Gasket dressing…what does that mean? Are we talking RTV silicone? And apply both sides of gasket? I think i see that Toyota stuff, may be worth a try. But i’ve never put sealant on intake manifold gaskets before, is this a Jaguar V12 thing?
Gasket dressing and sealants (like RTV, silicone, etc) are different. As Kirbert noted, ‘dressings’ are designed not to solidify or cure. They’re tacky, they help ensure the gasket doesn’t move while you’re lining up and assembling parts, they remain compliant which helps with the dis-similar rates of thermal expansion or relative motion across the gasketed joint. If you’ve ever worked with tappered threaded pipe, liquid pipe sealant (or “pipe dope”) is similar in that it is not mean to harden or cure.`
I don’t have any experience with the Toyota gasket product, but I’m curious about it now and may track some down. The classic “gasket dressing” is Gasgacinch 440-A. As the name implies, it ‘cinches the gasket.’ It appears that Edlebrock sells a branded version, too. This stuff has the appearance and performance of rubber cement. The odor is similar, if somewhat stronger, too. Seems like it is rubber cement that has been chemically stabilized for use with most automotive fluids.
As for using gasket dressings, I’m sure this varies by product. The Gasgacinch product is applied to both sides of the gasket and the parts that the gasket touches, and then allowed to dry for several minutes. Once it’s is dry, it becomes a sticky film that can be rubbed off the gasket or the part, if necessary. The gasket and parts are assembled as normal from there.
If the joint needs to be taken apart, the gasket should peal right off (thanks to the dressing) and any residual dressing can be removed easily, too.
Anyway, that’s what gasket dressing is and how it is supposed to work. They are certainly not ‘just a Jaguar V12 thing’ but as we all know this engines require employing all of the Dark Arts to get and keep them running.
As for intake manifold gaskets: I used the 12 individual gaskets made by Cometic. I did apply Gasgacinch to the intake ports, the manifold flange, and both sides of the gasket. Unfortunately, I haven’t run the engine yet, so I can’t tell you if this worked…but it seemed to.
Hope something here was helpful. Good luck!
-Drew
