First off If you don’t have a proper set of manuals, then to go this link Jaguar XJ-S Manual get a proper set of manuals. If you prefer paper and don’t want to print out the online version, then Amazon has the XJ-S abridged manual available too. Personally I think it’s useless for anyone new to Jaguars.
The XJ-S factory manual is a 6 volume set - covering all years - which the OTPubs online / CD version is an electronic copy of. This manual is worth it’s weight in Gold. Word of caution about OTPubs the, install the reader software on a computer that you’ll always want to use for reading the manual; because OTPubs are real dicks about relocating the software. I got all excited over the manuals, and installed the software on my work computer, thinking I’d just uninstall it and install it on my garage laptop. NOPE! Tech support refused to inactive the license on my work computer and activate it on a different computer. Now they won’t even return my calls or email.
If you need a mult-meter, let me know (personal message me) I’ve got a stack of them. Their like tape measures to me, I can’t ever find the damn thing when I need it. If you’re in the US, I’ll send you one of mine. The YouTube video is a real good hands on look on how to track down a parasitic draw. I forgot all about the post I did.
On a personal note
I joined this forum right after I purchased my second Jaguar, an '85 XJ6 for $500.00, The car had 45,000 original miles, no rust, a set of Dayton wire wheels, new tires, The downside was it didn’t run, the windows wouldn’t go up or down, the sun room didn’t work, the leather under the “seat covers” was torn, and the suspension and brakes were completely shot. The car was one tire away from being crushed, after my horrible experience with the XJ-S, summarized under the background heading, I decided to do the work myself.
I’m no stranger to wrenching. In one of my many career paths I was an ASC and GM Certified Service Technician. Worked at the local Chevy dealer for a bit and decided this wasn’t a career path as much as a dead end job for me.
So I’m thinking, I’ve got skills… It’s a car… How hard can it be? I went out to Amazon and purchased an XJ Series III (abridged) manual; and was stuck right out of the gate. I won’t bore you with the details…
It was with the help of @Frank_Andersen and the others alike, I got my XJ6 running. Total cost in parts? $50.00 - a coil. Time to figure it out? well it was more than the “manual says it should’ve taken” by a factor of weeks; but the car runs!! and is now my daily driver .
This experience gave me the confidence that I CAN repair my Jaguar; and If I ever get stuck, I’ll have a wonderful group of blokes to fall back on, who are more than willing to share their knowledge and experiences to help us of less (Jaguar) experience and knowledge on how to keep our Jaguars on the road.
My point is this. We are here to help.
Background
My first Jaguar is an '88 XJ-S I purchased 20 years ago. the brakes went out, and I was intimidated by the whole inboard brakes thing. At the time I didn’t have the money to spend on the car to get it fixed. The car sat - for years. years of scraping up what cash I could I had enough to send it off to get repaired. I finally did. The car was towed off to the not so local “respected” Jaguar centric repair facilities to have the car gone through so it could be driven again. Ten grand later, I still can’t drive the car.
After I got over the initial sticker shock, and kept telling myself I get to drive my Jag again!!! I’m heading home, tickled pink I’m actually driving my XJ-S! When I noticed the engine temp climbing. It’s in the dead of winter barely above freezing mind you. I pull over, and upon inspection, The radiator was pissing out coolant. The mechanic who’d been assigned to my car had punctured the radiator core while replacing one of the hoses coolant hoses.
I called the repair facility; they refused to accept liability and said to bring the car back and they’d gladly replace the radiator for an additional $2,500. I declined their offer, and decided if I’m going to own a Jaguar I’m gonna have to learn how to repair one. I’m so disgusted by that whole ordeal, I can hardly look at the car, let alone think about working on it… So there it sits up on the lift.
Back to the point.
Tracking down an electrical problem in a Jag is less than straight forward, it’s a time consuming process, and if you’re paying someone to do the work, it can be hugely expensive.
Jaguar’s done some pretty unusual things, like
- Running the positive pole from one side of the car to another - like an extension cord along the bulkhead.
- There are countless amounts of butt & other wire connectors littered through out the car connecting minor wiring harnesses to major harnesses. Some are easily accessible, some you’ll have to dig for. These connectors, climate dictating, can be the sole source of random and sporadic electrical failures, and worse case fire.
- There are several grounding points on an XJ too. some easily accessible, some are not.
- Time + heat equates to cooked wires - brittle insulation and work hardened conductors and sometimes exposed conductors (like in my XJ6 YouTube video “Here’s how to put the spark back in your Jag” - shameless plug) can be sources for sporadic electrical malfunctions and are the things that make tracking down an electrical problem so time consuming on a Jag.
Retired? then sound like you may have a bit of time to get it sorted.
We’re here to help.
Sincerely,
Mark
