When I open the drivers door, the interior light comes on. So far so good, but so do the HVAC fans at a very low speed. Both light and fans go off together when I close the door. With ignition on, all heater functions work normally.
I just finished replacing the heater core. Thinking this must be a bad ground. Column and instruments came out to do the core.
Mark,
Many years ago my fans started coming on when they shouldn’t. Turned out to be a failed diode that was supposed to prevent feedback from something else that came on. I realize this is kind of vague, but it was a long time ago.
To track it down, you have to carefully study the electrical schematics, looking for diodes that could form a circuit if failed. In my case, it was an inline diode… a Jaguar part packages in a black plastic case about 1/2" x 2" x 1/8".
Mark_SF,
I recommend that you provide info on what year and body type (coupe,
cabriolet, convertible) in your post. Jaguar produced many configurations
of the XJ-S/XJS from 1975 until 1996 and it would help others to know which
kind you are having this problem with.
Fixed it. The ground for the interior light switch was bad. The wire disappears behind the screen demister vent on the upper left, so rather than take everything apart, I added a new ground wire, and everything is back to normal.
