It is time for near rear brakes, plan to replace the pad, rotors, calibers, hand brakes pad, and shocks. Am I missing anything, please advise for anything else, while the rear end is down? Also, transmission mounts are shot.
Brake hose.
Stub axle seals?
DD
Go ahead and change the fluid in the differential while it is out - and maybe change the filter and the fluid in the transmission since you will have the transmission mount out of the way - Tex.
Good point changing the transmission filter, would you change the spring in the transmission mount too?
I thought the spring usually holds up well, but the center “foam/cotton” bushing is what deteriates on the mount and the “spacer cushions” for the spring - check the archives for more info - Tex.
Definitely and even bearings.
Anything after the disc brakes can be done in situ.
Anything before not, the cage has to be dropped.
Great thanks for the tip I will add this to my list
