When I got my 1969 E-Type FHC in 2002 it had an external mirror only on the left (driver’s) side door. I thought about installing a matching one on the right (passenger’s) side for years but never got around to it until now. Following a engine rebuild and clutch removal and replacement in early 2021 I have been driving the car again regularly and decided that it was finally time for me to install that mirror. Here are some before, in work, and after pictures of this successful project. I purchased the mirror from SNG Barratt, their part number C30827/1.
I am enjoying the additional visibility with the new mirror in place and I am very glad that I finally installed the mirror. It was easy to do and only took about an hour, including the time for a drive to evaluate and adjust the mirror.
Les,
The kit from SNG Barratt included the mirror, a vinyl mount gasket, and two metal screws. After identifying the correct location, you drill two holes in the door large enough for the vinyl pins in the gasket to fit into. Once the gasket is in place, you position the mirror, insert and tighten the two screws, and rotate the mirror so that it hides the screws. There are no nuts or bolts. The mirror is held in place by the two metal screws which go into the gasket pins.
BTW, I have no affiliation with SNG Barratt other than as a long time satisfied customer.
Very like the mounting for the original mirrors though Jaguar also had a large center hole, possibly because the original mirror needed some clearance for the swivel works:
I also added the additional RH mirror to my car. I went to the local hardware store and bought a couple stainless steel screws and lock nuts. I didn’t want to ever have to back in and tighten, then retighten the screws till they hogged out. I wanted the base comfortably snug to help keep water from leaking down behind the gasket.
Very nice. Mine only has drivers side. While I was trying to get it back to drivability, I had kind of decided to eliminate all sideview mirrors for aesthetics. Having now driven it and discovered that the positioning of the rear window prevents me from seeing anything more than about 40 feet behind me, I’m definitely keeping the sideview mirror and might even add one on the other side.
I can’t possibly imagine driving a car with only one side view mirror: I’m so used to having them on every vehicle I own now, including the hot rod, I couldn’t do without a passenger side mirror.
My other old cars are generally driven topless, so pretty much a 360 view (if I were an owl) and I’m used to either no or useless sideview mirrors. The FHC, on the other hand, seems to have about 150 degrees of blind spot.
Large hole for mounting door mirror.
My 69 XKE has the original side mirror with the extra long spring assembly that extends into the door. There by it needed the large hole.
John W
I’m in the same boat and was thinking of moving my driver side up to the bonnet when I got the passenger one, but really don’t want to deal with covering the hole left behind. Just happened to see this guy the other day and wonder if it’s blasphemous to do the same with the Jag?
Wiggles,
Yes, I am enjoying the patina of my E-Type again while driving it regularly following the 2021 engine rebuild and clutch replacement. Last month I had new tires mounted on the original wire wheels, I replaced the soggy brake fluid sensor cork floats, and added the passenger side mirror. I just replaced the front shocks, and I started replacing the coolant hoses (last changed in 2002) today. Next I plan to replace the soft front brake hoses and bleed the brakes, followed by a bunch of other things that I have been putting off for years now.
My former 1984 XJ6 VdP was repainted in 2006, then came my former 1957 MK VIII in 2008, followed by our 1990 XJ-S convertible in 2014. In between those three bare metal repaints were partial repaints of my former 1987 XJ6 VdP and my 1990 V12 VdP. So I had a close regular relationship with an excellent paint shop for many years. The 1969 E-Type was next up for a bare metal repaint, but my exodus from California earlier this year means that will be delayed for some time. So for right now I am driving, fixing, enjoying my E-Type again.
BTW, my car was originally painted Sable. It was repainted British Racing Green by prior owner number 5 decades ago. I believe I am owner #7. The paint is old, tired, and cracking (especially on the nose where a bondo repair is evident. Still it starts every time, and gives me a lot of pleasure while driving and working on it. There are not many E-Types here in Upstate South Carolina, so it gets lots of love while I am out driving it, even with all that patina.
