Hi Everyone - it’s been a while… so long I can’t even recognize the site
I’ve got an intermittent problem that I’m having trouble diagnosing because I can’t cause it to happen. Let me preface this by saying that all filters and other consumables have been replaced as well as wires, plugs, rotor, cap (both lucas oem stuff). Transmission was drained and new filter installed, etc, etc…
Drove the car on a long roadtrip (1600miles roundtrip). Car was fine going, but gave me trouble coming home. About and hour into the return trip I was going about 75 mph on the highway when it began to stumble or drop-out - sort of a lack of power. A tiny bit at first… it would do it and then be okay for a minute or two until eventually it lost power to the point that I had to pull over. The car never died and seemed to idle and rev okay while I was pulled over. The only thing I noticed was a whine from the original fuel pump which wasn’t that unusual because I’ve heard it before with no issue.
After idling about 10 minutes I couldn’t find any issues after wiggling every harness in the engine compartment so I figured I’d see if I could make it to the next rest stop (20 miles). It seemed to drive normally (although I was babying it) at about 65mph the whole way. I promptly changed the fuel pump with a new one in the parking lot because I always carry a spare.
After that I drove the car another 400 miles, babying it all the way and going about 65. Also stopped every 40 or 50 miles or so to make sure all was well. The issue didn’t happen again except I did notice a lack of power once while merging - not a stumble, just a lack of power.
About 200 miles away from home I got a little brave and didn’t stop for quite a while. The car started stumbling and losing power. First every once in a while and then it started to really get bad. My memory is kinda hazy about what I did because I was really tired at this point but I believe I put the car in neutral while traveling at 55 or 60 and revved it - I think it reacted normally but when I put it into gear the power loss got really bad so I started to exit. By the time I got all the way into the ramp the car would barely move. I nursed it super slowly into a truck stop and waited for the AAA man to bring us home. During all of this it never died - it just had no power. AAA tow-truck came about an hour later at which point I drove the car normally up to the back of the bed - no evidence of power loss.
I became convinced the issue was heat related and since the AAA truck was a broken-down nightmare that I didn’t think would get up our mountain, I had the guy offload the car at the bottom and after a brief drive to confirm that it was running okay I drove it up the mountain normally.
Since then I’ve driven the car around a good amount - never any road trips just regular driving. I also completely flushed the transmission, removed both catalytic converters and had the injectors cleaned and replaced all hoses. The problem didn’t surface again until a few days ago when I was coming up the mountain fast. Got a little stumble or drop-out and promplty continued home. I’ve driven it since and it’s normal.
So really the only thing these events seem to have in common are that they happened when I was going at highway speeds. I’ve jiggled, moved and molested every harness to make it happen again to no avail. I know this is reaching but could it possibly be a transmission issue? Like the torque converter giving up? I’ve also considered possibly that the fuel pressure regulator (original) may be failing but I when I’ve put a gauge on it in the garage it’s right where it should be. Of course I have no way to check while the problem is happening. I’m almost ready to start throwing parts at it - switching out the AFM and the ECM - but I hate to do that without a good reason.
Any thoughts?
~Mike
72 XJ6 (X2)
73 XJ6
85 XJ6
