 L
Craig
64 OTS
