jag-lovers-digest Sunday, 1 September 1996 Volume 02 : Number 322
Re: Wind Shield wipers (XJ)
XK engine spark plug harness
RE: XJS Wiring Help Needed
Re: Knock-off wrenches
Re: XJS wiring help needed
64 E-Type Brakes
XKE Batteries
Re: 64 E-Type Brakes
WW parking position
Alternator conversions
Re: XJS Engine cleaning–cooling overhaul
E-Type Section of Web Site
Re: E-Type mirrors
Re: S1 E Alternator Conversion
Utilitarian solution to : <Wind Shield wipers (XJ)>
Re: XK engine spark plug harness
Re: S1 E Alternator Conversion----------------------------------------------------------------------
Date: Sat, 31 Aug 1996 13:14:51 -0500
Subject: Re: Wind Shield wipers (XJ)
Kirbert wrote:
Steve Coleman:
If you disassemble the wiper motor you will find a gear inside whose
position can be reversed (or something to this effect) which will make
the wipers park on the other side.Both arms have an angular bend toward the side they park on, so they
park nearly parallel to the bottom of the windshield. If you alter
the parking as noted, won’t you need to replace the arms with ones
that bend the other way to avoid the wipers pointing up at steep
angles when parked? Or is it possible to merely BEND the arms you’ve
got?– Kirbert | If anything is to be accomplished,
| some rules must be broken.
| - Palm’s Postulate
You can get wiper arms with the bend in the opposite direction to
accomodate the new parking position. I remember trying to bend the
original ones and it was not possible, at least for a cosmetically
acceptable result.
Steve Coleman, Gadsden, Alabama
1987 XJ6
1989 XJ40
Date: Sat, 31 Aug 1996 14:50:02 -0400
Subject: XK engine spark plug harness
I have an NOS spark plug harness on my 4.2L E-type. The problem I have is
that the cardboard organizer should be held in place by two of the head
bolts. If I loosen just these two bolts, will I risk warping the head, or
should I undo all the bolts and retighten in the proper sequence?
Mike Frank
1969 E-Type 2+2
Date: Sat, 31 Aug 1996 15:28:52 -0005
Subject: RE: XJS Wiring Help Needed
The microswitch on the throttle is used in
conjunction with a vacuum operated switch to
provide what the manual refers to as “full fuel
loading”. It causes the EFI to drop out of closed
loop mode when these switches close. Basically
it enriches the mixture under conditions of heavy
acceleration. Interestingly, it seems this is only
used on North American models, so it’s probably
not very necessary.
Up until recently, the North American models were the only ones that
HAD a closed loop mode to drop out of! If you have such a system,
it’s probably pretty important that you have this switch!
The rubber hose is the distributor vent inlet.
I think it is supposed to attach to the air
filter. Mine is also “just there” and I can’t find
a fitting on the air filter to which I might
attach it.
There are two hoses for venting the distributor. One is from the
engine side of the air filter housing. The other is connected to a
small filter (looks like a fuel filter) and simply draws air from
inside the engine compartment; the other end of this filter isn’t
connected to anything. The slight vacuum on the engine side of the
air filter housing is what draws air through the distributor.
| - Palm’s Postulate
Subject: Re: Knock-off wrenches
On this topic, I was thinking of making a steel impact wrench attachment with brass lined jaws that would fit knock-offs. I think a heavy duty 1/2" impact gun would be sufficient, although a 3/4" might do the job better. From what Ryan said, it sounds like he easily had 200+ lb-ft of torque on the thing without budging it. Any ideas? Impact is not really comparable to steady torque. However, since knock-offs are DESIGNED to be installed/removed with a HAMMER, I kinda doubt if a 1/2" torque wrench will be very good for removal, especially when stuck. I used to work in a power plant, and the nuts holding the turbines together (about a 4" diameter thread, the turbine was the size of a mobile home) were tightened and loosened with what is called a “sledging wrench”. Essentially this is a relatively short wrench that fits the nut and has a block on the end of the arm for hitting with a sledgehammer. Seems to me that such a device might be adaptable to the knockoff problem. Fashion a wrench with soft jaws that fits the knockoff and with a short arm, perhaps 8 inches, with a spot on it to hit with a sledgehammer. If it doesn’t line up right for hitting, just roll the car forward or back until it does. I believe some of the mail-order outfits offer such a critter, although they claim it’s to protect the tangs of the knockoff from impact rather than to provide a better removal torque. Kirbert | If anything is to be accomplished, | some rules must be broken. | - Palm’s Postulate From: “Kirbert” palmk@gcn.scri.fsu.edu Date: Sat, 31 Aug 1996 15:28:52 -0005 Subject: Re: XJS wiring help needed First, under the bonnet there are two wires comming out of a harnes near the throttle “cam” where the throttle cable connects to the “cam” and there is a microswitch on the side of the cable. These two wires are Green and Green with a yellow tracer. The green one appears to have been snipped off the microswitch with cutters (pourposefully) the Green with Yellow tracer gives me no clue. What are these? Do I need them? What is the microswitch? It doed not seem to be working or at least I could not get it to “click”. You need this switch to give you full power when floored, since it kicks the EFI out of feedback mode and into power mode. As such, it will also probably help prevent burned pistons under full throttle conditions. Yeah, I’d fix it. The microswitch is available from any electronics supply store, complete with roller. You might wanna check first, however, and make sure yours doesn’t simply need adjustment. Loosening the screws allows you to reposition it a little. Second, under the bonnet on the left side just under where the hood brace ataches to the fender there is a black with pale yellow or maybe white tracer that has a connector in the end. It appears to go nowhere. What is this for? I dunno, but mine has it as well. Third, in that same location is a rubber vacuum hose with what appears to be an inline fuerl filter in the end of it. It too goes nowhere. What is it and where should it go? Ventilation for the distributor. It’s SUPPOSED to be just like that, to take in air from within the engine compartment. However, I installed a longer hose and relocated the filter to in front of the radiator so it would draw cooler outdoor air. And finaly, under the drivers carpet on the left side of the car there is a five wire cable that comes from under the drivers seat. The black wire is grounded under a screw into the floor pan under the carpet, the red wire is hanging loose, the yellow wire is cut off, and two wires, Brown and White, go up under the left side of the dash. Any idea what this is? Just a guess: one of those seat belt buzzer systems? Another guess: maybe your car had a driver’s seat heater at one time. Kirbert | If anything is to be accomplished, | some rules must be broken. | - Palm’s Postulate From: “Kirbert” palmk@gcn.scri.fsu.edu Date: Sat, 31 Aug 1996 15:33:29 -0005 Subject: Re: Wind Shield wipers (XJ) Kirbert wrote:
angles when parked?
Steve Coleman:
acceptable result.
Where do you get them? Is this via ordering the wiper arms for a
RHD Jaguar (LHD if we’re talking about a RHD car), or using some
generic arm? Are there generic arms that fit the Jaguar posts?
| - Palm’s Postulate
Date: Sat, 31 Aug 1996 15:51:21 -0500
Subject: 64 E-Type Brakes
I finally tracked down the source of my brake fluid leakage. It’s in the
master cylinder for the rear brakes. The newspapers-on-the-floor trick did
it. I pryed
off the rubber dust cap and fluid was dripping out of the cylinder. Looks
like all I’ll need is a new master cylinder (if they exist) or a rebuild
kit. Also, if I used a kit, the bore may have to be resleeved.
Date: Sat, 31 Aug 96 15:11:20 CST
Jim:
The green and green\yellow wires and microswitch are for the automatic
transmission “kickdown” function. My car had intermittant operation for a while
so I replaced the switch and it works fine now. The switch is a standard issue
but I don’t have the number available right now. Also, on my car you have to
stomp the pedal pretty hard to get the switch to actuate.
Larry Conrad
'83 XJ-S
______________________________ Reply Separator _________________________________
Subject: XJS wiring help needed
Author: JISBELL@mail.utexas.edu at INTERNET
Date: 8/31/96 12:35 PM
Date: Sat, 31 Aug 1996 17:55:58 -0400
Subject: XKE Batteries
Thanks to everyone who replied. I currently run an Interstate battery, which
the PO had installed almost five years ago, so I know they work and last. I
have two problems with replacing it with the same:
1. The fit is not really the correct (I have just replaced all the
rusty/worn components in that area, including a new battery tray and hold-down.)
2. It looks like sh*t. The E-Type engine compartment is a wonderful bit
of eye-candy, but the Interstate battery looks like the color pull-out
section of the Sunday paper.
I have used repro Mopar batteries from New Castle Battery, and was
hoping that their Lucalike was as good.
So I am still undecided. I suppose I will buy the New Castle, just to
try something different, and maybe a little better. I’ll post the list.
Mike Frank
1969 E-Type
Date: Sat, 31 Aug 1996 18:49:48 +0100
Subject: Re: 64 E-Type Brakes
At 03:51 PM 31/08/96 -0500, Bob Richardson wrote:
…source of my brake fluid leakage…master cylinder
Looks like all I’ll need is a new master cylinder (if they exist)
or a rebuild kit.
Bob,
The major mail order places (SICP, Welch, etc) all have
master cylinders and kits. Hopefully you just will have to
kit it out -the kits are quite inexpensive. Good luck.
Charles Daly, Toronto, Canada
'62 E-Type, ots
Date: Sat, 31 Aug 1996 18:08:46 +0000
Subject: WW parking position
Kirby,
Yes there is a slight bend, but its only a few degrees. If they are
supposed to park parallel to the bottom of the windshield, they dont.
If they did I wouldnt complain. The problem is that they are parked
at least 4" off the bottom, in my line of sight. They actualy park
much lower on the right side when I just turn off the wipers when
they get there. Even with the bentd they are lower than the parking
position on the left.
Strange thing, my 1982 XJ6 parks on the right side where they
should.
I think I will try the gear thing, or at least look at it.
There isnt someone in England that wants to swap WW arms is there?
If we reverse the gear and get them to park correctly the postage on
two wiper arms shouldnt be too much and we would have a correct
system.
Subject: Alternator conversions
I have been thinking about one of those “one wire” alternators that
JC Whitney sells for $60. The one wire hooks straight to the
battery and the regulator is built in. My concern is how much of the
old wiring (regulator, etc.) can/must be removed.
Anyone have any experience with the “one wire” alternators?
Date: Sat, 31 Aug 1996 21:08:05 -0400 (EDT)
Subject: Re: XJS Engine cleaning–cooling overhaul
Question #1) Can I spray clean it with one of those pressure sprays
or will water collect in places I dont want it to like it does in the
spark plug holes of a 4.2? It is not greasy, just very dusty.
I do it that way.
Question #2) Do I have to remove the hood completely to remove the
radiator and water pump? Should I?
No and yes. The pump can be done with the bonnet in place but it is
no picnic. Technically it might be possible to do the radiator with
the hood in place by just removing the gas struts and supporting the
bonnet fully open. I would advise against trying this. It is much
more “fun” working on that car with the bonnet out of the way. The
job you are about to embark on is a sizeable one. Make life easy.
Take the hood off.
Thomas E. Alberts
Date: Sat, 31 Aug 1996 21:23:55 -0400 (EDT)
It is the kickdown switch for the automatic transmission. The switch
should engage when the throttle pedal is fully deppressed.
es to
this for?
I think the only wires at that location are for the O2 sensor. Is the
comnnector like the kind on the fuel injectors?
Yes. That is the inlet for the distributor cap vent. There are two hoses
connected to the distributor capp. One is vacuum. The other goes to that
filter. There would not be a hose connected to the other end of that filter.
idea what this is?
Doesn’t sound familiar. Do you have a car phone or after market stereo?
Thomas E. Albers
Date: Sat, 31 Aug 1996 21:17:18 -0500
acceptable result.Where do you get them? Is this via ordering the wiper arms for a
I got them from the Jaguar dealer in West Palm Beach (I was living in
Vero Beach at the time). I had to explain at length what I wanted, that
is, wiper arms with the bend toward the right, but they did get it
right.
1987 XJ6
1989 XJ40
Date: Sat, 31 Aug 1996 19:36:50 -0700
Subject: E-Type Section of Web Site
Larry, I notice that we still don’t have anything yet on the
Jag-Lovers Net Guide web site specific to E-types. If I remember
correctly, someone said they were working on this section some months
ago. What happened? How can we contribute our experiences with restoring
and owning E-types?
Date: Sat, 31 Aug 1996 19:30:57 -0700
Subject: Re: E-Type mirrors
Mike, just to satisfy my curiosity, does your interior mirror appear to
have some mechanism for “breaking away” from the rod in an accident?
I’m curious because all cars sold in the USA during the early 70’s had to
meet certain federal safety and emission standards. The breakaway mirror
was one of them because it’s mentioned in the manual for my 73 Datsun
240Z. It may be possible that Jag snuck one past them but I bought my
Datsun new in 1973 and know first hand what kinds of problems the
government standards presented.
Believe it or not, my Datsun sat on a dock in California for 4 months
before it could be delivered to me because it didn’t meet certain
California emission standards and had to be modified by a team of Nissan
engineers!
I’m not sure how a flying projectile like a “break-away” mirror
represents a safety feature but remember those scariest words:
“I’m from the government and I’m here to help you!”
Date: Sat, 31 Aug 1996 19:56:43 -0700
Subject: Re: S1 E Alternator Conversion
Hunt, back when I still had my 64 E OTS, it seemed that I lost the
generator about once a year. If I remember the mechanism of failure
correctly, the generator has a ball bearing in the front and a bronze
bushing in the rear. On mine, the bushing would fail and allow the
brushes to ground out, destroying the windings on the armature. I would
take it to an old-timer at Barney’s Auto Electric and he would rewind it.
After about the third time, he got disgusted with the thing and found a
Delco generator the same physical size from a Cadillac, I believe. He
reversed the polarity on it to positive ground (er earth), and machined
the original pulley to a thickness that allowed the belt to line up. I
never had any more problems with electrics after that!
I can just imagine the next owner though if he ever did have to get it
repaired! What do you mean Delco is not a division of Lucas?
Date: Sun, 01 Sep 1996 19:59:36 -0700
Subject: Utilitarian solution to : <Wind Shield wipers (XJ)>
Several people have posted regarding their windshield wipers woes. The way
I have dealt with mine has been to patiently reposition the wiper arm in its
socket (where it attaches to the shaft from the motor assambly; it is
secured with a nut and washers) until the wiperarm (both), rest on the
chrome trim surrounding the windshield. May not look the greatest from the
outside, may offend the original idiot that designed the wipers to begin
with, but it works and it gets them out of my eyesight. All it takes is
patience playing around with the fit on the post. Hope this helps.
Rob W-M
85 XJ-s
Date: Sun, 1 Sep 1996 00:18:45 -0500
Subject: Re: XK engine spark plug harness
should I undo all the bolts and retighten in the proper sequence?Mike Frank
1969 E-Type 2+2
When I had my Series One E-Type engin rebuilt several years ago, the
mechanic said to get rid of that cardboard organizer. Should moisture
accumulate within the harness, you may get misfiring of the plugs. I think
it’s best to keep the ignition wires as separated as possible for ultimate
performance. Mind you, this is just an opinion.
Date: Sun, 1 Sep 1996 00:29:59 -0500
generator about once a year…
…after about the third time, he got disgusted with the thing and found a
Delco generator the same physical size from a Cadillac, I believe…
I too had generator problems with my 64 E FHC. And my Jag mechanic also
fitted a Delco generator. In my case I had to switch to a Mark II belt
because of the new pulley that was fitted.
End of jag-lovers-digest V2 #322
Return-Path: @owner-jag-lovers-di1
Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4)
id for jag-lovers-digest-out; Sun, 1 Sep 1996 16:01:29 +0200 (MET DST)
Date: Sun, 1 Sep 1996 16:01:29 +0200 (MET DST)
Message-Id: 199609011401.QAA08875@ekeberg.sn.no
X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f
To: jag-lovers-digest@sn.no
Subject: jag-lovers-digest V2 #323
Reply-To: jag-lovers@sn.no
Errors-To: @owner-jag-lovers-di1
Precedence: bulk
X-Newsgroups: mail.jag-lovers-digest
jag-lovers-digest Sunday, 1 September 1996 Volume 02 : Number 323
Jaguar Paints
Re: SI E Alternator Conversion “Call for Papers”
Re: Alternator conversions
Re[2]: XJ50
Re[2]: XJS Wiring Help Needed/workshop manuals
Re[2]: Wind Shield wipers (XJ)
MkVIII Window Rubbers
RE:electrical help
XK originality - various
XJ-S Boot Lid Woes
Jaguar Suppliers (posted monthly)
Date: Sat, 31 Aug 1996 21:33:02 -0700
Subject: Jaguar Paints
I am curious about the type of paint that Jaguar was using in the early
70’s. Was it a lacquer or an enamel? If it was enamel, what type,
acrylic, alklyd, etc. My interest has to do with restoring my 70 E OTS
which is painted Regency Red.
I am thinking about a complete re-spray and have looked at Glasurit
two-pack which is a catalyzed epoxy I think. It is very expensive at
around $380 per gallon (4 litres) US just for the paint.
I am concerned about the future. If the paintwork got scratched, could
the epoxy be retouched? I know that enamel is relatively easy to match
and retouch having done it several times myself on my 240Z.
Are there any experts out there who could put in there 2 cents (pence,
etc) worth?
Date: Sat, 31 Aug 1996 21:38:27 -0700 (PDT)
Subject: Re: SI E Alternator Conversion “Call for Papers”
Bob-
Thanks for your reply. Which alternator and bracket did you use? Did they
bolt in?
Hunt
At 12:30 PM 8/31/96 -0500, Bob Richardson wrote:
I just managed to get 100 miles out of my newly reconditioned generator on
my '62 E. I plan to pull it in the next few days and resubmit it for repair,
but this has gotten me thinking about alternator conversions, if for no
other reason that to get the part farther away from the exhaust manifold!I (an I’m sure others), would love to hear from those of you who have
successfully done this – particularly if you have found alternators that
are direct bolt-ons for the original generator.Thanks!
Hunt
I changed over to an alternator for my '64 E-Type in 1978 and it makes all
the difference in the world in keeping the battery topped while running air
conditioning, sitting in traffic, etc. Trouble is the alternator sits flush
against the subframe’s steel tubing. The only fan belt that would fit is
for a Mark II; the 4.2 belt is too long and the 3.8 belt is too short. If I
could afford it, I’d get rid of my Moss box and also the rubber bellows
vacuum server.
Date: Sat, 31 Aug 1996 21:38:44 -0700 (PDT)
Subject: Re: Alternator conversions
Jim-
I was discussiong this with my brother last week. He has several MGs and is
quite active in his MG club. Quite a few of the MG folk do this, and simply
jumper across the cuttout contacts on the regulator (or as appropriate).
This looks stock (other than the alt.), and maintains appropriate wiring to
the car. I believe the warning light then gets wired to one of the terminals
(I just put a new alt. in my XJ-6, of the “one-wire” vareity. Actually three
terminals: a field terminal, for noise supression capacitor, output, and the
warning light (I’m pretty sure – maybe an enable line from the ignotion).
Hunt
old wiring (regulator, etc.) can/must be removed.Anyone have any experience with the “one wire” alternators?
Date: Sat, 31 Aug 1996 21:38:48 -0700 (PDT)
Sounds like a good approach, too. It may be possible to put the rear-plate
from a generator with real bearings in. I think a small frame alternator
might be nice, if for no other reason than it would be a couple of inches
farther from the manifold. On the other hand, it would be nice to just have
it work for awhile (boy, are those bolts hard to get to!)
Thanks!
Hunt
take it to an old-timer at Barney’s Auto Electric and he would rewind it.After about the third time, he got disgusted with the thing and found a
never had any more problems with electrics after that!I can just imagine the next owner though if he ever did have to get it
From: “Richard.Mansell” Richard.Mansell@psemail.ps.net
Date: Sat, 31 Aug 1996 22:02:00 +0100
Subject: Re[2]: XJ50
Jaguar World Vol8 No 1 September/October 1995 has an article
celebrating 60 years of Jaguar
This lists the Series 3 V12's as follows:-
XJ12 4dr March 79/Nov 92 2,861
XJ12 VDP 2,553
XJ12 Sovereign to '88 6,438
Double-Six VDP 1,159
Double-Six 6,355
Richard
Subject: Re: XJ50
Author: /S=owner-jag-lovers@sn.no/O=SMTP/P=PSC/A=MCI/C=US/ at ccx400uk
Date: 30/08/96 23:37
Sort of. As far as I remember, the XJ12 III was produced in parallel to
the XJ6 III, I don’t know production figures but I guess the 6 was a lot
more popular than the 12.
I can’t split the production figures but the figures I do have say totals
for 6&12 are
Series 1 = 98,527, Series 2 = 127,078 and Series 3 = 177,243
Robert Bradley
82 XJ 4.2 (2 off), 87 XJS, 54 Mk 7
Date: Sat, 31 Aug 1996 22:04:00 +0100
Subject: Re[2]: XJS Wiring Help Needed/workshop manuals
>> "and there is a microswitch on the side of the cable"
Could this not actually be the kickdown switch?
The distributor filter being "just there" is normal. I have heard it
was added to vent the distributor after problems with fuel vapor.
A word of caution about the factory workshop manuals:-
Having just purchased an '89 XJ-S I ordered the factory manuals that
appeared to cover mid 88 until the facelift model. I already have the
pre-HE to mid 88 manual set but a lot has changed, Mirelli ignition,
air con etc. The manuals that turned up were actually the manuals for
the pre-HE to mid 88.
I had a stand up row with the parts manager who swore blind that they
were the only manuals available and that they were the manuals he
ordered for the workshop. After a bit of persuasion he went to talk to
the workshop who explained to him that most of the changes since late
88 were actually in the facelift to present day manuals.
Unfortunately the later manuals do not cover the earlier cars. This
appears to mean that if you want comprehensive manuals for a late 88
to facelift model you need both sets! When my parts manual and
workshop manual set turns up on Tuesday I should be geared up to
answer most XJ-S related questions :-)
Richard
Date: 31/08/96 18:36
Jim,
not very necessary.
attach it.
I’ll check on the other under bonnet wires you
mentioned this afternoon.
Phil
Subject: Re[2]: Wind Shield wipers (XJ)
It’s my understanding that RHD XJ-S’s wipers park to the right
and LHD park on the left – so it’s in your face, regardless of where
you live!
According to the XJ-S Collectors guide by Paul Skilleter the wiper
position was changed after Aug 89 (1990 MY) when the Electrolux
wiper system replaced the Lucas.
In reality both my UK 80 and 83 XJ-S’s hung to the right whereas
my June 89 hangs to the left. That’s me happy, shame about the
wife.
Richard
Date: Sun, 01 Sep 1996 19:04:58 +1100
Subject: MkVIII Window Rubbers
Hi. I am Clive Bell in Australia and I wish to enquire if NDV window rubbers are available or made on order
from specialised suppliers for a MARK VII Jaguar Saloon. This car has won a number of Concours events in
Australia, however new vent rubbers, front and rear, are in urgent need of replacement.
Any information available would be greatly appreciated.
REGARDS CLIVE.
Date: Sun, 01 Sep 96 13:47:25 -0700
Subject: RE:electrical help
Problems with 83 XJ6:
1.Antenna keeps blowing fuses, could be the system is in need of lubrication.
2.Check fuse and connections under the bonnet these sometimes get forgotten if
there has been any major overhaul work.
3.Interior light problems, check wiring for cuts in the insulation take special
care around the door frame. Check the light units for shorting to the body/doors.
Also check there is no shorting on the dashboard switch.
4.Check the steering column switch for bad connections. If all OK then motor is
faulty.
5.Many possibilties for the A/C not working properly.
Check compressor clutch engages when system operated, if engaging check for air
bubbles in the dryer sight glass, could be low or empty of refridgerant. If
clutch not engaging the limiter switch, overtemp fuse mounted at front of
compressor, may have blown(cheap fix).
The A/C on jaguars is very complicated and you would be best advised NOT to try
and fix it yourself apart from fuse and drive belt changing. Seek out your local
A/C specialist, they aren’t as expensive as some people belive.
Best of luck
Barrie Dawson
Chatham, Kent England
1985 seris III Jaguar Sovereign
Date: 01 Sep 96 09:26:57 EDT
Subject: XK originality - various
A few points that arose at a Jag meeting this weekend:
- XK120 brake fluid reservoir tops: most of the ones I have seen are non
bright plated, including a new onw I bought a few years ago. However, the 1,000
mile alloy car 670178 in the Jag World article shows the top all painted black.
Another friend said that he had seen Mk VII roadtest photos with just the cap
painted black. Anyone any idea how far the black painted tops were used?
- XK120 fuel lines: the consensus seemed to be that these were copper (and not
otherwise finished) and that 140/150 were steel with non-bright plating.
- XK chassis painting: an otherwise knowledgeable English XK guy says that
the chassis were dipped (not sprayed) when new. This has some repercussions on
what suspension etc fittings were chassis black.
- XK120 hood (soft top): what is the distance from the end of the hood up to
the rear window frame? I don’t suppose anyone out there has got an original 120
hood (or have you?). I don’t think I have ever seen one actually/.
- XK120 side screens: I was told that early cars have the chromed frame
meeting in a point at the lower front, and that later cars have a rounded frame
there. I have not yet checked my own records.
All comments welcomed. Regards, John Elmgreen
Date: Sun, 01 Sep 96 08:42:52 -0500
Subject: XJ-S Boot Lid Woes
My '86 Boot lid seems to be permenantly locked.
A few days ago it failed to latch. I discovered
that the bar to which the lock latches had become
loose and dropped down too low. Pulled it up
(all the way) and tightened it then shut the lid
as normal. There was no abnormal resistance,
unusual noises, etc. , however now the thing won’t
open. It acts as if the keying of the lock has
suddenly changed. The key won’t turn the lock.
- Any ideas as to what is wrong?
- Suggestions on how to repair it?
- How can I get the lid open to attempt a repair?
Thanks,
Phil Patton
Date: Sun, 1 Sep 1996 09:00:07 -0500 (CDT)
Subject: Jaguar Suppliers (posted monthly)
Suppliers, North America (mostly).
[This list is automatically sent out on the first of each month.]
Updates:
changed phone # and address for Gran Turismo
(Corrections, etc, to: jjoy@risc.sps.mot.com)
The majority of this list has come from Rob Reilly reilly@admail.fnal.gov
SUPPLIERS OF JAGUAR PARTS AND SERVICES Rev. 8-1-96
A D Motor Rebuilding, NY 1-516-395-5101
Lucas, Smith’s motors rebuilt
Al Hogan’s Autojumble Mansfield, Ohio 1-419-524-1088
NOS parts supplier
Specializes in buying out old dealer stock. Owner (Al) is knowledgeable
about british car parts.
- -Steve DuChene s0017210@cc.ysu.edu
Dick Ames, 608 Ft. Williams Pkwy, Alexandria, VA 22304 1-703-370-3097
stainless exhaust systems
Best price on stainless steel exhaust systems. I’ve misplaced the
address but can probably look it up if pressed.
- -PKR@SLACVM.SLAC.Stanford.EDU (Patrick Krejcik)
Ancient Car Parts, 64 N Main, Lyndonville, NY 14098 1-716-765-2894
rust repair panels for XJ
Apple Hydraulics, 715 Route 25A, Miller Place, NY 11764 1-800-882-7753
rebuilds Armstrong, Girling shocks, SU carbs 1-516-744-9627
Asom Electric, 1204 McClellan Dr., Los Angeles, CA 90025 1-310-820-3720
email: asomelect@aol.com 1-800-424-2766
Electrical rebuilding shop that deals mostly in Lucas and Bosch and
rebuild starters, alternators, generators, fuel pumps, voltage regulators,
wiper and window motors. They have a large supply of Lucas parts,
including discontinued items. In business for 36 years, have daily UPS,
and accept credit cards.
Atlantic Enterprises, Route 4, Box 394-B, Loris, SC 29569 1-803-756-7565
steering racks, seal kits, polyurethane rack mounts
Auto Interiors of Europe, 1790 E McFadden, Unit 107 1-800-533-2886
interiors Santa Ana, CA 92705
(not sure which addr. is correct)
3023 S. Orange Ave.
Santa Ana, CA 92707
(714) 751-9046
Nice stuff if I remember correctly. Not cheap but nothing for these
beasts is.
- s912!rick@bnf.com (Rick Ezneker)
Kent Bain, 1785 Barnum Ave, Stratford, CT 06497 1-203-377-6745
custom interiors, seat rebuilding and repadding
G.W.Bartlett, Muncie, Ind. 1-800-338-8034
interior and trim parts
Sells original Jaguar Interior kits and components. All to exact Jaguar
specifications. As per original spec. Quite costly but isn’t quality
always a bit more? (eg. Interior kit for Jag 3.8s is about $4200, retail.)
- zrol01@trc.amoco.com (Richard O. Lindsay)
Basset’s, Wyoming, R.I. 1-401-539-3010
restoration parts
Borla Industries, Oxnard, Calif. 1-805-983-7300
stainless exhaust
British Auto Center, 2938 SW Avalon Way, Seattle, WA 98126 206-935-0873
Lots of late model stuff, new and used. Very knowledgeable. Can
sometimes be grumpy. – Greg Meboe (meboe@wsunix.wsu.edu)
British Auto USA, 92 Londonderry Trnpk, 1-603-622-1050
British Auto USA Interiors Manchester, NH 03104 1-800-4-JAGPTS
interior and trim parts 1-800-452-4787
Exc. inventory of interiors and body parts. Limited inventory of
mechanical parts but I always check them out because they’re cheaper!
(I avoid Bartlets for Jag interiors)
British Car Parts, CA 1-818-788-7636
new and used parts
British Marque Auto PO Box 344, Bainbridge, PA 17502 1-717-426-2675
interiors
British Motor Service, 521 W. Katella, Orange, CA 92667 1-714-997-3800
Moss distributor, used XK parts
British Parts Northwest, 4105 SE Lafayette Hwy, 1-503-864-2001
new parts for late models, no sheet metal Dayton, OR 97114
British Restoration Parts, Kansas City, Mo. 1-800-821-3767
new restoration parts
British Spares, 46 Florence, Springfield, MA 01105 1-413-736-0463
fabricates panels for XK, Marks, E
British Vintages, 645-D Tank Farm Rd, 1-800-350-JAGS
San Luis Obispo, CA 93401 1-805-541-5986
Have their catalog but so far never used them.
British Wire Wheel, 1650 Mansfield St, 1-408-479-4495
Santa Cruz, CA 95062
Dayton and Dunlop wire wheels, tires
THE place to go for correct reconditioning of your JagWires. Also to
buy THE correct tires.
Bob Brosen, 7804 Billington Court, Oxen Hill, MD 20744 1-301-248-6327
new repro parts for pre-war, Mark IV, V
Classic Parts & Panels, Ltd. 0296 658938
Fleet Marston Farm, Bicester Rd., Nr Waddesdon
Aylesbury, Bucks, UK HD 18 ODZ XK panels
Classic Restoration Parts, Bellflower, Ca. 1-213-804-2756
XK grilles, gas tanks
Classic Tube 1-716-759-1800
A Division of Classic & Performance Specialists
80 Rotech Drive
Lancaster, NY 14086 USA
They supply steel and stainless steel pre-bent brake and fuel lines for
various makes of cars. I got half the brake lines and clutch lines
from them in stainless, and being the prudish restoration junkie I am,
I was concerned that the reproduction in stainless would not be very
“original”. However, I’m happy to say the final product is almost
identical to the original steel lines, most judges will not notice the
difference. – Mark Roberts (markdr@bnr.ca)
Concourse West, 644 Terminal Way, Costa Mesa CA 92627 714-642-9807
fax 714-645-8388
Have rebuilt diffs.
Cordell R. Newby, 1410 N. Aurora, East Wenatchee, WA 98801 509-884-6823
Specializes in Mark V parts. New and used.
Coshman Ent, PO Box 2685-J, Orcutt, CA 93455 1-805-937-7456
Whitworth tools, taps & dies, gauges, fasteners
Coventry Engineering, 9500 SW Martha St, Tigard, OR 97224 1-503-620-9482
wiring harnesses
Coventry S Ltd, 6406 85th Place, New Carrolton, MD 20784 1-800-537-4146
Joe Curto, 230-22 58th Ave. Bayside, NY 11364 1-718-465-4829
S.U. parts
Wes Czech, HCR 9550, Lucerne Valley, CA 92356 1-619-248-9603
XK parts
Stanley Daniel, 124 Parkview Rd. Cheltenham, PA 19012 1-215-782-1248
used Mark 7-9 parts from 30 cars, call after 9PM EST
Doctor Jaguar, 644 W 17th St, Costa Mesa, CA 92627 1-714-646-2816
parts, engines, trans, susp. parts
East Coast Jag Parts DE 1-302-731-7200
EJAG NEWS, Box J, Carlisle, Mass 01741 magazine, a few accessories
Engel Imports, Kalamazoo, Mich. 1-800-253-4080
new car dealer, will UPS, cheaper than other dealers
European Auto Specialists, 1-313-355-2730
OEM parts for late models
John Farrel, 4315 Murray St., Flushing, NY 11355 1-718-762-9071
NOS XK parts
Foreign Car Center, 1610 S Main, Milpitas, CA 95035 1-408-262-0325
used parts recycler
Grand Turisimo Jaguar 1-216-259-5656
4285 Main Street fax: 1-216-259-5588
Perry Village, OH 44081
engine rebuilder, parts
Specializing in high performance parts and services. They list a
‘level 5’ Jaguar V12 with all of the whistles and bells like porting,
balancing, etc. with 6, count them, 6 two bbl Weber carbs mounted
vertically across the top of the V12! This engine sells for about
$13,500. - zrol01@trc.amoco.com (Richard O. Lindsay)
Gunson Ltd., Pudding Mill Lane, London E15 2PJ
UK source for ColourTune
Tony Handler’s Foreign Parts Connection 1-213-473-7773
2028 Cotner Ave, Westwood, CA 90025
H.D. Rogers & Sons 1-318-742-3651
3418 Barksdale Blvd. fax: 1-318-742-5044
Bossier City, LA 71112
email: hdrsons@iamerican.net
Family-owned business supplying used, NOS, discontinued parts as well as
enhancements for newer cars. For example, they offer aftermarket a/c
hoses for XJ series and a less expensive amplifier. They try to give
special rates to internet users. They also have contracts worldwide
and will try to locate hard to find items, and offer special prices for
prepaid orders from overseas.
Harry CA 1-408-262-0235
used parts
H.P. Co., 1079 Colonial Club Dr, Harahan, LA 70123 1-504-737-4691
burled walnut dashboards
I-35 Imports Oklahoma 1-405-799-2886
used parts, 80 and older
Intermarque Auto Parts Houston 1-800-666-8700
parts and sheet metal
International Spare Parts 1-800-243-0073
J.K.Restorations, 12 Jackson, Oswego, IL 1-708-554-2120
complete restorations, specialist for XK and E, some used parts
Jag Atlanta, 3437 Sexton Woods Dr, Chamblee, GA 30341 1-800-533-8973
new, used parts for E and XJ 1-404-455-0175
Jaggist (Alan Trickel) 1065 Hillview, Ashland, OR 97520 1-503-535-8486
used XK parts
Jaguar Cars Inc, Public Relations, Mahwah NJ 1-201-818-9770
For a fee will authenticate your VIDNs.
Jaguar Denver 1-800-426-4515
Lucas, Girling, Jag parts
Jaguar Heaven, 1433 Tillie Lewis Dr, Stockton, CA 95206-1130
info: 1-209-942-4524, orders: 1-800-969-4524, FAX: 1-209-942-3670
used parts recycler, all models
Jaguar Interiors of England, PO Box 47, Muncie, IN 47308 1-317-289-9901
carpeting and upholstery
Jaguar Motor Works, 3701 Longview Dr, Atlanta, GA 30341 1-800-331-2193
used XJ parts recycler, rebuilt parts Local 404-451-3839
FAX-404-451-7561
Jaguar of North America, Leonia, NJ 1-201-592-5200
factory American distributor
Jaguar South Greenville, SC 1-803-244-1555, 1-803-292-3934
used parts recycler
Jaguar parts SC 1-803-754-5363
Jaguar Warehouse, 6010 Mardale Lane, Burke, VA 22015 1-703-451-4071
NOS parts
Jaguar Warehouse, 5727 Walcott Ave, Fairfax, VA 22030 1-703-968-3983
XK parts
J C Whitney, Chicago, IL 312-431-6102
Also known as Warshawsky/Whitney. Sells car parts cheap for most cars
including LBCs. Massive buying power. Brainless order-takers. You
can call in the middle of the night for good long-distance rates. They
will not tell you brand names. All the swaybars are ADDCO. See also
ADDCO and Werace. - ?
J.C. Whitney offers a few items that are of interest. Things like generic
weatherstrip by the foot, etc. The do offer after market A/C units and
high output quartz halogen 7 inch headlights (110 watts!!!). The ad
carries the label ‘Not legal for street use.’ They look really cool.
John’s Cars, 800 Jaguar Lane, Dallas, TX 75226 1-214-426-4100
fax: 1-214-426-3116
V-8 conversions, other repro parts, claims improvements over stock
Just Jags, 407 Industrial Dr, Carmel, IN 46032 1-317-844-8823
new, used parts, service, restorations
Just Jags, 8720 Big Bend at Elm, St.Louis, MO 63119 1-314-968-2450
service, parts, restoration shop
Keller Associates, PO Box 2833, Saratoga, CA 95070 1-408-370-3705
burl walnut dashboards
Lister of North Am, 1912 Granvill Av, Muncie, IN 47308 1-800-338-8034
high performance accessories
Lovello, Mark SC 1-803-244-1555
used parts
Moss Motors, PO Box MG, 7200 Hollister Av, Goleta, CA 93116 800-235-6954
new and repro parts for XK’s
Moss Motors, Santa Barbara, California 1-805-963-0741
new car dealer
Cordell Newby, 1625 N Western, East Wenatchee, WA 98801 1-509-662-7748
new, used, repro parts for pre-war, Mark IV, V
added: Jul. 29, 1994
Nisonger Instrument Sales & Service 1-914-381-1952
570 Mamaroneck Ave. fax: 1-914-381-1953
Mamaroneck, NY 10543
Repairs capillary based guages.
“I had them repair my water temp gauge 2 months ago. Charge was $100 including
shipping, turnaround time was 2 weeks, and they take plastic.” Rob Reilly
Northwest Modern Classics, 121 Duryea, Raymond, WA 98577
interiors, carpets, upholstery, tops 1-800-854-1751,1-206-942-5532
Northwest Transmission Parts, Ohio 1-513-442-2811 or 1-800-327-1955
auto trans rebuilding kits, torque convertors
Peninsula Imports, 3749 Harlem Rd, Buffalo, NY 14215 1-800-999-1209
XJ, E body and rust repair panels 1-716-833-3000
Fred Petroske, RR1, Box 112, Chaumont, NY 13622 1-315-649-2861
Paul K. Phillips 1-305-846-7976
1124 N. W. 134 Ave. fax: 1-305-846-9450
Sunrise, FL 33323
Specializes in the XJ Coupe market and runs an XJC register.
“I have dealt with him once on an exhaust system (via a referral from
SICP) and got good service. He does require cash C.O.D. (no credit cards)
which is a bit of a bother.” - gladish@suite.com (Brian Gladish)
Phil’s, Inc. Ashland Ave, Evanston, IL 1-708-869-2434
PII Distributing, PO Box 27358, Houston, TX 77227-7358 1-800-231-5836
genuine Jaguar parts, sheet metal 1-713-975-6272
Chuck Pilate, 24996 W Magdalena Dr, Mt Clemens, MI 48045
XK, E parts 1-313-791-0429
Rich’s Import Auto Parts & Serv, 730 N Glebe Rd, Arlington, VA 22203
parts for E, XJ and 62 on sedans 1-800-336-6603, 1-703-522-0440
Rhino Auto Parts, Hanover, MN 1-612-498-8711
used and NOS parts 50’s to 70’s
Rhode Island Wiring Service, Box 3737H, Peace Dale, RI 02883
wiring harnesses 1-401-789-1955
Martin Robey Panels, Pool Rd, Camp Hill 011-44-203-386-903
Industrial Estate, Nuneaton, Warks CV10 9AE England
Rodney, 2035 Cornell St, Sarasota, FL 33577 1-813-955-5960
used parts recycler
SCJ, 3 Elizabeth Ave, Burlington, MA 01803
NOS parts, pre-war to 61
Samplex, 30 Parkview Dr, Succasunna, NJ 07876 201-584-9370
US source for ColourTune
Special Interest Car Parts, 1340 Hartford Ave, Johnston, RI 02919
voice: 1-800-556-7496, 1-800-851-5600, 1-401-831-8850
fax: 1-800-672-SICP(1-800-672-7427), 1-401-831-7760
We have parts for your Jaguar, MG, Healey, TR. Good prices. Superb
catalog. Parts from XK120 through XJ40 including e-types. Will often
meet or beat prices from competitors.
S&S Specialties, 108 Sation St, Cumming, IA 50061 1-515-981-9148
NOS, rebuilt and used parts for XK, Mk and E, sheet metal parts
Stainless Steel Muffler Corp, 3032 Genesee St, Buffalo, NY 14225
stainless exhaust systems 1-716-893-2116
Terry’s Jaguar Parts, 117 E Smith St, Benton, IL 62812 1-800-851-9438
new and used parts for later models 1-618-439-4444
Bill Tracy, Sarasota, Florida 1-813-924-9523
Trans Ocean, Dept PDH, 390 Olive Tree Lane, Sierra Madre, CA 91024
Lucas parts jobber, '30 to '76 British cars
Welsh Jaguar Enterprises, Steubenville, Ohio 1-800-875-5247
new and repro parts for XK’s and newer 1-614-282-8649
fax: 1-614-282-1913
Catalogue available. (free)
The best prices for Jaguar parts that I have found.
Exc. inventory of parts, new and used. Can offer helpful technical advice.
Ed West, 1941H Jan Marie Place, Tustin, CA 92680 1-714-832-2688
new, used, repro parts for earlier Jags
Ed west has lots of intresting stuff at very resonable prices and lots
of advice. – m_skogs@ix.netcom.com (Matthew Skosberg)
White Post Restorations, White Post, VA 22663 1-703-837-1140
restorations, brake and clutch cylinders resleeved
XK’s Unlimited, 850 Fiero Lane, San Luis Obispo, CA 93401 1-805-544-7864
new and repro parts for XK’s 1-800-444-JAGS
In CA: 805-544-7864 FAX: 805-544-1664
catalog available. ($6.00, refundable first order)
“Parts & Service for all model Jaguars from 1948 on” XK’s Unlimited is
a good place to send Girling calipers for for piston bore sleeving. -?
XK’s Unlimited is good, but is a bit higher than Welch Jaguar. They
are also committed to “correct” parts. Additionally, you can call them
without a part number. Just be sure that they tell you what is
included in the replacement part. - zrol01@trc.amoco.com (Richard O.
Lindsay)
Good inventory and advice, but pricey. Nice catalogue. Has a
restoration shop sleeving brake cylinders in stainless.
XKSS Interiors, Thousand Oaks, CA 91359 1-800-922-XKSS, 1-805-482-4682
Vicarage Jaguar 1-305-444-8759
% Gables Cats fax: 1-305-443-6443
220 Granello Avenue
Coral Gables, FL 33146
vicarage@ix.netcom.com (alt. vicarage@paradise.net)
http://paradise.net/vicarage
Vicarage says: If one is in need of specialized or hard to find parts
we will have them. In addition we do offer the unique Vicarage
upgrades and enhancement products for all post war Jaguars.
Zimmer, Bob 2675 Stoney Brook Rd, Orchard Park, NY 14127 1-716-652-7909
XK parts
End of jag-lovers-digest V2 #323
id for jag-lovers-digest-out; Mon, 2 Sep 1996 17:12:09 +0200 (MET DST)
Date: Mon, 2 Sep 1996 17:12:09 +0200 (MET DST)
Message-Id: 199609021512.RAA11214@ekeberg.sn.no
Subject: jag-lovers-digest V2 #324
Precedence: bulk
jag-lovers-digest Monday, 2 September 1996 Volume 02 : Number 324
XK120, 140
Console lid cup holders
Re: Console lid cup holders
Re: Stuck XJ-S Boot Lid
Re: XJ6 SIII Smell of gasoline (petrol) in car
XJ-S wiring
Tampa FL, All British Field Meet & Autojumble
Jag Lover Goin’ Down…
Re: Jag Lover Goin’ Down…
Orlando Club of Floirda
Re: E-Type brakes and clutch/reply
XJ40 Rear Lamp Lens
New owner XKE OTS Series 1
Re: Standard or Koni shockabsorbers
XK Engine Oil Filter
[S3 XJ6] Rear shocks/dampers
need mechanic in Atlanta
XJS - Wheel removal
Series III XJ6 Lukewarm Starting Problem
Condensation drain??
XJ6 S III Door lock problem solved.
Date: 01 Sep 96 09:54:44 EDT
Subject: XK120, 140
Two more points:
- XK140 roadsters had a special satchel for storing the side curtains (side
screens), part no. BD 10956. I have never heard of these in real life. Anyone
seen one?
- XK120 roadsters are shown in parts book as having glass in the rear window,
but one original car I saw seemed to have thick perspex. Anyone know for sure?
Date: Sun, 01 Sep 1996 09:28:15 -0500
Subject: Console lid cup holders
As many of you probably know, Jaguar makes (or at least sells) a
replacement console lid for the XJ40 which contains a fold-out cup
holder. According to my local Jaguar dealer and at least one of the
third-party Jaguar parts suppliers, there is no such similar device for
the Series III XJ6. Has anyone encountered anything like this either
from third-party manufacturers or perhaps some custom designer? My wife
is about to trade her XJ40 for a Series III and is unprepared to face
the road without a beverage by her side.
1987 XJ6
1989 XJ40
Date: Sun, 1 Sep 1996 11:26:36 -0400
Subject: Re: Console lid cup holders
Steve:
I recently bough a high quality replacement armrest with integral
cupholders for my SAAB 900. The company that makes it is HUSCO, and they
carry a line of these items for many luxury vehicles. Husco is located at 17
Calvin Rd, Wilton CT, 06897. Phone 800-752-3181. Fax 203-762-3427, email
husco@prodigy.com. Web site is:
http://www2.spav.com/wilton/husco/
Give them a try.
Mike Frank
the road without a beverage by her side.Steve Coleman, Gadsden, Alabama
1987 XJ6
1989 XJ40
Date: Sun, 1 Sep 1996 11:49:01 -0400
Subject: Re: Stuck XJ-S Boot Lid
In a message dated 96-09-01 09:43:57 EDT, ppatton@ibm.net (Phil Patton)
writes:
<< My '86 Boot lid seems to be permenantly locked. >>
As luck would have it I just happen to have the trunk lock mechanism in
pieces in my basement for my '87 XJS. I assume that the mechanisms are
identical.
How to open the stuck lid:
When the latch lever is lifted (normal opening procedure) a small lever arm
on the other end of the lock barrel rotates clockwise and moves a linkage bar
which releases the latch.
I can see two failure modes here:
- the small lever arm is connected to the lock barrel with a square peg in
square hole type affair. This is what was worn on mine, requiring previously
mentioned adjustment. This could easily become a square peg in a round hole
thus leaving you in deep *****. I would strongly suggest checking this, it
looks like a summer intern designed it. - The lock mechanism is broken, therefore you can’t rotate the barrel.
There are two philips head screws which attach the lock barrel assy. to the
trunk lid. It looks like maybe with a bit of luck these can be unscrewed
from the outside with a very short screwdriver or needle nose pliers. They
are in the north and south position as you face the trunk. If you can get
these screws out, you should be able to rotate the entire assy. clockwise
enough to release the latch even if the lock is buggered. If you have
situation 1) you may still be able to fish something in there to lift up the
link bar enough to release the latch.
Also, by examining the latch which “hooks” the bar on the bottom side of the
trunk, it lookks like some mild upward lifting of the trunk lid may help it
release. This could help if the latch is almost releasing but not quite
enough.
Good luck,
Julian Mullaney
Date: Sun, 1 Sep 1996 18:01:53 -0400
Subject: Re: XJ6 SIII Smell of gasoline (petrol) in car
Roger,
I had a leak in the tank of my 85 XJ6. In that case, the only time I could
smell gas on the inside of the car was when the windows were rolled down.
There was a noticeable smell on the outside of the car. Hope this helps.
Steve
Date: Mon, 2 Sep 1996 08:32:38 +1000
Subject: XJ-S wiring
idea what this is?Just a guess: one of those seat belt buzzer systems?
| - Palm’s Postulate
I haven’t got my car or manual here to answer most of the questions.
Regarding the wires under the carpet, my car has a warning light on the
dash for when the seat belt is not done up, and a sensor under the seat to
determine if there is somebody sitting there. It also has a seat warmer
for drivers and passengers with delicate bums.
Tony Watts
Date: Sun, 1 Sep 1996 19:27:45 -0400
Subject: Tampa FL, All British Field Meet & Autojumble
Saturday, October 19, 1996, 8:00 am
Picnic Island Park, Tampa, Florida, USA
There are 36 classes for British Cars and Motorcycles including 2 classes for
Jaguar.
This is the 10th annual show and it has grown every year. This is a great show
and there is always a large Jaguar presence.
For further information call Marion Brantley at (813) 867-7129 or Bud Keck at
(813) 752-0186.
Doug Bohannon
jaguar@gate.net
Sun Coast Jaguar Club
(941) 967-7899
Date: Sun, 1 Sep 1996 21:11:38 -0400
Subject: Jag Lover Goin’ Down…
Hey All Good Jaggers:
Some of you will remember me. 1980 XJ6 and 1971 E-Type roadster. Spent =
the better part of last summer doin’ my sedan. Still pondering the =
roadster.
Been lookin’ for a job or business or source of income for a year and a =
half now. The wife had been nagging me to apply at her factory. No way. =
Been there, done that, lost it. Completely lost it.
My wife recently bought a new 1996 Suzuki Sidekick JX four door 4x4. =
Victory red. Clashes just a bit with the signal red but you couldn’t =
touch it for price in the sport utility category.
It’s a lot less vehicle than all the other sport utilities on the market =
- but it’s almost half the price. Even I had to agree with my wife that =
it was an intelligent buy. For the twenty two and change we paid I could =
have scooped up a decent XJS, any number of excellent XJ6/XJ12’s, or =
maybe an E-Type coupe. But who am I tryin’ to kid; we live in the =
country and the roads are the sh*ts, and we’re tired of sliding down the =
hills sideways in the winter. Any Jag I ever drove was not designed for =
the rigours of winter we are soon looking forward to. No way.
During our quest for the Sidekick I encountered the two extremes of car =
salesmanship. On the one hand we met the =
I’ll-treat-you-fairly-and-honourably-and-I-won’t-run-you-up-the-flagpole-=
but-then-treated-me-unfairly-and-dishonourably-and-did-run-me-up-the-flag=
pole type, and on the other hand we met the true professional who gave =
us the straight goods from start to finish.
Car sales seemed like such a fascinating activity that I decided I’d try =
my hand at it.
Then I got a job.
At Bill Storey Pontiac Buick GMC in Peterborough. No jag dealerships =
around here. This is GM country.
So everyday last week I took my 1980 signal red XJ6 with the deep wet =
look shine to work, parked discreetly in the back lot, and tried to =
figure out one new car from the other. They all look alike!
Then I started test drivin’ them.
Not suspecting anything, I got behind the wheel of a 1996 Bonneville =
SSEi Supercharged.
Vrooooooooooooooooooooooooooooom!
This machine’s a f*cking rocket!
This machine could eat my f*cking Jag and spit the bones out for =
breakfast!
Help me, good Jaggers. You’re losin’ me. I’m goin’ down…
formerly loner@peterboro.net
Date: Sun, 1 Sep 1996 19:49:10 -0800
Subject: Re: Jag Lover Goin’ Down…
Not suspecting anything, I got behind the wheel of a 1996 Bonneville SSEi
Supercharged.Vrooooooooooooooooooooooooooooom!
This machine could eat my f*cking Jag and spit the bones out for breakfast!
Go ahead and get the Bonneville. It sounds like your kind of car.
I’ll happily stay with my XJR. He too is supercharged, though he isn’t a
“f*cking rocket”. He is dashing British gentleman who reaches reaches
100mph in about a quarter of a minute and in about a quarter of a mile. And
he keeps going till he reaches 155, though I’ve only had him up to 130 on a
couple of occasions – Jaguar owners must be discrete, you know. Best of
all, because he is a Jaguar, he feels, looks, sounds, and smells like a
Jaguar – comfort, ride, wood, and leather. Oh, and the ladies seem to like
him better than a Bonneville.
Date: Mon, 2 Sep 1996 00:17:00 -0400
Subject: Orlando Club of Floirda
The 10th Annual Jaguar Club of Florida Concours D’ Elegance will take place on
Sept. 7th, 1996 at Cranes Roost Park in Altomonte Springs, Florida, USA.
For information contact Neville Brabrook at (407)813-2705.
Doug Bohannon
jaguar@gate.net
(941) 967-7899
Date: Mon, 2 Sep 1996 00:36:41 -0500
Subject: Re: E-Type brakes and clutch/reply
Hi and how is the car?
Any ideas on where the fluid is going? Do you have one of those big “sausage”
ballast things behind, I believe, the air cleaner? Somewhere I remember
someone telling me that brake fluid can get pushed back into that ballast.
It’s black and about 10 inches by 6.Could your synchronizers be bad in the trans? Is your throughout bearing a
composite or a ball bearing style? Sometimes the composite ones do wierd
things while they are on their way out. Does the clutch slave OPERATE when
the clutch pedal is pressed ( a brave soul under the car is needed).Good luck and let me know what you find out, I may need
the
info myself someday, Valerie
STabenow
The Series One E-Type has a rubber bellows, which furnishes a somewhat
antiquated power boost thus you have power brakes. The 4.2 E-Type has a
much more modern system that probably can be modified for a 3.8 E. Brake
fluid could end up in the bellows, but it’s not likely. My problem was
leakage from the master cylinder’s operating rod that means either a
recored cylinder or a rebuild kit.
Second, third and fourth synchros in the gear box work without any
scrubbing. My problem, I think, is the clearance of 1/16" for the slave
cylinder’s operating rod and that’s the first thing my mechanic will check.
The gearbox is topped up properly and the oil is clean. I really think the
problem is in the slave cylinder. Moss gearbox’s throwout bearing is a
composite and can wear quickly with a slipping clutch plate. The bearing in
my Jag has less than 5,000 miles on it, but that doesn’t mean it’s not at
the root of my problem. I’ll just have to keep my fingers crossed until the
mechanic can give the whole system a good going over.
Date: Sun, 1 Sep 1996 22:11:20 -0700
Subject: XJ40 Rear Lamp Lens
Hi Jag-Lovers!,
I would like to change the rear taillamps in my 1989 XJ40 VDP
(Plain black lens) to the 90’s version (black w/ chrome accents).
What year(s) are the lenses with the chrome strip that surrounds the
outside of the lens?
I assume 1988-89 where plain black/red
1990-1992 black/red some with accents?
1993-1994 look like 92, may have different mounting?
What year would fit into the 1989 body? (90-94 or all?)
Please help! I would like to order these ASAP.
Many thanks for any replys or ideas
-Eric
Date: Mon, 02 Sep 1996 19:41:33 +1300
Subject: New owner XKE OTS Series 1
I’ve been subscribing for a few weeks but have held off introducing myself until
I was sure my car was going to happen.
I’ve purchased ex US (New York) a Series one Roadster, one owner, original condition
89,000 miles. She gets converted to right hand drive on arrival. The sale was arranged
via an agent whose original estimate of 4 weeks delivery has now stretched to 12. On
arrival a RHD XK120 imported as well was found to have been totaled in transit but
mine’s unharmed.
The car has never been in an accident and has little rust but requires TLC to restore
to acceptable condition.
The reasons for purchasing via the US are price, less rust, availability and price.
Personal stuff: 33 years, Account Manager at Compaq Computer and reside in Auckland New
Zealand - and by the way - South Island roads are the ultimate. One Police Officer per
thousand miles and each one of them admires acts of sheer stupidity.
Stewart
Date: 02 Sep 96 04:20:24 EDT
Subject: Re: Standard or Koni shockabsorbers
Dear Martin Jacobsen,
To choose schock-absorbers is no easy task with the wealth of choice available.
However,
obviously “standard” schocks as recommended by Jaguar is not the worst choice
you could make. KONI’s are Dutch made and are of high quality, so are many
others, namin but a few Bilstein Girling and many more. KONI’s are adjustable,
which provides you with a minor control over the “stiffness” wanted, however be
careful , since a much stiffer or looser adjustment than standard will not give
satisfacory results
If you have a completely standard car and yoiu are happy with that, standards
schocks or any other suitable replacement will be OK. Quality varies, usually
indicated by price.
Although KONI’s and others are excellent, there will be no noticable increase in
driving characteristics, nithere good nor bad by choosing one brand for another.
There may be a very noticable increase in “feel” and presicion in steering, but
this would just indicate that your old schocks were really worn out.
The story you will get on “agening” symptoms of springs depends upon who you
ask. Some saythey never wear (obviously these are the idealists) , and some
say they do wear (they are right). My opinion is that springs do sag after a
while (long while), and my V12 XJ sits very low, and usually hits the ground in
multistorey car parks.
It is probably not only the amount of kilometers driven that causes this
sagging, but also level of “execising” the springs.
Fact is I will change my springs for high quality Harvey Bailey’s (UK), at a 25
% uprated spring rate. The schocks will be adjusted accordingly . I have now
SPAX externally adjustables on the front. These are brandnew so I have no
experience with these. My other Jag - a XJ6 Coupe has KONI’s all around. These
are now 7 years old and about 75.000 km. still no problems at all.
I would say that if you jag hangs low either always or after a heavy load in the
trunk, then get new springs.
Regards Jeffrey Gram
Date: Mon, 02 Sep 96 11:44:40 gmt
Subject: XK Engine Oil Filter
On an XK Engine oil filter, can anybody say wether the oil flow through the filter is from outside to inside, or the other way? I really can’t recall the layout of all the oilways, and in particular the oil filter housing so that I can decide, and I don’t want to remove it for such a small piece of knowledge Anyone know? ************************************************************************ * Alastair Lauener * * 1964 3.4 S-Type http://www.sn.no/home/nick/alas.html * ************************************************************************ From: Gunnar Helliesen gunnar@bitcon.no Date: Mon, 2 Sep 1996 13:04:43 +0200 (MET DST) Subject: [S3 XJ6] Rear shocks/dampers Folks, Anyone ever tried replacing the rear shocks/dampers on a Series III XJ6 (mine’s an ‘86)? I’m planning on doing this Real Soon Now™ and am wondering if I’ll have to lower the entire rear subframe to get at the upper shock mounts. Gunnar Gunnar Helliesen | Bergen IT Consult AS | NetBSD/VAX on a uVAX II Systems Consultant | Bergen, Norway | ‘86 Jaguar XJ6 4.2 Sovereign gunnar@bitcon.no | http://www.bitcon.no/ | Vicki who? What .sig virus? From: DeEtte Kattel deette@mindspring.com Date: Mon, 02 Sep 1996 08:16:48 -0700 Subject: need mechanic in Atlanta I just bought an 1989 XJ6 with 57k miles. I need to get names of a good local mechanic so I can start my regular mantinence program. I live in the buckhead -midtown area of Atlanta Ga and would prefer someone close. Thanks- I love my new Jag DeEtte From: RWOODLIN@garfield.foods.indiana.edu Date: 02 Sep 96 08:15:14 EDT Subject: XJS - Wheel removal Help! I am in the middle of a brake job - I’ve rebuilt the servo, master cylinder, and replaced the rear brake pads. However, when I attempted to remove the front wheels to gain access to the front brakes I discovered that the wheel is frozen in position. I have removed the five (5) lug nuts but the wheel will not budge! I surmise that either there is another bolt somewhere, not shown in any of my manuals, or the wheel was torqued so tight that the wheel has mated with the bearing dust cover. I have applied penetrating oil around the dust cover and banged on the back of the wheel with a rubber mallet to no avail!! Has anyone encountered this situation before? This would have been extremely frustrating had I had a flat and could not change the tire! Robert Woodling ‘84 XJ-S From: William F Trimble trimbwf@mail.auburn.edu Date: Mon, 2 Sep 1996 08:43:57 -0500 (CDT) Subject: Series III XJ6 Lukewarm Starting Problem Dear Jag-Lovers: I hate to bomb the list with another of my Jag problems, but this one’s been bugging me for a couple of months at least. Here’s the problem: The car (1985 XJ6 Series III) starts OK when cold, after sitting overnight, when the ambient temperature here in Alabama is about 70 degrees F. The car runs fine. And the car hot starts all right, although sometimes with a little cranking. It runs right at 90 degrees C, even on the hottest days with the AC on. Before replacing the thermostat in March, the car ran very cool, and I had no starting problems. The problem is that if the car sits all day in 90 degree plus temperatures, it will not start. Nor will it start after sitting for about 4-5 hours in cooler weather. Rick the mechanic and I have discussed this problem and played around with the thermotime switch, bypassing it and grounding out the cold start injector manually. The car starts instantly every time we do that. The thermotime switch is new, although it is 8 sec. rather than seconds at 35 degrees C. Could it be a broken wire leading from the thermotime switch to the cold start injector? I had to pull the injector harness out of the way back in March when I did the thermostat job, and I might have pulled something loose. The connections at the thermotime switch and at the cold start injector look OK, although the one at the thermotime switch is a little worse for wear, and the rubber boot is cracked from heat. It has always bothered me that the car, as long as I have owned it, has not started on the key, but has always needed some cranking. Could this in some way also be symptomatic of the problem? Any ideas would be greatly appreciated. Bill Trimble Auburn, Alabama From: GORDON80@aol.com Date: Mon, 2 Sep 1996 09:52:57 -0400 Subject: Condensation drain?? I am getting water under the carpet on both sides of my 1986 XJ6. I thought it was a result of our recent and long awaited heavy rains. However, after getting it all cleaned up I once again got wet carpets on the passanger side. Is there a common problem with A/C condensate backing up into the compartment? I can’t seem to find a ready source for water leaks from the A/C. Any suggestions will be appreciated. From: Cosmo simond@informix.com Date: Mon, 02 Sep 1996 14:17:25 -0100 Subject: XJ6 S III Door lock problem solved. A while back I had a problem with the driver side door lock that could be opened with a coin in the keyway. Not very secure and this weekend I had the chance to investigate. The cause was an acumulation of old grease in the lock that had become hard and was preventing the return springs inside the lock barrel from working. Once the correct key had been used to operate the lock, the internal parts got jammed in the grease and anything inserted into the lock that didn’t upset the mechanism would be able to turn the lock. I discovered this after removing the lock from the door - the barrel just drops out - take care. I had hoped to swap the lock barrel from the glove box but although the key is the same, the actual mechanism (push rather than turn) does not allow this. Instead I completely cleaned the door lock, removing all the dried up grease, being vary careful to not mix up or loose any of the small parts inside. I replaced the grease with Vaselene (petroleum jelly) and the internals don’t stick. Now its a little more secure. I don’t know if Vaselene was a good choice but it was better than the only other grease I had around (thick Castrol stuff) and I didn’t think the liberal spraying of WD40 would be a good substitute. Cosmo 83 XJ6 4.2 65 Mustang 289 End of jag-lovers-digest V2 #324 ******************************** Return-Path: @owner-jag-lovers-di1 Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4) id for jag-lovers-digest-out; Tue, 3 Sep 1996 06:33:12 +0200 (MET DST) Date: Tue, 3 Sep 1996 06:33:12 +0200 (MET DST) Message-Id: 199609030433.GAA20500@ekeberg.sn.no X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f From: @owner-jag-lovers-di1 To: jag-lovers-digest@sn.no Subject: jag-lovers-digest V2 #325 Reply-To: jag-lovers@sn.no Errors-To: @owner-jag-lovers-di1 Precedence: bulk X-Newsgroups: mail.jag-lovers-digest jag-lovers-digest Tuesday, 3 September 1996 Volume 02 : Number 325 Re: SIII XJ6 Condensation drain?? Dear Tommy, the lonely loner from Peterboro’, engine number Re: XJS - Wheel removal About the ignition wire harness Card board and losening head nuts. Re: Condensation drain?? RE:Condensation drain?? Holiday in Denmark Condensation drain? RE: New Owner Finally Re: xjc question Subwoofers Surface Rust Removal (foot wells) Any 420 owners? Trouble (E-Type) comes in threes Re: 1985 XJS (finaly aquired) 70 E-Type No Start Re: Condensation drain?? 85 XJ-S ac condensate: Where has all the water gone? From: Robert Bradley Robert.Bradley@bh.eyi.com Date: Mon, 2 Sep 1996 10:36:31 -0500 Subject: Re: SIII XJ6 Condensation drain?? Yes, it is an extremely common problem made worse by parking under molting trees, humid conditions and the location and inaccessibility of the drain holes. I have all three. Don’t panic, easily fixed from under the car (need hoist, stands, ramps or very thin son/daughter). There are two plastic tubes, one on either side of the transmission tunnel around about level with the front foot well vents (the ones spraying water on your legs). They are above the exhaust pipes so can be a bit hhard to get at especially if the pipes are hot. The tubes can be cleared easily - I’ve used a piece of single strand auto wire, poke it up the tube until the water pours down your sleeve , my dealer uses compressed air and does it for free (yes, FREE, well, he did it once for free). Long term fix is not to park under trees. Robert Bradley 87 XJS, 82 XJ, 82 XJ WROTE> I am getting water under the carpet on both sides of my 1986 XJ6. I thought it was a result of our recent and long awaited heavy rains. However, after getting it all cleaned up I once again got wet carpets on the passanger side. Is there a common problem with A/C condensate backing up into the compartment? I can’t seem to find a ready source for water leaks from the A/C. Any suggestions will be appreciated. From: Gram@eumetsat.de Date: Mon, 02 Sep 1996 15:52:26 +0100 Subject: Dear Tommy, the lonely loner from Peterboro’, Dear Tommy, the lonely loner from Peterboro’, I don’t think we’re losing you, If you came this far with a Jag, and still admires the deep lustre of a Jag , not only on the outside, but also in the amazing cultured way the drive is, then a supercharged FORD is not going to take the shine away from the Jag, just a part of your time and money, and shake your faith. We (and you ) could live with that. Somewhere there is always a little tendency in all of us (of varying strength) to sometime drive a car that really kicks, but for my beloved vehicle I would only accept such kicking if it came from an otherwise cultured vehicle, or I would have them both and if that is not possible I would only have the Jag. May your God go with you Jeffrey Gram - 2 Jags and none kicks ass (other than mine:-) From: martin.jacobsen@login.eunet.no (Martin Jacobsen) Date: Mon, 2 Sep 1996 17:53:38 -0100 Subject: engine number My Mk II(61.mod) was imported from the US in 1991.The VIN-plate tells me that the original engine number was LA 7878-9 (3.8 l). Both the BW gearbox and the engine are not original. The new engine number (quotet from the top) has the prefix NE (1351-8).I am not familiar with this prefix. “Jaguar 6 Cylinder Engine Overhaul (1948-1986) gives a survey of which prefix belongs to the the spesific model. They do not mention “NE”. Can somebody give me information? Martin Jacobsen Kristiansand, Norway Mk II 3.8 61mod V8 Land Rover County 110” Essex super six 1928 From: mfl@kheops.cray.com (Matthias FOUQUET-LAPAR) Date: Mon, 2 Sep 1996 18:24:55 +0200 (MET DST) Subject: Re: XJS - Wheel removal I am in the middle of a brake job - I’ve rebuilt the servo, master cylinder, and replaced the rear brake pads. However, when I attempted to remove the front wheels to gain access to the front brakes I discovered that the wheel is frozen in position. I have removed the five (5) lug nuts but the wheel will not budge! I surmise that either there is another bolt somewhere, not shown in any of my manuals, or the wheel was torqued so tight that the wheel has mated with the bearing dust cover. I have applied penetrating oil around the dust cover and banged on the back of the wheel with a rubber mallet to no avail!! Has anyone encountered this situation before? This would have been extremely frustrating had I had a flat and could not change the tire! I had the same problem on my '88 XJ-S on one of the rear tires. It was completed seized and only after brute force of 2 pairs of strong arms it came off. I applied anti-seize after this occasion and it is ok now. I had the same thought concerning the flat … I guess the problem is the alu wheel on the steal hub Do you have the same problem on both wheels ? Good luck Matthias Robert Woodling '84 XJ-S From: Gram@eumetsat.de Date: Mon, 02 Sep 1996 18:25:45 +0100 Subject: About the ignition wire harness Card board and losening head nuts. About the ignition wire harness Card board and losening head nuts. Generally it is not a good idea to loosen head bol nuts when not needed. If you must, wait until the engine is stone cold. If possible loosen only one at a time. Regards From: Hunt Dabney hdabney@earthlink.net Date: Mon, 2 Sep 1996 09:45:31 -0700 (PDT) Subject: Re: Condensation drain?? I had this: Someone, at some point, had lifted the car improperly, and cracked the joints between the floor pans and the front bulkhead. Silicone-seal (RTV) applied into the joints from below fixed it. Look for bumps up into the floor wells where the lift points shouldn’t have been! Good luck! Hunt At 09:52 AM 9/2/96 -0400, GORDON80@aol.com wrote:
Date: Mon, 02 Sep 96 18:24:59 -0700
Subject: RE:Condensation drain??
There isn’t a common problem as such with draining away the condensation from
the air-con system. But since the drain tubes vent out through the floor either
side if the gearbox there is a tendancy to collect dust and dirt in the tubes.
Pushing a still wire into the tubes then blowing them out usually does the trick.
I have the same problem myself, anoying isn’t it!
Barrie Dawson
1985 series III Jaguar Sovereign
Date: Mon, 02 Sep 96 18:45:10 -0700
Subject: Holiday in Denmark
Before I went on holiday I had been going through some serious overheating
problems with my series III Sovereign. With the help of several Jag-Lovers and
of course my friendly Jag specialist, JUST JAGS of Strood Kent England (quick
plug there), I was able to go away with confidence. The weather was great and
although outside temperatures were in the upper 30’s C my cat purred along at
a stable 75 C - 80 C all day. A big thankyou once again, especially from the kids.
Denmark is a beautiful country and the roads are well maintained for the comfort
seeker. There weren’t a great number of cats to be seen probably they were in
hiding protecting their paint from the sun. However I did see one series III
Sovereign tearing the tarmac away with such grace and I wasn’t exactly crawling
along, 80 ish, that I suddenly realised just hoe good they look. I saw one other
cat, a well kept red E type V12, resting under the shade of a group of trees at
the road side. Obviously admiring the view of and watching the lesser vehicles go
by.
The kids enjoyed their second trip to Legoland, so did my wife and I. We are
planning on a proper Scandanavian cruise next year sadly the cat will have to stay
at home in pleasent Jaguar storage (hopefully at JUST JAGS)
Barrie Dawson
Chatham Kent England
Date: Mon, 2 Sep 1996 11:17:01 -0700
Welcome to the joys of ownership of older Jags. I have owned three
Series III XJ 6’s and all have had plugged condensate drains eventually. It
appears that the inside of the AC box (where the evaporator is located and
where the drains are supposed to drain water) is insulated or lined with a
type of foam rubber or cell foam. Over the years this foam dries out or
deteriorates to the point that it crumbles and falls to the bottom of the
box and mixes with the condensate which creates MUD! I have removed the
side panels and the rubber connecters (2-3" horizontal tubes) and cleaned
out the bottom of the box on both sides. This helped but the foam keeps
falling.
The best procedure seem to be to put the car up on a lift and go up
through the drains on either side of the transmision with a straightened out
coat hanger and pull the mud out from the bottom. I have also used an air
gun to blow out the drain which also works but not as long as the coat
hanger method.
Date: Mon, 2 Sep 1996 11:35:26 -0700 (PDT)
Subject: RE: New Owner Finally
Roger Peng writes in response to a thread about cell phones:
Like David said, a Jaguar installed cell phone is placed on top of
the center storage compartment (between the driver and front passenger).
Cars equipt with the phone has a special storage compartment lid which
lets the phone sit in there, thus you’ll need to replace the lid if you
want your phone like this. Go to a Jaguar dealer’s parts department,
and ask to see their accessory brochure. You’ll see a picture of this.
On my car, the previous owner had a phone installed after-market, but of course he took the phone unit away when he sold me the car. I can simply purchase a phone and plug it in. It would sit on the right side of the center console, by the left leg of the front passenger. Jaguar also markets a sidemount phone holder & it’s in the accessory brochure along with the storage compartment lid version. The special phone compartment lid is OK, but I’d rather get the cupholder storage lid, as on the new X300 cars. You can’t have both, but you CAN get the cupholder lid combined with the Jaguar sidemount so that you can spill coffee onto the phone! By the way, I have a Jaguar CD changer in my 91 and it works GREAT! The car came that way when I picked it up as a lease return car. So far, after 9 months, the car’s had minimal problems. Steve A. '67 E Type Coupe (JJ - as in “Junior Jaguar” - our 2nd E Type) '76 XJ6C (Felix) '91 XJ40 (Nessie - as in Loch Ness Monster - Guess What Color it is?) From: averill@earthlink.net (Steve Averill) Date: Mon, 2 Sep 1996 11:35:38 -0700 (PDT) Subject: Re: xjc question LLoyd Nolan supposedly wrote:
For those of you who have a mid 70’s xjc, does the back seat sit two adults,
or am I dreaming? If so, does it leave room for the feet of the front passen-
gers?
Jim Cantrell then replied
It does seat two adults. The leg room is adequate by today’s
standards but the head room is marginal.
If its the occasional
passenger, then there should be no real problem. By the way, this car
handles, looks and feels unlike the long wheel base car.
I like it far better as it is more of a sports car than
the traditional XJ6/12.
I’ve never noticed any problems with the head room, but then I’m not a
basketball player, either. The car isn’t a problem for 4 adults and CAN
seat 5 in a pinch (I retrofitted the later seatbelts & now have 3 in back.
The biggest problem for frequent passenger carrying is that ingress and
egress isn’t nearly so nice as for a 4-door car. We often go out for a
drive with all three kids in the back as they MUCH prefer the pillarless
coupe with its weird rear window mechanism over the XJ40 for a “fun” drive.
They prefer the hydraulic ashtrays (great place to keep small toys),
sunroof and reading lights on the XJ40.
Bottom line - decent room in back but with typical coupe entry/exit problems.
-Steve A.
'67 E Type Coupe
'76 XJ6C
'91 XJ40
Date: Mon, 2 Sep 1996 14:20:58 +0700
Subject: Subwoofers
Hello everyone!
Now that my '85VdP is out of the paint shop (formerly Sage Green, now
Sapphire Blue - and FIVE WEEKS in the making), I’m looking to upgrade
my stereo. I’d like to put in a subwoofer without damaging any
interior panels and I need some advice. Has anyone put a subwoofer in their
XJ6? If so, what size did you install and where? What type of amp did you
install to run the subwoofer? Any info appreciated.
TIA,
Greg
Date: Mon, 2 Sep 1996 16:10:32 +0000
Subject: Surface Rust Removal (foot wells)
I am slowly getting the details of the “new” XJS sorted out. You can
tell I am getting to the bottom of the barrel since I am now
concerned with the only rust I could find on the beast. When I
opened the trunk I found a front carpet that had hardened rotten
peaches on one end of it. This led me to the drivers side footwell
which had an older carpet on it that did not match the rest of the
carpets. Under that carpet at about where the peaches had rotted I
found the only rust I have seen on the car.
There was an area about half the size of the footwell where surface
rust was evident and some scale. Not real bad though, some
scratching with a knife got me down to clean metal. I am now going
to take a wire brush to the entire area then use something I found at
the auto parts store on it, says it will convert the rust into
primer, sounds like “snake oil” to me, but what the hell. Has anyone
had any experience with these products that turn rust to primer?
After the “rust converter” follow up with some spray paint.
Hopefully this will cure the problem. Are the rubber strips in the
groves something special?
I think I will replace them with something that does NOT absorb water.
Maybe solid rubber. Anyone done this before?
Also, anyone know of a sourse for the 7 rubber plugs that are at the
back of the trunk bottom? 4 of mine are missing, but luckily, no rust
there.
I found out what the wires from under the seat were. It looks like
the PO had a CD or maybe a Ham radio mounted in the trunk since the
wires came from a 4 pin connector in the trunk that went nowhere.
There is also an audio plug hanging down from under the dash which I
assume went to an audio source. I will try putting something in
there and see if I get anything out the speakers. If so I will save
it for later use.
Removing the bonnet looks like a two man job, so I will wait until I
get the water pump in hand so I don’t have a rainstorm dump in the
engine while it is off and there is no one around to help put it
back.
Date: Mon, 2 Sep 1996 19:07:15 -0400
Subject: Any 420 owners?
Any 420 owners out there?
I’m looking at a 65 420, green, lhd, automatic, disk wheels, fair shape.
There is a small amount of rust in the usual places (for a 30 year old car)
but the chrome is good and if I buy it, I’ll have it resprayed anyway.
The seller is asking $3995. I’ve not heard the car run as the shop was
closed when I found the car.
Any 420 buying tips? We don’t get many classic jags around here so I have
to admit that I’m very tempted to grab the first thing that comes along…
Clayton B.
85 XJ-S
Clayton Betlyon cbetlyon@lumcorp.com
Software Engineer (717) 543-4994
Luminous Corporation
Date: Mon, 2 Sep 1996 19:15:05 -0500
Subject: Trouble (E-Type) comes in threes
I almost lost my Jag, my garage and my whole darned house last night. And
of course, I intially suspected and blamed it on the Jag.
Scenario: Discover water on the kitchen floor and go looking for flashlight
in my attached garage. Open garage door and am almost felled by gasoline
fumes. The kitchen was just a few open feet away and the stove’s pilot
lights were-a-burning. Switched on flashlight and there’s a major puddle of
gasoline underneath the Jag’s right outer sill.911!
Wait a minute. The lawn mower is sitting right over the puddle. It wasn’t
the old '64 FHC that has been leaking all manner of fluids on a regular
basis. Moved lawnmower, flushed gasoline and mopped area dry. Scolded lawn
mower and made it sit outside over night. Two problems already.
And during all this melee, Mickey, my beagle, makes another of his famous
escapes out the wide-open kitchen door. By this time, the grill’s charcoal
fire is slowly dying out and a choice sirloin is saved for another day.
Got in the Bimmer and found old Mickey tracking some wild Appalachian
critter. Got home, fixed the leak in the kitchen, gave Mickey a big hug,
apologized to the Jag, kicked the lawn mower, gulped down a peanut butter
sandwich and and retreated to my computer room.and wrung out a Warthog and
an F/A-18 Hornet. The government had better put this warning sticker on all
old Jags: “Owning an aging Jaguar may lead to serious heart ailments.”
Date: Mon, 2 Sep 1996 20:22:52 -0400 (EDT)
Subject: Re: 1985 XJS (finaly aquired)
I have it in my possesion now!!!
2)The car is too quiet. I cant tell when the engine is running and have
twice tried to start an already running engine. I need to start looking at
the Tach before I try to start it. But I also would like the car to sound
like my E-Type. There are 6 mufflers (actualy two are CATs) Which pair of
mufflers should I remove to get a nice exhaust note out of the car?
My 89 XJS is quiet too, and I have to watch the tach when it starts to
know that I started it. Acceleration is very silent and respectable. I
like the way the V12 does that.
(But it is also fun at times to have a bit more noise and human
interaction when accelerating, like my brother standard hard-shifting saab
900s turbo, a fun 4-cylinder)
Wish I was more familair with how E-types sound
3)Will removing the front license plate improve the cooling as it does
on an XJ6?
My license plate (a black plate with a raised silver jaguar) goes downward
from bumper and has no relationship to the grill, and probably little or
no effect on the airflow.
- -jason
Date: Mon, 2 Sep 1996 17:55:21 -0700
Subject: 70 E-Type No Start
Well my 70 E-Type decided to truly celebrate Labor Day (National Holiday in
US) by taking a “day of rest”.
I went to start the car this am and it behaved as if it had a dead/weak
battery. Turn key in ignition and only got a single "click "from the starter
solenoid. No horn, turn signals, but parking lights and map light worked.
Seemed like avery weak battery.
Hooked up battery charger and it indicated that the battery was fully
charged and I confirmed this with a battery tester. I concluded it wasn’t
the battery. Battery terminals looked ok, but I haven’t taken them off to
clean so it possible that it just a bad connection, but if that was the case
would not the battery be low as it was not receiving sufficient charge?
I then hooked up the jumper cables and the engine seemed to have difficulty,
at first turning over, but then it fired right up and I ran it till the car
heated up. during that time all of the electrical items functioned ok and
the battery meter was in the charge position, but no higher than “normal”.
Shut off the engine and you guessed it–same problem again.
My guess is the starter solenoid? But my experience with E-Types is very
limited and any advice is much appreciated.
Thanks
Stephen Patchel
Consulting Practice Leader
Radford Associates
voice: 408-321-2540
fax: 408-321-2650
Date: Mon, 02 Sep 1996 21:00:53 -0500
I believe the problem is a blockage in the drain tubes from the
evaporator coil. These tubes come out beside the transmission. Blowing
compressed air up the drain tube usually frees the obstruction and
allows free flow. I have thought the problem can be caused by periods
of inaction of the AC. Without use mold spores grow in the moist area
and eventually block the drain pipes.
I hope this helps.
Bob Johnson
Brattleboro, Vt
XJ12L, XJ50
Date: Tue, 03 Sep 1996 21:29:35 -0700
Subject: 85 XJ-S ac condensate: Where has all the water gone?
I’m probably going to sound paranoid but I’m worried as to what is
happenning to the condensate from the ac system in my 85 XJ-S (with all the
recent postings on this problem it got me thinking!!!)…
My problem is that I never see any condensate under the car! The ac works
fine, the windshield doesn’t fog up, there is no sloshing sounds, and the
carpet is not wet. Today I pushed a wire through both of the drain tubes
and didn’t get even a drop of water! Is it possible that the water
evaporates as it comes out of the tubes? (maybe it hits the cats or the
exhaust pipe?) Any ideas? Is this something to even worry about? (I know,
leave well enough alone;but, what is hapenning to the water?) Thanks
Rob W-M
85 XJ-S
End of jag-lovers-digest V2 #325
id for jag-lovers-digest-out; Tue, 3 Sep 1996 16:39:19 +0200 (MET DST)
Date: Tue, 3 Sep 1996 16:39:19 +0200 (MET DST)
Message-Id: 199609031439.QAA14297@ekeberg.sn.no
Subject: jag-lovers-digest V2 #326
Precedence: bulk
jag-lovers-digest Tuesday, 3 September 1996 Volume 02 : Number 326
Tire wear and shocks
Cup holder for 85 XJ6?
Re: Any 420 owners?
Re: Tire wear and shocks
Re: jag-lovers-digest V2 #325
Re: Knock-off wrenches
Re: 64 E-Type brake fluid leak
RE: XJ6 S III Door lock problem solved.
Bits and pieces
V-12 Air pump and XJ SIII rear seats
Radiator removal
RE: engine number
Rust converter
NE engine number - Mark Jacobsen
XJ-S Wiper Park / Removing Radiator
Re: About the ignition wire harness Card board and losening head nuts.
Re: XJ-S Wheel removal
Date: Tue, 03 Sep 1996 21:33:33 -0700
Subject: Tire wear and shocks
I need some advice regarding the possible association between tire wear and
bad shocks…
My front shocks are gone and they need replacing. When checking the front
tires today I noticed that they are both wearing unevenly. The thread is
worn down along the inside edge of both front tires. Is the wear symptom
due to the bad shocks? Thanks for any help,
Rob W-M
85 XJ-S
Date: Tue, 3 Sep 1996 00:44:09 -0400
Subject: Cup holder for 85 XJ6?
I checked out the “cup holder” web site at http://www2.spav.com/wilton/husco/
, but it appears that they don’t make a model for Jags. Has anyone fitted a
decent cup holder to a series 3 XJ6?
Steve
Date: Tue, 3 Sep 1996 00:58:11 -0400
Subject: Re: Any 420 owners?
I have a 1967 420 which I have owned for about two years. I believe they were
only made from 1966 to 1968 so I would check out the 1965 year. I think they
are great cars. They still have the classic body of the compact saloons like
the Mark II and the S-type but they have most of the modern enhancements we
are used to such as independent rear suspension, power steering, and air
conditioning. Because they are a fully outfitted Jaguar saloon, any
restoration cost, particularly the interior, will be costly. Because the cars
are not as popular as Mark II’s and S-types, their value is considerably
lower. Consequently, money spent on a 420 will probably not be realized on
sale in the near future. The cars are quite rare in the U.S. There were only
some 900 imported in 1967 and 68 and only about 168 are registered today.
Things to look for are both the front and rear suspension - both expensive to
rebuild. Also, if you can, have any rust checked by a professional.
Significant rust repair on major body parts can be ruinously costly. Wood
refinish can be about $1500. A complete interior (leather, trim panels,
carpet, headliner, etc.) will set you back $8000-$10000 parts and labour to
do it properly. If the car is drivable and in reasonably decent shape, the
price seems reasonable. Be sure the XK engine is OK - no blue smoke from the
exhaust. Also check the shifting on the BW8 auto tranny to make sure it works
all right - few places can work on these.
Jim Scannell
'67 420 valentine beige
'89 XJ-40 BRG
Date: Tue, 3 Sep 1996 01:15:01 -0005
like the way the V12 does that.(But it is also fun at times to have a bit more noise and human
interaction when accelerating…
You guys might wanna consider opening up the INTAKES. Just saw off
the horns on the front of the air filter housings, and relocate the
temp sensor in the left one to the housing itself. This makes the
car roar when floored, but remains silent at part throttle.
As explained in my booklet, if you wanna find out what the sound is
like before sawing, just remove the housing covers, tie the filters
in place with some string or wire, unscrew the temp sensor and let it
hang from the wire, and take 'er for a spin.
– Kirbert | If anything is to be accomplished,
| some rules must be broken.
| - Palm’s Postulate
Date: Tue, 3 Sep 1996 08:40:50 +0200 (MET DST)
Subject: Re: Tire wear and shocks
bad shocks…My front shocks are gone and they need replacing. When checking the front
Hi Rob,
I just replaced my front shocks with Koni’s. I found that one of the
old Boge shocks would stick from time to time when I tried it by hand.
I also have tire wear on the inner edges, although more noticable on the
right hand side. I guess this is a problem with the camber adjustement.
I’ll try to get this fixed. However, on our other car this kind of adjustement
took 3 sets of front tires over the years before finally a competent garage
fixed it.
I have noticed how many camber and castor alignment shims are on each site,
so I can check if the shop actually did some work. One thing I don’t understand
is that the car is supposed to have positive camber on the front wheels
(1/2 degree). I have checked with a builders tool (don’t know how they are
called) and found that both wheels have slight negative camber. But I
think camber measurements must be done with the suspension partly compressed.
However, the simple measurements I took were coherent with my tire wear
patterns.
Comments/suggestions anyone ?
Kind regards
- Matthias
Rob W-M
85 XJ-S
Date: Tue, 3 Sep 1996 09:16:30 -0700
Subject: Re: jag-lovers-digest V2 #325
Matthias;
completed seized and only after brute force of 2 pairs of strong…
I don’t know what you mean by anti-seize. If it’s spray, forget it! It
evapourizes/burns. Te ensure easy unscrewing and/or removal of parts that are
prone to get warm, use Copa-slip (it has other names too, but I can’t remember
it from the top of my head).
BTW Matthias, it’s completely seized…
Bard
______ _ ! Baard Th Hesvik, Telesoft AS
/ _ / _ _ _ / / ! Longhammarvn 7, N-5500 Haugesund
/ // / // /_ / / -/- -/- ! T: +47 52735000 F: +47 52717040
/ /_ / /_ / // / /_ ! E-mail: baard@telesoft.no
Date: Tue, 3 Sep 1996 08:49:22 +0100
Subject: Re: Knock-off wrenches
On Aug 31, 1996 15:28:52, ‘“Kirbert” palmk@gcn.scri.fsu.edu’ wrote:
My MKII has knock-offs with very stunted “ears” and there is a brass
fitting
supplied which fits over these and is then hit with a hammer. Maybe you
can just change the spinners. Makes the wheels harder to steal, too.
Ian
On this topic, I was thinking of making a steel impact wrench attachment
with brass lined jaws that would fit knock-offs. I think a heavy duty
1/2"
impact gun would be sufficient, although a 3/4" might do the job better.
From what Ryan said, it sounds like he easily had 200+ lb-ft of torque
on
the thing without budging it. Any ideas?Impact is not really comparable to steady torque. However, since
knock-offs are DESIGNED to be installed/removed with a HAMMER, I
kinda doubt if a 1/2" torque wrench will be very good for removal,
especially when stuck.I used to work in a power plant, and the nuts holding the turbines
together (about a 4" diameter thread, the turbine was the size of a
mobile home) were tightened and loosened with what is called a
“sledging wrench”. Essentially this is a relatively short wrench
that fits the nut and has a block on the end of the arm for hitting
with a sledgehammer. Seems to me that such a device might be
adaptable to the knockoff problem. Fashion a wrench with soft jaws
that fits the knockoff and with a short arm, perhaps 8 inches, with
a spot on it to hit with a sledgehammer. If it doesn’t line up
right for hitting, just roll the car forward or back until it does.
I believe some of the mail-order outfits offer such a critter,
although they claim it’s to protect the tangs of the knockoff from
impact rather than to provide a better removal torque.– Kirbert | If anything is to be accomplished,
| - Palm’s Postulate
Date: Tue, 3 Sep 1996 08:49:18 +0100
Subject: Re: 64 E-Type brake fluid leak
On Aug 30, 1996 19:35:22, ‘rrichardson@eurekanet.com (Bob Richardson)’ wrote:
... I don't have floor >stands and I don't trust getting under the car with just the support of a >lift or jack, so I can't really can't check out the underside of the master >cylinder...Go and find a high curb (kerb?), park two wheels on it. Instant lift!
Alternatively, buy some stands, or find somewhere with a “free” exhaust
check, or free brake check, and have a look while they’ve got it on
their ramp.
Ian
Bob “I hope somebody up “There” likes me.”
Date: Tue, 3 Sep 1996 09:55 +0200
Subject: RE: XJ6 S III Door lock problem solved.
Sorry to disappoint you but Vaseline is about as bad as the grease you found=20=
in your lock and quickly will give you the same symptoms. The best is to=20
clean the lock barrel until totally dry and to lubricate with pure graphite=20=
or with WD40 (my choice). The advantage is that both give a dry but slippery=20=
surface on the metal parts. The lock barrel must be dry to avoid=20
accumulation of dust and dirt that can adhere to grease and vaseline. You=20
can do it without dismantling by spraying the WD40 in the barrel until the=20
grease or vaseline has been washed away together with the dirt. The excess=20
WD40 will flow out and the rest will dry out. Try it and your lock will like=20=
it!
Frans.
the liberal spraying of WD40 would be a good substitute.Cosmo
83 XJ6 4.2
65 Mustang 289=20
Date: Tue, 03 Sep 96 10:57:58 gmt
I asked
Does no-one really know the answer to this?
I have bought an oil filter conversion, and the recommended filter
to go with it has a non-return valve in it, and I want to bew sure
which way the oil flows through the filter?
- Alastair Lauener *
- 1964 3.4 S-Type http://www.sn.no/home/nick/alas.html *
Date: Tue, 03 Sep 1996 06:04:16 EDT
Subject: Bits and pieces
Hi guys,
A couple of miscellaneous bits, to the guy who asked about Pninfarina’s
involvement in the xj6 - he did the redesign (subtle changes) that
changed the SII to Series III, according to the book that came with the
car (the PO still had it when I bought mine).
A previous thread was discussing air conditioning gas for the SIII(and
probably earlier, I just got mine regassed with the original R12 (correc
me if the number’s wrong) for $90 AUD apparently although it’s no longer
legal to manufacture it in Austrlia there’s ton’s stockpiled, and freely
available.
John
Level 1, 29-57 Christie St.
St Leonards NSW 2065
Ph: +61-2-9937-8063 Fax: +61-2-9937-8100
Mobile +61-419-617-619
Date: Tue, 3 Sep 1996 08:25:08 -0400
Supercharged.I’ll happily stay with my XJR.
Just say it! The XJR will leave the Bonneville for dead. Just cost 2.5x as
much…
Mark
Date: Tue, 3 Sep 1996 08:54:00 -0400
Subject: V-12 Air pump and XJ SIII rear seats
I am happy to report that Dennis Rockwood’s almost XJ SIII V-12
car has been purchased…by a friend of mine here in Ottawa.
Refer to “Canada-to-US Registration HELP” for Dennis’ trials
on trying to get this car into the States. The car is doing
well and adjusting rapidly to the new caretakers. This is their
third Jaguar, so they know what they are getting themselves
into.
One of the problems that Dennis would have had to overcome
had he kept the car was that it would require and airpump.
At the time, I had thought this was odd, because, as far as I knew,
all Canadian/US cars are virually identical, except that the US
did not import any SIII V-12. That is to say, the SIII XJ6’s and
XJ-S’s are the same. Hence, I had not known of any 80’s on V-12 engine
not to have an airpump, unless it has been removed by some owner, or
PO, trying to get just a bit more power. Well, I now know
something new, this car, a 1986 Canadian spec car, does not, and did
not ever have an airpump. I say did not, because the intake manifolds
should have holes drilled up near one set of mounting stud holes, for
the airpump lines for each cylinder, and these intakes do not have
those bespoken holes. So a question to all those V-12 owners
out there, how rare is this, and why on this car ?
The second item of note on this car is that the rear seats are bucket
seats, and the armrest has a cubby box in it, whereas in ours, the
seat is more of a bench style, and the arm rest is just an armrest.
So for all you XJ SIII owners, what style of rear seats do you have,
bucket, or bench, or something else ?
Regards, Mark Roberts Phone: (613) 763-2924
Ottawa, Ontario, CANADA Fax: (613) 763-3970
1988 VDP - SIII V12 email: markdr@nortel.ca
1963 3.8L E-Type Coupe - 15 years into a 3 year project
Subject: Radiator removal
Hi all !
I spent a wonderful long weekend replacing the radiator in
the SIII V-12. There sure is not alot of room to do anything
in that engine bay…and for those of you with V-12 XJ-S’s,
you think you have cramped working space, you aint seen the
SIII version. I helped a friend replace the rad on his XJ-S,
then did the SIII, and the XJ-S has loads more “empty” space.
For those of you with XJ6’s, you must just be in Heaven
when you have to do something around the engine.
The job of removing the radiator was not hard, just time consuming.
The radiato can be taken out without touching the oil cooler, or
A/C condenser, but the two fans and the radiator shroud does
have to come out. For those with XJ-S’s, the fan shroud does
not need to be removed to get the radiator out, so the job
is much easier.
I took the opportunity to replace the fan belts, and inspect all
the hoses while the front of the engine was so accessible :-),
and sandblasted and repainted everything that should have been
black again, in an attempt to keep the tin worm at bay…loosing
battle I know, but every little bit helps. Total time, including the
painting, about 20 hours. Total cost, about $600.00 CDN, including
the new belts.
Date: Tue, 3 Sep 1996 06:26:57 -0700
Subject: RE: engine number
top) has the prefix NE (1351-8).I am not familiar with this prefix. "Jaguar
My source lists ‘NE’ as the prefix for engines originally installed in
Mark IX 3.8
between 10/58 and 9/61.
Dave Covert
Reactive On-Site Services Lead
…Particle Man, Particle Man, doin’ the things a particle can…
They Might Be Giants
Date: 03 Sep 96 10:07:42 EDT
Subject: Rust converter
I used to use this stuff. The snake oil is a better choice. A magazine test I
read years ago said the only stuff worth anything in this category was zinc rich
type primers. The “rust converter” kind of turned the rust into a hard crust
that eventually flaked off. Why not just scrape/brush it off anyway, and forget
about the “convertor”?
Date: Tue, 03 Sep 1996 07:14:51 -0700
Gunnar Helliesen wrote (in part):
(mine’s an '86)?I’m planning on doing this Real Soon Now™ and am wondering if I’ll
I recently did mine and although a couple of the upper shock mounts are a
little ackward to get to, you do not need to drop the rear subframe. Buy or
borrow a sturdy spring compressor if you’re going to disassemble/assemble
the shock/damper assembly yourself.
Tracy A. Ferrell tracy@brooktree.com in Sunny San Diego, CA, USA
Date: 03 Sep 96 10:07:52 EDT
Subject: NE engine number - Mark Jacobsen
NE is a Mk IX engine number (3.8 litre).
Date: Tue, 03 Sep 96 08:19:00 PDT
Subject: XJ-S Wiper Park / Removing Radiator
On my 88 XJ-S, the wiper park does work & it does not work, just depends on
how it feels at that moment. If they do not park in the correct position (
not vertical in front of my face ), I pull the wiper stick toward me to move
the blades like I only want one wipe & hold until they are in position &
then release.
To Jim, I do not need to remove the bonnet to remove the radiator, but
having 2 people can help lift it out. ( 2 people really help placing it back
in, although I have only had help 1 of the 3 times I have done it ).
Question to the list: On the A/C pump label it states 4 - 6 lbs. Is this
stating that the freon charge should range between 4 - 6 lbs ?
John Himes
88 XJ-S 97K Miles
Date: Tue, 3 Sep 1996 10:33:29 -0400
Subject: Re: About the ignition wire harness Card board and losening head nuts.
Have you seen the D-type ignition wire harness that is available? Bolts on
at the right side valve cover and keeps the wires separated. Not standard, but
they were used on all the racing D & E-types. Looks cool too. See page 59 of
July/Aug Jaguar World, or the XKs Unlimited catalog. I am going to try to make
one - looks simple, just a piece of phenolic w/ some holes in it etc…
Mark McChesney
About the ignition wire harness Card board and losening head nuts.Generally it is not a good idea to loosen head bol nuts when not needed. If
the engine is stone cold. If possible loosen only one at a time.Regards
– End of excerpt from Gram@eumetsat.de
Date: 03 Sep 96 10:36:59 EDT
Subject: Re: XJ-S Wheel removal
Five nuts (or bolts, I can’t remember which) are enough, it sounds like its
stuck on the hub. Try heating the wheel (v. hot water poured around the
offending mating surfaces), and try a north/south rocking motion (don’t pull the
car off the stands/jacks). Once it starts to move a bit, more water and more oil
and more brute force.
Good luck
Regards
End of jag-lovers-digest V2 #326
id for jag-lovers-digest-out; Tue, 3 Sep 1996 19:55:38 +0200 (MET DST)
Date: Tue, 3 Sep 1996 19:55:38 +0200 (MET DST)
Message-Id: 199609031755.TAA22190@ekeberg.sn.no
Subject: jag-lovers-digest V2 #327
Precedence: bulk
jag-lovers-digest Tuesday, 3 September 1996 Volume 02 : Number 327
Another plug for Just Jags
Re: Dear Tommy, the lonely loner from Peterboro’,
XJ-40 VDP Starting problems
E-type on MTV/Nissan warm fuzzies
RE: 70 E-Type No Start
Re: Wind Shield wipers (XJ)
Worn schocks lead to increased and uneven tyre wear, and it extends the braking distance (by
Subwoofer cngo either under the front seats (eg. like what pioneer does offer) or you buy a
Hi Jim Isbell,
oil filter dircetion
Re: 85 XJ-S ac condensate: Where has all the water gone?
RE: SI E Alternator Conversion “Call for Papers”
Re: V-12 Air pump and XJ SIII rear seats
Re: XK Engine Oil Filter
To improve the sound of your Jag you dont remove ANY of the mufflers - it is supposed to be
Re[2]: chevy in jag
brake sleeves
Date: 03 Sep 96 10:37:00 EDT
Subject: Another plug for Just Jags
I’d like to echo Barrie’s plug for Just Jags, they have kept the XJ-S running
nicely (with regular injections of cash). The aren’t so hot (excuse the pun)
with A/C problems, OK for normal it’s broke type problems, but for anything
deeper I’d recommend Paul Taylor in Maidstone.
Regards
Paul Peard
86 XJ-S, Strood, Kent.
Date: Tue, 3 Sep 1996 10:43:23 -0400
Subject: Re: Dear Tommy, the lonely loner from Peterboro’,
Dear Tommy, the lonely loner from Peterboro’,I don’t think we’re losing you, If you came this far with a Jag, and still
drive is, then a
supercharged FORD
Uhh, how do I put this nicely… A BONNEVILLE IS NOT A FORD!!!
Mark
Date: Tue, 3 Sep 1996 15:46:02 +0100
I had this on my Porsche. I jacked up the car after removing the wheel
nuts, then sat down and kicked the bottom of the tyre HARD with both feet.
Three kicks and off it came.
Ian
On Sep 02, 1996 08:15:14, ‘RWOODLIN@garfield.foods.indiana.edu’ wrote:
Help!
banged on the back of the wheel with a rubber mallet to no avail!!Has anyone encountered this situation before? This would have been
extremely frustrating had I had a flat and could not change the tire!Robert Woodling
'84 XJ-S
Date: Tue, 3 Sep 1996 14:53:18 GMT
Subject: XJ-40 VDP Starting problems
Hello all,
I’m having problems with starting my 1988 XJ40 VDP. To make a long story
short the problem is that to get the starter to engage you must tap or bang
on the gear shift. This is while you have the key fully turned. This leads
me to believe that there is a sensor that checks if the transmission is in park
or not. Before I pull off the console I was wondering if anyone knows if this
sensor is inside the transmission (not fixable by me) or is it in the small
black box that sits right beside the shifter (possibly fixable by me). If any
one knows or has this problem before and knows the fix I’m all ears.
Another problem I am having is with the Low Brake Pad warning coming on alot.
The pads have been changed and are far from low. I have checked the wires which
run to the pads and they seem to be OK. I have even tried bypassing the pads
and just running a wire across the plug and still no luck. I think that there
is a break somewhere but can’t find where. If anyone knows of a way to bypass
this all together I’d be happy with that.
Thanks for all the advise
Craig
Date: Tue, 3 Sep 1996 11:07:44 -0400
Subject: E-type on MTV/Nissan warm fuzzies
My brother tells me that there is an advert on MTV that features an S1 E-type
ots. Has anyone seen it? It has a tennis player and a James Bond type chase
scene.
While I’m on the TV subject, has everyone seen the new Nissan TV ads (US)? I
think they are very cool - makes me want to adopt the little owner of Nissan
(is he really the owner/CEO or something?). Can’t see us doing that w/ Alex
Trotman.
Mark
Date: 03 Sep 96 11:09:28 EDT
Subject: RE: 70 E-Type No Start
If there are other electrical problems such as those you describe above, it
could be something other than a starter solenoid. Perhaps something as simple
as lose or dirty electrical connections from the battery. No, then again,
nothing is that simple.
Good luck,
Ed
Date: Fri, 30 Aug 1996 16:10:21 GMT
Subject: Re: Wind Shield wipers (XJ)
In message 199608301315.IAA31402@mail.utexas.edu Jim Isbell writes:
On my newly aquired XJS the windshield wipers park on the left side,
right in front of my face. Is this reversable?
If you have the same Electrolux motor in there as does my XJ-S, then yes,
it’ll only be a matter of opening the gear box and moving the rest position
switch cam by 180 degrees.
If you don’t, then I don’t know ;-(
Stefan Schulz
jaguar@suaviter.demon.co.uk
Date: Tue, 03 Sep 1996 18:44:35 +0100
Subject: Worn schocks lead to increased and uneven tyre wear, and it extends the braking distance (by
not providing maximum traction), and makes the car “nervous” and more sensitive to sidewind
impacts.
How the wear pattern looks depends on many factors, but can lead to uneven wear on the
inside, on the outside shoulder or across the thread, from rubber to rubber island , the forward
edge lower than the rear ward edge. In short not easy to say anything general about unless
youre an expert (and I’m not) and its different from make to make.
However similar symptoms can arise from incorrect camber caster and toe-in adjustments (the
wear out of the shoulders). Both my Jags eat the outer edge of the front tyres the last set lasting
30.000 km (Pirelli P-600 205/70 VR15), the rear lasting 50,000, the rear with absolute PERFECT
even wear.
It is not possible to use a “builders” water-level tool for accurate adjustment nor measurement.
The only way is a good and careful specialist shop. Note that Jaguar manuals specify quite
rigirously how the exact measures of the upper wishbones should be (when disassembled), and
the other measurements should be set accurately.(like all other cars…)
If the Jag book specifies 1/2 degree positive camber (top of wheel outwards) then that is as it
should be. The Jag front suspension is a double wishbone with un-equal length arms. This
causes a camber change with the motion of the wheel, and in the case of Jaguars, the camber
goes toward the negative when the spring is depressed (i.e moves into the wing). causing the
wheel the lean “in to the curve” just like a motorcycle rider does (althoug considerable less
pronounced). The camber also goes negative on extreme spring expansion. However there is
more to this issue since the castor angle ( the direction of the Crown pin attacted at the anchor
points of the upper and lower wishbones outer points) changes the camber whel the wheel is
turned left and right. Here the car manufactures have wildly differing opinions and solutions.
A Mercedes inner wheel in a curve goes Positive (and alot), and is part of the reasons for a
Mercedes being able to “turn on 5p coin”. The Jag is much much les pronounced, and the Jag
S3 XJ6/12 turning radius is appallingly large - room for some DIY’ing there - any takers ?
However all these issues are only interesting for vehicle dynamics engineering buffs - the
“normal” car driver does not need to know all this. Important is the setting is done by a real
professional, that knows what the issue is about and what affects what and how to read a
(Jaguar) Service manual the RIGHT way…
'78 XJ6C S2 Coupe, (The RED spinner )
84 XJ12 S3 Sov. HE (The great grey whisperer)
'74 W116 Mercedes 280 SE (The silver shadow) - this should really have been a Jag, started as
a Jag-temporary-replacement-extra-car-but-has-cost-too-much-to-sell-so-I-Cant-so-I-wont
'93 Audi 80 Avant (The Audi) - wify’s car - according to her the only CAR we have.
Planned :
an Morris Minor 1000 Traveller (for Wify) - but only if she trades in that awfully perfectly
engineered Audi…
an e-type , Either an OTS or a Coupe 2+2,
an XJS V12 Convertible
a MK2
a MK7
a C- or D type (will be a replica I Guess)
Life is too short and not enough money (because of all these money guzzling wrecks…)
Date: Tue, 03 Sep 1996 18:51:29 +0100
Subject: Subwoofer cngo either under the front seats (eg. like what pioneer does offer) or you buy a
bass-Tube-box , place it in the boot and attach it with a tube to the rear shelf (metal cutting
required), or put the woofers directly in the rearshelf . The metal cutting is REALLY difficult in
this area, but possible. The boot method gives deep wonderful bass.
You will however not be able to make sensible use of the rear mirror inside, since the bass
twacks shake the roof so vigorously that the image gets really blurred even at sensible (<120
dB) volumes…
Regards. Jeffrey Gram
Date: Tue, 03 Sep 1996 19:07:47 +0100
Subject: Hi Jim Isbell,
Hi Jim Isbell,
Footwell rust needs rustproofing, and the wirebrush method will work. Use it to a little bit outside
the infected area. The Rust Primer is a substance that converts the rust (Ironoxide) into some
other chemical “goe” which is not rust. Snakeoil or not, it does work, however so does good old
priming and painting.
I’m afraid I cannot recommend the spray can method, First it will leave paint spray everywhere,
secondly the paints are usually crap (honestly), thirdly the paintlayer is too thin (even if you use
a can on a square foot, fourthly the paints are not tough enough, and therefore the whole
exercise will be repeated in six months time, when new rust break out, this time just worse.
Use a proper primer with a handoperated hairbrush, to a thoroughly cleaned area, no dust, not
wet not greasy - in short clean enough to eat from. (dont test - or you will have to clean again…)
When dry (a day ?) sand down a bit with fine sandpaper and apply a topcoat with a brush .
The best is to use 2-component pack paints, these are more expensive, and you can only mix
what you need here and now since the stuff hardens, however these are tougher. You choice.
The rubber strips are simply to avoid the carpet to develop a pattern like the bottom plate.
These foam -rubber water absorbers are a real engineering feat. I replaced mine with a layer of
bitumen sound insulating thingies, undercarpet, and the original carpet on top. Works OK.
Date: Tue, 03 Sep 96 10:14:54 PDT
Subject: oil filter dircetion
Out-to -inside. Check the holes around the outside. They have a one-way flap
to keep oil in the filter.
LLoyd - I think they are all the same -
Date: Tue, 3 Sep 1996 13:28:04 -0400 (EDT)
Kirby mentions that certain intake modifications increase the engine
sound at high speeds. Some people might think this sounds neat.
Thomas E. Alberts
Date: Tue, 3 Sep 1996 13:33:40 -0005
Maybe. Gas shocks that have lost gas pressure will cause the front
to sag, which in turn will cause the front tires to wear on the inner
edge. I don’t think I’d replace the shocks and call it fixed,
though; I’d have the alignment checked.
| - Palm’s Postulate
Date: Tue, 3 Sep 1996 13:42:38 -0400 (EDT)
Subject: Re: 85 XJ-S ac condensate: Where has all the water gone?
Trust me Bob, if you had clogged drain tubes there would be no question about
it. You get a foot bath whenever you corner. Yours may be draining so
well that there is no excess condensate by the time you stop. Where
do you live, Alaska? On hot humid days (every day here in VA) I usually
get a small puddle under the car after a long drive. The drain tubes are
supposed to drop the water on the exhaust pipes by the way. Anyway, if
you are not getting wet feet, then congratulations and quit worrying.
Best,
Thomas E. Alberts
Date: Tue, 3 Sep 96 11:37:00 PDT
Subject: RE: SI E Alternator Conversion “Call for Papers”
In Hunt Dabney’s post to the net he states he wants to replace
his generator with a alternator. If the replacement alternator
is a direct bolt in for the generator, will it not also be too
close to the heat of the exhaust?
E-mail: lpratt@its.bldrdoc.gov
Date: 9/3/96
Time: 11:37:00 AM
This message was sent by Chameleon
From: Volker Nadenau nadenau@ipers1.e-technik.uni-stuttgart.de
Date: Tue, 3 Sep 1996 19:50:50 +0200 (MST)
Subject: Re: V-12 Air pump and XJ SIII rear seats
Hi Mark,
I was wondering why only very few people report on SIII V12s. But you
gave the reason. Concerning the air pump I can tell you that my '81 V12
does not have an air pump either. I realized that during the removal of
the alternator, when the workshop manual recommended to remove the air
pump first. I really do not now what the air pump does. Has it something
to do with the air/fuel ratio and emmision control? If so, it is clear
that the german version like mine do not have the airpump. Catalytic
converters were introduced only in the last SIII V12s since '89, as far
as I know.
I knew, > all Canadian/US cars are virually identical, except that the US
Mine has the bench type seat. As far as I know only the luxury versions
Daimler Double Six and VDP were fitted with the individually sculptured
seats in the rear.
bucket, or bench, or something else ?Regards, Mark Roberts Phone: (613) 763-2924
Regards
Volker
Volker Nadenau Phone: ++49 711 685 7200
University of Stuttgart Fax : ++49 711 685 7143
Institute for Physical Electronics Internet: nadenau@ipers1.e-technik.uni-stuttgart.de
Pfaffenwaldring 47
70569 Stuttgart
Germany
Date: Tue, 3 Sep 1996 13:53:02 -0005
Subject: Re: XK Engine Oil Filter
can decide, and I don’t want to remove it for such a small piece of knowledgeDoes no-one really know the answer to this?
I only know the answer in the GENERAL case, not in the specific case
of the XK – hence I didn’t answer the first time. However, I have
never seen an oil filter, or any other filter for that matter, that
didn’t flow from the outside in. There are two reasons for this: 1)
more dirt can accumulate on the outside before plugging the filter than on
the inside. 2) The filter element can withstand more pressure
differential without tearing.
| - Palm’s Postulate
Date: Tue, 03 Sep 1996 19:54:12 +0100
Subject: To improve the sound of your Jag you dont remove ANY of the mufflers - it is supposed to be
that way , not a bloody pain roaring down the road, with birds and old ladies stunned by fear of
the roar of the big cat.
If you must improve, then get an aftermarket damper system, with a glorious note, but with the
control over the pressures in the exhaust system, which are designed as part of the engine to
maximise also fuel economy (even in a gas-guzzling 12 cylinder overkill engine).
However the real good notes come from the inlet system as Kirbert writes, a sextet of weber
downdraughts will strike with a fabolous sound, clean up the messy engine bay as well with all
this emmission control garbage, fuel injection crap etc… A bit of re-engineering in the engine bay
with make the cat’s paws run faster than the hoves on the well known horse - you know the one
with another but different high-pitched squeal
But then you better take the car to the circuit - Beasts must be kept in closed areas - dont you
know that ? - only cultured and tame cats are let on the public road.
Stay tuned - but with modesty. Regards Jeffrey Gram
Date: Tue, 3 Sep 1996 10:48:54 -0400
Subject: Re[2]: chevy in jag
The Chevy gets the nod because, as high school kids have been
demonstrating for over 30 years, you can build a nice mouse motor with
plenty of hp and torque for very little money. There are probably
more overhaul and performance parts available, at least in the US, for
the small block Chevy than every other engine put together.
I'm not a Chevy lover and I wouldn't dream of replacing the V-12 in my
XJ-S or my E-Type. To me the engine is part of the very essence of a
Jaguar. The only small block Chevy I've ever owned is the one that's
in my Suburban. However, I've worked as a professional mechanic,
owned a speed shop and built mouse motors for others. They're cheap
to build, easy to maintain and very reliable. Newer, more exotic
designs require more special tools and equipment to diagnose and
maintain and parts are more expensive and harder to come by.
Mikec
______________________________ Reply Separator _________________________________
Subject: Re: 90-93 xj3 canadian /chevy in jag
Author: palmk@gcn.scri.fsu.edu at INTERNET
Date: 08/30/96 09:28 PM
steven leamy:
ok let's start a fight! I'm thinking about putting a chevy v8 in my
87 jag
I only have one question: If you have decided an engine swap is the
way to go, why in HELL would the Chevy V8 come to mind? How about
the NorthStar, or Ford’s Modular V8, or any of the other dozens of
engines that would be a better choice? It completely escapes me why
the Chevy V8 seems to always get the nod.
| - Palm’s Postulate
Date: Tue, 3 Sep 1996 11:07:12 -0700
Subject: brake sleeves
I am considering sleeving the hydraulic cylinders in the brake/clutch
systems of my '66 E-type. Any advice on brass vs stainless sleeves and
recommendations for a shop? I plan to switch to DOT 5 silicone fluid at
the same time.
End of jag-lovers-digest V2 #327
id for jag-lovers-digest-out; Wed, 4 Sep 1996 02:22:43 +0200 (MET DST)
Date: Wed, 4 Sep 1996 02:22:43 +0200 (MET DST)
Message-Id: 199609040022.CAA19342@ekeberg.sn.no
Subject: jag-lovers-digest V2 #328
Precedence: bulk
jag-lovers-digest Wednesday, 4 September 1996 Volume 02 : Number 328
Re: Rust converter
Re: Re[2]: chevy in jag
Re[2]: E-Type mirrors
Re: Worn schocks lead to increased and uneven tyre wear, and it extends
Re: High oil-pressure on 84 XJ6
Palo Alto reminder
Re: brake sleeves
Re: Palo Alto reminder
Re: E-type on MTV/Nissan warm fuzzies
Re: Jaguar XJ-S
Re: Subwoofer cngo either under the front seats (eg. like what
Re: Leather Dye Source
Introduction
Re: Stuck wheel, XJ-S
Series III XJ6 Lukewarm Starting Problem (fwd)
Date: Tue, 3 Sep 1996 10:21:28 -0400
You could move your steering wheel over to the right side where it
belongs . . .
<grin>
mikec
Subject: Wind Shield wipers (XJ)
Author: JISBELL@mail.utexas.edu at INTERNET
Date: 08/30/96 07:13 AM
My wind shield wipers park on the wrong side. Can this be cured?
Date: Tue, 3 Sep 1996 14:10:03 -0005
Subject: Re: Rust converter
A magazine test I
type primers.
We’re talking two different things here. The zinc primers are the thing
to use BEFORE the metal rusts.
Somebody wasn’t following directions. You’re supposed to
scrape/brush off anything that will come off, and THEN use the
convertor! That prevents any flaking problems, and prevents the
minor surface rust remaining from growing.
| - Palm’s Postulate
Subject: Re: Re[2]: chevy in jag
The Chevy gets the nod because, as high school kids have been demonstrating for over 30 years, you can build a nice mouse motor with plenty of hp and torque for very little money.
If any of these were valid issues, we wouldn’t be talking about a
Jaguar! All are EXCELLENT reasons to buy a Camaro!
| - Palm’s Postulate
Date: Tue, 3 Sep 1996 11:32:23 -0400
Subject: Re[2]: E-Type mirrors
My understanding was that breakaway mirrors were external (to avoid
impaling pedestrians). Of course, that may have been a misinterpretation
or misunderstanding on my part. There is no obvious breakaway point on my
inside mirror. However, the mirror shell is plastic and would probably
break at the ball and socket mount with only a modest impact. The mount to
the windscreen rod may also be designed to fail under a certain amount of
impact. For what it’s worth, the mirror itself appear identical to the one
in my '88 XJ-S. I haven’t removed the XJ-S mirror to compare the small
stub, but they are the same in all other respects.
MikeC
Subject: Re: E-Type mirrors
Author: “George W. Cohn” gwcohn@AZStarNet.com at INTERNET
Date: 08/31/96 07:30 PM
Mike, just to satisfy my curiosity, does your interior mirror
appear to have some mechanism for “breaking away” from the rod
in an accident?
Date: Tue, 3 Sep 1996 21:15:36 +0200 (MET DST)
Subject: Re: Worn schocks lead to increased and uneven tyre wear, and it extends
the other measurements should be set accurately.(like all other cars…)If the Jag book specifies 1/2 degree positive camber (top of wheel outwards) then that is as it
I was not suggesting to do any adjustements or so, I was just curious
why my front tires clearly have negative camber now which is coherent with the
wear pattern and I will check again after it’s back from adjustement.
Greetings from Berlin (where I am today) lots of Jags on the “Kurfuerstendamm”
- Matthias
Date: Tue, 3 Sep 1996 13:43:00 -0400
Subject: Re: High oil-pressure on 84 XJ6
In message “Re: High oil-pressure on 84 XJ6”,
‘southern@sol.cgd.ucar.edu’ writes:
This seems very high. My '81 Daimler XJ6 (high compression pistons, 88C
themostat and non-working electrical fan) normally warms up to and stays
at 88C. It only creeps over 90C on the hottest of days.
Thanks for the reply. I’ll check the items you listed if I go back to this
car for another look. My hesitancy is based on some other symptoms (low
power, broken catalytic convertor, etc.) + a premium price. Oh well - another
winter without a toy won’t drive me too silly!
Regards - Albert Cohoe
Voice: 393-3440 or 613-763-3440 Email: cohoe@nortel.ca
Date: Tue, 3 Sep 1996 13:37:09 -0700
Subject: Palo Alto reminder
Hello Everyone-
Just a reminder about this weekends all-British car meet in Palo Alto,
this Sunday (9/8/96). It’s $15 to enter your car, and free for the public
to attend. Being right across the street (El Camino) from the Stanford
Shopping Center ensures a steady stream of people all day, making this
(IMO) about the most fun show of the year. Last year there were (I’m
guessing) at least 50 Jaguars attending.
Ryan.
http://www.best.com/~border/pages/jag/jag.shtml
From: “Mark McChesney” mmcchesn%ford.com@vm1.cc.nps.navy.mil
Mark reminds us, with great vigor;
<Uhh, how do I put this nicely… A BONNEVILLE IS NOT A FORD!!!
I think he was just stating that it is more like a Ford, compared to a jag.
LLoyd
Date: Tue, 03 Sep 1996 15:04:21 -0600
Subject: Re: brake sleeves
Greetings
You write:
the same time.
I had the wheel cylinders in a '59 Mk 1 resleeved in stainless by Imperial
Machine in Lincoln, Nebraska. They advertise in Hemmings. 2-week turn-
around, good quality, and their price was better than the places advertising
brass. A recent post on the Jag-Lovers suggests that brass tends to stick
to the rubber seals in the cylinders, and in extreme cases breaking loose
under braking. I have no idea how silicone brake fluid would effect this.
Merritt
| Merritt Smith OOOOOO / OOOOOO |
| Software Design Engineer OOOO /__ ___ OOOO Hewlett Packard |
| WSY Technical Consulting OOO / // / OOO MS 37 |
| (970) 229-2162 OOO / //__/ OOO 3404 East Harmony Road |
| (970) 229-3002 FAX OOOO / OOOO Ft. Collins, CO 80525 |
mhsmith@fc.hp.com OOOOOO / OOOOOO |
Date: Tue, 3 Sep 1996 14:57:36 -0800
Subject: Re: Palo Alto reminder
Hello Everyone-
guessing) at least 50 Jaguars attending.Ryan.
BestWeb.com - Lease or Buy Domain Names - Best Web Limited
Ryan, is there any more online info about this event? Will you be showing
your MK1 there?
Date: Tue, 3 Sep 1996 18:13:26 -0500
their ramp.Ian
Ian. So I find a high curb and get the old Jag tilted enough so I can
crawl under and along comes this bozo who is eyeing some floozy adjusting
her panty and Bingo! I’m history. Or it could be some whimp who has a
thing about those
“those danged furrin cars” and he deliberately writes my epitaph. Actually,
I am going to invest in stands and hopefully may run into a real garage
sale and pick me up a professional hydraulic jack for a steal. Thanks for
the idea. What I did was I wrapped the bottom master cylinder with T.P. and
I could see that the leakage was coming out of the operating rod’s rubber
dust excluder. So now I’m going to have the cylinder resleeved with
stainless steel.
Date: Tue, 3 Sep 1996 18:19:57 -0500
Subject: Re: E-type on MTV/Nissan warm fuzzies
Trotman.Mark
As an advertising pro of many, many years I just can’t agree with you on
the recent Nissan series. They waisted lots of dollars with all those
30-second teasers. I thought maybe the little fellow was brain dead. It’s
too syrupy for me. Kind of reminds me of all those Kodak spots with the
bleeding heart music and granpa and grandma “finally” getting up the
courage to visit their rotten son and the grandkids. Oh, well, to each his
own. But will this series sell Nissans. That’s the bottom line in
advertising.
Date: Tue, 3 Sep 1996 18:24:18 -0500
close to the heat of the exhaust?Name: Lauren Pratt
Date: 9/3/96
Time: 11:37:00 AMThis message was sent by Chameleon
I had a Delco alternator installed on my 64 E-type Series One in 1978 and
it’s been doing a great job of keeping my battery fully charged since that
time. It sits flush against the left subframe steel tubing to keep it about
as far away from the exhaust manifold as was the generator. Trouble is, the
Type 1 E belt is too short and a 4.2 belt is too long. A Mark II belt is
the best substitute I could find.
Date: Tue, 3 Sep 1996 18:32:06 -0005
scene.
Yeah, I saw it – on a regular network, not just MTV. Monica Seles
is the player, Nike is the sponsor. Really dumb ad, although the
car is pretty. It smokes, though, and they give us a close-up of it
smoking.
| - Palm’s Postulate
Date: Tue, 3 Sep 1996 16:30:22 +0700
My '85VdP has a rear bench seat that looks like two closely spaced
bucket seats. The fold-down armrest has a cubby in it as well.
Greg
Date: Tue, 3 Sep 1996 19:07:17 -0005
Subject: Re: Jaguar XJ-S
MR RICHARD P HUSTA:
A few years ago we developed a neat combination armrest, cupholder
and phone message pad. Jaguar told us there wouldn’t be any demand
from their owners!
A quote from someone wise:
“There cannot be a demand until there is a supply.”
– boB Morris
Jaguar Corp. clearly doesn’t have a clue since Sir William croaked.
They don’t build a SWB XJ12; they don’t offer manual transmissions;
they don’t think a combo armrest/cupholder/message pad would have a
market. Screw 'em, offer the product anyway, I’ll mention it in my
XJ-S booklet, we can describe it on the jag-lovers discussion
group, and we can establish a link from the Jag-Lovers WWW site to
your site for a pic and online ordering info.
| - Palm’s Postulate
Subject: Re: Subwoofer cngo either under the front seats (eg. like what
Jeffrey Gram:
this area, but possible. The boot method gives deep wonderful bass.You will however not be able to make sensible use of the rear mirror inside, since the bass
dB) volumes…
If your objective is maximum bass regardless of fidelity, all of the
above is applicable – and you can be proud of an unusable mirror.
But if your objective is good, listenable music, forget anything
having to do with tubes or ports; they trade fidelity for volume.
| - Palm’s Postulate
Date: Tue, 03 Sep 96 15:57:42 PDT
Subject: Re: Leather Dye Source
Hi All
Another good source for leather dye kits is a company called Croftgate in the
UK, there was an article recently in Practical Classics which compared about 6
kits available from various companies in the UK
Croftgate came out best, they also supply Rolls Royce (English car manufacturer)
Tel # for Croftgate 44 1706 216096
I have a copy of the article if anybody is interested. I will be buying a kit
and will keep you posted as to the results.
Regards
Steve
Subject: Leather Dye Source
From: Ed Scripps 73200.2362@CompuServe.COM at CCMAIL
Date: 8/28/96 7:46 PM
Jim try,
Gerard Coachworks Jaguar
12840 NE 21st Pl
Bellevue, WA
1(206)869-1747
They have a great reputation for their leather dye and they deal almost
exclusively with Jags.
- -Ed-
Date: Tue, 03 Sep 1996 23:41:35 +0200
Subject: Introduction
I joined the jag-lovers-list some days ago, and want to introduce my
self.I bought a 1973 XJ6 series 1, in may, this year, after wanting to
get a series 1 for some years.It�s a low mileage car, looking almost
as new inside.The first owner had the car until he died at the age of
88 in 1990. The second one did take well care of the car and among other
thing had it beautifully repainted (BRG).I�m the third.
I work as a computer engineer in an insurance company and live in the
middle of Oslo, Norway in a old restricted house (my hobby for the last
years). I have a wife and two children, who all love driving in the car.
I�m planning to overhaul the brakes and change the servo unit. And there
is something strange with the heating-system. Either too hot or no heat at
all. When the hot-air knob is almost at max. its too hot, when I turn the
knob only 1 mm(1/25 inch) to left there comes cold air only.
I will take at closer look at this soon, as the temperature starts
decreasing in a week or two.
Regards
Date: Tue, 3 Sep 1996 20:10:48 -0400
Subject: Re: Stuck wheel, XJ-S
Robert- Did you have any luck with the wheel? I hadn’t read my mail for a
couple of days (Busy weekend) and I see now you had a problem. Looks like
you had some good suggestions, but I’ll add my 2 cents:
- -Did you pry the “Cat” out of the wheel center so the penetrating oil could
get down into the hub area? - -On other vehicles I’ve used a sledge hammer against a block of wood on the inside of the wheel. Hit it a couple of licks, rotate the wheel half-turn, and hit some more. on one old truck, I loosened the lug nuts a turn or two, and drove crazy down the road (slow speed, of course, and it would be a last resort on the Jag!) BTW, i was in bloomington on Sunday- my father’s in the hospital there, had a knee joint replaced. Cheers, Brian Sherwood From: William F Trimble trimbwf@mail.auburn.edu Date: Tue, 3 Sep 1996 19:22:29 -0500 (CDT) Subject: Series III XJ6 Lukewarm Starting Problem (fwd) Dear Jag Lovers: I tried to send the following message over the weekend, but our e-mail system was down, so I don’t know if everyone got this or not. My apologies to those who already received this. Feel free to delete: I hate to bomb the list with another of my Jag problems, but this one’s been bugging me for a couple of months at least. Here’s the problem: The car (1985 XJ6 Series III) starts OK when cold, after sitting overnight, when the ambient temperature here in Alabama is about 70 degrees F. The car runs fine. And the car hot starts all right, although sometimes with a little cranking. It runs right at 90 degrees C, even on the hottest days with the AC on. Before replacing the thermostat in March, the car ran very cool, and I had no starting problems. The problem is that if the car sits all day in 90 degree plus temperatures, it will not start. Nor will it start after sitting for about 4-5 hours in cooler weather. Rick the mechanic and I have discussed this problem and played around with the thermotime switch, bypassing it and grounding out the cold start injector manually. The car starts instantly every time we do that. The thermotime switch is new, although it is 8 sec. rather than seconds at 35 degrees C. Could it be a broken wire leading from the thermotime switch to the cold start injector? I had to pull the injector harness out of the way back in March when I did the thermostat job, and I might have pulled something loose. The connections at the thermotime switch and at the cold start injector look OK, although the one at the thermotime switch is a little worse for wear, and the rubber boot is cracked from heat. It has always bothered me that the car, as long as I have owned it, has not started on the key, but has always needed some cranking. Could this in some way also be symptomatic of the problem? Any ideas would be greatly appreciated. Bill Trimble Auburn, Alabama End of jag-lovers-digest V2 #328 ******************************** Return-Path: @owner-jag-lovers-di1 Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4) id for jag-lovers-digest-out; Wed, 4 Sep 1996 13:47:47 +0200 (MET DST) Date: Wed, 4 Sep 1996 13:47:47 +0200 (MET DST) Message-Id: 199609041147.NAA09816@ekeberg.sn.no X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f From: @owner-jag-lovers-di1 To: jag-lovers-digest@sn.no Subject: jag-lovers-digest V2 #329 Reply-To: jag-lovers@sn.no Errors-To: @owner-jag-lovers-di1 Precedence: bulk Status: O X-Status: X-Newsgroups: mail.jag-lovers-digest jag-lovers-digest Wednesday, 4 September 1996 Volume 02 : Number 329 61 Mk2 for sale Re: XJ-40 VDP Starting problems De-rusto Seeking '85 XJ6 A/C renewal advice Re:Series III XJ6 lukewarm starting problems Subwoofer cngo either under the front seats (eg. like what pionee Replacing shocks on 85 XJ-S Washington,DC area show, Jag club activity New England, USA area events Re: Seeking '85 XJ6 A/C renewal advice 61 E Alternator: Part I 1947 Mk IV Bass in an XJS XJS — Oops!!! (a.k.a. Chassis failure) Re: Tire wear and shocks XK Engine oil filter Re: Condensate drainDate: Mon, 2 Sep 1996 09:52:57 From: Bill Detelich bdetelic@nando.net Date: Tue, 20 Aug 1996 12:02:18 -0400 Subject: 61 Mk2 for sale I have a 61 3.8 Litre Mk2 that I need to sell. When I purchased this car I planned on keeping it but other things have come up. She has a completely rebuilt engine and was converted to 4 speed with overdrive. The body is very straight with a minimum of rust on the doors and rockers. The interior is nice but was redone in vinyl. The wood is in very good shape. I would like to get $6000 for this car but would consider all reasonable offers. The car is in North Carolina and stays in our dehumidified garage. Thanks Bill Detelich From: cobac@ix.netcom.com (Eric J Faber ) Date: Tue, 3 Sep 1996 17:46:30 -0700 Subject: Re: XJ-40 VDP Starting problems You wrote:
story
bang
leads
is in park
if this
small
Hello,
Craig, I had a similar problem with my 1989 XJ40 VDP when I first
purchased it. The car wouldn’t start, and I heard a high
beep,beep,beep sound from the dash, which puzzled me. I had to jiggle
the shifter in park for it to start, then the beeping stopped, the “P”
indicator relight on the dash and shifter, and the car started.
To fix this embarassment, I pulled off the rubber shift surround
(carefull not to break the crhome/plastic surround), unscrewed the
shift knob, unscrewed the (4) screws on the shift indicator and pulled
it up. Then I carefully cleaned those now visible gold metal contacts
on the left of the shifter (black box), greased everthing up and put it
together. I’ve never had the problem again (Unless, the car is out of
Park!
The problem could also be the solenoid inside the starter motor.
It may have gotten wet, and the solenoid may be sticking or not getting
good contact to start, this happened once to me after cleaning the
engine.
I don’t know about your brake pad problem though. But, on an Audi
I worked on, the wires to the pads had been slightly cut after I
installed new ones (they had hit the spinning brake rotor), this caused
the “Brake pad” light to turn on.
Maybe one of the wires under the dash had been crimped/cut. Also,
there are wires in the boot behind the spare wheel for the rear brake
pads. When I unplug these I can recieve a “Brake Pad low” on my Jag.
I would try jumping all 4 brake pad wires at the main harness (by the
fenders, and in the trunk) and see if the light goes away.
Hope all this talk helps,
Any questions? feel free to ask
cobac@ix.netcom.com
'89 XJ40 VDP
From: David J Shield David_J_Shield@ccm.fm.intel.com
Date: Tue, 03 Sep 96 13:34:00 PDT
Subject: De-rusto
Jim Isbell asks about rust cures:
> rust was evident and some scale. ............I am now going
> to take a wire brush to the entire area then use something I found >
> at the auto parts store on it, says it will convert the rust into
> primer, sounds like "snake oil" to me, but what the hell. Has
> anyone had any experience with these products that turn rust to
>primer?
I've used such stuff over the years with pretty good results. One
example is the wheelbarrow, which lives outside. About 10 years ago
the inside became really rusty. I cleaned the loose rust with a wire
brush then gave it a couple of treatments with a 3M product. It goes
on white, then turns black as it reacts with the rust. Don't recall
the name, might be De-Rusto, or whatever the 3M equivalent is. A
couple of coats of Red Rustoleum for good measure, and it's been fine
since. The rust has only returned where the paint has been penetrated
(by rocks, shovels, etc.). As for 'turning rust into primer', that
statement sounds a little strong, but I use it on any rusty metal and
it's been great.
Date: Tue, 03 Sep 1996 18:28:04 -0700
Subject: Seeking '85 XJ6 A/C renewal advice
Fellow jag lovers:
As you may recall, I’ve been restoring a series I E-type OTS for a
couple of years now (still making decent progress, though I have yet to
fire up the engine). Well, the wife recently decided she didn’t want to
drive her '90 Mazda MPV minivan around anymore… too many people
assumed that she could be the driver for group trips. When she
mentioned that, why I, being the good jag-lover that I am, immediately
suggested a series III XJ6.
Of course it didn’t take long to get her hooked, and now we own an '85
model. I figured that the cost of the XJ6 would about offset what we’d
get for the minivan (OK, so I’m a little optimistic… I prefer that
bias in general in life). And OK, the car was in the shop more that our
garage for the first 2 weeks, but now it’s pretty much ready to roll for
a while, with one exception: the A/C doesn’t work.
The shop (Jaguar Purrformance Center in Mt. View, CA) has determined
through testing that we have a couple of problems: first, the A/C
amplifier doesn’t work at all, and second, that the compressor and high
pressure hose both leak badly (needless to say, there is no longer any
freon in the system). Since they estimated close to $1500 US to fix
these problems, I thought I’d take a shot at doing at least the parts
replacement myself, then taking back to them (or another A/C shop?) to
recharge/retest. It looks like I can get all the parts (including a new
receiver/drier recommended with new compressor) thru XKs or other
suppliers for around $700 or less, so I could save a lot of $ by doing
some of this myself. Obviously, the replacement freon isn’t cheap
either, so that will eat into the savings.
What I’d likek to know is if any of you have had any experience
replacing these components, or any thoughts on the matter, before I
tackle this job. I know the compressor is a GM product - can a rebuilt
or new one be had for a lot less that $215 (XK’s price - I don’t have
any others handy)? I figure I can turn a wrench pretty well, and since
the system’s already empty, it should be ready for me to try.
TIA for any input/advice on the subject…
Brian
- at least there’s no A/C on my E-type to restore…
Brian Chase '66 E-type OTS (7/94 to present)
Amdahl Corp. '85 XJ6 (8/96 to present)
Sunnyvale, CA, USA btc00@eng.amdahl.com
Date: Tue, 3 Sep 1996 21:30:25 -0400
Subject: Re:Series III XJ6 lukewarm starting problems
Bill, it sounds like you may be losing pressure in your fuel injection system
when the fuel pump is turned off. This results in easy starting when it’s
cold (the cold start injector provides a rich enough mixture) and for a short
time after the engine has been turned off (residual fuel in the injectors),
but lukewarm starts can be a humiliating series of long grinds.
I recently fixed this problem on my Series II XJ12 by replacing the
non-return valve (located near the fuel pump). You or your mechanic can
check for this problem by simply inserting a pressure gauge into the
injection system and observing the effect on the fuel pressure of turning off
the ignition. The pressure may drop slightly, then should stabilize at a
reasonable level (greater than 26 psi in my XJ12) thereafter. If it drops
like a stone, you’ve found the problem.
There are several other possible reasons for a pressure drop: an
injector may be leaking (suspect this if your oil level is rising and the
oil smells like gasoline) or a pressure regulator may be leaking. By looking
at a flow diagram of your injection system you should be able to figure out
which line to clamp to test each component.
If you’d like to tackle the job yourself I’ll be happy to help you with
any other information I can supply (based on my XJ12). I’m embarrassed to
admit how long I put up with this problem before tackling this relatively
simple diagnosis and repair.
Jon Schrock
1976 XJ12L
1965 E Type
1956 XK140
Date: Tue, 03 Sep 96 22:41:00 EDT
From: ** SHANE MANTOSZKO ** IBMA INVENTORY ANALYST **
*** Resending note of 09/04/96 06:02
*** SYDVM1(SHANEM) PH. (02) 354-4918 CUMBERLAND FOREST FE21
*** INTERNET - SHANEM@VNET.IBM.COM *** IBMMAIL - AUIBMSPM ****
or you buy a
I have a phillips catalogue here in front of me, and there is a great
looking bass speaker that fits inside the spare wheel. Just reverse
your wheel around, may take a bit of fiddling, and fit this speaker in.
Looks like a hell of a set up…hopefully it unplugs easily so you
can get the wheel out in a hurry. Trouble is that the sound will be
muffled by whatever cover you have over the wheel in the boot.
Date: Sun, 01 Sep 1996 19:47:46 -0700
Subject: Replacing shocks on 85 XJ-S
On the off chance any of you out there have the inclination and the time… Could you walk me through the major steps in replacing fron and back shocks on my 85 XJ-S? I’ve never done this before and if any of you have you could make the adventure much easier !!! Thanks in advance, Rob W-M 85 XJ-S From: Michael Frank mfrank@westnet.com Date: Tue, 3 Sep 1996 23:31:53 -0400 Subject: Washington,DC area show, Jag club activity Someone was asking about club activity in the DC area. The “Nation’s Capital Concours” will be held Sept 15 in Rockville, MD at Montgomery College. Contact is Bill Moore 703-827-9509 From: Michael Frank mfrank@westnet.com Date: Tue, 3 Sep 1996 23:31:55 -0400 Subject: New England, USA area events Sept 8 Jag Club of Connecticut British Car Show Wickham Park, Manchester, CT Call 203-776-8148 Sept-20-22 British Invasion. Stowe, Vermont Sept 22 British MADDness Car show Bethlehem, CT 203-776-8148 Sept 29 Jaguar Assn. of New England Hill-Stead Museum Tour & Lunch Farmington, CT 860-928-9786 Mike Frank 1969 E-Type 2+2 From: Michael Frank mfrank@westnet.com Date: Tue, 3 Sep 1996 23:58:50 -0400 Subject: Re: Seeking '85 XJ6 A/C renewal advice Brian: I completely rebuilt the A/C on my 1969 E-type recently. I think what you are planning is very reasonable. A few pointers: 1. Since there is no Freon in the system, disassembly and reinstallation is a snap. Just lots of nuts and bolts. 2. When you get the new parts, they will be factory sealed. Keep the seals on until you are just ready to connect everything up. This will help keep moisture out of the system. As a rule of thumb, if you think it will take more than 5 minutes to complete a task, leave the part sealed. 3. Be sure the new hoses are ‘barrier’ type, if you have a choice…this is better than OEM. 4. Before you attach the fan belt, slowly turn the compressor for about a minute. This will distribute the lubricant properly. 5. Perfect opportunity to replace the fan belts. 6. Have the system recharged by a licensed technician. Be sure to use real R12, despite the cost. There are several reasons for this: the new R12 substitutes may or may not work-let someone else find out The technician can properly evacuate the system The technician will have electronic leak detection equipment which can save big $ down the road Unfortunately, a fill-up of R12 will cost you about $125, but act fast, supplies are limited, and prices are increasing. 7. I bet you can do much better on parts prices if you shop around. For example, having that old hose rebuilt would cost about $40. BTW, if one is leaking, and there is no obvious physical damage, I would bet that the others are about to go as well, so consider replacing all of them now. Try BPI 1-800-231-6563. I don’t usually deal with them, but they carry a good XJ6 line. And it may pay to try a Chevy dealer for the pump: you never know. 8. I have a detailed write up on XKE air conditioning…it may have some interest. If you would like a copy, e-mail me. Mike Frank 1969 E-Type 2+2 2At 06:28 PM 9/3/96 -0700, you wrote:
s.
the system’s already empty, it should be ready for me to try.TIA for any input/advice on the subject…
Date: Tue, 3 Sep 1996 21:48:09 -0700 (PDT)
Subject: 61 E Alternator: Part I
Well, I’ve begun. Today I took my (100 mile old) generator back to the
rebuild guy, who pronounced it slag. I’m having hime repair it anyway, so
that I have an original generator if I ever want it, but meanwhile, I am
elbow deep in the conversion process.
We poked around on his shelf of ready-rebuilt stuff, and came up with the
alternator for a '72-'79 MG miget, and early '74 MGB/GT, which is either a
36 or 43 amp Lucas 1 terminal alternator. It has a terminal for the idiot
light, and a pair for the battery, (both are B+). The mounting pattern and
offset are the same as the generator, and it will accept the generator
pulley, although I plan to order the alternator puley offered by Terry’s
Jaguar tomorrow, as it is slightly smaller diameter than the generator
pulley. (New belts, too.)
I am experimenting with mounting hardware. The middle bolt on the mounting
bracket interferes with the rear mounting ear on the alternator, unless I
remove the lock washer. I intend to look for a replacement to this bolt with
a low profile head. A 5/16 x 8" hex bolt will properly mount the alternator
to the bracket, clamping the front flange to the mounting bracket and
allowing the rear mounting ear to float, as is normal. I may use an
alternate method (which is harder to assemble but fits well), which is to
use a 5/16 x 1" bolt through the front mounting, into a split wahser, then a
5/16" x 1" threaded spacer, then insert a 5/16 x 6" bolt from the rear. This
also works, but boy, is it hard to get the parts under the alternator!
The upper (adjusting) bracket seems ok, but I will probably add a second
mounting hole about 1/2" in from the original one, so that the alternator
may be moved closer to the block. This seems necessary as the unit now
stands out just a bit more than required at minimum tension.
This alternator has very limited adjustment range installed as described.
The rear of the alternator is about 3" to 4" farther from the exhaust
mainifold than the generator. There is enough room to add a heat shield, so
I will look into that, too.
Once I deal with the mechanical issues, I’ll address the electrical. BTW, I
have already converted my car to negative ground.
Hunt
From: “Arnold, Dave Dr.” davearno@sandton.senchem.co.za
Date: Wed, 04 Sep 96 07:59:00 PDT
Subject: 1947 Mk IV
Question 2 of many. Can anyone please tell me the correct fluid to use
when filling Girling and Armstrong shocks, the old lever-arm types? I
can’t seem to find it in the manual, and I have a mental block on what I
used to use in my 53 Morris Minor…(geriatric old fart)
Question 3 of many. What is the modern NGK equivalent of Champion L 10 S
spark plugs?
Question 4 of many. When you wire up a positive earth battery, is the
earth (ground) lead black or red, and the live negative red, or black?
Dave
80 XJ6 II
47 Mk IV
From: Martin.Fooks@internetdesign.com (Martin Fooks – Internet Design)
Date: Wed, 04 Sep 1996 09:59:53 +0200
Subject: Bass in an XJS
Dear Kirby & Jeff,
I run a 520w system in my XJs with loads of speakers hidden out of site,
with the exception of the 200w mono Sub-woofer.
I originally tried 2 Subs, with 1 under each front seat. This gave a
somewhat distorted base combined with a butt massage which meant that
females always seemed to climb out of my XJ with a smile on their face. I
did not like the sensation or the overall sound however, hence the change.
We found that it is possible to design a speaker enclosure which is under 1
foot square, that can be located where the central part of the rear seat
actually bolts the rear seat in place. The speaker can be removed from the
enclosure to allow you to bolt the box (and hence the seat) down, then
replaced to give you a strange middle rear armrest as well. My upholsterer
covered the box with the same leather he used on the rest of the car and as
a result it looks as good as it sounds.
The only mistake made on the installation of this new sub was the assumption
that a 200w sub could handle the output from a 200w Amp… Not for any
REAL length of time it can’t!
As a final note : The 2 legless adults who are designed to fit in the back
of an XJS also have to be on a diet now.
Martin
Date: Wed, 04 Sep 1996 10:18:26 +0200
Subject: XJS — Oops!!! (a.k.a. Chassis failure)
Hi all,
I can finally bring myself to talk about this last weekends’ events without
bursting into tears.
It all started on Saturday evening (The night before I was supposed to meet
up with Jeff Gram at the British Race Festival in Zandvoort, Holland) as my
better half and I were driving in the XJS back from a party. I had a good
evening, which included a now famous ride on a mechanical rodeo bull and was
enjoyong myself even more by letting “Infra-Red”(The XJ) off it’s leash
using my right foot, when suddenly the evenings rodeo ride started to feel
very tame indeed as the rear end of the car let go BIG-TIME.
The sudden realisation(I’m allowed to use the letter “s” as I am English)
that the rear of the car was doing it’s very own impression of a fish very
violently thrashing from one side to another led me to think that maybee all
was not well with my toy.
It’s strange how as you get out from the car and wonder how you managed not
to hit anything at a moment like this. I walked round to the rear with my
trusty torch, wondering if I would be able to see the problem. Any hope
that it was a minor fault soon went when I noticed that the right hand side
rear suspension arm (sorry, don’t know its’ techy name) had ripped itself
out of the chassis, taking about a 7 inch diameter chunk of chassis with it.
My wallet started to empty itself in my head.
The local Jaguar dealer have called in their boy specialists who have
diagnosed nearly 2500 Dutch Guilders as the estimate for the chassis
repairs…SOB! but hey!, does anyone know how to swap a trusty Chevvy
Chassis over in it’s place ? ;-}
Martin
Date: Wed, 4 Sep 1996 09:13:42 -0100
Subject: Re: Tire wear and shocks
Mathias-=20
My initial reply to this query from Rob W-M was as follows:
"More likely bad wheel alignment. Bad wheel alignment doesn’t alwasy make=20=
the=20
car pull to the left or right.
P.S. are you sure it’s the shocks and not just the top shocker mounts. The=
y=20
don’t seem to last long, I’ve replaced all six sets on my three cars. When=
=20
they start to go you first get a tapping noise which escalates to something=
=20
which sounds like the wheel is about to fall off every time you go over a b=
ump"
My further comment on the additional query from you is that my dealer says=20=
they=20
always do the front end alignment with the suspension “loaded” that is I=20
presume with weights in the front to simulate the normal passenger load. T=
his=20
might explain why it took three attempts for you to get it right.
Robert Bradley
87 XJS,82 XJ6,82 XJ6
mfl%kheops.cray.com @ Internet=20
03/09/96 11:42 AM
To: ee84287%goodnet.com @ Internet
cc: jag-lovers%sn.no @ Internet, mfl%kheops.cray.com @ Internet=20
I need some advice regarding the possible association between tire wear a=
nd
bad shocks…
=20
My front shocks are gone and they need replacing. When checking the fron=
t
tires today I noticed that they are both wearing unevenly. The thread is
worn down along the inside edge of both front tires. Is the wear symptom
due to the bad shocks? Thanks for any help,
Hi Rob,
I just replaced my front shocks with Koni’s. I found that one of the
old Boge shocks would stick from time to time when I tried it by hand.
I also have tire wear on the inner edges, although more noticable on the
right hand side. I guess this is a problem with the camber adjustement.
I’ll try to get this fixed. However, on our other car this kind of adjustem=
ent
took 3 sets of front tires over the years before finally a competent garage
fixed it.
I have noticed how many camber and castor alignment shims are on each site,
so I can check if the shop actually did some work. One thing I don’t unders=
tand
is that the car is supposed to have positive camber on the front wheels
(1/2 degree). I have checked with a builders tool (don’t know how they are
called) and found that both wheels have slight negative camber. But I
think camber measurements must be done with the suspension partly compresse=
d.
However, the simple measurements I took were coherent with my tire wear
patterns.
Comments/suggestions anyone ?
Kind regards
- Matthias
=20
Rob W-M
85 XJ-S
=20
=20
=20
Date: Wed, 04 Sep 96 09:30:49 gmt
Subject: XK Engine oil filter
Lloyd, Kirby and Peter Carpenter,
Thanks, you all agree that the flow is out to in, which agrees with the filter I
bought. Just shows how wrong you can be, I thought it flowed the other way
until I started to think about it.
- Alastair Lauener Work Phone +44 131 455 2458 *
- 1964 3.4 S-Type story at http://www.sn.no/home/nick/alas.html *
Date: Wed, 04 Sep 1996 21:44:12 +1000
Subject: Re: Condensate drainDate: Mon, 2 Sep 1996 09:52:57
Re: Condensate leaking into car.
The drain pipes are too small on S111 XJ6s and get blocked with the
slightest bit of fluff or air bubble. I spent ages trying to find the
source of water on the floor ie. windscreen seal, scuttle vent etc.
Finally realized it was the drains, so now I carry a length of welding
wire in the boot and when I feel my foot getting wet I crawl under and
poke the wire up the two plastic pipes which emerge on either side of
the transmission tunnel works every time and generally fixes the
problem for about 6 months.
Michael Standley
S11 Soveriegn
XK 120 OTS 1950
Citroen 11BL 1951
End of jag-lovers-digest V2 #329
id for jag-lovers-digest-out; Wed, 4 Sep 1996 23:11:08 +0200 (MET DST)
Date: Wed, 4 Sep 1996 23:11:08 +0200 (MET DST)
Message-Id: 199609042111.XAA08544@ekeberg.sn.no
Subject: jag-lovers-digest V2 #330
Precedence: bulk
jag-lovers-digest Wednesday, 4 September 1996 Volume 02 : Number 330
Re: De-rusto/POR15/Duro Extend
XJ-S wheel - unstuck
?British Car Festival?
Rust convertor
Mk IV shock absorbers
Peculiar Series III VDP: '83 or '84?
Re: Palo Alto reminder…
Generator… Alternator migration
Re: jag-lovers-digest V2 #329
XJS – Suspension/Chassis Damage
Holiday Trip
Re: XJS – Suspension/Chassis Damage
Rust convertor
Re: Rust convertor
running hot
84 XJ6 Ongoing Overheating problem
XJ SIII Seats
Re: Generator… Alternator migration
Re: Connie’s Holiday Trip
XJ6 SIII A/C
Date: Wed, 4 Sep 1996 08:19:15 -0400
Subject: Re: De-rusto/POR15/Duro Extend
On Sep 3, 1:34pm, David J Shield wrote:
Subject: De-rusto
Jim Isbell asks about rust cures: sounds like "snake oil" to me, but
what the hell. Has
> anyone had any experience with these products that turn rust to >primer?
I have been using Duro Extend for a few years. What I can’t sand blast I treat
w/ the Extend. Seems to work ok as long as all the scale has been removed
first. If you do not top coat it the rust will come back. I hear that P.O.R 15
is better - and it needs no top coat, some guys have even coated the inside of
their exhaust systems with the stuff and had good results.
Mark
Date: 04 Sep 96 08:18:14 EDT
Subject: XJ-S wheel - unstuck
Many thanks to Robert Bradley, Richard Mansell, Matthias Fouguet-Lapar,
Rob Weiss-Malik, Ian Finlay, Paul Peard, and Brian Sherwood for their
helpful suggestions on how to unstick my wheels. The suggestion of
taking advantage of the differing expansion rates between steel and
aluminum (aluminium for my Brit friends :-}) proved to be the solution.
I tried everything else first but nothing would budge these wheels. A
carefull application of heat with a propane torch combined with
whacking the backside rim with a rubber mallet freed the wheels. The
amount of corrosion on the wheel and hub was extensive. As long as I
am at it I am pulling the hubs and renewing the wheel bearings. Oh,
yeah, the brakes - turns out the front pads are hardly worn! My rotors
do appear to be slightly warped. The wheels obviously have not been
off the beast in some time so I am surprised by the lack of wear. The
rear pads were fairly well history.
Kirby, I would suggest that you include removal of all wheels, cleaning
the mating surfaces and applying anti-seize compound to the hubs as
part of the maintenance to be performed on any older Jag in your
‘experience in a book’. This bit of preventive maintenance could be a
life saver if you have tire failure in the middle of nowhere.
Robert Woodling
'84 XJ-S
(Felix the Cat)
Date: Wed, 4 Sep 1996 09:22:43 -0400
Subject: ?British Car Festival?
Does anyone have any information regarding the “British Car Festival” in Des
Plaines, Illinois this weekend, at Oakton College? It is mentioned in the
SICP sales flyer, but there is no phone number-
I’d like to know more about it, before driving three hours to get there.
Thanks,-
Brian Sherwood
'85 XJ6
'84 XJ-S
Date: 04 Sep 96 09:33:36 EDT
Subject: Rust convertor
Kirby, You can’t scrape/brush all the rust off. If you could, there wouldn’t
be anything left to “convert”. What is left turns into the crust over time. It
never worked as claimed. Regards, John Elmgreen.
Date: 04 Sep 96 09:43:54 EDT
Subject: Mk IV shock absorbers
The workshop manual for the XK120 with lever rear shocks (Girling) says very
helpfully to use only Girling Piston Type Thin Oil. Work the lever while
adding the oil to avoid air bubbles.
Date: Wed, 4 Sep 1996 10:05:56 -0400
Subject: '85 XJ6 A/C renewal advice
Brian Chase asked about A/C repair-
Brian- I recently completed an A/C repair on my '85 XJ6: I had a local
automotive shop make a complete set of hoses; they cut the ends off the old
ones as necessary and swaged to new hoses, or put on new fitting if possible.
Cost for hoses and O-rings was about $120 US. I also replaced the expansion
valve and receiver-drier; less than $100 for the pair from SICP. The
compressor had previously checked OK for leakage and pressure, so I left it
in. I added about two tablespoons of refrigerant oil to the drier before
closing the system, had the system evacuated and charged with freon.
Everything is working great, now.
Cheers,
Brian Sherwood
From: nrichers@nexus.yorku.ca (Nikolaj Peddie-Richers)
Date: Wed, 4 Sep 96 10:35:09 EST
Subject: Peculiar Series III VDP: '83 or '84?
Dear fellow Jag-Lovers,
A few weeks ago, I introduced myself to this list as Jag-less
and looking to change.
Last night I checked out an '84 Jaguar Vanden Plas here in
Toronto and wondered what exact model year the car was: it had
the '84 and up trip computer, but the interior looked like
an early Series III: less wood, more flashy switch graphics, etc.
Production date was 7/83–is this a mongrel of two production
years? The last of the '83s sold as an '84), having already
received some of the later features? An '83-1/2?
I think somebody on this fantastic list also mentioned that
the model years at Jaguar aren’t that fixed–but I always thought
trip computer and updated interior were introduced together.
Was that a mid-run change, introduced gradually into
production?
It had the wrong speed-rated tires on it, the ‘Mars Special’
paint cracks and the hood needed to be aligned. It also had the
usual oil leak. But it had practically no rust, all original, the
engine ran beautifully and looked well-taken care of. The service
manual was with the car, but not stamped beyond the second
service (12’500km). Mileage is 96’000 kms or 60’000 miles. Asking
price: CDN$7000, certified. Is that a fair price? (An '85 with a
tad of rust, almost same mileage, and the Mars Special paint sold
for $5000 certified under my nose–$7000 seems on the high side).
I’m sorry to bother the list with my asking about the price.
But I did think the car was an interesting find…
Nikolaj
Nikolaj Peddie-Richers, North York, Canada, nrichers@nexus.yorku.ca
Date: Wed, 04 Sep 96 06:43:08 PST
Subject: Re: Palo Alto reminder…
Ryan... you're right... 50+... I counted 68 Jags there last year.
Stephen.... if memory serves me correctly the gates officially open at
0900. The reason for this late start is that the grass is watered
overnight and needs to dry out before being driven on...
Date: Wed, 04 Sep 96 06:45:54 PST
Subject: Generator… Alternator migration
One post mentioned doing something to the regulator... what exactly
was this ?
Catch me on the side if you like.
Thanks.
Date: Wed, 4 Sep 1996 08:07:11 -0700 (PDT)
Subject: Re: jag-lovers-digest V2 #329
Re Dave Arnold’s Mark IV:
Dave: The manual for my Mark V states Newton Hydraulic Shocks (on the
vehicle’s front end–what my wife refers to as the “pointee end”) should
be filled with S.A.E. 10 Engine Oil.
Cheers…
Date: Wed, 04 Sep 1996 17:10:02 +0200
Subject: XJS – Suspension/Chassis Damage
Hi again All,
It looks like Lady Luck may be smiling in my direction after all. I have
just had a telephone call from the Jaguar Garage, who have informed me that
the “RAC” (Royal Automobile Club, which is an English version of the AAA)
are going to pick up the whole bill… all 2,500 DFL of it!!! That is
on top of the free car I have from them all this week.
It won’t surprise me if they refuse my membership next year, but with the
amount of money they have spent on me during my 3 (2 Transmissions and 1
Chassis) breakdowns this year I wouldn’t blame them.
Long live Jaguar… Long live the RAC… Cancel that Chevvy Chassis
conversion!!!
Martin “Tested To Destruction” Fooks
From: “Connie Vloutely” connie_vloutely@macmail.git.gulfaero.com
Date: 4 Sep 1996 10:04:49 -0500
Subject: Holiday Trip
Hi Jaglovers,
Just want to report on my trip from Savannah, Ga to Mattituck, NY.
I am happy to report that my 1990 XJ-S, with 27,000 original miles on,
transported me without a problem.
Total distance traveled was 2600 miles in a period of 14 days.
Fuel consumption was 17.1 mpg. All highway driving using cruise control.
I used 94 octane in my car. Average speed as 65 miles per hour. Max speed
was 80 mile per hour. I didn’t want to get any more speeding tickets.
Car used a half a quart of engine oil. I think this is due to small oil leak
at the engine/oil cooler hose interface.
I had the airconding system serviced before I left. It was low on freon.
I had it recharged with two pounds of R12. The R12 cost $25.00 USD.
Airconding system work very well. It was set it and forget. I did notice
that when my wife was driving the passenger’s side was cooler then the
drivers side of the car.
I must say this was the most comfortable trip I have taken since the time I
owned my 1964 Buick Riviera. I drove eight hours a day on this trip without
any physcial strain. The engine has plenty of power, engine and road noise
is very low too.
The front seats are comfortable with plenty of leg room. Trunk area had
plenty of room for our luggage too.
Now I know why I want to own a Jaguar!!!
Connie.
Date: Wed, 4 Sep 1996 12:49:36 -0400 (EDT)
Subject: Re: XJS – Suspension/Chassis Damage
- ----- Begin Included Message -----
From jag-lovers-owner@sn.no Wed Sep 4 12:31:11 1996
Martin.
Please send me application forms for RAC.
Thomas
From: John Elmgreen 100353.1733%CompuServe.COM@vm1.cc.nps.navy.mil
John says;
<Kirby, You can’t scrape/brush all the rust off. If you could, there wouldn’t
<be anything left to “convert”. What is left turns into the crust over time. I
<never worked as claimed. Regards, John Elmgreen.
You can scrape/brush/chip off all loose rust, leaving only the thin layer
on the surface of the metal. This rust will continue to dissolve the metal if l
eft untreeted, or even painted over. The rust converter or rust eater stuff
will keep the rust from dissolving the metal, and it helps to primer/paint
over it. I’ve had no rust problems on a trunk floor I treeted about 5 years
ago with this method.
LLoyd
Date: Wed, 4 Sep 96 9:45:33 PDT
Brian:
I agree with Mike Frank. Try some other parts sources. XK’s Unlimited
tends to be more expensive.
Either BPI or Special Interest Car Parts have good prices.
BPI: 1-800-231-6563
Special Interest Car Parts: 1-800-556-7496
I usually use the latter, because they can ship stuff to me in 2 days
at no additional shipping cost (though there’s a weight limit).
I must admit though, ever since I sold my series II and got my XJ40,
I haven’t had to order any parts!
P.S. Ask for their excellent parts catalogues (free).
Roger Peng (408)765-7863
Intel Corporation
Design Technology, Physical CAD
Date: Wed, 4 Sep 1996 13:13:38 -0400
Subject: Re: Rust convertor
On Sep 4, 9:33am, John Elmgreen wrote:
Subject: Rust converter
wouldn’t
It never worked as claimed.
Seems to work for me, I have a sandblaster so I have a good comparison between
a blasted/prepped part and a “converted” part. In 1989 I did a little
experiment, I sandblasted 1/2 of my convertible top frame (much surface rust)
and metal prepped and primed it, the other half I wirebrushed and used Duro
Extend, and primed as on the first side. I never found the right paint for the
part so it has sat in the damp basement for 7 years in just grey primer. The
blasted side is now actually showing rust through the primer. The converted
side is still clean. I do not think it is wise to leaving anything in primer,
yet the converter seems to have worked anyway. I can’t vouch for it in all
conditions, I did one of the wheel wells on the Etype with converter (a place
that I couldn’t get to with the sandblaster) and I can’t say I trust it 100%. A
blasted/primed/and PAINTED part is still probably the safest way to go, but I
think the converters are probably ok for areas that are hard to sandblast.
I can take photos of the top frame if anyone is really that interested. Also,
I have heard that POR 15 is better than a converter.
Mark McChesney
Date: Tue, 3 Sep 1996 17:17:19 -0400
Subject: running hot
{ - Engine heat runs about mid way between 90C and 130C
after an
{ 8-10 minute run on city streets + a mile or so at
80kph. The temperature
{ seemed normal (90C) after 5 minutes of idling before
the road-test.
I had a similar problem that was caused by a partially open
thermostat,so that at speed the flow was too little to cool
effectively. It would warm up normally since it did close,
just never opened all the way.
My gauge is usually on 90 or a little over(needle on 0 of
the 90 on a hot day).
Alex Lynch
83 XJ6
62 TR-3
Date: Wed, 4 Sep 96 11:32:58 GST
Subject: 84 XJ6 Ongoing Overheating problem
After three weeks in the shop and both the thermostat and radiator
being replaced/rodded, my 1984 xj6 VDP is running hotter and overheating.
The mechanic checked the fan clutch and thinks its ok, he thinks the
water pump may be the culprit at this point, since there is adequate
air flow through he radiator. I really miss my car and am getting a
bit nervous about this situation since I took the car to a place
I wouldn’t normally go to because of a roommates recommendation.
Im not sure if my email is getting to everyone and I haven’t got
messages in two weeks, so if you could email me directly via
christopher@netmanage.com or my laptop address choward@ricochet.net
I would be very greatful, I am really really concerned about my
car right now.
Christopher Howard
E-mail: christopher@netmanage.com
9/4/96 11:32:58 AM
Chameleon - The Best Windows TCP/IP applications
Chameleon - The Best MacOS TCP/IP applications
WebSurfer - The Best Web Browser
ECCO - The Best Workgroup productivity tool
Swift - The Best Terminal Emulation Suite
NewtWatch - The Best Desktop Management
Date: Wed, 4 Sep 1996 13:30:00 -0400
Subject: XJ SIII Seats
Thanks for the replies for my query on the XJ Series III seat styles.
With a bit of a prod from Gregory Andrachuk, and a little reading
last night…looking for info on another topic…I think I have
the answer.
The 1986 Canadian V-12 VDP had/has the correct Vanden Plas seats.
ie. they are the individual bucket seats for the front, and the
look-alike bucket seats in the rear. These were the seats used
for all the top-end models, so they are found in the US XJ6 VDP,
the Canadian XJ12 VDP, the Daimler Double Six VDP, then just the
Daimler Double Six when the VDP was dropped, and I imagine in the
VDP’s found in the rest of the world…my info is mainly North
American based.
The next step down was the Sovereign, and it had the fluted front
and rear seats. This is found in the US XJ6, and the Canadian
XJ6 and XJ6 Sovereign. My confusion was that we have an 1988
XJ12 VDP, hence it should have the VDP seats, but Gregory points
out that after the the XJ6 Series III cars were dropped, in favour
of the XJ40, the VDP seats were also dropped for some reason, hence
the Canadian XJ12 VDP from late '87 to '92 got the Sovereign fluted
seats…what we have. Mystery solved. I hadn’t picked up on this
before, because my wife, Catherine, and I were actually looking
for a very nice Sovereign to purchase when we saw and bought the
VDP. I now think it was the better purchase !
Alan A., would it be at all possible for you to find out why the
VDP seats were discontinued in 1987 ? Thanks.
Ottawa, Ontario, CANADA Fax: (613) 763-3970
1988 VDP - SIII V12 email: markdr@nortel.ca
1963 3.8L E-Type Coupe - 15 years into a 3 year project
Date: Wed, 04 Sep 1996 16:48:23 +0100
Subject: Re: Generator… Alternator migration
At 06:45 AM 04/09/96 PST, Bill Clark wrote:
One post mentioned doing something to the regulator... what exactly was this ?
One thing I love to do to a Lucas regulator is to fix it
with a hammer. In fact, Home Depot has this reallllly big
50 lb. sledge that I have my eye on…
Charles Daly, Toronto, Canada
'62 E-Type, ots
Date: Wed, 04 Sep 1996 16:51:25 +0100
Subject: Re: Connie’s Holiday Trip
Total distance traveled was 2600 miles…
Connie,
With respect, I think you don’t really know
the joys of jag ownership! I use more oil
than that while watching TV!
Glad you had fun!
'62 E-Type, ots
Date: Wed, 04 Sep 96 14:06:00 PDT
Subject: XJ6 SIII A/C
Brian,
If the '85 XJ6 A/C is the same as the '84, then I just undertook much
of what you are about to. If it isn't, skip this.
My '84 XJ6 VDP blew the A/C compressor last winter, after about a year
of noisy operation. I finally decided to do something about it last
month. I called around and found a shop here in Sacramento called AIR
(916.923.1234). Probably there's a similar shop in Mt. View. They
sold me a GM A-6 rebuilt for $85, including clutch. The
receiver/dryer was inexpensive - ~$30 or so. New seals were pennies.
They can do hoses by taking your old hoses and building new ones with
the old ends (or new ends to match the old ones, I didn't ask). They
can make R134 hoses if you want, but you'd better get new R134 seals
all around. I didn't bother since the hoses had been replaced about 3
years ago and they look like they'll last.
The GM A-6 is almost a direct replacement - the threads on the
mounting holes are different, so you either need to retap the mounting
holes to match the old bolts, or get new bolts. I did the former
since it was late at night and I didn't want to wait till the next day
and then start hunting for the right bolts. The thermal fuse was shot
- a few bucks at the local auto parts house. The big difference is in
an electrical connector at the back end (over or under pressure
switch, I guess). The old Jag compressor has a post connector, the
new one has no post - just a flat connection - but there is enough
tension in the old connector body to make a good electrical
connection. You can *probably* just buy a new wiring harness at the
parts store - it looks like a standard deal that is for some reason
different on a Jag.
Welsh Jaguars in Ohio sells used (they say rebuilt) A/C amplifiers.
If you're doing all this other stuff, you might as well replace the
expansion valve as well. It's not expensive and it is easy to get at
- mounted externally on the firewall. (Maybe you can just inspect it
- I don't know.)
The local 76 Union recharged it for $140. Total outlay was less than
$300 and about 3 hours of my time, plus another hour to scrub my
fingernails clean. Next time I'd give that end of the engine a good
bath, first. I thought I did pretty well on this deal.
It's been incredibly hot here in Sacramento, and the A/C now works
great.
I face the same task on the '70 E 2+2, but the hoses need replaced
too. At least with the bonnet open it's all easy to get to.
End of jag-lovers-digest V2 #330
X-UIDL: 9d1df1f943c01ee80033a4fd2b33af2c
id for jag-lovers-digest-out; Thu, 5 Sep 1996 15:23:44 +0200 (MET DST)
Date: Thu, 5 Sep 1996 15:23:44 +0200 (MET DST)
Message-Id: 199609051323.PAA17654@ekeberg.sn.no
Subject: jag-lovers-digest V2 #332
Precedence: bulk
Status: RO
jag-lovers-digest Thursday, 5 September 1996 Volume 02 : Number 332
Where to locate fan relay?
RE: New Owner Finally
RE: Cup holder for 85 XJ6?
92 XJ40 Mud Flaps
Re: xjc question
Re: 92 XJ40 Mud Flaps
Security problem
Re: horn fault
Re: Rust convertor
Re: Security problem
Re: XJ-S wheel - unstuck
Brass vs Stainless–Brake Cylinder sleeve
Re: XJS AC controls
XJS Nose Paint Protection
Naming Conventions
Re: XJS AC controls
Date: Wed, 4 Sep 1996 21:11:29 -0700
Subject: Where to locate fan relay?
Hello everyone,
Summer is still around, and the AC in my 89 JX40 stops working. Some day
if I’m luckly it works, and the rest of the week I’m sweat. Where is the
relay for the AC fan located?
Thanks a million,
- Quang Ngo
- quang@valleynet.com
- 89-XJ6 89-300E P90 A3000/25 A1000 SNES PSX C C++ UNIX NT WIN95
Date: Wed, 04 Sep 96 23:20:11 -0500
Subject: RE: New Owner Finally
Steve,
Thanks for the information. I spent Wednesday at a Jaguar dealer in Chicago. The parts personnel were helpful but not that knowledgeable. They handed me the latest brochure showing both the options you describe but …They advised me that the side mount is not available for any car prior to 1994. That was the year Jaguar provided a “connection” just below the ashtray on the center console, for connection, to Motorola cell phones. Does anyone know if this is indeed so ?
Thanks
Lou
averill@earthlink.net (Steve Averill)
Averill replies…
Jaguar also markets a sidemount phone holder & it’s in the accessory
brochure along with the storage compartment lid version. The special phone
compartment lid is OK, but I’d rather get the cupholder storage lid, as on
the new X300 cars. You can’t have both, but you CAN get the cupholder lid
combined with the Jaguar sidemount so that you can spill coffee onto the
phone!
Date: Wed, 04 Sep 96 23:44:18 -0500
Subject: RE: Cup holder for 85 XJ6?
As a follow-up to my search for an aftermarket cup holder. I was finally able to see an installed cupholder sold by catalog by Automotion, 1-800-777-8881. In their catalog which is directed at the Porsche market, on page 30 they show a cup holder. This device bolts/screws to the door and also uses adhesives. The product is covered in leather (9 colors shown) and folds on itself when not in use. It holds containers from 2 3/8 inches to 3 1/2 inches. The product number is CH-9000 at $44.98. The installed product when not in use and folded looks like a leather covered rectangle case on the door panel. The one I saw was installed into the wood trim just below the window. Hope this helps. I don’t know if I am going to be ordering this one just yet I am still on the hunt. I really don’t want to have to drill into the door panel just yet.
Lou
Sent: Monday, September 02, 1996 11:44 PM
Subject: Cup holder for 85 XJ6?
I checked out the “cup holder” web site at http://www2.spav.com/wilton/husco/
, but it appears that they don’t make a model for Jags. Has anyone fitted a
decent cup holder to a series 3 XJ6?
Steve
Date: Wed, 04 Sep 96 23:49:29 -0500
Subject: 92 XJ40 Mud Flaps
After my last trip I notices that the slipstream design of the Jaguar really sprays back onto the rear quarter panels and also on the front doors. I found that Jaguar sells mud flaps made for the car. I was wondering if anyone had any experience with these ? Also how well do they do in winters slush and snow ?
Thanks
Lou
Date: 5 Sep 96 18:11:59
Subject: Re: xjc question
For a final clearing-up of this question, the passenger space in the XJC is
EXACTLY the same as in a short-wheelbase four-door XJ, as it’s built on the
same floor pan and has the same rear seat, roof profile and rear window (just
wider C pillars).
Yes, rear seat access is fairly cumbrous in the C, but so what? I ride in the
front seat, and the front seat access is wonderful with those wide doors…
- Jan
Date: 5 Sep 96 18:41:23
Subject: Re: 92 XJ40 Mud Flaps
I find mud flaps essential to protect the paintwork on gravel roads and they
work well if you have standard-size tyres. If you have extra-wide tyres the
protection is impaired.
One problem with standard Jaguar mud flaps (at least S2) is that they’re held
by four small screws and a thin strip of sheet steel and rip off easily, as
when you back up against a curb. I lost one of mine to a car-chasing dog…
er… slush and snow? What they?
- Jan
Sydney, Australia
formerly of Stockholm, Sweden…
- Jan
XJ12L
XJ12C
Date: 5 Sep 96 18:05:14
Subject: Security problem
A couple of days before going on holidays a bit over two weeks ago (Hi
everybody, I’m back…), I stopped getting jag-lovers mail. When I got back, I
sent a message to the majordomo program and started unravelling what had
happened.
Did you know that anybody - list member or not - can find out from Majordomo
- what lists are present on that server and
- the e-mail addresses of all members of those lists?
Having got that listing, the same anybody can then remove anybody at all from
any list by sending an e-mail containing UNSUBSCRIBE [address].
That may have been what happened to me, because my e-mail address was not on
the list Majordomo presented me with.
It is also possible that what happened is that the server had a system crash
and somebody restored it from an old backup copy from before I joined.
It was easy enough to restore myself to the list; I only had to send an e-mail
to Majordomo reading SUBSCRIBE. However, I’m a little bothered by the discovery
that it’s so easy for an outsider to peep into and tamper with the list. I’d
very much like to see the Majordomo authors introduce a modification that lets
anyone operate on his/her own name but password-protects other access to
restrict it to the list operator.
- Jan
Date: 5 Sep 96 18:26:58
Subject: Re: horn fault
Jim Isbell
2)The car is too quiet. I cant tell when the engine is running and have
twice tried to start an already running engine.
From (I think) about 1978, the S2 XJ got an improved steering/ignition lock. It
has to be turned back to ACC if you want to crank the engine again, precisely
to prevent trying to start a running engine. The improvement to the steering
lock is that it won’t latch until you pull the key out, keeping safe those
economy-minded citizens who switch off the ignition while coasting downhill.
This was the pattern of lock I got recently when I bought a new one (WASO
brand).
Incidentally, pulling the key out also operates the switch that controls seat
belt warning etc. As my car doesn’t have those, I’ve used it to operate a
“headlights on” warning buzzer.
- -Jan
Date: 5 Sep 96 17:47:03
John Elmgreen :
What is left turns into the crust over time. It never worked as claimed
All rust converter products I have seen are based on phosphoric acid in a
dilute solution, sometimes with a water-based lacquer added to form a skin. The
phosphoric acid converts various iron oxides to iron
phosphate, which is a good anti-corrosion coating.
I use plain 10-20% phosphoric acid myself; it’s cheaper. It may need two or
three applications; it foams visibly if there is anything left for it to react
with. Rinse residual acid off with water and rinse your brushes after…
What may have created your impression that these products don’t work, John, is
that any scale, loose rust, oil and grease interfere badly with the process.
Actually, it works best on bare metal, so the more rust you can remove, the
better. If you suspect any grease or oil contamination, wash liberally with
acetone first (don’t inhale and DON’T SMOKE!).
The phosphate coating is not mechanically strong and needs a paint coating for
protection. Something I’ve found great on the floor and similar situations is a
foaming spray-on under-chassis compound. When it’s tacky, you put a sheet of
heavy kraft paper on it to stop the carpets sticking (paint the kraft to
protect it from water). This makes perfect rust protection and provides extra
sound deadening.
- Jan
Date: Thu, 5 Sep 1996 09:10:33 +0100
Subject: Re: XK Engine Oil Filter
I had a look in my MKII shop manual last night, and it certainly looks like
outside → inside is the way. The return pipe comes off the centre tube and
goes to the sump.
Ian
On Sep 03, 1996 13:53:02, ‘“Kirbert” palmk@gcn.scri.fsu.edu’ wrote:
On an XK Engine oil filter, can anybody say wether the oil flow through the filter is from outside to inside, or the other way? I really can’t recall the layout of all the oilways, and in particular the oil filter housing so that I can decide, and I don’t want to remove it for such a small piece of knowledge Does no-one really know the answer to this? I only know the answer in the GENERAL case, not in the specific case of the XK – hence I didn’t answer the first time. However, I have never seen an oil filter, or any other filter for that matter, that didn’t flow from the outside in. There are two reasons for this: 1) more dirt can accumulate on the outside before plugging the filter than on the inside. 2) The filter element can withstand more pressure differential without tearing. Kirbert | If anything is to be accomplished, | some rules must be broken. | - Palm’s Postulate From: Nick Johannessen nick@sn.no Date: Thu, 05 Sep 1996 10:21:33 +0200 Subject: Re: Security problem At 06:05 PM 9/5/96, Jan the Man wrote:
happened.Did you know that anybody - list member or not - can find out from Majordomo
This is not so. Any request to unsubscribe where the sender is
not the same as the name that is requested unsubscribed is
forwarded to the admin (me) for approval. I then have to manually
unsubscribe the person. And yes, I do get a few of these. Every day.
This is very likely what happened. When I noticed the error I
re-subscribed everyone that was on the week-old list I had at
home.
discovery
Something along these lines has been mentioned on the British-car
list recently. There was talk of removing the “who” function that
potentially allows junk-emailers to collect email-addresses from
list-servers. I am following the development there and will
consider doing the same. Apart from getting the “who” list there
really isn’t much an outsider can do, unless they have somehow
found the admin-password.
Nick
List admin
To get help for majordomo: send mail to majordomo@sn.no with “help” in text
To unsubscribe: send mail to majordomo@sn.no with “unsubscribe jag-lovers”
(from digest: send mail to majordomo@sn.no with “unsubscribe jag-lovers-digest”)
If all else fails: report problem to nick@sn.no
List-archives are at: http://home.sn.no/home/nick/archive.html
Jag-lovers WWW-site at: http://home.sn.no/home/nick/jaguar.html
Jaguar specialists WWW-site at: http://www.jagweb.com/
Date: Thu, 5 Sep 1996 13:12:01 +0200 (MET DST)
snow ?
I bought a set (front and rear) for my '88 XJ-S. (at one of the big dealers
advertizing in the JEC magazine). The rear once are ok with even a “Jaguar”
signature on them.
The front ones did not work on my XJ-S (which has 235’s tires). This was
also on the package notice. Since shipping it back would be about the
same amount as the flaps, I tried to cut them off a bit to fit with the
wider tires, but it was too close.
Of course their advertisement did only say “XJ-S flaps” …
- Matthias
Date: Thu, 5 Sep 1996 13:14:30 +0200 (MET DST)
I heard that a proper repair of this area is starting at > 500 pounds.
Lucky you, with your insurance !
- Matthias
Date: Thu, 5 Sep 1996 13:17:12 +0200 (MET DST)
Subject: Re: XJ-S wheel - unstuck
When I had this problem on our XJ-S a while ago, I went off and bought
one of those cans which you blow into the tire and which “fix” small holes
for a while. I’ve never tried it, but maybe something usefull to have in
the trunk anyhow
- Matthias
Date: Thu, 5 Sep 1996 07:57:01 -0400
Subject: Brass vs Stainless–Brake Cylinder sleeve
Someone questioned the use of brass in brake cylinders. I had mine done
in brass-----------3 of the four wheels had to be redone because the
brass sleeve slipped allowing fluid to leak past them. Suggest
stainless. I’m using Dot 5 fluid.
Tom
Date: Thu, 05 Sep 96 07:59:14 EST
Subject: Re: XJS AC controls
David -
My experience is that the slider does not change the air flow,
but rather the temperature of the air that is flowing through
the upper vents. In my car, the effect is not very
pronounced, but it may have a greater impact upon the warm air
in the winter - I haven't had the car long enough to test that
yet.
- mclaus
'93 XJ-S Convertible
______________________________ Reply Separator _________________________________
Subject: XJS AC controls
Author: David Engelbach widi@artnet.net at WG-RAL-SMTP
Date: 9/4/96 7:45 PM
I’ve now had my '96 XJS convertible a little over a month now, and I’m
still puzzled about the operation of the slide control for the A/C. The
handbook suggests that sliding it to the right (Blue) increases air to
the upper vents while sliding it to the left (red) increases air to the
footwells. Well, I’ve tried it and it doesn’t seem to make any
difference. Am I missing something?
Any experience with this would be appreciated. Thanks.
David - 96 XJS conv. The last of the breed.
David C. Engelbach E-mail - widi@artnet.net
Valley Village, CA 91601 Voice - 818.506.5441
USA Fax - 818.506.1011
Date: Thu, 05 Sep 96 08:22:09 EST
Subject: XJS Nose Paint Protection
Lately it seems to me that every time I take my beautiful new
car out for a ride it comes home with a new ding or chip in
the paint on her pretty nose. The idea of spending a day or
two working with touch-up paint after every drive gets old
quickly.
So now I am considering an alternative. This is going to
start a fight but .......
Does anybody know if there is a bra which can be fit on the
car?
Gasp! Groan! Please don't flame me. I know it will not look
so great, but honestly, my car looks like it has dandruff in
front - I must have two or three dozen little white specs - it
doesn't look so great either.
Of course, if anybody has another good suggestion, please let
me hear.
- mclaus
' 93 XJ-S
Date: Thu, 05 Sep 96 08:34:48 EST
Subject: Naming Conventions
I want to thank everybody who replied to last weeks query
about how and why they name their cars. I got a huge flood of
responses, more than I can thank individually. Let it be said
that this is a topic about which there is a great deal of
passion among some of the list members!
For me, I have decided not to name my car for right now -
perhaps I have not had it long enough for its personality to
show clearly to me. I haven't been able to definitively sex
it yet - mostly it feels male to me, but other times decidedly
female. We considered 'Damion' for the male side and 'Linda'
(after Linda Blair) for the female, since there is a good
chance the car is possessed by the Devil him/her self - but
that doesn't feel right either when the car is behaving
itself.
Thanks again for all your input. That's what makes this list
so great!
- mclaus
'93 XJ-S (nameless for the time being)
Date: Thu, 5 Sep 1996 08:18:42 -0500
The 87 XJS and XJ series III have a similar control, red on side blue the
other. The control is just below the radio and it changes the tempreture of
the air issued from the vents. It think it works on a tempreture sensor in the
air box. THIS IS DIFFERENT TO THE IN CAR THERMOSTATE which gets its readings
from the small vent above the glove box. So if for instance the car is still a
bit warm inside but the AC vent is freezing your fingers on the wheel then you
move the slide/lever towards red and the thermostate will still try to cool the
car but the actual air coming from the vent will be less chilled. Did that
make sense? Hope its the same on the 96.
Robert Bradley
widi%artnet.net @ Internet
05/09/96 07:12 AM
To: jag-lovers%sn.no @ Internet
cc:
End of jag-lovers-digest V2 #332
X-UIDL: 2f37d013fd4898702721c7ac1006cac2
id for jag-lovers-digest-out; Thu, 5 Sep 1996 22:56:40 +0200 (MET DST)
Date: Thu, 5 Sep 1996 22:56:40 +0200 (MET DST)
Message-Id: 199609052056.WAA20913@ekeberg.sn.no
Subject: jag-lovers-digest V2 #333
Precedence: bulk
Status: RO
jag-lovers-digest Thursday, 5 September 1996 Volume 02 : Number 333
MkII front end rebuild…
Vanity Plates Responses
Re: Mud flaps
Re: Passenger space in XJC
Steamboat Race Weekend
SIII XJ6 thingie on the fuel rail
Re: XJS AC controls
Re: A/C Controls
RE:Brass vs Stainless–Brake Cylinder sleeve
Re: XJS wiring help needed
Re: Jaguar XJS Classic Rouge
Re: 96 XJS conv.
Re[2]: 96 XJS conv.
[Pure BS] Re: XJS – Suspension/Chassis Damage
Re: XJS — Oops!!! (a.k.a. Chassis failure)
Date: Thu, 05 Sep 96 07:21:20 PST
Subject: MkII front end rebuild…
It's that time, need to replace all the bushes etc.
Curious as to whether in the long run it is better to use stock rubber
ones or go for 'thane if they are available.
Any thoughts appreciated.
P.S. The general opinion seems to concur that XK's Unlimited are a
little more expensive and IMHO their service has dropped off, but
early next month they have an open house with a great barbeque and 20%
off all purchases - getting my wish list ready.
Date: Thu, 5 Sep 1996 09:38:47 -0500
Subject: Vanity Plates Responses
Mike C. put me to shame. I too received many, many responses to my query
regarding vanity plates on my '88 XJ40. THANKS TO ALL WHO RESPONDED. There
were many great ideas.
I too have decided to go with the one recommendation that stated the best
way to go is to just accept whatever the MOT gives you over the counter.
So for at least until I change my mind,
Scott Phillips
'88 XJ40 — Nameless and plated as 624 MLT
Minnetonka,mn,usa
Date: Thu, 5 Sep 1996 16:11:10 -0700
Subject: Re: Mud flaps
From the horses mouth; Norway, the land of slush & snow.
Yes Lou, Jaguar do sell mud flaps. Mine is a Series I XJ (as if you didn’t know
by now), but I suspect the concept to be the same for your XJ40. Without them we
would have a serious problem. Not only do we have slush and snow, we also have
all other sorts of dirt, grit, sand, pebbles and you name it. No problems at
all!
After I had the painted, I scrapped the rear mud flaps and fitted new ones. In
front the braces were badly rusted som I had a couple made but havn’t quite
finished them yet. I also had the small lids in which the flaps are fastened
made new, and havn’t got around to make the small square holes in them.
Inspecting the areas behind the road wheels, you will probably find the
mentioned square holes. Into these holes you prise the nylon plugs that come
with the mud flaps and fit the flaps. You may have to space out the flaps with
some washers between the flap and the panel. I don’t know why, but I had to.
Good luck.
Bard
______ _ ! Baard Th Hesvik, Telesoft AS
/ _ / _ _ _ / / ! Longhammarvn 7, N-5500 Haugesund
/ // / // /_ / / -/- -/- ! T: +47 52735000 F: +47 52717040
/ /_ / /_ / // / /_ ! E-mail: baard@telesoft.no
Date: Thu, 5 Sep 1996 16:18:48 -0700
Subject: Re: Passenger space in XJC
Correction to Jan;
The passenger space in an XJC is exactly the same as in the four door saloon
provided it is a Short Wheel Base four door saloon.
Also, I dare say that if your mud flaps are fastened by four screws only, they
weren’t factory fitted. When cornering heavily loaded I often scratch my flaps
in the road and, although it sounds rather nasty, they havn’t come loose yet.
Cheers,
Bard
Date: Thu, 05 Sep 1996 11:30:11 -0700
Subject: Steamboat Race Weekend
I just wanted to echo what I think all of this list’s thoughts are
regarding Lawrence Buja’s wonderful article on the race weekend in
Steamboat Springs, Colorado.
Rarely do I get the opportunity to live vicariously the life of the
weekend Vintage British Sports Car racer. It has always been my lifelong
dream to experience the joys of what Lawrence wrote of, but the realties
of earning a living and paying existing bills keep it out of reach for
now. Since I am a young 28 I know I have time to organize my life so
that soon I can enjoy my dreams of racing my TR6 at such wonderous events
where great machines, great people, great scenery and great fun unite.
Until then, I can only hope that Lawrence Buja and all the other weekend
racers who truly remind us of the joys of motoring will continue to share
their experiences in such a beautifully lucid and involving way.
Lawrence, I can’t thank you enough for that brilliant article. It
reminds me why I work so hard to keep these living works of art as close
to what they were meant to be. It also reminds me about the joys of
being with truly great people who understand how important it is to
really live.
Thank you again.
Sincerely,
Dave Oxenreider - Orlando, Florida
73 XJ12
75 TR6
Date: Thu, 05 Sep 96 08:58:00 PDT
Subject: SIII XJ6 thingie on the fuel rail
>I would also like to understand the operation of the "thermal valve"
>on the fuel rail. Does anyone know how this thing functions and how
>to check it?
>Tony Gardner
>1986 XJ6 Series III
Tony,
If you're speaking of the orange-colored device on the back end of the
fuel rail, with a vacuum inlet and outlet (outlet going to the fuel
pressure regulator), then I can describe it. If it's something else,
then my '84 XJ6 VDP is different than the '86s.
This is my empirical understanding of what it does and how it does it:
That valve is for warm restarts. I believe it senses the temperature
of the fuel rail and when warm, cuts the vacuum to the fuel pressure
regulator. The fuel pressure regulator responds to vacuum as follows:
High vacuum (at idle) = lower pressure, low vacuum (full throttle) =
higher pressure. When the engine is warm, the thermotime switch isn't
going to fire the cold start injector. Short of re-engineering the
fuel injecion system, the engineers apparently found that things just
needed a little help. Cutting the vacuum to the regulator increases
the pressure enough to get the car started, and didn't require major
re-engineering. In typical Jaguar fashion, they solved a problem by
adding more parts (although maybe it was the Bosch or Lucas
engineers).
On my car, that valve was leaking vacuum. I bypassed it entirely and haven't ever had difficulty on restarts. I've never measured the fuel pressure - it shouldn't be leaking down when the car is off, from what I understand. Best regards, David '84 XJ6 VDP '70 XKE 2+2 and a Volvo From: "Kirbert" <palmk@gcn.scri.fsu.edu> Date: Thu, 5 Sep 1996 12:04:12 -0005 Subject: Re: XJS AC controls I've now had my '96 XJS convertible a little over a month now, and I'm still puzzled about the operation of the slide control for the A/C. The handbook suggests that sliding it to the right (Blue) increases air to the upper vents while sliding it to the left (red) increases air to the footwells. Well, I've tried it and it doesn't seem to make any difference. As someone on this list once said: If it doesn't make any difference, it's working perfectly! It's supposed to vary the temperature relation between the upper and lower vents. One way, and the upper vents are COOLER than the lower; the other way, and the upper vents are WARMER than the lower. Difference is slight, and either way the control system is gonna vary overall supply temperature to maintain the temperature in the car. Kirbert | If anything is to be accomplished, | some rules must be broken. | - Palm's Postulate From: "Kirbert" <palmk@gcn.scri.fsu.edu> Date: Thu, 5 Sep 1996 12:04:13 -0005 Subject: Re: Seeking '85 XJ6 A/C renewal advice Randy Wilson <randy@taylor.infi.net>: ...and hoses can be made by any local A/C shop. Having recently gone through this, I must differ with the above. It turns out that some hoses are more difficult to rebuild than others, and the more difficult ones require a special crimp tool that, while reasonably priced as shop tools go (no power, hand operated), was only introduced a year or so back. If the A/C shop is dealing with the older crimp tools, it cannot rebuild some hoses. The usual result is that they will cut the fittings on your old hose and braze on sections of tubing that their tools can fit a hose to. This looks like c__p when done, but does work. If the fittings on your hose happen to be aluminum, ONLY the newer tool will work, since brazing is out and the older tool will crush the tube. Now, does any of this apply to the Jaguar? Well, probably not mine; it appears to have standardized fittings made of steel, so perhaps the older crimp tool will work. But I dunno what fittings are used on other Jaguars, so I thought I should clarify the situation. I have mid-80's Hondas that have unique, aluminum fittings on the hoses; a shop with the new crimp tool can rebuild, a shop without it will tell you that the hose is unrepairable and you must buy a new one from Honda. If the newer Jags have similar developments, take note. Kirbert | If anything is to be accomplished, | some rules must be broken. | - Palm's Postulate From: "Kirbert" <palmk@gcn.scri.fsu.edu> Date: Thu, 5 Sep 1996 12:09:13 -0005 Subject: Re: A/C Controls Robert Bradley: The 87 XJS and XJ series III have a similar control, red on side blue the other. The control is just below the radio and it changes the tempreture of the air issued from the vents. It think it works on a tempreture sensor in the air box. THIS IS DIFFERENT TO THE IN CAR THERMOSTATE which gets its readings from the small vent above the glove box. 'Fraid not. BOTH sensors are used in the main temperature control of the car. The slider doesn't involve any sensors whatsoever, it merely moves a link in the control linkage to vary the relationship of upper and lower heating flaps. Kirbert | If anything is to be accomplished, | some rules must be broken. | - Palm's Postulate From: "Claus, Mike" <claus%wg.com@vm1.cc.nps.navy.mil> Date: Thu, 05 Sep 96 08:22:09 EST Subject: XJS Nose Paint Protection Re; paint chipping; < Lately it seems to me that every time I take my beautiful new < car out for a ride it comes home with a new ding or chip in < the paint on her pretty nose. The idea of spending a day or < two working with touch-up paint after every drive gets old < quickly. I paint my cars with the new epoxy type paints, the ones that you mix two parts paint, one part reducer and one part hardner. It is a very hard paint which doesn't chip and is easy to touch up. LLoyd From: jwbeckmeye@orion.branch-co.lib.mi.us Date: Thu, 05 Sep 1996 12:44:06 -0400 Subject: RE:Brass vs Stainless--Brake Cylinder sleeve Tom Felts wrote:
Tom,
May I ask, who did the brass resleeving job for you? Say it ain’t White Post.
FWIW, I had White Post do my brakes in the MK II. So far, so good (using
DOT 4).
Best regards,
Jim Beckmeyer
Union City, MI
90 Jaguar Sovereign
60 Jag MK II
Date: Thu, 5 Sep 1996 12:45:15 -0400 (EDT)
Subject: Re: XJS wiring help needed
You may have gotten replies to this by now, but I might be able to help
you out a bit:
On Sat, 31 Aug 1996, Jim Isbell wrote:
First, under the bonnet there are two wires comming out of a harnes
near the throttle “cam” where the throttle cable connects to the
“cam” and there is a microswitch on the side of the cable. These two
wires are Green and Green with a yellow tracer. The green one appears
to have been snipped off the microswitch with cutters (pourposefully)
the Green with Yellow tracer gives me no clue. What are these? Do I
need them? What is the microswitch? It doed not seem to be working
or at least I could not get it to “click”.
You definitely want this circuit to work. It richens the mixture when
more power is needed. If the microswitch is bad replace it with any
garden-variety microswitch – Radio Shack sells them. At most you might
have to redrill one of the mounting holes.
This switch is wired in parallel with a vacuum switch mounted on the right
rear of the engine. Low vacuum OR a wider throttle opening (the vacuum
switrch and the throttle linkage microswitch, respectivelly) can give more
fuel by, I believe, widening the pulse supplied to the injectors.
Third, in that same location is a rubber vacuum hose with what
appears to be an inline fuerl filter in the end of it. It too goes
nowhere. What is it and where should it go?
This sounds like the fresh air purge to the distributor cap. Make sure
the filter isn’t plugged and replace it with a garden-varieyt inline
filter if it is. I poke the free end of mine out past the upper radiator
tank.
Hope this helps.
John
Date: Thu, 5 Sep 96 10:20:00 PDT
Subject: Re: Jaguar XJS Classic Rouge
I would appreciate if somebody could educate me what are the major differences
between this Jag and a regular XJS.
Please reply directly.
Thanks, Ilya.
All it is is a special edition with a few trim differences, the most notable
being that the leather seats are “piped” in red.
Intel Corporation
Date: Thu, 5 Sep 96 10:29:53 PDT
Subject: Re: 96 XJS conv.
By the way, is this a 6 cylinder car? How does it compare
with the V12 cars (if you’ve test driven one)?
Anybody else with 6 cylinder XJS’s? Is the maintenance cost
lower? (ie comparable to a XJ40?)
Intel Corporation
Date: Thu, 05 Sep 96 15:49:57 EST
Subject: Re[2]: 96 XJS conv.
My XJ-S is a 6. While I was hunting for a car, I badly wanted
a 12, but late model 12's are relatively scarce since they
started offering them with 6 standard after '92. Of the few
that I found, I was just not able to afford one.
I did test drive a few 12's - they are definitely smoother,
quieter and have more feel of power than my car. But they are
also a little heavier, and I could feel that difference in
handling too. I've driven my car up to about 110mph - about
as fast as I am comfortable driving even in my neighbor's
Turbo Bently - so I don't think I really need the extra engine
power for any useful purpose.
I'm not sure about maintenance costs - mine have been pretty
high so far - but I do not have any oil leaks, and so far have
not had any overheating problems - despite commuting regularly
in the car. The commute includes about 15-20 minutes with
stop and go traffic, and Raleigh NC is pretty hot - many 90
degree + days, so the AC has been working hard. If it were
going to overheat I think it would have by now. Because I
have been reading this list, I do keep a very wary eye on my
temp gauge however!
The mechanic at the local dealer (I did not buy the car there)
told me that I should be happy that I did not get the 12 - he
told me the maintenance costs are much higher, and that once
they start to get old it is very difficult to keep them from
leaking oil without constant attention. The tune ups are a
little cheaper for the 6 than the 12.
Isn't the 6 in the new XJ-S the same engine as in the sedans?
And aren't these just an updated version of the straight 6
that Jag has been producing for decades? We probably have more
folks with experience on this engine than on the 12's.
- mclaus
'93 XJ-S Convertible.
Author: rpeng@cadev6.intel.com at WG-RAL-SMTP
Date: 9/5/96 10:29 AM
Intel Corporation
Date: Thu, 5 Sep 1996 16:11:50 -0400 (EDT)
Several of you are giving Jim incorrect information. The micro with the
green wires, mounted on the throttle cable is the transmission kickdown
switch.
Thomas E. Alberts
or at least I could not get it to “click”.You definitely want this circuit to work. It richens the mixture when
have to redrill one of the mounting holes.This switch is wired in parallel with a vacuum switch mounted on the right
make sure
Date: Thu, 5 Sep 1996 22:45:48 +0200 (MET DST)
Subject: [Pure BS] Re: XJS – Suspension/Chassis Damage
conversion!!!
Chevy Chassis conversion eh? Next thing you know we’ll have people on
this list talking about Chevy engine conversions.
Sheeesh! Some people…
Gunnar
Gunnar Helliesen | Bergen IT Consult AS | NetBSD/VAX on a uVAX II
Systems Consultant | Bergen, Norway | '86 Jaguar XJ6 4.2 Sovereign
gunnar@bitcon.no | http://www.bitcon.no/ | Vicki who? What .sig virus?
Date: Thu, 5 Sep 1996 16:49:52 -0400 (EDT)
Subject: Re: XJS — Oops!!! (a.k.a. Chassis failure)
Sorry about your loss!!
Have a question, though:
When you say ‘right side suspension’ do you mean the trailing arm that
locates the cage? Or the lower swing arm that locates the wheel?
If you mean the trailing arm, I’ve got a radical fix – just eliminate
them both!!
Cobra Replicars and many hot rods use Jag rear ends with big motors. The
cage is deep sixed, and the center diff is mounted sollidly to the frame.
There are NO trailing arms. The key is that the whole thing is solidly
mounted.
Now, as I recall, you had already solidly mounted the cage to the car. If
you have, you don’t need the trailing arms and maybe this is why it ripped
out (not enough slop in the system).
With this fix, just patch the hole in the floor and that’s it. Of course,
I don’t really know if this is your problem (if your cage is already
solid, why did the ripped out arm cause a wiggle?).
But at the risk of being flamed, if your problem is the trailing arms,
consider eliminating them altogether.
Oh, yeah, there is a middle ground here as well. Racing XJ-S’s often lose
the original trailing arms and replace them with new fabricated arms that
pivot closer to the center line of the car (next to the drive shaft and
longer, too). The cage is not solidly mounted. This supposedly gives
better equations than those provided by the stock trailing arms. If you
go this route, you also have an easier patch job!
Good luck and let us know how you make out.
John
On Wed, 4 Sep 1996, Martin Fooks – Internet Design wrote:
Hi all,
My wallet started to empty itself in my head.The local Jaguar dealer have called in their boy specialists who have
Chassis over in it’s place ? ;-}Martin
End of jag-lovers-digest V2 #333
Return-Path: @owner-jag-lovers-di1
Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4)
id for jag-lovers-digest-out; Fri, 6 Sep 1996 11:22:39 +0200 (MET DST)
Date: Fri, 6 Sep 1996 11:22:39 +0200 (MET DST)
Message-Id: 199609060922.LAA22970@ekeberg.sn.no
X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f
To: jag-lovers-digest@sn.no
Subject: jag-lovers-digest V2 #334
Reply-To: jag-lovers@sn.no
Errors-To: @owner-jag-lovers-di1
Precedence: bulk
Status: O
X-Status:
X-Newsgroups: mail.jag-lovers-digest
jag-lovers-digest Friday, 6 September 1996 Volume 02 : Number 334
Re: Rust convertor
Re: XJS Nose Paint Protection
More stories
Re: Series III XJ6 Lukewarm Starting Problem
Re: XJS AC controls
No Jag content / Auto mailing lists
Re: Where to locate fan relay?
RE: XJS Micro switch on throttle
RE: The Drift King meets Capt’n Hook.
E gen->alt Heat Question
'61 E Alternator Conversion, 2nd installment (Success!)
RE: XJS — Oops!!! --------F.A.O. Kirby
Re: “Correction” to Jan.
RE:84 XJ6 Ongoing Overheating Problem
Date: Thu, 5 Sep 1996 16:56:04 -0400 (EDT)
Primer is porous and will let water through. If you need to store a
primed part for any amount of time, spray a thin sacrificial coat of
lacquer over it. Sands off easily enough and protects what’s underneath.
Date: Thu, 05 Sep 1996 21:37:28 GMT
Subject: Re: XJS Nose Paint Protection
In message 9608058419.AA841937204@smtp.wg.com “Claus, Mike” writes:
Lately it seems to me that every time I take my beautiful new car out for a ride it comes home with a new ding or chip in the paint on her pretty nose.
[snip]
Of course, if anybody has another good suggestion, please let me hear.
[snip]
' 93 XJ-S
Yours, being a '93, should still be under warranty for the paintwork. I have
noticed the attraction to small stones and other debris of my '88 XJ-S as
well, in the same area of the nose. However, I also noticed that the paint
in that area is RIDICULOUSLY thick, 3mm in places. As a result, dings and
chips don’t go down to the primer or bare metal. It sounds like yours has
thinner layers of paint and therefore a manufacturing defect. Try that line
with your local Jag dealer. Good luck.
Stefan Schulz
jaguar@suaviter.demon.co.uk
Date: Thu, 05 Sep 1996 15:32:23 -0700
Please make sure that your fix-a-flat in a can is the non flammable
type! Several techs have been injured badly when a spark was created
dismounting the tire. Also be prepared to pay extra to have all the
liquid residue removed during the repair. It makes it hard to get a
patch to stick. I would recommend that you buy yourself a good tire
plug kit and a mini compressor rather than use the fix-a-flat.
Also the stuck wheels are easily removed by prying between the lower
ball-joint and the wheel on the front or between the lower ends of the
shocks and the wheel on the rear. It’s amazing how a little pressure on
the proper fulcrum points will break the wheel loose. I also use a
copper anti-seize spray on the hub and lug nuts on reassembly.
life saver if you have tire failure in the middle of nowhere.When I had this problem on our XJ-S a while ago, I went off and bought
the trunk anyhow
- Matthias
Michael P. Neal ASE Master Technician, Jaguar Certified
'93 Ducati 900SS '83 Porsche 944 '85 Jaguar XJS
Home (707) 829-8464 Work (707) 577-0101
http://www.wco.com/~mneal (always under construction:-)
Date: Thu, 05 Sep 1996 18:45:40 +0100
At 08:22 AM 05/09/96 EST, mclaus wrote:
Does anybody know if there is a bra which can be fit on the car?
Hi!,
The second post after this referred to the gender aspect of the
jag-u-awe, with most saying, “male”… Now a bra!
May I suggest we move this list to alt.sex.transvestite.jag(blush)
lovers!
Have fun!
'62 E-Type, ots
From: “Peter Rebbechi (03) 9275 3374” <"REBBECHI PETER"@A1.MEOC02.SNO.mts.dec.com>
Date: Thu, 05 Sep 1996 22:46:00 +0000 (GMT)
Subject: More stories
More stories like the Steamboat Springs stories.!
This is why we drive Jags!
Thanks to Lawrence Buja, It was entertaining and enjoyable.
Date: Thu, 05 Sep 1996 21:29:58 GMT
In message 199609051112.NAA04318@turquoise.cray.com mfl@kheops.cray.com
(Matthias FOUQUET-LAPAR) writes:
I bought a set [of mud flaps] (front and rear) for my '88 XJ-S.
[snip]
The original Jaguar ones don’t work at the rear right where they foul an
exhaust pipe. Can be solved with a pair of garden scissors, though
Yet another reason to go for non-Jaguar parts. Get the same hassle for
LESS money!
Stefan Schulz
Date: Thu, 5 Sep 1996 20:40:21 -0400
Subject: Re: Series III XJ6 Lukewarm Starting Problem
Tony,
I’m afraid I may have accidentally misled you slightly about the
pressure in the fuel system. The pressure in my system also falls very
slowly over a period of hours, but never gets low enough to cause difficulty
starting. Since reaching that point solved the problem for me, I didn’t
explore the slow leakage any further.
Also, since my Series II XJ12 operates on 30 PSI, the 26 PSI figure I
quoted is actually closer to spec than it may seem.
If you’re still having lukewarm start problems despite adequate
pressure, I’m afraid you may have to look elsewhere into realms I haven’t
explored.
Good luck,
Jon Schrock
1977 XJ12L
1965 E Type
1957 XK140
Date: Thu, 5 Sep 1996 19:00:34 -0600
Subject: De-rusto
what the hell. Has
I've used such stuff over the years with pretty good results.
their exhaust systems with the stuff and had good results.Mark
I haven’t used the POR 15 for under car applications, but I have used their
gas tank coating stuff. It has worked well in 3 cars.
Phil Bates
67 MGB
75 Jaguar XJ12C
52 MG TD replicar (VW)
Date: Thu, 05 Sep 1996 21:33:19 GMT
David Engelbach writes:
It’s one of those traditional British things, you see. Wooden slabs on
dash and doors are a tip o’ the hat to the old coachbuilders. The a/c
slider you’re referring to is what’s known as a placebo control. All
British cars have them, particularly as they get older. In some cases
the ignition switch winds up being a placebo, too
Stefan Schulz
Date: 05 Sep 96 21:31:31 EDT
Subject: No Jag content / Auto mailing lists
Off topic a bit.
There used to be a ftp site for a complete list of automobile mailing lists.I
had it as: ftp://ftp.balltown.cma.com/misc/Autos/mailing-lists.text
but this doesn’t seem to work any more. Anyone have an updated site?
I’m looking for a Porsche mailing list. Porschephiles seems to be dead and
gone. It has been months and the home page is still down. Anyone know why?
Thanks,
- -Ed-
Date: Thu, 05 Sep 1996 21:23:16 GMT
In message 199609051117.NAA04336@turquoise.cray.com mfl@kheops.cray.com
the trunk anyhow
Erm, with due respect, no. Not for a Jaguar XJ-S with humungous tyres anyway.
The problem with these cans is that they create a solid residue which
coagulates (?) on the inside of the tyre and the rim, especially near the
joint between the two. Near impossible to get off when you replace the
tyre, it’ll give you a slow leak on the new one and imbalance to boot.
The larger the tyre, the larger the badly sealed area and the larger the
imbalance. It gave me problems on a Volvo with relatively small wheels.
Carrying a spare is easier. And yes, the tyres on my XJ-S stick to the
hubs, too, but a good kick always gets them loose.
Stefan Schulz
Date: Fri, 6 Sep 1996 12:35:15 +1000 (EST)
Subject: Re: Where to locate fan relay?
Quang Ngo writes
I am sorry to be the bearer of bad news, but the problem is unlikely to be
solved by locating a relay. There are a few of them and lots of other
control devices in the AC system. An intermittent fault, like you have,
could be caused by the water valve to the heater matrix not closing. This
valve is normally open, and is closed by vacuum from a reservoir via a
vacuum solenoid. On right hand drive cars, the valve is located on the left
hand side under the bonnet (hood) near the fire wall and just inboard of the
battery. It is easy to see and has a small plastic tube going to the top of
it. This tube is red, but has a black fitting on its end, so its colour
isn’t immediately obvious. First, disconnect the plastic tube and connect a
length of similar diameter plastic tube to it so that, with mouth suction,
you can check to hear if the valve appears to be closing under vacuum.
Next, run the car engine with the controls set for minimum temperature (with
a fairly high ambient temperature so that the AC should cool) and check that
you can feel suction on the tube which connects to the valve. If the valve
appears to be working alright, please get back to me, but that is my best
guess so far as these valves can also be a victim of the “Bars Leaks”
syndrome. Regards, Alan.
Date: Thu, 5 Sep 1996 22:54:16 -0400
slush and snow ?
Thanks
LouLou,
I had the same problem with my '88 XJ40. The road spray sandblasted the
paint right down to the primer behind both front and back wheels, so last
year I had the car re-painted in those areas by a Jaguar Dealer and also had
them install mud flaps. They work really well and also look pretty good.
I can’t comment on the winter slush since I don’t drive the car in the
winter, however I don’t think it would pose a problem. Besides, you would
be much better off with them than without them.
Rich Shehab
Pittsburgh, PA
Date: Fri, 06 Sep 1996 14:50:38 -0700
Subject: Re: De-rusto/POR15/Duro Extend
gas tank coating stuff. It has worked well in 3 cars.Phil Bates
67 MGB
75 Jaguar XJ12C
I am about to use POR 15 under the chassis of my newly painted Dailmer V8
250.
Has anybody got any comments good or bad about this product in this
application?
Thanks in Advance
Shane Gibson
1968 Daimler V8 250 (57% Restorartion Complete and only 150% over
budget)
Date: Thu, 05 Sep 96 22:23:41 -0500
Subject: RE: XJS Micro switch on throttle
According to both the shop manual and the
wiring diagram this switch has nothing whatever to
do with the transmission. It would make no sense
for the transmission kickdown to operate from
such a switch. If this were actually the case,
then the car would NEVER shift into 3rd gear at
anything more than about half throttle. This
switch, in fact, goes to the ECU and richens the
mixture, which also occurs below certain levels
of vacuum. Furthermore, the switch is only used
on cars shipped to North America. At least this is
what Jaguar thinks.
Phil
From: “Richard Atherton (Entex)” a-richat@microsoft.com
Date: Thu, 5 Sep 1996 21:50:23 -0700
Subject: RE: The Drift King meets Capt’n Hook.
Clipped from the original post:
"Despite the very stiff competition, the ever
popular HomyLordwouldjalookatthose Cup for the most gargantuan silicon
breast implants went to the same threepeat winner who’s dominated the
event for the previous two seasons. "
Are there any Pictures ? ..........Of the cars of course 8-)
Rich
Date: Thu, 5 Sep 1996 23:40:35 -0700 (PDT)
Subject: E gen->alt Heat Question
For those of you who have converted from generator to alternator,
1) What have you done to control heat to the alternator?
2) How reliable is your charging system?
Thanks!
Hunt
Date: Thu, 5 Sep 1996 23:40:20 -0700 (PDT)
Subject: '61 E Alternator Conversion, 2nd installment (Success!)
My new belts and pulley arrived today! As you may recall from yesterday’s
installment, I was quite pleased that the alternator that I chose mounted up
to my generator brackets unmodified. ('74 MGB alt.) Well, at least that was
the case yesterday. My new pulley came from Terry’s Jaguars - looks great,
and it’s an appropriate diameter, too. (Charges at or near 1000 RPM).
Unfortunately (I thought), it is 0.400" shorter than the original, which is
to say, the alternator now requires shimming toward the front of the car by
0.400" for the belt to align. I read on this list once something to the
effect that a Jaguar is an excuse to hold a lot of shims together, so for
now, I have precision washer stacks (glad I buy bulk hardware!). There turn
out to be two advantages to the offset:
1) Alt is a little farther from the exhaust system (psychological,
I’m sure)
2) Recalling from yesterday, the rear mounting ear on the alternator
was interfering with the middle mounting bolt on the generator bracket. This
fixes that problem.
My next suprise was the belt. the 3.8 MK II belt is too long, the 3.8 E belt
is just right, but next to impossible to put on. This is due to the
restricted adjustment range of the alternator, as the frame is a bit close.
I solved this by slightly modifying the adjustment bracket. I drilled a
5/16" hole about 0.5" closer to the slot, to use in place of the original
mounting hole, thus allowing a shorter total length. There is a trick to
installing the belt, too. Leaving the adjusting bracket unbolted, the hinge
bolt (bottom) is withdrawn from the rear of the generator bracket, so that
the alternator is only supported by the front of the bracket. Now it will
swivel freely and the belt will go right onto the pulley. Push the bolt back
through the rear of the bracket and the belt is on.
I’m on prototype wiring at the moment. THe alternator uses a 0.375 spade (2
of them, actually) to connect +output to the battery (via the ammeter), and
a 0.250" spade to run the idiot light. I made a temporary harness using 1/4"
split harness wrap, and 10AWG stranded for the alt. out, and 18AWG stranded
for the idiot lamp. This was routed to the regulator, where I used a male
spade on the idiot light wire and attached to the lamp wire, which I removed
from the regulator. I also removed the ground wire from the regulator, and
temporarily spliced the 10 AWG wire to the pair of terminals sourcing the
ammeter.
Start the car and… nothing (no charge, but is runs great!). Hmm… Oops,
idiot light terminal to wrong wire… Light works, no charge. After running
a few minutes (probably 30 seconds, but when waiting for smoke it seems an
eternity!), it’s charging! I guess the brushes needed to seat (no telling
how long that thing sat on a shelf). I just drove all over the neighborhood
with nice bright lights, and could not cause the ammeter to drop into
discharge no matter what I turned on! No noise in my radio and the engine
bay is quieter, too.
Next concern: HEAT! The good news in the .4" offset is that it is that much
farther from the exhaust manifolds. It still gets a lot hotter than I think
appropriate, though. I know that some 4.2L E’s have heat shields on their
alternators. On my car, the rearmost position on the alternator is fully
ahead of the front manifold, but it is still hot enough to soften the
insulation on my output leads (routed well away from the exhaust). SO, for
those of you who have done this, what (if anything) have you done to control
heat?
The plan, in order of priority is:
1) Find a way to moderate the heat!
2) Formalize the wiring
3) Locate proper spacers and hardware to clean up mounting (It
actually looks OK, but stacks of washers, even matching new ones, just
bother me!).
4) Document it well enough to be of use to others. For now, you will
just have to try to extract some intelligence from my ramblings!
Regards-
Hunt
'61 E FHC (no longer electron impaired)
'85 XJ-6 (also no longer electron or thermally impaired - it’s been a big week!)
From: Martin.Fooks@internetdesign.com (Martin Fooks – Internet Design)
Date: Fri, 06 Sep 1996 09:08:47 +0200
Subject: RE: XJS — Oops!!! --------F.A.O. Kirby
Hi Kirby,
As you suspected Kirby, there was rust inside the chassis rail, which had
weakened the unit enough to allow the torque through the radius arm to snap
a chunk of metal out. There was however some nice clean metal on about
50-60% of the break.
2,500 DFL is about $1,500 and whilst this is a little high I think it’s
about standard for a main dealer. Not having your engineering background I
am not willing to have someone just “Weld in a couple of bits of metal”, but
would much rather have a genuine Jaguar chassis rail replacement carried out
on a proper jig to make sure the chassis is still in proper alignment.
I spoke to David Manners Jaguar/Daimler spares in England and a new rear
chassis rail would set me back just over $450 so $1000 labour may be a
little high but I’m not paying.
Martin
Date: Fri, 6 Sep 1996 09:10:56 -0700
Subject: Re: “Correction” to Jan.
Dear all and Jan Wikstrom in particular!
My perseptions played a trick on me yesterday resulting in a nonsense correction
to Jan’s statement about passenger space in the XJC.
I assure you, I read the posting twice and still didn’t see that he specifically
mentioned short wheelbase. I guess I was looking for the initials; SWB.
Sorry Jan, naturally you’re right.
Eating humble pie.
Bard
Date: Fri, 06 Sep 96 10:19:40 -0700
Subject: RE:84 XJ6 Ongoing Overheating Problem
Christopher,
Have you checked the Jag Lovers Guide to Overheating Problems.
http://www.sn.no/home/nick/overheat.html
Seems to me that this room mates recommendation doesn’t quite know whats going
down here. To recap you’ve done the following work:
- Flushed out, forward & reverse, the entire system.
- Replaced Thermostat.
- Rodded/replaced Radiator.
- Confirmed fan clutch OK.
- Confirmed electric fan comes on when overheating occurs, if not check bottom of
radiator, if cold radiator still blocked. - I assume replaced system Pressure cap for 15 lbs unit.
- Checked no obvious signs of leak including water pump.
Don’t change the pump in desperation it’s far to expensive a job and quite often
you introduce a leak at the gasket that was never there before. I still think you
have a blockage somewhere.
Good luck
Barrie Dawson
Chatham, Kent England
1985 Jaguar Sovereign
End of jag-lovers-digest V2 #334
id for jag-lovers-digest-out; Fri, 6 Sep 1996 18:39:44 +0200 (MET DST)
Date: Fri, 6 Sep 1996 18:39:44 +0200 (MET DST)
Message-Id: 199609061639.SAA10919@ekeberg.sn.no
Subject: jag-lovers-digest V2 #335
Precedence: bulk
jag-lovers-digest Friday, 6 September 1996 Volume 02 : Number 335
Re: 85 XJ-S ac condensate: Where has all the water gone?
Re : Security problem -no problem
SU carbe and angry jags.
Looking for XK120/140
Re: E gen->alt Heat Question
Re: '61 E Alternator Conversion, 2nd installment (Success!)
Re[2]: XJS Micro switch on throttle
XJ40 A/C intermittent
Series II E-type Engine Removal
overheating
Re: No Jag content / Auto mailing lists
Hej Matthias,
RE; XJS Micro switch on throttle
Date: Tue, 03 Sep 1996 17:43:20 GMT
Subject: Re: 85 XJ-S ac condensate: Where has all the water gone?
In message 199609030431.VAA16907@goodguy.goodnet.com ee84287@goodnet.com (Weiss-Malik) writes:
Is it possible that the water
evaporates as it comes out of the tubes? (maybe it hits the cats or the
exhaust pipe?)
On mine the water from the right hand tube does hit the exhaust and evaporates
before it could ever make a puddle. The alignment of the tubes seems to be a
bit hit-and-miss, so perhaps you’ve got a car on which both drop on the
exhaust as you guessed.
leave well enough alone
Good advice with any Jaguar
Stefan Schulz
Date: Fri, 06 Sep 1996 12:15:21 +0100
Subject: Re : Security problem -no problem
Hi Jan Wikstroem and other estemeed jaggers,
The problem is not as you describe it Jam. You can indeed send a message to Majordomo to
unsubscribe another username, however the unsubscribtion is NOT automatic, but requires the
manual intervention and checking by our list guardian. Thus thou shall not fear. Worse it is of
course if some one subscribes you to the the Mazda-owners list, … Talk about traffic…
To see the effect (and possibly but not likely the wrath of Nick) Try to unsubscribe Nick
Johannsen .
Jeffrey Gram.
Date: Fri, 06 Sep 1996 12:16:24 +0100
Subject: SU carbe and angry jags.
P.S. - I have finally given up trying to fix my @#$%^&* HIF7
SU carbs, on the 4.2 litre Engine running worse than a chevy
? firing on half the cylinders, or whatever causes this
non-stable idle, no power on flooring, erratic power surge
during accelaration. This Race-bred engine, rebuilt as well,
was supposed to pump out at least 200 BHP as the slightes
touch of my right (leaded) foot, with its 308 degrees
rallye-cams.
I am at my wits end. I sit and stare at those carbs on the
bench, thinking - I know you’re simple in design, but probably
quite complex air flows. Endless hours were spent at SU /
Jaguar back in the Dark Ages of mechanical engineering,
fiddling with shapes forms sizes , jets, needle curvatures,
vacumm chamber sizes and other breathtakingly difficult
tasks.
Honestly when you think about it it is quite astonishing, how
the damper / pinston / vacumm bell assembly is though out
to precisely meter the varying fuelling (with engine speed),
and provide acceleration enrichment, when you floor the pedal
to the metal, causing the engine to swallow, hopefully around
4.2 liter of air per two rounds. Now that is about 6000 liter of
air per minute at 3000 RPM - did anybody calculate the
Jet-effect of the sexily bend Stainless Jag-exhausts ??.
But these carbs, aint much you can fiddle with, had them
apart at least twice to check taht float level - all OK, Jets are
alike, and correct. Actually only real difference I found with
the carbs were that the FXZ1252F (the front one) carb needle
is about 1 - 1.5 mm shorter than the rear carb ?. I checked
that the needle neck was in the eaxct same place, these
being the springloaded needels leaning towards the jetwall in
direction throttledisc. The needle diameter at point and neck
were identical to a 0.05 mm. apert from this there wer no
differences.
Yesterday I drove the car to another garage, ashamed, a
jag-lover with engineering background and 7 years with Jags
gives in and drives to a garage to fix a minor problem - But I
just cant find the combination - the secret the cat has.
Maybe she is angry with me that I bought a bigger and
younger sister of hers and let red Jackie sit in the Garage for
months ??.
But today I phoned - Well Yes she runs much better. I took
the garage man for a ride showing him that She was not giving
herself completely. Still Angry. They will now care for her the
next week trying to find her little secret.
Then I shall ride her again .
Jeff
Date: Fri, 06 Sep 1996 11:46:55 GMT
250.Has anybody got any comments good or bad about this product in this
application?
A customer once painted the exterior of a car radio with POR (don’t
ask me why). When we tried to remove the stuff, we found it was
nearly like porcelain in hardness and durability. We had to change to
a more agressive abrasive in the bead blast cabinet . I hope never to
see POR on a radio again, but wouldn’t mind it on the frame of my Mark
IX.
Vince
Vince Chrzanowski radiowsh@mindport.net
“There is not a moment to be lost” - Jack Aubrey
Date: 06 Sep 96 08:54:41 EDT
Subject: Looking for XK120/140
Dear friends
I’m still on my quest for an XK120 or 140.
I will be in two weeks for vacation in Florida. I have already had contacts with
Vintage from Sarasota and with Classic Car Exporters. Can somebody advise me to
another place where I could find my dream car?
Best regards Zoran Mitrovic
Date: Fri, 6 Sep 1996 09:32:09 -0400 (EDT)
On my '82 XJ-S HE there are two microswitches. The first is mounted such
that the rotating drum of the throttle pot closes it when the throttle is
opened past a certain point. This is the one that richens the mixture.
If this circuit doesn’t work, less performance (been there, done that).
The second one is mounted over towards the throttle cable, and is actuated
when an extra push on the accelerator cable (when already at wide open
throttle) forces the accelerator cable housing to move (the cable within
can’t move any more because you are already at WOT). This one gives
kickdown. If the cable housing is rusted up and not free to move easily,
no kickdown (been there, done that, too).
Question: will a pushbutton wired in parallel with this switch and
controlled somehow by the driver provide part-throttle kickdown? Or does
the electric kickdown only work if the transmission is also seeing zero
vacuum at the modulator (from WOT)?
what Jaguar thinks.
Phil
Date: Fri, 6 Sep 1996 09:37:24 -0400 (EDT)
Subject: Re: E gen->alt Heat Question
Hunt, I’ve done this on several cars, although never on an E-Type.
Heat to the alternator has never been a problem – these things are much
better vented than generators. And charging system dependability is about
as good as can be provided you use a dependable alternator! I tend to
swap in good old Delco alternators – cheap, dependable, and parts or
replacements available anywhere. Select ones that are used in cars at
least ten years old for the best price/performance/availability.
John
Thanks!
Hunt
Date: Fri, 6 Sep 1996 09:42:12 -0400 (EDT)
Subject: Re: '61 E Alternator Conversion, 2nd installment (Success!)
Gee, Hunt, at this rate you’ll get your climate control system in the XJ6
running, too!
John
Date: Fri, 06 Sep 96 08:48:46 CST
Subject: Re[2]: XJS Micro switch on throttle
Phil,
The switch that some of us are referring to is the microswitch on the
throttle cable! It is indeed the transmission kickdown switch. It is
activated when the gas pedal is stomped down (hard on my car). The
pedal must hit the stop which causes the throttle cable housing to
"push back" actuating the switch. This switch may only be on the
GM400s or maybe HEs only, I don't know, someone more familiar can say.
My repair manual shows decent pictures of it and describes it as well.
Larry Conrad
'51 MG TD 1965
'83 XJ-S 1995
Author: “Phil Patton” ppatton@ibm.net at INTERNET
Date: 9/5/96 10:23 PM
what Jaguar thinks.
Phil
Date: Fri, 06 Sep 1996 09:11:39 -0700
Subject: XJ40 A/C intermittent
Quang Ngo writes
Another possible cause is a bad microswitch in the A/C control assembly.
This is apparently quite common. The microswitch is located at the top of
the switch assembly in the console. Micheal Neal put me on to this and told
me how to get at the switch assembly. If you need instructions - let me know.
Dave
('90 XJ40, '91 Lotus Esprit)
Date: Fri, 06 Sep 1996 09:13:55 -0500
Subject: Series II E-type Engine Removal
I understand that the best way to pull the engine from a Series II E-type
OTS is from the bottom. Is there any documentation available on the web
that covers this method?
Thanks,
jvr
Date: Fri, 6 Sep 1996 16:26:47 +0200 (MET DST)
Subject: overheating
There have been several problems with overheating engines and questions
concerning radiators. Let me ask a simple question : Is it not enough
to measure the in and outlet temperature of the radiator to figure out
if the radiator is working correctly or not ? Somewhere I read in general
the radiator should drop the temperature by at least 10 degrees Celsius.
- Matthias
Date: Fri, 6 Sep 1996 10:33:55 -0400
Ok now I’m confused. My XJS (1984) has two micro-switches. One of them
definitley controls transmission kickdown. If you unplug it ( as I did
accidently) the transmission will not kick down from 3 to 2. I don’t er.
didn’t know whst the other one is for. Am I the only one with two switches?
owner-jag-lovers using -f
To: “Jaguar Lovers” jag-lovers@sn.no
Reply-To: “Phil Patton” ppatton@ibm.net
Priority: Normal
Sender: owner-jag-lovers@sn.no
Precedence: bulkAccording to both the shop manual and the
what Jaguar thinks.
Phil
Date: Fri, 6 Sep 1996 08:19:17 -0700 (PDT)
Thanks John-
Of course, my neeto Lucas alt. has a plastic back cover, we’ll see if it melts!
(It’s only money, right?)
Hunt
least ten years old for the best price/performance/availability.John
Thanks!
Hunt
Date: Fri, 6 Sep 1996 08:19:19 -0700 (PDT)
Maybe, maybe not! The pressure here is that the house is being remodeled, if
I don’t drive the E elsewhere, I’m dead!
Hunt
running, too!John
week!)
Date: Fri, 6 Sep 1996 08:52:19 -0700
A.J. Beale wrote:
Summer is still around, and the AC in my 89 JX40 stops working. Some day
if I’m luckly it works, and the rest of the week I’m sweat. Where is the
relay for the AC fan located?I am sorry to be the bearer of bad news, but the problem is unlikely to
be
This
left
the
of
connect a
suction,
(with
that
valve
Thanks for your reponse, Alan. That part seems to be working. The problem
is more likely be electrical rather than mechanical, as far as I can
tell. Normally, when it works you can see the LED labelled “AUTO” or
“MANU”
next to one of the knobs. However, when the problem occurs, the LED is not
ON, leading me into thinking that one of the relays is out. In fact,
sometimes
after driving a couple of hours it all the sudden kicks in and the LED
comes
on and cold air comes out; everything starts working again. Once, it works
I don’t dare to turn off the fan; I leave it at low level, and hit the 3rd
huminity button to turn off the compressor.
Many thanks,
- -Quang
- Quang Ngo
- quang@valleynet.com
- 89-XJ6 89-300E P90 A3000/25 A1000 SNES PSX C C++ UNIX NT WIN95
- Quang Ngo
Date: Fri, 06 Sep 1996 09:16:18 PDT
Subject: Re: No Jag content / Auto mailing lists
dead and gone. It has been months and the home page is still down.
Anyone know why?
Not sure why the Porschephiles list went away, I wasn’t paying close
attention to that e-mail when it happened, so my only clue was that
the list e-mail just stopped arriving! Fortunately, most of the
Porschephiles group has migrated to the PorscheFans group at
PorscheFans-request@ioio.com. The list has been broken into several
lists according to car type: PorscheFans-356, PorscheFans-911, -914,
- -924-944, and -928. I`ve attached instructions on how to register for
the list below.
Greg DesBrisay
'70 Series II E-Type FHC
'62 AH Sprite
'67 Porsche 912
To: Greg DesBrisay gd@CellNet.com
Subject: Help for the PorscheFans-911 list.
Date: Wed, 21 Aug 1996 11:33:42 -0700
X-ListManager: Porschefans-request@ioio.com
To send a message to the list, send an email message to
PorscheFans-911@ioio.com
To leave this list, send an email message to PorscheFans-Request@ioio.com
with the body:
leave PorscheFans-911
If your email address has changed since you joined, you can append your
original email address:
A summary of list processor commands follows:
JOIN []
Join or subscribe to the list. A copy of each message sent to the list
will be forwarded to the email address given.
DIGEST []
Join or subscribe to the list. A single message will be sent each day
containing an indexed summary of all the messages that have been sent to
the list in the previous 24 hours.
LEAVE []
Leave or unsubscribe from the list. If your address has changed since you joined
the list, send your original email address.
HELP []
Provide help about the list server or about the specified list.
The following PorscheFans lists are available:
PorscheFans-356
PorscheFans-911
PorscheFans-914
PorscheFans-924-944
PorscheFans-928
Date: Fri, 06 Sep 1996 18:36:00 +0100
Subject: Hej Matthias,
Hej Matthias,
As you might realise, it is not enough to measure the difference between water radiator inlet and
outlet temperatures in order to judge whether the radiator is “good”. The reason is that such
measurement is not a quantitave measurement, but a relative one, and indeed without a
reference to further circumstantial fact, you cant use it for anything.
The amount of energy the radiator can transfer to the surroundings depend on several factors. :
Size, surface, temperature difference between ambient air and the coolant, air speed, air
density, and I’m sure many more.
If you should give a referential point to the 10 degrees difference, you would need to put a
number to all of above, and last but not the least, put a number on the amount of energy the
engine pumps to the radiator, and that is not insignificant.
I’m convinced the phenomenon of heat problem of jags lie not only in the “traditional” faults such
as radiator full of sediment, engine scaled up, incorrect ignition (V12 in particular), but also in a
too small margin, of cooling efficiency, but strongly I believe the arrangement of the waterpump
with too little capacity and a radiator with a fan which is not optimally moving air is a major
cause. I too find the cooling inferior. I will not, and I can not accept to have to turn the airco off in
town on a hot hot day, just because the V12 beast sweats itself to death.
My feeling is I will excahnge the radiator for a better efficiency rad (in the same “frame”) , mount
one two three or four high capacity electrical tornado-generators (fans) and later I will have the
bonnet louvred.
Kirby mentioned the louvres will have ad adverse effect on airco performance leading hot air into
the fresh air intake, but I’ll find a fix for that too.
Also I plan to install another thermostat system - electrically operated. However the last is the
last resort.
One day - One day I will get it to work alright…
Jeffey gram
Date: Fri, 6 Sep 1996 12:48:53 -0400 (EDT)
Subject: RE; XJS Micro switch on throttle
- ----- Begin Included Message -----
From daemon Fri Sep 6 12:44:42 1996
Subject: Returned mail: User unknown
To: talberts
MIME-Version: 1.0
Content-Type: multipart/report; report-type=delivery-status; boundary=“MAA00246.842028282/gemini.aero.odu.edu”
Auto-Submitted: auto-generated (failure)
Content-Length: 2479
X-Lines: 69
Nobody ever argued that there is only one micro switch. Jim Isabelli’s
original question was about the switch on the throttle cable with green
wires connected to it. That one is the kickdown switch and there is
simply no point arguing over it.
Thomas E. Alberts
didn’t know whst the other one is for. Am I the only one with two switches?According to both the shop manual and the
what Jaguar thinks.
Phil
End of jag-lovers-digest V2 #335
id for jag-lovers-digest-out; Fri, 6 Sep 1996 21:04:46 +0200 (MET DST)
Date: Fri, 6 Sep 1996 21:04:46 +0200 (MET DST)
Message-Id: 199609061904.VAA09232@ekeberg.sn.no
Subject: jag-lovers-digest V2 #336
Precedence: bulk
jag-lovers-digest Friday, 6 September 1996 Volume 02 : Number 336
Wind Deflector
Re: XJS Micro switch on throttle
Re: SU carbe and angry jags.
Re: About the mysteries of the XJ series
Re: Hej Matthias,
Setting SU carbs with a UNISYN.
Service Manuals
Date: Fri, 6 Sep 96 10:15:22 PDT
Subject: Wind Deflector
Has anyone installed a wind deflector for the sunroof of an XJ40?
Do they work? Meaning, do you get less wind noise and buffeting?
How easy was the installation? Does it require drilling any holes?
And finally, how much does it cost?
Thanks.
Roger Peng (408)765-7863
Intel Corporation
Design Technology, Physical CAD
Date: Fri, 06 Sep 1996 17:16:03 GMT
Subject: Re: XJS Micro switch on throttle
no kickdown (been there, done that, too).Question: will a pushbutton wired in parallel with this switch and
When the kickdown switch on my '85 XJ-S went bad I couldn’t get the
transmission out of first gear, regardless of the speed of the car or
amount of throttle depression. The failure mode of the switch was
that the normal-open contacts never opened.
Vince
Date: Fri, 6 Sep 1996 13:45:46 -0005
John Napoli jgn@li.net:
mounted.Oh, yeah, there is a middle ground here as well. Racing XJ-S’s often lose
Both of these are workable plans, with differing results. The first
will result in a lot more differential noise inside the car, as well
as an increased feel for small bumps and rough road surfaces.
Both, however, are changes in suspension GEOMETRY. With the stock
system, as the rear wheel travels up and down, it is travelling
around an axis that is at a rather severe angle to the centerline of
the car. IOW, as the wheel moves away from level, it also moves
forward and turns in a little, providing a little rear-wheel
steering. The effect of the stock design is to provide a lot of
stability on the freeway, making the car impervious to crosswinds and
the like. (And you thought it was just because the car is heavy?
Get real)
In racing, such stability due to rear wheel steering is also
desirable, but to a much lesser extent – a lot of it tends to make
the car corner poorly. So, the arm is altered to pivot closer to the
centerline of the car. This reduces the rear wheel steering effect
and allows the driver more control over how the car drives at the
limit of adhesion.
The first option, eliminating the arm entirely and rigidly mounting
the diff, will work – but it makes for a rather poor suspension
geometry, with no rear wheel steering stability at all. On hot
rods, where this idea is often used, the idea is to make the
suspension LOOK pretty by eliminating any extraneous parts (arm and
cage) and chroming the ones that remain. And in both the hot rod
and Cobra applications, the suspension is normally sprung so stiffly
as to not move much anyway, you’re driving a go-kart rather than a
car, suspension geometry is not an issue.
The Jaguar is an excellent handling car even though it is softly
sprung. If you wish to maintain this, I would avoid eliminating the
radius arms. Rearranging them to closer to center is a possibility,
but I probably wouldn’t try it without replacing the cage mounts with
something stiffer like polyurethane; the flex of the stock system may
overpower the small amount of rear-wheel steering stability you end
up with.
– Kirbert | If anything is to be accomplished,
| - Palm’s Postulate
Date: Fri, 6 Sep 1996 13:45:47 -0005
Subject: Re: SU carbe and angry jags.
I thought about that, and have decided it ain’t right. Gotta feeling
one of your needles was intended for a different size carb. I would
do either of two things:
Buy one new needle, and see which one it matches. Pitch the
other. -
Buy two new needles, pitch both of the originals.
| - Palm’s Postulate
“Phil Patton” ppatton@ibm.net:
what Jaguar thinks.
Hey, there are two microswitches on the throttle linkage, and one
DOES go to the transmission and operate the kickdown. However, this
discussion has suffered for a lack of clarity on which switch is
being discussed, and both have been described. One has its roller
follow a cam on the bellcrank, and the cam moves the roller at about
the half-throttle position; this operates the ECU, switching from
closed- to open-loop operation. The other is on the throttle cable
attachment, and the roller is moved by the cable HOUSING being
forcibly pulled toward the bellcrank – which only happens when the
pedal is mashed all the way to the floor. This switch operates the
kickdown relay within the GM400 transmission.
| - Palm’s Postulate
Date: Fri, 6 Sep 1996 13:45:48 -0005
I’m sure)
If heat is a concern – and if an electrical item is near a Jaguar
exhaust manifold, then heat IS a concern – then the thing to do is
provide a heat shield. Just fashion a piece of sheet metal to block
the line of sight between the manifold and the part being protected.
In this case, you could provide such a shield wrapped around the
alternator (careful not to block any ventilation holes), or you could
provide a cover over the manifold. Or both, if you really wanna cut
the heat.
Heat shields are VERY effective. Basically, all radiant heat is
blocked. If the metal is shiny, it is reflected. If not, it is
absorbed, but the shield itself is usually cooled well enough by
passing airflow that it itself doesn’t get hot enough to emit a lot
of radiant heat onward.
is just right…
I keep hearing owners of older Jags talk this way. Why would anyone
refer to a “3.8 MK II belt” or a “3.8 E belt”? Belts is belts,
aren’t they? Don’t you just go to the parts store and say “I need a
V-belt this long”? Or is there something really unique about early
Jaguar belts?
| - Palm’s Postulate
Date: Fri, 6 Sep 1996 13:11:26 -0500
Subject: Re: About the mysteries of the XJ series
While we are discussing controls, A/C etc. Can anyone tell me what the
purpose is for the small hole on the underside of the top lip of the dash?
The hole is about 1/2 inch in diameter and is positioned directly above the
glovebox. It is definitely there for some sort of purpose that has
continued to elude me.
Additionally, I have noted that there is an indentation on the other side
of the car in the same basic location apparently where the hole would be if
the car were a RHD. This is on an 83 XJ6 SIII. (GOD I’m going to hate it
if it is for something perfectly obvious)
“Always remember, pillage BEFORE you burn!”
David Tordoff - Dallas, TX
Date: Fri, 6 Sep 1996 14:50:18 -0400 (EDT)
Subject: Re: Hej Matthias,
Yes, I am interested in this myself.
Here’s a suggested experiment to see if the hot air exiting would affect
the air inlet.
Drive the car with the bonnet popped open. If you’ve got good struts, the
bonnet will be held up against the safety catch. Now see if you can
detect any change in A/C performance.
Not exactly the same air flow as if you punched louvers, but painless to
try.
I can’t wait to try this in the winter to instantly evaporate all of the
nasty ice and snow!
John
bonnet louvred.
Date: Fri, 6 Sep 1996 14:53:15 -0400 (EDT)
OK, so I can get part-throttle kickdown by ading a push button?
John
that the normal-open contacts never opened.Vince
Date: Fri, 6 Sep 1996 12:55:58 -0600 (MDT)
Subject: Setting SU carbs with a UNISYN.
Jeff moans…
{P.S. - I have finally given up trying to fix my @#$%^&* HIF7
{SU carbs, on the 4.2 litre Engine
Don’t give up. You can set these buggers if you put your mind to it.
Just think of them as big airbrushes which use petrol rather than paint.
First, once the site comes back up (it’s offline right now) download the
SU guide from Tuning Your S.U. Carbs
Below is another run thru the same thing, but requiring special tools
(you can buy both tools for less than what it’ll cost you to have a
pro set your carbs once).
/\ Lawrence Buja http://www.cgd.ucar.edu/cms/southern
_][ southern@ncar.ucar.edu National Center for Atmospheric Research
________________Boulder,Colorado___80307-3000
- -Date: Tue, 8 Feb 94 12:43:02 PST
- -To: swedishbricks@me.rochester.edu
- -Subject: Tuning Your SU Carburetors
I’ve been meaning to write this up for some time, ever since I did the
SU Performance Tuning 101 a few months ago. This one is more like Basic
SU Adjustment for Happy Driving.
The trick to tuning SU carbs is to understand that there are two things
you need to get right: the air flow, and the fuel mixture. While they
are interconnected, they are also independent, and need to be measured
and adjusted independently.
Special Tools
You will probably need to arrange to buy or borrow a Unisyn flow meter.
The Unisyn is the usual gauge for getting the air flow balanced between
the two carbs. This costs about $20 and is simple to use. It consists
of an adjustable opening (same size circumference, but with a disc on a
threaded rod that you can screw tighter or looser) that you use to
set the level of a little float that rises or falls in a glass tube at
the side of the gauge.
For the fuel mixture, I have become sold on a device called the Gunson
ColorTune (maybe ColourTune, as it’s a British co.). This is a spark
plug with a crystal pressure- and heat-resistant window in it that lets
you see into the combustion chamber while the motor is running. The
color of the flame indicates the mixture richness. It costs about $40,
and while it’s not absolutely essential, it makes life so much easier
that it’s worth the cost.
If you don’t have a Gunson, I’ve included the standard directions here
for determining correct mixture (step 4 of the Adjusting Mixture procedure).
To tune SU carbs, first locate the following components:
Throttle linkage nuts. These are the things that connect the
throttle linkage (the bar connected to your foot through whatever
means your car uses, cables or rods) to the carburetors’ throttle
levers. -
Throttle stop screws. These set the idle speed for each carb,
and are located typically behind the dashpot, on the same side
of the carb to which the throttle linkage connects. -
Mixture adjusting nut. This is the lower of the two nuts at the
very bottom of the carburetor. Later SU carburetors of the HIF
type have integral float chambers, on which the mixture is
adjusted by turning a screw. You’ll need to experiment (and I
explain how) to see which way makes this richer and which way
makes it leaner. -
Lifting pins. These are little wobbly metal pins under the
dashpot. When you push up on the pin, it raises the piston in
the dashpot. Find these; they’re crucial if you don’t have a
Colortune. If you don’t have or can’t find them, you can raise
the piston with a flat-bladed screwdriver pushed down the throat
of the carb and twisted to lift it. -
The bridge. This is the part inside the carburetor, where the
gas jet opens into the airstream. You’ll see a needle inside
the jet, and the jet itself should be a few fractions of an inch
down from the bridge itself. The jet is the brass tube that sits
in the center of the bridge, with a tapered needle poking down
into it. -
The choke linkage nuts. Comparable to the throttle linkage nuts
(and usually the same size), but on the linkage that goes between
the choke cable and the mixture adjustment mechanism. They make
sure that both carbs are enriched when you pull on the choke.
Balancing The Air Flow
Start with the engine warmed up to operating temperature and
perform your standard ignition tune-up (points gap, timing, spark
plug gap, new condenser, etc.) first. If you’ve got a timing light
and a dwell meter, you can verify all that stuff independent of the
way the car is running. When it’s warm, shut the motor off and
remove the air filters. -
Begin by balancing the air flow. To do this, first loosen
the throttle linkage nuts. Leave them connected, just loosen them
half a turn or so. -
Back out the throttle stop screws till you can see that they
are just touching the throttle stop. Then open each carburetor
(that is, lower the throttle stop screw) 1-1/2 turns of the throttle
stop screw and start the engine. It will probably idle at about
2000 RPM; don’t worry. -
Put the Unisyn over either carb and adjust the orifice in the
Unisyn till the little float at the side rests at the middle of its
graduated tube. (Pre-diagnostics: if the idle drops and the car
wants to die when you slap on the Unisyn, the carb is too rich; if
the idle soars upwards, it’s too lean.) Hold the Unisyn over the
carb for only long enough to see the level of the float, then
remove it. -
Place the Unisyn on each carburetor in turn to check its flow,
adjusting the throttle stop screws until both carburetors register
the same position on the graduated tube of the Unisyn. (The float
will probably move either up or down in the tube, which is why you
want to center it in Step 4.) When both carburetors flow the same
amount of air, tighten the throttle linkage nuts, adjusting for
the amount of free-play between the linkage and the throttle stops
that your manual calls for (probably about 0.006"). Your goal
should be to achieve the lowest possible idle with both carbs
balanced and the engine running smoothly. (Note that the idle speed
will very probably rise as you get the mixture correct.)
If you’ve taken more than five minutes to do this, rev the engine
to over 2500 RPM (assuming the idle isn’t already that high) for
thirty seconds or so to clear the spark plugs. Then adjust the
mixture.
Adjusting The Mixture:
Note: in the following procedure, one “flat” is the basic increment of
adjustment, and refers to 1/6 of a turn of the mixture adjusting nut.
This corresponds to the flat faces on the nut.
I’m going to give instructions for SUs with the separate float
chambers. If you have the HIF integral-float carbs, you’ll have
to look in a manual to see whether you turn the mixture screw to
the right or the left to make it richer or leaner; I’ve done that
once but I can’t remember. Alternatively, you can – with the
motor shut off – peer down the throat of the carb and turn the
mixture screw while watching the top of the jet. Remember that
moving the top of the jet up will lean out that carb, while moving
the top of the jet down will richen it.
Shut the car off and loosen the choke linkage nuts.
Adjust the mixture nuts (screws) fully lean.
For separate float-chamber cars, this means raising the mixture nut
all the way up against the bottom of the carb (or rather, against
the spring). For HIF carbs, you can try turning the screw while
looking down the throat to see which way the jet is moving. In either
case, the idea is to zero out the jet: raise it all the way up in
the bridge.
- Now drop the jet an equal amount – two full turns for HS-type carbs,
two full turns (I believe) for HIFs. Then start the car.
Note: In the following step, you might want to consider adjusting the
carburetors one-half a flat too lean, as the mixture will be enriched
when you put the air filters (which restrict air flow) on at the end
of the tuning process.
- Raise the lifting pin (or use a screwdriver if you don’t have the
pins) so that the piston rises no more than 1/16". Listen to the engine’s
exhaust note and compare it to the following conditions:
If the exhaust note rises and stays high till you drop the piston,
this carburetor is adjusted too rich. Turn the mixture nut one
flat (one-sixth of a turn) up, moving the jet toward the bridge,
then repeat Step 4. -
If the exhaust note falls and the car sounds as though it is going
to stall, this carburetor is adjusted too lean. Turn the mixture
nut one flat (one-sixth of a turn) down, moving the jet away from
the bridge, then repeat Step 4. -
If the exhaust note rises briefly and then settles back down to
something like the original RPM level, this carburetor is set
correctly. When you have achieved this setting for both
carburetors, continue with Step 5.
Tighten the choke linkage nuts so that the choke cable will pull
an equal amount on both mixture nuts when you pull the knob. -
At this time, I find I usually have to adjust the idle again because
getting the fuel mixture right usually changes the idle speed. Since you
know you have the throttles synchronized, I normally just adjust the
idle without loosening the throttle linkage. The easiest way is to screw
one of the screws out till it doesnt’ even touch the throttle stop, then
use the other to get the idle speed right. When that’s done, you can screw
the other stop screw down till it just touches the stop on that carb and
you’re set. -
Replace the air filters and go for a test drive!
Notes
SU carburetors are most fuel-efficient when slightly lean, and provide
the most power when they are slightly rich. You can use this knowledge
to provide a certain amount of tuning for the kind of driving you do.
If you learn to read spark plugs, you can get a basic idea of what your
engine’s condition is and make fine adjustments to the mixture nuts
accordingly.
If you have a ColorTune, you simply install it in place of one of the
plugs, then adjust the carburetor that feeds that cylinder (the front
carburetor for 1 & 2, the rear for 3 & 4). The ColorTune will let you
see the color of the flame. White flashes mean too lean; yellow flame
means too rich. Blue (like a Bunsen burner) is correct, and blue with
a faint orangish tinge is the best for power.
You can also modify your car’s throttle response characteristics slightly
by adjusting the viscosity of the oil in the dashpot damper. SUs are
set up so that a thicker oil will resist the piston’s attempt to rise
in the dashpot for just long enough that the engine’s increased load
(when the throttle is opened) will pull more fuel across the bridge;
this enriches the mixture and temporarily bumps power up to help the
engine achieve higher speed more readily.
If you modify your engine, you will probably need to modify your needles,
as it is the needle profile that determines the mixture curve for different
air-fuel loads.
If you experience uneven idle, hunting, or an idle that changes (rises
or falls) as the engine’s temperature climbs or drops, you probably have
vacuum leaks. The most serious fault on most old SUs is wear in the
throttle shaft area. To test for this, spray some carburetor cleaner
on the outside of the throttle shaft; carburetor cleaner is non-combustible,
and if the engine speed drops, it means some of this is getting into the
air stream from outside the carburetor. You may also have leaks from
the manifolds, from tubing such as the vacuum advance line to the
distributor (if fitted), or from other places; the carb cleaner trick
works well for locating those leaks as well.
Other problems that SU carbs experience involve dirt in the dashpot
and occasionally in the float chamber. The dashpot is a precision
piece of machining that involves very close tolerances so that the
piston doesn’t stick or bind when it rises and falls. A little grit
between the piston and the dashpot can make the car jerk and sputter.
Take the dashpot off, wipe the insides down with carb cleaner and a
lint-free, clean rag, then reinstall it, getting the screws down
tight. Also, don’t swap the pistons between dashpots; they’re matched
to one another so that the clearance between the piston and the wall
of the dashpot makes a tight seal but permits easy rising and falling.
Dirt in the float bowl basically shuts off that carburetor (or can
make it flood open, depending on whether the dirt is wedging the
valve open or closed). You can try rapping on the float bowl with
the handle of a screwdriver, but your best bet is to take the cover
off, clean out the valve fittings, and reinstall everything, with a
new fuel filter for good measure.
Some older SU models also have adjustable floats, in which you need
to set the float height (which basically equals the fuel level in the
float chamber) by bending a brass rod. These carburetors were replaced
in the mid-1960s with carburetors that had fixed, plastic floats which
are basically trouble-free unless abused. The stop at the back of the
floats can break if they are installed badly, and the brass pin that
holds them in place can wear an oval hole in the float pivot. New
floats are fairly inexpensive and aren’t a bad idea if you’re doing
a rebuild.
Grose-Jets are very popular with some people and a big pain for others.
It appears – and this is just conjecture – that Grose-Jets work best
in cars with adjustable floats, as they are longer than the stock SU
float valves. The standard failure for Grose-Jets is to flood the
carburetor. I have never had problems with the stock SU float valves
or floats.
- –Scott “I like SU carbs – they’re expert-friendly” Fisher
From: Michael Powers/TEIR/Thomson Michael_Powers@teir.com
Date: 6 Sep 96 15:05:09
Subject: Service Manuals
Hello there:
Has anyone used the factory service manual set for the 89 XJ6?
Is it worth the money? Any recommendations for better 3rd party service books
that contain wiring diagrams?
My local Jag dealer wants $185 for the complete set of manuals. Not a bad
price, but I hate to pay that much for something which may not
get used very often.
Thanks for the help,
Mike
| mpowers@teir.com
| (703) 736-1832
| Would somebody please explain to me those signs that
| say, “No animals allowed except for Seeing Eye Dogs?”
| Who is that sign for? Is it for the dog, or the blind person?
| -Jerry Seinfeld
Date: Fri, 6 Sep 1996 15:04:32 -0400 (EDT)
Good reply. And it raises some questions:
Is there a source for stiffer cage mounts? Or is it a case of using
the stock setup or going solid? -
The XJ-S in question seems to be one of the more powerful ones out
there. Is the stock setup just unable to absorb the extra power over an
extended time? So to have more power must you forego the other benefits
of the stock suspension? -
If the failure was hastened by rust in the tub, do we all face this
problem? Where does the water get in from? How do you check (drill holes
in some strategic location)? I have seen E-Type tubs cut open; they get
looking pretty bad inside rust-wise. Do our XJ-S’s have the same
proclivity?
car, suspension geometry is not an issue.The Jaguar is an excellent handling car even though it is softly
up with.– Kirbert | If anything is to be accomplished,
| some rules must be broken.
| - Palm’s Postulate
End of jag-lovers-digest V2 #336
id for jag-lovers-digest-out; Sat, 7 Sep 1996 00:51:45 +0200 (MET DST)
Date: Sat, 7 Sep 1996 00:51:45 +0200 (MET DST)
Message-Id: 199609062251.AAA25743@ekeberg.sn.no
Subject: jag-lovers-digest V2 #337
Precedence: bulk
jag-lovers-digest Saturday, 7 September 1996 Volume 02 : Number 337
AK Miller Auction (No Jag Content, but very interesting)
Re: 96 XJS conv.
Re: overheating
When the student surpasses the teacher…
'70 XKE intake manifold (dual Strombergs) - question
4.2l and transmission for sale
Re: overheating
Re: When the student surpasses the teacher…
Re: overheating
1985 XJ-S Blown Head Gasket
Hurricane Fran - XJS lowrider (R.I.P.)
Re: Hej Matthias,
Date: Fri, 6 Sep 1996 16:18:38 -0400
Subject: AK Miller Auction (No Jag Content, but very interesting)
This weekend I will be at East Orange Village, Vermont. I will be attending
the AK Miller estate auction, run by Christies.
Consider if you will, Mr & Mrs AK Miller. No obvious means of support,
although he did something in aviation. After 60 years of frugal living, they
both pass on. When the trustees examine the house, they discover $1,000,000
in gold and silver bullion, some in safes, some hidden under floors, or in
the walls. Ok, so what should this interest the jag lovers? Well it seems
that this couple had a hobby: they went around the country collecting Stutz
automobiles, and building little barns on their property to house them.
There are 45 cars altogether, in original, driven condition: Bearcats,
Blackhawks, DV32 Supers, Vertical 6’s. Some of the greatest cars ever built
in America.
Oh, they will also be auctioning Mr & Mrs Miller’s daily drivers: Volkswagen
Beetles.
I will be taking plenty of photos, so if anyone would like copies, just
e-mail me with an address.
Mike Frank
1969 E-Type 2+2
Date: Fri, 6 Sep 1996 16:23:18 -0400 (EDT)
Underneath the mysterious hole is (drumroll)…
… the interior temperature sensor for the automatic climate control
system!!! This betty reports inside temperature to the climate control
brain (that’s being generous). A similar sensor provides outside
temperature. The system notes the different temperatures, the temp you’ve
selected on the dial by the radio, and the operating mode (from the switch
on the other side of the radio) and decides what to do. It’s instructions
are carried out by the servo (flaps open/close, etc.).
It is always on the side with the glovebox.
If you want to annoy a Jag owner, slip a sliver of dry ice up there
on a summer’s day…
John
Date: Fri, 6 Sep 96 13:21:27 -0700
Subject: Re: 96 XJS conv.
It’s a 237 HP six. They stop putting the 12 in the XJS in '94 (could be
'95). This six is torquier than the older six even though the horsepower
rating is the same. It handles better than the 12 because it’s not
carrying an extra 200 lbs. As far as economy - are your kidding? It’s a
Jag.
David C. Engelbach E-mail - widi@artnet.net
Valley Village, CA 91601 Voice - 818.506.5441
USA Fax - 818.506.1011
Date: Fri, 6 Sep 1996 16:30:39 -0005
Subject: Re: overheating
Matthias FOUQUET-LAPAR:
if the radiator is working correctly or not?
No, it is not!
At least? You could as easily have said at most!
You see, there are two common problems with radiators. One is that
they get crudded up, both with deposits on the inner surfaces of the
tubes and with mud and bugs stuck on the outside. Either of these
problems will reduce the cooling of the water flowing through, and
the difference between inlet and outlet temperature will go DOWN –
it’ll be coming out nearly as hot as it went in. A reduction in
airflow – for whatever reason – will have the same effect, and
this may not even be the radiator’s fault, the fan may be defective.
The other problem with radiators is they get obstructed, blocking the
flow of the coolant through them. In this case, the flow drops way
off, meaning the radiator has more time to cool the small amount of
coolant that does go through. In this case, the difference between
the inlet and outlet temps will go UP – there won’t be much coolant
flowing, but it is getting really cool. Meanwhile, the engine is
dropping valve seats!
| - Palm’s Postulate
Date: Fri, 6 Sep 1996 16:43:57 -0400 (EDT)
It would be easy enough to try. I think kickdown can be inhibited
by the vacuum modulator and the trans governer. Otherwise I don’t
see how the kickdown servo can tell the difference between the
micro switch and you own pushbutton. (Possibly must be in open-loop
mode.)
Thomas E. Alberts
Date: Fri, 6 Sep 1996 16:45:21 -0400 (EDT)
Subject: When the student surpasses the teacher…
I have a friend who is interested in automobiles, especially higher
performing luxury machines. For some time I’ve been urging him to
consider a Jag (and he has been kept up to date on my own XJ-S
adventures).
Two months ago, he called me up, telling me about a sweet '87 XJ-S he
had seen advertised for sale. It sounded like a low-miles creampuff. He
wanted to know what to look out for.
I spent an hour describing the known trouble spots, and additionally
encouraged him to bring the car in to an authorized Jag dealer for an
inspection. I didn’t hear anything more from him until recently, when he
showed up in my driveway with the car.
The thing is beautiful. Very low miles, garaged all its life: a real
mint example, and he got it for a song.
So now, of course, I’m feeling pretty bad: his car is a lot nicer than
mine! Not fair! But it gets worse!!!
It seems that he and his wife are regulars at a restaurant in New Jersey
also frequented by a senior Jag executive (apparently Jag has
offices somewhere in Northern Jersey). My friend and his wife are having
dinner, having driven up in their ‘new’ XJ-S. They brag about their car
to the proprietor, who introduces them to the Jag exec. She in turn shows
them the light blue XJ8 she had temporary custody of. Not fair!! But
wait, it gets worse!!!
My friend mentions to her that he was interested in obtaining service
manuals. And the next time he and his wife visit the restaurant, what do
you think is waiting for them??? Why, a gift-wrapped, complete and
complimentary set of factory manuals!
NOT FAIR!!!
Boy, how often does all your bragging about Jaguars fall on deaf ears??
This is one case where the student beat the teacher!!!
John
From: David J Shield David_J_Shield@ccm.fm.intel.com
Date: Fri, 06 Sep 96 14:04:00 PDT
Subject: '70 XKE intake manifold (dual Strombergs) - question
Hi All,
The other day I was looking at the engine of the '70 E 2+2 and I found
something strange. I was inspecting the general integrity of the
vacuum hoses and wondering whether to replace them all as a matter of
course (as you recall, I just bought this car from the OO - Original
Owner). I tugged on one of the hoses and here's where it fell off of,
and what I found:
At the back end of the manifold (this strange thing that routes the
mixture through a long, heated path at low throttle and bypasses that
long path at high throttle), there are two coolant fittings. In
between, there is a small (brass?) pipe, over which is a vacuum hose
that travels to the air cleaner box. That particular fitting has been
crimped closed, and looks kind of corroded (blue). The coolant
fittings are intact and look happy.
What is this fitting and what function should it perform?
This is an emission-controlled (kinda) car with dual Strombergs, if
that helps.
I start my 8-week sabbatical on Monday PM. I bought an E and air
tools for my birthday. Ready for fun.
Thanks.
'70 XKE 2+2 with above-mentioned problem - maybe no problem?
'84 XJ6 VDP
Date: Fri, 06 Sep 1996 16:44:58 -0700
Subject: 4.2l and transmission for sale
To all: I have a 4.2l I6 for sale with autotrans. It was removed for a
conversion (not by me). It has the typical head problems with fluid
leakage. I would like to find a good home. Make offer. Mid-Missouri, USA
location. Thanks Bob Gallo, rsgallo@ix.netcom.com
Date: Fri, 6 Sep 1996 17:44:50 -0400
- Matthias
Hi, I am sure none of you want to hear about my TVR again, but here it
comes. My temp measurements for input and output made it seem as though the
rad was behaving perfectly. The engine still overheated. But the rad was
partially blocked for water and air: the small air-flow cooled the small
water-flow just right.
As you say - there have been a lot of overheating problems recently, and
there just don’t seem to be any short cuts or easy fixes…
Peter Carpenter
1967 420
UK
Date: Fri, 6 Sep 1996 15:08:45 -0700
Subject: Re: When the student surpasses the teacher…
service
restaurant, what do
complete and
My brother told me that some guy offered Lotus a deal to put
all of the service manuals for the Esprit on a CD-ROM. They
“rewarded” him with a brand new Esprit Turbo. Talk about
not fair…
Lee
Date: Fri, 6 Sep 1996 15:17:14 -0700
that
of the
these
and
DOWN –
in
and
defective.
You also should state that you’ll transfer more heat energy by
increasing the flow through the radiator. e.g.
On a solar swimming pool heater, at a slow flow rate the temperature delta of the inlet vs. outlet will be very high, but you’ll get a better heat transfer rate at higher flow rates. The water temp at the outlet won’t be much greater than the inlet but the energy transfer will be greater for any given period of time. Best bet is to perform a reverse flush of the system and heater core at least every two years, and a refill with a good 50/50 mix of antifreeze. Lee From: Brent Eagling brent@filoli.com Date: Fri, 6 Sep 96 15:41:56 -0700 Subject: 1985 XJ-S Blown Head Gasket Ladies and Gents, I have an opportunity to purchase a 1985 XJ-S for $3,000 USD. It’s in excellent condition with 80,000 orginal miles. Is it worth it to mess with the blown head gasket? What cost would I be looking at to repair it? Is it a difficult job? Any inputs/recommendations would be greatly appreciated. Brent 1953 XK-120 OTS 1955 VW Beetle Convertible (36 wopping Horsies!) 1986 BMW 535i From: Juliansean@aol.com Date: Fri, 6 Sep 1996 18:41:33 -0400 Subject: Hurricane Fran - XJS lowrider (R.I.P.) Hurricane Fran To the Jag-lovers mailing list. I�ve never experienced a hurricane before so the feeling of powerlessness is strangely interesting. It�s 4:00 AM and the wind is still building. Nothing can stop it. Earlier this evening I deliberated on what to do to prepare for Fran�s landfall. I covered my XJS with the cover and two tarps� tied down really well with rope. I thought long and hard about where to position the car in the driveway to minimize the possibility of trees falling on it. I have lots of huge oak trees in the yard, but no garage. I would have driven the car elsewhere out of harm�s way but I can�t drive it. It just came back from the body restoration shop and I haven�t had chance to put the interior back in. So, I choose to move it to the end of the driveway furthest from the trees and then parked my Isuzu trooper an a vain protective stance thinking it could perhaps offer some protection as a sacrificial shield. Came in, settled in for the duration had a beer. Then the winds started building. Things started hitting the roof. I walked outside once and came back in because tree branches were flying everywhere. I knew that some of the trees were likely to fall. They were just too big, too old, and leaning just a bit too much. The first one sounded like distant thunder as it cracked then a horrendous fright as it hit the roof of the house. By now the power was off and there was no light outside. I peered out of the window and could barely see the Jag, but it looked OK. I scrambled up in the attic to bring down the seats, new carpet, dash etc. where I had been storing them. The tree had punctured the roof and rain was pouring in. While I was up there the storm intensified and I heard another tree fall. The wind seems to be going in cycles up and down with some regularity. Shingles were strewn inside the attic. I knew this was very serious now. I tried to time quick sprints into the attic to fetch parts during the lulls in the storm. When I opened the front door of the house I was greeted by a tree trunk. Part of the roof had been torn off and the side door was blocked by a tree. I was actually imprisoned in my own house with no power, no telephone, no radio. Isolated and powerless. I tried stabbing at the outside darkness with the flashlight through the broken glass windows, but the driving rain made it impossible to see what was going on. Strangely, the best way to see was to turn the flashlight off and wait for an occasional car to pass by (yes, some people were still driving!). This way I could make out the silhouette of the trees from the headlights and see what was still standing. Two 6 foot dia. oaks were not where they used to be anymore. One of them was lying squarely across the Jag. A wave of sickness swept over me. Each passing car produced a flash image of the crushed car until finally I believed it - it was gone. I cannot describe the feeling of knowing that all the hours of work and care to restore every bit of wood and leather rust and bolt and bushing had just been annihilated in 2 seconds. It has nothing to do with the money. I�m sure it�s totalled. The sickest part is that just last week my insurance agent told me that the car had to be 10 years old to get increased insurance coverage. I would have been 10 in January. Any feedback on advice, to keep for parts or not, market values (I�ll have to deal with insurance people) would be much appreciated. By the way, wasn�t someone selling a convertible XJS on this list not too long ago?? I forgot who it was but please contact me. Thanks for listening. Julian Mullaney 1987 XJS Convertible (now with VERY low ride height) From: “Kirbert” palmk@gcn.scri.fsu.edu Date: Fri, 6 Sep 1996 18:51:06 -0005 Subject: Re: XJS Micro switch on throttle Question: will a pushbutton wired in parallel with this switch and controlled somehow by the driver provide part-throttle kickdown? Or does the electric kickdown only work if the transmission is also seeing zero vacuum at the modulator (from WOT)? Of course, this begs the question: Why would you want to do such a thing? You can always just pull the shifter into 2nd. When the kickdown switch on my '85 XJ-S went bad I couldn’t get the transmission out of first gear, regardless of the speed of the car or amount of throttle depression. The failure mode of the switch was that the normal-open contacts never opened. Cool! At least your kickdown solenoid worked. Mine never made any difference at all, you could take the switch out and throw it over your shoulder for all the effect it had. Kirbert | If anything is to be accomplished, | some rules must be broken. | - Palm’s Postulate From: “Kirbert” palmk@gcn.scri.fsu.edu Date: Fri, 6 Sep 1996 18:51:06 -0005 Subject: Re: Hej Matthias, Jeffey gram: strongly I believe the arrangement of the waterpump with too little capacity… Hey, I’m the one with the XJ-S that has absolutely no tendency to overheat. One thing I suppose I should note: One time, while fiddling around with the water pump, I cracked the cast iron impeller. Too cheap and too stubborn to just fork over the $$$ for a new one, I went down to the local junkyard and got one off an OLD Chevy waterpump. The impellers themselves were very similar in size and shape, close enough that the Chevy one would fit. It was a tiny hair smaller in diameter, no more than 1/8" as I recall, which has an effect on centrifugal pumps but I wasn’t gonna sweat it. It also was not quite as deep as the Jaguar pump impeller; IOW, the vanes did not stand as tall, so the openings between them were a little smaller. Again, I was willing to try it anyway. The more startling difference, though, was in the arrangement of the vanes themselves. The original Jaguar impeller had radically backward-sloping vanes, while the Chevy part had nearly radial vanes with only a small amount of backward lean. For those unfamiliar with the nature of centrifugal pumps, I will explain the importance of the vane angle. When you use very backward-sloping vanes, you are looking for high flow but not necessarily a lot of pressure; they will, however, provide good flow at low RPM/low pressure. Going toward more radial vanes means you’re more interested in pressure – which may be necessary to achieve adequate flow. And most centrifugal pumps (not necessarily automotive coolant pumps, I mean centrifugal pumps in general) have FORWARD-sloping vanes, for maximum pressure – but most such pumps operate at a fixed speed and don’t have to worry about low speed/low pressure flow, which suffers somewhat. I have never mentioned this impeller substitute in my booklet, primarily because it was NOT a perfect fit. But seeing as how I seem to be the only one around here who lives in a hot climate and has no overheating problems, maybe there’s a clue here somewhere. The next time somebody has a pump off (or a spare laying around), take it down to the local parts store and compare the impeller with those on the various pumps on the shelf. Tell us if there appear to be any that would be an excellent fit, and if any have vanes that look like those on the Jag impeller. Jag impellers have steeply backward-sloping vanes, and nobody else does. Jaguars have a reputation for overheating, and nobody else does. Connection? Kirbert | If anything is to be accomplished, | some rules must be broken. | - Palm’s Postulate From: “Kirbert” palmk@gcn.scri.fsu.edu Date: Fri, 6 Sep 1996 18:51:05 -0005 Subject: Re: About the mysteries of the XJ series David Tordoff: While we are discussing controls, A/C etc. Can anyone tell me what the purpose is for the small hole on the underside of the top lip of the dash? The hole is about 1/2 inch in diameter and is positioned directly above the glovebox. It is definitely there for some sort of purpose that has continued to elude me. This is the air intake for the air temperature sensor for the A/C control. Rather than just put the sensor out there where it could just sense the air, they hid it and bring the air to it. There is a hose to one of the blowers, arranged so that the airflow blowing through a duct draws air through this opening, past the sensor and through the hose. Classic British overdesign with poor results, the system never seems to hold temp as well as you’d like. Kirbert | If anything is to be accomplished, | some rules must be broken. | - Palm’s Postulate From: “Kirbert” palmk@gcn.scri.fsu.edu Date: Fri, 6 Sep 1996 18:51:06 -0005 Subject: Re: XJS — Oops!!! (a.k.a. Chassis failure) John Napoli: 1) Is there a source for stiffer cage mounts? Or is it a case of using the stock setup or going solid? I have not seen any alternative mounts offered. A shame, too, I bet there’d be a market. But the more common fix is to ADD a support, usually some kind of link from the bottom center area of the cage forward, parallel to the drive shaft, to some bracket attached to the floorpan. Rubber doughnuts on both ends, like an anti-sway bar link. The result is that the cage is held much more securely without stiffening the existing mounts themselves, and there’s probably a lot less stress on some other components as well. I would like to take this opportunity to point out that if one was to go to totally solid mounts, it would be a good idea to toss the trailing arms at the same time. It would probably still work with the trailing arms, but only because of the rubber mounts at the end of them, which will be much more highly stressed than before. In order for the trailing arms to move through their arc, the cage must rock forward and back slightly. If it is rigidly mounted, the rear wheels can only go straight up and down, they cannot move forward with the arc of the trailing arm. So, the rubber joints would have to stretch and the arm is really doing more harm than good, might as well remove it. 2) The XJ-S in question seems to be one of the more powerful ones out there. Is the stock setup just unable to absorb the extra power over an extended time? So to have more power must you forego the other benefits of the stock suspension? It’s my understanding that any effort toward giving the XJ-S a serious hole-shot capability endangers the rear cage mounts. My own car hauls a__, but I don’t push it very often at all, probably have just avoided problems for myself. Again, the standard fix is that link holding the bottom of the cage; I’ll probably rig one for my car one of these days. In the case of the trailing arm forward mounts pulling out, I had asked about rust because I had heard about it being a problem here and sure enough, rust was involved. I can’t say I’ve ever heard of a stress failure at these mounts without a rust condition. 3) If the failure was hastened by rust in the tub, do we all face this problem? Where does the water get in from? How do you check (drill holes in some strategic location)? I have seen E-Type tubs cut open; they get looking pretty bad inside rust-wise. Do our XJ-S’s have the same proclivity? Some quote I heard recently, supposedly from some old-timer at Jaguar upon hearing a speech from somebody about rust protection in hidden sections of the body: “Y’know, if it didn’t show, we never bothered to paint it.” There are guys here more adept at anti-rust practices than I, and one of the discussions has been going on recently. I can only say that, clearly, this particular spot is one where attention is warranted. Kirbert | If anything is to be accomplished, | some rules must be broken. | - Palm’s Postulate End of jag-lovers-digest V2 #337 ******************************** Return-Path: @owner-jag-lovers-di1 Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4) id for jag-lovers-digest-out; Sat, 7 Sep 1996 17:02:37 +0200 (MET DST) Date: Sat, 7 Sep 1996 17:02:37 +0200 (MET DST) Message-Id: 199609071502.RAA25566@ekeberg.sn.no X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f From: @owner-jag-lovers-di1 To: jag-lovers-digest@sn.no Subject: jag-lovers-digest V2 #338 Reply-To: jag-lovers@sn.no Errors-To: @owner-jag-lovers-di1 Precedence: bulk X-Newsgroups: mail.jag-lovers-digest jag-lovers-digest Saturday, 7 September 1996 Volume 02 : Number 338 1975 XJC Water light on XJS Re: Water light on XJS [XK Engines] Rebuild Questions Re: Service Manuals Re: E gen->alt Heat Question Re: [XK Engines] Rebuild Questions Re: E gen->alt Heat Question Re: '61 E Alternator Conversion, 2nd installment (Success!) Re: '61 E Alternator Conversion, 2nd installment (Success!) Re: Water light on XJS RE: About the mysteries of the XJ series RE:Hej Mathias Re: 1985 XJ-S Blown Head Gasket O2 Reset Button on XJ6 Re: Brass vs Stainless–Brake Cylinder sleeve Re: When the student surpasses the teacher JAG - Michigan Concours Re: Brake pedal to the floor Re: RE : Jump start and damages (long) From: Brent Eagling brent@filoli.com Date: Fri, 6 Sep 96 16:36:19 -0700 Subject: 1975 XJC Folks, Another opportunity I have: 1975 XJ12C with 65k original miles. Car is currently not running and the reason is unknown (could be a dead battery for all I know at this point) . The current owner is asking $3,000 USD or best offer. I have yet to see the car but he says it is in perfect shape. It’s been sitting in a garage for a bunch of years now and the guy just wants to get rid of it. The car is located about 2 hours away from me so it will take some effort to check it out. What do you current XJC owners recommend that I do? Brent From: terry_craig@mindlink.bc.ca (terry_craig) Date: Fri, 06 Sep 1996 16:37:13 -0700 Subject: Water light on XJS I hope someone out there will be able to answer my question about the “Water” light on the dash of my 1980 XJS. Even with the rad full, the reservoir full, the left-most lamp on the dash continues to blink. Nowhere in the manual can I find a reference to where this sensor is located and the local Jag shop thought it might be the windshield washer level. Anyone seen this before? thanks! regards, terry, the JagMan terry_craig@mindlink.bc.ca (604) 533-6728 home (604) 533-6729 fax (604) 645-5071 pager From: kew@hutch.com.au Date: Thu, 07 Sep 1995 11:39:34 +1100 Subject: Re: Water light on XJS terry_craig wrote:
“Water” light on the dash of my 1980 XJS.Even with the rad full, the reservoir full, the left-most lamp on the dash
windshield washer level.Anyone seen this before? thanks!
(604) 533-6728 home
(604) 533-6729 fax
Hi Terry,
I have an '85 XJ-S. My low coolant level warning light was coming on. I
was losing water from the cooling system. There is a probe in the
expansion tank that senses when water level is low and lights a warning
light on the dash. There may be a problem with the probe perhaps.
Unfortunately my expansion tank was rusted out and leaking and a
replacement (I found out yesterday) is AUD$300-00. Needless to say it
went to the radiator place for repairs. A second thought is that the
cooling system may not have been bled properly causing airlocks but
these are both guesses are for you to consider. Good luck.
Nathan Campbell
85 XJ-S
Date: Fri, 06 Sep 1996 22:23:33 -0400
Subject: [XK Engines] Rebuild Questions
Greetings All -
My block is now at a machine shop and upon preliminary inspection, the
machinist said “it looks pretty good”.
Questions:
Has anyone rebuilt an XK engine without needing to regrind the
crankshaft
main bearings and crankpins (big ends)? I’m looking for anyone with
data
which says their crankshaft journal measurements were within
specifications
after xxx,000 miles. (My engine has 96,000 miles on it.) -
How many of you out there have replaced the bronze bush which guides
the
oil pump driveshaft/distributor shaft? Are there inside diameter
specifications
for this component? -
How can I definitively tell what compression ratio my engine is? On
page 05-2
of my Series III Service Manual it says I should have 120psi -
135psi compression
pressure. I have a U.S. emissions, late 1982 vehicle. What
compression ratio
pistons do I have?
Thanks as usual for any and all replies.
B.J. Kroppe - '82 XJ6
Date: Fri, 06 Sep 1996 22:46:46 -0500
Subject: Re: Service Manuals
Michael Powers/TEIR/Thomson wrote:
Hello there:
that contain wiring diagrams?My local Jag dealer wants $185 for the complete set of manuals. Not a bad
get used very often.Thanks for the help,
Mike
| mpowers@teir.com
| (703) 736-1832
| -Jerry Seinfeld
I have had the updated 88 XJ6 (XJ40) factory manual. It is quite good.
Five volumns cover all aspects. When I received mine, I got two sets
of many pages. The changes were typically minor. I consider the
presentation redundant. Also, I would like to see more explanation of
function to help in diagnosis.
Bob Johnson
Brattleboro, Vt.
XJ40, XJ50
Date: Fri, 6 Sep 1996 23:17:00 -0500
For those of you who have converted from generator to alternator,
1) What have you done to control heat to the alternator?
2) How reliable is your charging system?
Thanks!
Hunt
I had my 64 E-Type converted nearly 20 years ago. I have had no heat
problems;the alternator is further from the manifolds than was the
generator. I get very reliable charges. I can see the full charge being
applied when I first start a run and very soon it will indicate a full
charge. It is important to have a top-of-the-line battery to insure good
starting in the middle of a cold spell. I recommend at least an 850-rated
battery.
Date: Fri, 6 Sep 1996 21:33:36 -0700 (PDT)
Subject: Re: [XK Engines] Rebuild Questions
The size of the dome on the piston is the clue. On my E, I determined that I
have 8:1 pistons (but due to machining, am back nearer 9:1). There are
pictures of both in my factory service manual, which made it easy.
Hunt
At 10:23 PM 9/6/96 -0400, Kroppe wrote:
Greetings All -
machinist said “it looks pretty good”.Questions:
crankshaft
data
specifications
after xxx,000 miles. (My engine has 96,000 miles on it.)How many of you out there have replaced the bronze bush which guides
the
specifications
for this component?How can I definitively tell what compression ratio my engine is? On
page 05-2
135psi compression
compression ratio
pistons do I have?Thanks as usual for any and all replies.
Date: Fri, 6 Sep 1996 21:33:34 -0700 (PDT)
Subject: Re: E gen->alt Heat Question
Bob-
Thanks! I have the same smooth charging performance. Heat and electronics
(unless contained in evacuated glass bottles), just don’t feel right, given
my professional background!
Hunt
Thanks!
Hunt
battery.
Date: Fri, 6 Sep 1996 21:33:31 -0700 (PDT)
Subject: Re: '61 E Alternator Conversion, 2nd installment (Success!)
At 01:45 PM 9/6/96 -0005, Kirbert wrote:
1) Alt is a little farther from the exhaust system (psychological,
I’m sure)
Sounds good to me. I saw a wonderful little mod at the Monterey Historics,
by a fellow named Malcom Adams. He had fabricated a stainess shield,
louvered as the bonnet is, which mounted about 1" below the louvers, to
prevent damage to the bonnet paint. Worked great and looked right, too. This
is also on my list of things to do.
My next suprise was the belt. the 3.8 MK II belt is too long, the 3.8 E belt
is just right…I keep hearing owners of older Jags talk this way. Why would anyone
Jaguar belts?
Yes, there is. They’re more like “W” belts (notice the reference to grooved
pulleys in the catalogs). They are wider, flatter, and have a groove in the
middle for a ridge which is formed in the pulley. They are non-standard
(believe me, I checked Grainger’s!) So, the choice are the four standard Jag
belts: 2.4L or 3.8L Mk II, 3.8 or 4.2L E.
| - Palm’s Postulate
Date: Sat, 7 Sep 1996 02:15:26 -0005
Hunt Dabney hdabney@earthlink.net:
…is there something really unique about early
Jaguar belts?Yes, there is. They’re more like “W” belts (notice the reference to grooved
Considering what belts look like today, it appears once again that
Jaguar was decades ahead of its time!
Now all you guys need is a set of pulleys to convert those cars to
modern serpentine belts!
| - Palm’s Postulate
Terry Craig:
The leftmost indicator on the bottom row of the dash is the coolant
level warning light. The sensor on my '83 is on the front left edge
of the radiator, a few inches down from the top, where it’s REALLY
hard to see unless you have the hood removed! I understand it was
later moved to the header tank.
This sensor is really just a terminal in the coolant, measuring the
conductivity of the coolant itself. Therefore, there is a box
somewhere that takes this reading and decides if there is coolant in
there or air, and operates the warning light. You problem might be
in the box rather than the sensor, although I suppose if the sensor
itself is covered with crud it might give a false low coolant
indication.
Sorry, I dunno where the box is.
| - Palm’s Postulate
Date: Sat, 07 Sep 96 09:06:54 -0700
Subject: RE: About the mysteries of the XJ series
David,
You are going to hate this, that little hole you talk about is the in-car
sensor for the air-con. Your guess is correct about the blanking plug.
I think you are going to like jag ownership because they fit loads of
“obvious” things that elude just about everyone, at first.
Barrie Dawson
Chatham, Kent England
1985 series III Jaguar Sovereign
Date: Sat, 07 Sep 96 09:21:05 -0700
Subject: RE:Hej Mathias
This radiator thing for series 3’s is a drag and there have been many good
suggestions but I think the point has been missed. From about 1985 Jaguar
had modified the cooling system such that there is only need for auxillary
cooling in extreme cases. Maybe older model owners having overheating
problems should look toward the later model for fixes.
I think the main changes were a slightly larger radiator, larger capacity header
expansion tank, higher pressure cap rating (15 lbs), low temperature thermostat. In
the hotter climates I belive these cars are fitted with 2 electric fans which come
on at around 85 C - 90 C measured at the lower quarter of the radiator core.
Barrie Dawson
Date: Sat, 7 Sep 1996 08:07:12 -0400 (EDT)
Subject: Re: 1985 XJ-S Blown Head Gasket
My opinion is yes it is worth it and yes it is a fairly difficult job.
If you don’t feel comfortable working on it yourself it would still
probably be worth it to pay for the head gasket job although the job
requires very careful attention to detail and I must admit I’d have
difficulty with trusting it to anyone but a known and trusted Jag
mechanic. Actually I’ve never known anyone I’d trust with this job
although I knoe there are some good ones out there. One good thing is
that you can do it without releasing the A/C freon. Besides the obvious
things like removal of A/C compressor (right head only), fan, cooling
hoses, exhaust manifolds, etc. you have to deal with removal and resetting
of the camshaft, which in turn requires reshimming the valves. Camshaft
removal requires releasing the timing chain tension with “special tools”
which many of us have improvised. The hazard of this step is that the
chain tensioner is usually brittle and often breaks. At this point
substantial additional work is required to replace the tensioner and
extract its broken pieces as it is behind the timing case cover. Kirby’s
book talks about this.
Good luck,
Thomas E. Alberts
Date: Sat, 7 Sep 1996 07:47:05 +0000
Subject: O2 Reset Button on XJ6
I am putting the finishing touches on the XJ6 book and need some
information from anyone that knows.
On the US series 3 there is an O2 sensor in the exhaust system. The
reset for one model is in the trunk and there is another under the
hood. Can someone describe this reset unit location and operation?
The Haynes manual only says that you have to go to the dealer to get
it done. I know that is only because they wont tell you how.
On the later model series 3 the reset is in the trunk and I am told you stick a allen wrench in a hole to reset it though I have never done it myself. Anyone have the answer? From: jwbeckmeye@orion.branch-co.lib.mi.us Date: Sat, 07 Sep 1996 10:02:38 -0400 Subject: Re: Brass vs Stainless–Brake Cylinder sleeve At 08:06 PM 9/6/96 -0400, Rrrroxxo@aol.com wrote:
Thanks for asking who did the other sleeves, and how satisfied were you with
White Post as far as service, quality and price. Thanks SS
I’m very satisfied with the work White Post did. The cylinders came back
all rebuilt, re sleeved and powder coated…really look nice…and work well.
FYI, White Post said that the warranty would be voided if I used DOT 5 so
that’s why I went w/ DOT 4. However, this winter the MK II will be off the
road and the jury is still out on how well the new brakes will be working
next spring after sitting all winter.
BTW, the turnaround time at White Post was about a week!
Best regards,
Jim Beckmeyer
Union City, MI
90 Jaguar Sovereign
60 Jag MK II
Date: Sat, 7 Sep 1996 10:04:57 -0400
Yes, Jaguar North American marketing has their headquarters in Mahwah,
New Jersey, USA.
Only marketing people throw around trinkets like that! I rave all the time
about how good my SIII XJ6 to my bosses (some of them Jaguar employees)
and I just get warm smiles and pats on the back! (I don’t mind, tho!)
Date: Sat, 7 Sep 1996 10:12:28 -0400
Subject: JAG - Michigan Concours
The Jaguar Affiliates Group of Michigan will be holding its 29th
annual Concours d’ Elegance on Saturday September 14, 1996 at the
Hyatt Regency - Dearborn (Across from the Ford Motor Company
World Headquarters). For more information, please contact:
Marilyn Marcrum Concours d’ Elegance Chairperson
P.O. Box 530432
Livonia, Mi. 48153-0432
Telephone: (313) 427-1043
Robert J. Reid
65 E Type FHC
Date: 07 Sep 96 10:55:42 EDT
Subject: Re: Brake pedal to the floor
Hi Dave,
Interesting theory you have on the behaviour of partly rusted / uneven surfaced
Master cylinder, posted
on 28/8-96
I cant jugde, since its been a while I fiddled with them, but do continue the
searh for the culprit.
Consider this : If the pedal goes to the floor or “sinks” with slow or low
pressure applied, scouring
past the pitted wall, when do you think it will be worn out). You may not be
able to tell us when it
happen going ari\ound thar right bend with screeching TR6 tyres … and the
pedal goes :
+plop+
I would not trust my life on a pitted master brake cylinder wall. Surely a
stainless relined in UK does not cost 200 US dollars ?
Classic Spares in UK tel +44 (0)1992 716236 / fax - 788424, sell Stainless lined
Dunlop brake cylinder
parts starting at 43 Pounds for a MK II, They also have stainless pistons…
I love to look at Jags as well, Somehow the older Series 2 XJ’s look more
“jaguar” than the newer Series 3
Regards Jeffrey Gram
Date: 07 Sep 96 10:55:39 EDT
Subject: Re: RE : Jump start and damages (long)
Hi list
I fell over the note from Russ Lehman from 28/8/96 13:34 CET on this issue. A
few corrections and more comments :
On the jump start issue… If I were to jump anothers car, my engine running to send in my alternator charge current into the other’s dead battery, this is no problem. BUT if he (jumpee) then starts his car, his charging system would compete with my charge system and damage my electrical system. Russ , there is no problem here. When jump starting the idea is to fill the jumpee’s battery. By letting the donor car run a little while say 5 to tem minutes, the chance of succesful start is greater. When the receiving car cranks, the power comes from 1) the donor car battery (most) and 2) from the donor car alternator. The split is according to the balance that Ohm’s law prescribes. When the receiving car starts and runs the alternator produces energy and charges the receiving cars battery (to a great extend) and only if the receiving cars alternator voltage is higher than the donor car’s alternator, will a small current flow from the “receiving” car. It is however unlikely, but quite posssible that the receiving cars alternator is able to sustain both charging the dead battery, and still have enough “residual” voltage superiority left to also "charge the donor car. Importantly however , the donor car and the receiving car does not suffer any electrical damage from this (or at least should not). What is very important when jumpstarting (apart from getting the polarity right), is to ensure you have BEEFY cables. It is completely un-understandable, how many useless jump start cables are sold. A car jump start cable should be about 16 square millimeters of crosssection cobber. The handles should be of a powerful “beek” preferably with the cable connecting to both sides of the “teeth”. If a Jump start cable is too wimpy it will : 1) cause a SIGNIFICANT voltage drop and the donor car does only turn slowly or not at all. 2) the cable will melt its insulation, start smoking and whats the use oif that ? I don’t think you can harm the car with the dead battery, because his alternator will send out gobs more current into his dead battery and thus into my system, not the ============= ==== Well , not “thus”, but possible as described above. other way around (unless of course, I’m wrong). A related alternator question: If my engine is running and I disconnect my battery, will: the engine stop, no damage My alternator diodes fry massive electrical damage First : if the alternator is “bad” the engine may stop. Possibly no damage. Some cars will suffer damage (to electrical systems and the alternator) if the battery is taken out while the engine is running. I once had to do this to get the V12 started (left the ligth on for 6 hours - wimpy battery…) I borrowed another mans battery (had no jump cables), undid my battery, and dropped the donor battery in. - started the Jag, turned lights on (to create a load for the alternator and then with 2 helpers :. one held the battery cables firmly attached to the donor battery (by hand) . then on command he disconnects these , and second helper pulls out the donor battery, and I put the original flat battery back in, and first helper connects battery cable terminals immediately. Operation is less than 5 seconds. Now - if the car would be of a kind that would suffer electrical damage when taking the battery out of a running engine, even 5 seconds only could be a killer - so do this at your own risk. The jag manual tells you not to do this, however being an electronics engineer (about 12 years ago), I reasoned that the headlight on will sink enough energy to let the alternator “think” the battery was still in. The alternative for me was to walk home or at least a trouble some way and expoensive way to get professional help. My alternator diodes fry Diodes fry when they are overloaded. By rule this should not be possible, since it would require the alternator to deliver more Amperes than the diodes can handle - which would be a really bad design… Diodes die the overvoltage death mostly, or simply age and then die (tough environment). Massive electrical damage Depends on the car. However note that power charge from a powerful external charger can cause electrical damage to electronics by overvoltage . Batteries should generally not be charged by an Ampere rating above about 10% ot the Ampere hour rating (rule of thump), refer to battery manual or the specifications. For the same reason most cars specify to disconnect the battery leads before welding (to protect the alternator diodes). Many regulators control the field winding to the alternator, won’t the regulator see the high voltage and shut the feed to the alternator off? …all regulators control the field winding, and answer is : In principle Yes, but lets be precise, there is much more to this seeminly “simple” example. : If The donor car alternator regulator “sees” the (marginally higher) voltage from the receiving and started cars alternator, the donor car regulator “thinks” its own battery is fully charged, and regulates the current accordingly lower. However the donor regulator does not see the voltage of the receiving cars regulator voltage. There is namely all the wiring from donor alternator to donor battery and from here through the jumper cables to receiver battery etc. When these wires carry current there is a voltage drop along them. The donor car produces a certain current to its own battery which has just been “partly” surged when the receiving car was cranking. The donor car then charges its battery according to the voltage seen. This causes a voltage drop along the line from donor alternator to donor battery. When the total voltage seen from donor battery + drop along donor regulator (alternator)/donor battery line is less than the voltage regulator setting (13.9 - 14.2 Volts) then the donor alternator will continue to produce the current that satisfies the equation of Ohms law. So if the receiving cars regulator is set to 14.2 volts and the donor car regulatore is set to 13.9, the likely scenario is that the donor car charges its own battery, the receiving car charges its own battery, and a small current might flow from receiving vehicle to the donor vehicle. The Beefier the jump cables the more current will flow but still small and insignificant. If the receiving cars regulator is set to 13.9 and the donor vehicle is set to 14.2 , basically the same scenario take place, however the small current flow from donor to receiver vehicle. Boaters with two batteries have problems if they OOPS! switch batteries when the engine is running. I’m not a boater, so I dont know what “special” system they may have. But basically Ohm’s law is the same in boats. The reason why damages may occur is that the alternator and regulator circuit may be so (stupidly) engineered that the voltage rises on seeing a no-load or open-circuit. The voltage rises then with lightning speed (microseconds) and this may kill the alternator diodes. Such switches (with such sensitive circuits) should be of contact before break type to ensure a continious load during the flick over of the switch There could be more to this topic. Please Join in. Should I have made errors or incorrect assumptions, I pardon, but please respond. I intend to shape this into a FAQ entry. Regards Jeffrey Gram End of jag-lovers-digest V2 #338 ******************************** Return-Path: @owner-jag-lovers-di1 Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4) id for jag-lovers-digest-out; Sun, 8 Sep 1996 15:01:02 +0200 (MET DST) Date: Sun, 8 Sep 1996 15:01:02 +0200 (MET DST) Message-Id: 199609081301.PAA05980@ekeberg.sn.no X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f From: @owner-jag-lovers-di1 To: jag-lovers-digest@sn.no Subject: jag-lovers-digest V2 #339 Reply-To: jag-lovers@sn.no Errors-To: @owner-jag-lovers-di1 Precedence: bulk X-Newsgroups: mail.jag-lovers-digest jag-lovers-digest Sunday, 8 September 1996 Volume 02 : Number 339 Re: '61 E Alternator Conversion, 2nd installment (Success!) Re: O2 Reset Button on XJ6 Re: [XK Engines] Rebuild Questions E-Type Stainless Sleeve Pricing Re: Hurricane Fran - XJS lowrider (R.I.P.) Re: 1985 XJ-S Blown Head Gasket back in the fold Oil additives Jaguar XK140 Can You Help 87 XJ6-III for sale/new photos! Re: E-Type window winders XJ40: How does your A/C operate? Exhaust Heat Shield Re: Where to locate fan relay Re:E-Type engine removal RE:Jump start and damages (long) RE: Oil additives Subject: RE: XJ40:How does your A/C operate Re: Water light on XJS From: Hunt Dabney hdabney@earthlink.net Date: Sat, 7 Sep 1996 08:14:25 -0700 (PDT) Subject: Re: '61 E Alternator Conversion, 2nd installment (Success!) Jeez Kirby- Then we could have “Belt Lump” discussions - probably use up all the available internet bandwith. Sure would be nice to be able to get any length, though! Hunt At 02:15 AM 9/7/96 -0005, Kirbert wrote:
Hunt Dabney hdabney@earthlink.net:…is there something really unique about early
belts: 2.4L or 3.8L Mk II, 3.8 or 4.2L E.Considering what belts look like today, it appears once again that
Jaguar was decades ahead of its time!Now all you guys need is a set of pulleys to convert those cars to
modern serpentine belts!– Kirbert | If anything is to be accomplished,
| - Palm’s Postulate
Date: Sat, 7 Sep 1996 08:18:06 -0700 (PDT)
Subject: Re: O2 Reset Button on XJ6
Jim-
Pull the access panel from the back of the trunk (oops - boot), and (far) to
the left of the ECU there is a device that looks like it has a motor under
the cover (there is a cylindrical moulding protruding from the case).
Somewhere on this is a little white button that you push. I need to do it
this weekend, and have done it before, so I will post better detail after I
do it.
Hunt
information from anyone that knows.On the US series 3 there is an O2 sensor in the exhaust system. The
hood. Can someone describe this reset unit location and operation?The Haynes manual only says that you have to go to the dealer to get
it done. I know that is only because they wont tell you how.On the later model series 3 the reset is in the trunk and I am told
done it myself.Anyone have the answer?
Date: Sat, 7 Sep 1996 09:14:26 +0700
Date: Sat, 7 Sep 1996 09:10:33 +0700
Though I haven’t rebuilt an XK engine (yet), I have rebuilt
others. I read in a service manual (Haynes, I think :-\ ) that you can just replace
the XK bearing shells after 120,000 miles. However, as far as your
crank goes, it doesn’t matter what anyone else has found on their engine
rebuilds or what the manual says. It all boils down to the condition of
your crank’s journals. If your machinist has mic’d your journals and found them
still within initial specs (see below), free of scoring and pits, no taper or
out-of-roundness on any rod or main journal, then you may get by
without regrinding the crank. On an engine which has been well-cared
for, this is possible. On an engine which has been abused or
neglected, it’s unlikely.
In my SIII service manual, the specs for the crank are as follows:
3.4l engine:
Mains 2.7502 - 2.7497 in (69.855 - 69.842mm)
Rods 2.0861 - 2.0865 in (52.987 - 52.974mm)
(maximum regrind is -.020in (-0.51mm)
4.2l engine:
Mains 2.7500 - 2.7505 in (69.85 - 69.86mm)
Rods 2.0860 - 2.0866 in (52.984 - 53.00mm)
Racers will usually not undercut their cranks, but instead have the
journals built up with welding rod, then recut to the original
manufacturing specs. Street engines (including street rods) can
usually tolerate a .010 - .020 undercut. If you have the journals built up
then recut to the original specs, then be sure that the machinist
rebalances the crank. Balancing the entire reciprocating assembly is
something I do routinely and doesn’t add much to the entire machine
job (~120USD).
It is usually understood, but I’ll repeat it anyway, but find the
best machinist you can. ( I have to travel 75 miles to get to a good
one). Shops that continually upgrade their
equipment and spend a substantial portion of their time doing machine
work for race cars are a good place to start.
Good luck and let us know what you find and how it turns out.
Greg Price
recently purchased '85 VdP
(just beginning to look and behave as it should :-> )
G. W. Price & Company, Ltd
Santa Fe, New Mexico
Probabilistic Record Linkage Services
Consultants in research, information management
and program evaluation
Date: Sat, 7 Sep 1996 11:29:13 -0500
Subject: E-Type Stainless Sleeve Pricing
Thanks to Meritt Smith, I got a much better price for resleeving a brake
master cylinder in stainless steel from Imperial Machine in Lincoln,
Nebraska, than I did from Stainless Steel Corp. in New York. Imperial
charges $60 plus shipping cost and normally takes two weeks to do the job.
Stainless wants $175 with a four-week wait period. Merrit said Imperial did
a first-class job for him. Anyone else on the list who has experience with
Imperial?
I only got a quote for E-Type resleeving. Imperial’s phone number is:
1-402-488-9450
The mailing address is:
Imperial Machine Co.
621 S. 112th St.
Lincoln, NE 68520
Credit cards not accepted. You must enclose a check with the master cylinder
including shipping cost. In my case (Ohio) I was told $5 would cover a UPS
return shipment. Thus, my total cost will be $65 to have the master
cylinder sleeved in stainless steel.
Date: Sat, 7 Sep 1996 12:22:42 -0700 (PDT)
Subject: Re: Hurricane Fran - XJS lowrider (R.I.P.)
Julian,
My condonlances. Having lost two British sports cars earlier this
year in the house fire, I konw the feeling of helplessness.
Greg
Greg Meboe meboe@mont-blanc.scs.wsu.edu
Web site>> http://www.scs.wsu.edu/~meboe
Mechanical Engineer Boeing Payloads Division
'85 XJ-12 H.E. (daily) '67 Spit-6 '74 TR-6
Date: Sat, 7 Sep 1996 17:43:36 -0005
Thomas E. Alberts:
Besides the obvious things like removal of A/C compressor (right
head only), fan, cooling hoses, exhaust manifolds, etc. you have to
deal with removal and resetting of the camshaft, which in turn
I think we’re talking about a head gasket replacement here. In that
case, the above is not true. The head can be unbolted, removed, the
gasket replaced, and the whole thing reassembled without ever taking
the camshaft off of the head or fiddling with the valve shims.
It’s not like any of us would actually try this, since once we’re in
there we’d be adjusting the valve clearances anyway. However, the
last time I was there, the valve clearances were ALL WITHIN
TOLERANCE, so I left them alone!
| - Palm’s Postulate
Date: Sat, 7 Sep 1996 13:34:31 ±900
Subject: back in the fold
greetings from Beijing, China. I’m back and it feels good. Missed all =
the clatter…have only seen two jags here in a month. Capitalism is =
here, but not quite. Did see one guy in an xj40 with a phone stuck to =
his head, so there is hope. The cars around here are a mess. Some of =
the taxis are a loose group of parts all going down the road in the same =
direction. Rode in one that had a worn out horn…We have a car and =
driver. He has a chinese made Audi. Like an old 5000 with a 4 cyl vw =
motor and 5 speed. No British cars on the street, but many new Audi, =
Beemers and Mercs. Yep the BMW’s have their fog lights on. Love it and =
it is an adventure every day. Bottled water is 4 RMB and beer is 2 =
RMB…hmmmmm. 8 RMB to the USD. There are no phone books, no Yellow =
pages, and no checks. I’m coming at you at 26. something so things are =
getting better. Give me a buzz off line…anyone. See Ya…
Date: Sat, 07 Sep 1996 19:45:06 -0500
Subject: Oil additives
I wonder if there are any opinions out there about certain oil
additives. I have two in mind, one being the one that is supposedly for
“older” engines, purporting to increase compression by filling in the
wear and scratches on the moving parts; the other being the one that
claims to suppress leaks by sealing leaky gaskets. Do they do what they
claim, and does their use pose any risk of damage to the engine?
Steve Coleman, Gadsden, Alabama
1987 XJ6 x2
1989 XJ40
Date: Sat, 7 Sep 1996 21:23:33 -0400 (EDT)
Subject: Jaguar XK140 Can You Help
I have an early (1955) Jaguar XK 140 Roadster and I am experiencing some
difficulty identifying what model engine it has in it.
Facts making me believe it is a “C” type head are the engine and Chassis
numbers are prefixed with a “S”.Also the car has duel exhausts from the
manefold to tail pipes passing through cross member in chassis.
Facts that indicate I might not have a “C” type head are no badges on cam
covers and no “C” cast into head. Books on Jaguars have mentioned the fact
that early cars did not come with cam cover badges, but I have not heard of
heads not having “C” cast in them. I do not want to strip head to measure
valve size and would appreciate any comments or help in determining what
head I have and what color it should be painted.
Date: Sat, 07 Sep 1996 22:05:22 +0000
Subject: 87 XJ6-III for sale/new photos!
Many thanks to those of you who stopped by my web page at:
http://www.cyberenet.net/~atlantic
The xj6 is still looking for a good home. Price has been reduced to
$8300. I’ve added a few more pictures to the web page - check 'em out!
Thanks,
Dave
From: “Barry Cooper” b.w.cooper@acslink.aone.net.au
Date: Sun, 8 Sep 1996 12:03:06 +1000
Subject: Re: E-Type window winders
Anyone know whether the Series 2 E-Type window winder mechamism is used on
any other Jaguar model or British car? My Series 1 1/2 E has odd winders
with a Series 2 winder on one door and a Series 1 winder on the other
fitted by a PO. I have established that the Series 2 is correct for my car
and the change
to the mechanism is obvious after dismantling. The Series 2 type has a
square
section shaft with a thin hexagon clamped to the end to provide the
drive for the winder handle. The handle is secured by a screw into the end
of the square section shaft. One of the XJ models has a similar appearance
but does not have the hex drive. Would make it easier to fix if I could
obtain the shaft and hexagon but it would be possible for a machine shop to
modify the existing one. Very few notice the mismatch but I do, so I want
to fix it while all
is apart.
Thanks
Barry Cooper
Date: Sat, 7 Sep 1996 19:02:26 -0700
Subject: XJ40: How does your A/C operate?
Hi again!,
I don’t have the owners manual and would like to know how the A/C
works in the cars of other XJ40 owners.
What vents get cold/warm air and how is the AUTO mode supposed to
work? My AUTO mode turns opens & closes the center vents when the car
is cold (air is then sent to footwells). Just wondering if the system
is operating like it should (according to the owners manual). Also the
‘FACE’ control varies the center vent temperature slighlty. I assume
this works like it should.
Would be grateful if someone would be kind enough to share how
their Jag’s A/C works (technichal or non-technical).
Thanks!
-Eric
cobac@ix.netcom.com
P.S. I’d like to thank Randy Wilson for his help about the “blower
speed controller”, but I’m unable to send mail to his E-Mail address.
Thanks for all the help! I was able to fix this part, now the A/C
works great in all Fan speeds. Thanks again!
Date: Sat, 07 Sep 1996 22:43:28 -0400
Subject: Exhaust Heat Shield
On Fri, 6 Sep 1996 Hunt Dabney wrote;
< I saw a wonderful little mod at the Monterey Historics, by a fellow named
Malcom Adams.
< He had fabricated a stainess shield, louvered as the bonnet is, which
<the louvers, to prevent damage to the bonnet paint. Worked great and looked
right, too. This
<is also on my list of things to do.
I have had similar problems with the bonnet paint blistering above the
exhaust manifolds of my '67 E-Type. I purchased a used manifold heat
shield taken from a SIII, XJ6 (from Welsh Jaguar). The fit was perfect
of course as the manifolds are basically the same for all years of the 4.2L
engine. Only some minor creativity was required for making a mounting
bracket. The shield now protects the bonnet paint and reduces the heat on
the alternator and it’s associated wiring. This fix looks very good but my
not be satifactory for Concours condition cars. The porcelain finish, on my
exhaust manifolds,were so cracked that a cover up was a major improvement.
Date: Sun, 8 Sep 1996 12:51:49 +1000 (EST)
Subject: Re: Where to locate fan relay
Summer is still around, and the AC in my 89 JX40 stops working. Some day
if I’m lucky it works, and the rest of the week I’m sweat. Where is the
relay for the AC fan located?Another possible cause is a bad microswitch in the A/C control assembly.
This is apparently quite common. The microswitch is located at the top of
the switch assembly in the console. Micheal Neal put me on to this and told
me how to get at the switch assembly. If you need instructions - let me know.
Dave:
I would also be very interested in these instructions. In fact, I think
that anyone with an XJ40 of about 1989 vintage would also be. Could you
please oblige. Many thanks. Alan.
Date: Sun, 8 Sep 1996 16:18:40 +1000
Subject: Re:E-Type engine removal
My Haynes E-Type manual (1987 edition) has a supplementary chapter devoted
to engine removal from below.
Barry Cooper
1968 E-Type FHC
Date: Fri, 06 Sep 1996 09:13:55 -0500
Subject: Series II E-type Engine RemovalI understand that the best way to pull the engine from a Series II E-type
OTS is from the bottom. Is there any documentation available on the web
that covers this method?Thanks,
jvr
Date: Sun, 08 Sep 96 10:47:44 -0700
Subject: RE:Jump start and damages (long)
Just a short offering on the subject but one I have found extremely useful.
When I first came across a non-starter, battery failed, with an alternator
I was concerned that I may cause damage jumping. I had read somewhere that
jump starting these vehicles could result in alternator damage once the dead
one had started.
Since then I have followed a simple but extremely safe procedure.
- Connect donor to receiver using heavy guage cables.
- Allow donor to run for about 5 minutes to build up a basic charge in receiver.
- Where there are 2 people doing this 1 needs to be ready to remove cables
as soon as then receiver starts, allowing own alternator to charge 1 battery, the
receiver alternator WILL try and charge donor. - NEVER allow the receiver to be on the starter for more than 5 seconds. This
WILL bring the donor cars charging system into full swing and may not produce
sufficient charge to start the receiver. - Once started run at about 1500 RPM for no less than 10 minutes.
- Finally find out what caused the problem and FIX IT.
Jeffrey Cram, in his offering has given a detailed account which I support and
in my 24 years in the communications business have applied in smaller systems.
He is quite right refering to stupidly engineered systems but then thats the
motor industry for you.
Barrie Dawson
Date: Sun, 08 Sep 96 11:05:45 -0700
Subject: RE: Oil additives
There is no amount of oil additive that will satisfactorily “fill in wear” on
an older engine, for that matter any engine. once the wear has reached the
state where something needs to be done only replacing the defective part will
do. There is only one way to keep moving metal against metal parts in good
condition and that is regular oil/filter changes FROM NEW.
Regarding leaks from gaskets, anything introduced into the engine to seal leaks
WILL cause a blockage somewhere else and that WILL cause damage to the engine.
The best way to cure leaks is to remove the old gasket and thoroughly clean the
mating surfaces, then replace with a new gasket and sealing compound. Where
this does not cure the leak the mating surfaces need to be checked for flatness
and the necessary repair should be carried out. When the leak is from a bearing/
seal these should be replaced as soon as possible.
In answer to the question “do they do what they claim”, briefly, but ulimately at
the expense of the engine for the reasons I point out above.
My own car has had regular oil/filter changes in its 76300 miles and there are no
obvious signs of mechanical wear, no smoke/knocks or rattles. As for leaks, well
it is a Jaguar so what do you expect, I have had a couple and these have been due
to joints having worked loose over the years, easily fixed with a screwdriver or
spanner. On the subject of leaks the previous owner had used a sealing compound
in the cooling system and that cost me #500.00 to fix.
Conclusion: Repair or replace don’t cover up you’ll pay in the end.
Barrie Dawson
Date: Sun, 08 Sep 96 11:46:00 GMT
Subject: Subject: RE: XJ40:How does your A/C operate
The Jaguar A/C is complicated and unlike any other system I have come
across.
Apparently if you can hear clicks, wheezes and whirring form behind the dash
and you get hot or chilled air when required the system is working. I have
noticed on my series III that the air flow changes are so subtle that they
are hardly noticed except in extreme circumstances, e.g. high fan speeds.
With regard the centre vents I believe only chilled air is directed through
them.
The face control I believe allows for fine tuning of the chilled air so as
not
to
cause discomfort from an icy blast.
I don’t think there is a great difference between XJ6 and XJ40 but there
will
be
slight changes I’m sure.
Barrie Dawson
------------------------------ End of forwarded message 1
From: “Richard.Mansell” Richard.Mansell@psemail.ps.net
Date: Sun, 8 Sep 1996 12:52:00 +0100
The low coolant sensor control unit is behind the passenger scuttle.
On the pre-HE it is square in shape and appears to be bolted to the
fan motor. On the HE it is a cylindrical in shape and is attached to
the 'B' component panel. The manual says that if the white and red
lead from the sensor unit are disconnected the warning lamp should
flash.
I guess if the sensor is ok check continuety of these two wires.
Hope this helps.
Richard
______________________________ Forward Header
Author: /S=owner-jag-lovers@sn.no/O=SMTP/P=PSC/A=MCI/C=US/ at ccx400uk
Date: 07/09/96 03:10
Terry Craig:
indication.
| - Palm’s Postulate
End of jag-lovers-digest V2 #339
id for jag-lovers-digest-out; Mon, 9 Sep 1996 04:22:07 +0200 (MET DST)
Date: Mon, 9 Sep 1996 04:22:07 +0200 (MET DST)
Message-Id: 199609090222.EAA00800@ekeberg.sn.no
Subject: jag-lovers-digest V2 #340
Precedence: bulk
Status: O
X-Status:
jag-lovers-digest Monday, 9 September 1996 Volume 02 : Number 340
Re XJ-S workshop manuals
Re: Looking for XK120/140
Oil aditives
Radiator removal XJS
Re: Radiator removal XJS
Re: Back in the fold
Jaguar XK-120 for sale (CT, USA) (fwd)
Jag Cooling
Re: XJ40: How does your A/C operate?
could use advice regarding tire brands for 85 XJ-S
420G/General questions
Re: Security problem
Re: XJS wiring help needed
RE: XJS Micro switch on throttle
Date: Sun, 8 Sep 1996 13:15:00 +0100
Subject: Re XJ-S workshop manuals
------ =_0_MIME_Boundary_1845.3232c2e2.imsukk50.eurh021.eur.ps.net
---------------------------- Forwarded with Changes
Date: 9/3/96 9:00PM
To: Richard Mansell at Not-Cop5
Subject: Re[3]: XJS Wiring Help Needed/workshop manuals
Content-Type: text/plain; charset=iso-8859-1
Content-Transfer-Encoding: quoted-printableMike
I am not ignoring you=2c my reply to you appears to have bounced =
therefore I am replying via the list=2e
I guess you have got to go for the earlier 4 volume set=2e I received =
my =88 onwards manuals yesterday but they really are geared towards the =
facelift model=2e =
I was interested in the later manuals because they contain the info =
for the Mirelli ignition which I assume you do not have because it was=
=introduced in '89=2e
Now that I have the manuals in my hot little hands it appears to be =
more complicated than I thought=2e
The pre-HE to 87=2f88 manuals =28JJM 10 04 06=29 appear to be based ar=
ound =the pre-HE with extra sections to cover the differences between these =
=and the HE =28pretty logical so far=29
The new manuals=2c up to 91=2c =28JJM 10 04 06=2f20=29 come in 5 volum=
es rather =than the earlier 4 but only appear to cover the additions since the =
earlier manuals for the 5=2e3 plus a random selection of the original =
=information=2e Oh and it covers the 4=2e0 engine too=2e =
In otherwords if you have an '89 to '91 5=2e3 and you want to know abo=
ut =the new ignition etc you will need both sets as the later volume set =
refer to many sections that only exist in the earlier set e=2eg=2e Und=
er =the heading Cylinder heads overhaul it says=3a- =
Remove left and right hand cylinder heads=2c see 12=2e29=2e01=2e =
Where is 12=2e29=2e01=3f only in the earlier set=21
Since the five volume set costs =a33 more than the earlier one =28=a31=
05=29 I =assumed it would be a complete guide to the later cars=2e Wrong=21
I understand that there are add-ons =28approx=2e =a325 each=29 =
JJM 10 04 06=2f201 and 202 that cover models '92 to '96=2e 6=2e0L engi=
ne =plus other changes=2e
For the earlier cars =28up to '84=29 the 1 volume Repair Operation Man=
ual =is available either hard bound or soft bound=2e This is a lot cheaper =
=but more condensed and although not so well laid out it does contain =
most information needed=2e
Then of course there is the Haynes Manual=2c people do joke about thes=
e =but they do give useful timesaving tips=2e They are also less expensiv=
e =to replace when they are soaked in oil=21
The other reading material I bought this week was the Jan '87 to late =
='89 parts book =28RTC9900CA =a319=2e99=29 IMHO this is laid out a lot =
better =than the earlier parts manuals as it has a description for each item =
on the same page as the pretty picture=2e If you have an '87 to '89 3=2e=
6 =or 5=2e3 XJ-S this guide is well worth getting especially to aid =
reassembly =3a-=29 Why do I always have one washer left after working =
on =the car=3f
I hope this info is of use =28and correct=21=21=29=2e
Richard
=5f=5f=5f=5f=5f=5f=5f=5f=5f=5f=5f=5f=5f=5f=5f=5f=5f=5f=5f=5f=5f=5f=5f=5f=5f=
=5f=5f=5f=5f=5f Forward Header =
Subject=3a Re=5b3=5d=3a XJS Wiring Help Needed=2fworkshop manuals
Author=3a M=2eCogswell=40zds=2ecom=25smtp at ccx400uk
Date=3a 03=2f09=2f96 21=3a00
Can you tell me what the break point is within the '88 model year=3f I hav=
e =
an
'88 that I would like to buy a manual set for=2e
MikeC
- ------ =_0_MIME_Boundary_1845.3232c2e2.imsukk50.eurh021.eur.ps.net
Content-Type: text/plain; name=“RFC822me”; charset=us-ascii
Received: from mis.mi04.zds.com by ccmail.mi04.zds.com with SMTP
(IMA Internet Exchange 1.04b) id 22b03510; Mon, 2 Sep 96 11:54:57 -0400
Received: from bull.com by mis.mi04.zds.com with SMTP
(5.65c/051995-1) id AA22991; Sun, 1 Sep 96 04:44:23 EDT
Received-Date: Sun, 1 Sep 96 04:44:23 EDT
Received: from ekeberg.sn.no by nc-17.ma02.bull.com with SMTP
(5.65c/061396-1) id AA66386; Sun, 1 Sep 1996 04:53:07 EDT
id for jag-lovers-out; Sun, 1 Sep 1996 09:34:50 +0200 (MET
DST)
owner-jag-lovers
using -f
Received: from gateway1.ps.net (firewall-user@gateway1.ps.net [192.131.85.
2]) by
with SMTP id for jag-lovers@sn.no; Sun, 1 Sep 1996 09:34:
47
+0200 (
MET DST)
Received: by gateway1.ps.net; id AA22161; Sun, 1 Sep 96 02:34:45 CDT
Received: from eurh021.eur.ps.net(160.110.72.21) by gateway1.ps.net via smap
(V3.
1.1)
id xma022144; Sun, 1 Sep 96 02:34:20 -0500
Received: by eurh021.eur.ps.net
(1.37.109.16/16.2) id AA210433052; Sun, 1 Sep 1996 08:30:52 +0100
Content-Identifier: Re[2]: X
Priority: Normal
Importance: Normal
Sensitivity: Personal
Date: Sat, 31 Aug 1996 22:04:00 +0100
Message-Id: <M295627.003.1m5f2.1.960901072940Z.
CC-MAIL*/O=CCMAIL/PRMD=PSE/ADMD=MC
I/C=GB/@MHS>
Subject: Re[2]: XJS Wiring Help Needed/workshop manuals
X400-Mts-Identifier: [ /P=PSE/A=MCI/C=GB/ ; c\pscgcc02\960901082940c ]
Original-Encoded-Information-Types: ISO6937-Text
Ua-Content-Id: Re[2]: X
Autoforwarded: FALSE
X-Mailer: Worldtalk (4.0.2-p6)/MIME
Sender: owner-jag-lovers@sn.no
Precedence: bulk
- ------ =_0_MIME_Boundary_1845.3232c2e2.imsukk50.eurh021.eur.ps.net–
Date: Sun, 8 Sep 1996 16:25:22 GMT
Subject: Re: Looking for XK120/140
I am also looking for an XK 120 OTS for a friend of mine who
wants to participate in the Mille Miglia. As only pre 1957 cars
are eligible, this means - if my very limited knowledge about
XK-jags does not deceive me - that also an XK 140 would be OK.
Thing is: A Lagonda Tickford Drop Head Coupe 3 Litre, 1953,
should be traded in. Otherwise no deal.
Any offers, preferable from European source?
At 08:54 06.09.96 EDT, Zoran Mitrovic wrote:
Dear friends
I’m still on my quest for an XK120 or 140.
I will be in two weeks for vacation in Florida. I have already had contacts
with
Vintage from Sarasota and with Classic Car Exporters. Can somebody advise me to
another place where I could find my dream car?Best regards Zoran Mitrovic
Glue Man
glueman@collano.ch (former address: gleuma@dial.eunet.ch)
Date: Sun, 8 Sep 1996 12:35:53 +0000
Subject: Oil aditives
There is nothing to do once it is already worn, but before it is worn
there are aditives that you can add that make a difference. You want
one with Teflon in it, the more the better.
There are those who say Teflon will not help a car, but they are full
of shit. Dupont says, “It wont help” but they are trying to cover
their butt and I think damage their competitors until they can put
their own Teflon aditive on the market.
My experience is 300,000 miles on a Mercedes 220D using Teflon every
40,000 and changing the oil every 10,000 miles. Yes I said 10,000
miles and this IS a diesel!!!
I also have 120,000 miles on an XJ6 without ever removing the head and it
still has oil pressure of 50 psi at cruise at temperature.
I race this engine and turned 100,000 miles while passing a Ferrari
at 100mph in the first turn at Texas World Speedway. On the race
track it never exceeds 80C on the temp guage. My wife recently
totaled the car and we are having the engine and transmission
transplanted into a new body. It will race again! It is treated with Metalon every 40K.
Used to use another product, Lubrilon, the first one
that started the whole Teflon thing, but they are no longer
available.
I got well over 240K on a 6cyl 64 mustang that I treated with Teflon.
On a 1985 Escort with the cheap sidwinder 4 cly engine that everyone
knows is a “throw away” at 70K, I got 187,000miles before I gave it
away because I was tired of it. It is still running fine and has
never had the head or oil pan off of it. I have no idea how many
miles it has on it now. I treated it every 40K with
Lubrilon.
Dupont can po-po it if they want, but I think my experience shows
that it works. I dont know what Dupont is up to because you know
they know better.
Date: Sun, 8 Sep 1996 12:46:02 +0000
Subject: Radiator removal XJS
I am in the process of removing the radiator from my XJS and have
found several errors in the Haynes manua. So whats new? The big
error is that they say you have to discharge the AC. It aint so!
The second is that they say you need to remove the bonnet. It aint
so. Just remove the grill and one end of the lift struts and the
bonnet will lean back very happily on the bumper, well out of your
way.
I will have more news on the radiator/waterpump renewal in a few
days. I am looking for a replacement impeller, as Kirby suggested, to
put on my new water pump before I install it.
Anyone know how important the sponge rubber inserts around the
ratiator are. Mine are rotted away.
What does the air dam look like on the 85 XJ-S? Anyone have one to
sell, trade, give away? I have only a piece of mine left on the
right side. Is it supposed to go all the way across the center?
It looks like the front license plate does alot of damage to the air
flow into the lower grill, and with that dam gone, that might be a
big part of my overheating problem. Any comments on removing the
licnseplate?
Date: Sun, 8 Sep 1996 13:27:29 -0700
told
know.
Dave,
Would you please post the instructions.
Thanks,
- Quang Ngo
- quang@valleynet.com
- 89-XJ40 89-300E P90 A3000/25 A1000 SNES PSX C C++ UNIX NT WIN95
Date: Sun, 8 Sep 1996 16:38:28 -0400 (EDT)
Subject: Re: Radiator removal XJS
It is difficult to quantify how important they are. They serve
an obvious purpose and should be replaced. SICP has them at
a reasonable price.
Any comments on removing the licnseplate?
Mine runs well below N with the license plate in place. I have
heard several accounts of the license plate flow obstruction
theory but personally I doubt that it matters very much. What
happened to the air dam? Never mind, I guess you bought the
car without it. I’d be inclined to want to replace that, but
I think the car should run cool without it when the cooling
system is healthy.
About removing the radiator without purging the freon, what
did you do? Move the condensio
condensor out of the way with the hoses still connected?
Thomas E. Alberts
Date: Sun, 8 Sep 96 13:41:52 PDT
Subject: Re: Back in the fold
Very interesting to hear your report from Beijing, China.
I heard that Jaguar began selling cars there a couple of
years ago. Amazing that you actually saw an XJ40 there. I
saw plenty of Lexus and German makes in Canton, but no British
cars whatsoever. Personally, I would never own a luxury car
there. The traffic is just too terrible; gasoline is not
always of assured quality once you get out of the city,
and car maintenance is not yet a pervasive concept. Just
imagine a British car without proper maintenance!
Roger Peng (408)765-7863
Intel Corporation
Design Technology, Physical CAD
Date: Sun, 8 Sep 1996 23:26:06 +0200 (MET DST)
Subject: Jaguar XK-120 for sale (CT, USA) (fwd)
Folks,
I received this email today. If anyone is interested, please reply to
John Krewalk jkrewalk@worldnet.att.net directly.
Disclaimer: I do not know John or his car. I’m simply forwarding his
message as I thought it might be of interest to someone on this list.
Gunnar
Gunnar Helliesen | Bergen IT Consult AS | NetBSD/VAX on a uVAX II
Systems Consultant | Bergen, Norway | '86 Jaguar XJ6 4.2 Sovereign
gunnar@bitcon.no | http://www.bitcon.no/ | Vicki who? What .sig virus?
- ---------- Forwarded message ----------
Date: Sun, 08 Sep 1996 00:20:34 -0400
To: virtualwheels@bitcon.no
I live in Connecticut and own a 1954 XK-120 Jaguar Convertible that has
been in storage for more than 20 years. If you are interested in this
beautiful classic auto or know of someone who might be, please contact
me by email or phone at 860-242-4005.
John Krewalk (jkrewalk@worldnet.att.net)
Bloomfield, CT
MZ�
Date: Sun, 8 Sep 1996 17:42:31 -0005
put on my new water pump before I install it.Anyone know how important the sponge rubber inserts around the
ratiator are. Mine are rotted away.What does the air dam look like on the 85 XJ-S? Anyone have one to
So: You’re missing the sponge inserts AND the front air dam, and you
think the impeller is the reason your car is overheating? Tsk, tsk.
| - Palm’s Postulate
Date: Sun, 8 Sep 1996 19:46:24 -0400
Subject: Jag Cooling
There was a thread the other day about Jag Cooling that led to the topic of
WaterPump Impellers. I’m not familiar with the one on my XJS but thought I’d
share what I learned about my TR8. I live in very hot climate and was
concerned about cooking the all-aluminum V8. After trying most of the normal
things (Radiator flush, etc.), Woody Cooper of the WedgeShop suggested a
unique solution. Install a waterpump impeller from a mid-60’s Buick 215 cid
(This is actually the engine that spawned the 3.5L.) he said. The Buick
impeller had twice as many fins, which also were more sharply raked…
Intuitively, it seemed the Buick impeller would allow faster coolant flow.
The charge was $10 and now I run the AC on 95 degree days without any
problems.
One other thing I learned, RedLine Inc. makes a product called Waterwetter
which dramatically reduces max engine temperature. I’m not normally a fan of
gimmick additives but this is one of the few I’ve tried that really work.
Tony Blevins
80 TR8 Conv
85 XJS-HE
Date: Mon, 9 Sep 1996 10:13:16 +1000 (EST)
Subject: Re: XJ40: How does your A/C operate?
Eric writes:
I agree with Barrie’s remarks. Although I have a (brief) description of the
system in the workshop manuals, I am still unable to fully understand how
some things that have happened to me can be possible. The description, with
diagrams, gives the impression that hot air from the heater matrix and cold
air from the evaporator are mixed together in proportions determined by the
in-car and ambient temperatures and the control settings and this is then
discharged at both foot and face levels. If this is so, then with the
possible exception of the changes made by the face level temperature
control, there should be no difference between the temperature of air from
all of the outlets. This face level control is (I think) only supposed to
change the temperature by a few degrees, but I cannot notice any change. I
once had hot air at face level and cold air at foot level with the controls
set to cool. I couldn’t find any fault and it didn’t recur. As regards the
difference between the AUTO and MAN modes, I read the description to mean
that with AUTO the system maintains the set temperature but in MAN it works
as a non-climate control system. The side vents on my car always have a
good volume of air but the volume from the centre vent varies considerably.
If anyone can give a detailed description of the system, or preferably a
fault finding list, I would be very interested. Alan
Date: Fri, 06 Sep 1996 17:10:23 -0700
Subject: could use advice regarding tire brands for 85 XJ-S
I am facing the task f buying new tires for my 85 XJ-S. I’d be interested in
anyone’s feedback regarding the following apparent three brands that I have
as a choice for 215/70 VR15:
- Dunlops. At around $150/tire.
- Pirellis (I’m told that there is a new P4000 that replaces the previous
vintage). Best price so far; $115/tire including mounting, stems, and
balancing. - Bridgestones (my current set, gave a great ride but didn’t last very
long). At around $145/tire.
Any other ones I should consider? Are the Pirelli’s any good and is the
price aboput right? Your opinions regarding the above will be much
appreciated, and thanks in advance,
Rob W-M
85 XJ-S
Date: Sun, 08 Sep 96 20:59:36 EDT
Subject: 420G/General questions
From: ** SHANE MANTOSZKO ** IBMA INVENTORY ANALYST **
*** SYDVM1(SHANEM) PH. (02) 354-4918 CUMBERLAND FOREST FE21
*** INTERNET - SHANEM@VNET.IBM.COM *** IBMMAIL - AUIBMSPM ****
Fellow jag-lovers,
Raquel (my 420G) is still awaiting her body repair.
In the meantime, I bought the factory repair manual, and after flicking
through it briefly, discovered a few things. I also have some other
questions :-
- The 420G came out with a factory power window option. Raquel does
not have this, however whilst my sister was in England, I had her buy
four brand new power window motors to suit an XJ6 series 2.
Can anybody confirm whether or not these can be fitted to the 420G ?
I know I will have to shop around for the window control switches, which
appear in the manual to be totally different from the xj6 ones. Are there
any club members or other mkX/420G owners out there who can help me ?
Is it a big job to install the motors, remove the manual winders, and
fit all of the electric switches ? I plan on joining the jag drivers
club here in Sydney when she is road worthy. Since some of you use
this list, can you confirm whether there is a good support base for
things like this from the club ?
Since this car has no air-conditioning, I would like to fit a
Webasto sunroof. I have seen that they make roofs which are in panels
that fold back, as opposed to a vinyl ‘tarp’ which just pulls back like
a curtain. Does anyone out there have a similar type roof ? I plan
on using this car for weddings, and would love to have the front
and rear passengers enjoy the sunshine. Can the roof panels come
completely off, and make the car like a cabriolet ? Is there more
road noise with this type of webasto sunroof ?
Does anybody in Sydney know which companies do quality webasto
sunroof installations ? -
I would love to fit air conditioning. I don’t want it integrated
with the heating as it is with the climate control systems in later
jags. The heater works fine, so all I want to do is fit a stand alone
air-con system, that has it’s own fans, and a wide thin outlet that
can fit inside the parcel shelf in the bottom of the 420G dash.
Are there aftermarket systems like this available ? I guess I can use
a compressor, condensor, receiver dryer from an XJ6 or later. The main
problem is fitting the outlet assembly into the dash. Maybe someone has
played around with old mk 1/2’s or 420’s in the past and rigged up
some neat after market aircon system. I’d love to find out from anybody
who has done it successfully. Maybe the ‘factory’ air-con assembly
that was available can be tracked down. Anybody know who made this for
Jaguar ? Probably hard/impossible to find one in a spare parts place. -
The engine was completely reco’d on this car. When I start it cold,
the accelerator seems to be restricted to stop the engine from
revving out. I push it, but the engine revs do not go up. If I push it
too hard, the engine starts to stall. After a minute or so, the car will
rev normally. Is this some type of cold start control that the triple
carbies and throttle governor use to stop over-excessive revving when
cold ? I can see that the throttle rods/cables have a governor set up
also. Is this there to restrict revving when cold, or is it there
because the 420G was a limo, and thus had a throttle governor to make
take-offs smooth and slow ?
Thats about it for now…hope someone can help with some of my
queries…cheers.
REGARDS…Shane
Date: 9 Sep 96 11:28:43
Subject: Re: Security problem
Thanks for the reassurance, Nick. I’m glad to see our list does have a degree
of security!
By the way, how’s the kitty (and I don’t mean the four-wheeled one)? Do we need
to kick in another subscription soon, or are the costs covered?
Thanks for all the work you’re putting in, Nick.
- -Jan
Date: 9 Sep 96 12:57:15
Subject: Re: XJS wiring help needed
On Sat, 31 Aug 1996, Jim Isbell wrote:
First, under the bonnet there are two wires comming out of a harnes
near the throttle “cam” where the throttle cable connects to the
“cam” and there is a microswitch on the side of the cable. These two
wires are Green and Green with a yellow tracer.
As an add-on to John Napoli’s answer, the description sounds exactly like the
kick-down switch on my S2 XJ12s. I’m assuming this XJS is a V12 with a GM400
box…
If that’s the switch we’re talking about, it operates when full pressure is put
on the throttle pedal; after the butterflies open fully, the cable sheath moves
half an inch or so toward the throttle wheel against a very strong spring; a
thicker portion of the throttle cable ferrule comes under the microswitch lever
and operates it. The microswitch lever can get damaged and may need bending to
operate properly.
Jim, if your kick-down isn’t working, that’s what it is. If the kick-down is
working, John has the right of it.
- -Jan
Date: 9 Sep 96 13:14:36
Subject: RE: XJS Micro switch on throttle
John Napoli :
Question: will a pushbutton wired in parallel with this switch and
controlled somehow by the driver provide part-throttle kickdown? Or does
the electric kickdown only work if the transmission is also seeing zero
vacuum at the modulator (from WOT)?
id for jag-lovers-digest-out; Mon, 9 Sep 1996 06:42:17 +0200 (MET DST)
Date: Mon, 9 Sep 1996 06:42:17 +0200 (MET DST)
Message-Id: 199609090442.GAA10726@ekeberg.sn.no
Subject: jag-lovers-digest V2 #341
Precedence: bulk
Status: O
X-Status:
jag-lovers-digest Monday, 9 September 1996 Volume 02 : Number 341
Re: Wind Deflector
Re: Hole in dash SIII
AK Miller Auction (Only a bit of Jag content/No Mopar content)
HIF carbs
Re: XJS brake fluid reservoir cap
Re: overheating
Getting at the A/C microswitch - XJ40
XJC12 purchase
XJ S I Corner window
XJC - Oops!
[none]
Date: Sun, 08 Sep 1996 21:33:25 -0500
Subject: Re: Wind Deflector
Roger Peng rpeng@cadev6.intel.com:
Has anyone installed a wind deflector for the sunroof of an XJ40?
Do they work? Meaning, do you get less wind noise and buffeting?
How easy was the installation? Does it require drilling any holes?
And finally, how much does it cost?
I installed a wind deflector on my previous XJ40 (an 88 1/2 XJ6). The
installation is simple and results in reduced wind noise. Seems like the
cost was around $90.
Installation is quite simple. The deflector is held in place by two
clips that wedge themselves into the forward drain holes of the sun roof
(no drilling required). Be sure to clean and wax the area in front of
the sunroof before starting.
Adding the wind deflector does change the appearance of a
lighter-colored car (mine was Artic Blue). Another caveat: the gasket
for the deflector made an impression in the finish so I left it on the
car when I sold it.
I am planning an adding one to the current XJ40 (93 BRG VDP) one of
these days.
Randy
Date: Sun, 8 Sep 1996 21:11:56 -0500
Subject: Re: Hole in dash SIII
Many thanks for the inf. on the climate control sensor. Makes perfect
sense.
BTW, is there any satisfactory rebuild for a viscous fan coupler or is it
cheaper/wiser to just replace it? Any idea of cost (US)? I noticed a
distinct roaring sound the other day and have discovered it is apparently
being caused by the fan being in constant service rather than varying as it
should.
“Have you ever seen a plumber bite his nails?”
David Tordoff 83 XJ6 SIII, Dallas, TX.
Date: Sun, 8 Sep 1996 22:56:36 -0400
Subject: AK Miller Auction (Only a bit of Jag content/No Mopar content)
To all those interested:
Just back from the AK Miller Auction in Vermont. To recap for those who
missed my first post, AK Miller was an eccentric recluse whose hobbies were
collecting gold bullion and Stutz automobiles. In all, there were 49 classic
cars, mostly Stutz’s, with a few odd cars thrown in. Among the oddballs: a
Locomobile town car, a Stanley 7-passenger tourer, a couple of Franklins,
and a Springfield Rolls Royce. Also a couple of lots of Volkswagen parts
cars (his daily drivers).
There are so many stories about this guy it is hard to separate truth from
fiction. The consensus is that he came from a wealthy family: grandfather
was a commodity trader, papa was a Wall Streeter. When and where he
developed a passion for Indiana-built cars is not known, but he had already
collected many as a young man. His profession was aviation: he flew a
delivery service using autogyros. (Autogyro parts, manuals, and training
films were auctioned in one huge lot - I would have loved to get some of
those films). Somewhere along the way, he met his like-minded wife, and
moved to a remote farm in Vermont. His cars, which had been stored in an
airplane hangar in New Jersey, came with him. In Vermont, he housed his
collection in purpose built barns, which sprung up as his collection grew.
When Stutz went out of business in 1932, he bought the contents of the
factory, and stuffed his barns with spare parts. From that point on, he
seems to have made his living selling spares, often at outrageous prices. I
say ‘seems’, because there really is no record. Neither he or his wife had a
social security number, and they never paid income taxes. They must have had
some serious influence on that little community, since it seems to have
grown all around them.
People who dealt with him report that he was a very shrewd negotiator. He
claimed not to have a phone, and preferred contact by letter. When a deal
was concluded, payment sometimes had to be made in a peculiar manner: gold,
or silver coins minted before 1964. He would then ship the parts, which
might be original, or might be copies which he made himself, or maybe he
would forget to send any parts at all.
When he and his wife died, the assumption made was that they were destitute,
since they lived so frugally. The town paid for their funerals. When the
house was opened, millions of dollars of gold and silver bullion was
discovered. Also stocks and bonds worth over a million. The house contents
were auctioned earlier this year. One of the local folks bought a picture at
the sale, planning to reuse the frame. When the picture was removed, they
found $150,000 in bonds which had been used for backing…
The first day of the auction was devoted to the cars, and it was a major
media event. It was a beautiful day, and close to 1500 people turned out.
Also lots of reporters from the newspapers and TV. The cars were all over
the place. So many cars, so many barns, so many people, it was bewildering.
Most of these cars needed full restoration, but for the most part they were
amazingly complete and original. My favorite of the sale was a 1916 Stutz
Bearcat…I think it was Miller’s favorite, as well, judging by how it was
cared for.
As for buying any of these cars, well, this was definitely not my day. With
so many buyers present, and several big money buyers on the phone, there was
just no chance for yours truly to own a Stutz. Prices were as much as 50%
higher than Christies generous catalog estimates. In all, $1.5 million was
raised on cars alone. The ‘16 which I covet went for $155,000, plus
Christies’ 15% buyers premium. Every car set a new record. One pile of junk,
identifiable only by a Stutz radiator badge, went for $6,000. The
Springfield Rolls Picadilly Roadster went for $115,000 to a telephone
bidder, rumored to be a famous celebrity.
The second day of the auction was devoted to automobilia, and was much less
crowded. Whole barnfuls of Stutz spares were sold, along with 100 lots of
papers and books. One lot consisted of correspondence which Miller had had
with…Jaguar Cars. It seems he owned a Mark VII, which had a faulty
speedometer, and which leaked oil incessantly. He had sent so many letters,
that Jaguar sent him a set of gaskets for free. Not satisfied, he tried to
get them to install a Mark VIII engine and tranny. There was no indication
in the correspondence of how this story ended. However, there was certainly
no Mark VII at the sale, so we must assume that he never stopped the leak. A
sad end to Mr. Miller’s Jag days, and a lesson to us all.
Prices were actually more outrageous the second day than the first.
Formless piles of Stutz junk went for thousands of dollars. I was, however,
able to hit paydirt in the form of a salesman’s award watch. These watches
were typically given to salesmen who achieved certain sales targets. They
carry a Stutz logo on the face, and a Stutz watch fob. The crowd, which
consisted mostly of antique auto parts dealers, seemed to assume that this
was an inexpensive Ingersoll movement, when in fact it was a high grade
Elgin. For once my horological background served me well, and I confidently
outbid the crowd. I am very, very happy with my Stutz pocket watch!
As to photographs, I took many. We will soon see how well I was able to deal
with the dim light in those barns! If they come out at all, I will try to
upload them to a Web site to share with those who have read thru my
ramblings, and still have some interest in the topic…
Mike Frank
1969 E-Type 2+2
1966 Plymouth Barracda
1927 Stutz/Elgin Pocket Watch
Date: Sun, 08 Sep 1996 22:57:20 -0400
Subject: HIF carbs
Hello Jeff,
In response to your ‘wits-end’ message regarding HIF carbs, I too went
through the same trial-by-fire on my TR6 as you are (apologies to
everyone for always referring to my TR6 adventures, but it turns out
that A LOT of what I’ve learned on the 6 transfers to my Jag).
A couple years back I decided I wanted better air flow to the engine. I
had a chance to get two VERY cheap sets of 1.75 SUs - two HIFs and two
HS6s. I quickly tore off the CD2s (which I hated. Not sure why though,
probably because they were borne out of emissions) and with some slight
mods to the linkage, put on the HIFs. The HIFs were the first choice
due to their slightly more modern design of an integrated bowl and
temperature mixture compensator. Once on, they idled great! I thought
“geez, that wasn’t too hard”, washed my hands and hopped in. It made it
down the street OK, but seemed a little weird. I got out onto the
highway and opened him up. Good power until about 4k and then…chaos.
It fealt as if half the engine decided it needed more (or less) fuel (or
air). No matter WHAT I did to the mixtures, dashpot oil or even the air
cleaner density - I could not rid this strange occurance.
I soon gave up on the HIFs and turned to the HS6s. Basically, these did
the same thing! Very frustrating. I knew both of these sets were off 4
cylinders and probably Volvos, so I did some figuring and determined
they needed more fuel (due to the long stroke of the 6). But, I could
not come up with a good mixture setting that would give me tolerable
idle mixture (10:1) and proper acceleration (1:1) due to the needle and
the spring. The damper spring in these carbs appears almost more
critical than the actual needle. It’s obvious job is to regulate the
ventury size (and thereby the depression) during running and
acceleration. The oil then determines how long the ventury stays at
that size before opening up. This is a very critical balance since the
ventury size determines the depression, air speed and fuel flow rate -
these must all change in the correct non-linear sloping way the engine
demands change. I realized the ONLY way to get these carbs to work
properly was to obtain a set of needles and springs TOGETHER. This was
difficult since SUs in any form were not offered on the 2.5L Triumph
motor. I managed to find a setup similar on the BJ8(?) Austin Healey
motor that ended up working perfectly (only for the HS6s though, the
HIFs have no equivalent setup :-(.
The point to all of this is you mentioned that one needle was slightly
shorter than the other. This is a SURE sign that someone (the PO?) has
been playing - trying to make a perfectly good carb work better (when
they should have been concentrating on cams first anyway). If these
carbs are not original you will never get them to perform properly on
anything but the original setup’s motor. Your best bet is to determine
the absolutely correct type of carbs and call Joe Curto (address at
bottom) to obtain the proper setup needles and springs. He was my
saving grace in a dark time. Another good idea is the Haynes SU
manual. It helps you properly identify, tune, adjust and care for these
carbs - invaluable.
BTW, I plan to keep my Strombergs on my XJ12
Dave Ox.
SU parts:
Joe Curto, Genuine SU Spares
22-09 126th Street
College Point, NY 11356
718-762-SUSU
Dave Oxenreider
Audio Visual Imagineering, Inc.
Orlando, FL USA
73 XJ12
75 TR6
Date: Sun, 08 Sep 1996 23:20:48 -0400
Subject: Re: XJS brake fluid reservoir cap
I am now replacing the cap on the brake fluid reservoir for the second
time. the two previous units failed in a similar manner. It appears
that the modl used for the caps has a section near the top of the
threads and the top surface that is too thin. The cap has separated
into a threaded piece and a top piece.
Has anyone else seen this problem and is there a better replacement
part? Did I overtighten it? She leaks a bit of fluid and I have too
replenish the fluid about every month. Is it possible to replace the
entire reservoir with a better designed unit?
While I’m thinking of it, it seems there are many items on our cars that
could be better designed and or manufactured. Would there be any
support in compiling a list of replacement parts/suppliers that would
potentially give better service? It seems like almost everyone has
some experience in this respect. I have seen Kirby’s XJS book but
don’t recall a specific section on better replacement parts. Items like
a good GM alternator conversion kit for those with heavier electrical
demands and things like that.
Ivan | The meek shall inherit the Earth
http://users.visi.net/~isk00 | The rest of us will head for the Stars
Date: 9 Sep 96 13:43:31
Subject: Re: overheating
Matthias Fouquet-Lapar :
Is it not enough to measure the in and outlet temperature of the radiator to
figure out
if the radiator is working correctly or not ?
That’s not a simple as it sounds - it’s a pressurised system, and running near
the upper end of the range, the coolant would be hot enough to boil instantly
if you release the pressure, so you’ll have to install properly calibrated
thermometers in pressure-tight fittings at suitable points.
The measurement would tell you that the temperature drop across the radiator
isn’t sufficient, which you already know as the system is overheating. It won’t
tell you what the cause is, such as 1) there isn’t enough cooling air coming
through or 2) there isn’t enough coolant flowing through or 3) some tubes are
blocked so the perfectly adequate coolant flow doesn’t have enough transfer
area exposed to the perfectly adequate air flow.
The air flow is easy enough to check - you can see the fans turning and you can
feel the flow. If the fans are turning and you can’t feel the flow, the air
side of the radiator is blocked. S1 and S2 XJ12s also have a problem with air
flow restriction at speed, which can be partly cured by moving the number
plate, horns and fog lights out of the main (below the bunmper) intake.
Water flow is harder to check without introducing flow meters into the system;
about all you can do is check the thermostats, inspect the water pump (the
impeller can lose much of its vanes to corrosion over the years) and (on the
V12) make sure that the bypass seats behind the thermostats, which are supposed
to be closed when the thermostat opens, aren’t seriously eroded. Sometimes an
elderly water hose can develop a loose flap inside, which impedes the water
flow. It’s anyway a good idea to replace any old, swollen and perishing hoses
before they pop 1,216 km from the nearest workshop…
Case 3 has in my experience been the most common with older cars (two cars,
both partly blocked when bought), which also is the impression I get from the
list. Unfortunately, there’s no simple way to check this; the radiator has to
be opened up and rodded.
Of course you can also have overheating due to seriously incorrect ignition
and/or fuel/air mixture settings, but if you have those, the engine will be
running very badly even before overheating, so that would be the first thing
you fix, anyway.
- Jan
Date: Sun, 8 Sep 1996 23:37:36 -0400 (EDT)
I am putting the finishing touches on the XJ6 book and need some
information from anyone that knows.On the US series 3 there is an O2 sensor in the exhaust system. The reset for one model is in the trunk and there is another under the hood. Can someone describe this reset unit location and operation? First off, this reset has nothing to do with the O2 sensor itself. It is merely a mantainance “reminder” light, required by our dear government, Telling you it’s time to do the x0,000 mile service. It’s driven by the speedo, and turns on a light on the dash after a cetain milage has passed. In the case of JAg, the light says Ox sensor. Other brands had the light labeled “EGR” or “Service” or … The early cars with mechanical speedo had a Smiths unit in the middle of the speedo cable. It’s a white box mounted in the engine bay at the bulkhead. This unit has an odometer looking counter that shows the percentage of mileage that has passed. It is reset by turning the recessed knob on the side until the counter shows 0000. The knob has two holes in it to turn it. Smiths makes (made?) a little key that fit. I have sucessfully reset them with a set of small circlip pliers, though this is a pain. The later cars with electronic speedos use a different system. This is one of my favorite examples of British parts bin engineering. The box, as you mentioned is mounted in the boot on the foreward bulkhead. This box is black, and has a push button to reset it. That’s it. Push the white button (it is recessed behind a guard), and kerchunk, it’s reset for another 30K miles. What makes this such a favorite of mine is the box. It’s a VDO pieces that, like the Smiths, is designed to go inline with the speedo cable. Jaguar, unlike most everyone else, did not go the all electronic route when they converted to the electronic speedo. They made a interface that takes the signal from the pulse generator, and drives a stepper motor attached to this mechanical counter. Hey, it works… :> Randy K. Wilson randy@taylor.infi.net From: viadata@interramp.com (David Hurlston) Date: Sun, 08 Sep 1996 22:41:47 -0700 Subject: Getting at the A/C microswitch - XJ40 Alan Beale asks… Another possible cause is a bad microswitch in the A/C control assembly. This is apparently quite common. The microswitch is located at the top of the switch assembly in the console. Micheal Neal put me on to this and told me how to get at the switch assembly. If you need instructions - let me know. Dave: I would also be very interested in these instructions. In fact, I think that anyone with an XJ40 of about 1989 vintage would also be. Could you please oblige. Many thanks. Alan. Looking back at my notes, it was Micheal Neal who told me what the problem was likely to be (where is Michael anyway? he has been absent from this list for quite a while) - and the instructions for getting at it were courtesy of one Donald McGregor. Here goes, it’s actually pretty easy to do… 1. Take out the center console ashtray - 2 screws in the armrest storage. 2. Unclip the gear shift selector surround. There is one clip in the middle of each. 3. Unscrew the 2 plastic wingnuts under the veneer by the ashtray. Don’t drop 'em. You have to reach under the veneer to do this, but it’s easy. These nuts are on screws that slide out of the veneer mounting. Don’t drop these either. 4. Push the veneer upwards and clear of the gear shift knob. This takes some courage, but the veneer will flex OK without breaking anything. 5. Remove the 4 or 6 panel screws that hold the A/C controls assembly and the whole thing will come out. 6. The microswitch in question is at the top of the switch assembly. It may be dirty and cleaning with contact cleaner will help, or it may be toasted (as mine was) and need to be replaced. Jaguar sells the microswitch as a separate item for 25 bucks, but an electronics parts store will probably have something suitable for a buck or so. It pays to put a cloth over the gear shift knob while you’re messing around, so it doesn’t get scratched. Good luck … Dave From: Dave Oxenreider daveox@av-imagineering.com Date: Sun, 08 Sep 1996 23:53:16 -0400 Subject: Re: Brake pedal to the floor I feel pretty confident after rebuilding the master cylinder that it will never leave me completely without brakes, but it is in the back of my mind when hammering and I never run completely to the edge. I would like to replace it soon and I will look for a rebuilt, sleeved unit. I’m not sure Girling is as supported as Dunlops, though. Also, I’m not sure who mentioned it before, but the fact that when the rear brakes were unhooked the pedal never sunk is curious. How could the piston go to the floor without the fluid going somewhere? Unless the fluid is leaking out of the rear calipers, there is no way that unhooking them could prevent it. Plus, for the piston to go to the floor means that either BOTH the front and the rear are leaking or the master cylinder is leaking. The reason the front and back are kept seperate is to regulate pressure and prevent total brake failure. If one system fails the other part of the master cylinder will still be partially functional. Let me know what you find. Dave Ox. 73 XJ12 75 TR6 From: Dave Oxenreider daveox@av-imagineering.com Date: Mon, 09 Sep 1996 00:06:11 -0400 Subject: XJC12 purchase I own a 73 XJ12 after many months of searching for a unique Jag that I could afford (I paid $5,000). I would have fealt fortunate to find what you’ve found for 3,000 USD. If you like working on the V12 (tight confines, lots of plumbing, etc) then I would go for it - if it’s everything the seller says… Good luck, let us know what you find. Dave Ox. 73 XJ12 75 TR6 From: “Kirbert” palmk@gcn.scri.fsu.edu Date: Mon, 9 Sep 1996 00:16:37 -0005 Subject: Re: Radiator removal XJS Thomas E. Alberts: Mine runs well below N with the license plate in place. I have heard several accounts of the license plate flow obstruction theory but personally I doubt that it matters very much. I agree. However, the XJ-S might have less trouble in that regard than the XJ12, which was where the suggestion came from. Just intuitively, I can’t see a front tag making much difference on an XJ-S, but it does look like trouble on an XJ12. What happened to the air dam? I’d be inclined to want to replace that, but I think the car should run cool without it when the cooling system is healthy. You MIGHT be wrong. The air dam has a significant effect on airflow through the engine compartment, and these cars are marginal to begin with. Of course, the indication might be the speed at which problems occur; the air dam is important only while moving, has no effect at idle, so if the car overheats at idle the problem is elsewhere. Meanwhile, I will NOT be volunteering to remove my air dam to try it! About removing the radiator without purging the freon, what did you do? Move the condensio condensor out of the way with the hoses still connected? The radiator comes out upward, not forward; the condensor stays put. The issue, apparently, is the dryer, which is bolted to the top crosspiece over the radiator, but it is easy enough to unbolt and leave hanging there while the radiator is out. It appears the Haynes manual suggests purging the freon in order to leave the dryer attached to the crosspiece when it is removed. Totally pointless. By the way, the official Jaguar manual ALSO says the freon must come out! Suggest that all XJ-S owners take note, and scribble some comments in their repair manuals to avoid extra work if the radiator ever has to come out in the future. Kirbert | If anything is to be accomplished, | some rules must be broken. | - Palm’s Postulate From: Dave Oxenreider daveox@av-imagineering.com Date: Mon, 09 Sep 1996 00:35:44 -0400 Subject: XJ S I Corner window To All, I have a Series I XJ12 that the driver’s small corner window opener knob is stripped, thus allowing the window to be pressed open from the outside. Is this an easy fix? Has anyone successfully repaired this mechanism (or possibly just locked it from inside the door)? I am not interested in necessarily having it function properly as much as I am in having it secured. Also, has anyone ever added an aftermarket power antenna to an XJ? Any particular brands that fit nicely? Thanks in advance to all your collective knowledge. Dave Ox. 73 XJ12 75 TR6 From: Jan Wikstroem Jan_Wikstroem@acp.com.au Date: 9 Sep 96 15:18:01 Subject: XJC - Oops! I thought I’d better draw the attention of the group to a nasty design error in the XJ (at least S1 and S2) rear suspension. My attention was drawn to it when the left rear wheel started rubbing the wheel arch on tight right-handers; when I jacked the car up to investigate, the wheel flopped over about 45 degrees… The stub axle in the hub carrier (the bit that turns in the rear wheel bearings) is splined for the hub and has a large thread and castellated nut on its outer end. This thread comes right down to the splined part with no fillet whatever and creates a horrendous stress concentration at the end of the thread. Mine suffered a fatigue fracture in consequence; my local parts pusher tells me this is not uncommon, as one would expect from such an elementary error, especially if the nut is overtightened. Accordingly, I ground and polished a shallow rounded groove at the base of the thread of the new part and the unbroken old part. This may not look sensible, as the shaft appears thinner, but it makes it better able to carry the load by reducing the stress concentration. A bit of home-made Magnafluxing indicated that the right-hand stub axle was OK. I didn’t really mind doing this job, as the rear sub-frame was due to come out anyway to correct an ailing diff (PO ran it without oil) and clapped-out rear disks (now replaced with extremely expensive and not very good ventilated ones from GT Jag). I suspect this problem is the reason why the workshop manual specifies putting Loctite Stud-Lock on the outboard half of the splines, as this would take up the backlash and reduce twisting fatigue loading on the axle end. It may be an idea for those of you with older XJs to check that this has been done: 1. Jack up one side. 2. Take the hub cap off. 3. Remove the split pin and slacken the nut a couple of turns. 4. Twist the wheel back and forth and see if it’s loose on the spline. If it is, I’d recommend a generous application of Loctite Super Wick-In without taking the hub off. Allow it enough time to set. 5. Retighten the nut to the specified torque (73-77 lb/ft, but it might vary according to series and model, so look it up) and back it off slightly until you can get the split pin in. Do NOT tighten it down further to get the pin in. And the next time you do the rear wheel bearings or U-joints, I strongly recommend having the stub axles checked and modified; any competent engineering shop will know about stress relief. Modifying parts of the Jaguar may be sacrilege to some of us, but fine as the design is, it isn’t perfect… Jan From: sfisher@sola.com.au (Scott Fisher) Date: Tue, 10 Sep 96 00:03 CST Subject: [none] To: jag-lovers@sn.no From: sfisher (Scott Fisher) Subject: Re: Water light on XJS Kirby writes… This sensor is really just a terminal in the coolant, measuring the conductivity of the coolant itself. Therefore, there is a box somewhere that takes this reading and decides if there is coolant in there or air, and operates the warning light. You problem might be in the box rather than the sensor, although I suppose if the sensor itself is covered with crud it might give a false low coolant indication. Sorry, I dunno where the box is. In my 82 XJ6 the box is a black plastic canister about the size of the cardboard tube from a toilet roll. It has three or so wires comming out of one end. It in the passenger side fuse box area. Have a look in both sides if you don’t see it there. This beastie is about $130 Aus…ouch ($1 Aus = 0.78 US). Regards Scott. __________________________________________________________________________ Scott Fisher [sfisher@sola.com.au] PH: +61 08 329-28341. –|\ N SOLA / \ W + E International Holdings Research Center _.–_/ S Adelaide, South Australia. v Joy ia a Jaguar XJ6 with a flat battery, a blown oil seal and an unsympathetic wife, 9km outside of a small remote town, 3:15am on a cold wet winters morning. __________________________________________________________________________ SOLA?- Opthalmic Lens Manufacturer, unless all those transparent disks we make are part of some secret conspiracy to make transparent disks! __________________________________________________________________________ End of jag-lovers-digest V2 #341 ******************************** X-UIDL: 7e63d37fb2f7d520a2cb41c1978cb2c7 Return-Path: @owner-jag-lovers-di1 Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4) id for jag-lovers-digest-out; Mon, 9 Sep 1996 17:30:09 +0200 (MET DST) Date: Mon, 9 Sep 1996 17:30:09 +0200 (MET DST) Message-Id: 199609091530.RAA21079@ekeberg.sn.no X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f From: @owner-jag-lovers-di1 To: jag-lovers-digest@sn.no Subject: jag-lovers-digest V2 #342 Reply-To: jag-lovers@sn.no Errors-To: @owner-jag-lovers-di1 Precedence: bulk Status: RO X-Status: X-Newsgroups: mail.jag-lovers-digest jag-lovers-digest Monday, 9 September 1996 Volume 02 : Number 342 Re: XJS brake fluid reservoir cap Radiator Removal XJS Re: jump starting [XK Engines] Rebuild Questions Re: After market power antenna. CWW Repair E-Type V12 floor panel Imperial Machining Re: Radiator removal XJS Re: jag-lovers-digest V2 #337 From: “Kirbert” palmk@gcn.scri.fsu.edu Date: Mon, 9 Sep 1996 01:27:30 -0005 Subject: Re: XJS brake fluid reservoir cap Ivan S Kirkpatrick, PE isk00@visi.net: I am now replacing the cap on the brake fluid reservoir for the second time. the two previous units failed in a similar manner. It appears that the modl used for the caps has a section near the top of the threads and the top surface that is too thin. The cap has separated into a threaded piece and a top piece. This is the first I’ve heard of a problem here. Can anybody confirm? By the way, which system are we talking about? ABS? Is it possible to replace the entire reservoir with a better designed unit? If you find a way, please send it to me for inclusion in the XJ-S book. Would there be any support in compiling a list of replacement parts/suppliers that would potentially give better service? It seems like almost everyone has some experience in this respect. I have seen Kirby’s XJS book but don’t recall a specific section on better replacement parts. Items like a good GM alternator conversion kit for those with heavier electrical demands and things like that. The GM alternator conversion is in there, as well as several other suggestions. They are not in a separate section, but in the sections talking about the various parts themselves. Perhaps that isn’t ideal for some purposes, but every arrangement I could think of had pros and cons. For those who have my booklet: I have been thinking of eliminating the separation between “Maintenance” and “Modifications”. Some of my suggestions for maintenance are to replace a stock part with a non-stock part, which technically is a modification. And some modifications I suggest be considered even by those who don’t modify the car, such as the installation of aftermarket steering rack bushes. As a result, I have quite a few references back and forth between the sections. Do you guys think it would be a better idea for that to be one large section, where you can look up the thing you’re concerned about and find the maintenance suggestions and the suggested modifications at the same place? Kirbert | If anything is to be accomplished, | some rules must be broken. | - Palm’s Postulate From: “John Littler” auibmdak@ibmmail.com Date: Mon, 09 Sep 1996 02:02:59 EDT Subject: Radiator Removal XJS Jim spake thusly What does the air dam look like on the 85 XJ-S? Anyone have one to sell, trade, give away? I have only a piece of mine left on the right side. Is it supposed to go all the way across the center? It looks like the front license plate does alot of damage to the air flow into the lower grill, and with that dam gone, that might be a big part of my overheating problem. Any comments on removing the licnseplate? Unless I’ve misunderstood the readings I’ve been doing over the last month your lack of an air dam is probably the reason you’re having over- heating problems. My understanding is that the vast majority of cooling air flow comes up and in from the air dam and that the area of the grille actually contributes very little to the (air) cooling of the engine.If that dam is missing it would therefore follow that air flow around your engine is going to be neccessarily limited and will therefore at the least hamper you radiator’s cooling efforts. In a conversation with Jan Wikstrom on the weekend about handling characteristics he mentioned that on the Series II XJC (i.e his car) that the air was actually relatively stagnant around his radiator (correct me if I’ve misquoted you Jan). John SIII XJ6 Sovereign 4.2 Level 1, 29-57 Christie St. St Leonards NSW 2065 Ph: +61-2-9937-8063 Fax: +61-2-9937-8100 Mobile +61-419-617-619 From: Don Tracey dont@echuca.net.au Date: Sun, 08 Sep 1996 19:24:55 -0600 Subject: Re: jump starting From: Barrie Dawson DAWSONB@btcec3.agw.bt.co.uk Subject: RE:Jump start and damages (long) Just a short offering on the subject but one I have found extremely useful. When I first came across a non-starter, battery failed, with an alternator I was concerned that I may cause damage jumping. I had read somewhere that jump starting these vehicles could result in alternator damage once the dead one had started. Since then I have followed a simple but extremely safe procedure. 1. Connect donor to receiver using heavy guage cables. 2. Allow donor to run for about 5 minutes to build up a basic charge in receiver. 3. Where there are 2 people doing this 1 needs to be ready to remove cables as soon as then receiver starts, allowing own alternator to charge 1 battery, the receiver alternator WILL try and charge donor. 4. NEVER allow the receiver to be on the starter for more than 5 seconds. This WILL bring the donor cars charging system into full swing and may not produce sufficient charge to start the receiver. 5. Once started run at about 1500 RPM for no less than 10 minutes. 6. Finally find out what caused the problem and FIX IT. There are available jumper leads with prevents voltage surge when hooked up ,I believe these are essential boot gear to anyone with a computer car,I use a similar device that hooks across the battery when welding on cars and have had no problems. Regards Don Tracey AUSTRALIA 58 XK150,59 Mk2,50 Mk5. From: “Alastair Lauener” a.lauener@napier.ac.uk Date: Mon, 09 Sep 96 09:51:52 gmt Subject: [XK Engines] Rebuild Questions B.J. Kroppe asked 1. Has anyone rebuilt an XK engine without needing to regrind the crankshaft main bearings and crankpins (big ends)? I’m looking for anyone with data which says their crankshaft journal measurements were within specifications after xxx,000 miles. (My engine has 96,000 miles on it.) My 3.4 S-Type engine had 112,048 miles. It didn’t get a rebore, or a regrind. The crank had less than 1/2 thou wear on, and was not oval. The bores had less than 3thou wear, with about 1/2 thou ovality. All measured myself. The (lump) went together with new rings and shells all round. 2. How many of you out there have replaced the bronze bush which guides the oil pump driveshaft/distributor shaft? Are there inside diameter specifications for this component? Yes, but sorry, I just replaced it without much examination. Much like a clutch release bearing, because I was in there. 3. How can I definitively tell what compression ratio my engine is? Should be able to tell from your engine number, ************************************************************************ * Alastair Lauener Work Phone +44 131 455 2458 * * 1964 3.4 S-Type story at http://www.sn.no/home/nick/alas.html * ************************************************************************ From: Baard Th Hesvik baard@telesoft.no Date: Mon, 9 Sep 1996 12:08:38 -0700 Subject: Re: After market power antenna. Dave, I’ve fitted a power antenna on my XJ Series I. Mine didn’t have a power antenna at all as standard. I used a Bosch antenna because it is very compact, although not like the cheap Japanese ones that literally shoots out. I fitted the unit in the left rear wing, between the tank and the light cluster. The lower quarter panel was removed and the unit fixed to the lower edge of the wing. It was a tight fit! I had to slightly bend one of the bulb holders in the light cluster. Having checked the positioning in advance, and found it close to perfect, I decided to go for this easy/cheaper solution as opposed to get the original antenna ($$$). Good luck. Bard ______ _ ! Baard Th Hesvik, Telesoft AS / _ / _ _ _ / / ! Longhammarvn 7, N-5500 Haugesund / // / // /_ / / -/- -/- ! T: +47 52735000 F: +47 52717040 / /_ / /_ / // / /_ ! E-mail: baard@telesoft.no From: brownd@filon.ml.com (Dave Brown - London Dev X1818) Date: Mon, 9 Sep 96 13:37:36 BST Subject: CWW Repair Hi, My better half was driving the Daimler on Friday whilst our “normal” car was in for a service. As luck would have it she had a puncture which resulted in total rapid deflation. It also resulted in one completely buggerred tyre and one partially buggerred chrome wire wheel… I’m not sure how bent the rim is, but I’ve definitely lost a couple of spokes. Can anyone reccomend someone/somewhere (in the UK, preferably around the London area) that can repair CWW’s (assuming it IS possible to repair CWW’s) ? Further to my previous post a few weeks back about bodywork restoration, I still haven’t decided what to do. I’m in the process of getting another quote which I think will be cheaper than the 8K (sterling) I was quoted, but probably still around the 5.5K mark. One day soon I’ll have to make up my mind… Cheers, David P.S. My deepest comiserations to the poor guy who watched his XJS being destroyed in the hurricane! And we complain about OUR weather!! David Brown '67 Daimler 250 V8 brownd@ml.com ///_/_/_/_/////_///______ /_/_//_/_/_/_/_/____ /_/_/_/_/______/_/_/_/______ /_/_/_/_/_/_/________/_/_____ ___/_/_/////_/_/_/_/_/______ /_/___/_/_//_/_/_/____ ///_/_/_/____/////_///_________ From: hastings@frodo.eucom.mil (Craig R. Hastings) Date: Mon, 9 Sep 1996 13:34:22 GMT Subject: E-Type V12 floor panel Just a quick question for the E-Type Gurus out there. I’m looking at a 1973 V12 E-Type Coupe for possible purchase. One thing I noticed in a cursery inspection via pictures was that the floor panels underneath the carpets were a reddish color. Is this typical of the color painted? The car is painted Silver and I’m told that is the original color. If any more information is needed let me know. For those looking for an XK120. I have seen sveral listed on the net at www.specialcars.com Good Hunting. Craig Hastings 88 VDP From: traver@vnet.IBM.COM Date: Mon, 9 Sep 96 09:58:55 EDT Subject: Imperial Machining I used Imperial to sleeve several wheel cylinders and master cylinder on my Series 1. I am very satisfied with their quality of work and service. From: “Jim Cantrell” jimc@sysdiv.sdl.USU.edu Date: Mon, 9 Sep 1996 09:14:54 MDT Subject: Re: Radiator removal XJS Jim Isbell wrote:
You should replace these. They are rubber isolation mounts. If you
don’t, then two bad things will happen over time: 1) the metal to
metal contact will wear through your new radiator tanks eventually
springing a leak and 2) the direct mechanical mount transmits more
vibration to the core and your solder joints will prematurely debond
(primarily around the tak to frame pieces).
Kind Regards,
Jim Cantrell
Date: Mon, 09 Sep 96 08:21:04 PDT
Subject: Re: jag-lovers-digest V2 #337
The following is an attached File item from cc:Mail. It contains
information that had to be encoded to ensure successful transmission
through various mail systems. To decode the file use the UUDECODE
program.
- --------------------------------- Cut Here ---------------------------------
begin 644 TextItem.txt
M#0IJ86<M;&]V97)S+61I9V5S=“@("
@(”@4V%T=7)D87DL(#<@4V5P=&5M M8F5R(#$Y.38@("
@(%9O;‘5M92P,B
Z($YU;6)E<BS,S<-"@T*04L@36EL M;&5R($%U8W1I;VX@*$YO($IA9R!#;VYT96YT+"!B=70@=F5R>2!I;G1E<F5S M=&EN9RD-"E)E.B!!8F]U="!T:&4@;7ES=&5R:65S(&]F('1H92!82B!S97)I M97,-"E)E.B
Y-B!82E,@8V]N=BX-"E)E.B!O=F5R:&5A=&EN9PT4F4Z(%A
M4R!-:6-R;R!S=VET8V@@;VX@=&AR;W1T;&4-"E=H96X@=&AE(’-T=61E;G0@
M<W5R<&%S<V5S(‘1H92!T96%C:&5R+BXN+@T*)S<P(%A+12!I;G1A:V4@;6%N
M:69O;&0@&1U86P@4W1R;VUB97)G<RD@+2!Q=65S=&EO;B-"C0N,FP@86YD M('1R86YS;6ES<VEO;B!F;W(@<V%L90T*4F4Z(&]V97)H96%T:6YG#0I293H@ M5VAE;B!T:&4@<W1U9&5N="!S=7)P87-S97,@=&AE('1E86-H97(N+BXN#0I2 M93H@;W9E<FAE871I;F<-"C$Y.#4@6$HM4R!";&]W;B!(96%D($=A<VME=
T
M2’5R<FEC86YE($9R86X@+2!82E,@;&]W<FED97(@%(N22Y0+BD-"E)E.B!8
M2E,@36EC<F@<W=I=&-H(&]N('1H<F]T=&QE#0I293H@2&5J($UA='1H:6%S
M+T*4F4Z($%B;W5T('1H92!M>7-T97)I97,@;V8@=&AE(%A*('-E<FEE<PT* M4F4Z(%A*4R
M+2T@3V]P<R$A(2H82YK+F$N($-H87-S:7,@9F%I;'5R92D- M"@T*+2TM+2TM+2TM+2TM+2TM+2TM+2TM+2TM+2TM+2TM+2TM+2TM+2TM+2TM M+2TM+2TM+2TM+2TM+2TM+2TM+2TM+2TM+2TM+0T*#0I&<F]M.B!-:6-H865L M($9R86YK(#QM9G)A;FM
=V5S=&YE="YC;VT^#0I$871E.B!&<FDL(#8@4V5P
M(#$Y.38@,38Z,3@Z,S@@+3T,#
-"E-U8FIE8W0Z($%+($UI;&QE<B!!=6-T
M:6]N("A.;R!86<@0V]N=&5N=“P@8G5T('9E<GD@:6YT97)E<W1I;F<I#0H-
M"E1H:7,@=V5E:V5N9”!)('=I;&P@8F4@870@16%S="!/<F%N9V4@5FEL;&%G
M92P@5F5R;6]N="X@22!W:6QL(&)E(&%T=&5N9&EN9PT=&AE($%+($UI;&QE
M<B!E<W1A=&4@875C=&EO;BP@<G5N(&)Y($-H<FES=&EE<RX@#0H-“D-O;G-I
M9&5R(&EF('EO=2!W:6QL+”!-<BF($UR<R!!2R!-:6QL97(N($YO(&]B=FEO M=7,@;65A;G,@;V8@<W5P<&]R="P-"F%L=&AO=6=H(&AE(&1I9"!S;VUE=&AI M;F<@:6X@879I871I;VXN($%F=&5R(#8P('EE87)S(&]F(&9R=6=A;"!L:79I M;F<L('1H97D-"F)O=&@@<&%S<R!O;BX@5VAE;B!T:&4@=')U<W1E97,@97AA M;6EN92!T:&4@:&]U<V4L('1H97D@9&ES8V]V97(@)#$L,#
P+#P,
T:6X@
M9V]L9"!A;F0@<VEL=F5R(&)U;&QI;VXL(’-O;64@:6X@<V%F97,L(‘-O;64@
M:&ED9&5N(‘5N9&5R(&9L;V]R<RP@;W(@:6X-"G1H92!W86QL<RX@3VLL(’-O
M(’=H870@<VAO=6QD(‘1H:7,@:6YT97)E<W0@=&AE(&IA9R!L;W9E<G,(%=E
M;&P@:70@<V5E;7,-“G1H870@=&AI<R!C;W5P;&4@:&%D(&$@:&]B8GDZ('1H
M97D@=V5N=”!A<F]U;F0@=&AE(&-O=6YT<GD@8V]L;&5C=&EN9R!3=‘5T>@T*
M875T;VUO8FEL97,L(&%N9"!B=6EL9&EN9R!L:71T;&4@8F%R;G,@;VX@=&AE
M:7(@<’)O<&5R=‘D@=&@:&]U<V4@=&AE;2X-"E1H97)E(&%R92T-2!C87)S M(&%L=&]G971H97(L(&EN(&]R:6=I;F%L+"!D<FEV96X@8V]N9&ET:6]N.B!" M96%R8V%T<RP-"D)L86-K:&%W:W,L($16,S(@4W5P97)S+"!697)T:6-A;"
V
M)W,N(%-O;64@;V8@=&AE(&=R96%T97-T(&-A<G,@979E<B!B=6EL=T*:6X@ M06UE<FEC82X@(
T*#0I/:"P@=&AE>2!W:6QL(&%L<V@8F4@875C=&EO;FEN
M9R!-<BF($UR<R!-:6QL97(G<R!D86EL>2!D<FEV97)S.B!6;VQK<W=A9V5N M#0I"965T;&5S+@T*#0I)('=I;&P@8F4@=&%K:6YG('!L96YT>2!O9B!P:&]T M;W,L('-O(&EF(&%N>6]N92!W;W5L9"!L:6ME(&-O<&EE<RP@:G5S=
T92UM
M86EL(&UE('=I=&@@86X@861D<F5S<RX-"@T36EK92!&<F%N:PT*,3DV.2!%
M+51Y<&4@,BLR#0H@#0H-“B@("
T*#0H-"BTM+2TM+2TM+2TM+2TM
M+2TM+2TM+2TM+2TM+2TM+0T*#0I&<F]M.B!;VAN($YA<&]L:2\:F=N0&QI M+FYE=#X-"D1A=&4Z($9R:2P@-B!397
@,3DY-BQ-CHR,SHQ."
M,#0P,“H M1414*0T*4W5B:F5C=#H@4F4Z($%B;W5T('1H92!M>7-T97)I97,@;V8@=&AE M(%A*('-E<FEE<PT*#0I5;F1E<FYE871H('1H92!M>7-T97)I;W5S(&AO;&4@ M:7,@*&1R=6UR;VQL*2XN+BXN+BXN#0H-"BXN+BXN('1H92!I;G1E<FEO<B!T M96UP97)A='5R92!S96YS;W(@9F]R('1H92!A=71O;6%T:6,@8VQI;6%T92!C M;VYT<F]L#0IS>7-T96TA(2$A("!4:&ES(&)E='1Y(')E<&]R=',@:6YS:61E M('1E;7!E<F%T=7)E('1O('1H92!C;&EM871E(&-O;G1R;VP-"F)R86EN("AT M:&%T)W,@8F5I;F<@9V5N97)O=7,I+B
@02!S:6UI;&%R('-E;G-O<B!P<F]V
M:61E<R!O=71S:61E#0IT96UP97)A='5R92X@(%1H92!S>7-T96T@;F]T97,@
M=&AE(&1I9F9E<F5N=”!T96UP97)A='5R97,L('1H92!T96UP('EO=2=V90T
M<V5L96-T960@;VX@=&AE(&1I86P@8GD@=&AE(’)A9&EO+“!A;F0@=&AE(&]P
M97)A=&EN9R!M;V1E(“AF<F]M(‘1H92!S=VET8V@-“F]N('1H92!O=&AE<B!S
M:61E(&]F('1H92!R861I;RD@86YD(&1E8VED97,@=VAA=”!T;R!D;RX@($ET
M)W,@:6YS=’)U8W1I;VYS#0IA<F4@8V%R<FEE9”!O=70@8GD@=&AE('-E<G9O
M(“AF;&%P<R!O<&5N+V-L;W-E+”!E=&,N2X-"@T270@:7,@86QW87ES(&]N
M(‘1H92!S:61E(’=I=&@@=&AE(&=L;W9E8F]X+@T*#0I)9B!Y;W4@=V%N=”!T
M;R!A;FYO>2!A($IA9R!O=VYE<BP@<VQI<“!A('-L:79E<B!O9B!D<GD@:6-E
M('5P(‘1H97)E#0IO;B!A(’-U;6UE<B=S(&1A>2XN+BXN+BXN+BXN+BXN+BXN
M+BXN+@T*#0I296=A<F1S+T*#0I*;VAN#0H-"D]N($9R:2P@-B!397
@,3DY
M-BP@1&%V:60@5&]R9&]F9B!W<F]T93H-”@T*/B!7:&EL92!W92!A<F4@9&ES
M8W5S<VEN9R!C;VYT<F]L<RP@02]#(&5T8RX@0V%N(&%N>6]N92!T96QL(&UE
M(‘=H870@=&AE#0H^(’!U<G!O<V4@:7,@9F]R(‘1H92!S;6%L;“!H;VQE(&]N
M('1H92!U;F1E<G-I9&4@;V8@=&AE('1O<”!L:7@;V8@=&AE(&1A<V@_#0H- M"@T*+2TM+2TM+2TM+2TM+2TM+2TM+2TM+2TM+2TM+2TM#0H-"D9R;VTZ($1A M=FED($5N9V5L8F%C:"
=VED:4!A<G1N970N;F5T/@T1&%T93H@1G)I+“V M(%-E<"
Y-BQ,SHR,3HR-R
M,#<P,T*4W5B:F5C=#H@4F4Z(#DV(%A*4R!C M;VYV+@T*#0I)="=S(&$@,C,W($A0('-I>"X@(%1H97D@<W1O<"!P=71T:6YG M('1H92
Q,B!I;B!T:&4@6$I3(&EN(”<Y-“H8V]U;&0@8F4@#0HG.34I+B!4 M:&ES('-I>"!I<R!T;W)Q=6EE<B!T:&%N('1H92!O;&1E<B!S:7@@979E;B!T M:&]U9V@@=&AE(&AO<G-E<&]W97(@#0IR871I;F<@:7,@=&AE('-A;64N("!) M="!H86YD;&5S(&)E='1E<B!T:&%N('1H92
Q,B!B96-A=7-E(&ET)W,@;F]T
M(T*8V%R<GEI;F<@86X@97AT<F$@,C
P(&QB<RX@07,@9F%R(&%S(&5C;VYO
M;7D@+2!A<F4@>6]U<B!K:61D:6YG/R!)=”=S(&$@#0I86<N#0H-“E]?7U]?
M7U]?7U]?7U]?7U]?7U]?7U]?7U]?7U]?7U]?7U]?7U]?7U]?7U]?7U]?7U]?
M7U]?7U-“D1A=FED($,N($5N9V5L8F%C:”@("
@(“!%+6UA:6P@
M+2!W:61I0&%R=&YE=“YN970-“E9A;&QE>2!6:6QL86=E+”!#02Y,38P,2
M(”@("
@5F]I8V4@+2@(#@Q."XU,#8N-30T,0T*55-!("
@(“@ M("
@(”@($9A>"
M(“@.#$X+C4P-BXQ,#$Q#0I?7U]? M7U]?7U]?7U]?7U]?7U]?7U]?7U]?7U]?7U]?7U]?7U]?7U]?7U]?7U]?7U]? M7U]?7PT*#0H-"@T*#0HM+2TM+2TM+2TM+2TM+2TM+2TM+2TM+2TM+2TM+2T- M"@T*1G)O;3H@(DMI<F)E<G0B(#QP86QM:T!G8VXN<V-R:2YF<W4N961U/@T* M1&%T93H@1G)I+"
V(%-E<“Q.3DV(#$V.C,P.C,Y("TP,#
U#0I3=6)J96-T
M.B!293H@;W9E<FAE871I;F<-”@T36%T=&AI87,@1D]5455%5"U,05!!4CH-
M"CX@3&5T(&UE(&%S:R!A('-I;7!L92!Q=65S=&EO;BZ($ES(&ET(&YO="!E M;F]U9V@-"CX@=&\@;65A<W5R92!T:&4@:6X@86YD(&]U=&QE="!T96UP97)A M='5R92!O9B!T:&4@<F%D:6%T;W(@=&\@9FEG=7)E(&]U=
T/B!I9B!T:&4@
M<F%D:6%T;W(@:7,@=V]R:VEN9R!C;W)R96-T;‘D@;W(@;F]T/PT*#0I.;RP@
M:70@:7,@;F]T(0T*#0H^(%-O;65W:&5R92!)(’)E860@:6X@9V5N97)A;T* M/B!T:&4@<F%D:6%T;W(@<VAO=6QD(&1R;W
@=&AE('1E;7!E<F%T=7)E(&)Y
M(&%T(&QE87-T(#$P(&1E9W)E97,@0V5L<VEU<RX-”@T070@7VQE87-T7S@
M(%EO=2!C;W5L9"!A<R!E87-I;'D@:&%V92!S86ED(&%T(%]M;W-T7R$-"@T
M66]U(’-E92P@=&AE<F4@87)E(‘1W;R!C;VUM;VX@<’)O8FQE;7,@=VET:“!R
M861I871O<G,N(”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
T*;V9F+“!M96%N:6YG('1H92!R861I871O<B!H87,@
M;6]R92!T:6UE(‘1O(&-O;VP@=&AE(’-M86QL(&%M;W5N=”!O9B-"F-O;VQA M;G0@=&AA="!D;V5S(&=O('1H<F]U9V@N("!);B!T:&ES(&-A<V4L('1H92!D M:69F97)E;F-E(&)E='=E96X@#0IT:&4@:6YL970@86YD(&]U=&QE="!T96UP M<R!W:6QL(&=O(%50("TM('1H97)E('=O;B=T(&)E(&UU8V@@8V]O;&%N="
M"F9L;W=I;F<L(&)U=“!I=”!I<R!G971T:6YG(‘)E86QL>2!C;V]L+B@365A M;G=H:6QE+"!T:&4@96YG:6YE(&ES(
T9’)O<‘!I;F<@=F%L=F4@<V5A=’,A
M#0H-“B@+2T@2VER8F5R="
@("@268@86YY=&AI;F<@:7,@=&\@ M8F4@86-C;VUP;&ES:&5D+
T(“@("
@(”!S;VUE
M(’)U;&5S(&UU<W0@8F4@8G)O:V5N+@T*(“@("
M(”@("
@(“T@4&%L;2=S(%!O<W1U;&%T90T*#0HM+2TM+2TM+2TM+2TM+2TM
M+2TM+2TM+2TM+2TM+2T-”@T1G)O;3H@5&AO;6%S($%L8F5R=',@/'1A;&)E
M<G1S0&%E<F\N;V1U+F5D=3X-"D1A=&4Z($9R:2P@-B!397@,3DY-B
Q-CHT
M,SHU-RM,#0P,"
H14140T4W5B:F5C=#H@4F4Z(%A4R!-:6-R;R!S=VET
M8V@@;VX@=&AR;W1T;&4-“@T270@=V]U;&0@8F4@96%S>2!E;F]U9V@@=&@
M=')Y+B@22!T:&EN:R!K:6-K9&]W;B!C86X@8F4@:6YH:6)I=&5D(
T8GD@
M=&AE('9A8W5U;2!M;V1U;&%T;W(@86YD('1H92!T<F%N<R!G;W9E<FYE<BX@
M($]T:&5R=VES92!)(&1O;B=T#0IS964@:&]W('1H92!K:6-K9&]W;B!S97)V
M;R!C86X@=&5L;”!T:&4@9&EF9F5R96YC92!B971W965N(‘1H92-"FUI8W)O M('-W:71C:"!A;F0@>6]U(&]W;B!P=7-H8G5T=&]N+B
@%!O<W-I8FQY(&UU
M<W0@8F4@:6X@;W!E;BUL;V]P#0IM;V1E+BD-"@T5&AO;6%S($4N($%L8F5R
M=’,-“@T*/B!/2RP@<V@22!C86X@9V5T('!A<G0M=&AR;W1T;&4@:VEC:V1O
M=VX@8GD@861I;F<@82!P=7-H(&)U='1O;C-”@T*(T*(
T*#0HM+2TM+2TM
M+2TM+2TM+2TM+2TM+2TM+2TM+2TM+2T-“@T1G)O;3H@2F]H;B!.87!O;&D@
M/&IG;D!L:2YN970^#0I$871E.B!&<FDL(#8@4V5P(#$Y.38@,38Z-#4Z,C$@
M+3T,#
@$5$5"D-“E-U8FIE8W0Z(%=H96X@=&AE('-T=61E;G0@<W5R<&%S
M<V5S('1H92!T96%C:&5R+BXN+@T*#0I)(&AA=F4@82!F<FEE;F0@=VAO(&ES
M(&EN=&5R97-T960@:6X@875T;VUO8FEL97,L(&5S<&5C:6%L;'D@:&EG:&5R
M#0IP97)F;W)M:6YG(&QU>'5R>2!M86-H:6YE<RX@($9O<B!S;VUE('1I;64@
M22=V92!B965N(‘5R9VEN9R!H:6T@=&-“F-O;G-I9&5R(&$@2F%G(“AA;F0@
M:&4@:&%S(&)E96X@:V5P=”!U<”!T;R!D871E(&]N(&UY(&]W;B!82BU3#0IA
M9’9E;G1U<F5S2X-"@T5’=O(&UO;G1H<R!A9V\L(&AE(&-A;&QE9”!M92!U
M<“P@=&5L;&EN9R!M92!A8F]U=”!A('-W965T(”<X-R!82BU3(&AE#0IH860@
M<V5E;B!A9’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
T*;6EN=“!E>&%M
M<&QE+”!A;F0@:&4@9V]T(&ET(&9O<B!A(‘-O;F<N#0H-“E-O(&YO=RP@;V8@
M8V]U<G-E+”!))VT@9F5E;&EN9R!P<F5T=‘D@8F%D.B!H:7,@8V%R(&ES(&$@
M;&]T(&YI8V5R(‘1H86X-“FUI;F4A(”!.;W0@9F%I<B$@($)U=“!I=”!G971S
M(’=O<G-E(2$A#0H-"DET(’-E96US(‘1H870@:&4@86YD(&AI<R!W:69E(&%R
M92!R96=U;&%R<R!A="!A(’)E<W1A=7)A;G0@:6X@3F5W($IE0T86QS
M;R!F<F5Q=65N=&5D(&)Y(&$@V5N:6]R($IA9R!E&5C=71I=F4@&%P<&%R
M96YT;‘D@2F%G(&AA<PT*;V9F:6-E<R!S;VUE=VAE<F4@:6X@3F]R=&AE<FX@
M2F5R<V5Y2X@($UY(&9R:65N9"!A;F0@:&ES('=I9F4@87)E(&AA=FEN9PT
M9&EN;F5R+"!H879I;F<@9’)I=F5N(‘5P(&EN(‘1H96ER(“=N97<G(%A*+5,N
M(”!4:&5Y(&)R86<@86)O=70@=&AE:7(@8V%R#0IT;R!T:&4@<’)O<’)I971O
M<BP@=VAO(&EN=’)O9’5C97,@=&AE;2!T;R!T:&4@2F%G(&5X96,N(“!3:&4@
M:6X@='5R;B!S:&]W<PT*=&AE;2!T:&4@;&EG:'0@8FQU92!82C@@<VAE(&AA
M9”!T96UP;W)A<GD@8W5S=&]D>2!O9BX@($YO=“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
\1&%V
M:61?2E]3:&EE;&18V-M+F9M+FEN=&5L+F-O;3X-"D1A=&4Z($9R:2P@,#8@ M4V5P(#DV(#$T.C
T.CP(%!$5
T4W5B:F5C=#H@)S<P(%A+12!I;G1A:V4@
M;6%N:69O;&0@&1U86P@4W1R;VUB97)G<RD@+2!Q=65S=&EO;B-"@T*("
M(”!(:2!!;&PL#0H@(“@(
T*(”@("!4:&4@;W1H97(@9&%Y($D@=V%S(&QO M;VMI;F<@870@=&AE(&5N9VEN92!O9B!T:&4@)S<P($4@,BLR(&%N9"!)(&9O M=6YD(
T*(“@("!S;VUE=&AI;F<@<W1R86YG92X@($D@=V%S(&EN<W!E8W1I M;F<@=&AE(&=E;F5R86P@:6YT96=R:71Y(&]F('1H92
-“B@("
@=F%C=75M
M(&AO<V5S(&%N9”!W;VYD97)I;F<@=VAE=&AE<B!T;R!R97!L86-E('1H96T@
M86QL(&%S(&$@;6%T=&5R(&]F(T*("
@(”!C;W5R<V4@&%S('EO=2!R96-A
M;&PL($D@:G5S=“!B;W5G:'0@=&AI<R!C87(@9G)O;2!T:&4@3T@+2!/<FEG
M:6YA;”-"B
@(“@3W=N97(I+B
@22!T=6=G960@;VX@;VYE(&]F(‘1H92!H
M;W-E<R!A;F0@:&5R92=S(’=H97)E(&ET(&9E;&P@;V9F(&]F+”-"B
@(“@ M86YD('=H870@22!F;W5N9#H-"B
@(”@#0H@("
@($%T('1H92!B86-K(&5N
M9"!O9B!T:&4@;6%N:69O;&0@‘1H:7,@<W1R86YG92!T:&EN9R!T:&%T(’)O
M=71E<R!T:&4@#0H@(“@(&UI>'1U<F4@=&AR;W5G:"!A(&QO;F<L(&AE871E M9"!P871H(&%T(&QO=R!T:')O='1L92!A;F0@8GEP87-S97,@=&AA="
-“B@ M("
@;&]N9R!P871H(&%T(&AI9V@@=&AR;W1T;&4I+”!T:&5R92!A<F4@='=O
M(&-O;VQA;G0@9FET=&EN9W,N(”!);B-"B
@("@8F5T=V5E;BP@=&AE<F4@ M:7,@82!S;6%L;"
H8G)A<W,2!P:7!E+“!O=F5R('=H:6-H(&ES(&$@=F%C
M=75M(&AO<V4@#0H@(”@('1H870@=')A=F5L<R!T;R!T:&4@86ER(&-L96%N M97(@8F]X+B
@5&AA=“!P87)T:6-U;&%R(&9I='1I;F<@:&%S(&)E96X@#0H@
M(”@(&-R:6UP960@8VQO<V5D+"!A;F0@;&]O:W,@:VEN9"!O9B!C;W)R;V1E M9"
H8FQU92DN(“!4:&4@8V]O;&%N=”-"B
@(“@9FET=&EN9W,@87)E(&EN M=&%C="!A;F0@;&]O:R!H87!P>2X-"B
@(”@#0H@("
@(%=H870@:7,@=&AI
M<R!F:71T:6YG(&%N9"!W:&%T(&9U;F-T:6]N('-H;W5L9"!I="!P97)F;W)M
M/PT("@("
-"B@("
@5&AI<R!I<R!A;B!E;6ES<VEO;BUC;VYT<F]L;&5D
M("AK:6YD82D@8V%R(’=I=&@@9’5A;“!3=')O;6)E<F=S+”!I9B-"B
@(“@ M=&AA="!H96QP<RX-"B
@(”@#0H@("
@($D@<W1A<G0@;7D@.“UW965K('-A
M8F)A=&EC86P@;VX@36]N9&%Y(%!-+B@22!B;W5G:'0@86X@12!A;F0@86ER M(
T*(”@("!T;V]L<R!F;W(@;7D@8FER=&AD87DN("!296%D>2!F;W(@9G5N M+@T*("
@(“-"B
@(”@5&AA;FMS+@T*("
@(“-"B
@(”@1&%V:60@#0H@ M("
@(“<W,”!82T4@,BLR(‘=I=&@@86)O=F4M;65N=&EO;F5D(’!R;V)L96T@
M+2!M87EB92!N;R!P<F]B;&5M/PT*(“@("
G.#0@6$HV(%9$4”-"B
@(“@ M#0H-"BTM+2TM+2TM+2TM+2TM+2TM+2TM+2TM+2TM+2TM+0T*#0I&<F]M.B!R M<V=A;&QO0&EX+FYE=&-O;2YC;VT-"D1A=&4Z($9R:2P@,#8@4V5P(#$Y.38@ M,38Z-#0Z-3@@+3
W,#-"E-U8FIE8W0Z(#0N,FP@86YD('1R86YS;6ES<VEO M;B!F;W(@<V%L90T*#0I4;R!A;&PZ($D@:&%V92!A(#0N,FP@238@9F]R('-A M;&4@=VET:"!A=71O=')A;G,N($ET('=A<R!R96UO=F5D(&9O<B!A(
T8V]N
M=F5R<VEO;BH;F]T(&)Y(&UE*2X@270@:&%S('1H92!T>7!I8V%L(&AE860@ M<')O8FQE;7,@=VET:"!F;'5I9"
-“FQE86MA9V4N($D@=V]U;&0@;&EK92!T
M;R!F:6YD(&$@9V]O9”!H;VUE+B!-86ME(&]F9F5R+B!-:60M36ES<V]U<FDL
M(%5302-"FQO8V%T:6]N+B!4:&%N:W,@0F]B($=A;&QO+"!R<V=A;&QO0&EX M+FYE=&-O;2YC;VT-"@T*+2TM+2TM+2TM+2TM+2TM+2TM+2TM+2TM+2TM+2TM M#0H-"D9R;VTZ(%!E=&5R($-A<G!E;G1E<B
,3V,C4W+C,S,S1
0V]M<'53
M97)V92Y#3TT^#0I$871E.B!&<FDL(#8@4V5P(#$Y.38@,3<Z-#0Z-3@+3
T
M,#-"E-U8FIE8W0Z(%)E.B!O=F5R:&5A=&EN9PT*#0H^/E1H97)E(&AA=F4@ M8F5E;B!S979E<F%L('!R;V)L96US('=I=&@@;W9E<FAE871I;F<@96YG:6YE M<R!A;F0@<75E<W1I;VYS#0H^/F-O;F-E<FYI;F<@<F%D:6%T;W)S+B!,970@ M;64@87-K(&$@<VEM<&QE('%U97-T:6]N(#H@27,@:70@;F]T(&5N;W5G:
T
M/CYT;R!M96%S=7)E('1H92!I;B!A;F0@;W5T;&5T('1E;7!E<F%T=7)E(&]F
M(‘1H92!R861I871O<B!T;R!F:6=U<F4@;W5T#0H^/FEF(‘1H92!R861I871O
M<B!I<R!W;W)K:6YG(&-O<G)E8W1L>2!O<B!N;W0@/R!3;VUE=VAE<F4@22!R
M96%D(&EN(&=E;F5R86P-"CX^=&AE(’)A9&EA=&]R(’-H;W5L9”!D<F]P('1H
M92!T96UP97)A=‘5R92!B>2!A="!L96%S=“Q,"!D96=R965S($-E;'-I=7,N M#0H-"CX^+2
M($UA='1H:6%S#0H-”@T2&DL($D@86T@<W5R92!N;VYE(&]F
M(‘EO=2!W86YT(‘1O(&AE87(@86)O=70@;7D@5%92(&%G86EN+“!B=70@:&5R
M92!I=T*8V]M97,N($UY('1E;7
@;65A<W5R96UE;G1S(&9O<B!I;G!U=”!A
M;F0@;W5T<‘5T(&UA9&4@:70@<V5E;2!A<R!T:&]U9V@@=&AE#0IR860@=V%S
M(&)E:&%V:6YG(’!E2X@5&AE(&5N9VEN92!S=&EL;“!O=F5R:&5A
M=&5D+B!”=70@=&AE(’)A9"!W87,-“G!A2!B;&]C:V5D(&9O<B!W
M871E<B!A;F0@86ER.B!T:&4@<VUA;&P@86ER+69L;W<@8V]O;&5D('1H92!S
M;6%L;T*=V%T97(M9FQO=R!J=7-T(')I9VAT+@T*07,@>6]U('-A>2
M('1H
M97)E(&AA=F4@8F5E;B!A(&QO=”!O9B!O=F5R:&5A=&EN9R!P<F]B;&5M<R!R
M96-E;G1L>2P@86YD#0IT:&5R92!J=7-T(&1O;B=T(’-E96T@=&@8F4@86YY
M(‘-H;W)T(&-U=’,@;W(@96%S>2!F:7AE<RXN+@T#0I0971E<B!#87)P96YT
M97(-"C$Y-C<@-#(P(T*54L-"@T*+2TM+2TM+2TM+2TM+2TM+2TM+2TM+2TM M+2TM+2TM#0H-"D9R;VTZ("),964@5V%L9&5N(B
;’=A;&1E;D!E8FUU9"YC
M;VT^#0I$871E.B!&<FDL(#8@4V5P(#$Y.38@,34Z,#@Z-#4@+3W,#
-“E-U
M8FIE8W0Z(%)E.B!7:&5N('1H92!S=‘5D96YT(’-U<G!A<W-E<R!T:&4@=&5A
M8VAE<BXN+BX-”@T2F]H;B!W<F]T93H-"BT@+2TM+2TM+2TM+0T/B-"CX@ M37D@9G)I96YD(&UE;G1I;VYS('1O(&AE<B!T:&%T(&AE('=A<R!I;G1E<F5S M=&5D(&EN(&]B=&%I;FEN9PT*<V5R=FEC90T*/B!M86YU86QS+B
@06YD('1H
M92!N97AT(‘1I;64@:&4@86YD(&AI<R!W:69E(‘9I<VET(‘1H90T*<F5S=&%U
M<F%N=“P@=VAA=”!D;PT*/B!Y;W4@=&AI;FL@:7,@=V%I=&EN9R!F;W(@=&AE
M;3_/R@5VAY+"!A(&=I9G0M=W)A<'!E9"P-"F-O;7!L971E(&%N9
T*/B!C
M;VUP;&EM96YT87)Y(’-E="!O9B!F86-T;W)Y(&UA;G5A;’,A#0H^(T*#0I- M>2!B<F]T:&5R('1O;&0@;64@=&AA="!S;VUE(&=U>2!O9F9E<F5D($QO='5S M(&$@9&5A;"!T;R!P=70-"F%L;"!O9B!T:&4@<V5R=FEC92!M86YU86QS(&9O M<B!T:&4@17-P<FET(&]N(&$@0T0M4D]-+B
@5&AE>2-"B)R97=A<F1E9"(@ M:&EM('=I=&@@82!B<F%N9"!N97<@17-P<FET(%1U<F)O+B
@5&%L:R!A8F]U
M=T*;F]T(&9A:7(N+BX-"DQE90T*#0HM+2TM+2TM+2TM+2TM+2TM+2TM+2TM M+2TM+2TM+2T-"@T*1G)O;3H@(DQE92!786QD96XB(#QL=V%L9&5N0&5B;75D M+F-O;3X-"D1A=&4Z($9R:2P@-B!397
@,3DY-BQ-3HQ-SHQ-"
M,#<P,T* M4W5B:F5C=#H@4F4Z(&]V97)H96%T:6YG#0H-"DMI<F)Y('=R;W1E.@T*#0H^ M(%EO=2!S964L('1H97)E(&%R92!T=V\@8V]M;6]N('!R;V)L96US('=I=&@@ M<F%D:6%T;W)S+B
@3VYE(&ES#0IT:&%T#0H^(‘1H97D@9V5T(&-R=61D960@
M=7L(&)O=&@@=VET:"!D97!O<VET<R!O;B!T:&4@:6YN97(@<W5R9F%C97,- M"F]F('1H90T*/B!T=6)E<R!A;F0@=VET:"!M=60@86YD(&)U9W,@<W1U8VL@ M;VX@=&AE(&]U='-I9&4N("!%:71H97(@;V8-"G1H97-E#0H^('!R;V)L96US M('=I;&P@<F5D=6-E('1H92!C;V]L:6YG(&]F('1H92!W871E<B!F;&]W:6YG M('1H<F]U9V@L#0IA;F0-"CX@=&AE(&1I9F9E<F5N8V4@8F5T=V5E;B!I;FQE M="!A;F0@;W5T;&5T('1E;7!E<F%T=7)E('=I;&P@9V\-"D1/5TX@+2T-"CX@ M:70G;&P@8F4@8V]M:6YG(&]U="!N96%R;'D@87,@:&]T(&%S(&ET('=E;G0@ M:6XN("!!(')E9'5C=&EO;@T*:6X-"CX@86ER9FQO=R
M+2!F;W(@=VAA=&5V
M97(@<F5A<V]N("TM(’=I;&P@:&%V92!T:&4@<V%M92!E9F9E8W0L#0IA;F0-
M"CX@=&AI<R!M87D@;F]T(&5V96X@8F4@=&AE(’)A9&EA=&]R)W,@9F%U;‘0L
M(‘1H92!F86X@;6%Y(&)E#0ID969E8W1I=F4N#0H-"EEO=2!A;’-O(’-H;W5L
M9"!S=&%T92!T:&%T(‘EO=2=L;“!T<F%N<V9E<B!M;W)E(&AE870@96YE<F=Y
M(&)Y#0II;F-R96%S:6YG('1H92!F;&]W(‘1H<F]U9V@@=&AE(’)A9&EA=&]R
M+B@92YG+@T*#0I/;B!A('-O;&%R('-W:6UM:6YG('!O;VP@:&5A=&5R+"!A M="!A('-L;W<@9FQO=R!R871E('1H90T*=&5M<&5R871U<F4@9&5L=&$@;V8@ M=&AE(&EN;&5T('9S+B!O=71L970@=VEL;"!B92!V97)Y(&AI9V@L(&)U=
T*
M>6]U)VQL(&=E=”!A(&)E=‘1E<B!H96%T(‘1R86YS9F5R(’)A=&4@870@:&EG
M:&5R(&9L;W<@<F%T97,N(T*5&AE('=A=&5R('1E;7
@870@=&AE(&]U=&QE
M=“!W;VXG=”!B92!M=6-H(&=R96%T97(@=&AA;B!T:&4-“FEN;&5T(&)U=”!T
M:&4@96YE<F=Y(‘1R86YS9F5R(’=I;&P@8F4@9W)E871E<B!F;W(@86YY(&=I
M=F5N#0IP97)I;V0@;V8@=&EM92X-“@T0F5S=“!B970@:7,@=&@<&5R9F]R
M;2!A(‘)E=F5R<V4@9FQU<V@@;V8@=&AE(’-Y<W1E;2!A;F0@:&5A=&5R#0IC
M;W)E(&%T(&QE87-T(&5V97)Y(‘1W;R!Y96%R<RP@86YD(&$@<F5F:6QL(’=I
M=&@@82!G;V]D(#4P+S4P#0IM:7@@;V8@86YT:69R965Z92X-”@T3&5E#0H-
M"BTM+2TM+2TM+2TM+2TM+2TM+2TM+2TM+2TM+2TM+0T*#0I&<F]M.B!”<F5N
M=“!%86=L:6YG(#QB<F5N=$!F:6QO;&DN8V]M/@T1&%T93H@1G)I+"@-B!3 M97
@.38@,34Z-#$Z-38@+3W,#
-“E-U8FIE8W0Z(#$Y.#4@6$HM4R!”;&]W
M;B!(96%D($=A<VME=T*#0I,861I97,@86YD($=E;G1S+
T#0I)(&AA=F4@
M86X@;W!P;W)T=6YI='D@=&@<'5R8VAA<V4@82Q.3@U(%A*+5,@(&9O<B
D
M,RPP,#@55-$+B
@270G<R!I;B@#0IE>&-E;&QE;G0@8V]N9&ET:6]N('=I M=&@@.#
L,#P(&]R9VEN86P@;6EL97,N("!)<R!I="!W;W)T:"!I="!T;R!M M97-S("
-“G=I=&@@=&AE(&)L;W=N(&AE860@9V%S:V5T/R@5VAA="!C;W-T M('=O=6QD($D@8F4@;&]O:VEN9R!A="!T;R!R97!A:7(@:70_("
-“B!)<R!I
M=”!A(&1I9F9I8W5L=”!J;V(#0H-“D%N>2!I;G!U=‘,O<F5C;VUM96YD871I
M;VYS(’=O=6QD(&)E(&=R96%T;‘D@87!P<F5C:6%T960N#0H-"BT@+2TM0G)E
M;G0-"C$Y-3,@6$LM,3(P($]44PT*,3DU-2!65R!"965T;&4@0V]N=F5R=&EB
M;&4@#,V(‘=O<’!I;F<@2&]R<VEE<R$I#0HQ.3@V($)-5RU,S5I#0H-"BTM M+2TM+2TM+2TM+2TM+2TM+2TM+2TM+2TM+2TM+0T*#0I&<F]M.B!*=6QI86YS M96%N0&%O;"YC;VT-"D1A=&4Z($9R:2P@-B!397
@,3DY-BQ.#HT,3HS,R
M
M,#0P,T*4W5B:F5C=#H@2'5R<FEC86YE($9R86X@+2!82E,@;&]W<FED97(@ M*%(N22Y0+BD-"@T*2'5R<FEC86YE($9R86X-"E1O('1H92!*86<M;&]V97)S M(&UA:6QI;F<@;&ES="X@(
T29)V92!N979E<B!E>’!E<FEE;F-E9”!A(&AU
M<G)I8V%N92!B969O<F4@<V@=&AE(&9E96QI;F<@;V8@<&]W97)L97-S;F5S
M<R!I<PT*<W1R86YG96QY(&EN=&5R97-T:6YG+B@2722<R
T.CP($%-(&%N M9"!T:&4@=VEN9"!I<R!S=&EL;"!B=6EL9&EN9RX@($YO=&AI;F<-"F-A;B!S M=&]P(&ET+B
@16%R;&EE<B!T:&ES(&5V96YI;F<@22!D96QI8F5R871E9"!O
M;B!W:&%T(‘1O(&1O(‘1O(’!R97!A<F4@9F]R#0I&<F%NDG,@;&%N9&9A;&PN
M("!)(&-O=F5R960@;7D@6$I3(’=I=&@@=&AE(&-O=F5R(&%N9"!T=V@=&%R
M<‘.2(‘1I960@9&]W;@T*<F5A;&QY(’=E;&P@=VET:“!R;W!E+B@22!T:&]U M9VAT(&QO;F<@86YD(&AA<F0@86)O=70@=VAE<F4@=&\@<&]S:71I;VX@=&AE M#0IC87(@:6X@=&AE(&1R:79E=V%Y('1O(&UI;FEM:7IE('1H92!P;W-S:6)I M;&ET>2!O9B!T<F5E<R!F86QL:6YG(&]N(&ET+B
@20T*:&%V92!L;W1S(&]F
M(&AU9V4@;V%K('1R965S(&EN('1H92!Y87)D+”!B=70@;F@9V%R86=E+B@ M22!W;W5L9"!H879E(&1R:79E;@T*=&AE(&-A<B!E;'-E=VAE<F4@;W5T(&]F M(&AA<FV2<R!W87D@8G5T($D@8V%NDG0@9')I=F4@:70N("!)="!J=7-T(&-A M;64@8F%C:PT*9G)O;2!T:&4@8F]D>2!R97-T;W)A=&EO;B!S:&]P(&%N9"!) M(&AA=F5NDG0@:&%D(&-H86YC92!T;R!P=70@=&AE(&EN=&5R:6]R#0IB86-K M(&EN+B
@4V\L($D@8VAO;W-E(‘1O(&UO=F4@:70@=&@=&AE(&5N9"!O9B!T
M:&4@9’)I=F5W87D@9G5R=&AE<W0@9G)O;0T*=&AE(‘1R965S(&%N9"!T:&5N
M(’!A<FME9"!M>2!)<W5Z=2!T<F]O<&5R(&%N(&$@=F%I;B!P<F]T96-T:79E
M(’-T86YC90T*=&AI;FMI;F<@:70@8V]U;&0@<&5R:&%P<R!O9F9E<B!S;VUE
M(‘!R;W1E8W1I;VX@87,@82!S86-R:69I8VEA;“!S:&EE;&0N#0I#86UE(&EN
M+”!S971T;&5D(&EN(&9O<B!T:&4@9’5R871I;VX@:&%D(&$@8F5E<BX@(%1H
M96X@=&AE(’=I;F1S(‘-T87)T960-"F)U:6QD:6YG+B@5&AI;F=S('-T87)T M960@:&ET=&EN9R!T:&4@<F]O9BX@($D@=V%L:V5D(&]U='-I9&4@;VYC92!A M;F0@8V%M90T*8F%C:R!I;B!B96-A=7-E('1R964@8G)A;F-H97,@=V5R92!F M;'EI;F<@979E<GEW:&5R92X@($D@:VYE=R!T:&%T('-O;64@;V8-"G1H92!T M<F5E<R!W97)E(&QI:V5L>2!T;R!F86QL+B
@5&AE>2!W97)E(&IU<W0@=&]O
M(&)I9RP@=&]O(&]L9"P@86YD(&QE86YI;F<-“FIU<W0@82!B:70@=&]O(&UU
M8V@N(”!4:&4@9FER<W0@;VYE(’-O=6YD960@;&EK92!D:7-T86YT(‘1H=6YD
M97(@87,@:70-“F-R86-K960@=&AE;B!A(&AO<G)E;F1O=7,@9G)I9VAT(&%S
M(&ET(&AI=”!T:&4@<F]O9B!O9B!T:&4@:&]U<V4N(“!”>2!N;W<@=&AE#0IP
M;W=E<B!W87,@;V9F(&%N9"!T:&5R92!W87,@;F@;&EG:‘0@;W5T<VED92X@
M($D@<&5E<F5D(&]U="!O9B!T:&4@=VEN9&]W(&%N9T*8V]U;&0@8F%R96QY M('-E92!T:&4@2F%G+"!B=70@:70@;&]O:V5D($]++B
@22!S8W)A;6)L960@
M=7@:6X@=&AE(&%T=&EC('1O#0IB<FEN9R!D;W=N('1H92!S96%T<RP@;F5W M(&-A<G!E="P@9&%S:"!E=&,N('=H97)E($D@:&%D(&)E96X@<W1O<FEN9R!T M:&5M+@T*(%1H92!T<F5E(&AA9"!P=6YC='5R960@=&AE(')O;V8@86YD(')A M:6X@=V%S('!O=7)I;F<@:6XN("!7:&EL92!)('=A<R!U<
T*=&AE<F4@=&AE
M(’-T;W)M(&EN=&5N<VEF:65D(&%N9"!)(&AE87)D(&%N;W1H97(@=’)E92!F
M86QL+B@5&AE('=I;F0@<V5E;7,@=&\-"F)E(&=O:6YG(&EN(&-Y8VQE<R!U M<"!A;F0@9&]W;B!W:71H('-O;64@<F5G=6QA<FET>2X@(%-H:6YG;&5S('=E M<F4@<W1R97=N#0II;G-I9&4@=&AE(&%T=&EC+B
@22!K;F5W(‘1H:7,@=V%S
M(‘9E<GD@<V5R:6]U<R!N;W<N(“!)('1R:65D(‘1O(‘1I;64@<75I8VL-"G-P
M<FEN=’,@:6YT;R!T:&4@871T:6,@=&@9F5T8V@@<&%R=’,@9’5R:6YG('1H
M92!L=6QL<R!I;B!T:&4@<W1O<FTN(”!7:&5N($D-“F]P96YE9”!T:&4@9G)O
M;G0@9&]O<B!O9B!T:&4@:&]U<V4@22!W87,@9W)E971E9"!B>2!A(‘1R964@
M=’)U;FLN("!087)T(&]F#0IT:&4@<F]O9B!H860@8F5E;B!T;W)N(&]F9B!A
M;F0@=&AE(’-I9&4@9&]O<B!W87,@8FQO8VME9"!B>2!A(‘1R964N("!)(’=A
M<PT86-T=6%L;'D@:6UP<FES;VYE9"!I;B!M>2!O=VX@:&]U<V4@=VET:“!N
M;R!P;W=E<BP@;F@=&5L97!H;VYE+”!N;R!R861I;RX-“B!)<V]L871E9”!A
M;F0@<&]W97)L97-S+B@22!T<FEE9"!S=&%B8FEN9R!A="!T:&4@;W5T<VED M92!D87)K;F5S<R!W:71H('1H90T*9FQA<VAL:6=H="!T:')O=6=H('1H92!B M<F]K96X@9VQA<W,@=VEN9&]W<RP@8G5T('1H92!D<FEV:6YG(')A:6X@;6%D M92!I=
T:6UP;W-S:6)L92!T;R!S964@=VAA=“!W87,@9V]I;F<@;VXN(”!3
M=’)A;F=E;‘DL(‘1H92!B97-T(’=A>2!T;R!S964@=V%S(‘1O#0IT=7)N(‘1H
M92!F;&%S:&QI9VAT(&]F9B!A;F0@=V%I=“!F;W(@86X@;V-C87-I;VYA;”!C
M87(@=&@<&%S<R!B>2H>65S+"!S;VUE#0IP96]P;&4@=V5R92!S=&EL;"!D M<FEV:6YG(2DN("!4:&ES('=A>2!)(&-O=6QD(&UA:V4@;W5T('1H92!S:6QH M;W5E='1E(&]F('1H90T*=')E97,@9G)O;2!T:&4@:&5A9&QI9VAT<R!A;F0@ M<V5E('=H870@=V%S('-T:6QL('-T86YD:6YG+B
@5’=O(#8@9F]O="!D:6$N
M#0IO86MS(’=E<F4@;F]T(’=H97)E('1H97D@=7-E9"!T;R!B92!A;GEM;W)E
M+B@3VYE(&]F('1H96T@=V%S(&QY:6YG('-Q=6%R96QY#0IA8W)O<W,@=&AE M($IA9RX@($$@=V%V92!O9B!S:6-K;F5S<R!S=V5P="!O=F5R(&UE+B
@16%C
M:“!P87-S:6YG(&-A<B!P<F]D=6-E9T*82!F;&%S:"!I;6%G92!O9B!T:&4@ M8W)U<VAE9"!C87(@=6YT:6P@9FEN86QL>2!)(&)E;&EE=F5D(&ET("T@:70@ M=V%S(&=O;F4N#0H@22!C86YN;W0@9&5S8W)I8F4@=&AE(&9E96QI;F<@;V8@ M:VYO=VEN9R!T:&%T(&%L;"!T:&4@:&]U<G,@;V8@=V]R:R!A;F0@8V%R90T* M=&\@<F5S=&]R92!E=F5R>2!B:70@;V8@=V]O9"!A;F0@;&5A=&AE<B!R=7-T M(&%N9"!B;VQT(&%N9"!B=7-H:6YG(&AA9"!J=7-T#0IB965N(&%N;FEH:6QA M=&5D(&EN(#(@<V5C;VYD<RX@($ET(&AA<R!N;W1H:6YG('1O(&1O('=I=&@@ M=&AE(&UO;F5Y+@T*29)M('-U<F4@:722<R!T;W1A;&QE9"X@(
T5&AE('-I
M8VME<W0@<&%R=“!I<R!T:&%T(&IU<W0@;&%S=”!W965K(&UY(&EN<W5R86YC
M92!A9V5N=“!T;VQD(&UE('1H870@=&AE#0IC87(@:&%D('1O(&)E(#$P('EE
M87)S(&]L9”!T;R!G970@:6YC<F5A<V5D(&EN<W5R86YC92!C;W9E<F%G92X@
M($D@=V]U;&0@:&%V90T8F5E;BQ,"!I;B!*86YU87)Y+@T*06YY(&9E961B M86-K(&]N(&%D=FEC92P@=&\@:V5E<"!F;W(@<&%R=',@;W(@;F]T+"!M87)K M970@=F%L=65S("A)DFQL(&AA=F4@=&\-"F1E86P@=VET:"!I;G-U<F%N8V4@ M<&5O<&QE*2!W;W5L9"!B92!M=6-H(&%P<')E8VEA=&5D+B
@#0I”>2!T:&4@
M=V%Y+“!W87-NDG0@<V]M96]N92!S96QL:6YG(&$@8V]N=F5R=&EB;&4@6$I3
M(&]N('1H:7,@;&ES=”!N;W0@=&]O#0IL;VYG(&%G;S_(“!)(&9O<F=O=”!W
M:&@:70@=V%S(&)U=“!P;&5A<V4@8V]N=&%C=”!M92X-“E1H86YK<R!F;W(@
M;&ES=&5N:6YG+@T*#0I*=6QI86X@375L;&%N97D-“C$Y.#<@6$I3($-O;G9E
M<G1I8FQE(“H;F]W('=I=&@@5D5262!L;W<@<FED92!H96EG:'0I#0H-"@T* M+2TM+2TM+2TM+2TM+2TM+2TM+2TM+2TM+2TM+2TM#0H-"D9R;VTZ(")+:7)B M97)T(B
<&%L;6M9V-N+G-C<FDN9G-U+F5D=3X-"D1A=&4Z($9R:2P@-B!3 M97
@,3DY-BQ.#HU,3HP-B
M,#P-0T*4W5B:F5C=#H@4F4Z(%A*4R!-:6-R M;R!S=VET8V@@;VX@=&AR;W1T;&4-"@T*/B
^475E<W1I;VXZ(”!W:6QL(&$@
M<'5S:&)U='1O;B!W:7)E9”!I;B!P87)A;&QE;”!W:71H(‘1H:7,@<W=I=&-H
M(&%N9T*/B
^8V]N=’)O;&QE9"!S;VUE:&]W(&)Y(‘1H92!D<FEV97(@<’)O
M=FED92!P87)T+71H<F]T=&QE(&MI8VMD;W=N/R@3W(@9&]E<PT*/B
^=&AE
M(&5L96-T<FEC(&MI8VMD;W=N(&]N;‘D@=V]R:R!I9B!T:&4@=’)A;G-M:7-S
M:6]N(&ES(&%L<V@<V5E:6YG('IE<F-“CX@/G9A8W5U;2!A=”!T:&4@;6]D
M=6QA=&]R("AF<F]M(%=/5"D#0H-“D]F(&-O=7)S92P@=&AI<R!B96=S('1H
M92!Q=65S=&EO;CH@(%=H>2!W;W5L9”!Y;W4@=V%N=”!T;R!D;R!S=6-H(&$@
M#0IT:&EN9S@(%EO=2!C86X@86QW87ES(&IU<W0@<‘5L;“!T:&4@<VAI9G1E
M<B!I;G1O(#)N9"X-“B-"CX@5VAE;B!T:&4@:VEC:V1O=VX@<W=I=&-H(&]N M(&UY("<X-2!82BU3('=E;G0@8F%D($D@8V]U;&1N)W0@9V5T('1H90T*/B!T M<F%N<VUI<W-I;VX@;W5T(&]F(&9I<G-T(&=E87(L(')E9V%R9&QE<W,@;V8@ M=&AE('-P965D(&]F('1H92!C87(@;W(-"CX@86UO=6YT(&]F('1H<F]T=&QE M(&1E<')E<W-I;VXN("!4:&4@9F%I;'5R92!M;V1E(&]F('1H92!S=VET8V@@ M=V%S#0H^('1H870@=&AE(&YO<FUA;"UO<&5N(&-O;G1A8W1S(&YE=F5R(&]P M96YE9"X-"@T*0V]O;"$@($%T(&QE87-T('EO=7(@:VEC:V1O=VX@<V]L96YO M:60@=V]R:V5D+B
@36EN92!N979E<B!M861E(&%N>2-"F1I9F9E<F5N8V4@ M870@86QL+"!Y;W4@8V]U;&0@=&%K92!T:&4@<W=I=&-H(&]U="!A;F0@=&AR M;W<@:70@;W9E<B
-“GEO=7(@<VAO=6QD97(@9F]R(&%L;”!T:&4@969F96-T
M(&ET(&AA9"X-”@T*(“M+2!+:7)B97)T("
@(”!(”@("!)9B!A;GET:&EN M9R!I<R!T;R!B92!A8V-O;7!L:7-H960L#0H@("
@(‘P@
M(“@('-O;64@<G5L97,@;75S="!B92!B<F]K96XN#0H@("
@(“@ M("
@('P@(”@("
@(“@+2!086QM)W,@4&]S='5L871E#0H-"BTM+2TM+2TM M+2TM+2TM+2TM+2TM+2TM+2TM+2TM+0T*#0I&<F]M.B
B2VER8F5R=”(@/’!A
M;&UK0&=C;BYS8W)I+F9S=2YE9’4^#0I$871E.B!&<FDL(#8@4V5P(#$Y.38@
M,3@Z-3$Z,#8@+3P,#4-"E-U8FIE8W0Z(%)E.B!(96H@36%T=&AI87,L#0H- M"DIE9F9E>2!G<F%M.@T*/B!S=')O;F=L>2!)(&)E;&EE=F4@=&AE(&%R<F%N M9V5M96YT(&]F('1H92!W871E<G!U;7
-“CX@=VET:”!T;V@;&ET=&QE(&-A
M<&%C:71Y+BXN#0H-“DAE>2P@22=M('1H92!O;F4@=VET:”!T:&4@6$HM4R!T
M:&%T(&AA<R!A8G-O;‘5T96QY(&YO(‘1E;F1E;F-Y(‘1O(T*;W9E<FAE870N M("!/;F4@=&AI;F<@22!S=7!P;W-E($D@<VAO=6QD(&YO=&4Z("!/;F4@=&EM M92P@=VAI;&4@#0IF:61D;&EN9R!A<F]U;F0@=VET:"!T:&4@=V%T97(@<'5M M<"P@22!C<F%C:V5D('1H92!C87-T(&ER;VX@#0II;7!E;&QE<BX@(%1O;R!C M:&5A<"!A;F0@=&]O('-T=6)B;W)N('1O(&IU<W0@9F]R:R!O=F5R('1H92
D
M)“0@9F]R(&$@#0IN97<@;VYE+”!)(’=E;G0@9&]W;B!T;R!T:&4@;&]C86P@
M:G5N:WEA<F0@86YD(&=O=“!O;F4@;V9F(&%N($],1”-"D-H979Y('=A=&5R M<'5M<"X@(%1H92!I;7!E;&QE<G,@=&AE;7-E;'9E<R!W97)E('9E<GD@<VEM M:6QA<B!I;B!S:7IE(
T86YD(‘-H87!E+“!C;&]S92!E;F]U9V@@=&AA=”!T
M:&4@0VAE=GD@;VYE(’=O=6QD(&9I=“X@($ET('=A<R!A(‘1I;GD@#0IH86ER
M(’-M86QL97(@:6X@9&EA;65T97(L(&YO(&UO<F4@=&AA;BQ+S@B(&%S($D@ M<F5C86QL+"!W:&EC:"!H87,@86X@#0IE9F9E8W0@;VX@8V5N=')I9G5G86P@ M<'5M<',@8G5T($D@=V%S;B=T(&=O;FYA('-W96%T(&ET+B
@270@86QS;R!W
M87,@#0IN;W0@<75I=&4@87,@9&5E<”!A<R!T:&4@2F%G=6%R('!U;7@:6UP M96QL97([($E/5RP@=&AE('9A;F5S(&1I9"!N;W0@#0IS=&%N9"!A<R!T86QL M+"!S;R!T:&4@;W!E;FEN9W,@8F5T=V5E;B!T:&5M('=E<F4@82!L:71T;&4@ M<VUA;&QE<BX@(
T06=A:6XL($D@=V%S(’=I;&QI;F<@=&@=’)Y(&ET(&%N
M>7=A>2X-"@T5&AE(&UO<F4@<W1A<G1L:6YG(&1I9F9E<F5N8V4L('1H;W5G
M:“P@=V%S(&EN('1H92!A<G)A;F=E;65N=”!O9B!T:&4@#0IV86YE<R!T:&5M
M<V5L=F5S+B@5&AE(&]R:6=I;F%L($IA9W5A<B!I;7!E;&QE<B!H860@<F%D M:6-A;&QY(&)A8VMW87)D+7-L;W!I;F<@#0IV86YE<RP@=VAI;&4@=&AE($-H M979Y('!A<G0@:&%D(&YE87)L>2!R861I86P@=F%N97,@=VET:"!O;FQY(&$@ M<VUA;&P@#0IA;6]U;G0@;V8@8F%C:W=A<F0@;&5A;BX-"@T*1F]R('1H;W-E M('5N9F%M:6QI87(@=VET:"!T:&4@;F%T=7)E(&]F(&-E;G1R:69U9V%L('!U M;7!S+"!)('=I;&P-"F5X<&QA:6X@=&AE(&EM<&]R=&%N8V4@;V8@=&AE('9A M;F4@86YG;&4N("!7:&5N('EO=2!U<V4@=F5R>0T*8F%C:W=A<F0M<VQO<&EN M9R!V86YE<RP@>6]U(&%R92!L;V]K:6YG(&9O<B!H:6=H(&9L;W<@8G5T(&YO M=
T;F5C97-S87)I;‘D@82!L;W0@;V8@<’)E<W-U<F4[(‘1H97D@=VEL;"P@
M:&]W979E<BP@<’)O=FED92!G;V]D(&9L;W<-"F%T(&QO=R!24$TO;&]W(’!R
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
T5&AE(&YE>'0@=&EM92!S;VUE8F]D>2!H
M87,@82!P=6UP(&]F9BH;W(@82!S<&%R92!L87EI;F<@87)O=6YD*2P-"G1A M:V4@:70@9&]W;B!T;R!T:&4@;&]C86P@<&%R=',@<W1O<F4@86YD(&-O;7!A M<F4@=&AE(&EM<&5L;&5R('=I=&@-"G1H;W-E(&]N('1H92!V87)I;W5S('!U M;7!S(&]N('1H92!S:&5L9BX@(%1E;&P@=7,@:68@=&AE<F4@87!P96%R('1O M#0IB92!A;GD@=&AA="!W;W5L9"!B92!A;B!E>&-E;&QE;G0@9FET+"!A;F0@ M:68@86YY(&AA=F4@=F%N97,@=&AA=
T;&]O:R!L:6ME(‘1H;W-E(&]N(‘1H
M92!86<@:6UP96QL97(N#0H-“DIA9R!I;7!E;&QE<G,@:&%V92!S=&5E<&QY
M(&)A8VMW87)D+7-L;W!I;F<@=F%N97,L(&%N9”!N;V)O9’D@96QS90T9&]E
M<RX@($IA9W5A<G,@:&%V92!A(’)E<‘5T871I;VX@9F]R(&]V97)H96%T:6YG
M+“!A;F0@;F]B;V1Y(&5L<V4-“F1O97,N(”!#;VYN96-T:6]N/PT*#0H@(“TM
M($MI<F)E<G0@(”@('P@("
@($EF(&%N>71H:6YG(&ES('1O(&)E(&%C8V]M
M<&QI<VAE9"P-“B@("
@<V]M92!R=6QE<R!M
M=7-T(&)E(&)R;VME;BX-“B@("
M
M(%!A;&TG<R!0;W-T=6QA=&4-"@T*+2TM+2TM+2TM+2TM+2TM+2TM+2TM+2TM
M+2TM+2TM#0H-“D9R;VTZ(”)+:7)B97)T(B\<&%L;6M
9V-N+G-C<FDN9G-U
M+F5D=3X-“D1A=&4Z($9R:2P@-B!397@,3DY-B
Q.#HU,3HP-2M,#
P-0T*
M4W5B:F5C=#H@4F4Z($%B;W5T(‘1H92!M>7-T97)I97,@;V8@=&AE(%A*(’-E
M<FEE<PT*#0I$879I9”!4;W)D;V9F.@T*/B!7:&EL92!W92!A<F4@9&ES8W5S
M<VEN9R!C;VYT<F]L<RP@02]#(&5T8RX@0V%N(&%N>6]N92!T96QL(&UE(’=H
M870@=&AE#0H^(’!U<G!O<V4@:7,@9F]R(‘1H92!S;6%L;“!H;VQE(&]N('1H
M92!U;F1E<G-I9&4@;V8@=&AE('1O<”!L:7@;V8@=&AE(&1A<V@_#0H^(%1H M92!H;VQE(&ES(&%B;W5T(#$O,B!I;F-H(&EN(&1I86UE=&5R(&%N9"!I<R!P M;W-I=&EO;F5D(&1I<F5C=&QY(&%B;W9E('1H90T*/B!G;&]V96)O>"X@270@ M:7,@9&5F:6YI=&5L>2!T:&5R92!F;W(@<V]M92!S;W)T(&]F('!U<G!O<V4@ M=&AA="!H87,-"CX@8V]N=&EN=65D('1O(&5L=61E(&UE+B
-“@T5&AI<R!I
M<R!T:&4@86ER(&EN=&%K92!F;W(@=&AE(&%I<B!T96UP97)A=‘5R92!S96YS
M;W(@9F]R(‘1H92!!+T,@#0IC;VYT<F]L+B@4F%T:&5R('1H86X@:G5S="!P M=70@=&AE('-E;G-O<B!O=70@=&AE<F4@=VAE<F4@:70@8V]U;&0@#0IJ=7-T M('-E;G-E('1H92!A:7(L('1H97D@:&ED(&ET(&%N9"!B<FEN9R!T:&4@86ER M('1O(&ET+B
@5&AE<F4@:7,@82-"FAO<V4@=&\@;VYE(&]F('1H92!B;&]W M97)S+"!A<G)A;F=E9"!S;R!T:&%T('1H92!A:7)F;&]W(&)L;W=I;F<@#0IT M:')O=6=H(&$@9'5C="!D<F%W<R!A:7(@=&AR;W5G:"!T:&ES(&]P96YI;F<L M('!A<W0@=&AE('-E;G-O<B!A;F0@#0IT:')O=6=H('1H92!H;W-E+B
@0VQA
M<W-I8R!“<FET:7-H(&]V97)D97-I9VX@=VET:”!P;V]R(’)E<W5L=’,L('1H
M92-"G-Y<W1E;2!N979E<B!S965M<R!T;R!H;VQD('1E;7
@87,@=V5L;“!A
M<R!Y;W4G9”!L:6ME+@T#0H@(“TM($MI<F)E<G0@(”@('P@("
@($EF(&%N
M>71H:6YG(&ES('1O(&)E(&%C8V]M<&QI<VAE9"P-“B@("
@(”@ M("
@<V]M92!R=6QE<R!M=7-T(&)E(&)R;VME;BX-“B@("
@(”@ M("
M(%!A;&TG<R!0;W-T=6QA=&4-“@T*+2TM
M+2TM+2TM+2TM+2TM+2TM+2TM+2TM+2TM+2TM#0H-“D9R;VTZ(”)+:7)B97)T
M(B\<&%L;6M
9V-N+G-C<FDN9G-U+F5D=3X-“D1A=&4Z($9R:2P@-B!397@ M,3DY-B
Q.#HU,3HP-BM,#
P-0T4W5B:F5C=#H@4F4Z(%A4RM+2T@3V]P M<R$A(2
H82YK+F$N($-H87-S:7,@9F%I;'5R92D-”@T2F]H;B!.87!O;&DZ
M#0H^(#$I("!)<R!T:&5R92!A('-O=7)C92!F;W(@<W1I9F9E<B!C86=E(&UO
M=6YT<S@($]R(&ES(&ET(&$@8V%S92!O9B!U<VEN9PT/B!T:&4@<W1O8VL@
M<V5T=7@;W(@9V]I;F<@<V]L:60_#0H-"DD@:&%V92!N;W0@<V5E;B!A;GD@ M86QT97)N871I=F4@;6]U;G1S(&]F9F5R960N("!!('-H86UE+"!T;V\L($D@ M8F5T#0IT:&5R92=D(&)E(&$@;6%R:V5T+B
@0G5T(‘1H92!M;W)E(&-O;6UO
M;B!F:7@@:7,@=&@041$(&$@<W5P<&]R=“P-“G5S=6%L;'D@<V]M92!K:6YD
M(&]F(&QI;FL@9G)O;2!T:&4@8F]T=&]M(&-E;G1E<B!A<F5A(&]F('1H92!C
M86=E#0IF;W)W87)D+”!P87)A;&QE;”!T;R!T:&4@9’)I=F4@<VAA9G0L(‘1O
M(’-O;64@8G)A8VME=”!A=‘1A8VAE9"!T;PT*=&AE(&9L;V]R<&%N+B@4G5B M8F5R(&1O=6=H;G5T<R!O;B!B;W1H(&5N9',L(&QI:V4@86X@86YT:2US=V%Y M(&)A<@T*;&EN:RX@5&AE(')E<W5L="!I<R!T:&%T('1H92!C86=E(&ES(&AE M;&0@;75C:"!M;W)E('-E8W5R96QY('=I=&AO=70-"G-T:69F96YI;F<@=&AE M(&5X:7-T:6YG(&UO=6YT<R!T:&5M<V5L=F5S+"!A;F0@=&AE<F4G<R!P<F]B M86)L>2!A#0IL;W0@;&5S<R!S=')E<W,@;VX@<V]M92!O=&AE<B!C;VUP;VYE M;G1S(&%S('=E;&PN#0H-"DD@=V]U;&0@;&EK92!T;R!T86ME('1H:7,@;W!P M;W)T=6YI='D@=&\@<&]I;G0@;W5T('1H870@:68@;VYE('=A<R!T;R
-“F=O
M('1O('1O=&%L;'D@<V]L:60@;6]U;G1S+”!I=“!W;W5L9”!B92!A(&=O;V0@
M:61E82!T;R!T;W-S(‘1H92-"G1R86EL:6YG(&%R;7,@870@=&AE('-A;64@ M=&EM92X@($ET('=O=6QD('!R;V)A8FQY('-T:6QL('=O<FL@=VET:"!T:&4@ M#0IT<F%I;&EN9R!A<FUS+"!B=70@;VYL>2!B96-A=7-E(&]F('1H92!R=6)B M97(@;6]U;G1S(&%T('1H92!E;F0@;V8@#0IT:&5M+"!W:&EC:"!W:6QL(&)E M(&UU8V@@;6]R92!H:6=H;'D@<W1R97-S960@=&AA;B!B969O<F4N("!);B!O M<F1E<B
-"F9O<B!T:&4@=’)A:6QI;F<@87)M<R!T;R!M;W9E(‘1H<F]U9V@@
M=&AE:7(@87)C+"!T:&4@8V%G92!M=7-T(’)O8VL@#0IF;W)W87)D(&%N9"!B
M86-K(’-L:6=H=&QY+B@268@:70@:7,@<FEG:61L>2!M;W5N=&5D+"!T:&4@ M<F5A<B!W:&5E;',@#0IC86X@;VYL>2!G;R!S=')A:6=H="!U<"!A;F0@9&]W M;BP@=&AE>2!C86YN;W0@;6]V92!F;W)W87)D('=I=&@@=&AE(
T87)C(&]F
M(‘1H92!T<F%I;&EN9R!A<FTN("!3;RP@=&AE(’)U8F)E<B!J;VEN=‘,@=V]U
M;&0@:&%V92!T;R!S=’)E=&-H(T*+2
M+2!A;F0@=&AE(&%R;2!I<R!R96%L
M;'D@9&]I;F<@;6]R92!H87)M('1H86X@9V]O9"P@;6EG:'0@87,@=V5L;"- M"G)E;6]V92!I="X-"@T*/B
R2@5&AE(%A*+5,@:6X@<75E<W1I;VX@<V5E M;7,@=&\@8F4@;VYE(&]F('1H92!M;W)E('!O=V5R9G5L(&]N97,@;W5T#0H^ M('1H97)E+B
@27,@=&AE(’-T;V-K(’-E=‘5P(&IU<W0@=6YA8FQE(‘1O(&%B
M<V]R8B!T:&4@97AT<F$@<&]W97(@;W9E<B!A;@T*/B!E>‘1E;F1E9"!T:6UE
M/R@4V\@=&\@:&%V92!M;W)E('!O=V5R(&UU<W0@>6]U(&9O<F5G;R!T:&4@ M;W1H97(@8F5N969I=',-"CX@;V8@=&AE('-T;V-K('-U<W!E;G-I;VX_#0H- M"DET)W,@;7D@=6YD97)S=&%N9&EN9R!T:&%T(&%N>2!E9F9O<G0@=&]W87)D M(&=I=FEN9R!T:&4@6$HM4R!A(
T*<V5R:6]U<R!H;VQE+7-H;W0@8V%P86)I
M;&ET>2!E;F1A;F=E<G,@=&AE(’)E87(@8V%G92!M;W5N=’,N("!->2!O=VX@
M#0IC87(@:&%U;’,@85]?+“!B=70@22!D;VXG=”!P=7-H(&ET(‘9E<GD@;V9T
M96X@870@86QL+“!P<F]B86)L>2!H879E(T*:G5S="!A=F]I9&5D('!R;V)L M96US(&9O<B!M>7-E;&8N("!!9V%I;BP@=&AE('-T86YD87)D(&9I>"!I<R!T M:&%T(
T*;&EN:R!H;VQD:6YG(‘1H92!B;W1T;VT@;V8@=&AE(&-A9V4[($DG
M;&P@<’)O8F%B;‘D@<FEG(&]N92!F;W(@;7D@8V%R(T*;VYE(&]F('1H97-E M(&1A>7,N#0H-"DEN('1H92!C87-E(&]F('1H92!T<F%I;&EN9R!A<FT@9F]R M=V%R9"!M;W5N=',@<'5L;&EN9R!O=70L($D@:&%D#0IA<VME9"!A8F]U="!R M=7-T(&)E8V%U<V4@22!H860@:&5A<F0@86)O=70@:70@8F5I;F<@82!P<F]B M;&5M(&AE<F4-"BT@+2T@86YD('-U<F4@96YO=6=H+"!R=7-T('=A<R!I;G9O M;'9E9"X@($D@8V%N)W0@<V%Y($DG=F4@979E<B!H96%R9
T*;V8@82!S=’)E
M<W,@9F%I;'5R92!A=”!T:&5S92!M;W5N=’,@=VET:&]U="!A(’)U<W0@8V]N
M9&ET:6]N+@T*#0H^(#,I(“!)9B!T:&4@9F%I;'5R92!W87,@:&%S=&5N960@
M8GD@<G5S=”!I;B!T:&4@=‘5B+"!D;R!W92!A;&P@9F%C92!T:&ES#0H^(’!R
M;V)L96T_(“!7:&5R92!D;V5S('1H92!W871E<B!G970@:6X@9G)O;3@($AO
M=R!D;R!Y;W4@8VAE8VL@&1R:6QL(&AO;&5S#0H^(&EN('-O;64@<W1R871E
M9VEC(&QO8V%T:6]N3@($D@:&%V92!S965N($4M5’EP92!T=6)S(&-U=”!O
M<&5N.R!T:&5Y(&=E=T*/B!L;V]K:6YG('!R971T>2!B860@:6YS:61E(')U M<W0M=VES92X@($1O(&]U<B!82BU3)W,@:&%V92!T:&4@<V%M90T*/B!P<F]C M;&EV:71Y/PT*#0I3;VUE('%U;W1E($D@:&5A<F0@<F5C96YT;'DL('-U<'!O M<V5D;'D@9G)O;2!S;VUE(&]L9"UT:6UE<B!A="!*86=U87(@#0IU<&]N(&AE M87)I;F<@82!S<&5E8V@@9G)O;2!S;VUE8F]D>2!A8F]U="!R=7-T('!R;W1E M8W1I;VX@:6X@:&ED9&5N(
T*<V5C=&EO;G,@;V8@=&AE(&)O9’DZ(“B62=K M;F]W+"!I9B!I="!D:61N)W0@<VAO=RP@=V4@;F5V97(@8F]T:&5R960@#0IT M;R!P86EN="!I="XB#0H-"E1H97)E(&%R92!G=7ES(&AE<F4@;6]R92!A9&5P M="!A="!A;G1I+7)U<W0@<')A8W1I8V5S('1H86X@22P@86YD(&]N92
-“F]F
M('1H92!D:7-C=7-S:6]N<R!H87,@8F5E;B!G;VEN9R!O;B!R96-E;G1L>2X@
M($D@8V%N(&]N;'D@<V%Y('1H870L(T*8VQE87)L>2P@=&AI<R!P87)T:6-U M;&%R('-P;W0@:7,@;VYE('=H97)E(&%T=&5N=&EO;B!I<R!W87)R86YT960N M#0H-"B
@+2T@2VER8F5R=”@("
@268@86YY=&AI;F<@:7,@=&@
M8F4@86-C;VUP;&ES:&5D+T*("
@(“!(”@("!S;VUE M(')U;&5S(&UU<W0@8F4@8G)O:V5N+@T*("
@(“!(”@ M("
@(“`@(“T@4&%L;2=S(%!O<W1U;&%T90T*#0HM+2TM+2TM+2TM+2TM+2TM
M+2TM+2TM+2TM+2TM+2T-”@T16YD(&]F(&IA9RUL;W9E<G,M9&EG97-T(%8R
K(",S,S<-"BHJBHJBHJBHJBHJBHJBHJBHJBHJBHJ*BHJ#0H-”@``
end
OUT OF OFFICE AT EUROPEAN SERVICE MEETING.
Will not be able to answer ccmail until I return.
End of jag-lovers-digest V2 #342
id for jag-lovers-digest-out; Tue, 10 Sep 1996 00:09:08 +0200 (MET DST)
Date: Tue, 10 Sep 1996 00:09:08 +0200 (MET DST)
Message-Id: 199609092209.AAA21736@ekeberg.sn.no
Subject: jag-lovers-digest V2 #343
Precedence: bulk
jag-lovers-digest Tuesday, 10 September 1996 Volume 02 : Number 343
Thanks and XJ6 Radiator Foam Blocks
Re: Hole in dash SIII
How smooth thy jag?
XJS repail manual
Re: XJ40: How does your A/C operate?
Heat Shield, E-type bonnets.
FW: could use advice regarding tire brands for 85 XJ-S
Re: Radiator Removal
Re: XJS — Oops!!! (a.k.a. Chassis failure)
'88XJ6 transmission “clunk”
(Fwd) Rad for Jaguar E type
1986 XJ6 Battery
96 XJS Conv
RE: [XK Engines] Rebuild Questions
Rear Brakes on an 89 XJS with ABS
64 3.8 S-type automatic transmission shfiting hard
Re: Michael Powers/TEIR/Thomson - XJ40: Owners Manual
Date: Mon, 9 Sep 1996 11:44:45 -0400
Subject: Thanks and XJ6 Radiator Foam Blocks
Greetings All -
Thanks to Hunt Dabney and others who replied to my XK engine
rebuild questions. Very helpful.
On the subject of XJ6 foam blocks, I cannot find replacements
in any of the usual parts catalogs. I have seen XJS and
XJ6/12 S1/S2, but no Series 3 XJ6 radiator foam blocks.
(I’m referring to the foam pieces which seal around the radiator.)
Can anyone refer me to a source for these foam bits?
Thanks in advance for any replies.
B.J. Kroppe - '82 XJ6
Date: Mon, 9 Sep 1996 12:13:07 -0005
Subject: Re: Hole in dash SIII
BTW, is there any satisfactory rebuild for a viscous fan coupler or is it
cheaper/wiser to just replace it?
I’ve never seen one that would come apart short of a saw!
Any idea of cost (US)?
Generic, $30. Anything that would fit a Jag, $100+.
– Kirbert | If anything is to be accomplished,
| - Palm’s Postulate
Date: Mon, 9 Sep 1996 09:22:44 -0700
Subject: How smooth thy jag?
Finally got my Uni-Syn to work. Mfg defect… the passage from the
throat to the float assembly was not drilled deep enough. A dead end if
you will. I fixed that and now it works as advertised…
Anyway, I balanced and adjusted the mix (best I could)* on my '73 XJ12
and got the idle speed while in gear down to about 750rpm. The exhaust
note is clean and steady.
But when I sit in her, it is like sitting in a Chevy 350 muscle car…
by that I mean she is not smooth. She has a heavy, idle that shakes the
car. At 1000rpm, she is smooth as glass.
Is this normal? How smooth are these engines at low idle? I mean, I
could see that a big displacement engine could do everything big…
- Anybody know where I could get one of those fabled ColorTunes?
Dave Covert
Reactive On-Site Services Lead
…Particle Man, Particle Man, doin’ the things a particle can…
They Might Be Giants
From: “Kirbert” palmk%gcn.scri.fsu.edu@vm1.cc.nps.navy.mil
Date: Sun, 8 Sep 1996 17:42:31 -0005
HUH?
Anyone know how important the sponge rubber inserts around the
ratiator are. Mine are rotted away.What does the air dam look like on the 85 XJ-S? Anyone have one to
The rubber inserts are, I believe, to keep the air from sneaking araound
the sides of the radiator. Gotta keep it going through the radiator or it
does no good.
Air dam missing? Doesn’t that force air through the radiator at low speeds
whenthe fan is the primary cooling device?
LLoyd
Date: Mon, 9 Sep 1996 11:45:34 -0500
Subject: XJS repail manual
I’m looking for XJS repair manual. I own 89 XJS and I’m planning to
replace shock absorbers all the way around and replace all the rubber bushings.
If you have XJS repair manual for sale(for 89) or information on where I could
buy the repair manual please let me know.
Thanks in advance
- –Sang
Sang Oh
Motorola
Cordless Product
Cellular Subscriber Group
1900 W. Winchester Road
Libertyville, IL 60048
Phone:(708) 523-4725
Fax:(708) 523-2499
E-mail: sango@ecg.csg.mot.com
From: Michael Powers/TEIR/Thomson Michael_Powers@teir.com
Date: 9 Sep 96 13:07:35
Subject: Re: XJ40: How does your A/C operate?
I just purchased a “drivers manual” for my 89 XJ6. I’d
more than happy to scan and post the section on Climate control.
Just tell me what format you need (jpeg, bmp, etc.).
- -Mike
PS - It’s pretty good reading. It explains all the buttons that seem to have
no purpose.
Plus it only $15 (US) at your local Jag dealer.
ajbeale @ squirrel.com.au (A.J. Beale)
09/09/96 10:13 AM
To: jag-lovers @ sn.no @ Internet
cc:
Eric writes:
I don’t have the owners manual and would like to know how the A/C
works in the cars of other XJ40 owners.
What vents get cold/warm air and how is the AUTO mode supposed to
work? My AUTO mode turns opens & closes the center vents when the car
is cold (air is then sent to footwells).
I agree with Barrie’s remarks. Although I have a (brief) description of the
system in the workshop manuals, I am still unable to fully understand how
some things that have happened to me can be possible. The description, with
diagrams, gives the impression that hot air from the heater matrix and cold
air from the evaporator are mixed together in proportions determined by the
in-car and ambient temperatures and the control settings and this is then
discharged at both foot and face levels. If this is so, then with the
possible exception of the changes made by the face level temperature
control, there should be no difference between the temperature of air from
all of the outlets. This face level control is (I think) only supposed to
change the temperature by a few degrees, but I cannot notice any change. I
once had hot air at face level and cold air at foot level with the controls
set to cool. I couldn’t find any fault and it didn’t recur. As regards the
difference between the AUTO and MAN modes, I read the description to mean
that with AUTO the system maintains the set temperature but in MAN it works
as a non-climate control system. The side vents on my car always have a
good volume of air but the volume from the centre vent varies considerably.
If anyone can give a detailed description of the system, or preferably a
fault finding list, I would be very interested. Alan
Date: Mon, 09 Sep 1996 13:37:28 -0400 (EDT)
Subject: Heat Shield, E-type bonnets.
John,
We have a 68 E-type FHC which badly discolored paint over the entire
louvered areas and the center raised section up to where the raised
section flows into the bonnet nose. We are planning a repaint this winter
and the mainfold heat shield idea sounds as if it will provide some badly
needed protection. What did the used XJS series III shield cost from
Welsh? Can you describe the minor creativity of the mounting bracket?
Bill Graham
68 XKE FHC (hers)
71 MGB (his)
Date: Mon, 9 Sep 1996 11:04:17 -0700
Subject: FW: could use advice regarding tire brands for 85 XJ-S
Just purchased a set of P4000s for my '85 XJ-S. So far, performance has
been great and were, only minimal (6,000 miles). Your price ($115
including mounting etc.) is excellent. I paid $125 plus mounting and
balancing.
Aaron
'85 XJ-S
From: ee84287@goodnet.com[SMTP:ee84287@goodnet.com]
Sent: Friday, September 06, 1996 5:10 PM
Subject: could use advice regarding tire brands for 85 XJ-SI am facing the task f buying new tires for my 85 XJ-S. I’d be
interested in
anyone’s feedback regarding the following apparent three brands that I
have
as a choice for 215/70 VR15:
- Dunlops. At around $150/tire.
- Pirellis (I’m told that there is a new P4000 that replaces the
previous
vintage). Best price so far; $115/tire including mounting, stems, and
balancing.- Bridgestones (my current set, gave a great ride but didn’t last very
long). At around $145/tire.
Any other ones I should consider? Are the Pirelli’s any good and is
the
price aboput right? Your opinions regarding the above will be much
appreciated, and thanks in advance,Rob W-M
85 XJ-S
Date: Mon, 9 Sep 1996 11:07:15 +0000
Subject: Re: Radiator Removal
checked, and not only does the Haynes manual state the A/C must be
discharged to remove the radiator, but the official Jaguar manual
does too!
They are both wrong, in fact it doesnt even make it any easier to do
it that way!
You’ve apparently tried it, I haven’t. So, for final confirmation:
You had no trouble getting the radiator out without disturbing the
freon circuit? I presume you merely left the dryer hanging there by
the tubes? Any tricks involved, or is it as obvious as it looks?
Actualy the dryer is fastened to a cross brace in front of the
condenser and there is no stress on it to leave it there. You just
have to slightly bend the brackets up enough to remove the radiator
top piece after remove 4 small nuts (real small!).
OK heres the skinny. First, the hood. Remove the Grill and then
pull the hoot into its upright position. Unscrew the bolts that holt
the lift struts to the fenders. Lift the hood up untill it is
resting on the bumper (if you dont have a rubber bumper like I do put
a towel there to protect the paint on the hood from chipping) The
compress the struts one at a time and place the end/bolt against the
end of the drip lip in the inside of the fender. This will hold
pressure against the hood to hold it open. It WILL NOT be in the way
when it is fully extended this way.
Next follow the following description from John Himes. I didnt do it
quite this way since I was done by the time I got his post, but his
description is good.
I found it was very easy to do, but unlike John I did remove the fan,
clutch, and shroud first. I had to anyway since I am also replacing
the water pump.
I didnt need a friend to do any of it, but it might have been easier.
You have got to be kidding about the A/C discharge. On mine, and I
doubt that they are that different, the A/C radiator ( can’t remember
the name at present ) sits infront of the radiator. There are 2
mounting straps that hold a large round part of the A/C system ( in
front of the A/C radiator, I hate when my mind goes blank on part
names ) that is held by 4 nuts on the plate that covers both
radiators. Unscrew these 4 nuts & move the straps up & out of the
way, takes a little force. This plate is held by 4 screws, 2 on each
side, remove these, remove the thin bypass tubing by undoing the 3
c-clams on the hoses, remove the bolt on the right side this tubing is
also held in by, there are some copper washers there you may want to
replace. There are also 2 nuts that hold the A/C radiator in place.
These have rubber under the washer. You also need to do remove the
nuts that hold the shroud that the electrical fan is attached to and
move back as far as you can. ( oh yea, also remove the 3 main
radiator hoses from the radiator if you have not already done so. )
Now with the help of a friend ( easier if the shroud is not there, but
you can’t remove it with the clutch driven fan & radiator in place. I
have remove both of mine and the shroud & gone to 2 electrical fans
mounted to the radiator ) Lift the empty radiator up & out. Watch
out for your hands. If the shroud is in the way & you cant jimmy out
the radiator, then you will need to remove the 4 bolts that hold in
the clutch driven fan & clutch.
Then you should be able to get the shroud out of the way. If the hood
is in
the way, you can just un-hook the struts to give you more room to move
the hood with out removing the hood. If you are going to remove the
hood, you are correct that it is MUCH easier with two people. One to
hold the hood & one to remove the bolts.
I probably dont need the radiator rodded, I found over 1/3rd of the
surface blocked with leaves and such so it probably only needed to
have those cleaned out.
Hope this will find its way into the XJ-S book. BTW, this was on a
1985 XJ-S
Another note, the Haynes manual (both the one for the XJ6 and the one
for the XJ-S) says that the XJS clutch was first 4
bolt then 1 bolt, but my 85 which is after the change by 3 years has
a four bolt clutch. So both Haynes manuals seem to be incorrect on
this point.
Date: Mon, 9 Sep 1996 15:35:55 -0400
Subject: Re: XJS — Oops!!! (a.k.a. Chassis failure)
John Napoli:
- Is there a source for stiffer cage mounts? Or is it a case of using
the stock setup or going solid?I have not seen any alternative mounts offered. A shame, too, I bet
there’d be a market.
There are hard rubber mounts available from SNG Barratt, also, Terry’s is now
selling a full kit to convert to a diagonal radius link (with diff cage
supports). I’m not sure the kit will work on an XJS, I think it’s intended for
E-types.
Mark McChesney
Date: Mon, 09 Sep 96 12:27:00 PDT
Subject: '88XJ6 transmission “clunk”
Driving in Southern Cal frequently presents the opportunity for freeway
commutes at low speeds. I have noticed lately that when I am bumper to
bumper, starting to accelerate from 1st to 2nd at a low speed, it will
engage with a very healthy “clunk.” I never notice this from a dead stop
acceleration, but rather from a rolling start at a low speed. Is this an
indication of a near term transmission diaster, some required maintanence,
or anything to worry about?
Mike in San Diego
'88 XJ6 with 77K
Date: Mon, 9 Sep 1996 15:45:11 -0400
Subject: (Fwd) Rad for Jaguar E type
- — Forwarded mail from GriffinRad@aol.com
Date: Wed, 4 Sep 1996 22:36:40 -0400
To: mmcchesn
Subject: Re: Rad for '65 Jaguar E type
Hi Mark,
Yes we do have a radiator for your Jaguar the only problem is that I don’t
have the cost. So I will get that information to you by mail. Thanks for
checking with us…
- —End of forwarded mail from GriffinRad@aol.com
To anyone interested, Griffin Radiator has rads for E-types (and other Jags?).
I understand that they have a higher cooling capacity. I’ll post the price when
I get it.
Mark McChesney
Date: Mon, 09 Sep 1996 16:33:11 -0400
Subject: 1986 XJ6 Battery
Greetings all;
I have a need to check my battery. It appears to be not holding
a charge. When I test the draw it seems to be minimal (computer draw
only), therefore it would appear to be a battery problem. 2 questions
does this seem to be a correct procedure, and where might I find a
proper battery in the Northeastern section of US?
Thanks in advance for any information regarding these items.
Bill Stickney
Date: Mon, 09 Sep 1996 15:31:47 -0400
Subject: 96 XJS Conv
I have a 95 XJS Conv. Believe it or not, I have no Maintenance problems at
all. Regular oil changes, lube and add gas is all that is required so far.
I test drove a 95 XJS Conv 6 cyl. The car is lighter and a lot less power.
I think it’s the torgue. I have a 71 XKE V12 so I’m used to 12 cyl power.
The 6 cyl XJS is faster than the sedan. I like the heavier feel of the 12
and the car handles great! Gas milage is 12.5 to 13.5 city and no more than
18 mph on the highway. Once I got 7 mph on the highway. You guess the speed.
Jack Bednarski
71 XKE V12
90 XJ6 VDP
95 XJS V12
From: “White, Dick” white@msgate.ColumbiaSC.NCR.COM
Date: Mon, 9 Sep 1996 17:15:00 -0400
Subject: RE: [XK Engines] Rebuild Questions
B.J.,
I rebuilt my 3.8 litre S-Type engine at 99,000 mi. and did not have to
have the crankshaft re-ground. The block and crank were checked by the
machine shop which did the boring for me (one new sleeve and bore all
cylinders +.030").
I did not replace the bronze bush on the distributor/oil pump shaft.
After rebuilding the S-Type engine (9:1) I have 175-180 psi in all
cylinders. On my XK150 (8:1) I have ~150 psi on all cylinders. I don’t
know how long ago it was rebuilt.
Dick White
Columbia, SC
'64 3.8 S-Type
'58 XK 150 FHC
- Has anyone rebuilt an XK engine without needing to regrind the
crankshaft
data
specifications
the
specifications
for this component?How can I definitively tell what compression ratio my engine is? On
page 05-2
of my Series III Service Manual it says I should have 120psi -
135psi compression
pressure. I have a U.S. emissions, late 1982 vehicle. What
compression ratio
pistons do I have?Thanks as usual for any and all replies.
Date: Mon, 9 Sep 1996 18:34:38 -0400 (EDT)
Subject: Rear Brakes on an 89 XJS with ABS
I have overhauled the rear brakes on the above car and while I was under there I
had planned to replace the flexible brake line which goes to the T connector.
However, on the flexible line in the car there is what appears to be a mini-
c-clamp that cross clamps the flexible line in the middle. Is this factory?
If so
what purpose does it serve? I was planning to simply remove it and replace
the line.
Are there any problems with this?
Patrick Bowers
Date: Mon, 9 Sep 1996 15:26:00 -0400
Subject: 64 3.8 S-type automatic transmission shfiting hard
One of the local Jag club members has a 1964 3.8 S-type with a problem:
when hot, the Borg-Warner DG250 transmission shifts are delayed and abrupt.
Comments or pointers to an FAQ would be appreciated.
Here’s the details:
- cold operation (first 15-20 minutes) is fine.
- when hot and refusing to shift as expected, shifts can be triggered by
reducing the amount of throttle slightly.
- the transmission has been rebuilt twice without solving the problem.
Related to this problem is a question about the amount of ATF that this
transmission needs. If the amount in the literature is installed, the
dipstick is dry or has only a tiny amount showing on it. To get the
correct level showing on the dipstick, an extra 1.5 litres of ATF has
to be added. What’s the correct amount? Note that the transmission operation
doesn’t change with the amount of ATF.
Regards - Albert Cohoe
Voice: 393-3440 or 613-763-3440 Email: cohoe@nortel.ca
Date: Mon, 9 Sep 1996 12:04:42 -0700
Subject: Re: Michael Powers/TEIR/Thomson - XJ40: Owners Manual
Mike,
Thanks for the offer! If you could please post the section on the
Climate control in jpeg format, I would be very grateful.
Also, thanks for mentioning the price and availabilty of the manual
from the dealer. I figured it would be $100+, like the owners manual
cost me on the Mercedes I owned prior to the Jag. I’ll have to add
this to my next list of things to buy from the dealer.
Thanks again! This information you may send, will surely tide my
curiousity over until I am able to order my “shopping list” of little
parts from the dealer.
-Eric
cobac@ix.netcom.com
End of jag-lovers-digest V2 #343
X-UIDL: 1e65f721c9d97560f998d9b30613b316
Return-Path: @owner-jag-lovers-di1
Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4)
id for jag-lovers-digest-out; Tue, 10 Sep 1996 06:42:35 +0200 (MET DST)
Date: Tue, 10 Sep 1996 06:42:35 +0200 (MET DST)
Message-Id: 199609100442.GAA13702@ekeberg.sn.no
X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f
To: jag-lovers-digest@sn.no
Subject: jag-lovers-digest V2 #344
Reply-To: jag-lovers@sn.no
Errors-To: @owner-jag-lovers-di1
Precedence: bulk
Status: RO
X-Status:
X-Newsgroups: mail.jag-lovers-digest
jag-lovers-digest Tuesday, 10 September 1996 Volume 02 : Number 344
Re: FW: could use advice regarding tire brands for 85 XJ-S
Knockoff tool - Marston Motors
Porcelain Manifolds at the Palo Alto meet
short Palo Alto report
XK-140 - early C Type Cylinder Heads
XJ40- caught again!
Special Car Journal
88xjs idle
remove
Re: Wind Deflector
Re: Subject: RE: XJ40:How does your A/C operate
Re: XJS brake fluid reservoir cap
Re: could use advice regarding tire brands for 85 XJ-S
I saw “old #25” today and the XJ-S is getting better too.
does too!
it that way!
the water pump.
is in
1985 XJ-S
this point.
Date: Mon, 9 Sep 1996 15:21:58 -0400
Subject: Re: FW: could use advice regarding tire brands for 85 XJ-S
When I used to have my '84 XJ-6 I was unimpressed with the pirelli tires that
came with it. I went with Yokohama AX-321 tires and saw a drastic increase in
performace. of course, the XJ-S is a different car, but I would take a look
at those or any Yokohama tires. I have had them on a couple of cars and they
always produce fantastic performance. Of course, they are softer than other
tires and do wear a bit quicker but the are great. I have always found
Pirelli to be a disapointment the tires that came on my Porsche were Pirelli
and I got rid of them after only 3000 miles, they just arent great (IMHO) -
Doug
Date: Mon, 09 Sep 1996 11:29:03 -0700
Subject: Knockoff tool - Marston Motors
Picked up a few interesting tips at the Palo Alto British Car meet this
weekend.
The meet was very well attended and a huge turnout of Jaguars as well,
which gave lots of opportunity for comparing notes with other owners.
I saw a nice tool for removing eared knockoffs without damaging them. It
was a 20 inch length of aircraft plywood with a milled out center
section that snugly fits over the knockoff. You hit the plywood with the
hammer and get an additional factor of 5 in leverage.
An E-Type owner (Chuck Rockhold) told me he got it from Marston Motors
at Bradford in the UK at a cost of about $US25 including shipping to the
US.
Apparently they advertise in Jaguar World, so can somebody look up their
telephone and/or fax number and tell me.
It seems a reasonable price and is a nice tool that fits in easily with
the spare tire.
Cheers, Patrick.
1965 E-Type 4.2 Series I FHC
Date: Mon, 09 Sep 1996 11:43:31 -0700
Subject: Porcelain Manifolds at the Palo Alto meet
At the Palo Alto meet there were a few success and failure stories to
compare on the porcelaining of exhaust manifolds. One E-Type owner who
claimed success (even with sustained high speed driving) had his
manifolds done at Parkeys in the Los Angeles area. Suprisingly, he
claimed that it cost him only about $120. But another E-Type owner had
his done a few years ago at Parkeys for well over $200 and the porcelain
only lasted a very short time. Has their process improved? Anyone else
had experience with them? Anyone know their phone number?
Cheers, Patrick.
1965 E-Type 4.2 Series I FHC.
Date: Tue, 10 Sep 1996 09:02:14 +1000 (EST)
Mike writes:
Thanks, Mike, but I have both the drivers manual and the workshop manual.
The problem is that while the drivers manual tells you what each of the
buttons does and the workshop manual gives a brief description of the
system, neither gives a sufficiently detailed description of the system to
allow accurate fault finding. Almost any fault can be caused by at least
half a dozen components and you need the experience of someone like Michael
Neal, to avoid checking the least likely first. Regards, Alan.
Date: Mon, 9 Sep 1996 16:41:38 -0700
Subject: short Palo Alto report
Hello-
Thought a quick report from this Sunday’s Palo Alto meet was in order:
Jag’s rolled on and off of the grass all day, but the local club made a
high-water count of 73 Jaguars. Quite a good showing I thought. The
earliest car I saw, was an SS 3.5L Saloon; with just about every model
represented from there to a couple of new XJS convertibles. I’d heard
that there was an XK8 or 2 in the area… (didn’t Michael Neal say there
were 1 or 2 here to do mechanics training on?), and was sort of hopeful one
might show up, but I guess it just wasn’t to be :-(.
Anyway, there were XK’s XJ’s E-types, S-types, Big Saloon’s, and Little
Saloon’s, of all shapes and sizes. The event was advertised as open to
all cars- from trailer queens to works in progress; but I must say that nearly
every Jaguar there was looking very very good. A few Jag’s for sale; including
a pair of MK2’s at ~$5K each, and a nice looking MKX- looking for offers at
around $7K. With so many Jaguars in one place, it was neat to compare one
model to the next and see how the styling evolves from one car to the next.
There was a total of 1 MK1 in the group, parked way out in the corner
In addition the the Jags, there were Triumphs, MG’s, Aston Martin’s, Austin
Healey’s, Land Rovers, Lotus’s (or is it Lotii?), Bentley’s and RR’s,
Nash Metropolitans, Mini’s, and countless other more obscure marques. In
total, I’d guess 5 or 6 hundred cars. Weather was bright sunshine, though
a tad hot (>90 degrees).
A personal thanks to all the jag-lovers who stopped by to say hi, it’s
always nice to put a face to an email address :-). And, apologies to
anyone who I missed, stopping by while I was away taking in the show.
===== __ ============================================================== |> ===
/_\ Ryan Border o~_ o~_ | *
/ / / Hewlett Packard Company, Inc. >/-.>/’ /o| *
/ / / _______ Software Design Engineer ( )-–(*)-( )’ *
/ / //_____\ email: rborder@cup.hp.com or border@best.com *
/ / __ / / __ / 19111 Pruneridge Ave. mailstop 42LX, Cupertino, CA 95014 *
/ / / / / / // / (408) 447-2496 FAX: (408) 447-0641 *
//// / _____/ WWW: BestWeb.com - Lease or Buy Domain Names - Best Web Limited *
Date: Mon, 09 Sep 1996 20:22:20 -0400
Subject: XK-140 - early C Type Cylinder Heads
This is a MIME message. If you are reading this text, you may want to
consider changing to a mail reader or gateway that understands how to
properly handle MIME multipart messages.
- –=_05560EDF.17761A1B
Content-Type: text/plain
Content-Disposition: inline
Here’s my reply to Neville Laing’s recent question about early XK-140 C-Type
cylinder heads.
Content-Type: message/rfc822
Date: Mon, 09 Sep 1996 09:09:58 -0400
To: cppceng@richmond.infi.net
Subject: XK-140
Mime-Version: 1.0
Neville: Saw your message. I am currently restoring a 140 DHC Sepecial
Equipment Model which bears chassis # s817002DN. This is the second left
hand drive 140 DHC and according to Jaguar records is the first 140 with a C
Type head. The car has no cam cover badges and no cast “C” in the plug well.
The the original well colour appears to have been silver and I plan on leaving it
that way. For $40 you can get a Jaguar Daimler Heritage Trust certificate for
your car which should confirm that it has a C Type head: contact Karen Miller
at Jaguar in Mahweh, N.J.
Hope this helps and that we can share further insights. Regards.
Brian Pel
Toronto, Ontario
(bpel@mccarthy.ca)
- –=_05560EDF.17761A1B–
From: “Peter Rebbechi (03) 9275 3374” <"REBBECHI PETER"@A1.MEOC02.SNO.mts.dec.com>
Date: Mon, 09 Sep 1996 21:27:00 +0000 (GMT)
Subject: XJ40- caught again!
That will teach me to tell people that my car doesn’t let me
down.
For the third time in 3 yrs, I have had a ‘broken’
thermostat, that has resulted in overheating.
The first time I caught it, no damage.
The second time, well, I replaced 4 valves, and generally
rebuilt the head.
Last night, whilst driving in traffic, I noticed the guage
suddenly climb. It usually sits at 90, and hardly moves.
This time it was moving, up, fast.
I pulled over, switched off, and popped the bonnet.
The radiator cap was just starting to expunge water. I
waited some time, made some phone calls, read a book, etc,
and released the cap.
Then I undid the housing, and removed the thermostat. The
thermostat was well and truly busted. Some silastic around
the housing, and more water, and I was away. When I got
home, I retightened the housing, and checked for leaks.
After 2-3 hrs, I checked again, and topped up the water.
The car runs fine, but does not reach operating temperature
without the thermostat.
Every 6 Months, replacement of this will be done from now.
I will take a leaf out of the aviation book, and if life is
about 12months, then I will replace every 6 just to make
sure from now on.
Ah well, Gotta spice up ya life somehow!
Date: Mon, 9 Sep 96 18:24:37 PDT
Guys,
I think when a bunch of people wonders about how to use the
A/C controls, the manufacturer has done a lousy job of designing
it! My opinion on the A/C controls in my XJ40 is that it’s
very confusing, and very stupid.
Roger Peng (408)765-7863
Intel Corporation
Design Technology, Physical CAD
Date: Mon, 9 Sep 96 18:44:42 PDT
Subject: Special Car Journal
Check out the Jaguar articles on the Special Car Journal Homepage:
Intel Corporation
From: “Ernie Laprairie” lapraire@enterprise.cybersurf.net
Date: Mon, 9 Sep 1996 20:02:20 MST
Subject: 88xjs idle
I have an 88xjs that idles between 900 and 1100 when warm, the jag
dealer here tells me that it will require a heater on the throttle
mechanism to cure the erratic idle and $600.00 Any ideas or parts
for sale. Also hard to find here plastic seat hinge covers with no
leather on that can be recovered with original leather.
88 xjs
lapraire@cia.com
Date: Mon, 9 Sep 1996 21:59:48 -0400
Subject: remove
signoff
Date: Mon, 09 Sep 1996 21:10:14 -0500
Subject: Re: Wind Deflector
Donald R. Farr wrote:
Hi Randy,
The weather in Arizona is about to turn nice again…and I’ll open the
sun roof after four months (grin). I’d love to have a wind deflector
added to my 91 Sovereign, can you tell me where you bought yours?Thanks
don
Donald R. Farr
Paradise Valley, AZ 85253
91 Sovereign
d.farr@phx.cox.com - e-mail
http://people.phx.cox.com/dfarr/dfarr.htm - Don’s Homepage
http://people.phx.cox.com/dfarr/jetta1.htm - Jetta Notebook Computers
http://people.phx.cox.com/dfarr/march10.htm - Wireless products
http://people.phx.cox.com/dfarr/ncs1.htm - National Consulting Services
Hello, Don,
I don’t quite understand why you have not opened the sunroof for four
months; after all, everyone tells me that it is a “dry heat” from which
Arizona suffers. In spite of the other kind of heat in the Dallas
area, I open the roof and roll down all the windows every opportunity I
get.
But now to answer your question: I obtained the wind deflector at the
local dealership. It is a standard accessory and was shown in the
accessory brochure around 1993. It is so official that it even has a
leaper embossed in the center (wonder how much I paid for that?)
Randy
Date: Mon, 09 Sep 1996 19:58:53 -0700
Subject: Re: Subject: RE: XJ40:How does your A/C operate
Just for the record; The XJ40 A/C system is completely different than
the S3 XJ6.
Dawson, Barrie wrote:
The Jaguar A/C is complicated and unlike any other system I have come
across.
Apparently if you can hear clicks, wheezes and whirring form behind the dash
and you get hot or chilled air when required the system is working. I have
noticed on my series III that the air flow changes are so subtle that they
are hardly noticed except in extreme circumstances, e.g. high fan speeds.With regard the centre vents I believe only chilled air is directed through
them.
The face control I believe allows for fine tuning of the chilled air so as
not
to
cause discomfort from an icy blast.I don’t think there is a great difference between XJ6 and XJ40 but there
will
be
slight changes I’m sure.Barrie Dawson
Chatham, Kent England
1985 series III Jaguar Sovereign------------------------------ End of forwarded message 1
Michael P. Neal ASE Master Technician, Jaguar Certified
'93 Ducati 900SS '83 Porsche 944 '85 Jaguar XJS
Home (707) 829-8464 Work (707) 577-0101
http://www.wco.com/~mneal (always under construction:-)
Date: Mon, 09 Sep 1996 20:01:51 -0700
Subject: Re: XJS brake fluid reservoir cap
This is a problem and tends to reoccur if you dont modify the
reservoir. This is on the pre-abs XJS brake reservoirs. Usually just
flattening the sharp vertical ridge on the reservoir with a file will do
it.
Kirbert wrote:
Ivan S Kirkpatrick, PE isk00@visi.net:
I am now replacing the cap on the brake fluid reservoir for the second
time. the two previous units failed in a similar manner. It appears
that the modl used for the caps has a section near the top of the
threads and the top surface that is too thin. The cap has separated
into a threaded piece and a top piece.This is the first I’ve heard of a problem here. Can anybody confirm?
By the way, which system are we talking about? ABS?
Is it possible to replace the
entire reservoir with a better designed unit?If you find a way, please send it to me for inclusion in the XJ-S
book.Would there be any
support in compiling a list of replacement parts/suppliers that would
potentially give better service? It seems like almost everyone has
some experience in this respect. I have seen Kirby’s XJS book but
don’t recall a specific section on better replacement parts. Items like
a good GM alternator conversion kit for those with heavier electrical
demands and things like that.The GM alternator conversion is in there, as well as several other
suggestions. They are not in a separate section, but in the sections
talking about the various parts themselves. Perhaps that isn’t ideal
for some purposes, but every arrangement I could think of had pros
and cons.For those who have my booklet: I have been thinking of eliminating
the separation between “Maintenance” and “Modifications”. Some of my
suggestions for maintenance are to replace a stock part with a
non-stock part, which technically is a modification. And some
modifications I suggest be considered even by those who don’t modify
the car, such as the installation of aftermarket steering rack
bushes. As a result, I have quite a few references back and forth
between the sections. Do you guys think it would be a better idea
for that to be one large section, where you can look up the thing
you’re concerned about and find the maintenance suggestions and the
suggested modifications at the same place?– Kirbert | If anything is to be accomplished,
| some rules must be broken.
| - Palm’s Postulate
Date: Mon, 9 Sep 1996 19:04:50 -0700
Subject: Re: could use advice regarding tire brands for 85 XJ-S
This is a Mime message, which your current mail reader
may not understand. Parts of the message will appear as
text. To process the remainder, you will need to use a Mime
compatible mail reader. Contact your vendor for details.
- –IMA.Boundary.143123248
Content-Type: text/plain; charset=US-ASCII; name=“RFC822 message headers”
Content-Transfer-Encoding: 7bit
Content-Description: cc:Mail note part
Received: from ekeberg.sn.no by internet.golder.com with SMTP
(IMA Internet Exchange 1.04b beta) id 2344cd30; Mon, 9 Sep 96 09:58:59 -0700
id for jag-lovers-out; Mon, 9 Sep 1996 02:13:50 +0200 (MET DST)
using -f
Received: from goodguy.goodnet.com (root@goodnet.com [207.98.129.1]) by ekeberg.s
with ESMTP id for jag-lovers@sn.no; Mon, 9 Sep 1996 02:13:49 +0200
(MET DST)
Received: from HAL (tempe-ts5-18.goodnet.com [206.43.126.179]) by goodguy.goodnet
.com (8.7.5/8.7.1) with SMTP id RAA08061 for jag-lovers@sn.no; Sun, 8 Sep 1996
17:12:44 -0700 (MST)
Message-Id: 199609090012.RAA08061@goodguy.goodnet.com
X-Sender: ee84287@mail.goodnet.com
X-Mailer: Windows Eudora Version 1.4.4
Mime-Version: 1.0
Content-Type: text/plain; charset=“us-ascii”
Date: Fri, 06 Sep 1996 17:10:23 -0700
Sender: owner-jag-lovers@sn.no
Precedence: bulk
Content-Description: cc:Mail note partUnder advice from a friend and motoring “expert”, I bought a set of
Goodyear GA’s about 3 years ago. I had become very nervous about the
ageing Pirellis that would lose grip at the slightest suggestion of
torque or wetness.Well, the GA’s were OK for a while, but after 35k miles, they don’t
have much tread left, and they are starting to lose grip, just like
the Pirelli’s :-((Another thing: these humungous tires seem to go out-of-round almost as
soon as they go on the car. Test drive any new tires on a nice very
smooth road at 10 to 20 mph. If you think you are running over a herd
of hedgehogs, then your new babies are as bad as mine: Take em Back!Michael Kenrick
86 XJ-S, Seattle USA -
–IMA.Boundary.143123248–
Date: Tue, 10 Sep 1996 22:38:07 -0500
Subject: I saw “old #25” today and the XJ-S is getting better too.
Tomorrow I will pick up “old #25” from the cat house. She looks prety good
with a new body.
I looked at the old body and I still can’t see how my wife walked away from
it without a bruise. Someone up there was watching over her.
One of the mechanics that didn’t know me walked up while I was looking under
the hood at the engine and said, “They put a used engine in it.” I replied,
“I know, it was a heart transplant.” I then explained who I was and that
that engine had done 120 at TWS with me on the gas and I thought we could do
it again in our new body.
Tomorrow she is well enough to go home so we will see just how good she
feels when we hit the open road.
Except for a mildly leaking steering rack and a slow leak from the rear seal
everything else looks great. I guess I will have to do two new bellows on
the steering rack. The mechanic didn’t even offer, so I guess it’s a real
bitch of a job.
The Radiator of the XJ-S (Mabaline) went to the clinic today. The doctor
said the arteries were partialy blocked and the flow was down about 30%.
With the 33% blockage due to the leaves that means the efficiency of that
radiator was .7 X .67 = .469 or less than 50%. So its no wonder she was
getting hot in traffic.
Tomorrow I will begin putting her back together and soon we will take her
for a romp at Texas World Speedway.
Jim
“Better an outlaw than not free.”
Nance O’Neil
End of jag-lovers-digest V2 #344
id for jag-lovers-digest-out; Tue, 10 Sep 1996 19:30:30 +0200 (MET DST)
Date: Tue, 10 Sep 1996 19:30:30 +0200 (MET DST)
Message-Id: 199609101730.TAA26047@ekeberg.sn.no
Subject: jag-lovers-digest V2 #345
Precedence: bulk
jag-lovers-digest Tuesday, 10 September 1996 Volume 02 : Number 345
Re: Rear Brakes on an 89 XJS with ABS
Re: 1986 XJ6 Battery
Re: I saw “old #25” today and the XJ-S is getting better too.
Fair price for SIII V12 Sovereign
RE: Knockoff tool - Marston Motors
RE: Getting at the A/C microswitch - XJ40
XJ sIII V12 price
1952 MK V
Re: viscous coupler
Re: Fair price for SIII V12 Sovereign
JPI - Jaguar Price Index
Re: XJ40: Owners Manual - Climate Control section
XK140 C type heads
Knock-Off tools…
FOAM not rubber & air dam on XJ-S
XK40 Pwr Door locks
Water Pump Removal
Air Pump
re: air dam on XJ-S
Oil Cooler/AC Condenser – XJ-S
Date: Tue, 10 Sep 1996 00:53:58 -0005
Subject: Re: Rear Brakes on an 89 XJS with ABS
If so
the line.
Y’know, you may find that this is an aluminum tag with the part
number of the hose assembly on it!
| - Palm’s Postulate
Date: Mon, 9 Sep 1996 22:53:11 -0700 (PDT)
Subject: Re: 1986 XJ6 Battery
The S-III XJ-6 battery is common, so should be available most anywhere. If,
while running the car, the dashboard voltmeter is indicating near (or very
slightly below) 13 volts, the charging circuit is working. If the voltage is
substantially above 13, the battery probably has an open cell, while below
12 volts would tend to indicate no output from the alternator. You might try
charging the battery, disconnect the ground lead from the car to the
battery, wait for some (fairly long) time, then test for charge (reattach to
car, if you like).
Good luck! (The alternator isn’t fun – just did that).
Hunt
At 04:33 PM 9/9/96 -0400, William F. Stickney wrote:
Greetings all;
proper battery in the Northeastern section of US?Thanks in advance for any information regarding these items.
Bill Stickney
Date: Tue, 10 Sep 1996 02:54:26 -0005
Subject: Re: I saw “old #25” today and the XJ-S is getting better too.
Jim Isbell:
the steering rack.
Yo, Jim! Do I have to tell you that the bellows are not the problem?
| - Palm’s Postulate
Date: Tue, 10 Sep 96 09:26:18 gmt
Albert Cohoe asked
If the gearbox changes up due to the throttle being released, this would
indicate to me the lever from the throttle to the gearbox is in need of
adjustment. By this I mean that the gearbox thinks the throttle is pushed
further than it actually is, and is thus delaying the gearshift. Often, these
boxes move off in second instead of first (with interestinmg slushy noises), and
this is due to the same lever with incorrect adjustment in the other direction.
The lever also actuates the kickdown.
I just filled mine (last year) until I got the correct dipstick measurement.
Much less, and the gearbox won’t engage, slippage occurs. Don’t actually know
how much I put in. Bear in mind the amount in the book quoted is probably for a
change of oil, not for a fill from dry, which will take a few pints extra.
- Alastair Lauener Work Phone +44 131 455 2458 *
- Chief Technician Fax +44 131 455 2267 *
- Department of Building & Surveying Home Phone +44 1577 864242 *
- Napier University, Edinburgh EH10 5DT a.lauener@central.napier.ac.uk *
- 1964 3.4 S-Type story at http://www.sn.no/home/nick/alas.html *
From: brownd@filon.ml.com (Dave Brown - London Dev X1818)
Date: Tue, 10 Sep 96 09:37:46 BST
Subject: Fair price for SIII V12 Sovereign
My local garage has a quite beautiful 1987/88 SIII V12 Sovereign for sale at
6395 pounds. The car is in mint condition, the PO (company director) having
spent thousands 9I believe over 15K !!) on the car over the last few years
getting everything perfect. The car has 85K miles on it with FSH.
Assuming they would let it go for a straight 6000, is this a fair price for this
model in this condition? I’m toying with the idea as I’ve always fancied a V12!
TIA for any advice/comments.
Cheers,
David Brown
'67 Daimler 250 V8
(and maybe a V12 SIII!!)
brownd@ml.com
///_/_/_/_/////_///______
/_/_//_/_/_/_/_/____
/_/_/_/_/______/_/_/_/______
/_/_/_/_/_/_/________/_/_____
___/_/_/////_/_/_/_/_/______
/_/___/_/_//_/_/_/____
///_/_/_/____/////_///_________
Date: Tue, 10 Sep 1996 11:13 +0200
Subject: RE: Knockoff tool - Marston Motors
Hi everyone, no need to import these from Europe as you can get them from=20
British Autos USA.
Frans.
weekend.
US.
the spare tire.Cheers, Patrick.
1965 E-Type 4.2 Series I FHC=20
Date: Tue, 10 Sep 1996 02:42:00 -0700
Subject: RE: Getting at the A/C microswitch - XJ40
Does anybody have the info on how to change the range of the temperature
control on the XJ40 air con - mine is too warm even on full cold if it’s
running in automatic mode, although it’s OK on manual - I know there is
a rheostat in the control panel I can twirl, but dunno which one.
BTW, feedback for those kind souls who gave me advice on the AC system
“fumigating” me - it turned out to be a leak in the water system. I now
have a constantly slightly fogged up passenger side of the windscreen,
and the coolant level has gone down a fraction. Many Thanks for the
helpful advice.
Graham
Date: Tue, 10 Sep 1996 13:09:58 +0100
Subject: XJ sIII V12 price
XJ sIII V12 price
6000 pounds is very ok for a Mint condition. What are you waiting for ?
Regards Jeffrey Gram
Date: Tue, 10 Sep 1996 08:39:56 -0500
Subject: 1952 MK V
Folks,
I have a friend who has a Mk V Jaguar for sale. The car is all
original except for the upholstery which has been replaced with vinyl. The
car
appears to be above average condition. Any idea what the going price is for such
a car? The body does not show any rust and the chrome looks decent. The woodwork
inside is excellent and it has a sliding sunroof.
Date: Tue, 10 Sep 1996 07:24:45 -0500
Subject: Re: viscous coupler
Kirby,
Thanks. I have not removed one before and did not realize that there was no
accomidation for rebuild.
“Have you ever seen a plumber bite his nails?”
Dt Dallas, TX 83 SIII XJ6
Date: Tue, 10 Sep 1996 13:55:08 PDT
Subject: Re: Fair price for SIII V12 Sovereign
David,
Sounds like a good price. Are you sure everything is perfect!!??
Not wishing to put a downer on things, but remember that this car is
still depreciating. No matter what you do, it will drop in value by a
grand a year for the next three years. At present prices tend to level
off at 3 grand for a good XJ6/12, regardless of age, and will drop from
there according to condition. Also, this one owner car will instantly
become a two owner when you get it!
On the positive side, we all know the XJ6/12 is a classic car. It’s now
beginning to be noticed by the rest of the classic car fraternity, with
the SIII 12 cylinder the most desirable. If you keep it ten years, it
might be worth more than you paid for it!!
Go for it, keep some money aside for when it bites (as it surely will),
and let us know how you get on. Whenever I can afford it, a SIII ‘12’
will be on my short list for another Jag.
Cheers,
Dave Wood.
Date: Tue, 10 Sep 1996 08:13:40 -0500
Subject: JPI - Jaguar Price Index
Since there has been a bit of chat lately about particular car prices perhaps
this is a good time to ask about prices in general. I am thinking of leaving
my current location in the Middle East. Possible destinations are UK or around
Dallas in the US. Can any offer advice on the following.
What is the going rate for
- Series III XJ4.2 circa 82-85 model
- XJS V12 coupe circa 86/87
in UK pounds / $US
Could I take any of my existing (left hand drive) fleet of pussies with me to
the US (or the UK for that matter but I presume not).
Thanks, Robert Bradley
87 XJS V12 coupe, 82 XJ4.2 Series III, 82 XJ4.2 Series III Daimler.
Date: 10 Sep 96 9:23:01
Subject: Re: XJ40: Owners Manual - Climate Control section
I’ll scan this and send it off tomorrow. If anyone else would like a copy,
email me at mpowers@teir.com
and I’ll send you one.
- -Rgds
Mike
Date: 10 Sep 96 09:20:49 EDT
Subject: XK140 C type heads
Dear Brian (Pel), My information also agrees that the earliest XK140 C type
heads had no C type badge and were silver (not red). We have recorded that the
following engines on 140s had no badges: G1161-8S, G1268-8S, G1369-8S. Your car
has engine no. G1022-8S and was despatched from the factory on 14 Oct 54, same
day as the car with G1021-8S. They were the earliest cars with C type engines
to leave the factory. There was a lower engine number G1015-8S but the car was
not despatched from the factory until 20 Oct 54. Terry McGrath wrote at letter
published in the Classic Jaguar Assn journal of March 96 to the same effect as
what you are saying. I will add you to our XK group, but please advise if you
do not want this.
Regards, John Elmgreen
Date: Tue, 10 Sep 96 07:11:24 PST
Subject: Knock-Off tools…
FWIW - Was talking with Bruce Erfer of British Wire Whewels at Palo
Alto All British last Sunday and he made the observation that there is
an element of risk in the use of these.
i.e. the torque thus applied may over-ridede the holding power of your
handbrake, meaning you need another person to stomp on the brakes, if
on a jack stand - may pull you car off (true story), if it slips may
cause knuckle and/or panel damage (true stories).
The good old soft lead hammer ($15 at BWW coincidentally) has always
worked for me.
Date: Tue, 10 Sep 96 09:39:00 PDT
Subject: FOAM not rubber & air dam on XJ-S
Jim Cantrell replied to this message:
You should replace these. They are rubber isolation mounts. If you
don’t, then two bad things will happen over time: 1) the metal to
metal contact will wear through your new radiator tanks eventually
springing a leak and 2) the direct mechanical mount transmits more
vibration to the core and your solder joints will prematurely debond
(primarily around the tak to frame pieces).
I believe Mr. Isbell is talking about the foam rubber that sandwiches
between the radiator & the fender well by the light housing, not the 4
rubber mounts, 2 top & 2 bottom that the radiator sits inside with “pins” on
the radiator going into the center of these. Yes I agree these rubber
mounts or bushings are very important, but how important is the foam rubber
on the sides? Dose this only prevent engine heat from being sucked through
the radiator at low speed? Is this even a problem with the fan shroud in
place?
On the subject of the air dam, are we talking about the $450 US piece of
plastic that mounts just under the black grill under the bumper and a larger
$250 US larger piece of plastic that attaches to the air dam and continues
under the front of the car just under the radiator? Is this not designed &
intended to direct air away from the underside of the car to create a
“vacuum” or low pressure under the vehicle for better handling ? How would
this scoop any significant air up into the radiator? I can see how this does
deflect some air upward, but including the ram force of air by the vehicles
forward movement, does it really make that much difference?
John Himes
88 XJ-S 97K Miles
Date: 10 Sep 96 11:41:20
Subject: XK40 Pwr Door locks
Any help on figuring out this puzzle would be appreciated:
On the drivers side:
outside keylock operates all locks except the for the front passenger lock
inside lock stalk only works once after use of window/lock button OR use of
external keylock
On the passenger side outside keylock operates all locks OK inside lock stalk operates all OK Window/Lock button: operates all locks except front passenger lock I’d swear everything worked OK before I blew the 15 amp power lock fuse. What am I missing? Is there some elusive relay somewhere that needs to be reset? Thanks for any help, Mike /-----------------------------------------------------------------\ | mpowers@teir.com | (703) 736-1832 | | Would somebody please explain to me those signs that | say, “No animals allowed except for Seeing Eye Dogs?” | Who is that sign for? Is it for the dog, or the blind person? | -Jerry Seinfeld *-------------------------------------------------------------------/ From: JISBELLJR@mail.utexas.edu (James A. Isbell) Date: Wed, 11 Sep 1996 10:09:26 -0500 Subject: Water Pump Removal I finaly got the damned thing off. That was worse than the radiator removal! Anyone have any suggestions on how to get the short (3") hose on the top of the temp sender housing into place when I go back on? I had to cut it off to get the pump off and dont see how I am going to get it back on with that hose in there unless I remove the crossover pipe. Second question, there is a pair of wires that comes from below the right side intake manifold (couldnt trace it any further back) and comes around to the area of the temp sender housing on the waterpump. It has two wirws, one black and one white with push connectors on it. Doesnt seem to go anywhere. The temp sender has a pair od green and green/yellow wires on it so thats not what they are for. I am stumped. Kirby, here are the measurementss of the stock impeller: Six blades “A” Outside Diameter = 3.592 inches “B” shaft Diameter = 0.625 inches “C” Height (deck to bottom)= 0.660 inches “D” Height (inside height of impeller blades to bottom)= approx 0.8 inches That last one was hard to measure without removing the impeller. | |<— “B” / | | \ /_ | | \ ___________ | // | || || | \ ^ V// ||| ||| \ |_____ / | | \ | “C”|||_|____V"D" ^ | | | |<---- “A” ------>| | | Obviously the drawing is not to scale…#8-) Jim “Better an outlaw than not free.” Nance O’Neil From: “Jim Isbell” JISBELLJR@mail.utexas.edu Date: Wed, 11 Sep 1996 10:17:54 +0000 Subject: Air Pump I am checking things out under the hood while all the front is accessable. The Air pump seems to make alot of noise. I realise it is a pump so should make some, but how much? From: Ryan Border rborder@hpspls16.cup.hp.com Date: Tue, 10 Sep 1996 10:01:58 -0700 Subject: re: air dam on XJ-S piece of plastic that mounts just under the black grill under the bumper and a larger $250 US larger piece of plastic that attaches to the air dam and continues under the front of the car just under the radiator? Is this not designed & intended to direct air away from the underside of the car to create a “vacuum” or low pressure under the vehicle for better handling ? How would this scoop any significant air up into the radiator? I can see how this does deflect some air upward, but including the ram force of air by the vehicles forward movement, does it really make that much difference? Air which flows through the radiator, into the engine bay, has to exit somewhere. Assuming your bonnet is in place, the exit point for most of this air is out the bottom. The lower the pressure under the car, the easier it is for the air to “get out”. Decreasing the pressure under the car with an air-dam can increase the airflow through the engine bay and the radiator, thus improving the cooling. Just a guess- but I don’t think cars go nearly fast enough for an airdam under the bumper to significantly increase the pressure in front of the radiator grille. At speed, the contribution from the fan is pretty insignificant. Ryan. From: “Kirbert” palmk@gcn.scri.fsu.edu Date: Tue, 10 Sep 1996 13:29:20 -0005 Subject: Oil Cooler/AC Condenser – XJ-S The official Jaguar repair manual and the Haynes manual for the XJ-S both contain the same illustration showing the oil cooler being BELOW the radiator. It’s not that way in my car; the oil cooler is in front of the radiator, and below the condenser. The illustrations in the SICP catalog seem to indicate that all cars were like mine. It has occurred to me that perhaps the oil cooler being under the radiator may be the configuration for cars not equipped with air conditioning. Having the oil cooler in front of the radiator when there is no condenser above it – so the airflow can either go through the oil cooler or simply go around it – probably wouldn’t work too well. Is there ANYBODY out there with an XJ-S that didn’t come with air conditioning? I don’t think it was ever even an option here in the US, they all came with it. If anybody has one, how about checking the location of the oil cooler? Kirbert | If anything is to be accomplished, | some rules must be broken. | - Palm’s Postulate End of jag-lovers-digest V2 #345 ******************************** Return-Path: @owner-jag-lovers-di1 Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4) id for jag-lovers-digest-out; Wed, 11 Sep 1996 00:58:04 +0200 (MET DST) Date: Wed, 11 Sep 1996 00:58:04 +0200 (MET DST) Message-Id: 199609102258.AAA13394@ekeberg.sn.no X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f From: @owner-jag-lovers-di1 To: jag-lovers-digest@sn.no Subject: jag-lovers-digest V2 #346 Reply-To: jag-lovers@sn.no Errors-To: @owner-jag-lovers-di1 Precedence: bulk X-Newsgroups: mail.jag-lovers-digest jag-lovers-digest Wednesday, 11 September 1996 Volume 02 : Number 346 Brake Sleeves FWIW XJ40 hard starts Re: '86 XJ6 Battery Re: Water Pump Removal XJ-40 Hard Stsrts Local Jag-lovers Re: Oil Weight A/C Systems Re: XJ6 S3 Fan Clutch $ Mk2 steering column rebuild Re: Knockoff tool - Marston Motors Re: When the student surpasses the teacher… Re: Hurricane Fran - XJS lowrider (R.I.P.) 88-89 XJ40 Low Brake Pressure?? Re: XJS — Oops!!! (a.k.a. Chassis failure) Re: XJS Micro switch on throttle Re: Hej Matthias, Re: Radiator removal XJS RE: XJS Micro switch on throttle Re: XJS brake fluid reservoir cap re: air dam on XJ-S From: “KENNETH M GILSON” kgilson@ccmail.unl.edu Date: Tue, 10 Sep 96 12:30:58 CST Subject: Brake Sleeves FWIW The company you suggested “Imperial Machine Co. in Lincoln, Ne USA” to resleeve the master cylinder and/or the brake cylinders is owned and ran by an acquaintance of mine. He is a top notch machinist and does excellent work. I would recommend him to do anyone’s work. From: Michael Powers/TEIR/Thomson Michael_Powers@teir.com Date: 10 Sep 96 13:34:54 Subject: XJ40 hard starts I have a 89 XJ6 that takes about 4-6 seconds to start after it has sit for about an hour. It starts fine when the engine is cold and it starts fine immediately after it has been turned off. Also, I never use the gas pedal when cranking the engine (per the manual). Any areas I can starting looking? Any component failures that this might point to? As always, thanks for any input, Mike /-----------------------------------------------------------------\ | mpowers@teir.com | (703) 736-1832 | | Would somebody please explain to me those signs that | say, “No animals allowed except for Seeing Eye Dogs?” | Who is that sign for? Is it for the dog, or the blind person? | -Jerry Seinfeld *-------------------------------------------------------------------/ From: BSherw@aol.com Date: Tue, 10 Sep 1996 13:39:34 -0400 Subject: Re: '86 XJ6 Battery "William F. Stickney >picker1@ix.netcom.com< wrote:
I have a need to check my battery. It appears to be not holding a charge.<
William- before buying a new battery, I suggest you check alternator output,
should be about 13.5 to 14 volts, measured across battery terminals with
engine at
idle. Also good to check battery with engine off: turn on lights and see if
battery
residual voltage (12 V) drops quickly under load (not good).
Good luck-
Brian Sherwood
'85 XJ6
'84 XJ-S
Date: Tue, 10 Sep 1996 14:26:14 -0400 (EDT)
Subject: Re: Water Pump Removal
One of the reasons I recommended taking the hood off even though it
is not strictly necessary. Removing and replacing the hood is not
difficult. Working on the water pump/radiator ect is a lot
easier with the hood out of the way. One recommendation: be careful
when you reinstall the pump. I understand that a lot of people
break the pump housing by over-tightening that one countersunk
head allen bolt.
Why don’t you want to remove the crossover pipe? That is the way to do it.
Do remove the crossover pipe and replace the little hoses on each end too.
Thomas E. Alberts
Date: Tue, 10 Sep 96 13:15:30 CDT
Subject: XJ-40 Hard Stsrts
I had this same exact problem with my 88 XJ-40 and several others on the list
have reported the same. Hard starting with a hot engine that has sat for a
while. It was due to failure of the non-return valve at the fuel pump. This
allowed the fuel vapor pressure to push the fuel back to the tank and the
system to vapor-lock. The non-return valve is cheap and easy to replace.
Paul Lacey, Texas
Date: Tue, 10 Sep 1996 12:22:57 +0700
Subject: Local Jag-lovers
Are there any other Jag-lovers in the Northern New Mexico area?
Greg Price
Date: Tue, 10 Sep 1996 14:55:15 -0400
Subject: Re: Oil Weight
until recently, i have been using Castrol 10W-40 oil in my 1985 Vanden Plas
with 136,000 miles on the engine. yesterday, i took the car to an authorized
jaguar dealer in frederick, maryland for some gasket repairs to fix a major
oil leak. the mechanics there impressed me as being extremely knowledgeable
about jaguar cars (or extreme bullshit artists; its too early to tell).
those mechanics recommended using Castrol 20W-50 in order to burn less oil.
they think that the “proper” weight oil, coupled with the gasket repair,
should curb my cat’s appetite (100 +/- miles/quart!!!) for the viscuous
petrol stuff. even though they make a convincing argument, i have NEVER
heard of using that weight of oil in an automobile.
my question to the auto handymen of the jaguar persuasion is: does this
sound reasonable? is 20w-50 the correct weight oil? if so, how does
temperature and seasonality affect this oil in my 4.2 liter? all insights
and opinions are appreciated.
thanx - jim
From: Carlos Madero/Intl/Corp/Tyson Carlos_Madero/Intl/Corp/Tyson.TYSON@mislnx.tyson.com
Date: Tue, 10 Sep 1996 13:50:24 -0500
Subject: A/C Systems
I have read with interest the discussion in regard to Jag A/C systems and all
the hassles and problems associated with them. The reports I have read on the
A/C on early 70’s XJ cars don’t have much good to say about it either. Has
anyone exchanged / upgraded components (evaporator, expansion valve, etc) to
make the system perform better? I know it must be a pain to gain access to
these components under the dash, but with current technology and parts
available, there must be a way to upgrade the system so that it cools better.
Since I still intend the remove the dash to refinish it, I also will look into
upgrading the A/C while everything is apart.
Carlos Madero
'73 XJ6 (since '86)
'53 Chev PU
'86 Caprice (with COLD air and a strong V8 which is scheduled to go in the Jag
soon)
Date: Tue, 10 Sep 1996 15:42:55 -0600
Subject: Re: XJ6 S3 Fan Clutch $
Don’t recall the originator but someone asked about an XJ6 Fan Clutch. The
Original part number for the Series 3 is EAC4751. The XJ40 is different
incidentally. If anyone wants an aftermarket alternative, I sell them for
$69.95 each.
Best Regards,
Hal
Hal Rogers
H.D. Rogers & Sons
Import Auto Specialists
3418 Barksdale Blvd.
Bossier City LA 71112
(318) 742-3651 voice
(318) 742-5044 fax
Serving Auto Enthusiasts since 1959
From: “Patrick O’Neill” patrick.oneill@premierusa.com
Date: Tue, 10 Sep 1996 14:00:18 -0700
Subject: Mk2 steering column rebuild
I am in the middle of rebuilding the steering column on my 1963 LHD Mk2
3.8L MOD, actually I am just putting in new nylon bushings.
Has anyone done this before? My car had a nylon bushing in the top of the
column but it has a felt bussing in the bottom. I purchased the top and
bottom nylon bushings and I will us the nylon in the bottom unless some one
has a good reason not to.
Are you supposed to use any kind of lubricant on these nylon bushings?
Are there any other jobs I should do as I have the column out?
On a side note a few months back there was a discussion about Mk2’s RHD vs.
LHD with regard to a U-joint or a rubber “flex” joint into the steering
box. I believe the general thinking was that RHD cars had the U-joint and
LHD cars had the flex-joint, well my LHD car has a U-joint and it is a
original Power steering car.
Kind Regards,
Patrick D. O’Neill
1963 MK2 3.8L MOD
Rolling Hills Estates, California
www.beachnet.com/~patricko
PS I have just added some cool Jaguar Animated GIF files to my Web site
Date: Tue, 10 Sep 1996 23:05:19 +0200
Subject: Re: Knockoff tool - Marston Motors
[ Patrick Krejcik pkr@SLAC.Stanford.EDU ]
| US.
This would be The Hutson Motor Company. They have incidentally
just opened a web-page at http://www.jagweb.com/hutson/
Nick
<<< Nick Johannessen | nick@sn.no | nickj on IRC >>>
<<< Jaguar XJ6 4.2 '70 MOD & '82 Auto >>>
The JagWeb http://www.sn.no/~nick/jaguar.html <<<
The Jaguar Specialists Web http://www.jagweb.com <<
Date: Tue, 10 Sep 1996 17:22:41 -0400 (EDT)
Subject: Re: When the student surpasses the teacher…
And second prize is two Esprits…
John
On Fri, 6 Sep 1996, Lee Walden wrote:
My brother told me that some guy offered Lotus a deal to put
all of the service manuals for the Esprit on a CD-ROM. They
“rewarded” him with a brand new Esprit Turbo. Talk about
not fair…
Lee
Date: Tue, 10 Sep 1996 17:37:37 -0400 (EDT)
Subject: Re: Hurricane Fran - XJS lowrider (R.I.P.)
My condolences to you and your family on the damage to your house and
property and XJ-S. This is a terrible thing to go thru and I only hope
that you are treated fairly by the insurance adjusters.
Consider using an agent to negotiate on your behalf. They charge a fee
but in the experiences of several friends that went thru similar losses
during local storms, they end up getting you far more than you would have
on your own. Since many of the Jag parts were in the house and possibly
damaged, perhaps that can be counted as ‘personal property’ rather than as
part of the car.
It seems that you are all ok physically, and of course that is the most
important, but nevertheless thius is a terrible thing to go thru.
Especially the waste ofthe car.
Consider keeping the hulk if it is not repairable and parting it out.
Perhaps you will find enough buyers on the list to help with the loss.
John
On Fri, 6 Sep 1996 Juliansean@aol.com wrote:
Hurricane Fran
To the Jag-lovers mailing list. =20
I=92ve never experienced a hurricane before so the feeling of powerlessne=
ss is
strangely interesting. It=92s 4:00 AM and the wind is still building. N=
othing
Any feedback on advice, to keep for parts or not, market values (I=92ll h=
ave to
deal with insurance people) would be much appreciated. =20
By the way, wasn=92t someone selling a convertible XJS on this list not t=
oo
long ago?? I forgot who it was but please contact me.
Thanks for listening.
=20
Julian Mullaney
1987 XJS Convertible (now with VERY low ride height)
=20
=20
Date: 10 Sep 96 17:46:41
Subject: 88-89 XJ40 Low Brake Pressure??
My VCM Low Brake Pressure light ALWAYS comes on for a minute
or so after I start my XJ6. It also seems to appear once in a while when I put
the
car in park What’s up with this thing? The brakes seem like they are in
perfect working
order.
Any ideas and/or experience with this?
- -Mike
| mpowers@teir.com
| (703) 736-1832
| -Jerry Seinfeld
Date: Tue, 10 Sep 1996 17:48:24 -0400 (EDT)
On Fri, 6 Sep 1996, Kirbert wrote:
John Napoli:
there’d be a market. But the more common fix is to ADD a support,
usually some kind of link from the bottom center area of the cage
forward, parallel to the drive shaft, to some bracket attached to
the floorpan. Rubber doughnuts on both ends, like an anti-sway bar
link. The result is that the cage is held much more securely without
stiffening the existing mounts themselves, and there’s probably a
lot less stress on some other components as well.
I have not heard of this solution previously but it makes a lot of sense.
It would keep the cage from rocking back and forth.
I would like to take this opportunity to point out that if one was to
go to totally solid mounts, it would be a good idea to toss the
trailing arms at the same time.
Yes, this is an absolute. The trailing arms might not even have enough
flex if the cage was solid.
- The XJ-S in question seems to be one of the more powerful ones out
there. Is the stock setup just unable to absorb the extra power over an
extended time?It’s my understanding that any effort toward giving the XJ-S a
serious hole-shot capability endangers the rear cage mounts. My own
car hauls a__, but I don’t push it very often at all, probably have
just avoided problems for myself. Again, the standard fix is that
link holding the bottom of the cage; I’ll probably rig one for my car
one of these days.
I am interested in this mod myself. But one of my plans was to route the
exhaust pipes under the center of the cage to be able to go to a larger
diameter and remove some of the heat from the rear disks. I wonder if you
can do both?
- If the failure was hastened by rust in the tub, do we all face this
problem? Where does the water get in from? How do you check (drill holes
in some strategic location)? I have seen E-Type tubs cut open; they get
looking pretty bad inside rust-wise. Do our XJ-S’s have the same
proclivity?There are guys here more adept at anti-rust practices than I, and one
of the discussions has been going on recently. I can only say that,
clearly, this particular spot is one where attention is warranted.
They seemed to discuss rust in areas easily accessible. We are talking
about, I think, hidden sections. I wonder if there is a stabilization
technique that can be effectively used on hidden box sections. Maybe
spritz in a rust neutralizer followed by a resilient coating followed by a
closed-cell foam that expands just the right amount and that does not
absorb water.
John
Date: Tue, 10 Sep 1996 17:56:25 -0400 (EDT)
Subject: Re: XJS Micro switch on throttle
Question: will a pushbutton wired in parallel with this switch and
controlled somehow by the driver provide part-throttle kickdown? Or does
the electric kickdown only work if the transmission is also seeing zero
vacuum at the modulator (from WOT)?Of course, this begs the question: Why would you want to do such a
thing? You can always just pull the shifter into 2nd.
Faster than struggling with the detents.
John
Date: Tue, 10 Sep 1996 17:55:00 -0400 (EDT)
Subject: Re: Hej Matthias,
What year range did the donor impeller come from? I presume that it was
from a Chevy small-block V8.
My water pump is very accessible (mechanical fan drive long gone) and I
have a lot of instrumentation (TWO mechanical water temp gauges installed
in different locations in addition to the stock gauge) so my car might
make a great experiment. I’m willing to do it, but don’t want to kill my
perfectly fine water pump to try it. Anyone got a dead water pump to lend
me? I don’t think I’d have trouble in getting one of the impellers Kirby
describes.
My car could be the guinea pig, and I will be able to report quantified
results.
John
I have never mentioned this impeller substitute in my booklet,
primarily because it was NOT a perfect fit. But seeing as how I
seem to be the only one around here who lives in a hot climate and
has no overheating problems, maybe there’s a clue here somewhere.
The next time somebody has a pump off (or a spare laying around),
take it down to the local parts store and compare the impeller with
those on the various pumps on the shelf. Tell us if there appear to
be any that would be an excellent fit, and if any have vanes that
look like those on the Jag impeller.Jag impellers have steeply backward-sloping vanes, and nobody else
does. Jaguars have a reputation for overheating, and nobody else
does. Connection?
Date: Tue, 10 Sep 1996 18:22:51 -0400 (EDT)
Subject: Re: Radiator removal XJS
On Sun, 8 Sep 1996, Jim Isbell wrote:
I am in the process of removing the radiator from my XJS and have
found several errors in the Haynes manua. So whats new? The big
error is that they say you have to discharge the AC. It aint so!
The second is that they say you need to remove the bonnet. It aint
so. Just remove the grill and one end of the lift struts and the
bonnet will lean back very happily on the bumper, well out of your
way.
On my car, with the replacement struts we talked about on the list a long
time ago, I don’t even have to do that. Just remove the top panel and
hoses.
Anyone know how important the sponge rubber inserts around the
ratiator are. Mine are rotted away.
Very important. As Kirby points out in his book, the radiator absorbs
vibrations from the rest of the car and it can’t do this unless properly
mounted.
It looks like the front license plate does alot of damage to the air
flow into the lower grill, and with that dam gone, that might be a
big part of my overheating problem. Any comments on removing the
licnseplate?
My XJ-S has never had an air dam (PO must have killed it) and it has not
made any difference (car never overheats). It will run a few degrees
hotter at high speeds (I can track this on the tertiary mechanical water
temp gauges I have recently installed) and presumably if I had a front air
dam this would not be the case.
John
Date: Tue, 10 Sep 1996 18:29:13 -0400 (EDT)
Subject: RE: XJS Micro switch on throttle
Thanks. Another thing to try.
John
On 9 Sep 1996, Jan Wikstroem wrote:
John Napoli :
From my own experience when the arm on the microswitch decided to bend past the
critical point, I can report that it’s the switch alone that operates the
kickdown subject to governor settings, regardless of vacuum.
-Jan
Date: Tue, 10 Sep 1996 18:37:07 -0400 (EDT)
Yes, I like that idea. Makes it less likely to miss something.
John
Date: Tue, 10 Sep 1996 18:54:46 -0400 (EDT)
the radiator, thus improving the cooling.Just a guess- but I don’t think cars go nearly fast enough for an airdam
radiator grille.
Your response raised an interesting question. My XJ-S has no air dam.
Some time ago, as an experiment, I disconnected my hood struts, popped the
hood latch, and went out for a drive. By 30 mph or so the hood was firmly
pulled up against the hood safety latch. Conclusion: much higher
pressure underneath, even at that low speed. I wonder what the results
would be on a car with an air dam?
John
End of jag-lovers-digest V2 #346
X-UIDL: 88f155a9bdce0fcbd5c4925cf574c182
id for jag-lovers-digest-out; Wed, 11 Sep 1996 05:26:27 +0200 (MET DST)
Date: Wed, 11 Sep 1996 05:26:27 +0200 (MET DST)
Message-Id: 199609110326.FAA13761@ekeberg.sn.no
Subject: jag-lovers-digest V2 #347
Precedence: bulk
Status: RO
X-Status:
jag-lovers-digest Wednesday, 11 September 1996 Volume 02 : Number 347
Re: Oil Weight
re: air dam on XJ-S
Re: 88-89 XJ40 Low Brake Pressure??
XJ40: ‘Coolant level low’ indication
Re: FOAM not rubber & air dam on XJ-S
Panic in the forest
Re: XJ40: ‘Coolant level low’ indication
1986 XJ6 Series III - Fuel pressure regulator.
Re: air dam on XJ-S
Rear Brakes on 89 XJS
fuel for the “air dams on the XJ-S” controversy
XJ rear suspension behaviour
Wire wheel repair in merry old England
Date: Tue, 10 Sep 1996 19:02:21 -0500
heard of using that weight of oil in an automobile.my question to the auto handymen of the jaguar persuasion is: does this
and opinions are appreciated.thanx - jim
20W50 is the recommended oil for the V12 engine except for operating
conditions below freezing. I believe the reason is the high expansion
coefficient of the Al block and the resulting increased clearances of
a hot engine.
Bob Johnson
XJ12l, XJ50, XJS
Date: Tue, 10 Sep 1996 16:31:47 PDT
Hi John,
Lets see if all those aerodynamics classes I took can be useful
here in the real world:
Bernouli’s equation for for incompressible inviscid fluid:
P + (r/2) * V*V = K
P= static pressure
r= density: constant for our case… unless your radiator’s really
doing a good job
V= velocity
K= some arbitrary constant.
What this says: as V goes up, P goes down (proportional to the square of V)
The faster the air is flowing over a surface, the less the pressure is
on that surface. That’s why convertible tops bow up off their frames
at speed. That’s why your hood tried to lift… airflow over the top
of it was going much faster than the air under it. It’s why (sort
of) airplanes can fly :-).
Adding an airdam may indeed decrease the pressure under the car, increasing
the speed of the air through the engine bay; BUT, I don’t think you
could ever get the hood to be sucked down, short of some very special
air channelling under the hood, combined with a big upright windshield
to stagnate the flow over the top of the hood :-). You might be able
to increase the speed where the pressure differential across the hood
overcomes the weight of the hood slightly though.
Ryan.
Date: Wed, 11 Sep 1996 09:28:19 +1000 (EST)
Subject: Re: 88-89 XJ40 Low Brake Pressure??
put
the car in park What’s up with this thing? The brakes seem like they are in
perfect working order.
Michael Neal sets out tests to determine if the system is working OK and if
not, what is wrong. It is well worth reading, so here is what he says:-
"Check Accumulator
Run car at 2000+ RPM for 30 seconds. Shut motor off and turn key on to
activate VCM. Pump pedal slowly, 3 count intervals, check the number of
times before the low brake pressure warning light comes on. A fully charged
accumulator will go 9 pumps. 4 pumps necessitates system check out,
probable accumulator bladder failure.
Check Charge Solenoid
Continue pumping down system after previous test until pedal is rock hard.
Start car and stopwatch, run at idle, observe VCM. Stop timer when low
brake pressure indicator goes out. A red border can be seen if a different
warning is reading on the inner screen. The red border is a background
indicator of this warning. Test several times. 9 to 15 seconds is a good
reading. Any longer and pump pressure could be low or charge (load)
solenoid may not be seating. Common probable fault is the charge solenoid.
Pump, Charge Solenoid, Accumulator Combo Test
Run car at 2000+ RPM for 30 seconds. Return to idle. Pump brake pedal
firmly and swiftly until low brake pressure light comes on. Stop at 30 pumps.
Roughly 10 pumps usually signals a faulty charge solenoid (not seating). It is
less likely but possible for low pump pressure or a completely discharged
accumulator to fail this test. See pump test.
Hydraulic Pump Test
Disconnect line to valve block. Check pressure. Most failed pumps can be
stopped off with thumb pressure. Check flow of ??? per minute???
Check Valve Test
To check discharge of hydraulic ride leveling system, charge system and
measure ride height at fender lip. Recheck height after 12 hours. More than
1/8"??? sag is a sign of a faulty check valve located behind the up solenoid."
Michael, I hope you don’t mind me reproducing this, but it is necessary
reading for all XJ40 owners. Alan
From: “Rennick, Kim (AS01)” KRennick@p03.as01.honeywell.com.au
Date: Wed, 11 Sep 96 09:27:00 EST
Subject: XJ40: ‘Coolant level low’ indication
Folks,
Some time ago I posted this message to jag-lovers:
My 3.6L XJ40 Sovereign is reporting ‘Coolant Level Low’ on the VCM. It was
originally an intermittent >indication but has progressed to being
constantly ‘on’.I checked the condition of the level sensing float in the header tank - it
seems to be OK. I then >checked the resistance across the two wires
connected to the sensor . When the float is in the ‘low’ >position, the
switch goes open circuit (as expected). When the float is in the ‘full’
position, the >resistance was 250 ohms. (Actually in the space of 30
minutes or so, this reading gradually increased >to 450 ohm.)The circuit diagram is unclear on this, but I would have expected this
sensor to be a simple >open/closed contact - either open circuit (for
‘empty’) or 0 ohm (for ‘full’) . Can anyone confirm this?If so, can anyone tell me if the sensor switch is serviceable? ( haven’t
yet been brave enough to pull it >out of the header tank to check!) Are the
switch contacts accessible for cleaning once the switch is >removed?Any other ideas as to the cause?
Well, time goes by, and I slowly learn more about this little gadget!
Firstly, it is easy to remove from the expansion tank (just pull it out,
like a tooth!). The sensor is (I presume) a magnetic switch, with all the
electrical side totally encapsulated, hence not able to be worked on
(viewed, cleaned etc). I assume that when the float is ‘up’ the magnetic
fields align and cause the electronic switch to close. When the float is
‘down’ the switch opens.
However I still need help! (some things never change!) On the bench the
switch read some 3K ohms in its ‘closed’ state - which is a long way from 0
ohms, you will agree.
Since I hadn’t purchased the replacement part, I re-installed the switch,
and sure enough, it still reported ‘coolant level low’, even though the
level was OK. However, over the succeeding 2 days (yep, you guessed it) the
system has seen the error of its ways and has stopped the false indication,
even though I did nothing substantive to correct the problem!!
Just for the record, can someone tell me:
- Is my understanding (!) of the circuit correct?
- What is the resistance across the terminals when the sensor is reading
‘full’? - Will the instrument ECU be harmed if I short the terminals to simulate a
closed switch?
Any comments would be most appreciated - the workshop manual doesn’t get
within a hundred miles of this sort of detail!
Kim Rennick
| XJ40 3.6L Sovereign -
| Citroen BX 19 GTI -
|…(English and French rapprochement in my garage!)
|__________________________________________________
Date: Tue, 10 Sep 1996 20:38:51 -0005
Subject: Re: FOAM not rubber & air dam on XJ-S
John Himes:
sandwiches between the radiator & the fender well by the light
housing… how important is the foam rubber on the sides? Dose
this only prevent engine heat from being sucked through the
in place?
This sponge prevents air from bypassing the radiator AND fan shroud
at speed. If the problem is overheating at speed but not at idle,
these sponge items are important.
Gee, I only paid $175 for the spoiler a few years back, and I MADE
the other part.
We have located yet another jag-lover who has not read my booklet!
The spoiler is VERY important for cooling at speed. Without it, the
pressure under the front of the car is higher. Since that is where
any air coming through the radiator has to go (this car has no hood
louvers), this high pressure backpressures air coming THROUGH the
radiator, reducing cooling airflow considerably. Basically, the
spoiler missing allows air to bypass the radiator AND the engine
compartment and go directly under the car.
| - Palm’s Postulate
Date: Tue, 10 Sep 1996 20:38:52 -0005
Jim Isbell:
Methinks you just answered your own question! Why didn’t you pull
the crossover pipe to begin with? It’s only held by the 3 hoses
(well, plus one tiny one), is a cinch to remove, and makes it easier
to work on the pump!
Six blades
“D” Height (inside height of impeller blades to bottom)= approx 0.8 inchesThat last one was hard to measure without removing the impeller.
--->| |<--- "B" / | | \ /_ _| |_ _\ ___________ | // | || || | \\ ^
V// ||| ||| \ |______
“C”|||_|____V"D"
| |<---- “A” ------>|
This data may be useful for finding substitutes, but then again, it
might not be. Take the D dimension, for example; a substitute
impeller might have vanes that extend farther INWARD. Since the
housing is conical, they would also be taller, since the D dimension
is taken at a radially inward spot.
This data is still not very useful for determining if the impeller
vane SHAPES are the problem. Of course, I dunno how we’d determine
that, other than to have someone with an overheating problem replace
his impeller with one from a Chevy and make NO OTHER CHANGES and his
overheating problems go away. Still, I’d appreciate qualitative
observations/comments about the shape of the Jag impeller vanes vs.
the shape of other water pump impeller vanes.
By the way: Once, while replacing the water pump on a Citation (!),
I happened to notice that the impeller vanes on the rebuilt pump
angled the opposite direction from those on the original pump. Took
it back to the store and compared against the other pumps on the
shelf for the same car, and found I had the ONLY one with the
impeller vanes the opposite way. I think someone at the rebuild shop
had accidentally installed the wrong impeller. I traded for one that
looked right, and suggested the store send that one back. The
lesson, of course, is that if you’re looking for a substitute
impeller for the Jag, make real sure to get an impeller that is
designed to turn the right way! Apparently there are some that turn
the other way, for some reason.
| - Palm’s Postulate
Date: Tue, 10 Sep 1996 21:36:44 -0400
Subject: Panic in the forest
I spent a long time finding my first Jaguar, a 1990 XJ40 VDP Majestic which I
purchased in May. One of my criteria (besides a low enough price that the
payments would not bankrupt me) was a “fresh” interior with good wood…
I wound up with a very nice car which cost me only $2,200 to repair due to
the PO’s dwindling interest in maintenance. The only fault in the wood was a
severely deteriorated ash receiver cover on the console; this has actually
fractured into several pieces.
It would appear that the rest of my wood trim is deteriorating rapidly. It
looks great from arm’s length, but getting real close reveals many tiny
light-colored “fractures” appearing in the finish. Have I just noticed them,
I wonder, or is something horrible happening? What can I do to prevent this
deterioration? Is refinishing or replacement the only option?
I hesitate to ask what it would cost to replace this all.
Robert MacLeay
Date: Tue, 10 Sep 1996 19:06:10 -0700
Subject: Re: XJ40: ‘Coolant level low’ indication
Can’t help with the technical aspects of your problem…but this came
through the jag-lovers list several weeks ago, and if you haven’t seen
it, I believe it applies to your situation nicely. I’ve had one or two
of those with my 91 Sovereign too.
There are four engineers traveling in a car; a mechanical engineer, a
chemical, an electrical engineer and a computer engineer.The car breaks down.
“Sounds to me as if the pistons have seized. We’ll have to strip down
the engine before we can get the car working again”, says the
mechanical engineer.“Well”, says the chemical engineer, "it sounded to me as if the fuel
might be contaminated. I think we should clear out the fuel system.“I thought it might be an grounding problem”, says the electrical
engineer, “or maybe a faulty plug lead.”They all turn to the computer engineer who has said nothing and say:
“Well, what do you think?”“Ummm - how about if we all get out of the car and get back in again?”
Mike Frank
If you can’t fix em…enjoy em!
Don Farr
Donald R. Farr
Paradise Valley, AZ
91 Sovereign
Date: Tue, 10 Sep 1996 21:16:12 -0600 (CST)
Subject: 1986 XJ6 Series III - Fuel pressure regulator.
Hello the list. I want to revisit a subject i mentioned briefly in a
previous post.
The Bosch FI book by Charles Probst (1991 Ed) states on page 9 that a “neat”
method of relieving fuel pressure is to “connect a hand vacuum pump at the
pressure regulator, when you pump vacuum the regulator will dump pressure to
the fuel tank”. Mine pulls 62 Hg with no effect. Has anyone on the list
tried this? A fuel gauge is not necessary. Just pump up the system using
the air flow meter vane (with the ignition on). Squeeze the hose to the
fuel rail and apply vacuum to the regulator, the hose will relax if the
pressure drops significantly. Go on, try it.
Therefore, is the Bosch FI oracle wrong, the Jag L-jetronic system different
(its a Bosch regulator), or some function of my regulator, to use a quaint
British (engineering) expression, just buggered? Assuming the latter, I
took regulator and vacuum pump to a local Bosch parts purveyor. After much
sucking, blowing and pumping they declined to relieve me of the eighty or so
dollars to order a new one saying that it was “probably OK”. Unfortunately,
they did not have an equivalent in stock to make a comparison, so I am still
not sure, but for now I will look elsewhere for the cause of my pressure leaks.
Tony Gardner
XJ6 Series III 1986
Date: Tue, 10 Sep 1996 22:27:48 -0400
Subject: Re: air dam on XJ-S
In a message dated 96-09-10 19:03:40 EDT, jgn@li.net (John Napoli) writes:
<< By 30 mph or so the hood was firmly
pressure underneath, even at that low speed. I >>
John, this was surely due to the Bernoulli effect. Faster airflow over the
outside of the hood = lower pressure on outside of hood than underneath. Not
necessarily higher pressure underneath. This caused the bonnet of my MG to
lift up once and crease itself over the windshield. It was worse than an XJS
though…
Julian Mullaney
Date: Tue, 10 Sep 1996 23:18:51 -0400 (EDT)
Subject: Rear Brakes on 89 XJS
> I have overhauled the rear brakes on the above car and while I was
under there I
had planned to replace the flexible brake line which goes to the T
connector.
However, on the flexible line in the car there is what appears to be a mini-
c-clamp that cross clamps the flexible line in the middle. Is this factory?
If so
what purpose does it serve? I was planning to simply remove it and replace
the line.
Are there any problems with this?
– Kirbert
Nope,
I’ve looked closely. It actually cross clamps the line!!!
Any Ideas? Any reason why it would hurt the ABS system if I removed it?
Patrick Bowers
Date: 11 Sep 96 13:40:21
It’s fairly simple to test if the battery holds charge. Disconnect the battery,
charge it fully, let it stand an hour to settle down, then use a hydrometer to
check the density of the electrolyte in all cells. Leave the car parked for a
couple of days, then repeat the electrolyte test. There should be no visible
change to any cell. If there is, the battery is being discharged.
The battery can be discharged by an external load (typically, a damaged diode
in the alternator) or an internal one. What happens is that with age, the lead
paste in the grids gradually falls out and accumulates in the bottom of the
battery. This not only gradually reduces the capacity of the battery; the paste
on the bottom of the container eventually builds up to where it reaches the
grids and draws a leakage current.
- -Jan
Date: Sun, 08 Sep 1996 19:40:53 -0700
Subject: fuel for the “air dams on the XJ-S” controversy
Here’s my two cents worth on the air dam controversy:
- -The front spoiler helps to create a low pressure zone under the car at
higher speeds. - -At low speeds, the “spoiler undertray” prevents flow of the “air being
blown into the engine bay by the radiator fan” under the car, through the
opening that exists between the front of the engine and the back of the
radiator. - -The impact of this opening is really obvious on a car like mine which
currently lacks the “undertray” as well as the dam (I’m looking for a
reasonably priced used set if anyone knows of one). If the undertray is not
there, then the path of least resistance for the flow of air (once it hits
the mammoth front of the engine) is to go down through the opening created
by the absent undertray, rather than around the engine bay (big obstacle). - -If the undertray is there then the air is forced to flow through the engine
bay (actually around the engine) and to exit at the back end of the engine bay. - -At high speed, and if both the dam and undertray are there, they help each
other. The dam creates a low pressure zone under the front of the car that
helps to suck-out the air flowing to/out-of the back of the bay. - -I also suspect, that if both the dam and undertray are present, they
probably reduce the amount of heat that accumulates (and radiates from) the
transmission tunnel.
Any other thoughts?
Rob W-M
85 XJ-S
Date: 11 Sep 96 13:58:51
Subject: XJ rear suspension behaviour
Some measurements that may interest you:
In the process of overhauling the rear suspension on my XJC, I took the
opportunity to study the suspension geometry in detail, since we’ve just been
having a few comments on that. Kirby made the point that the torque arms will
tend to tilt the rear sub-frame as they move up and down, giving rise to some
rear-end steering - which sounds reasonable. So I did some linkage moving with
the torque arms fitted but no shock/spring units (hey, I’m not that strong!)
and a dial gauge set up longitudinally against the rear middle of the rear
subframe. Keep in mind that this car is 19 years old and the torque arm
bushings look original; they certainly have plenty of surface cracking and
appear soft. Measurements on another car with fresher rubber may be different.
The subframe tilts visibly as you move the suspension up and down as far as it
will go - however, this mostly seems to happen at the bottom end of the travel,
and mostly outside the possible range as the complete suspension will not go
beyond where the shock absorbers are fully extended.
Now for simulated cornering: moving the suspension on the notional outside in a
corner through the roughly 80 mm (3 1/4 in) of travel from the static ride
height (sedate cornering) to full bump stop (yeeee-haa!) the subframe doesn’t
move visibly - 0.11 mm (4.3 thou) forward by the dial gauge. Simulating
cornering roll by leaving the outside suspension fully compressed and moving
the notional inside wheel halfway down to maximum shock absorber extension,
there’s again no visible movement - hard to read the dial gauge but say 0.04 mm
(1.6 thou) forward. That’s what you’d get under very hard cornering indeed; if
the inside rear wheel lifts (which I can’t make it do in real driving) there’s
a sharp forward kick by all of 1.9 mm (75 thou) in the last inch or so of
extension.
The conclusion is that under mere brisk cornering, the rear sub-frame tilts
very slightly base-forward, with the outside leading. Under all-out race
cornering, the tilt on the inside may become larger than on the outside. What
does this mean at the wheels, except of course that movement at the centre
corresponds to twice as much movement at the wheel? Well, we have deflected the
outside wheel to where its axis is mere millimetres below the subframe mounting
rubbers; with the subframe probably tilting about a virtual axis close above
those rubbers, the leverage effect would reduce the forward movement to
effectively zero. On the inside, the wheel axis is close to the base of the
subframe, so the wheel gets the full effect of the forward movement. This would
move the inside wheel slightly forward of the outside one. Net effect: very
slight steering effect except right close to the limit of adhesion - and let’s
not forget the rear wheel toe-in (nearly 3 mm on my car), which would tend to
counteract that.
I can’t measure what might happen under acceleration and braking torque loads,
as this requires resources I don’t have - but the XJ is a fine exponent of
classical rear wheel drive behaviour, meaning that giving extra gas in a corner
tends to tighten the line slightly and increase perceived grip. “Tightening the
line” means of course that the rear wheels steer out slightly, going from
neutral steering to slight oversteer. I don’t think that effect comes from
anything to do with suspension geometry; it’s adequately accounted for by the
fact that applying driving force to the wheel/road interface reduces the
proportion of total adhesion left to resist cornering force.
Sure, applying increased torque to the final drive unit would tend to twist the
rear sub-frame base forward and top back against the rubber mounts and torque
arm rubbers, equally on both sides. The only effect on cornering I can see in
that is that the pushing of the hub carriers against the torque arms flexes the
lower suspension arms, hubs and pivot bearings slightly backward from the
centre, counteracting the toe-in. Since this would have the greatest effect on
the much more heavily loaded outside tyre, there would be a slight outward
steering. However, those suspension parts are enormously strong, and I can’t
imagine any deflection that matters.
Anyway, all these slight deflections I’m talking about may well be swamped
utterly by wholesale rubber flexing in real-life driving on a bumpy real-life
road - but all in all, I’m left with a strong impression that the Jaguar XJ
rear suspension is pretty damn’ good even by today’s standards.
- Jan
Date: Tue, 10 Sep 1996 23:26:16 -0400
Subject: Wire wheel repair in merry old England
Earlier this week, someone was asking about wire wheel repairs in England.
This month’s issue of Jaguar Enthusiast carries an ad from “Peter Rees
Wheels”, 01342 850551/0468 573005. They list locations in London, Manchester
and Cardiff. Hope it works out for you.
Mike Frank
1969 E-Type 2+2
End of jag-lovers-digest V2 #347
id for jag-lovers-digest-out; Wed, 11 Sep 1996 15:33:19 +0200 (MET DST)
Date: Wed, 11 Sep 1996 15:33:19 +0200 (MET DST)
Message-Id: 199609111333.PAA09101@ekeberg.sn.no
Subject: jag-lovers-digest V2 #348
Precedence: bulk
jag-lovers-digest Wednesday, 11 September 1996 Volume 02 : Number 348
Fire extinguisher/XJ
Re: 1986 XJ6 Series III - Fuel pressure regulator.
Re: jag-lovers-digest V2 #346
Re: Rear Brakes on 89 XJS
Re: Oil Weight
64 3.8 S-type automatic transmission shifting hard
Cats in Their Environments
Re: Mk2 steering column rebuild
SI XJ12 idle
Date: 11 Sep 96 14:27:25
Subject: Fire extinguisher/XJ
I’ve found a great location for the fire extinguisher in S1 and S2 XJs (don’t
know if it applies to S3, S4 and XJ-S).
Under the passenger seat cushion, which can be lifted off in a fraction of a
second (pull bottom front edge up and forward) there’s a chassis cross member.
I’ve attached the quick-release clip for my 1kg powder extinguisher to the rear
side of that. I can get the extinguisher out of there faster than out of its
previous place in the foot well, and it’s not in the way of the rear seat
passenger’s feet.
If I carry a passenger, I’ll of course have to get that person to vacate the
seat smartly, but most of the time, that seat is empty. It might be better to
put the extinguisher under the driver’s seat, since you have to get out of it
to use the extinguisher anyway, but the steering wheel makes it more awkward to
remove the cushion.
The only real drawback I can see is that it’s easier to forget to give the
extinguisher a shake at every service to prevent the powder packing down…
- -Jan
77 XJ5.3C
78 XJ5.3L
Date: Tue, 10 Sep 1996 23:43:57 -0400 (EDT)
Subject: Re: 1986 XJ6 Series III - Fuel pressure regulator.
My first reaction is the guy is out to lunch, but the more I think about it…
The regualtor is a linear device. It’s job is to keep the fuel pressure
approx 36 psi above the absolute pressure. Note that I did not say atmosphere
pressure. this is because that does not matter. It’s the pressure at the
injector tips that matters. For this reason, it is better to view the hose
on the regulator not as a vacuum line, but rather a vent line routed to
the same enviroment as the injector tips. thus, when there is atmospheric
pressure in the manifold, such as WOT, a fuel pressure gauge, which is vented
and relative to the atmosphere, will read 36 psi. When there is a partial
vacuum in the manifold, such as idle, the same gauge will read about 26 psi.
But there is still a 36 psi pressure drop across the injector.
So much for the thinking. The guy is out to lunch. Assuming no mechanical
limits in the regulator, an absolute vacuum should drop the fuel pressure
to around 20 psi relative to the atmosphere.
And, yes. With the minor exception of the handling of the throttle switch,
the 4.2 injection is stock Bosch L-jet. I use the same breakout box I have
for Jags on my Lancia, and a friends BMW.
The regulators are a fairly common failure. The standard failure mode is
to stick totally closed, not allowing any fuel to dump. This puts the
system on the pumps full pressure; approx 100 psi. Note that they will
often work fine when first started, then jam within two or three minutes.
A quick no gauge test for this condition is to remove the return line and
install a 6 foot length of 5/16 fuel line on to the regulator outlet. Put
the other end of the hose in a five gallon gas can, and activate the
fuel pump. You should have a healthy stream of fuel from the hose. If it
stops, suspect the regulator.
Tony Gardner
Randy K. Wilson
randy@taylor.infi.net
Date: Tue, 10 Sep 1996 21:12:33 -0700
Subject: Re: jag-lovers-digest V2 #346
Jim,
I live in North Carolina and the temperatures are mild but tending
to be pretty hot in the summer. In my 10 years of Jag driving I found
the 10W-40W Castrol to be too thin in the summer. I have always used
Castrol 20W-50W year round, and it does not leak much in my cars. Two
quarts between 3,000 mi. changes would be OK for a 6 cyl. Jag of
moderate milage. I would give the 20W-50W a try. On cold AM’s (+10 to
+15F) my old XJ12 would turn a little slower but fire right up and
build pressure quickly.
By the way, I always check the compression and look at the plugs
when oil consumption is high on any vehicle. A quart in a hundred
takes puddles to get that kind of consumption from just a leak.
Gerald
- ----------------------------Snip----------------------------------------
Subject: Re: Oil Weightuntil recently, i have been using Castrol 10W-40 oil in my 1985 Vanden
Plas with 136,000 miles on the engine. yesterday, i took the car to an
authorized jaguar dealer in frederick, maryland for some gasket repairs
to fix a major oil leak. the mechanics there impressed me as being
extremely knowledgeable about jaguar cars (or extreme bullshit artists;
its too early to tell). those mechanics recommended using Castrol
20W-50 in order to burn less oil. they think that the “proper” weight
oil, coupled with the gasket repair, should curb my cat’s appetite (100
+/- miles/quart!!!) for the viscuous petrol stuff. even though they
make a convincing argument, i have NEVER heard of using that weight of
oil in an automobile. my question to the auto handymen of the jaguar
persuasion is: does this sound reasonable? is 20w-50 the correct
weight oil? if so, how does temperature and seasonality affect this
oil in my 4.2 liter? all insights and opinions are appreciated.thanx - jim
Date: Tue, 10 Sep 1996 23:47:40 -0400 (EDT)
Subject: Re: Rear Brakes on 89 XJS
Y’know, you may find that this is an aluminum tag with the part
number of the hose assembly on it!
– KirbertNope,
I’ve looked closely. It actually cross clamps the line!!!Any Ideas? Any reason why it would hurt the ABS system if I removed it?
Patrick Bowers
I would hazzard a guess that the car has had some differential repair,
or some such that required disconnected the rear brake line(s). The
mechanic put a clamp on the flex hose to keep from losing all of the
brake fluid, and neglected to remove it when done.
Randy K. Wilson
Date: Wed, 11 Sep 1996 00:02:47 -0400 (EDT)
Yes, Jaguars (really most British cars) want the heaviest oil the ambient
temps will allow. For this climate (Va. Beach) it’s 20w/50 year round.
For your area it might be prudent to switch to a lighter oil during the
winter months. Say 15w/40. The is a temp vs. viscosity graph in the
owners manual. But I’d say trust your Jag dealer. They know your climate
better than I do. If they say 20w/50 all year, then do it.
Randy K. Wilson
Date: Wed, 11 Sep 96 13:51:00 EST
put
the
perfect working
order.
Michael,
It’s almost certainly the brake accumulator at fault. The diaphragm in the
accumulator deteriorates with age, so that the system doesn’t maintain the
pressure properly. (The hydraulic pump actually generates the pressure, the
accumulator acts as a ‘store’.) The symptom you describe shows that the
pump is taking too long to restore the pressure throughout the system.
The accumulator is a small pressure vessel, mounted at the low, right hand,
front of the engine bay - effectively in the engine bay behind the RH turn
indicator. Replacing it is easy - I did mine about six months ago (with the
help of jag lovers’ advice!). The job took me about one hour go-to-whoa,
and would be less with practice! The cost of the replacement part in
Australia is A$295 (c. US$200).
Kim Rennick
| Citroen BX 19 GTI -
Date: Wed, 11 Sep 96 09:47:45 gmt
Subject: 64 3.8 S-type automatic transmission shifting hard
Albert
Does this adjustment change with operating temperature? To me (who has NO
experience in this) this would mean that the lever would have to be set
on the basis of:
1 Set to shift when cold. Mark the setting.
2 Set to shift when hot. Mark the setting.
3 Set to half-way between the two marks so that both cold operation
and hot operation work.
You usually find that automatics work best (properly) when warm. The old 30 -
40 year old DG’s can be sluggish to change into top when cold, but can also
change from 1-2 very early. When warm, they can drop into top gear very harshly
by modern standards. My experience is of thrr of these gearboxes.
The lever also actuates the kickdown.
So is there some symptom in the kickdown we could expect? Such as:
1 Kickdown works when cold, but not hot - therefore do X
2 Kickdown works when hot, but not cold - therefore do Y
3 Kickdown operation isn’t materially affected by this setting.
Kickdown is very much affected by this setting. I can’t answer about my
experience with engine cold, as I tend not to give it too much throttle before
it is warm, and therefore don’t use the kickdown when cold. I don’t know also
how long it takes auto fluid to warm up.
The best way to set the lever is described in the transmission books, but is
basically done without engine running. If you have the engine off, and open the
bonnet (so you can hear). With drivers door open (so you can hear), press
acelerator full to the floor. You should hear/feel a clunk of the gearbox lever
‘going over’ to kickdown mode, at just past full normal throttle… This car by
the sound of it may ‘go over’ too soon., before it is getting to full throttle.
If the noise is heard early, the car will probably hang on to lower gears for
too long, as the gearbox thinks that you have the throttle pressed to the floor,
even though you may only have a moderate throttle on, and may not actually be
accelerating.
More common, is that the adjustment is the other way, the gearbox may move off
in second gear, and may change into top at below 20 mph, at very low engine
revs. It is possible in this condition to give it full throttle, the car will
accelerate in top gear very slowly until about 30 mph, when you get normal
acceleration… This is very bad for the gearbox, it is being overloaded, and
can overheat very quickly. This is almost like the lever not even being there.
I think your friends condition is the other mode, ie is holding gears too long.
The owner may hear the lever going ‘over’ at even 1/2 throttle.
The adjustment is way below the heater box, (behind the exhaust system as well)
not to sure about Left hand drive cars. It is a very simple rod in adjustable
holes, and there is a lever from the throttle that can be rotated on a rod.
Again, i have never seen a LHD car, but the principal is the same.
What I am trying to say is that the gearbox has to know what your throttle is
doing. This lever affects kickdown very much, but also gearbox performance.It
already knows engine speed from the speed of the torque converter.
Apparently the amount of ATF doesn’t affect the operation in this case.
This is a surprise to me: I’d expect the symptom you mention. Still, I’ll
get the owner to look into the amounts he’s seen listed to see if they
differentiate between fill from dry and fill from change.
From normal fill, these gearboxes can lose about 6 pints before you may notice
any fault, although the fluid may be getting too warm. First fault of low fluid
is slippage from moving off. If owner is prepared to remove part of the inside
of the car, there is an internal dipstick which is much more accurate. Not sure
if that can be reached from under the car.
Hope the rambling helps, if you want more specifics, please ask.
- Alastair Lauener Work Phone +44 131 455 2458 *
- Chief Technician Fax +44 131 455 2267 *
- Department of Building & Surveying Home Phone +44 1577 864242 *
- Napier University, Edinburgh EH10 5DT a.lauener@central.napier.ac.uk *
- 1964 3.4 S-Type story at http://www.sn.no/home/nick/alas.html *
Received: from central.napier.ac.uk by ccmailgate.napier.ac.uk (SMTPLINK V2.11 PreRelease 4)
; Tue, 10 Sep 96 17:12:19 gmt
Return-Path: cohoe@nortel.ca
Received: from bnr.ca (x400gate.bnr.ca [192.58.194.73]) by central.napier.ac.uk (8.6.10/8.6.10) with SMTP id QAA12628 for a.lauener@napier.ac.uk; Tue, 10 Sep 1996 16:51:18 GMT
X400-Received:
by mta bnr.ca in /PRMD=BNR/ADMD=TELECOM.CANADA/C=CA/; Relayed; Tue, 10 Sep 1996 11:43:10 -0400
X400-Received:
by /PRMD=BNR/ADMD=TELECOM.CANADA/C=CA/; Relayed; Tue, 10 Sep 1996 11:27:39 -0400
X400-Received:
by /PRMD=BNR/ADMD=TELECOM.CANADA/C=CA/; Relayed; Tue, 10 Sep 1996 11:24:00 -0400
Date: Tue, 10 Sep 1996 11:24:00 -0400
X400-Originator: /dd.id=1508238/g=albert/i=a/s=cohoe/@bnr.ca
X400-MTS-Identifier:
[/PRMD=BNR/ADMD=TELECOM.CANADA/C=CA/;bcars735.b.039:10.08.96.15.27.39]
X400-Content-Type: P2-1984 (2)
Content-Identifier: re:64 3.8 S-t…
Sender: “albert (a.) cohoe” cohoe@nortel.ca
Message-ID: <"21072 Tue Sep 10 11:27:55 1996"@bnr.ca>
To: a.lauener@napier.ac.uk
Subject: re:64 3.8 S-type automatic transmission shifting hard
Date: Wed, 11 Sep 96 10:07:12 gmt
Patrick O’Neill asks
I also bought new nylon bushes from a well known spares dealer. When I rebuilt
my column, I realised the bushes are not a matched pair, as sold. Also, the old
fitted better than the one new one that was correct, and I put both original
back in. Yes, replace the felt with the nylon, don’t lubricate the nylon (I
believe).
Check the shim bits at the bottom don’t allow the column to move in and out.
It is age dependant, don’t know the dates though. I know of some RHD cars with
the old flex joint. The petrol from the carbs overflowing generally destroyed
them, and they broke!!. Problem on the LHD cars was the heat from the exhaust.
I think the change date was sometime in 1962.
Date: Tue, 10 Sep 1996 22:10:49 -0500
Subject: Cats in Their Environments
Took the family to NYC last week and had a wonderful time. Saw several =
Jaguars, mostly sedans, prowling the busy streets, shooting through =
intersections but staying above the fray of yellow Caprices and Crown =
Victorias. Returned to central Missouri Sunday night and late Monday =
night found me driving 100 miles from one small city to another. Two =
curving lanes and just enough traffic to offer something to pass. And I =
did. XJ6 running great, stereo sounding good, and new tires holding =
their own. Every ten miles found a small town of 200 -1000 that slowed =
me down so that I could relax any muscles that were still tensed from =
those last curves and begin the next stretch. As I arrived home I =
thought about those cats in the city and hoped that they got the chance =
to run now and again. I felt a bit sorry for them living in the concrete =
maze, but then again, my country cat doesn’t get many chances to dart =
and strut and cats love to dart and strut.
Date: Wed, 11 Sep 96 11:10:17 BST
Subject: Re: Mk2 steering column rebuild
Patrick,
I’ve just rebuilt the column on my Mk2, but it’s a 1966 rhd non-assisted 3.4l
MOD car:
looking in the parts book there are quite a few changes from earlier cars.
[for UK “bushes” read US “bushings” as preferred ]
My column always made a grating noise when turning the wheel, so I thought
I’d replace the bushes which are nylon top and bottom on my car. With the
column stripped down I found that the grating sound was from the earth
contact near the base of the upper column. I replaced this contact (it was
worn badly) and the horn slip ring contact (also worn badly). On late
columns there is a thrust bearing; mine was worn so I replaced that too.
The new bushes were a looser fit than the old ones so I didn’t change them
in the end. I used some ordinary grease when reassembling these bushes but
I don’t know if this is recommended. A coat of paint and clean-up of all
contacts completed the job.
The lower column on my car has two ujs, the upper one does not have a gaiter
as shown in some diagrams. I think it’s original.
Cheers,
Ted
1966 3.4 Mk2 “getting closer to running”
Date: Wed, 11 Sep 1996 09:31:09 -0400
Subject: SI XJ12 idle
Hello Dave,
She has a heavy, idle that shakes the car.
At 1000rpm, she is smooth as glass.
Yes, your V12 should idle like glass as well as run smooth as glass. It
sounds as if you have a BAD vacuum leak at one of the ports nearest one
of the butterflies. If one of these goes to atmosphere your mixture
leans out. This causes you to tune down that carb and compensate by
slowing the idle down by choking it off (closing the butters). This
causes the Strombergs to struggle to deliver a consistent mixture ratio,
causing a major imbalance in combustion. This all goes away when you
open the butters because the critical low pressure area is not
concentrated on the vacuum port, but rather at the venturi - and so it’s
smooth.
Mfg defect… the passage from the throat to the float
assembly was not drilled deep enough. A dead end if
you will. I fixed that and now it works as advertised…
I am curious as to where you did your drilling. On the Strombergs
fitted
on my '73 XJ12 the left-hand front and right-hand rear carbs do not have
choke assemblies (the others of each pair handle richening). Therefore,
the machined area is present on the side of the carb body, but the holes
are not drilled through to the plenum. Is this where your drilling took
place? If so, that is the cause of your vacuum leak. If not, please
tell me where you had to drill so I can check mine.
If none of the above is the case, is your vacuum retard unit working on
the distributor? If not, and you have compensated by bumping up the
timing at idle, then this could cause you to have to really turn down
the
idle speed by closing the butterflies, thereby causing an inconsistent
mixture. Let us know what you find.
BTW, The Roadster Factory and Moss Motors I believe both carry
Colortune,
probably Welsh Jaguar also.
Dave Ox.
73 XJ12
75 TR6
Date: Wed, 11 Sep 1996 23:32:03 +1100
Brake Sleeves FWIW
XJ40 hard starts
Re: '86 XJ6 Battery
XJ-40 Hard Stsrts
Local Jag-lovers
Re: Oil Weight
A/C Systems
Re: Hej Matthias,
re: air dam on XJ-S
Subject: Brake Sleeves FWIWThe company you suggested "Imperial Machine Co. in Lincoln, Ne USA" to resleeve the master cylinder and/or the brake cylinders is owned and ran by an acquaintance of mine. He is a top notch machinist and does excellent work. I would recommend him to do anyone's work.
Subject: XJ40 hard startsI have a 89 XJ6 that takes about 4-6 seconds to start after it has sit for
about an hour.
Also, I never use the gas pedal when cranking the engine (per the manual).Any areas I can starting looking? Any component failures that this might
point to?As always, thanks for any input,
- -Mike
| mpowers@teir.com
| (703) 736-1832
| -Jerry Seinfeld
Subject: Re: '86 XJ6 Battery"William F. Stickney >picker1@ix.netcom.com< wrote:
engine at
battery
Good luck-
Brian Sherwood
'85 XJ6
'84 XJ-S
Subject: Re: Water Pump RemovalI finaly got the damned thing off. That was worse than the radiator removal!
head allen bolt.Anyone have any suggestions on how to get the short (3") hose on the top of
the temp sender housing into place when I go back on? I had to cut it off
to get the pump off and dont see how I am going to get it back on with that
hose in there unless I remove the crossover pipe.Why don’t you want to remove the crossover pipe? That is the way to do it.
Do remove the crossover pipe and replace the little hoses on each end too.Thomas E. Alberts
Subject: XJ-40 Hard StsrtsI had this same exact problem with my 88 XJ-40 and several others on the list
system to vapor-lock. The non-return valve is cheap and easy to replace.Paul Lacey, Texas
Subject: Local Jag-loversAre there any other Jag-lovers in the Northern New Mexico area?
Greg Price
Subject: Re: Oil Weightuntil recently, i have been using Castrol 10W-40 oil in my 1985 Vanden Plas
Jim in my V12 I was using GTX2 many years ago and heaps of it! I
changed to a non friction modified oil Penrite HPR30 in Australia, and
the use and leaks halved. I’ve forgotten the viscosity rating of HPR30
but Pennzoil also make a suitable oil. A multigrade with 50 at the top
end is OK, perhaps North American winters need lighter oil but it’s
worth talking to your Pennzoil distributor.
Regards Peter Smith
Subject: A/C SystemsI have read with interest the discussion in regard to Jag A/C systems and all
upgrading the A/C while everything is apart.Carlos Madero
'73 XJ6 (since '86)
'53 Chev PU
soon)
Subject: Re: XJ6 S3 Fan Clutch $Don’t recall the originator but someone asked about an XJ6 Fan Clutch. The
$69.95 each.Best Regards,
HalHal Rogers
H.D. Rogers & Sons
(318) 742-5044 faxServing Auto Enthusiasts since 1959
Subject: Mk2 steering column rebuildI am in the middle of rebuilding the steering column on my 1963 LHD Mk2
3.8L MOD, actually I am just putting in new nylon bushings.Has anyone done this before? My car had a nylon bushing in the top of the
has a good reason not to.Are you supposed to use any kind of lubricant on these nylon bushings?
original Power steering car.Kind Regards,
Patrick D. O’Neill
1963 MK2 3.8L MOD
www.beachnet.com/~patrickoPS I have just added some cool Jaguar Animated GIF files to my Web site
Subject: Re: Knockoff tool - Marston Motors[ Patrick Krejcik pkr@SLAC.Stanford.EDU ]
| An E-Type owner (Chuck Rockhold) told me he got it from Marston Motors
| at Bradford in the UK at a cost of about $US25 including shipping to the
| US.
| Apparently they advertise in Jaguar World, so can somebody look up their
| telephone and/or fax number and tell me.This would be The Hutson Motor Company. They have incidentally
just opened a web-page at http://www.jagweb.com/hutson/Nick
<<< Jaguar XJ6 4.2 '70 MOD & '82 Auto >>>The JagWeb http://www.sn.no/~nick/jaguar.html <<<
Subject: Re: When the student surpasses the teacher…And second prize is two Esprits…
John
not fair…
Lee
Subject: Re: Hurricane Fran - XJS lowrider (R.I.P.)My condolences to you and your family on the damage to your house and
that you are treated fairly by the insurance adjusters.Consider using an agent to negotiate on your behalf. They charge a fee
part of the car.It seems that you are all ok physically, and of course that is the most
Especially the waste ofthe car.Consider keeping the hulk if it is not repairable and parting it out.
Perhaps you will find enough buyers on the list to help with the loss.Regards,
John
Hurricane Fran
ss is
othing
ave to
oo
=20
Julian Mullaney
=20
=20
From: Michael Powers/TEIR/Thomson Michael_Powers@teir.com
Subject: 88-89 XJ40 Low Brake Pressure??My VCM Low Brake Pressure light ALWAYS comes on for a minute
the
perfect working
order.Any ideas and/or experience with this?
- -Mike
| mpowers@teir.com
| (703) 736-1832
| Would somebody please explain to me those signs that
| say, “No animals allowed except for Seeing Eye Dogs?”
| Who is that sign for? Is it for the dog, or the blind person?
| -Jerry Seinfeld
Subject: Re: XJS — Oops!!! (a.k.a. Chassis failure)On Fri, 6 Sep 1996, Kirbert wrote:
John Napoli:
- Is there a source for stiffer cage mounts? Or is it a case of using
the stock setup or going solid?I have not seen any alternative mounts offered. A shame, too, I bet
lot less stress on some other components as well.I have not heard of this solution previously but it makes a lot of sense.
It would keep the cage from rocking back and forth.I would like to take this opportunity to point out that if one was to
trailing arms at the same time.Yes, this is an absolute. The trailing arms might not even have enough
one of these days.I am interested in this mod myself. But one of my plans was to route the
can do both?
clearly, this particular spot is one where attention is warranted.They seemed to discuss rust in areas easily accessible. We are talking
absorb water.John
thing? You can always just pull the shifter into 2nd.Faster than struggling with the detents.
John
Subject: Re: Hej Matthias,What year range did the donor impeller come from? I presume that it was
from a Chevy small-block V8.My water pump is very accessible (mechanical fan drive long gone) and I
describes.My car could be the guinea pig, and I will be able to report quantified
results.John
does. Connection?
way.On my car, with the replacement struts we talked about on the list a long
hoses.Anyone know how important the sponge rubber inserts around the
ratiator are. Mine are rotted away.Very important. As Kirby points out in his book, the radiator absorbs
mounted.It looks like the front license plate does alot of damage to the air
licnseplate?My XJ-S has never had an air dam (PO must have killed it) and it has not
dam this would not be the case.John
Subject: RE: XJS Micro switch on throttleThanks. Another thing to try.
John
John Napoli :
-Jan
Subject: Re: XJS brake fluid reservoir capYes, I like that idea. Makes it less likely to miss something.
John
For those who have my booklet: I have been thinking of eliminating
the separation between “Maintenance” and “Modifications”. Some of my
suggestions for maintenance are to replace a stock part with a
non-stock part, which technically is a modification. And some
modifications I suggest be considered even by those who don’t modify
the car, such as the installation of aftermarket steering rack
bushes. As a result, I have quite a few references back and forth
between the sections. Do you guys think it would be a better idea
for that to be one large section, where you can look up the thing
you’re concerned about and find the maintenance suggestions and the
suggested modifications at the same place?
Subject: re: air dam on XJ-SOn Tue, 10 Sep 1996, Ryan Border wrote:
Air which flows through the radiator, into the engine bay, has to exit
somewhere. Assuming your bonnet is in place, the exit point for most of
this air is out the bottom. The lower the pressure under the car, the easier
it is for the air to “get out”. Decreasing the pressure under the car
with an air-dam can increase the airflow through the engine bay and
under the bumper to significantly increase the pressure in front of the
radiator grille.Your response raised an interesting question. My XJ-S has no air dam.
would be on a car with an air dam?John
End of jag-lovers-digest V2 #348
Return-Path: @owner-jag-lovers-di1
Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4)
id for jag-lovers-digest-out; Thu, 12 Sep 1996 00:04:39 +0200 (MET DST)
Date: Thu, 12 Sep 1996 00:04:39 +0200 (MET DST)
Message-Id: 199609112204.AAA08442@ekeberg.sn.no
X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f
To: jag-lovers-digest@sn.no
Subject: jag-lovers-digest V2 #349
Reply-To: jag-lovers@sn.no
Errors-To: @owner-jag-lovers-di1
Precedence: bulk
X-Newsgroups: mail.jag-lovers-digest
jag-lovers-digest Thursday, 12 September 1996 Volume 02 : Number 349
Oil weight
Air dam on XJS
XK’s Unlimited Open House… 20% off parts… Barbeque…
Re: XJ rear suspension behaviour
JCNA Concors d’Elegance - Sacramento - September 28th.
Santa Cruz - Autumn Classic British Sports Car Concors
Re: air dam on XJ-S
Re: fuel for the “air dams on the XJ-S” controversy
Power steering rack bellows
RE: Mk2 steering column rebuild
XKE engine oil capacity
Re: XKE engine oil capacity
Re: Power steering rack bellows
XJ-S Water Pump Replace
California Clubs
Re: XJ-S Water Pump Replace
Re: Oil weight
re: air dam on XJ-S
Re: air dam on XJ-S
1964 E-type FHC production
Date: Wed, 11 Sep 1996 09:47:27 -0400
Subject: Oil weight
those mechanics recommended using Castrol 20W-50 in order
to burn less oil. They think that the “proper” weight oil,
(100 +/- miles/quart!!!) for the viscuous petrol stuff. Even
though they make a convincing argument, i have NEVER
Jim, I use 20W-50 in both my Jag and my TR6. I live in Florida and the
hot climate is the main reason I use such heavy oil in the XJ12. It
gives good pressure at operating temp.
I began running it in my TR6 because of bad cylinder wear (124,000+
miles) and a poor reaming job on the valve guides (damn machine shop!)
cause it to use about a quart every 250 miles (driving hard). I would
only recommend this weight if the average temperature does not fall
below about 50 degrees F. Below this the viscosity creates VERY high
pressures and very low flow, in addition to putting undue stress on the
oil pump and lines.
Unfortunately, nothing can really solve an engine’s oil consumption
except for a proper repair of the cause. There is no additive that I
know of that can effectively ‘fill the gaps’ that allow the oil into the
cylinders. If you live in a hot climate, I would say that a heavier oil
will reduce your consumption by about 10-20 percent per weight increase
(i.e., 10W-40 to 20W-50). Not much, I know.
Good luck!
Dave Ox.
73 XJ12
75 TR6
From: “Martin R. Fooks – InternetDesign” Martin.Fooks@internetdesign.com
Date: Wed, 11 Sep 1996 15:49:50 +0200
Subject: Air dam on XJS
I saw a picture of a Lister once with twin NACA ducts on the bonnet and
decided to do the same to my XJS whils performing all the other
modifications.
Take a look at the pictures to see what it looks like –
HTTP://www.internetdesign.com/mrfooks
Look in the section “Martins’ XJS”.
These are placed in front of each air box, but not up tight as I don’t
want rain water running into the engine when parked.
Martin
Date: Wed, 11 Sep 96 07:12:58 PST
Subject: XK’s Unlimited Open House… 20% off parts… Barbeque…
Open house weekend October 5th and 6th.
Saturday: Peoples Choice Car Show, free bbg 'n drinks. 20% off parts.
Sunday: 0900 meet in park lot for start of 2-3 hour rallye ending in
a luncheon/picnic with live blue Grass Country Concert.
I've ever only made the Saturday part, and it's always enjoyable.
The local JAG club (San Francisco) is convoying down Saturday... all
welcome to join... ocntact me on the side for details.
Date: Wed, 11 Sep 1996 09:58:55 -0005
Subject: Re: XJ rear suspension behaviour
Jan Wikstroem:
subframe.
Cool! This is a GREAT group!
Are you still there? How about disconnecting the trailing arms and
taking the same measurements that way? In theory, of course, the
subframe should not move at all, but it makes an easy baseline test.
I might argue here. Applying increased torque to the final drive
unit tends to twist the rear subframe as described, and the lower
suspension arms are in fact so massive that flex is probably
negligible. However, the forces involved tend to flex the rubber
joints on either end of the trailing arms (effectively making the
trailing arms shorter) and rocking the bottom of the subframe forward
- – probably a fairly significant amount, and perhaps the cause of
failed subframe mounts in cars with significantly more get-up-and-go
than stock.
In fact, given the nature of the geometry here, I wouldn’t be too
surprised to learn that there was a significant amount of flexing in
the entire subframe under heavy torque. The subframe mounts are out
at the outer end; the trailing arms, effectively serving as torque
links, are also at the outer end – but are connected at the diff, at
the center. And the torque is applied at the diff. And the subframe
is a large, fairly flimsy-looking sheet metal structure.
What we REALLY need is a high-frame-rate camera mounted under there
on a car with about 600 HP!
– Kirbert | If anything is to be accomplished,
| some rules must be broken.
| - Palm’s Postulate
Date: Wed, 11 Sep 96 07:18:22 PST
Subject: JCNA Concors d’Elegance - Sacramento - September 28th.
Sponsored by Sacramento Jaguar Club during the All British Car Day
which they;re running in conjunction with the Sacramento Valley MG Car
Club.
Held at Cosumnes River College Fountain Quad area - grass trees
fountains etc.
Entry7 fees: $25 driven, $30 concors classes
(proceeds to Children's Hospital)
contact Chuck Imperatori (510) 825-7731 for more details.
Date: Wed, 11 Sep 96 07:53:00 PST
Subject: Santa Cruz - Autumn Classic British Sports Car Concors
October 20th 0900 .... (rain day October 27th)
Inn at Pasatiempo
This Autumn Classic brings back the nostalgic fun of the relaxed,
friendly sports car club events of the 1950's and 1960's (for those
who go back that far). This event is for all regularly driven British
classic two-seater (or their jumpseat or 2+2 derivatives) cars.
NO TRAILER QUEENS or towed cars.
Excellent brunch... all in cost $15.50. All reservations must be in
advance... no same day meal payments.
Great door prizes etc, mountain driving tour.
Directions: Exit off Route 17 at Pasatiempo Drive (just North of Santa
Cruz)
Registration Forms: Dave Ferguson (408) 363-1423 evenings
Two Thumbs Up: based on past experience... a very relaxing and
enjoyable day.
Date: Wed, 11 Sep 1996 07:55:16 -0700
air dam.
struts, popped the
hood was firmly
higher
Are you sure about the higher air pressure underneath? It
sounds more like a lower air pressure above the hood. Bernoulii
effect at work. faster airflow across the hood lowers the air
pressure on the hood, and causes it to rise until it hits the
stops. Lee
Date: Wed, 11 Sep 1996 08:14:03 -0700
Subject: Re: fuel for the “air dams on the XJ-S” controversy
Date: Sunday, September 08, 1996 7:40 PMHere’s my two cents worth on the air dam controversy:
the car at
higher speeds.
“air being
through the
back of the
radiator.
mine which
looking for a
undertray is not
(once it hits
opening created
(big obstacle).
through the engine
of the engine bay.
they help each
the car that
bay.
present, they
radiates from) the
transmission tunnel.Any other thoughts?
Rob W-M
85 XJ-S
I always thought the purpose of the air dam was to reduce the
amount of air reaching the “dirty” underside of the car. Other
benefits include better gas mileage due to reduced drag, and
better traction due to increased downforce. Look at most race
cars. No air dam, but the underside of the car is very flat and
“clean”. Air dams on trucks are there to improve fuel mileage
by reducing the air flow under the truck and trailer. Lee
Date: Wed, 11 Sep 1996 08:59:06 -0500
Subject: Power steering rack bellows
Yo, Jim! Do I have to tell you that the bellows are not the problem?
No Kirby, you dont. I know the leak is not stopped by the bellows. But the
bellows are also shot so it ends up on my driveway a drip at a time and I
want to keep dirt out of the stuff that is coating the ends of the rack.
The leak is not bad, maybe a few drops a day, not enough to notice on the
filler cap maybe an oz a month. So rather then do a real horrible job, for
now I am only goint to replace the bellows.
Jim
“Better an outlaw than not free.”
Nance O’Neil
From: “White, Dick” white@msgate.ColumbiaSC.NCR.COM
Date: Wed, 11 Sep 1996 11:30:00 -0400
Subject: RE: Mk2 steering column rebuild
Patrick,
I have replaced the bushings on my '64 3.8 S-Type. The S-Types have
only the nylon type. According to my parts books, Mark II’s used both
felt and nylon bushings ( 3.4 up to chassis #162488 and 3.8 up to
chassis #230140 used felt). As long as the nylon one will go in the
bottom I don’t see a problem using it.
I occasionally spray mine with WD-40 or silicone but I don’t think it’s
really necessary.
My parts books also imply that Mk II’s used flex couplings up to chassis
#17893 (3.4_LHD) and #222240 (3.8_LHD). All S-types used nylon roller
u-joints and the 420’s went back to the flex coupling. All Mk X’s and
420G’s used u-joints.
While out check the condition of the split cone near the top of the
column and the rubber gaiter around the nylon roller u-joint. Both are
available from Brit/Auto or XK’s.
Dick White
'64 3.8 S-type
'58 XK 150 FHC
From: “Patrick O’Neill” patrick.oneill@premierusa.com
Date: Tue, 10 Sep 1996 14:00:18 -0700
column but it has a felt bussing in the bottom. I purchased the top and
bottom nylon bushings and I will us the nylon in the bottom unless some one
Are there any other jobs I should do as I have the column out?
On a side note a few months back there was a discussion about Mk2’s RHD vs.
LHD with regard to a U-joint or a rubber “flex” joint into the steering
box. I believe the general thinking was that RHD cars had the U-joint and
LHD cars had the flex-joint, well my LHD car has a U-joint and it is a
Patrick D. O’Neill
1963 MK2 3.8L MOD
Rolling Hills Estates, California
Date: Wed, 11 Sep 1996 11:40:18 -0400
Subject: XKE engine oil capacity
What is the proper oil level on an E-type ?
The manual states 8.5 liters ( 9 quarts) for refill. This shows a level about
1/4 inch over the lower mark on the dipstick. It takes 2 more quarts to reach
the upper mark.
Date: Wed, 11 Sep 1996 12:35:36 -0400
Subject: Re: XKE engine oil capacity
This is a multi-part message in MIME format.
- ------=_NextPart_000_01BB9FDD.BB9DF260
Content-Type: text/plain; charset=ISO-8859-1
Content-Transfer-Encoding: 7bit
hmmm…my 67 E does the same.
Let me know what you find out?
Larry
psllarry@gate.net
Subject: XKE engine oil capacityThe manual states 8.5 liters ( 9 quarts) for refill. This shows a level
about
reach
the upper mark.
Content-Type: text/html; charset=ISO-8859-1
Content-Transfer-Encoding: quoted-printable
hmmm...my 67 E does the same. =
Let me know what you find =
out?
Larry
psllarry@gate.net
> From: DHarr13177@aol.com
> The manual states 8.5 liters ( 9 quarts) for refill. This shows =
a level about
> 1/4 inch over the lower mark on the dipstick. It =
> the upper mark.
Date: Wed, 11 Sep 1996 12:50:17 -0400 (EDT)
Subject: Re: Power steering rack bellows
- ----- Begin Included Message -----
If you are going to replace the steering rack gaitors (I hear they are
not cheap) make sure that the stainless steel exhaust heat shields
are in place so the gaitors will last a while.
Thomas E. Alberts
Date: Wed, 11 Sep 1996 08:59:02 -0500
Subject: XJ-S Water Pump Replace
when you reinstall the pump. I understand that a lot of people
break the pump housing by over-tightening that one countersunk
head allen bolt.
Interesting. My orriginal pump with the exact same casting number does not
have a counter sunk PHILLIPS head bolt (phillips, not allen). But the
replacement does. Whats it for and why does the orriginal have a normal
bolt (casting is NOT countersunk)?
Jim
Nance O’Neil
From: “John Hed” john_hed@wssagw.chinalake.navy.mil
Date: 11 Sep 1996 10:42:14 -0700
Subject: California Clubs
Subject: Time:10:43 AM
OFFICE MEMO California Clubs Date:9/11/96
I am in the early stages of planning a British car event in S. Calif. for next
year and would like to contact any and all Jaguar clubs in California to
participate. I have only one contact for the “Jaguar Owners Club” in L.A.
There must be more clubs out there in California. If you know of any, please
Email the POC to me. Thanks in advance.
John Hed John_Hed@WSSAGW.chinalake.navy.mil
Ridgecrest British Car Club
Ridgecrest California
Date: Wed, 11 Sep 1996 14:47:41 -0005
Gee, how can I clarify this? The bellows are SUPPOSED to be a
dust-only item; some of them even have little drain holes. They
certainly cannot hold the pressure of the pump, and usually fail even
to hold a significant amount of liquid. If your seals are leaking,
the ONLY solution is an overhaul – replacing the bellows is
worthless.
| - Palm’s Postulate
Date: Wed, 11 Sep 1996 15:10:16 -0400 (EDT)
Subject: Re: XJ-S Water Pump Replace
head allen bolt.Interesting. My orriginal pump with the exact same casting number does not
Right, Phillips. I forgot. Anyway I have no idea why they decided
to make one bolt countersunk. It doesn’t appear that the bolt head would
be in the way if it had one. Possibly a remnant from other models?
I’ve always been curious about this. Anyway, when I bought my rebuilt
pump the guy at the counter showed me one someone had overtightened and
broken and warned me that lots of people break them this way.
Thomas
From: M.Cogswell@ccmail.mi04.zds.com (Mike Cogswell)
Date: Wed, 11 Sep 1996 15:29:50 -0400
Subject: Re: Oil weight
FWIW I've used 10W-40 in winter and 20W-50 in summer in all my
vehicles for many years.
MikeC
m.cogswell@zds.com
______________________________ Reply Separator _________________________________
Even
heard of using that weight of oil in an automobile.
Date: Wed, 11 Sep 1996 17:43:23 -0400 (EDT)
OK, so then don’t I want hood louvers to exhaust hot air under the hood
and also to slightly reduce front end lift?
And does my car have more front end lift without an air dam?
John
Hi John,
Adding an airdam may indeed decrease the pressure under the car, increasing
the speed of the air through the engine bay; BUT, I don’t think you
could ever get the hood to be sucked down, short of some very special
air channelling under the hood, combined with a big upright windshield
to stagnate the flow over the top of the hood :-). You might be able
to increase the speed where the pressure differential across the hood
overcomes the weight of the hood slightly though.
Date: Wed, 11 Sep 1996 17:53:43 -0400 (EDT)
Ummm, isn’t lower pressure on top the same as higher pressure underneath?
Everything is relative, after all. It just depends on your frame of
reference.
BTW, I too have an MG that popped its bonnet. Fortunately, the damage was
slight and easily repaired (stepped on it while it was upside down on my
lawn!).
John
though…
Julian Mullaney
Date: Wed, 11 Sep 1996 18:03:43 -0500
Subject: 1964 E-type FHC production
I have a LHD 1964 E type Series 1 FHC with the armrests and padded dash. My
serial number is 890630; the 1961 FHC model started with serial number
875001 and a total number of Series 1 FHC built were 7,663, which would
indicate that the last serial number for the four years that Series 1 E
type FHC’s would be 882664. I found these figures in a 1991 issue of
“Jaguar Quarterly.” Since the production figure includes the small number
of RHD models sold in Great Britain (and this figure was not given in the
article) there is no way I can figure just when in 1964 my particular
E-type was built and delivered. The interior is identical to the 1965 4.2,
but I have the Moss crash box, the XK type clutch and the XK 150 braking
system. I was wondering if any of you can tell me the serial number of the
last '64 FHC (LHD) produced before the introduction of the 4.2 in 1965. If
I knew how many LHD E types were exported during the four years of
production, that would help me estimate whether my Jag was an early '64 or
built near the end of the production run. Will, for example, a 4.2’s vacuum
assist brake setup bolt onto a 3.4 without any major modifications? Can the
4.2’s clutch system (housing, pressure plate, clutch, master cylinders,
etc.) be fitted to a 3.8 E type, again as a bolt-on system? I’d put a
4.2’s gearbox in my '64 E type in a minute, but the price is just too steep
for me to pay now that I’m an aging retiree. Would appreciate getting some
numbers from someone steeped in Jag lore.
End of jag-lovers-digest V2 #349
X-UIDL: 2dd14932fcdb9a2668b96415b57afdbc
id for jag-lovers-digest-out; Thu, 12 Sep 1996 06:15:04 +0200 (MET DST)
Date: Thu, 12 Sep 1996 06:15:04 +0200 (MET DST)
Message-Id: 199609120415.GAA19966@ekeberg.sn.no
Subject: jag-lovers-digest V2 #350
Precedence: bulk
Status: RO
X-Status:
jag-lovers-digest Thursday, 12 September 1996 Volume 02 : Number 350
Re: 1964 E-type FHC production
Vehicle Dynamics (Was XJ Rear Suspension Behavior) [Very Long]
Re: Oil Weight
XJ40: Round to Square Headlamps
Re: 88-89 XJ40 Low Brake Pressure??
Re: Cats in Their Environments
RE: XKE engine oil capacity
Re: Vehicle Dynamics (Was XJ Rear Suspension Behavior) [Very Long]
Re: XJ40: Round to Square Headlamps
Re: Oil Weight
Re: Oil weight
Date: Wed, 11 Sep 1996 18:03:11 -0400 (EDT)
My XJ-S, the one without the air dam or undertray, gets real hot in the
transmission tunnel. This is not wafting heat from the climate
control system, because I have checked this with no water flow through the
heater core (hoses bypassing the heater core entirely). Furthermore, I
have checked this with the ski slope (center console) removed, so I can
actually touch the floor in this area.
So you may be right on this.
John
Rob W-M
85 XJ-S
Date: Wed, 11 Sep 1996 20:05:16 +0100
Subject: Re: 1964 E-type FHC production
I perhaps should have mailed this directly to
Bob Richardson, but I went to the list in case anyone
else can benefit.
Bob,
Haddock’s Originality Guide says, in part;
LHD FHC #890487 (rubber added to bumper) May 1964
LHD FHC #890714 (rear springs…changes) October 1964
FYI, #890871 was the last 3.8 FHC
He further states;
Total production, Series 1, 3.8
RHD Roadsters; 942
RHD Coupes; 1,798
LHD Roadsters; 6,885
LHD Coupes; 5,871
This seems to put your car between May and
October, perhaps mid-summer. If you can’t find the
book I’ll do more research for you, if it will help.
BTW, he further states that white is the best colour,
but that’s not important to this post (just to me!)
Now, I knew all those numbers/dates without need
of the book…but why waste my memory!
Hopes this bit helps.
Charles Daly, Toronto, Canada
'62 E-Type, ots (June '62!)
Date: Wed, 11 Sep 1996 21:24:00 -0400
Subject: Vehicle Dynamics (Was XJ Rear Suspension Behavior) [Very Long]
counteract that.the XJ is a fine exponent of
Jan -
I am impressed with your initiative to observe your rear suspension.
Are you in the mechanical engineering field?
What you are talking about is roll steer. This one third of the
phenomenon known as “understeer” or “oversteer”. The other two thirds
of under/oversteer are compliance steer and tire grip (adhesion).
When you say that the “rear wheels steer out slightly”, that is not
quite correct. Public passenger cars are emphatically not designed for
oversteer, because that is an unstable and unsafe condition. Start
from the principle of lateral acceleration, acting on the vehicle’s
center of gravity. Given a fixed lateral acceleration (a fixed
radius corner at constant speed), a car which exhibits oversteer will
steer into the corner, therefore decreasing the radius. If the radius
is decreased and speed is held constant, lateral force is increased,
thus making the car roll more and higher cornering forces are
imparted to the rubber suspension components, both creating more
oversteer in our hypothetical car. The car again steers into the
corner, decreasing the radius and increasing the lateral force, and
you can see where we are going – into the oncoming lane of traffic
or the ditch!
To fully understand the rear suspension behavior you must also
observe toe-in through suspension travel. You say your rear toe-in
at design load (fully laden stationary vehicle) is nearly 3mm. OK.
Now measure toe-in when both wheels are in full rebound (maximum
lower limit of travel, with car on stands and rear wheels unsupported).
Toe-in should decrease at full rebound, maybe even toe-out. Now
move both wheels into full jounce (maximum upper limit of travel).
Measure toe-in and you should find it to be more than 3mm.
The effect of the change of toe through travel is that in cornering,
the outside wheel will go into jounce, and toe-in. The inside wheel
will go into rebound, and toe-out. The net effect is that the rear
wheels will steer into the corner making the vehicle yaw out of the
corner and increase the cornering radius, thus defining the term
“roll understeer”.
Compliance understeer is the resultant change in geometry that occurs
when you apply cornering forces to the tire/road contact patch (which
we can’t do in our driveways!). Consider a force at the tire contact
patch and think about the four rubber subframe bushes and rubber radius
arm bushes. These rubber springs must react the lateral force applied
at the tire. The static equilibrium of this system will cause the rear
wheels to steer into the corner and yaw the vehicle out of the corner
in public passenger vehicles.
Tire grip/adhesion is controlled by weight on the tire, which is
controlled
by weight distribution, center of gravity height, tires, and anti-roll
bars.
Since weight distribution and c.g. height is fixed in public passenger
vehicles, you must look at tires and anti-roll bars to obtain greater
grip.
I am not a tire expert, so I will only say that you can buy tires with
greater or lesser grip. To increase the grip of a given tire, you can
increase the force on the tire using anti-roll bars. This causes the
weight transfer from the inside tire to the outside
tire to be reduced, thereby utilizing more of the grip of your inside
tire.
If the front/rear balance of grip is biased towards the front, you will
have an oversteer condition whereby the front tires are controlling the
behavior of the vehicle vs. the rear tires. The car will yaw into the
turn
and oversteer.
B.J. Kroppe - '82 XJ6
Date: Wed, 11 Sep 1996 20:23:38 -0500
Hail fellow jag lovers. A new job has kept me away, but I must add a
Minnesota perspective to this issue.
In the winter here it is common to use 5W-10 so the stuff can retain some
fluidity to it!
Don’t you wish you all lived here???
Scott Phillips – now re-employed as a professional fund raiser (so I can
get my A/C fixed now)
'88 XJ40
Minnetonka,mn,usa
Date: Wed, 11 Sep 1996 18:26:12 -0700
Subject: XJ40: Round to Square Headlamps
Hello Jag-lovers!,
Has anyone out there changed the headlamps in their XJ40 from the
four round headlamps to the two square headlamps? I was looking to do
this to my car because I think the two headlamps are nicer and more
European looking than the four.
What is involved in this process? I’m not sure if I’ll have to
change those bulb failure units (with the wiring) or be able to plug
the other headlamps in with an adapter. Any idea on cost? Or
aftermarket suppliers or places to get used headlights?
As always, thanks for any ideas or input!
-cobac@ix.netcom.com
-89 XJ40-VDP
Date: Wed, 11 Sep 1996 22:04:06 -0500
Subject: Re: 88-89 XJ40 Low Brake Pressure??
or so after I start my XJ6. It also seems to appear once in a while when I put
the
car in park What’s up with this thing? The brakes seem like they are in
perfect working
-Mike
| mpowers@teir.com
| (703) 736-1832
| -Jerry Seinfeld
I would guess the cause is the nitrogen pressure bladder. This
pressurized cylinder is intended to keep a reserve of high pressure
hydraulic assist. If the bladder looses charge the hydraulic pump is
activated on start up to repressurize the system, and the VCM signals
that the pressure is low. I don’t know why the signal would come on on
engaging ‘Park’.
Bob Johnson
Brattleboro, Vt.
XJ40, XJ50
Date: Wed, 11 Sep 1996 22:38:49 -0400
put
the car in park What’s up with this thing? The brakes seem like they are
in
perfect working order.
Don’t panic. The owners manual says this is normal and to be expected. I
have the same symptoms in my 1990.
Robert MacLeay
1990 XJ40 VDP Majestic
Date: Wed, 11 Sep 1996 22:38:53 -0400
Subject: Re: Cats in Their Environments
There is no doubt that having a two lane country road to oneself is fun
indeed. NYC driving, which as a resident of suburban New Jersey I do
occassionally, can be equally rewarding providing traffic can move at all.
I have found city driving the only practical use for the J-shift
transmission. I put the transmission in “2”, activate Sport shift points,
and slice and dice with the best of them. Rough pavement, agressive local
drivers, and double-parked shmucks make for the ultimate real-life chicane –
just the environment where sure-footedness, power, and nerve can triumph.
(Incidentally, there are only three violations for which police will give you
a citation in the city – gridlock, illegal parking, and vehicular homicide.)
Robert MacLeay
Date: 11 Sep 96 22:32:17 EDT
Subject: RE: XKE engine oil capacity
I was taught long ago to fill to the top mark…drive around for a week or so
and then check the level. That’s that particular engine’s level. All engines
have their own level, somewhere between the high and low marks. Continually
filling above this “natural” level is hard on the engine since the excess must
be expelled. On most engines if you’re between the high and low marks your
fine. You’re not “low” until the level drops to or below the mark. The natural
level in my '66 E-Type Jag is just below half.
All this of course depends on how badly your Jag leaks.
- -Ed-
Date: Wed, 11 Sep 1996 23:13:20 -0500
else can benefit.
Bob,
FYI, #890871 was the last 3.8 FHCHe further states;
RHD Roadsters; 942
RHD Coupes; 1,798
LHD Coupes; 5,871This seems to put your car between May and
book I’ll do more research for you, if it will help.BTW, he further states that white is the best colour,
but that’s not important to this post (just to me!)Now, I knew all those numbers/dates without need
Hopes this bit helps.Regards,
Thanks Charles. I’m really amazed about the thoroughness of Haddock’s guide.
I’m going to make every effort to obtain the guide. Our university book
store is networked in such a way that I’m sure the store can locate a
Haddock’s. The Brits, you reveal, only got to buy approximately 2,800
E-types out of a production of about 15,500 Series 1 that were produced. I
had done some rough calculations from another source and had figured my car
was built mid-way between the 1964 model run. Again, thanks for your very
informative replay, which I am now going to Save as…on my Mac for future
reference.
Date: Wed, 11 Sep 1996 23:12:41 -0400 (EDT)
Subject: Re: Vehicle Dynamics (Was XJ Rear Suspension Behavior) [Very Long]
(Very long part deleted)
What B.J. has described is pretty much the standard thinking of most
sedan makers. The effects (bump/roll steer and compliance steer) do
apply to a degree with the XK/XJ rear suspension, but I don’t think it
was by design. This suspension system, started with the E-type, dates
back to the very early sixties. It’s design in both layout and function
is very close to the racing machinery of the period. upper and lower
tranverse arms (with the axle often being the upper arm) attached to
the differential housing, and trailing arm(s) attached to the monicoque.
The results are a system with minimal toe change with travel, a low IRC
(minimum side scrub), while giving an acceptable camber change curve.
Note that the transverse links run on bearings, not rubber. The only
rubber in the system is the diff to frame mounts (via the cage), and the
trailing arm links. I feel that the rubber was added only for noise and
vibration control (comfort), and the resulting compliance is a “necessary
evil” side effect.
Another side effect of this particular suspension layout is the hub
and arms are not positioned to effectively deal with brake reaction torque.
Thus, as with sixties Formula 1 cars, the brakes had to be moved inboard,
inducing much owner shock at the cost of service. :>
This, the race bred suspension (that’s not just a slogan!), with simuliar
details in the front, is the Magic of the Jaguar, especially the XJ
sedans. The ride is fantastic. The handling, for a 2ton+ sedan, is outstanding.
Having both in the same car, at the same time, was unheard of. It took
25 years and lots of computer time for the rest of the world to catch up.
Now, the XJ40 is a totally different beast. The whole rear suspension was
designed around compliance steer. while the suspension arms are still
firmly attached to the diff housing, the diff in these cars is hung by
a very complicated rubber suspended trapeze arrangement. It is set up to
induce a fairly large amount of compliance understeer. Blasting down a
back country lane, the magic just is not there with these cars.
tire.
Ummm, huh? The total weight transfer for a given condition is determined
by the CoG position and the mean track of the vehicle. Where this
weight is tranfered from and to is a function of the springs and anti-roll
bars. Adding more anti-roll bar force at one end of the car will increase
the weight transfered from inside to outside at that end of the car, which
in turn means less will be transfered at the other end. In general, the
more weight transfer taken on on end of the vehicle, the less relative
grip that end will have, though there are notable exceptions to this. these
exceptions are often cars with an extremely offset (fore/aft) CoG position.
Randy K. Wilson
Date: Wed, 11 Sep 1996 23:17:12 -0400 (EDT)
Subject: Re: XJ40: Round to Square Headlamps
Hello Jag-lovers!,
I’ve done it for a customer. It’s all bolt in stuff. The bulb controllers
have to be changed. The wiring (to the lamps) is different, the bulb wattage
is different, and the logic is different. The time I did it was with
customer supplied used parts, so I can not give an accurate guess at the
cost.
-cobac@ix.netcom.com -89 XJ40-VDP
Randy K. Wilson
Date: Wed, 11 Sep 1996 23:27:20 -0500
Minnesota perspective to this issue.In the winter here it is common to use 5W-10 so the stuff can retain some
fluidity to it!Don’t you wish you all lived here???
'88 XJ40
Minnetonka,mn,usa
Scott’s information led to my reminiscing about owning my first Jag (used)
in 1956. We had a very strong sports car club and we never missed being
part of a parade or racing during intermission on a local half-mile dirt
track while the Detroit iron made hasty repairs or modified what had
already been modified. Anyhow, there were several XK-120 and XK-140 owners
in our club and we all religiously used nothing but Castrol motor oil in
the appropriate weight for each of the four seasons. And we changed oil
more often than we probably needed to, we all wore leather open-backed
driving gloves, Brit style caps (wool in winter, of course) and probably
looked pretty hilarous to those “others” in Warren, Ohio. We had to be
careful to what we exposed all that natural rubber in the brake system and
elsewhere. But this strict maintenance paid off. I took my Jag to Aruba
where I worked for Esso and there was no one on the island one could go to
for any kind of mechanical work. When the Jag, an XK-120M Drophead Coupe
hit about 50,000 miles, a good friend of mine with all the right tools
helped me rebuild the lower end, replace the rings and we even ground all
the valves with a homemade device (a rubber dart on the end of a dowel with
grinding compound did the trick). Now I let BP lube my E-type and fill the
crank with 10-30w with whatever oil they recommended. Oh, yes. Back in the
XK-120 days, all of us in the club swore by 100-octane white gasoline
(nearly an aircraft grade), but I long ago forgot the brand name.
Date: Wed, 11 Sep 1996 23:26:34 -0400
In a message dated 96-09-11 22:42:02 EDT, RMac@aol.com writes:
<< (Incidentally, there are only three violations for which police will give
you
homicide.) >>
not totally true. if you drive agressive enough (and the road is not full)
you can a ticket for other things. in my 84 XJ-6 I used to drive like a nut
in NY (actually I used to drive it like it was a little sports car.) anyway,
in that car, no wait, it was the 90vdp…well, it was one…anyway, I was on
the west side highway, and decided I wanted to be on the service road to turn
to go to 7th ave (I was headed uptown). At about 60 I changed over in one of
the places that are not turn lanes and cut the shit out of someone without
slowing down, well, a cop saw it and ticketed me. I will admit I was driving
that car like a porsche not a jag. thats why I bought a porsche, and now
drive a jag the proper way. fast but not that way. anyway, NY cops will
ticket you when it is blatent enough
Date: Wed, 11 Sep 1996 22:44:36 -0700
Date: Tue, 10 Sep 1996 17:22:41 -0400 (EDT)
Whoa, just a cotton pickin minute now…
My Turbo Esprit SE looks amazing
It doesn’t drip oil
It’s very reliable (so far)
AND
it will leave all those wussy Jags in its dust.
So there!
Dave
Date: Wed, 11 Sep 1996 23:22:57 -0400 (EDT)
put
the
perfect working
order.Michael,
From the description, I would say that the charge solenoid is faulty; not
seating properly. This allows pump output to partially bypass back to the
reservoir, hence the long charge time. This may be combined with a weak
or dead pressure accumulator.
Randy K. Wilson
Date: Wed, 11 Sep 1996 23:32:40 -0400 (EDT)
gives good pressure at operating temp.I began running it in my TR6 because of bad cylinder wear (124,000+
oil pump and lines.
I did something today that I had not done in many years. I dug up and
looked at the Jaguar oil viscosity vs. ambient temp chart while talking
to a customer that was running 10w/30 in his V12. Jaguar recommends
20w/50 in all temps above -10c (18F). Their high temp cut off point
for 10w/30 and 10w/40 is 15c (60F). I didn’t even look at the 5w/30
numbers, but the bar was way down the chart.
We run 20w/50 here all year, and winter ambient temps do go below
freezing… though not by much.
Randy K. Wilson
Date: Wed, 11 Sep 1996 21:14:31 -0700
Bob, according to the Jaguar E-Type Six-Cylinder Restoration and
Originality Guide by Dr. Thomas Haddock, the LHD Coupes started with
chassis number 885001 and the total production was 5,871 for a total of
89,0872 LHD FHC built. I believe this would make your car one of the
last 242 3.8 liter coupes built. The 87,5001 number you quote is for the
LHD roadsters with a total of 6,885 built. According to the book, the
last years production incorporated several of the features of the soon to
be 4.2. These included upholstered dash, console with storage
compartment and padded cover, armrests on the doors, sculpted windshield
L-post trim, and even synchromesh on the very last cars.
I would say that you probably just barely missed the all-synchro tranny.
I used to own a 64 E-type roadster and it too had all of the above
mentioned items except the synchro-tranny. From what I read in the parts
catalogs, I believe the sychro 4-speed is a bolt up proposition but I’ll
defer to someone whose actually done it.
My current project car is a 70 E-type roadster. It is a series 2 and I
know a lot of people don’t think they are a pure sports car like the
series 1. I have read many test reports that seem to indicate that they
are the equal of the series 1, just a little more civilized. I fully
believe that they could be built today to comply with most safety and
emmisions standards and still look like a sports car. I have mixed
feelings on the styling of the new XK-8. Hope this info helps! GWC
End of jag-lovers-digest V2 #350
id for jag-lovers-digest-out; Thu, 12 Sep 1996 19:30:04 +0200 (MET DST)
Date: Thu, 12 Sep 1996 19:30:04 +0200 (MET DST)
Message-Id: 199609121730.TAA00696@ekeberg.sn.no
Subject: jag-lovers-digest V2 #351
Precedence: bulk
jag-lovers-digest Thursday, 12 September 1996 Volume 02 : Number 351
RE: Oil Weight
re: air dam on XJ-S
re: air dam on XJ-S
XJ6 II vacuum connections
Le Jog 1996
SV: Oil Weight
re: air dam on XJ-S
XJ40: How does your A/C work
Re: Re: When the student surpasses the teacher…
XJ12 carbs, timing
E-Type all syncro trans conversion
83 XJ-S TRACTION PROBLEM
Re:V12 Radiator stuff
To: Larry Lee
Re[2]: fuel for the “air dams on the XJ-S” controversy
Missed messages and FTP address
Last Report on “Old #25”. It is finished.
Date: Thu, 12 Sep 1996 00:52:56 +0100
At 10:32 PM 11/09/96 EDT, Ed wrote, in part:
I’m sure you meant “how well your Jag leaks!”
It is a jag-u-war, after all!
Mine leaks very well, thank you very much.
'62 E-Type, ots
Date: Wed, 11 Sep 96 23:16:41 -0500
Subject: RE: Oil Weight
Scott,
As a new Jag owner I have been looking for additional information on oil used for the winter. Here in Wisconsin I have always changed from a 20W50 to a 10W30 for winter. But 5W10 ? Do you do freeway driving with that weight oil ?
fluidity to it!
Date: Thu, 12 Sep 1996 00:54:36 -0005
John Napoli:
I’m not sure how much louvers will do toward reducing front end lift,
but they will definitely help engine compartment cooling. Question
is, is this necessary? And worth the problems of intaking hot air
into the A/C intake?
Oh, yes. By a whole bunch.
| - Palm’s Postulate
Thomas Alberts talberts@aero.odu.edu:
…I have no idea why they decided
Just a guess: The pre-79 V-12 supposedly had a double-groove pulley.
Maybe the wider pulley – or the belts – got too close to the bolt
head.
This is the first I’ve heard of this. Hard to imagine anybody
breaking a Phillips countersunk bolt. Is this really something that
needs mentioning in the XJ-S booklet?
| - Palm’s Postulate
John Napoli:
…but my question is
whether this happens at a lower speed than on a car with the air dam. If
thirty mph (neglecting wind) was the number on my car, then will it be 33?
36? on your car? Even a five percent difference would seem to be
significant.
Gee, are we all supposed to go out and perform this test? Seems to
me it would go a long way toward testing the condition of people’s
hood struts, but I dunno what else we will learn. Probably need
somebody to try a spoiler on/spoiler off test with the same car.
Won’t be me, it’s too much work – and I’m already convinced the
spoiler is valuable.
Perhaps a better idea would be to forget about unlatching the hood,
and instead rig some sort of manometer within the passenger
compartment with a hose run into the engine compartment. Then take
the car up to highway speed and see how much pressure there is in
there with the hood shut. A couple readings like this – from people
with and without spoilers – should give us a good indication.
I’m pretty sure a suitable manometer can be faked with a piece of
clear nylon hose and a yardstick. And a few ounces of water.
| - Palm’s Postulate
Date: Thu, 12 Sep 1996 00:57:25 +0100
you
homicide.) >>
I understand that they are also ticketing chevy engines in…
oh, never mind!
'62 E-Type, ots
From: “Arnold, Dave Dr.” davearno@sandton.senchem.co.za
Date: Thu, 12 Sep 96 07:41:00 PDT
Subject: XJ6 II vacuum connections
Dear experts…could anyone please tell me how many vacuum
connections there are to the inlet system on my 1980 XJ6 ser II? And
where they are? I am missing a vacuum pipe from the air temperature
valve on the air inlet tube (the one that mixes hot air from the exhaust
cowling and colder air from the ram tube) and I can’t see any reference
to it in my manual, so even if I get one I don’t know where it plugs into
the inlet manifold, if indeed it does! I also have symptoms of a vacuum
leak such as no brake assist immediately I switch the engine off. I will
be most eternally genuflectingly grovellingly topknotpullingly grateful
if you can share your all-knowing worldly wisdom.
Dave.
80 XJ6 II my daily transport
47 Mk IV my daily transport of delight
84 VW Passat son’s daily resource drain
84 Renault TSE daughter’s ditto
90 Corolla wife’s daily
49 Wife husband’s weakly
Date: Thu, 12 Sep 1996 01:22:25 -0500
worthless.
Technically Kirbert is correct, however, resealing the rack doesn’t always fix
a leak anyway. If the leak doesn’t annoy you then I agree with Jim; keep the
dust out and top it up once a month. Fix something more serious instead.
Date: Thu, 12 Sep 1996 06:58:06 GMT
Subject: Le Jog 1996
Any of you jag-lovers planning to participate?
(Dec 7-10 in England)
Glue Man
glueman@collano.ch
Date: Thu, 12 Sep 96 10:17:00 PDT
Subject: SV: Oil Weight
Scott,
I have used Mobil 1 5W50 for a year now, and I like to think upon this as
a grade for all conditions. This grade is produced in Sweden, and is
maybe only ment for the Scandinavian marked(?). Any comments…
Are Lorentsen
Narvik, Norway
82 XJ6
Date: Thu, 12 Sep 1996 04:50:45 -0500
Some time ago, as an experiment, I disconnected my hood struts, popped the
hood latch, and went out for a drive. By 30 mph or so the hood was firmly
pulled up against the hood safety latch. Conclusion: much higher
pressure underneath, even at that low speed. I wonder what the results
John
About 45-50 mph which supports all the other responses you got explaining the
function of the air dam and Whatshisname’s theory.
Robert Bradley, 87 XJS c/w air dam etc.
From: etles@etlxdmx.ericsson.se ( espen skare xm/pp )
Date: Thu, 12 Sep 96 11:01:53 BST
Subject: XJ40: How does your A/C work
I agree in Roger Pengs opinions on stupid controls design. An
attempt to make it non-tech and user friendly has made it confusing
instead.
I also think a major missing of the A/C and vent control of the XJ40 is
the lacking ability to get some fresh air through the vents without using
the fans. Just pure ventilation from the speed of the car. Most other makes
have this. It should not be impossible or too expencive even combined with
all the A/C stuff.
/Espen
Date: 12 Sep 1996 14:03:55 GMT
Subject: Re: Re: When the student surpasses the teacher…
It doesn’t drip oil
AND
At least it’s a british car. You can stay
Cuno
Date: Thu, 12 Sep 1996 08:28:24 -0400
Subject: XJ12 carbs, timing
Dave,
How can I check for vacuum leaks?
Best way I’ve found is to use a length of hose with one end to your ear
and the other used to poke around everything that has to do with vacuum
- from all around the carbs to the heater and A/C controls. I go to the
extent of putting small hose clamps on all the vacuum hoses just to be
sure of a tight fit. Also, make sure your brake diaphragm is not
leaking (although I haven’t heard of that failing in that way).
The drilling I did was on the UniSyn… not the carbs…
Oh. Whew!
When I set the timing (6 ATDC?), should the vacuum pot have the vacuum
hose connected or not? I just replaced the pot with a new one.
I have a factory shop manual (unfortunately for a '72 XJ12 - anyone know
if there is a difference timing-wise???) and it says:
1. Disconnect vacuum pipe from vacuum retard unit (plug).
2. Slacken locknut of micro adjustment control and set
vernier at zero.
3. Set engine idling speed at 500 to 600 rev/min.
4. Check timing with a stroboscope and adjust vernier
until timing is 12 degrees BTDC.
5. Tighten locknut, refit vacuum pipe.
6. Reset engine idling speed at 650 to 750 rev/min.
BTW, where did you find a retard module? I got a price of $85 USD from
Welsh with a 2-3 week wait (I’m using an old one from the TR6).
Let me know how it runs…
Dave Ox.
73 XJ12
75 TR6
Date: Thu, 12 Sep 1996 08:25:09 -0500
Subject: E-Type all syncro trans conversion
Greetings,
In a recent post someone mentioned that converting an E-type Moss =
gearbox (aka Crash Box, I don’t need no stink’n synchro in first) might =
be a straight bolt on. I have a 67 E-Type that a PO converted from and =
all synchro box to a Moss Tranny. I called two or three shops including =
Grand Tourismo and Straight Six about converting back to the correct =
tranny. According to the people that I talked to, it would require a =
replacement bell housing, speedo gear, fly wheel, starter and =
transmission. This started running into big (for me) $$$$$. I still =
have the old Moss box… The things are darn near indestructible.
Jack Fulford
67 E-type
Dallas, TX
Date: Thu, 12 Sep 1996 08:13:21 -0700
anyway,
You must have thought that you thought you were driving a Mk2!?
on
turn
of
without
driving
Give up the porsche buy a Mk2 if you want a sample of how you can scare the
Lexus’ or is Lexii, and do it in a Classic manner, come out to LA and we
will go hunting.
Patrick D. O’Neill
1963 Mk2 3.8L MOD
Date: Thu, 12 Sep 1996 09:04:50 -0700
Subject: 83 XJ-S TRACTION PROBLEM
xjs 5.3 automatic which is used on slalom circiut is equipped with race
tires ,shocks,and sway bars. However have traction problem exiting corners,
the car wants to go sideways (rear end) upon applying throttle need advise
on traction control.
considering manual transmission any advise as to helping this problem would
be appreciated. Also availability of used or new manual transmission.
S.R. BROADY
acmevfsl@direct.ca
Date: Wed, 11 Sep 1996 17:06:00 -0400
Subject: Re:V12 Radiator stuff
Jim:
I’ve just been where you are going now with your radiator,
both in a friend’s XJ-S, and in our SIII V12.
To get that short hose from the cross-over pipe to the
water pump housing back in, you will have to remove
the cross-over pipe. To get it back in, you have to
put the short end of the cross-over pipe “just” in its
hose, at the same time as you “just” put the large
cross-over pipe in that short hose. This is done with
the longer end of the cross-over pipe in front of, and
just above the A/C compressor pulley. the trick then is
to twist and push down the cross-overpipe so that it
goes below the A/C pulley and the longer end of the pipe
goes into it’s hose, WITHOUT the shorter pipe end coming
out of it’s hose. Life is a bit easier if you remove
the crankcase breather elbow, and the A/C compressor,
but I did not have to. It took me about an hour to
figure that out, and about 30 seconds to actually put it
in.
I don’t know about the wires you’re talking about, but I
will look for them tonight.
Something that I’m a bit interested in…what is “rodding out”
in reference to radiators. The only option I know of around these
parts is a core replacement, or a new radiator. We did a core
replacement on the SIII, temp now at between 90-100 C, and just
a clean on the XJ-S, temp now at the “N”. I think I may still
have a thermostat problem on the SIII, as the temp fluctuates,
for no apparent reason.
Regards, Mark Roberts Phone: (613) 763-2924
Ottawa, Ontario, CANADA Fax: (613) 763-3970
1988 VDP - SIII V12 email: markdr@nortel.ca
1963 3.8L E-Type Coupe - 15 years into a 3 year project
Date: Thu, 12 Sep 1996 12:23:07 -0005
Subject: To: Larry Lee
Hey, I don’t happen to have Larry Lee’s e-mail address. Everyone
else can delete this message.
Lee: On your schematic for connecting a Dana aftermarket cruise
control to the Jaguar set switch and ON/OFF/RESUME switch, there is a
standard relay. Did you mean to imply that the installer must buy
such a relay? Or does the Dana kit come with one?
Thanks.
| - Palm’s Postulate
Date: Thu, 12 Sep 1996 12:46:53 -0400
be careful what you offer. I may just take you up on it. - Doug
and the correct reply is not give up the porsche and get…it is drive the
porsche a little less and get…
I am a lover of all fine cars. and the each have their place and purpose. I
hope to never sell another car (except for daily beaters “take your dog to
the vet cars” like my integra). But I do hope to get an MK2 someday (along
with several other jags) - Doug
Date: Thu, 12 Sep 1996 12:38:58 -0400
Subject: Re[2]: fuel for the “air dams on the XJ-S” controversy
- –IMA.Boundary.611645248
Content-Type: text/plain; charset=US-ASCII
Content-Description: cc:Mail note part
FWIW: My '88 XJ-S, which has both the air dam and undertray present and in
good condition, also gets extremely hot in the transmission tunnel area.
My theory is that the very hot (and therefore expanded) air flowing through
the engine compartment is partially forced to exit via the tunnel. This is
caused by the reduction in area when it gets to the firewall and is forced
under the car. The air dam and undertray should help cooling by forcing
more air through the radiator and reduce front lift by lowering the
pressure under the extreme front of the car. However, I’m not sure that
forcing more air through the radiator will reduce the tunnel temperature.
MikeC m.cogswell@zds.com
'74 E-Type OTS
'88 XJ-S (H&E Convertible)
'88 Honda Accord (330,000 miles and climbing)
'91 Chevy Suburban (when you really need the room)
'96 Honda Accord (hope it lasts as long as the '88)
Author: John Napoli jgn@li.net at INTERNET
Date: 09/11/96 06:03 PM
John
- –IMA.Boundary.611645248–
Date: Thu, 12 Sep 1996 13:05:08 -0400
Subject: Missed messages and FTP address
- –IMA.Boundary.974745248
My internet mail connection was lost from 9/3 through 9/11. If anyone sent
me mail and had it “bounced”, please resend.
Also, can anyone supply the ftp address for the digest archives? I’d like
to get up to speed on what I missed the past week and also while I was on
vacation. The www site doesn’t have any recent digests on it. While it
suggests getting them from the ftp site, the address is not provided.
Thanks
- –IMA.Boundary.974745248–
Date: Thu, 12 Sep 1996 10:23:21 -0500
Subject: Last Report on “Old #25”. It is finished.
She is at home now and resting well. I have put 250 miles on it the last
two days.
The cost was reasonable, though a bit above my orriginal expectations.
We essentialy removed the body from my '82 and placed the body from a '85
onto the old running gear. The only thing that is from the new car in the
running gear is the front suspension and steering rack. The rest including
the exhaust system, and drivetrain (engine and trans) is from the old car.
The interior is from my old car.
Things that got fixed because of a new body:
1) old car needed a new paint job. New body has a 1 year old $3000 job.
2) Antena now works properly
3) rear radius arm bushings needed replacement.
4) Old windshield gasket was leaking
5) there were rust spots on the old body and left rear door was shot.
6) There was a "cow bell" behind the rear seat
The cost was just $500 more than the insurance to buy the '85 and another
$2175 to the shop to do the work. (they gave me $500 for the old car as
salvage) or the price would have been $2675.
So my bottom line was $2675 to get a car that was worth $2200 more (1985 vs
1982). Thats $475 in the hole, but my deductable was $500 so I actualy came
out $25 ahead.
But…But… look at all the things I got fixed for free (list above).
So, as we can see, totaling the old car was not so bad after all. And now I
have a computer!
Jim
Nance O’Neil
End of jag-lovers-digest V2 #351
X-UIDL: cd9cb31ca79189a26628a46aeefff8a4
id for jag-lovers-digest-out; Fri, 13 Sep 1996 03:56:15 +0200 (MET DST)
Date: Fri, 13 Sep 1996 03:56:15 +0200 (MET DST)
Message-Id: 199609130156.DAA07828@ekeberg.sn.no
Subject: jag-lovers-digest V2 #352
Precedence: bulk
Status: RO
X-Status:
jag-lovers-digest Friday, 13 September 1996 Volume 02 : Number 352
Wheres Nick?
Re: Panic in the forest
Re: SV: Oil Weight
Re: Wheres Nick?
Re: 64 3.8 S-type automatic transmission shfiting hard
S.U. CARB PARTS
front shocks 86 XJ6 SIII FW: S.U. CARB PARTS Advice: Cold start/idle:'78 Ser2 XJ-12 Off topic help request Re: V12 Radiator stuff XJS air dam and XJ6 engine cooling, mixed a bit. Re: XJ-40 Hard Stsrts Re: When the student surpasses the teacher.... Re: Off topic help request Inroduction + MK2 steering re: air dam on XJ-S re: air dam on XJ-S Re: XJS air dam and XJ6 engine cooling, mixed a bit. Re: XJS air dam and XJ6 engine cooling, mixed a bit. XJ6 III Stake-down Re: front shocks
86 XJ6 SIII
Date: Thu, 12 Sep 1996 10:23:18 -0500
Subject: Wheres Nick?
I have lost the address that I need to send to to get to Nick. “The Jaguar
XJ6 from Bumper to Bumper” is ready for publication on Saturday as promised.
I need to knopw where to send the document to get it on the WEB page.
Jim
Nance O’Neil
Date: Thu, 12 Sep 96 10:34:50 PDT
Subject: Re: Panic in the forest
It would appear that the rest of my wood trim is deteriorating rapidly. It
looks great from arm’s length, but getting real close reveals many tiny
light-colored “fractures” appearing in the finish. Have I just noticed them,
I wonder, or is something horrible happening? What can I do to prevent this
deterioration? Is refinishing or replacement the only option?
This may not be possible, but the best thing for you to do is to not
let your car sit out in the sun all day. Use a window shade whenever
it is under the sun.
My `91 XJ40 has received this treatment since very new, and the wood still
looks great.
By the way, I think your “Majestic” has a terrific interior, similar
to a Rolls Royce.
Roger Peng (408)765-7863
Intel Corporation
Design Technology, Physical CAD
Date: Thu, 12 Sep 1996 13:38:56 -0005
Subject: Re: SV: Oil Weight
Are Lorentsen:
Around here, Mobil 1 comes in 15W-50. However, Pennzoil Performax
100 synthetic oil comes in a 5W-50, and I think some others do too.
I’m not sure the weight is as important as the fact it is synthetic.
I live in Florida, but a few friends and relatives that live in the
cold North tell me that a synthetic oil – ANY synthetic oil – is
simply wonderful for cold weather starting.
| - Palm’s Postulate
Date: Thu, 12 Sep 1996 20:07:37 +0200
Subject: Re: Wheres Nick?
[ JISBELLJR@mail.utexas.edu (James A. Isbell) ]
You can remember “jag-lovers@sn.no” but not “nick@sn.no”?
Nick
<<< Nick Johannessen | nick@sn.no | nickj on IRC >>>
Date: Thu, 12 Sep 1996 13:29:28 -0500 (GMT-0500)
Subject: Re: 64 3.8 S-type automatic transmission shfiting hard
Dear Albert,
If that particular transmission has a govenor, I would replace
that part first. The governor in a BW Tranny is what forces the 1-2 and
the 2-3 valves in your tranny to move, causing repective shifts. If the
Governor is worn, it will cause erratic shifting. Do not play with the
throttle cable, as if you do adjust it to get it to shift properly, You
could lower the hydraulic pressure to the clutch packs in the transmission
and cause them to slip, and eventually burn up the transmission. If it
has a govenor, all of the above will apply.
Yours Truly,
Mario James
Date: Thu, 12 Sep 1996 11:50:14 -0700
To: patrick.oneill@premierusa.com; jag-lovers@sn.no
Date: Thursday, September 12, 1996 9:46 AMbe careful what you offer. I may just take you up on it. - Doug
The offer is open.
the
Just a minute I thought this was the Jag Lovers List, with that in mind I
am sure my reply was the correct one!
I
to
(along
Words to live by.
Cheers,
Patrick O’Neill
1963 Mk2 3.8L MOD
Rolling Hills Estates, California (near LA)
Date: Thu, 12 Sep 96 14:14:41 CDT
Subject: S.U. CARB PARTS
I have a 66 3.8L MKII LHD with all synchro tranny and type "A" compact
OD. I just finished a big DIY brake job - new pipes, new servo,
resleeved cylinders (XKs did these) etc. Now I'm on the carbs. Does
anyone know of a good source for S.U. HD6 parts (other than the big
catalog folks - seem to only have some of the AUC #s)? I don't need
anything yet but I am curious about a source for new/used
pistons/chambers.
Date: Thu, 12 Sep 1996 16:33:10 -0400 (EDT)
Subject: front shocks `86 XJ6 SIII
Hello, Recently bought my first Jag, an `86XJ6 and am busy working
on various things. Immediate major concerns are back brakes, front
shocks and probably most serious of all is the rust. Anyway, I want
to get shocks on the front right away. The place I called wants to know
if I want replacement hydraulic shocks or the “upgrade” gas shocks
(about $20 more each). Mostly cross-town driving but there are
plenty of potholes here in Ann Arbor. Recommendations on which type
to get would be appreciated. Thanks in advance, Gary
ps: I enjoy the jag-lovers postings; helpful because I have never
worked on a car like this before.
Date: Thu, 12 Sep 1996 16:01:08 -0500
Subject: FW: S.U. CARB PARTS
You wrote "Does=20
anyone know of a good source for S.U. HD6 parts "
I used Joe Curto as the supplier when I rebuilt the triple SUs on my 67 =
E-type. He is OUTSTANDING!! He walked me through some tight spots in =
the rebuild and helped save me a little money.
His particulars are Joe Curto, 230-22 58th Ave. Bayside, NY 11364 =
1-718-465-4829
Jack Fulford
67 E-type
Dallas, TX
Date: Thu, 12 Sep 1996 17:18:22 -0400
Subject: Advice: Cold start/idle:'78 Ser2 XJ-12
Does any one have suggestions re: diagnosis on hard-start and stall
from cold on '78 XJ12.
I suspect, and have removed for testing, the auxillary air valve, but
I'm not sure that the "boiling water test" has told me anything--seems
to be no change in the valve, but maybe I'm looking at the wrong
port/area.
Has anyone had success in relacing/renewing these to fix idle speed
and/or start problems?? Also can the valves be purchased; I did some
checking w/ one supplier and was told they are no longer manufactured.
Other suggestions?
All comments appreciated.
Phil Grant
Purcellville, VA
Date: 12 Sep 96 17:44:59 EDT
Subject: Off topic help request
I think I saw someone on this list that sold notebook computers, does anyone
remember who it was? I’m in the market for a new computer and am wondering
about the pro’s and con’s of a notebook replacing my desktop computer.
Thanks one and all fellow Jag lovers and drivers,
Ron Powers
Date: Wed, 11 Sep 1996 17:12:00 -0400
Subject: Re: V12 Radiator stuff
Jim:
Now that I’ve actually thought about it for more than
30 seconds, if you have the water pump off, and the cross-over
pipe out, relacing them as a unit would be MUCH easier than
replacing either of them individually. The instructions
I gave earlier were for replacing the cross-over pipe
with the waterpump still on the engine. :-0
Sorry for the wasted bandwidth.
Date: Thu, 12 Sep 1996 13:20:49 -0500
Subject: XJS air dam and XJ6 engine cooling, mixed a bit.
Since my XJ-S has no air dam I will gladly preform any experiment (within
reason and below 100MPH) that anyone thinks will be beneficial to the
conversation.
Now as to louvers. It is my considered opinion that two, just two, louvers
in say three rows across the hood, just infront of the firewall might be
beneficial on an XJ6 so maybe also on an XJ-S.
The reason for this opinion is that day before yesterday I got the XJ6 back
after the rebuild. When I go out on the highway the bonnet will stay down
for about 50 miles at highway speed then it will pop up on the right side.
(yes, I am going to fix it, just dont have time right now!) I don’t stop to
put it back down because it isnt dangerous.
But…I have noticed that the engine temp drops by 3 drgrees centigrade
from 82 to 79 after a few minutes with the bonnet poped up.
Emperical data, lap it up!
Jim
Nance O’Neil
From: Michael Powers/TEIR/Thomson Michael_Powers@teir.com
Date: 12 Sep 96 17:54:37
Subject: Re: XJ-40 Hard Stsrts
Many thanks to the people that replied on this one!! The new valve on fuel pump
fixed the troubles. Now she starts up on the first crank!!
Rgds,
Mike
89 XJ6
PLacey @ swri.edu
09/10/96 01:15 PM
To: Jag-LOVERS @ sn.no @ Internet
cc:
Subject: XJ-40 Hard Stsrts
I had this same exact problem with my 88 XJ-40 and several others on the list
have reported the same. Hard starting with a hot engine that has sat for a
while. It was due to failure of the non-return valve at the fuel pump. This
allowed the fuel vapor pressure to push the fuel back to the tank and the
system to vapor-lock. The non-return valve is cheap and easy to replace.
Paul Lacey, Texas
Date: Thu, 12 Sep 1996 19:01:16 -0400 (EDT)
Subject: Re: When the student surpasses the teacher…
So you don’t pass any Jags, because none of them are wussy.
Gotcha back!
John
It doesn’t drip oil
AND
it will leave all those wussy Jags in its dust.So there!
Dave
Date: Thu, 12 Sep 1996 16:10:21 -0700
Subject: Re: Off topic help request
Ron,
I don’t know if if was me, but my company sells the Jetta Notebook
computers, and they are priced well also. My personal choice is to
use a notebook with a large color monitor and 101 keyboard while at
my desk, and to travel where-ever I go with my computer. It keeps me
always up to date, and I seldom have to double enter things and NEVER
wish I had access to a file or program when I’m away from my office.
Our homepage is below…please look the Pentium 133 MHz configured
there,
and give me a call if you would like a different configuration.
Delivery is running about a five to seven days.
If you have any other questions, please give me a call. Hope we can
help.
Donald R. Farr
President
National Consulting Services
6719 North 58th Place
Paradise Valley, AZ 85253
(602) 998-3919 - voice
(602) 948-7499 - fax
91 Sovereign
d.farr@phx.cox.com - e-mail
http://people.phx.cox.com/dfarr/dfarr.htm - Don’s Homepage
http://people.phx.cox.com/dfarr/jetta1.htm - Jetta Notebook Computers
http://people.phx.cox.com/dfarr/march10.htm - Wireless products
http://people.phx.cox.com/dfarr/ncs1.htm - National Consulting Services
From: Frank Holden Frank_Holden@qmgates.affymax.com
Date: Thu, 12 Sep 1996 16:14:58 +0000
Subject: Inroduction + MK2 steering
Hello all, I just subscribed.
Here is a breif introduction-
My name is Frank Holden, I live in California near San Francisco, but I’m
really from Northern Michigan.
I have a 1961 Mk2 Jag, a couple of other British cars, a Volvo and a GMC truck.
I also have three motorcycles, an AJS, a BSA and a Norton
I work for a biotech type company and do pharmaceutical research.
I’m having some trouble with the power steering box on my Mk2. It leaks. I
have replaced all the seals except the one on the bottom where the shaft comes
out. It still leaks.
I am considering installing a rack and pinion power unit from an XJ6 or XJS.
I see XKs Unlimited sells a kit for about $2000 but I think that is a little
steep. I can get a rebuilt power steering rack from an XJ6 for less than $400.
I will have to fabricate mounting hardware and modify the steering column
shaft. I talked to the guy that rebuilds the racks and he says there are two
types. Does anyone know which type I need for my Mk2? What kind XKs
unlimited uses? Any help would be greatly appreciated.
Thanks,
- -Frank
Date: Thu, 12 Sep 1996 19:14:59 -0400 (EDT)
Subject: re: air dam on XJ-S
Oh, come on. Anyone with the spoilers and disconnected hood struts can do
the test.
I like the manometer idea. Take readings on both sides of the hood at
different speeds. How much head is needed to use water? Is glycerin or
mercury or something needed to have a small enough gauge?
John
spoiler is valuable.I’m pretty sure a suitable manometer can be faked with a piece of
clear nylon hose and a yardstick. And a few ounces of water.– Kirbert | If anything is to be accomplished,
| - Palm’s Postulate
Date: Thu, 12 Sep 1996 19:24:21 -0400 (EDT)
A number! Thanks. Now I can rest.
Now I guess I’ll need the air dam stuff. I still like the idea of hood
louvers. Any of you E-Type guys have problems sucking hot air into the
cowl inlets? My guess is that the flow is turbulent enough and so small
compared to the mass of ambient air and what about the hot heater matrix
in there anyway and besides we waste some of the cool chilling gasoline
and it still works so it should not be a problem.
John
function of the air dam and Whatshisname’s theory.Robert Bradley, 87 XJS c/w air dam etc.
Date: Thu, 12 Sep 1996 19:48:57 -0400 (EDT)
Subject: Re: XJS air dam and XJ6 engine cooling, mixed a bit.
So far I think we’re the only ones without the air dams.
John
conversation.
Date: Thu, 12 Sep 1996 16:50:27 -0700 (PDT)
My father had the same experience with his series 2 XJ12. In the
summer he regularly drove with the bonnett loose, allowing air to
escape; it was the only way to keep the engine from overheating.
The air conditioner also couldn’t be ran… unless it was cold
outside without causing overheating. Not very useful. That
car, a '79, used as a daily driver, was one of those that gave
Jaguar it’s poor reputation. It was total’d when we here hit
by a big old Cadillac; but the machanics who had done most of the work
on the car bought it from the insurance and rebuilt it; we’d see
it driving around Denver every now and then (recognizeable by
the custom steering wheel and a few other oddities).
My dad was just getting ready to put louvres in the bonnet when
the car got smacked…
Ryan.
Date: Thu, 12 Sep 1996 19:48:11 -0500
Subject: XJ6 III Stake-down
Jag-lovers,
I’m almost ready to tackle the last major maintenance item that I have =
planned for my XJ6 with 77K miles (purchase 6 months ago). I think that =
it’s time for the stake-down kit. I have read archive references from =
quite a while back that seem to be in agreement that it must be done. =
Also, I do seem to occasionally have excessive clacking on the exhaust =
side when cold started and until oil pressure comes up to normal. I =
believe that is a symptom. Perhaps someone could better describe the =
symptoms and the models that are most likely to need this alteration.
I am asking someone to walk me through the process in much detail. If =
possible, I would appreciate a description done with the head in place. =
It sounds easier. I have valve cover gaskets, the XJ Unlimited =
stake-down kit, and almost enough courage to drill holes in the head. I =
understand that many recommend pulling the head and that some are using =
simple metal screws to hold down the valve guides, and I am not above =
changing my mind if these solutions are better. However, as an example =
of the level of instruction I need for this job, I have not tapped =
threads before. TIA
Date: 13 Sep 96 12:54:33
Subject: Re: front shocks `86 XJ6 SIII
I’d go for the gas shocks, Gary; not only are they much better as shock
absorbers, they also help the road springs a wee bit, and those springs need
all the help they can get…
- Jan
End of jag-lovers-digest V2 #352
Return-Path: @owner-jag-lovers-di1
Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4)
id for jag-lovers-digest-out; Fri, 13 Sep 1996 15:38:41 +0200 (MET DST)
Date: Fri, 13 Sep 1996 15:38:41 +0200 (MET DST)
Message-Id: 199609131338.PAA05804@ekeberg.sn.no
X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f
To: jag-lovers-digest@sn.no
Subject: jag-lovers-digest V2 #353
Reply-To: jag-lovers@sn.no
Errors-To: @owner-jag-lovers-di1
Precedence: bulk
X-Newsgroups: mail.jag-lovers-digest
jag-lovers-digest Friday, 13 September 1996 Volume 02 : Number 353
Wisconsin Jag clubs
XJ6 Book is finished???
Re: Advice: Cold start/idle:'78 Ser2 XJ-12
Re: 83 XJ-S TRACTION PROBLEM
re: air dam on XJ-S
jaguar info.
One-man E-type brake bleed
Re: One-man E-type brake bleed
Re: jag-lovers-digest V2 #352
Burlen Fuel Systems
Jag: Mk2 electrics - heated rear window
Bonnet openning (NOT XJS air Damn!)
Oil Weight
Limited edition XK8 in Neiman’s
Re: Bonnet openning (NOT XJS air Damn!)
Date: 13 Sep 96 12:57:30
Jim Isbell :
Yeah, that’s why I used to pop the bonnet on my XJC when getting into town -
until I had the radiator rebuilt.
- Jan
Date: Thu, 12 Sep 1996 21:01:30 -0500 (CDT)
Subject: Wisconsin Jag clubs
I have been a subscriber to the jag list for a number of months now.
I own a 1988 XJ-6, and have enjoyed reading all the imformation that
comes to me on a daily basis. I live outside Madison, Wisconsin in a
town called Mcfarland, and I would like to know if there is a Jaguar
club near me. Thanks
Donald Buschner dbusch@inxpress.net
Mcfarland, Wisconsin U.S.A.
1988 XJ-6
Date: Thu, 12 Sep 1996 20:21:24 +0000
Subject: XJ6 Book is finished???
As Kirby Palm pointed out, “It will never be finished.”
But I am now up to 80 plus (probably be near 100 by Saturday) pages
and I see that there is at least another 100 pages more information that
I will be adding forever if I dont stop and say “Now is the time”.
The other 100 pages and the information that is sure to flow in as
the orriginal gets distributed around the world will be added to it
in the months following.
“The XJ6 Jaguar from Bumper to Bumper” will be an ongoing project,
constantly evolving and hopefully getting better.
I will deliver the first edition to Nick on Saturday then as he feels
moved it will apear on the web page. It will be rather long so
downloading could become laborious. If you want a copy on paper or
on disk I will be able to send you one as below.
This book covers the XJ6 Jaguar from 1968 to 1986. Even though the
later Jaguar sedans are marked on the back with an XJ6 badge they are
more commonly known as the XJ40. This book does not cover the XJ40.
This book is not meant to replace a proper repair manual. This book
is a supplement to a good manual. If something in this book does not
make sense to you then use your own good judgement, thats what it’s there
for.
Some of the contents of this book were contributed by members of the
Jag-Lovers list on the internet. Where known, their names are noted.
Major sections include maintenance tips, modifications, and sources
for parts. The information is not intended to replace a repair manual,
but rather to supplement it.
If your name appears in this list, you have been quoted in the book
and your name was mentioned. I DID NOT mention your E Mail address
and only will do so if you send me a note saying you want me to.
Names in no particulat order:
Lawrence Buja (Starter diagnostics from your web page)
Bela Orban (Front end repairs and notes)
Gregory Andrachuk (all sorts of stuff)
Larry Lee (Series 1 and 2 cruise control installation)
Nick Johannessen
Greg Moboe
John Proctor
Tom Grahm
Julio Loza
Andrew Kalman
B.J. Kroppe
The book is organized as your car is organized, from the front bumper
to the back bumper. If you want to know something about the dash
board it will likely be near the midle of the book. The headlights
will be in the front of the book and the gas tanks will be just
before the appendices which include, Starter Diagnoses, Front end
bits of rubber, Wood care, a list of suppliers, production numbers of
the XJ6 and hopefully a parts replacement list of other makes that
match the Jag.
To receive a printed copy of this book send $15(US) to the author
(below). To receive a Word for Windows file so you can print your
own copy, send $9(US). Add $1(US) for Canada, $2(US) for other countries
outside the USA. Be sure to give your name and address, and state
what you want: printout vs. diskette, type of diskette (IBM
Compatable only, 3.5" or 5.25").
This book will be corrected and updated constantly. If you have learned
something about your Jag that the rest of us should know, please
write, call or send a message to:
Jim Isbell
2404 Pebble Beach Drive
Austin, Texas 78747
(512) 280-4457
InterNet: JISBELLJR@mail.utexas.edu
This book IS copyrighted. You are NOT allowed to make copies for
sale. The information in this book is for the benefit of Jag-Lovers and is
not to be used for commercial gain.
Date: 13 Sep 96 13:24:19
Subject: Re: Advice: Cold start/idle:'78 Ser2 XJ-12
Yes, Phil, your aux. air valve is deceased. It’s a particularly dumb design,
unfortunately, being a slide valve - one tiny speck of grit or a modest
accumulation of soot and it jams, and if your engine boils, the wax bulb that
operates it can expire. You can overhaul these valves, though. When you look
down the neck from the top, you’ll see a part with about six holes (there are
variations) in it; that’s the actual valve. If you make up a tool with six
flat-ended pegs to pass through these holes (about 2in long, from memory) you
can press out the brass bulb unit in the bottom - carefully; the pegs need to
be as large as you can fit through.
You can now clean out the bore and the valve slider and press the bulb back in
(or buy a new one if it’s dead; they must be available, as a chap here in
Sydney rebuilds these valves.
I got sick of fixing and replacing aux. air valves when the one on my XJC stuck
open the third time. Don’t tell anyone, but all I did was prepare a long,
narrow (1/2in) rag with some old-fashioned gasket stickum, take off the left
air filter and allow the end of the rag to be sucked in by the tube to the aux.
air valve. That blocks the cold-start passage without interfering with the idle
bypass.
The result is that my engine (which idles a bit rich) starts just fine, idles
at 650 rpm at first, coming up to 900 rpm when the cold start enrichening goes
off and settling to 700 rpm as the engine warms up. Perfect, for my money - I
was contemplating the alternative of fitting a solenoid valve, controlled by
the temperature gauge sender. If your idling problem is that it’s too fast, try
the rag cure - you’ll hear a “thup!” and the idle quiets down immediately. The
reason I made up a long, thin rag was so I could pull it out again if it didn’t
work out. Bush engineering lives!
If your engine is still hard to start, check the cold start jets; they should
open for the first couple of seconds under control of the thermotime switch. I
made the experiment of unplugging them, and they really are needed.
- Jan
Date: Thu, 12 Sep 1996 22:56:07 -0005
Subject: Re: 83 XJ-S TRACTION PROBLEM
S.R. BROADY:
If you have a traction problem on one end of a car, install a stiffer
anti-sway bar at the other end – or a less stiff one on the end with
the problem.
Y’know, I’d almost be willing to bet your rear bar is an Addco.
| some rules must be broken.
| - Palm’s Postulate
Date: 13 Sep 96 14:46:20
John Napoli : And does my car have more front end lift without an air dam?
Yes, by varying amounts depending on ground clearance etc. I fitted a very
serious air dam to my 240Z, which is a car that feels very insecure and wanders
all over the place as its front end goes light at speed. Not only did the air
dam cure that absolutely and utterly, it generated so much downforce that the
steering became too heavy.
- Jan
Date: Thu, 12 Sep 1996 22:06:31 -0700
Subject: jaguar info.
hello, i reside on the west coast of vancouver island, british columbia, canada.
home of beutiful long beach and clayoquot sound.
i am quite interested in finding a used series 3 sedan on vancouver island or?
i am a long time admirer of jags and a fairly skilled back yard mechanic,
would appreciate any leads that could be sent my way.
thank-you, leverne duckmanton
Date: Fri, 13 Sep 1996 01:20:32 -0500
Subject: One-man E-type brake bleed
There only three mechanics in my area that I would trust in solving my
master cylinder dilemma on my 64 Series 1 E-type. I guess they want jobs
that are quick turnovers. So I’ve decided to send both master cylinders to
Imperial in Nebraska to get stainless steel slieves. I can remove them and
refit the rebuilt cylinders, but I’ve never personally bled a brake system.
I know I’ll need to purchase two and possibly four jack stands plus a
hydraulic jack capable of taking the Jag high enough for placing the jack
stands. Does anyone know the approximate cost of a reliable jack stand and
the cost and brand name of a suitable hydraulic jack? These items would be
a good investment for me as I also have decided to service it properly and
at scheduled intervals. My final question is this: Can one person, without
any assistance, bleed brakes. I know the brake pedal should be pumped until
no air is evident in the brake fluid for that particular disc unit. I don’t
see how one person could both pump the brakes and observe the draining
brake fluid for air bubbles. Most of my acquaintenances
are profs like me and scoff at the idea of helping someone work on a “toy.”
Any suggestions as to any or all of the above would be appreciated.
Date: 13 Sep 96 17:06:49
Mark Roberts : .what is “rodding out”
It’s jargon for cleaning out a blocked core; you unsolder the ends and push a
special flat rod through the tubes. I have achieved much the same effect (after
unsoldering the ends, of course) with a penknife, a garden hose and patience,
as most of the blockage seemed to be close to the tube ends.
- -Jan
Date: 13 Sep 96 18:32:22
Yeah, B.J., I’m in the mechanical engineering field - Ph.D in engineering from
the University of Severe Impact, Dept. of Implied Sciences. And I have a patent
on a high-speed railway pantograph that never sold…
Seriously, let’s not confuse theory - especially public passenger vehicle
theory - with actual measurement. By actual measurement, the XJ turns the axis
through its rear wheels very_slightly outward in the corner as cornering
force increases to near-racing levels, thereby adding a wee bit oversteer. This
is why she says to a sensitive driver “hey, boss, we’re getting close to the
limit here - let’s make music” where a lump of safely-understeering Detroit
iron would just mulishly mush outward in the corner at much lower speeds,
forcing the driver to either back off or deliberately break the rear-end loose.
I have an appalling memory from road-testing the Ford Edsel back when I was a
motor journalist (yes, that long ago). Flicking the steering wheel rapidly from
side to side through fully half a turn produced loud screams from the front
tyres but no change in direction whatever, and the stupid thing rolled so much
from side to side that the suspension bottomed out. I wouldn’t recommend
copying that action with an XJ…
Where Ralph Nader (a non-driver) and his soul-mates went wrong is in looking at
the car as a pure machine, which needs to be self-stabilising and as much as
possible physically limited to a “safe” condition. It’s no such thing, of
course - the driver is very much part of the system, and must be given the best
possible means to control the vehicle throughout its performance envelope,
including strong feedback from the suspension. If he/she/it is not capable of
safely controlling a sensitive and well-balanced car, what is needed is not
castrating the car, its improving driver training.
Randy is absolutely right; this two-ton luxury car is indeed race-bred, which
explains why it’s so nimble and such indecent fun to drive fast on a twisting
country road. At my age, booze doesn’t seem as much fun as it used to be and
broads are just too much trouble - so the exhilaration my sure-footed,
sensitive, smooth and powerful Jaguar gives me is all the more precious.
As for the toe-in, it doesn’t change measurably through the suspension travel.
The torque arms have no effect on it at all, being connected through rubber.
Regarding tyre grip, I have always found wheel alignment, or rather wheel
positioning, critically important - that’s why I wanted to investigate the rear
suspension in the first place. As cornering side loads deform a tyre, pushing
the tread to one side, the wheel needs to be tilted so as to maintain the tread
flat to the road. This is why you see racing saloons with several degrees of
negative camber in order to milk their mandatory standard suspensions for the
final bit of adhesion. I’m not saying that’s the way to go with the Jag, but I
am looking to fine-tune my XJC for the best balance in handling and cornering.
I have the rears set at -1 deg camber, which is a hair over the limit specified
by the manual, and when I get back on the road in a couple of days, I’ll try
the same camber up front (currently working very well with -1/4 deg). I expect
to spend some time finding the best combination of angles with wide, modern
tyres - the factory angles were devised for the technology of a generation ago.
At least it’s worth investigating.
Some tyres do indeed have more grip than others. Radials can vary a lot in slip
angle (how much you need to turn them for a given cornering load), which
strongly affects the handling. I’ve used Dunlop Le Mans and Bridgestone Eagers
on my Jaguars, and I find both very grippy and nimble with a very low slip
angle. I’d give the Dunlops the nod, but unfortunately they don’t come in
235-60.
- -Jan
Date: 13 Sep 96 18:58:42
Subject: Re: One-man E-type brake bleed
Bob Richardson :
I know I’ll need to purchase…
No.
Can one person, without any assistance, bleed brakes
Yes.
Most of my acquaintenances … scoff at the idea of helping someone work on a
“toy.”
Sheesh…
You can do the job perfectly well with just the jack in the car, as you only
need to lift one wheel at a time enough to get access to the bleeding nipple on
the caliper (always starting with the farthest from the master cylinder). Get a
longish transparent hose (long enough to see from the driver’s position at any
wheel) and a check valve - sometimes available as a “brake bleeding kit”. Hook
the hose up, fill your master cylinder, stick the end of the hose into a jar,
loosen the nipple and pump away until the fluid is bubble-free. Don’t loosen
the nipple too much, so air is drawn in around the shank; “just enough” is the
ticket. Keep topping up the master cylinder so it doesn’t get too low. Tighten
the nipple and go to the next wheel.
If you have help, you don’t need the check valve but you have to close and
re-open the nipple for each pump stroke (or put your fingertip lightly over the
hose end to work as a check valve). Note that your helper must hold the brake
pedal down while you close the nipple, so absolutely no air gets drawn back in.
Throw out the old fluid that accumulates in the jar. When the clear, fresh
fluid comes through, re-use it.
- -Jan
Date: Fri, 13 Sep 96 09:46:05 BST
Subject: Re: jag-lovers-digest V2 #352
little_mike wrote…
Now I’m on the carbs. Does anyone know of a good source for S.U. HD6 parts
Burlen Fuel Systems in the UK make/stock just about all SU bits. I haven’t
got the address to hand, they advertise in most of the UK classic mags. I’ve
got their catalogue if you need anything looked up, or you can’t find the
address.
Cheers,
Ted
1966 3.4 Mk2
Date: Fri, 13 Sep 1996 11:20:21 +0200
Subject: Burlen Fuel Systems
[Ted Trim]
address.
From sometime next week I hope to have Burlen on the web. Their address
will then be http://www.jagweb.com/burlen/
Nick
Nick Johannessen // nick@sn.no // http://www.sn.no/~nick/
Adminstrator of the JagWeb and the Jag-lovers mailing-list
JagWeb - Jag-lovers web-site http://home.sn.no/home/nick/jaguar.html
JagWeb.com - Jaguar specialist web-site http://www.jagweb.com/
Check out the North Cape Challenge 1996 http://www.sn.no/~moydalus/
Date: Fri, 13 Sep 96 10:31:05 BST
Subject: Jag: Mk2 electrics - heated rear window
Fellow Jag-lovers,
I need to share my astonishment with some sympathetic folk…
Setting the scene: I have recently been refitting the instrument panels and
bulkhead wiring on my 1966 Mk2. This car, 170906, is a late Mk2 and incorp-
orates a number of 340 type features, but the wiring doesn’t match either
Mk2 or 340 diagrams - and the heated rear window doesn’t feature on either.
The window heater is operated by a push/pull switch at the right hand end of
the dashboard (rhd car); there is a small warning light by the switch. When
stripping the dash assembly I found a 6RA relay mounted at the lefthand end
of the bulkhead panel. (There is only one other relay on the car, which is
the horn relay in the engine bay fusebox assembly - neither relay is fitted
in early Mk2s). I assumed this second “mystery” relay controlled the hrw.
Now, I’ve got used to return wires being smaller gauge than feed wires on this
car (probably fits with the Lucas “smoke” theory!), but the sole purpose
of this relay appears to be to…control the hrw warning light, enabling it
only when the lights are on. Honestly. A heavy duty relay and several lengths
of wire for what seems an unnecessary purpose.
So is this how it’s meant to work? I always thought the bulb was just too
dim to see in daylight! Can anyone see any sense in this? Any owners of
similar era Jags got any insight (or better wiring diagrams)?
Cheers,
Ted
Date: Fri, 13 Sep 1996 12:40:13 +0100
Subject: Bonnet openning (NOT XJS air Damn!)
The bonnet on my XJ6 SIII as started to open when on the move. This
is a tad annoying and has now become serious as both sides now do it
occasionaly. The Fine Manual only mentions adjusting the release
cable and I can’t see any adjustment in the catch mechanism. Is
there any trick to this?
I’d hate to do what my father did - he put chrome, go faster, bonnet
pins on his series I. ACK!
Cosmo
83 XJ6 4.2
65 Mustang 289
Date: Fri, 13 Sep 1996 09:23:24 -0400
Subject: Oil Weight
Caution to all…
My TR6 blows a lot of oil. I decided to try Castrol Syntec 5w-50
(synthetic). It promtly blew almost ALL the oil out the pipes within 50
miles!
If your car uses oil through the exhaust I strongly recommend that you
don’t use synthetic multi-vis 5w-50.
Dave Ox.
73 XJ12
75 TR6
Date: Fri, 13 Sep 1996 08:11:18 -0500 (CDT)
Subject: Limited edition XK8 in Neiman’s
Anyone else read about the limited edition XK8 that is going to
be included within the famous Neiman Marcus Christmas catalog?
For our non-US readers, Neiman Marcus is one of the US’s premier
(read: usually very expensive, anything-goes) retail stores.
If memory serves me correctly, they plan to install birds-eye maple
as the wood treatment. I don’t recall any other significant changes.
Now, if Santa would just leave THAT in my garage…
Lance Hartmann (lance@io.com)
Date: Fri, 13 Sep 1996 14:42:45 PDT
Subject: Re: Bonnet openning (NOT XJS air Damn!)
This
do it
My SIII bonnet hinges were going rusty, such that it was
becoming difficult to open the bonnet without a lot of heaving on
the structure - a common failing apparently, but never mentioned
in ANY of the reports I have seen on an XJ6 (why? Do all the
hacks just rehash each other’s work? I digress.)
After a local garage had fixed the hinges, the bonnet shut and opened
with no trouble, but occassionally the rhs would pop open out of its
catch. Rather than taking it back, I noticed that the bonnet was not
catching properly when it was should, although it appeared to do so.
A final press in the offending area made sure the bonnet catched, and
stayed shut.
Cheers,
Dave Wood.
End of jag-lovers-digest V2 #353
id for jag-lovers-digest-out; Sat, 14 Sep 1996 00:44:07 +0200 (MET DST)
Date: Sat, 14 Sep 1996 00:44:07 +0200 (MET DST)
Message-Id: 199609132244.AAA27974@ekeberg.sn.no
Subject: jag-lovers-digest V2 #354
Precedence: bulk
jag-lovers-digest Saturday, 14 September 1996 Volume 02 : Number 354
re: air dam on XJ-S and E-Type air intake
XJ6 bonnet opening fix.
RE: XJ6 III Stake-down
E-type master cylinder reservoirs
RE:Bonnet opening(NOT XJS air Damn!)
Re: V12 Water Pump
Re: E-type tranny swaps
XJ6 SIII Brake master cylinder seals
Re: Limited edition XK8 in Neiman’s
Re: XJ6 III Stake-down
GM400 book for sale
[none]
70 E Tune Wire Wheels
Camshafts
TM8 - An additive from a major oil company
Date: Fri, 13 Sep 96 09:23:07 PDT
Subject: re: air dam on XJ-S and E-Type air intake
John
The E-Types do not have cowl air intakes.
Cheers Lauren
E-mail: lpratt@its.bldrdoc.gov
Date: 9/13/96
Time: 9:23:08 AM
This message was sent by Chameleon
Date: Fri, 13 Sep 1996 09:33:48 -0600 (MDT)
Subject: XJ6 bonnet opening fix.
Cosmo pleads…
{The bonnet on my XJ6 SIII as started to open when on the move. This
{is a tad annoying and has now become serious as both sides now do it
{occasionaly. The Fine Manual only mentions adjusting the release
{cable and I can’t see any adjustment in the catch mechanism. Is
{there any trick to this?
This was happening on the Daimler for a long time before I got around to
fixing it.
I loosened the pinch nut on the bonnet pin and turned the bonnet pin a
few turns to make it longer, then retightened the pinch nut. It was
really very simple. I did this to both sides of the bonnet and now it’s
stopped popping up. Previously, I had increased the spring tension on
the catch mechanism and it didn’t help at all.
Since I happened to have the ASCII graphic lying around from a previous
post, here’s what the bonnet pin looks like:
The assembled product: 2. The individual parts:
bonnet top
\ ####### / \ ####### / ← Sheetmetal U
*#######/ *#######/ channel
===== weld Nut weld
/// |~| <-bonnet pin (threaded)
-–/ ===== <-pinch nut
V =====
/—\ <-washer
/// <-spring over the pin
-–/ <-washer
V <-end of pin which engages
the striker plate
If somehow you mess up and can’t get the bonnet released (say the bonnet
release cable breaks), there are little access holes in each wheel well
thru which you can insert a slim screwdriver and manually release each
bonnet catch. Just to be on the safe side, I practiced opening the
bonnet this way a few times before I started messing around with the
catch mechanism.
Below are some further posts on the subject
/\ Lawrence Buja http://www.cgd.ucar.edu/cms/southern/
_][ southern@ncar.ucar.edu National Center for Atmospheric Research
________________Boulder,Colorado___80307-3000
On Wed, 29 Nov 1995, Aygen E. Dogar wrote:
Now my problem and it’s been a frustrating one as several people including
myself worked on it with no solution: … MY HOOD WILL POP OUT
UNEXPECTEDLY… ^^^^^^^^^^^^
Aygen,
Believe it or not, our car had the same problem. Boy, we messed
with adjustment, hood pin springs (even removing them at one point),
cable adjustment. etc… It would sure strike fear into occupants’ heads
when the hood jumps up 2 inches at 70 mph! On one trip of several
hundred miles duration, I got out and adjusted the inner headlights to
compensate for the always-up hood, so that we could see the road
adequately.
Ok I’ll quit with the stories and tell you what we did which
stopped the problem. I removed the striker plate assemblies and replaced
the plate retraction springs with ones of higher stiffness. I noted that
the coils of the old springs had begun to separate, indicating that the
original preload wound into the spring had been lost. All tension
springs have a wound-in preload during cold-forming which gives the
spring a non-zero initial takeup force.
Greg
Greg Meboe meboe@lestat.scs.wsu.edu
From: ** SHANE MANTOSZKO ** IBMA INVENTORY ANALYST **
*** Resending note of 11/29/95 21:14
*** SYDVM1(SHANEM) PH. (02) 354-4918 CUMBERLAND FOREST FC42
*** INTERNET ADDRESS - SHANEM@VNET.IBM.COM *****************
Subject: Hood(Bonnet) catch problems
UNEXPECTEDLY… This will happen usually if I hit a slight bump on the
road. First one side will come loose, then about 5-10 minutes of driving
Boy what a familiar problem. I went through exactly what you went
through here in Sydney. I took the car to the mighty rip-off artist
called Gary Walker Jaguar (only because he’s a few blocks from my house.
All you other Sydney Jag Lovers should avoid him like the plague…if
he was operating in America, he would have so many law suits that he’d
have to leave the country…any other Sydney-siders had experiences
with him they would like to share? I know this list tries to avoid
such things, but I think it’s important that people know who to avoid
when it comes to spending money on their jag…after all we’re not
all engineers/mechanics who can do all their own work).
Anyway, basically he had the car 3 times, and each time he said he
had it fixed, and lo and behold, you couldn’t drive 2 blocks without it
popping again. All the parts had been replaced, so what the hell was
going on !!!
I was so angry I could have killed these guys…anyway, I calmed down,
got the car home and had a good look at the latch. What I noticed, was
that the bolt sticking down from the bonnet on the problem side, was
not sticking out at the same angle as the bolt on the other side. Even
though both sides slid into the hole easily, it was just a fraction of an
inch out.
All I did was tap it a few times with a rubber mallet, to get it
parallel to the other pin. It closes just as easily now, but has not
popped in the 2 years since. Also, no damage to the pin or bonnet.
I had to tap it towards the back of the car. The more it
was tilted towards the front, the more the bonnet(hood) would pop.
Sure this may not be the problem with yours, but it sure was with
mine…amazing what a couple eighth’s of an inch can do in a jag…
Date: Fri, 13 Sep 96 09:30:28 PDT
Subject: RE: XJ6 III Stake-down
Kyle
Installing the stake down kit is fairly straight forward
but there is something that should be mentioned. The metal
in the head is about 1/4 inch thick where you will be
drilling and taping the holes. If you drill through this
1/4 inch you will dump a LOT of metal drillings in to the
oil return below. It’s very hard to remove these metal drillings,
so they will end up in the oil pan.
If you can stop drilling JUST BEFORE going through (requires
good luck and lots of skill for 6 holes) you may be able
to catch most of the drillings. This will also require using a
bottoming tap and cutting the bolts to length or shimming under
the bolt heads.
My recommendation; do it when the head is removed so it can
be properly cleaned.
Cheers and good luck Lauren
Date: 9/13/96
Time: 9:30:28 AM
Date: Fri, 13 Sep 1996 12:44:25 -0500
Subject: E-type master cylinder reservoirs
I’ve now beem twice bitten because of the service manual for my 64 Series 1
E-type. I had traced the brake fluid leakage to the bottom master cylinder
after having the center brake fluid reservoir go bone dry although the car
hadn’t been driven for three weeks. Page L.7 of the manual states that on
LHD cars, “the forward reservoir supplies the rear brakes, the rear
reservoir supplies the front brakes.” This lead me to believe lead that
“rear reservoir” meant the reservoir nearest the bulkhead (far right
reservoir when facing the three units). Indeed, the center reservoir’s
steel pipe can be traced to the bottom master cylinder. Today, I was
examining the schematic on Page L.24 and was surprised to see that the top
master cylinder serves the rear brakes and the bottom master cylinder
serves the front brakes. And since the bottom ms is leaking fluid from the
operating rod (I had to remove the rubber dust excluder to spot this) then
my stopping problem has been the front brakes and not the rears. And this
is reason that in my past missives I was fraught about having to drop the
rear suspension in order to overhaul the rear brake system. In a nutshell
am I correct now in my finding that: 1}the center brake fluid reservoir is
connected to the bottom (front brake) master cylinder and to remove this ms
I must first disconnect and remove the top (rear brake) master cylinder?
Date: Fri, 13 Sep 96 18:02:19 -0700
Subject: RE:Bonnet opening(NOT XJS air Damn!)
Dave Wood, wrote about the rhs of the bonnet occasionally popping open. I to
have had this problem especially when I first got my XJ6. My friendly Jaguar
speciallist helped me out by showing me the recognised method of closing the
bonnet. You stand to the front centre of the open bonnet and place the hand
on finger tips centrally on the bonnet, then push firmly so that the bonnet
shuts with a “clunk”. This ensures sufficient force within the flexing bonnet
to snap shut in the locks. If the bonnet pops up on one side NEVER push that
side back down as the bonnet can bend, always open and start closure afresh.
Try it out, I’ve had no trouble since adopting this technique.
Barrie Dawson
Chatham, Kent England
1985 series III Jaguar Sovereign
Date: Fri, 13 Sep 1996 12:06:00 -0400
Subject: Re: V12 Water Pump
Took a look at the water pump in the '88 and it too has the
countersunk phillips screw in one location. I had seen
a '89 V12 VDP that did not have this screw, just a standard
stud. I also took a look at the NEW waterpump that I just
got from a wrecker in Hamilton, Ont. (for $100 CDN ),
and does not have that hole countersunk…you got me on
the rhyme or reason for it, but I think it provides
marginally more room for the crankshaft pulley and the
alternator belt.
Also of note, the new waterpump has the double groove
pulley up front. Looking at the maintenance manual,
it seems that this pulley is required for cars
with an airpump, but no A/C compressor, thus Kirby’s
speculation that the double pulley was for pre '79 engines
may not be completely correct.
Subject: Re: E-type tranny swaps
Just a data point for the thread on the Moss box-to-synchro
box conversions. When I got my E-type, 1963 3.8l E-type,
it had a 1968 E-type 4.2l engine in it. It also had the
original generator, starter, flywheel, transmission (Moss
Box), and I think, clutch.
The 4.2l engine has a different flywheel, 132 teeth rather
than the 102 teeth (I think…I’ve forgotten the actual
number) for the 3.8l E-type motor. Thus, me thinks that
if you want to go the reverse route, you only need the
synchro box. The bolt pattern on the two bellhousings
are identical, except the 4.2l one has an extra bolt
right up at the top…I think. In the worst case, you
will need the 4.2l starter, flywheel, clutch and tranny.
Date: Fri, 13 Sep 1996 11:50:56 -0700
Jan wrote in reply to Bob:
This is not a good idea! E-Type rear brakes are inboard and you
definitely don’t want to crawl under the car with the car supported only
on a jack.
Definitely buy stands, just buy the sturdiest ones you can find in a
parts store. A floor jack is also a great investment, as you can roll it
around and lift the car to a considerable height. I got a very sturdy
one from Price Club for about $70 which is way better than the flimsy
ones sold in most parts stores.
I found the best way to raise the rear of the E-Type on a jack was with
a wooden block placed between the tail pipes onto the differential cage,
and the front with a wooden piece under the frame crossmember (not the
radiator crossmember!).
Cheers, Patrick.
1965 E-Type 4.2 Series I FHC.
PS
This morning I got off with a smile and a warning for doing twice the
speed limit, after he asked a question or two about my Jaguar. Yes, I am
going to drive more carefully from now on.
Date: Sat, 14 Sep 1996 03:14:22 +0000
Subject: XJ6 SIII Brake master cylinder seals
Hello all,
I’m going to replace the seals in my brake master cylinder tomorrow. I
have bought a kit which contains the various seals and other parts.
I was wondering if anyone has done this recently and if they have any
tips which might come in useful to save me making any stupid mistakes, or
ways of doing it that might be easier than suggested in the instructions.
Its just that I have memories of doing things like this before and
getting 90 per cent of the way through the job and then finding I have
done something wrong at the beginning and have to start all over again
(I’m sure you all know what I mean!).
Thanks in advance.
Pete Hamel
London UK
Date: Fri, 13 Sep 1996 16:09:55 -0400
Subject: Re: Limited edition XK8 in Neiman’s
(read: usually very expensive, anything-goes) retail stores.If memory serves me correctly, they plan to install birds-eye maple
as the wood treatment. I don’t recall any other significant changes.Now, if Santa would just leave THAT in my garage…
News to me that we’re doing limited editions for posh shops and I build the
thing We’re working flat out just to get stock cars out to dealers for the
October launch.
I have had the chance to drive the 8 around the plant and I can tell you its
like no other Jag we have built. It goes faster than the Supercharged X300,
the road holding is liken to a snail and the growl from the lump gets the old
blood pumping. Open your cheque books NOW
Terry Fairbrother
Date: Fri, 13 Sep 96 14:10:22 PDT
Subject: Re: XJ6 III Stake-down
LEAMYS wrote:
<couldn 't you magnitize the drill bit and drill at low speed removing
<the
<drill constanly and cleaning the bit or in aluminum use somthing sticky
<i.e.
<90 weight to catch the fillings
Good idea.
This might be a solution, but I would suggest using bees wax
or taping wax (they are sticker), and plug and tape all other
openings. The head is aluminum, so a magnet will not work.
Cheers Lauren
Date: 9/13/96
Time: 2:10:22 PM
From: Patrick Krejcik pkr%SLAC.Stanford.EDU@vm1.cc.nps.navy.mil
about lifting E-types, Patrick tells us;
<and the front with a wooden piece under the frame crossmember (not the
<radiator crossmember!).
Yes, some have gone as far as to fasten a piece of wood, about 14 inches by
3/4 inch by 1 inch to the underside of the crossmember. It will fit snugly
with the 3/4 inch side front to rear, then tie it in place.
LLoyd - perhaps use burlwood walnut for concorse applications…-
Date: Thu, 12 Sep 1996 17:53:04 GMT
Subject: GM400 book for sale
As a result of a mix-up at a mail order book shop I have wound up with
two copies of Ron Session’s “How to work with and modify the Turbo-
Hydramatic 400 Transmission”, ISBN 0-87938-267-8.
One is for sale, condition as new (obviously).
First offer over GBP10 + shipping secures.
Stefan Schulz
jaguar@suaviter.demon.co.uk
Date: Fri, 13 Sep 96 10:27:35 +0100
Subject: [none]
HELP !
I have an 88 3.6 XJ-S, and it is not a happy bunny at the moment.
The symptoms are 4 blown hoses in the last 2 weeks, the last
resulting in a near boil-up.
Whilst pressure testing (after hose replaced again), the header
tank started springing leaks. This is the present situation, with a
header tank on order. The system was eventually succesfully pressure
tested (twice), and resulted OK.
There is, however, a sediment in the water which has been present for
the last 5 or 6 weeks, that looks not dissimilar to McDonalds
Chocolate milk shake.
This made me suspect the head gasket, but no other symptoms of
this are present :- NEVER misses, no steam/water from exhausts, no
water in oil.
All the hoses are pretty old (about 75000 miles), and so I am now
in the process of replacing EVERY hose, and the header, to cut out
any weak spots.
Hopefully, ( ;} ), this will cure things, and I can put the sediment
down to perhaps some oil being shot across the head gasket very
briefly, before resealing.
A friend suggested that perhaps some auto transmission oil may be
gettin ginto the radiator and causing the sediment - thereby blocking
the radiator, and causing the pressurisation - I have back-flushed
the radiator just in case.
Sorry to drone on, but I wanted to add as much info as possible.
Does anyone have any experience of this situation, as I am at
present a man possessed (obsessed) (depressed ??)
cheers in advance,
The_Tiger < bb@eagpde.co.uk >
Date: Fri, 13 Sep 1996 14:29:17 -0700
Subject: 70 E Tune Wire Wheels
I’ve not owned a car with wire wheels prior to the Jag (my 71 MG had steel
wheels) and am seeking advice regarding wires.
How often do they need to be “tuned” and are there any tell tale signs that
they are due?
Roads here in Northern California are in fairly good shape with regard to
pot holes, etc.
Thanks in advance
Stephen Patchel
Consulting Practice Leader
Radford Associates
voice: 408-321-2540
fax: 408-321-2650
Date: Fri, 13 Sep 1996 14:55:56 -0700
Subject: Camshafts
Does anyone have any camshafts for the following motors. Later XJS, XJ6
Series 3 or XJ40. I’m planning on making some special tools, damaged
lobes are ok.
Thanks
Michael P. Neal ASE Master Technician, Jaguar Certified
'93 Ducati 900SS '83 Porsche 944 '85 Jaguar XJS
Home (707) 829-8464 Work (707) 577-0101
http://www.wco.com/~mneal (always under construction:-)
Date: Fri, 13 Sep 1996 15:17:35 -0700
Lance wrote…
Anyone else read about the limited edition XK8 that is going >
to be included within the famous Neiman Marcus Christmas >
catalog?
Don’t you mean Needless Markup???
Date: Fri, 13 Sep 1996 17:38:21 -0500
Subject: TM8 - An additive from a major oil company
If you haven’t noticed, there is another additive. This one is from =
Valvoline and you can read the “information” made available at their =
site www.valvoline.com. I wrote for more information and was =
disappointed. I asked for documentation regarding the research report =
referenced, “scientific evidence in laboratory experiments and in a =
variety of engines.” What I got was a phone number (1-800-TEAM-VAL) and =
instructions to discuss Valvoline products with one of the technicians. =
Anyone care to do so? Sounds like the usual pitch to me.
End of jag-lovers-digest V2 #354
id for jag-lovers-digest-out; Sun, 15 Sep 1996 05:40:53 +0200 (MET DST)
Date: Sun, 15 Sep 1996 05:40:53 +0200 (MET DST)
Message-Id: 199609150340.FAA01383@ekeberg.sn.no
Subject: jag-lovers-digest V2 #355
Precedence: bulk
jag-lovers-digest Sunday, 15 September 1996 Volume 02 : Number 355
Re: your mail
New York/New Jersey/Pennsylvania/New Englad (USA) Jag Events
Re: Jag: Mk2 electrics - heated rear window
Jag V12 Firing Orders
Re:
Sediment in cooling system
Re: Jag V12 Firing Orders
[JagWeb] Update 14th September
Re: [JagWeb] Update 14th September
E-type ramps and bleed kit
Re .Bonnet/Hood catch -all syncro g/box
'85 SIII Radio/Tape Player For sale
XJ-S Book Update
Date: Fri, 13 Sep 1996 19:42:58 -0400 (EDT)
Oops. A Jag faux pas.
Don’t you add cowl vents when the Chevy motors go in???
John
On Fri, 13 Sep 1996, Lauren E. Pratt wrote:
John
Cheers Lauren
Date: Fri, 13 Sep 1996 20:01:23 -0400 (EDT)
Subject: Re: your mail
I have had this problem once or twice on non-Jags, but cars with alloy
engines. If you find the gunk in the water but the engine oil is OK, then
you have someplace in the engine where engine oil under pressure finds its
way into the coolant.
This persisted on one car for ten years and over 175,000 miles. No amount
of flushing solved the problem (would come right back) and there was never
any reverse infiltration into the oil (engine was never apart, so I never
found the cause. Never knocked, blew a head gasket or burnt oil. Never
overheated or lost coolant, either.).
So, unless others know of specific dangers inherent in the Jag, I’d ignore
it and feel good about all that extra water pump lubrication!
John
On Fri, 13 Sep 1996, The_Tiger wrote:
HELP !
water in oil.
Date: Fri, 13 Sep 1996 20:05:54 -0400
But there is really no need to raise the front in order to bleed the brakes!!!
Mike Frank
<radiator crossmember!).Yes, some have gone as far as to fasten a piece of wood, about 14 inches by
Date: Fri, 13 Sep 1996 20:48:12 -0400
Subject: New York/New Jersey/Pennsylvania/New Englad (USA) Jag Events
New Jersey Jaguar Touring Club (my affiliation) event highlights (Membership
Chairman is Jacqueline Maetsky, 201-935-3431):
September 28-29. Excursion to Steamtown, USA in Reading, Penn. This is a
huge museum devoted to steam locomotives. It is the home of a Union-Pacific
Big Boy, the world’s largest locomotive. Sunday the tour continues with a
stop at the Lackawanna Coal Mine and Anthracite Museum. Club event Saturday
evening. Contact Chris Acker 717 278-4159
October 20. Fall foliage tour. Includes tour of the Charles Lindbergh
cottage. (Site of the famous kidnapping) Contact is John and Jane Jennings
201-894-0091.
Unaffiliated events:
September 20-22 British Invasion Stowe, Vermont 860-029-6176
September 22 British Car and Bike show sponsored by Mid-Penn British
Marques. Allenby Playhouse, Boiling Springs, PA 717 469-1034
email:britishmom@aol.com
September 22 British MADDness Car Show. Bethlehem, CT 203-776-8148
September 28. Car show at Special Interest Car Parts. 1340 Hartford Ave
(route 6a) Johnston, Rhode Island 800 556-7496 x 3002 15% discount on all
SIPC parts purchased at the show.
September 29 Jaguar Assn of New England Hill-Stead Museum tour & lunch
Farmington, CT 860-928-9786
October 6 Jaguar Club of CT annual show. Litchfield Inn 203-776-8148
Oct 18-20 Bridgehampton, NY Historical Society sports car rallye.
516-352-7311 x115
October 20 Goshen, NY. Red Ribbon car show & family day. Pre registration
required 914-651-6100
October 27 British Cars of New England Hartford, CT
Mike Frank
1969 E-Type 2+2
Date: Sat, 14 Sep 1996 12:40:59 -0700
Subject: Re: Jag: Mk2 electrics - heated rear window
Ted
I tried to e-mail direct but got a delivery error so I am posting to the
whole group.
The Daimler V8 250 utilised the same body shell as the MKII but
incorporated a heated rear windscreen.
I can fax you the wiring diagram from my manual to see if it matches, if
you are interested.
Shane Gibson
1968 Daimler V8 250 (55% complete, 167% over budget)
Date: Fri, 13 Sep 1996 21:18:34 -0400 (EDT)
Subject: Jag V12 Firing Orders
Last July, when in Denver on a business trip, I had the pleasure to have
dinner with the Bujas and John Himes, et at – local Jag people all.
One of our dinner conversations dealt with the issue of the firing order
of the Jag V12, and if it was the same as some Ferrari V12s, and if not
was this a reason why they don’t seem to sound the same.
John Himes dug out his service manual and with help from the Bujas we
determined that the firing order of the Jag V12 works out as follows:
Right Bank: 1 5 3 6 2 4
Left Bank: 6 2 4 1 5 3
in other words, the right bank is firing a standard inline 6 firing order,
and the left bank interpserses with the same firing order, but with the
rear three cylinders swapped with the front three.
(Zigzag down and up the above illustration as you scan left to right.
The front of the engine would be on the left.)
I finally found some reference material on one of the best-sounding
Ferrari V12s, the 330 series from the late sixties. I think this is a
Colombo engine.
The Ferrari firing order is:
Right bank: 1 5 3 6 2 4
Left Bank: 7 11 9 12 8 10
but Ferrari numbers their cylinders down one bank and up the
other, beginning at the right front. In other words, the #1 cylinder is
right front and the #12 cylinder is left front.
So the firing orders are the same. Differences in the exhaust sound
must arise from the mufflers and pipes used.
Now before some of you flame me for wanting a Jag that sounds like a
Ferrari, let me just say that to me there is nothing sweeter than the
sound of a twelve. And I want to hear every 12 sing.
John
Date: Fri, 13 Sep 1996 21:13:11 -0500 (CDT)
@owner-jag-lovers-di1 writes:
Subject: Re: Limited edition XK8 in Neiman’sAnyone else read about the limited edition XK8 that is going to
[STUFF DELETED]News to me that we’re doing limited editions for posh shops and I build the
October launch.
I found the article dated Sep. 9, 1996 regarding the special XK8
on Jaguar’s “offical” website:
http://www.jaguarvehicles.com/news/neiman.html
Date: Fri, 13 Sep 1996 20:55:49 -0700
Subject: Re:
STOP!!! Don’t drive your car!!! This sounds like the power steering
cooler in the right side of the radiator or the trans cooler in the left
side is blown. You are getting extreme pressure in your cooling system
that could blow the head gasket, heater core etc… and cause serious
problems. I had a restriction in the return line to the power steering
reservoir that blew the cooler and pressurized the system to over 100
PSI. Needless to say the potential destruction was rather fascinating.
BTW, the customer got cheap and just had me disconnect the power
steering cooler. I would not do this on the trans cooler, it would
shorten the life of the trans. An aftermarket cooler would probably do
and just plug the radiator.
The_Tiger wrote:
HELP !
resulting in a near boil-up.Whilst pressure testing (after hose replaced again), the header
water in oil.All the hoses are pretty old (about 75000 miles), and so I am now
any weak spots.Hopefully, ( ;} ), this will cure things, and I can put the sediment
briefly, before resealing.A friend suggested that perhaps some auto transmission oil may be
the radiator just in case.Sorry to drone on, but I wanted to add as much info as possible.
present a man possessed (obsessed) (depressed ??)cheers in advance,
Date: Fri, 13 Sep 1996 23:30:58 GMT
Subject: Sediment in cooling system
In message 9609130927.AA03525@eeyore.eagpde.co.uk The_Tiger writes:
88 3.6 XJ-S
[snip]
[snip]
If it’s really water in the cooling system, then that’s half your problem,
and the other half is the brown stuff. RUST.
Get some Barr’s FLUSH, fill up the cooling system with the
prescribed water/antifreeze mixture, add the flusher, and run the car nor-
mally for a week. (Ignore what the label says about 48 hours tops.) Then
flush the system again and fill with water/antifreeze again. Oh yes,
avoid Barr’s Leaks when you refill the system - never mind what Jaguar say.
Worked for me 2 years ago with a freshly-bought badly maintained V12 and
just did it again with wifey’s new 13-year-old Volvo.
If flushing doesn’t do the trick, do component elimination testing throughout
the cooling system ;-(
Stefan Schulz
Date: Sat, 14 Sep 1996 09:43:10 -0400
Hi again,
Just been to the above site to see what this limited edition is based on.
Working on the line we see specs for different markets. The Neiman LE is
similar in spec to the Japanese market.
Still a damn nice car to drive
Tez
Date: Sat, 14 Sep 1996 13:59:25 -0005
Subject: Re: Jag V12 Firing Orders
Napoli:
I have heard a consistent rumor that the late 50’s/early 60’s Ferrari
V-12’s (which have a truly excellent sound) have a 65-degree V. This
makes absolutely no sense, and I would pass it off as a misprint
except that I have heard it from several sources. The logical layout
of a V-12 is a 60-degree V, as in the Jaguar.
If the Ferrari in fact has a 65-degree layout, there would follow
another question. Does the crankshaft have a 5-degree step between
adjacent big ends on the same crank throw? Because if it doesn’t,
then the engine would have a slightly uneven fire – fire, 55 deg,
fire, 65 deg, fire, 55 deg, and so on. Might have an interesting
effect on its sound. Would not affect balance, since each half of a
V-12 – as two separate inline sixes – is balanced, you can put 'em
together any way you want they will still be balanced even though the
firing is uneven.
| - Palm’s Postulate
Date: Sat, 14 Sep 1996 19:49:11 +0200
Subject: [JagWeb] Update 14th September
Well, I finally got my act together and have now
officially released the new-look JagWeb. The search
engine Excite commented in their review of the site
that the only thing missing was the burled walnut on
the front-page. This has now been taken care of.
Not only a new look, some nice new material as well:
- Jim Isbells “XJ6 - Bumper to bumper”
A book written by Jim based on his experience and
messages from Jag-lovers. A downloadable Word 2
document for you to print out at work^h^h^h^hhome.
- The Monster.guide to Jaguar - The E-type chapter!
Lawrence Buja has massaged together another chapter
in the definitive guide to Jaguars. This time it’s
E-types (XKE), with lots of valuable knowledge and
anecdotes from owners.
- How to buy a Jaguar
Another look at buying a Jaguar, this time by Gunnar
Helliesen. A good read.
- The tappet guy
Gunnar Helliesens holiday saga. Experience the thrill
of the tapping tappets in full glorious webOrama.
- The tappet guy
- The archives are now as up to date as they can be. I
upload in batches of 30. Need another 5 before the
next batch goes up. Please note: there archives are no
longer available by FTP. Web only.
Thats all for now. Thanks. And remember, if you have
something you’d like to share with the rest of the
Jag-lovers, let me know. If you have submitted something
and wonder where the hell it’s got to, send me a nasty
mail. Please do, I don’t like to disappoint people.
Nick
<<< Nick Johannessen | nick@sn.no | nickj on IRC >>>
<<< Jaguar XJ6 4.2 '70 MOD & '82 Auto >>>
The JagWeb http://www.sn.no/~nick/jaguar.html <<<
Date: Sat, 14 Sep 1996 12:33:04 -0700
Subject: Re: [JagWeb] Update 14th September
Nick:
Just checked out the article on E-Types. Nice work!!!
I appreciate the time and effort you devoted to the JagWeb, its been
especially helpful to me in locating resources for my 70 E-Type.
Regards
Stephen Patchel
Radford Associates
voice: 408-321-2540
fax: 408-321-2650
Date: Sat, 14 Sep 1996 21:46:57 +0200
[ Steve Patchel spatchel@radford.com ]
Thank Lawrence Buja for the brain-work, I just did the
donkey-work of putting it into HTML
We aim to please.
Nick
Nick Johannessen // nick@sn.no // http://www.sn.no/home/nick/
Date: Sat, 14 Sep 1996 18:21:22 -0500
Subject: E-type ramps and bleed kit
One thing I have always admired the British for is they know how to even up
a score. The outcome of the U.S. revolution would have to smart a bit. So
how did they eventually even up the score (and remember, they gave it back
to Adoph in spades)? First, they introduced the XK120 to we wild-eyed Yanks
and made the do-it-yourself crowd add Whitworth spanners and such to their
toolkits. And they made us more profane as we scraped knuckles in such tiny
hiding places for clevis pins and such. But they didn’t quit there.
Along came the irresistible E-types and more tiny places that hold
operating rods and locknuts and, yes, those dratted clevis pins. I’ve just
spent six times as many hours as would a professional mechanic in
disconnecting just one of two master cylinders. A 8/16 open end was a hair
too large and a 7/16 wouldn’t cut it at all. The service manual devotes
three short paragraphs to this “mundane” task and I still have one master
cylinder, lock nuts that haven’t been freed since 1978 and a tiny clevis
pin that I can see, sort of, but will surrender only to the nimble fingers
of a Rhesus monkey.
The point of all this is, that I don’t have to have my E-type sitting
outside some mechanic’s shack for weeks on end waiting for a master
cylinder to be resleeved (in stainless steel, naturally). In this small
town with 18,000 college students staggering down streets and alleys at all
hours, a lone E-type could be the object of the revenge of a “have not.”
I priced jack stands for the bleed job that will follow (I also want to do
all of the necessary under-body maintenance chores) and a professinal
hydraulic floor jack one can roll in and out. Well, the jack alone costs
$260. And most car jacks can’t lift the car high enough for one to place
the jack stands.
The young man at my parts store came up with a brilliant money-saving idea!
He sold me a set of Ultra-Ramps and a Napa “One-Man” brake bleeding kit.
The ramps cost $21 and are rated at 6,500 pounds Gross Vehicle Weight. The
ramps are 7.5 inches in height and this, (plus the distance of half a tire
height) allows one safe access the rear brake bleed nipples, differential
housing, lube points,tranny and such. I can’t vouch for the one-man
bleeding kit, but it has a device that prevents air bubbles from being
drawn back into the wheel cylinder. The kit is $10. The Ultra-Ramps
wouldn’t be practical for doing major underbody work, but should prove
useful for oil changes and lube jobs, etc.
Date: Sat, 14 Sep 1996 07:56:19 -0600
Subject: Re .Bonnet/Hood catch -all syncro g/box
Regards, Mark Roberts Phone: (613) 763-2924
Ottawa, Ontario, CANADA Fax: (613) 763-3970
1988 VDP - SIII V12 email: markdr@nortel.ca
1963 3.8L E-Type Coupe - 15 years into a 3 year project
I did this conversion on a Mk 2 and if I remember rightly the all
syncro box has a bigger front bearing,requiring machining the recess in
the original bell housing.
Also don’t own an XJ but have fiddled with the bonnet catch,the best
people to adjust them (my experience anyway) is your local friendly
panel beater, as they do it all the time,as its a standard type bonnet
lock .If you think its a problem with them coming loose ,if they stick
down it’s real fun getting them to release.Someone told me that there is
a hole in the inner guard to get at the release ,but haven’t checked.
Don Tracey
AUSTRALIA
50 Mk5,58 XK150,59 Mk2
Date: Sun, 15 Sep 1996 02:49:56 GMT
Subject: '85 SIII Radio/Tape Player For sale
I have an '85 SIII radio/tape player for sale. It is in excellent
condition, but two LED segments are not working, so sometimes it is
difficult to tell the exact station. Otherwise perect. Includes radio/tape
player, face plate and detachable face control panel.
All wiring is in place, but you’ll need new connectors to fit radio wire
harness to car harness. Simple single connectors will do though.
I will have to check wholesale prices from Welsh, Terry’s, etc. to
determine fair asking price. I will do so Monday.
If interested, please e-mail.
Larry Karpman
Bedford, TX
Date: Sat, 14 Sep 1996 23:39:21 -0005
Subject: XJ-S Book Update
I have just posted a new version of the XJ-S help book. I’ve been
adding stuff like crazy over the past few days, mainly putting in a
lot of input from jag-lovers e-mail that I’d just been saving until I
got around to it.
Flyer follows:
EXPERIENCE IN A BOOK:
Help for the Jaguar XJ-S owner
by Kirby Palm
This book contains things that a Jaguar XJ-S owner should know, but
doesn’t know who to ask. Owners of other late model Jaguars may also
benefit, as much of the cars are similar. This book is over 100
pages, and includes a few illustrations.
Sections of the book address:
Maintenance and repair
Performance modifications
Sources for parts, accessories, etc.
Generally, the book offers practical knowhow not found in the
official repair manuals, and should be considered a supplement
rather than a substitute.
There are several ways to obtain this book. To receive the very
latest version printed out, send US$15 to the author (below). To
receive a diskette of the latest MicroSoft Word file so you can
print your own copies, send US$7. Add US$1 for Canada, US$2 for
other countries outside the US. Be sure to give your name and
address.
For InterNet users, the archived file is also available (free of
charge) via the World Wide Web page:
http://gcn.scri.fsu.edu/~palmk/jaguar.html
This book is corrected and updated constantly. If you have learned
Kirby Palm
Route 1, Box 3498
Havana, FL 32333-9762
(904) 539-7775
InterNet: palmk@gcn.scri.fsu.edu
| - Palm’s Postulate
End of jag-lovers-digest V2 #355
id for jag-lovers-digest-out; Sun, 15 Sep 1996 22:41:25 +0200 (MET DST)
Date: Sun, 15 Sep 1996 22:41:25 +0200 (MET DST)
Message-Id: 199609152041.WAA03278@ekeberg.sn.no
Subject: jag-lovers-digest V2 #356
Precedence: bulk
jag-lovers-digest Sunday, 15 September 1996 Volume 02 : Number 356
XKE Valve adjustment
XJ40: Headlamps $$$ ?
re: One-man E-type brake bleed
Mark 2 Paint Colors
re: cowl inlets on E-types; and louvers on XJs
Re: E-type ramps and bleed kit
Series 3, XJ6, Starter motor.
S3 and XJ40 queries
Re: seeking advice on my old flame
XJ6 S2 4.2 rebuil, leaks oil + headgasket question
Re: Koni - standard shockabsorbers
Re: Series 3, XJ6, Starting problem
Re: Series 3, XJ6, Starter motor.
Re: Vehicle Dynamics
xj40 shop manual
Date: Sat, 14 Sep 1996 23:41:40 -0400
Subject: XKE Valve adjustment
I am trying to get an accurate valve lash measurement with the engine
assembled. Can one cam be rotated 360 degrees if the other is removed ? [
Will the valves hit the pistons ? ]
Date: Sat, 14 Sep 1996 20:38:56 -0700
Subject: XJ40: Headlamps $$$ ?
for a XJ40 (The two flat-square type) and the bulb controllers that go
with them.
I was looking to switch the headlamps from my '89 VDP to the newer
square headlamps. But, for approx. $1500 new, I would have to be crazy
to spend this to replace my round lights (which are in execellent
condition).
I was hopeing someone would know of a good junk-yard, or place to
obtain these lights at a “reasonable” cost. Most places won’t sell
ONLY the headlamps, just the complete front end of the car. Maybe
there is someone or somewhere that trades these lights, I would only
need one pair of headlamps.
Thanks for any input or help!
-cobac@ix.netcom.com
1989 XJ40 Vanden Plas
Date: Sat, 14 Sep 1996 23:51:37 -0400 (EDT)
Interesting idea. Too my knowledge, though, the Ferrari V12s were all 60
degrees. So I went to the bookshelf.
All of the COlumbo and Lampredi V12s were 60 degrees (of course, that
might not eliminate the possibility of some one-off specials, which
Ferrari was always likely to do).
However, between 1958 and 1964 there was a Type 206S V6 car that ranged
from 1 and a half to two liters. It had a 65 degree block. In two liter
form it produced 220 HP at 8500 rpm. Now THAT must have sounded wild!
John
On Sat, 14 Sep 1996, Kirbert wrote:
Napoli:
was this a reason why they don’t seem to sound the same.I have heard a consistent rumor that the late 50’s/early 60’s Ferrari
of a V-12 is a 60-degree V, as in the Jaguar.If the Ferrari in fact has a 65-degree layout, there would follow
firing is uneven.– Kirbert | If anything is to be accomplished,
| - Palm’s Postulate
From: David J Shield David_J_Shield@ccm.fm.intel.com
Date: Sat, 14 Sep 96 21:33:00 PDT
Subject: re: One-man E-type brake bleed
Bob,
One more thing to add on top of Jan's (and any oine else's) advice:
Get a jar that won't tip over. Usually the long transparent hose is
heavy enough, esp. when filled with brake fluid, that it knocks the
damn jar over. Or else pulls out of the jar since it's too heavy and
slick. What a mess. Glue the jar down to a big piece of wood if you
need to.
While I'm at it, I've never used a Mitey Vac for brake bleeding,
though I do own one (~$35 USD). Can anyone vouch for this method?
Also, in some old issue of Jaguar World, a writer mentioned installed
bleeder extenders on the rear calipers. Has anyone else done this,
and where can I buy a set?
One answer and two questions. Guess this helps?
'70XKE 2+2 and a
'84 XJ6 VDP currently on the trickle charger due to not enough use
Date: Sun, 15 Sep 1996 01:16:40 -0400
Subject: Mark 2 Paint Colors
I am having a 62 MK2 painted and am having trouble matching colors with
code numbers. If anyone can provide me with a list of colors and some
form of paint code I would greatly appreciate it. The colors I am most
interested in are: Cotswold Blue, Opalescent Blue, Opalescent Gunmetal,
and Opalescent Silver Blue.
Thank You
Fred Phelps
Date: Sat, 14 Sep 96 23:51:00 PDT
Subject: re: cowl inlets on E-types; and louvers on XJs
John,
There aren't any cowl inlets on an E. Fresh air comes from the front
and is channeled to the heater box. Thus the louvers are not a
problem, and they look nice.
I often thought of hood louvers on my XJ6 until someone on the list
mentioned that the heat would flow right back into the cowl inlets.
Jim Isbell reports that his engine runs a few degrees cooler with the
bonnet popped open and resting on the safety catch, wonder what that
does in terms of heat flowing back into the cowl? This can be
measured - put a thermoprobe in various cowl inlet positions and
measure it with and without the bonnet popped. I'd do this if I had a
thermoprobe.
Is there any other way to vent the engine compartment to get that heat
out of there, esp with the catalyst under the hood (bonnet)? Side
louvers? (Maybe too ugly.) Wheel well louvers? (Maybe would weaken
the shock tower.)
snip from John Napoli:
>I still like the idea of hood louvers. Any of you E-Type guys have
>problems sucking hot air into the cowl inlets? My guess is that the
>flow is turbulent enough and so small compared to the mass of ambient
>air and what about the hot heater matrix in there anyway and besides
>we waste some of the cool chilling gasoline and it still works so it
>should not be a problem.
>John
Date: Sun, 15 Sep 1996 02:52:12 -0500
Subject: Re: E-type ramps and bleed kit
Sorry, no Rhesus monkeys available, all are still receiving psycho therapy
after 10-20 years of assembling Minis in the 60s and 70s.!
Date: Sun, 15 Sep 1996 04:16:14 EDT
Subject: Series 3, XJ6, Starter motor.
Hi all
A few different things to report: First the tale of woe (but it has a
happy ending )
On Friday night the better half and I went out to dinner, afterwards we
got into the Sovereignto head home,when thekey was turned all I got was
a click. Hmm…hit the lights yep, plenty of power, tried a few times,
still nothing but a click. Popped the bonnet,nothing loose as far as I
could see. Maybe it’s the little switch that stops you starting it when
the transmission is in drive- put it in and out of gear pushed it up and
down etc - no luck. Ah well, call the NRMA (Aussie version of AA or RAC),
an hour later the roadside assistance van turns up. I tell him what
happened and what I’ve tried and I go to show him by turning the key…
and the damned thing fires !!! Aaarrgh. Face very red !!! I drive
home uneventfully. It’s friday the 13th …just one of those things huh?
Sat. morning starts OK we go into town for Yum Cha, we get back it does
it again - I fiddle around for 10 minutes, just about ready to give up
when it fires - still haven’t figured out the cause - we have to go to
one of my wife’s friends place (no choice - at this point I’d have gone
and started serious trouble shooting otherwise). We get there do the
business and try to leave - same thing- aaarrgh !!! Nrma turn up quickly
- he grabs a screwdiver and a small hammer and givesthe starter motor
a tap while I hit the key - goes first hit !!! Sticky solenoid he says,
sounds logical to me on the facts. Looks like my first real Jaguar
maintenance job is going to be a starter motor replacement. Go up the
road to buy the Jag service manual I’ve been meaning to buy for the last
month ($110 AUD - approx $85 USD- is that a reasonable price ? ).
Ring up Jan W on the grounds that he knows what he’s talking about and
I don’t …and he’s been patient with all my other stupid questions !!
Solenoid sounds right …
I then do a search of jag lovers digest and come up with an interesting
post :
On my S2 XJ12, I had exactly the problem you describe and found that
it was due to the heavy white+red wire having a slack female spade
connector on
it that made bad contact with the spade on the relay. I tightened this
connector up with a pair of pliers and haven’t had any trouble since
This was a reply to a slightly different problem but what the hell, I’m
lazy, I’ll try the easy fix first.
So I sprayed INOX on the spades and connectors, tightened the females,
plugged them back onto the starter relay and what do you know, the damn
thing worked!!! INOX is basically WD40 with an anti corrosion agent.
I’ve started it 10 times today and it’s worked every time so hopefully
that’s fixed it.
Hey Jan, that’s your post I just quoted - you could have suggested that
one first
BARRS Leaks:
There’s been an on again off again thread about Barrs Leaks, I think I’ve
already commented that the Series 3 XJ6 Sovereign manual DEFINITELY
doesn’t mention it at all. On the other hand having just bought the
shop manual (thats the official one not the Haynes) I noticed in passing
that it DOES mention the stuff: Page 09-2 (09 is the recommended lubrican
ts etc.) states
additiveBarrs Leak Inhibitor 1 sachet per car - 6 cylinder model
2 sachets per car - 12cylinder model.
I personally still wouldn’t use the stuff unless someone can give me a
convincing argument why I should, but there you go, Jaguar does endorse
its use.
John
Level 1, 29-57 Christie St.
St Leonards NSW 2065
Ph: +61-2-9937-8063 Fax: +61-2-9937-8100
Mobile +61-419-617-619
Date: Sun, 15 Sep 1996 04:55:03 EDT
Subject: S3 and XJ40 queries
*** Resending note of 15/09/96 18:51
Hi all
Following fiddling with the starter relay (see prev post), I’ve noticed
there are 3 pins without spade connectors (out of about 8) does anyone
know if this is correct ? Everything seems to work OK but it worries me…
The manual doesn’t even have a picture let alone a description of the
pin outs. Which follows to the next questiondoes anyone know a good
supplementary manual ?
Last question, someone posted something about converting a round
headlighted XJ40 to square (a week or 2 ago) Ithought XJ40’s only came in
square headlighted models ? Can somebody fill me in on this please ?
John
Date: 15 Sep 96 06:56:28 EDT
Subject: Re: seeking advice on my old flame
Hi, JH Ferell,
What a shame to hit a pole . 1.5 feet !!! into to engine compartment…
It is always easy to be better knowing afterwards , but I presume the car was
not all risk insured ?.
There is always a risk when not fully insured, and I guess we decide to
take the pounding and grief if it happens anyhow.
If you are short of cash to actually let her repair, now that you have decided
for a sister of hers,
then you have already made the decision or not?
Never mind what “freinds” say. If they only say you’re crazy seen from a
financial point of view then they
have not understood the point of real (jaguar) love. In that case they cannot
help you - they have no reference point to judge from. If it is real love to the
car, it doesn’t matter whether the 9000 bucks are a
financially bad investment. The issue is not about investment but about the
feelings you have for that car.
If you can’t repair her yourself for whatever reason, then there is only few
solution’s. Either store her - but she will slowly die then, or sell her to
someone who will repair her in his/hers free time - this way you know she will
be going to a good home. Selling her to the schredders is downright heresy !.
Other solution is to let her slowly raise from her badly injured state to the
grace she once had by a person who restores her over say a year or two in
his/her free time. May cost 9000$ anyway but so what ? allways better to have it
done by a person with skill and natural love than the local run of the mill
crash-repair shop.
Do you feel alright going Golfing in Scotland while your torn beaty cries for
help ?
Hope you find the right solution for you.
Regards Jeffrey Gram
Date: 15 Sep 96 06:56:17 EDT
Subject: XJ6 S2 4.2 rebuil, leaks oil + headgasket question
Hi list,
The 4.2 litre I had rebuilt iun 1995, now with 3600 Km on the clock has a
“minor” oil leak. When I think
about the only reason for taking the engine out in the first place during body
rebuild, was to put a stop
to oil leaks…
Rebuild background :
The engine has new sump seal,new oil pump , and new pick up pipe seals, new rear
crankshaft seal, new
front crank seal, new timing chain cober seal, new camshaft cover seals. The
rebuild was honing (only 70.000 km) , new piston rings, new bigends and main
bearings and toughrided crank. The valve seats were reground, all new valves (S3
head), valve stem seals, and 308 degree cams with 10.75 mm lift. gap adjusted to
0.20 mm +/- 0.05
The things not done were : bore and new pistons, new valve stem guides, tappet
bucket guides and tappet buckets. These were not necessary according to the
engine restorer. However after just few hundred kilometers a tappet guide
started “clicking” . Installed a tappet guide stake down kit to solve that
problem. However there remains strange single metallic clicks in idle still. I
guess the valve stems are loose now ? or a seat maybe ? - I wish I had gone for
the complete tour… How expensive it is to save
money…
The Oil leak. First I used Hylomar and no gasket to seal the cam covers. Big
mistake - Credit to Michael Neal. Hylomar cannot be used to seal metal to metal
parts. I used another silicone based procud to seal
toe cam covers and the oil breather connection on font of the head.
The oil leak seems to come from between the head and the cylinder block at the
front where the cylinderblock meets the chain housing. If the restorer milled my
block (dont think so) without mounting the chain cover there would be a small
but significant edge being higher on the chain cover onto which the cylinder
head woul lean and possibly cause an oil leak ?. However then the first cylinder
would not be tied down properly possibly causing a blown head gasket, weak
compression, water in the oil , and I have none of these problems.
So what could it be ?
I am reluctant to strip the head again (another 70 Uk pounds for the head
gasket…) unless I have to.
This oils leak must be stopped - I’m deeply ashamed to leave stains and the
environmental law are tough here - I can get fined and charged to the clean up
of the street here in Germany.
Head gasket. I bough a Proper S3 4,2 headgasket (original Jaguar), however the
water holes puzzled me.
In the head there is along the sides the elongated water holes. the holes in the
gasket to fit these holes were however of smaller “size” thus in principle
restricting water flow and causing “edges” where “sludge” could build up ?. I
was very much under time pressure to finish the car and was reluctant to open up
these holes in case it was supposed to be so ?, and left it as it was.
But I wonder what you think / know about this ?.
In any case this little “adventure” has tought me that it would have been
- cheaper to get a complete rebuild long block (1000 pounds), instead on
endless telephone calls, importing two engines from UK and and and… - It would have been better to get a rebuild long block since I would have
guarantee… - It would have been a lot quicker ( 2 weeks) instead of 1 year with two times
2 weeks of extremely
stressful 16 hour work days, not having time to enjoy the company of my own
family… - It would even have been cheaper to get a Jaguar factory replacement (1950
pounds)…
But I WANTED to know why the engine had burned a rear main bearing, I WANTED to
prove that it couldn’t be true that the engine was a gonner. Today I still dont
know why, the engine runs but not quite as it should.
Tsk Tsk Jaguars… BUT THEY DRIVE BLOODY MAGNIFICENTLY when they drive.
Date: 15 Sep 96 06:56:33 EDT
Subject: Re: Koni - standard shockabsorbers
Hi Martin,
I can’t remember If I already answered you last note from 6/9 on this subject ?,
anyhow here is a (nother)
answer
Harvey Bailey delivers a complete system, of schocks all around (specially
re-valved BILSTEIN shocks)
and a stiffer torsion bar front and a torsion bar for the rear (not standard on
any jag).
HB also delivers at set of springs uprated 25% in spring rate at about 220 UK
pounds. You could in theory
mount these springs with standard schocks to ensure you dont sit to low or sag
too much with 4 passengers.
I have asked around in UK before for extra haevy duty springs, but none came up
with a really convinging offer. The HB springs are more expensive than standard,
but he’s got a name to defend so I expect the quality is really OK
Harvey Bailey Engineering Ltd. is at : Ladycroft Farm, Kniveton, Ashbourne,
Derbyshire DE6 1JH
Telephone +44 (0)1335 346419, fax +44 (0)1335 366440
And he does for most Jags… XK120 / 140 /150, MK II, S type, E type 6 & 12 's,
XJ6, XJS, XJ40.
Date: Sun, 15 Sep 1996 10:01:48 EDT
Subject: Re: Series 3, XJ6, Starting problem
Hi all,
As per the last line of Robert’s post (attached) I’m posting this up to
the group because it follows on from mine - seems I’m not the only one
with this problem…
John
*** Forwarding note from I2131131–IBMMAIL 15/09/96 09:09 ***
Date:Sun, 15 Sep 1996 08:09:56 -0500
To: “auibmdak%ibmmail.com” auibmdak@ibmmail.com (Return requested)
$A110 sounds about right. The 87 XJS was $A99 from Tech Book store in Melb
and the One I just ordered from UK is UKP35. -
The starting problem you described in your previous mail is EXACTLY the same
scenario I suffered two weeks ago, including your suspicions about the safety
micro switch in the selector housing (uncanny) but minus the Yum Cha & RACV (OK
NRMA for you) no such road service in Bahrain. I have traced it to the starter
relay on the fire wall (the one closest to the middle of the car, the other
three are to do with the fuel pump/system) which sticks/fails intermittently.
If your car does it again, which I think is highly likely, lift the bonnet
gently and give the relay a tap with a screwdriver handle and try again. Its a
Lucas part with a superseding number, I can tell you what it is if you’re
interested (I don’t have it with me). P.S. It has spare terminals some of
which are just extra posts on the same electrical point.
You can post this back to jag lovers if this sounds like it is your problem.
Robert Bradley
Bahrain (ex-Melbourne, Go Bombers)
82 XJ4.2,
82 XJ4.2 Daimler,
87 XJS.
- ---- End of mail text
Additional SMTP headers from original mail item follow:
Received: from eyi.com by ibmmail.COM (IBM VM SMTP V2R3) with TCP;
Sun, 15 Sep 96 09:10:25 EDT
Received: by InfoXchange1.eyi.com id <21889>; Sun, 15 Sep 1996 08:05:28 -0500
Return-Path: Robert.Bradley@bh.eyi.com
X400-Received: by mta MTAEYI-1 in /c=US/admd=TeleMail/prmd=ErnstYoung/; Relayed
X400-Received: by /c=US/admd=TeleMail/prmd=ErnstYoung/; Relayed;
X400-MTS-Identifier: Y/c=US/admd=TeleMail/prmd=ErnstYoung/; 048B3323C002401F-MT
AEYI-1?
Content-Identifier: 048B3323C002401F
Content-Return: Allowed
X400-Content-Type: P2-1988 ( 22 )
Conversion: Allowed
Original-Encoded-Information-Types: IA5-Text
Priority: normal
Disclose-Recipients: Prohibited
Alternate-Recipient: Allowed
X400-Originator: Robert.Bradley@bh.eyi.com
X400-Recipients: non-disclosure;
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
Message-Id: 96Sep15.080528cdt.21889@InfoXchange1.eyi.com
Date: Sun, 15 Sep 1996 07:52:29 -0700
Subject: Re: Series 3, XJ6, Starter motor.
On Friday night the better half and I went out to dinner, afterwards we got into the Sovereign to head home,when the key was turned all I got was a click. Sorry, I don’t have an answer for you, but it reminded me of a situation I encountered with my 91 Sovereign one Sunday after church. I turned the key and got nothing, absolutely quiet. Tried and tried with no success, had a friend jump-start it, still got a big NOTHING. Then I called the Jaguar 800 number; they were totally worthless, not being in any way familiar with the car. Finally, I called AAA to have them come start it and they could not so I had them tow the car to Scottsdale Jaguar. By that time I had wasted pretty near the whole day. Next morning Scottsdale Jag called and said that someone must have “bumped” me in the parking lot and triggered the “cutoff” device which I could have reset by pushing the switch (had I known about it). Turns out there is a little switch down near your left foot (LHD), on top of a small plastic housing about the size of say three tennis balls. Hope this saves someone else who may be “bumped” in the future in a parking lot from a lot of wasted time. BTW I was parked in a large parking lot with no way for someone to “bump” the car. don Donald R. Farr Paradise Valley, AZ 85253 (602) 948-7499 - fax 91 Sovereign d.farr@phx.cox.com - e-mail http://people.phx.cox.com/dfarr/dfarr.htm - Don’s Homepage http://people.phx.cox.com/dfarr/jetta1.htm - Jetta Notebook Computers http://people.phx.cox.com/dfarr/march10.htm - Wireless products http://people.phx.cox.com/dfarr/ncs1.htm - National Consulting Services From: Kroppe kroppe@mich.com Date: Sun, 15 Sep 1996 13:46:04 -0400 Subject: Re: Vehicle Dynamics Jan Wikstroem Jan_Wikstroem@acp.com.au wrote:
Seriously, let’s not confuse theory - especially public passenger vehicle
theory - with actual measurement.
Yes, Jan, you’re right. After careful thought and staring at my XJ6
rear suspension
and speaking with vehicle dynamics gurus where I work, we have concluded
that there
is significant compliance oversteer in the XJ6 rear suspension. This is
because
lateral cornering forces steer the rear wheels out of the corner,
because the
subframe bushes allow lateral movement of the subframe, but the assembly
pivots about the two trailing link forward attachments, causing the
oversteer.
I wonder if you and others agree, though, that because the majority of
vehicle
drivers in the world are not enthusiast types (too bad!) that an
understeer
philosophy is the prudent way for vehicle manufacturers to go.
Understeer for
most people is a behavior which “feels predictable” whereas oversteer is
not
intuitively predictable. The Chevy Corvair and I think BMW have had
negative
experiences with oversteer. Granted, the oversteer may have come from
causes
other than compliance oversteer, but here I am arguing that oversteer in
general is not a responsible design philosophy for manufacturers other
than
all-out racing machines (McLaren, Ferrari, etc.).
I agree that a sporting vehicle (saloon or coupe) should be as neutral
as
possible, but should not be manufactured with designed-in oversteer.
Oversteer
can be be left to enthusiasts who choose to fit their own aftermarket
rubber
bits to their vehicles.
I have requested from my contacts the camber, caster and toe curves for
the
1982 XJ6 front and rear suspensions, as well as the coordinates for the
suspension pivot and mounting points. If I receive this data, I will
simulate the motion of the suspensions on my UNIX workstation, thereby
re-creating the suspension curves. Comparing the Jaguar-derived
(manually using pencil drawings!) suspension curves with my computer
generated curves will be interesting. It will also allow us to
compare calculations with observed behavior in our vehicles.
As for the toe-in, it doesn’t change measurably through the suspension travel.
The torque arms have no effect on it at all, being connected through rubber.
We’ll see from the suspension curves whether this is true or not. I
have
read on this list that some Jaguar racers move the trailing link forward
attachment inboard towards the propshaft tunnel. I believe this is to
reduce the toe change through travel. If this is true, then the
trailing
link does have an effect on toe. Without the trailing link altogether,
the rear suspension would have no toe change (discounting any
compliances,
for now). Doing the racing-mod as above would have the geometric effect
of
“eliminating” the trailing link.
I hope I get the suspension data - if so, I will post my calculations
to either the Jag-web or my own web page. I’ll keep the list posted.
(no pun intended).
B.J. Kroppe - '82 XJ6
Date: Sun, 15 Sep 1996 16:37:19 -0400
Subject: xj40 shop manual
Would anyone know where the best place is to buy a shop manual for an XJ40?
Here in northern Maine we are 350 miles from the nearest dealer so repairs by
local mechanics are somewhat of a necessity. One of the local garages tells
me that a
factory manual costs $271.00 u.s… I know that there are aftermarket
manuals, but I’m told that they aren’t comprehensive enough. Any help would
be greatly appreciated.
Rick Castonguay 1990 sovereign.
End of jag-lovers-digest V2 #356
Return-Path: @owner-jag-lovers-di1
Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4)
id for jag-lovers-digest-out; Mon, 16 Sep 1996 10:23:58 +0200 (MET DST)
Date: Mon, 16 Sep 1996 10:23:58 +0200 (MET DST)
Message-Id: 199609160823.KAA27377@ekeberg.sn.no
X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f
To: jag-lovers-digest@sn.no
Subject: jag-lovers-digest V2 #357
Reply-To: jag-lovers@sn.no
Errors-To: @owner-jag-lovers-di1
Precedence: bulk
Status: O
X-Status:
X-Newsgroups: mail.jag-lovers-digest
jag-lovers-digest Monday, 16 September 1996 Volume 02 : Number 357
Feul Addictives
SII luggage compartment springs
Hung up on E brake job
reverse lump?
Re: S3 and XJ40 queries
Re: XJ’s :Louvres and headlamp air scoops
Re: XKE Valve adjustment
Re: SII luggage compartment springs
Re: XJ40 headlamp preferences
Jaguar World - free copy
Re: XJ 6 Bonnet issues.
SV: XJ40 headlamp preferences
Date: Sun, 15 Sep 1996 14:57:22 -0800
Subject: Feul Addictives
Hello everyone,
Is it okay to use feul addictives on a jag? My XJ40 loses power every so
often. When this happens I added a bottle of GUM OUT and it feels more
accelerated. Does this stuff really work or is it just my psychological
mind? If it does work which brand should I use and how often?
Thanks…
_,'| _.-''``-...___..--';) Quang Ngo
/_ \'. __..-' , ,--...--''' Principal Software Engineer
<\ .`--''' ` /' quang@valleynet.com
`-';' ; ; ; 89-XJ40 89-300E
__…–‘’ …–…’ .;.’ Unix NT Win95 C C++
Date: Mon, 16 Sep 96 18:26:00 ���
Subject: SII luggage compartment springs
Ouch! Ever had the bootlid come down on your head?
Do I have to replace the springs or can they be retempered, or for that
matter, adjusted?
The Haynes manual states that removal is straightforward, using a screwdriver
to lever the springs off and, you guessed
it, replacement is the reversal of the removal method. This usually means a
two-day job.
Thanks in advance to anyone who’s done this and can offer advice, aspirin and
a bandage for my poor loaf.
Regards
Peter Brown
Lobotomised 1979 double 6
Date: Sun, 15 Sep 1996 18:59:08 -0400 (EDT)
On Sat, 14 Sep 1996, David J Shield wrote:
I often thought of hood louvers on my XJ6 until someone on the list mentioned that the heat would flow right back into the cowl inlets. Jim Isbell reports that his engine runs a few degrees cooler with the bonnet popped open and resting on the safety catch, wonder what that does in terms of heat flowing back into the cowl? This can be measured - put a thermoprobe in various cowl inlet positions and measure it with and without the bonnet popped. I'd do this if I had a thermoprobe.
I have a thermoprobe and will check it out.
John
Date: Sun, 15 Sep 1996 19:14:01 -0400 (EDT)
One of those little relays on the fender near the firewall is called an
inhibit relay (on my XJ-S and I think its the same on an XJ6). When these
bettys go, they do a good job of inhibiting the car from starting!!
Mine went, too – same symptoms, and over a l o n g period of time – so
you think the fiddling fixes it, and then weeeks or months later it fails
again. I eventually tossed mine and replaced it with a small jumper with
spade connectors. For most, this should be the get-me-home repair, tho,
because then the engine will start in any gear.
John
On Sun, 15 Sep 1996, John Littler wrote:
Hi all,
- The starting problem you described in your previous mail is EXACTLY the same
Date: Sun, 15 Sep 1996 19:21:54 -0500
John Littler wrote:
Hi all
happy ending )
On Friday night the better half and I went out to dinner, afterwards we got into the Sovereignto head home,when thekey was turned all I got was a click. Hmm…hit the lights yep, plenty of power, tried a few times, still nothing but a click. Popped the bonnet,nothing loose as far as I could see. I have seen many V12 Jags and some 6 cylinder cars exhibit a similar symptom. The explanation is contamination in the starter solenoid. After running for some time, and than being turned off for about 30 min. The engine heat is soaked by the starter, which, with no cooling gets hotter than the clearances allow within the solenoid. The behavior is to hear only a slight click, and no starter engagement. Invaribly, within another 30 min the starter will work fine. The only fix is a little patience, especially on a hot day, or a replacement solenoid/starter. Bob Johnson XJ12, XJS, From: rrichardson@eurekanet.com (Bob Richardson) Date: Sun, 15 Sep 1996 19:26:56 -0500 Subject: Hung up on E brake job I hope I’m not a pest, but so far I have removed to top master cylinder (rear brake system) and am hung up on removing the bottom master cylinder. I was able to remove one of the bolts (secured by a locknout), but the other bolt and nut seem to be frozen solid. I tried liquid wrench. There is no room to get a spanner or socket in there to keep the locknut from turning. I tried inserting shims, but the nut appears to have rounded corners from some past effort to secure it. Would it help if I applied the heat from a propane torch to this balky locknut? Is there a closed-end spanner that has an ultra-thin surround? Apparently when this entire unit is produced, it’s easy enough, with the proper tools, to assemble it on a clean workbench. Someone didn’t figure in that guys like me, with big clumsy fingers, would have to undo the blasted thing! From: Patrick Krejcik pkr@SLAC.Stanford.EDU Date: Sun, 15 Sep 1996 19:13:14 -0700 Subject: Re: E-type ramps and bleed kit Bob, I hate to be a pessimist, but E-Types are extremely difficult to drive up onto ramps because the long nose is too low and scrapes up against the ramp. For the ramp to work it has to have a very shallow angle and be quite long. The only time I used a ramp was when I jacked the car up slid the ramps underneath. Look around some more for a professional rolling jack. $260 sounds awfully expensive and I am sure discount places will have one for under $100. Cheers, Patrick. 1965 E-Type 4.2 Series I FHC From: “Peter Rebbechi (03) 9275 3374” <"REBBECHI PETER"@A1.MEOC02.SNO.mts.dec.com> Date: Mon, 16 Sep 1996 02:42:00 +0000 (GMT) Subject: reverse lump? Dropped in to the local JAG parts place over the weekend, and participated in a group discussion re kit cars. Two of the guys are planning Cobra replicas powered by 6L V12’s. You should have seen the looks of horror on the faces of the purists! Considering the iscussions on this list, I was quite amused. Remember: Smoke tyres not tobacco. Smells better, and feels great! From: cobac@ix.netcom.com (Eric J Faber ) Date: Sun, 15 Sep 1996 21:33:03 -0700 Subject: Re: S3 and XJ40 queries You wrote:
in square headlighted models ? Can somebody fill me in on this please?
John,
That was I who was asking about the headlamp conversion. It seems
as if the group isn’t very talkative about the headlamps, so I’ll tell
you how the headlamps in the XJ40 are setup in the U.S…
1988-89 All models have 4 round headlamps
1990-92 Vanden Plas, Sovereign, Majestic: 2 Square headlamps
1990-92 XJ6: Only model for '90’s to have 4 round headlamps
(Also included some black door trim instead of the
usual chrome framed doors.)
1993-94 All models (XJ6, VDP): 2 Square headlamps (also BUILT-IN
FRONT fog lamps)
The round headlamps are sort of shaped like a square. A painted flat
piece covers the front of the 2 lamps (per side) and gives it the look
of a painted rectangle with two circles in it.
I’m still confused on which lights I prefer. From a short distance, I
sometimes percieve the car to be a 1995 X300 or S3, because of the
round lights. The round lights are a bit more traditional for Jaguar.
The car can look like an old, very old or new model. The square ones
can be looked at as unusual for a jaguar, however they still look more
modern, and don’t resemble any other Jaguar.
Hope this answers your question. I’d love to know which headlamps
other Jaguar lovers prefer!
- -cobac@ix.netcom.com
Date: 16 Sep 96 02:17:31 EDT
Subject: Re: XJ’s :Louvres and headlamp air scoops
I’m interested in the Louvres in the XJ12 S3. As mentioned by Kirby the hot air
stream from the engine compartmen could enter the fresh air inlet and impair
air-condition performance , especially at standstill I presume. Did anyone try
yet or do I have to be one spending 750 pounds on destroying my V12 bonnet
I thought the louvers could be made towards the outer side of the bonnet leaving
the centre free to allow most hot air to escape and “miss” the centre fresh air
intake ? any ideas ?.
My Series 2 XJ6C has headlamp air scoops ending up in each footwell. These could
serve as air inlet to the fresh air for the airco - with some not so easy
modifications ? any opinions on that ?
My S3 XJ12 does not have these footwell air scoops - why did Jaguar discontinue
these ?
Just vistited the Jaguar Germany Dealer in Kronberg in Tausun Near Frankfurt.
The new x300’s are for sale used now at about 90.000 German marks (60.000 US$).
Some very nice XJS’s as well V12’s dreaming…, Really I would like a V12
Convertible, but ther aint no room for junior. I guess I’d be better off
converting the Coupe to a Cabrio ? Heresy ?. Vicarage will do it for me…
Date: 16 Sep 96 02:17:26 EDT
Subject: Re: XKE Valve adjustment
You can rotate a XK engine camshaft 360 degrees without hitting other valves if
the other camshaft is completely loosened or removed.
What I am not 100 % certain about is whether the inlet valves could hit a
piston at Top dead centre. It is better to set the the crankshaft to 30 degrees
before of after TDC to make sure the piston are out of the way.
However it is not necessary to be able to rotate one camshaft freely to make
100% accurate measurements of the valve clearance. With cam covers off and spark
plugs out you can turn the engine on the starter or with a key on the crankshaft
pulley nut and get quite accurate measurements. It is not necessary for the cam
lobe to point absolutely straight up from the valve in order to measurethe
clearance accurately. An error of +/- 30 degrees wont make a difference.
Date: Mon, 16 Sep 1996 01:22:51 -0500
d.farr%phx.cox.com @ Internet
15/09/96 08:31 PM
To: auibmdak%ibmmail.com @ Internet
cc: jag-lovers%sn.no @ Internet
a click.
don
Since I had this one last week (the relay was two weeks ago) I’ll post script
this one too. For those who read my comment on the starter relay, it was the
other XJ6 (Scarlett) this time! Two days after I get the car back from the
dealer who finally fixes (I think) an 18 month old miss fire, my wife goes to
start the car at school, nothing. She gets out, thinks quickly (it’s still
35-40c here and takes about 60 - 90 seconds to start sweating if your outside)
and lifts bonnet, taps starter relay (previous week, othercar, good thinking I
thought). Still nothing. Thinks even quicker and goes inside to the Air
Conditioned office and calls our friendly Jag service manager. He comes out
personally and tries all tricks including the fuel inertia switch mentioned
above by Don. Nothing. Tows Scarlett back to workshop and lends Felicity a
Peugot 306 (better than walking) cause Rhett was in for a service as well. (its
post summer, holiday over, catch up on put off maintenance time) Turns out it
was the fuel inertia switch which he said had burnt out or something. He said
he had not seen this before. He replaced it FOC with a second hand one. No
“bump” involved here either.
P.S. For those who are wondering about Kermit (87 XJS) and who think these
things come in threes, stay tuned - he is in the shop for his service at the
moment. I’m holding my breath.
P.P.S I should also say that apart from two blown hoses, This is only the third
time these cars have let me down in 2 1/2 years. Given their age, the heat
here and the likely attention of POs to maintenance, I’m philosophical about it.
Robert Bradley
Bahrain
82 XJ4.2 (Scarlett)
82 XJ4.2 Daimler (Rhett)
87 XJS (Kermit) (he’s green)
Date: Mon, 16 Sep 1996 01:30:23 -0500
Subject: Re: SII luggage compartment springs
pbrown%sbnsw.com.au @ Internet
16/09/96 05:04 AM
To: jag-lovers%sn.no @ Internet
cc:
matter, adjusted?
two-day job.
Regards
Peter Brown
On my old Series I it wasn’t the springs that caused this, it was the thrashed out hinge pivot points. Robert Bradley Bahrain 82 XJ4.2 (Scarlett) 82 XJ4.2 Daimler (Rhett) 87 XJS (Kermit) (he’s green) From: Jeffrey Gram 101454.2570@CompuServe.COM Date: 16 Sep 96 02:29:27 EDT Subject: Re: XJ40 headlamp preferences Hi, I have never owned an XJ40, I Wonder whether I will ever . I find the S3 XJ more “Jaguar” like, and the XJ40 seems cramped to me at the driver seat with all the computer panels around the steering wheel. The squary shape of the Jag is not my taste either, here the XJ40 is a serious deviation from the beatitufully curved lines that has marked Jaguar, to be introduced again with the X300. But Hedlamps it was… In Europe all XJ40 were sold with square lamps (me thinks), and this design sort of underlines the square look (no pun intented) of thge XJ40. So One of the mods that significantly increased the sex appeal of the XJ40 is the round Lamp conversion. I would prefer the rounds anytime. I don’t like XJS’s oval lamps either…(and the butresses…) Regards Jeffrey Gram From: hastings@frodo.eucom.mil (Craig R. Hastings) Date: Mon, 16 Sep 1996 06:49:36 GMT Subject: Re: S3 and XJ40 queries As far as my opinion goes. I prefer the round headlights. More traditional I think and where would Jaguar be without tradition. Craig 88 VDP 73 E-type (maybe, I’m waiting to see if my offer is excepted) From: Jan Wikstroem Jan_Wikstroem@acp.com.au Date: 16 Sep 96 18:19:54 Subject: Re: S3 and XJ40 queries The Australian situation appears to be exclusively the “two square” variety. I can’t recall seeing a series 4 with anything else. Personally, I think the rectangular lamps stink, mainly because they are hideously expensive to replace in the $A1,000 region - and people tell me you average one a year on pebble-strewn Australian roads. In contrast, the standard round ones on S1-2-3 cost around $A80-100 for good halogens. BTW, to remove a small but common confusion, only the outer lamps on S1-2-3 are headlamps; the inners are long-range driving lamps. Some people swear by aircraft landing lights in this position; I’ve found excellent Hella 100W halogen spotlight inserts that make the original Lucas sealed beams look like anemic glow-worms. The number of “stylists” and “engineers” who feel unable to create a good-looking car with standard headlamps has now grown so much that practically only old cars use standard lamps, which I guess means that the standard is on its way out… Jan From: David Wood David.Wood@durham.ac.uk Date: Mon, 16 Sep 1996 09:13:30 PDT Subject: Jaguar World - free copy I’ve just received my subscription copy of Jaguar World - two copies in fact. For UK list members, the first person interested who sends me his/her postal address (by email) can have the spare copy free. Cheers, Dave Wood. From: Baard Th Hesvik baard@telesoft.no Date: Mon, 16 Sep 1996 09:59:15 -0700 Subject: Re: XJ 6 Bonnet issues. Barry Dawson wrote:
… You stand to the front centre of the open bonnet and place the hand
on finger tips centrally on the bonnet, then push firmly so that the bonnet
shuts with a “clunk”. This ensures sufficient force within the flexing bonnet
to snap shut in the locks. If the bonnet pops up on one side NEVER push that
side back down as the bonnet can bend, always open and start closure afresh.
Although all this is correct and, as I’ve posted previousely, the described
manner is indeed the only way allowed to close the XJ bonnet, I’m not sure that
the method of closing necessarily will remove the problem with popping bonnets.
A (Jaggee) friend of mine showed me this method of closing the bonnet, a method
he had used for some 15 years at the time. Yet, he has always had his bonnet
popping up on the right hand side. Until I showed him where to make the
adjustment;
The whole latch mechanism is adjustable! You note where the pins strike on the
plate surrounding the hole, loosen the bolts and make the adjustment. Checking
the bonnet mounted spring/pin for angle first is a very good idea (it is more
likely that this has come out of alignment than the solidly bolted striker
mechanism), whereas adjusting the spring/pin length should only be for the
purpose of aligning the bonnet heigth as opposed to the front wings.
Also, a small correction to Barry’s description; The greater force applied to
close the bonnet should not be on the finger tips placed centrally on the
bonnet, but the other hand, firmly gripping the upper part of the grille, making
an upwards movement as the first hand ensures the direction, lightly supporting
the closure. PS! place a piece of cloth between fingers and bonnet paintwork!
Good luck!
Bard
______ _ ! Baard Th Hesvik, Telesoft AS
/ _ / _ _ _ / / ! Longhammarvn 7, N-5500 Haugesund
/ // / // /_ / / -/- -/- ! T: +47 52735000 F: +47 52717040
/ /_ / /_ / // / /_ ! E-mail: baard@telesoft.no
Date: Mon, 16 Sep 96 10:03:00 PDT
<Hope this answers your question. I’d love to know which headlamps
<other Jaguar lovers prefer!
<-cobac@ix.netcom.com
My opinion is that square headlights (or tail lights) doesn’t fit the
beautiful curves on a jaguar. Therefore I was very happy to see that X300
was one step nearer the SIII design.
Are Lorentsen
82XJ6
Date: Mon, 16 Sep 96 10:11:00 PDT
Subject: SV: XJ40 headlamp preferences
Jeffrey Gram:
<But Hedlamps it was… In Europe all XJ40 were sold with square lamps
<(me thinks),
XJ40 was sold in Norway also with round headlights. The sovereign had
squares, if I remember correctly.
Are Lorentsen
82XJ6
End of jag-lovers-digest V2 #357
id for jag-lovers-digest-out; Mon, 16 Sep 1996 20:48:37 +0200 (MET DST)
Date: Mon, 16 Sep 1996 20:48:37 +0200 (MET DST)
Message-Id: 199609161848.UAA04531@ekeberg.sn.no
Subject: jag-lovers-digest V2 #358
Precedence: bulk
jag-lovers-digest Monday, 16 September 1996 Volume 02 : Number 358
Re: One-man E-type brake bleed
Re: Luggage comp. springs.
[SIII XJ6] Experiences with shocks and such
Re: long-range driving lamps (Was: S3 and XJ40 queries)
E type Electrical Problems
Hydraulic Floor Jack & Jack stands
XJ12 cutoff cutoff
Series III ('85) XJ6 cylinder head off!
Re: [SIII XJ6] Experiences with shocks and such
Re: xj40 shop manual
Re: XJ40: Headlamps $$$ ?
XJ front susp. upper bushes.
XK engine stake down
GM 400 throttle switch
Date: Mon, 16 Sep 1996 09:21:42 +0100
thge XJ40.
In the UK all XJ40s were sold with ROUND headlights, except the
Sovereign and Daimler models.(no VDPs in UK - we had Daimlers instead -
what was the spec of the VDP and Majestic models?) The proportion of
Sovs was very high, judging from what I see on the roads.
Mark Stiles
90 Daimler 4.0
Date: Mon, 16 Sep 96 11:38:30 BST
Subject: Re: One-man E-type brake bleed
…on the subject of one-man brake bleeding…
…surely I can’t be the only jag-lover who has an “Eazi-bleed” kit?
(I think they’re made by Gunsons but I’m not sure).
This device uses your spare type as a compressed air reservoir which
pressurises a large plastic brake fluid reservoir via a hose and
footpump-style valve connector. A tube dips into the bottom of this
reservoir and feeds fluid up to an air-tight cap that screws onto
your brake fluid reservoir on the car (the kit comes with a wide range
of different caps and rubber gaskets to fit most cars).
Once you’ve fitted this and got it air-tight you can bleed the brakes
by just opening each of the nipples and letting the fluid flow out until
it’s bubble free (or longer if you’re changing the fluid).
No pumping, No assistant needed, and no worrying about having to top
up the reservoir for fear of running out of fluid and pumping air through
the system.
They’re extremely cheap and work pretty well. Maybe they’re not
available in the states?
Dan.
Date: Mon, 16 Sep 1996 13:14:13 -0700
Subject: Re: Luggage comp. springs.
To Peter Brown (Lobo)
We were driving along on our way home from our mountain cabin when we suddenly
heard a big BANG! I also think I felt a sudden push from behind. I was convinced
it was something very serious because of the expencive sound of the bang,
climbed out of the car and examined its lower parts, but couldn’t find anything
wrong, so I drove the car carefully home.
When unpacking the boot (boot lid held up by back of head :-, I found a large
spring and wandered where the hell that came from…?! After a short analysis
of the situation, I found out where the spring belonged It had literally
eaten its way through the metal, and finally contracted with a bang, forcing me
to replace the whole hinge/spring unit.
As to your problem, which is similar to a friend of mine’s whose boot lid and
bonnet both has very weak springs, I suggest a replacement of the springs as the
best/easiest solution.
Bard
Date: Mon, 16 Sep 1996 07:56:54 -0500
Available from whom? Approx cost please.
I’ve heard of these things and always wanted one. An added benefit would come
from reducing the risk of damage to the master cylinder seals when they travel
where no seals have gone before when you pump full strokes.
Date: Mon, 16 Sep 1996 15:53:08 +0200 (MET DST)
Subject: [SIII XJ6] Experiences with shocks and such
Folks,
I just replaced all six shocks on my '86 Series III XJ6 Sovereign with
Monroe gas shocks (gas-o-matic(?)).
They give the car a whole new feel, much firmer. They also lifted the car
just that little bit that was needed. Perfect! All the little noises from
the suspension vanished too, but that could also be related to the next
item replaced:
I also replaced the steering rack bushes with the original Jaguar Sports
bushes. I couldn’t believe the difference! Anyone out there thinking
about doing this - stop thinking and get to it right away!
Now for a question: Up front (way up front) there are two major bushes
(one each side, of course) holding the whole front suspension to the
car (or so it seems). Mine are shot. How much work is it to replace them?
Does the weight of the engine also lie on these bushes? Recommended
procedure and Real Life™ experiences?
Hints and help appreciated!
Gunnar
Gunnar Helliesen | Bergen IT Consult AS | NetBSD/VAX on a uVAX II
Systems Consultant | Bergen, Norway | '86 Jaguar XJ6 4.2 Sovereign
gunnar@bitcon.no | http://www.bitcon.no/ | Vicki who? What .sig virus?
Date: Mon, 16 Sep 1996 16:03:55 +0200 (MET DST)
Subject: Re: long-range driving lamps (Was: S3 and XJ40 queries)
Very interesting. Do you have a part number or other reference I could
use at my local Hella shop?
Gunnar
Date: Mon, 16 Sep 1996 09:04:54 -0700
Subject: E type Electrical Problems
I have recently been experiencing problem with my 74 E-type. After two
years of virtually trouble free motoring ( unless you count the
replacement of the rear main seal) the car has been “blowing” the fuses
for the Radio, gages etc [one circuit] and the Cigarette lighter [other
circuit]. Any SHORTCUTS to this problem?
Bruce E. 74 E Type Rdstr / 93 XJ- 40/ 60 Rolls Silver SC II
Life is Way Good!
insnet@netins.net…sort of a palindrome without the .net
Amana, IA 52203
USA
Lottery: A tax on people who are bad at math.
He who laughs last thinks slowest!
Karaoke is Japanese for “Tone Deaf”.
A bird in the hand can be messy.
A rolling stone gathers momentum.
Date: Mon, 16 Sep 96 08:05:00 PDT
Subject: Hydraulic Floor Jack & Jack stands
My wife bought me a new 2 ton hydraulic floor jack from Sams Club in the US
for about $60 last Christmas ( Yes she had a hard time wrapping that box ).
It works great. That $260 jack must be one of those used in racing that
lifts the car all the way in 3 pumps( or is chromed with gold accents ). I
can not see paying that much for a floor jack for home use, or in the shop.
As far as jack stands, I purchased mine about 5 years ago. They are rated
at 2 tons each ( set of 4 ) and I don’t think I paid more then $15 or so
each, but my memory is not too good some days ( as many of you know :-} ).
John Himes
88 XJ-S 97K Miles
Date: 16 Sep 96 10:17:38 EDT
Subject: XJ12 cutoff cutoff
I had the same problem with our XJ5.3C years ago when the “cutout” cutout on a
channel crossing (rough). It is designed to stop the petrol pouring out when
you crash, I was told. Annoying mystery the first time … John Elmgreen
Date: Mon, 16 Sep 96 16:16:49 BST
Subject: Series III ('85) XJ6 cylinder head off!
Greetings fellow jag-lovers.
I have just taken the cylinder head off my 1985 (series III) XJ6 Sovereign.
(It was FUN!.. more detailed account will follow later).
The reason for this was:-
1) Leaky head gasket (shaving foam in the breather system).
2) No compression (well not much) on number three - burnt exhaust valve
(diagnosis confirmed!)
3) Lumpy idle (probably due at least in part to 2)
4) A good de-coke while I'm in there.
5) Install bucket guide stake-down measures
6) Check head for flatness and skim if necessary.
My question is:- “what else should I do while I’m in there?”
- should I replace the valve springs as a matter of course?
- should I replace all the valves similarly?
- should I clean and polish the stud threads to make sure I’m getting the
maximum clamping pressure at the specified nut torque?
- should I replace the upper timing chain?
…or anything else I haven’t thought of.
your collective wisdom is appreciated.
Dan.
P.S. …can’t wait to read Jim’s new bumper-to-bumper book on the XJ6.
Can we have a plain text version though? (or better still html)
- some of us have to work at grown-up’s computers.
Date: Mon, 16 Sep 1996 12:05:42 -0005
Subject: Re: [SIII XJ6] Experiences with shocks and such
Gunnar Helliesen:
Good advice – except the wrong bushings. The aftermarket bushings
are MUCH better (IMHO) than the Jag items, Sports or not.
It’s a snap, nuthin’ to it.
The whole CAR lies on those bushes!
Recommended
Jack up car, put on stands at jack points. Put floor jack under
front crossmember, apply a little lift to relieve weight on mounts.
Unbolt mounts, remove and replace.
Some would suggest a realignment afterward wouldn’t be a bad idea.
By the way, there are two other mounts to look at, sort of along the
rear edge of the crossmember and just above it. Wouldn’t be a
terrible idea to simply replace while you’re at it.
| some rules must be broken.
| - Palm’s Postulate
From: Patrick Krejcik pkr%SLAC.Stanford.EDU@vm1.cc.nps.navy.mil
Whoa, wait!!
<I hate to be a pessimist, but E-Types are extremely difficult to drive
<up onto ramps because the long nose is too low and scrapes up against
<the ramp. For the ramp to work it has to have a very shallow angle and
<be quite long. The only time I used a ramp was when I jacked the car up
<slid the ramps underneath.
<Look around some more for a professional rolling jack. $260 sounds
<awfully expensive and I am sure discount places will have one for under
Hold on a minute. I got the $17.95 specials, and all I had to do was to put
a 2X6, about 18-24 inches long on each ramp to lengthen the slope. I used a
nail in the end of the 2X6, bent it and stuck it in a hole about half way down
the original slope, and made the slope longer and more shallow. The “E”
drives up it very well, thank you.
It is, of course, not a concourse ramp. But we can be innotive, and fab-
ricate to make things work.
BTW, painted the “E” bonnet this weekend, WHAT A JOB!
3030P@VM1.CC.NPS.NAVY.MIL
LLoyd Nolan Monterey, Ca. USA
'71 E-Type OTS, "PrtyKty" It needs some assembly.
'69 280sl, “Darth Vader” Just when you think all is lost it saves you.
In search of a Mk II or 3.8s
From: Michael Powers/TEIR/Thomson Michael_Powers@teir.com
Date: 16 Sep 96 12:51:33
Subject: Re: xj40 shop manual
I placed a similar post a couple of weeks ago. I didn’t get much in the way of
responses, but here’s
what I’ve found out so far:
My local Jag dealer sells the complete 5 volume set for $185. Pricey but I
suppose it’s worth money if
you are going to do a lot of work.
My local library has Mitchell guides for many previous years (86-95). Mitchell
has a section on Jags, which
includes wiring diagrams. I found the info to be pretty good, but somewhat
brief.
Rgds,
Mike
SirSmed @ aol.com
09/15/96 04:37 PM
To: jag-lovers @ sn.no @ Internet
cc:
me that a
Date: 16 Sep 96 12:55:10
Subject: Re: XJ40: Headlamps $$$ ?
I was looking into this myself. A boneyard by me has an 2 88s and a 90 that I
am
going to take a look at this weekend and see if there are any good parts.
But I am interested in 2 squares if anyone is stockpiling them!
Rgds,
Mike
cobac @ ix.netcom.com (Eric J Faber)
09/14/96 08:38 PM
To: jag-lovers @
sn.no.Just.wondering.if.anyone.knows.where.to.obtain.two.front.headlamps @
Internet
cc:
with them.
condition).
Date: Mon, 16 Sep 1996 19:16:36 +0100
Subject: XJ front susp. upper bushes.
Hi Gunnar,
The Front suspension top wishbone bushes replacement is not as easy as the Schocks.
The weight of the engine rests on the front subframe, and tghe subframe is bolted (via metalactic
rubbers) to the car chassis, So no the engine weight is not directly on the bushes or the
wishbone arms.
However the springforce of the spring rests or “loads” these bushes.
You need to raise front front wheels off, losen torsion bar connections to wishbones (buy all new
rubbers and metal rings for the torsion bar and torsion bar “rods” - close to the wheel.
Now remove the schocks front (sorry - but you could have asked earlier)
Now you need a blo… big threaded steelbolt 50 cm long 2,5 cm thick with giant steel nuts
and large washers 5 mm thick, to construct a spring compressor strong enough to take the
force of the front spring.
Alternative buy a proffessional tool at the Jaguar Enthusiast club in UK (it is epensive - about
200 pounds).
Then the spring is compressed, and the spring retainer plate below the front sprint can be
losened and the spring losened and the assembly becomes “slack”. Now remove upper
wishbone bolts and nuts and you are there.
Note however that you are likely to need new bushes in the bottom wishbone also, and this can
be a real nightmare to get the bottom bolt out. Prepare by having new bottom bolts and nuts
available - I had to cut mine out.
This work is considerably easier to do with the whole subframe removed, which is very easy,
however you need a special tool ( or get it made at the local smith - easy) which holds the
weight of the engine while you remove the front supension on the subframe complete.
In this case buy new front subframe rubbers - 2 at the rear of the front subframe and 2 round
ones front.
You see - might as well do the whole front suspension in one go.
Regards and have fun. Jeffrey Gram
Date: Mon, 16 Sep 1996 19:56:02 +0100
Subject: XK engine stake down
Hi, As some may remember I fumbled my way to mount a stakedown kit with the head on.
It is not as easy as it sounds the hardest part being drilling exactly where you want to drill. The
drill bit is very prone to “wandering” while getting the first grip in the light alloy, and the tolerance
on the holes in the stake down plate do not allow much error. I had to drill up the holes on
several, and I damn near splintered a tapped guide, when “easing” one into position with a
sledgehammer. One tappet bucket didn’t fit after the stake down kit was mounted, until i
realised the guide was under deformation… Own fault of course. Off again and drill the hole in
the stake down plate bigger to correct for the drill position error. One fatal error and the whole
work is lost and professional help is needed to get head off , new guides in… $$$$$$$$$$$$
Dont forget you need to get camshafts off, where there are other traps laying waiting for the
innocent DIY’er : you could lose a valve sprocket bolt or lock plate down the chain housing -
this will set the repair back by another two weeks, getting either the engine front off (bonnet,
radiator etc…or turn thecar upside down and shake it vigorously…
Or you could get the valve timing wrong an re-assembly - Just ask Ryan Border
Still want to do this ?
OK :
Tapping in aluminium requires the tap to be wetted with alcohol, however for this particular
operation a more sticky material is better to get the cut bits up. Compressed air is great (when
all other oil holes are covered up with cloth.
There is a way to tap which is called two step forward, one step back, two step forward, etc.
This MUST be obeyed or the risk is a broken tap in the head and then you are really stuck.
Holding the tap perpendicular to the head is also not that easy especially if you have never done
it before., buy extra taps and train yourself on a scrap piece og aluminium.
Frankly speaking, I would not attempt this if I hadn’t been drilling and tapping for 25 years now
on a DIY hobby basis, (Ok less experience will also do). But realise there is a fair chance to get
it wrong.
I will send you my description from february this year.
Date: Mon, 16 Sep 96 10:58 PDT
Greetings,
JG>One of those little relays on the fender near the firewall is called an
JG>inhibit relay (on my XJ-S and I think its the same on an XJ6). When these
JG>bettys go, they do a good job of inhibiting the car from starting!!
I encountered a similar problem with my 1980 S3 a couple of weeks ago.
Symptoms: turn key to start position, no clicks whatsoever, warning
light test OK, no dimming of headlights when attempting to start.
Get-home fix: locate starter relay(rectangular silver secured by two
screws) centre of firewall. Remove heavy gauge wire(from relay on
right side of relay). Turn on the ignition.
CAUTION: Ensure that the gear lever is in the PARK position as the
inhibit circuit is bypassed.
Using a short piece of electrical wire connect from positive terminal of
battery to the heavy gauge relay wire. If the starter and solenoid are
serviceable, the car will start and get you home.
Cause and fix: an intermittent starter inhibit micro switch in the
gearshift console prevented the starter relay from operating. There are
two identical microswitches if cruise control is installed. The left
hand switch is the inhibit switch. Switches are secured by two hex
headed machine screws passing through both switches. The most difficult
part of the operation was finding a wrench small enough to fit the screw
heads. I finally opened up an 8BA wrench with a file (3/16" across the
jaws). Cost of the switch: CDN$15.66 Part number C33509.
Incidentally, the 1980 Series 3(California Specs) does not have an
inhibit relay.
Dennis Smith
� OLX 2.2 � 1941 Plymouth P12, 1980 Jaguar XJ6, 1969 Austin Mini
Date: Mon, 16 Sep 1996 14:47:00 -0400 (EDT)
Subject: GM 400 throttle switch
Sure enough, after it’s been discussed it happens to me!
85 XJSHE 135K Recently had the cam cover gaskets replaced. When tracking down
a water leak (the water valve to the heater core), I noticed a wire just
hanging there. It goes to the switch on the throttle cable, not the
one on the round mechanism that the cam thingy engages). I connected the wire
to the switch, and found the car wouldn’t go into third gear. I disconected it
and the transmission worked fine again. The repairman was right to leave it
hanging?? (I guess I should next check if the switch is bad)
What is this switch for, and is there a problem if I just leave it
disconnected/disabled?
Russ Lehman
“nothing worthwhile is ever easy”
“pessimists are accurate; optimists live longer”
Internet: rlehman@npr.org
End of jag-lovers-digest V2 #358
id for jag-lovers-digest-out; Tue, 17 Sep 1996 02:18:59 +0200 (MET DST)
Date: Tue, 17 Sep 1996 02:18:59 +0200 (MET DST)
Message-Id: 199609170018.CAA20106@ekeberg.sn.no
Subject: jag-lovers-digest V2 #359
Precedence: bulk
jag-lovers-digest Tuesday, 17 September 1996 Volume 02 : Number 359
'86 XJ-S Dying on Acceleration
XJ3 Fuel Cutoff “USEFULNESS”
Re: GM 400 throttle switch
AC vents question (85 XJS HE)
1967 e type 4.2 2+2 kickdown cable
Re: XJ front susp. upper bushes.
FW: XJ3 Fuel Cutoff “USEFULNESS”
XJ 40 Alarm transmitter
Hood latch on XJ6
Re[2]: cowl inlets on E-types; and louvers on XJs
Turbos for a V12
Re: XJ 40 Alarm transmitter
Expensive over night parking (XJ6)
Re: Hood latch on XJ6
Kirbys question on oil pressure senders.
89 XJ40 Air Conditioning
Engine Paint Recommendations?
XJ40/Jaguar World
Date: Mon, 16 Sep 96 14:06:29 -0500
Subject: '86 XJ-S Dying on Acceleration
My 1986 XJ-S sometimes tries to die when
accelerating at low speed (below about 1800 RPM)
If I continue to hold the throttle constant the
engine surges off and on somewhat like a carb.
with vapour lock problems. I have replaced the
fuel filter and throttle posistion sensor and this
has had no effect. According to Kirby’s book, the
TPS should be set for .32-.36 volts at idle.
The highest voltage I could get with the pot.
rotated to it’s highest voltage point was .297
volts. I left the pot set it the exact same
posistion as the old one. (near the center of it’s
range). If I back the throttle down to just above
an idle posistion the engine will begin to run
smooth again. After trying to accelerate several
times it will “catch” and begin to operate
normally. It does not do this every time and never
once a speed above about 40 MPH is obtained. It
makes no difference whether the engine has just
been started or is at operating tempreture.
Any suggestions?
Thanks, Phil
P.S. - Thanks for all the help with my stuck boot
lid lock. The easiest suggestion worked. Sprayed
the lock with lubricant and waited a couple of
days and it opened right up!
Date: Mon, 16 Sep 1996 12:13:47 -0700 (PDT)
Subject: XJ3 Fuel Cutoff “USEFULNESS”
Fellow Jag lovers,
Last week I was trying to park the jag in downtown Seattle, and
the closest lot I could find was called “Secured Parking”. After I parked
my car, a dark foreign man approached and asked for my keys. What!
“This is secured parking,” he said, “you give us your keys and we
watch the car for you.” Sure enough, he had a wall full of keys in his
little booth. I gave him the keys (which he tagged and put on the wall),
but before parting the lot I used my wife’s spare key, opened the
passenger car door, and lifted gently on the fuel cutoff plunger. Of
course it’s not foolproof, but I’m pretty sure that it’s not too widely
known.
On another note, I’ve “Secured” a stable E-mail address: meboe@atc.boeing.com Greg Greg Meboe meboe@mont-blanc.scs.wsu.edu Web site>> http://www.scs.wsu.edu/~meboe Mechanical Engineer Boeing Payloads Division '85 XJ-12 H.E. (daily) '67 Spit-6 '74 TR-6 From: “Jim Cantrell” jimc@sysdiv.sdl.USU.edu Date: Mon, 16 Sep 1996 13:52:43 MDT Subject: Re: GM 400 throttle switch Russ Lehman wrote:
My guess is that it is the kickdown terminal for the TH400
transmission. This transmission uses a solenoid kickdown. on the
XJS, there should be a micro switch that switches on 12V under full
throttle. This activates the solenoid. THis wire run hot all the
time could certainly make the trans stay in second or even first gear
depending on the shift body specifics. My guess is that you either
found the wrong terminal that is hot all the time or your switch is
stuck “on”. Try checking the switch with an VOM for proper operation
and if bad, replace it, it will make a big difference in performance.
Kind Regards,
Jim Cantrell
Date: Mon, 16 Sep 1996 14:58:16 -0500
Subject: AC vents question (85 XJS HE)
Yet another AC question. (85 XJS HE)
I have a problem with the center ventilation opening (right above
the trip computer). It looks like it has a mind of its own. When
the air flow is directed towards the front window (defrost position)
then no air flows through the center vent (that’s good!). But when
I switch to either HIGH, AUTO, or LOW no air comes out of the center
vent for about 5 to 10 minutes, then it opens and everything works
fine. Does anyone know where the vacuum controls are, how to get to
then, and what should be oiled?
Also, I have a feeling that my climate control is not very responsive
to the temperature setting. In my car, on a very hot day, setting the
temp dial to 65F does not imply max power fan output. Few minutes
later the fan might speed up. When it gets cold in the car, and I
raise the setting, again, it takes few minutes before I get any kind
of response from the car.
Thank you,
Vlad
85 XJS HE
Date: Mon, 16 Sep 1996 14:53:51 -0700
Subject: 1967 e type 4.2 2+2 kickdown cable
Need to find out if there are any NOS-New-Rebuilt or after market
kickdown cables for a Borg Warner model 8 transmission.
My cable is comming undone at the adjustment end, next to carb linkage.
Please post answer on list or e-mail me directly.
Date: Mon, 16 Sep 1996 13:00:49 -0700
Subject: Re: XJ front susp. upper bushes.
Jeffrey,
Well you must be talking about old Jags not the XJ6 and newer. The
newer cars, specifically S3 XJ6 and XJS are very easy to do. Just
support the lower a-arm and unbolt the upper ball joint.
Hi Gunnar,
Date: Mon, 16 Sep 1996 16:41:18 -0400 (EDT)
hanging?? (I guess I should next check if the switch is bad)What is this switch for, and is there a problem if I just leave it
It is the transmission kickdown switch. It is a normally opened
switch. When the switch is engaged it forces a downshift via a
solenoid on the transmission thus providing for rapid acceleration.
No switch means sluggish acceleration from third gear. No the
“repairman” was not correct in leaving it disconnected. It sounds
like either the switch is broken and stuck in the engaged state,
or it is simply improperly adjusted. Thus when the wire is connected
the car is permanently in the downshifted condition.
Thomas E. Alberts
Date: Mon, 16 Sep 1996 14:18:42 -0700
Subject: FW: XJ3 Fuel Cutoff “USEFULNESS”
I have an '85 XJ-S(also in Seattle). Anyone know if the procedure
listed below also will work on an XJ-S?
Aaron
'85 XJ-S
Sent: Monday, September 16, 1996 12:13 PM
Subject: XJ3 Fuel Cutoff “USEFULNESS”Fellow Jag lovers,
parked
wall),
known.
meboe@atc.boeing.comGreg Greg Meboe meboe@mont-blanc.scs.wsu.edu Web site>> http://www.scs.wsu.edu/~meboe Mechanical Engineer Boeing Payloads Division '85 XJ-12 H.E. (daily) '67 Spit-6 '74 TR-6
Date: Mon, 16 Sep 1996 16:33:38 -0700
Subject: XJ 40 Alarm transmitter
My 93 XJ 40 did not have the remote door lock/ alarm arming transmitter
when I purchased the car. I ordered the part from the dealer and have
attempted to program the transmitter to the motorcar… I was told to
disconnect the neg terminal of the battery and wait 15 min before
reconnecting. At that time there should have been a “low moaning sound”
from the car and I was to push the transmitter button 5 times.
Well no moaning sound and no working remote. I waited up to five minutes
after reconnecting the battery. Any ideas?
Also the bulb - out indicator light illuminates when the side lights and
head lights are on yet all lamps are working and the correct Jaguar
bulbs. Very frustrating.
Thanks in advance
Bruce E. Life is Way Good!
Amana, IA 52203
USA
Date: Mon, 16 Sep 1996 15:16:21 -0500
Subject: Hood latch on XJ6
Thanks to whoever it was that suggested making sure the two latch pins were
parallel.
I took the handle of a 1/2" socket wrench and gave it three whacks toward
the windshield. It would now not close so I gave it one whack back toward
the grill.
Voila, it now closes and stays closed until the release is pulled.
The good old, “Whack it with a wrench” cure.
Jim
“Better an outlaw than not free.”
Nance O’Neil
From: David J Shield David_J_Shield@ccm.fm.intel.com
Date: Mon, 16 Sep 96 14:02:00 PDT
Subject: Re[2]: cowl inlets on E-types; and louvers on XJs
Awesome, John. The results will be very interesting to me.
Thanks,
John
Date: Mon, 16 Sep 1996 14:22:51 +0700
Subject: Turbos for a V12
A friend has an XJS that he wants to stuff twin turbos into (yes,
he’s a speed freak of the highest order). Anyone done this or know
someone who has? Any sources on parts?
TIA
Greg Price
Date: Mon, 16 Sep 1996 15:33:25 -0700
Subject: Re: XJ 40 Alarm transmitter
Bruce,
You were given instructions for an earlier car that had a bad backup
battery.
With the ignition off turn the alarm on in the center console. Turn
the ignition on, then turn the alarm off. Turn ignition off, rock alarm
switch until you hear the chirping tone and then hit the remote. The
system is set up for multiple remotes. Since you only have one just
keep hitting it until everything works.
from the car and I was to push the transmitter button 5 times.Well no moaning sound and no working remote. I waited up to five minutes
after reconnecting the battery. Any ideas?Also the bulb - out indicator light illuminates when the side lights and
bulbs. Very frustrating.Thanks in advance
Amana, IA 52203
USALottery: A tax on people who are bad at math.
Michael P. Neal ASE Master Technician, Jaguar Certified
'93 Ducati 900SS '83 Porsche 944 '85 Jaguar XJS
Home (707) 829-8464 Work (707) 577-0101
http://www.wco.com/~mneal (always under construction:-)
Date: Mon, 16 Sep 1996 15:16:17 -0500
Subject: Expensive over night parking (XJ6)
Has everyone but me heard that you should not use the park positioon on an
automatic transmission if the car is on a hill?
It seems stupid to put a park position on a transmission if the only time
you can use it is when you dont need it (on level ground).
Today I spent $270 learning that the park position is not to be used.
Last night I parked on a slope and put the tranny in Park. When I got back
to the car and tried to pull it out of park the cable bent and the thing was
permanantly in Park.
$35 for a tow truck and $235 more in labor to replace the cable (the cable
was free) I now have a driving car again.
I will never again use the park position, that was a very expensive lesson.
Jim
Nance O’Neil
Date: Mon, 16 Sep 1996 16:37:32 +0700
Subject: Re: Hood latch on XJ6
“Don’t force it; get a bigger hammer”
(sign found on ancient Roman chariot shop wall)
(translated)
Greg.
G. W. Price & Company, Ltd
Santa Fe, New Mexico
Consultants in research, information management
and program evaluation
Probabilistic Record Linkage Services
Date: Tue, 17 Sep 1996 09:05:37 +1000 (EST)
Subject: XJ40 headlamp preferences
For some unknown reason, I am now only getting a digest of jag-lovers mail,
which may or may not be a good thing. On the subject of headlamps on the
XJ40 models of about 1988/89, I believe that it worked like this, at least
in Australia. The base model XJ40 was labeled XJ6 and had dual round
headlamps. The Sovereign had square (or really rectangular) headlamp
assemblies as (apparently) Jaguar considered them to look more up-market.
Not everyone agrees with them on this point. As someone (I think it was
Jan) pointed out, the square ones are horrifically expensive, but if you
don’t mind fitting protectors, these are readily obtainable for about
A$175/pair. Alan.
Date: Mon, 16 Sep 1996 16:45:17 -0500
Subject: Kirbys question on oil pressure senders.
Kirby and I have been having a discussion off the list on the oil pressure
senders for the XJ6 and for the XJ-S. Apparently they suffer the same problems.
I have opened up one from a series 3 XJ6 and found a mechanical diaphram to
wirewound pot contraption. It essentialy acts as a variable resistor that
shows high resistance at low pressure and low resistance at high pressure.
This is in series with the guage which apparently just measures current.
The question was, “what is the resistance range required.” When I opened it
up the wilre was already broken, but by measuring the pieces I determined
that it was PROBABLY about 10 ohms at min scale. My ohm meter is very
inacurate, so this is not a definative answer.
However if anyone out there has an oil pressure guage that they could hook a
potentiometer up to and a 12 volt battery, they could determine the end
points empiricaly. Be carefull and start with a high resistance so you dont
dammage the guage.
Kirby is looking for the information so he can research other senders that
might substitute.
Jim
Nance O’Neil
Date: Tue, 17 Sep 1996 09:45:03 +1000 (EST)
Subject: 89 XJ40 Air Conditioning
Following a number of queries about the AC system on the XJ40, I have
checked out all the literature and notes I have and now believe that I can
describe the system fairly accurately as it applies to my 1989 XJ40, so here
goes.
The system has two modes of operation - auto and manual. On auto, the
system adjusts the temperature of the air entering the cabin of the car to
achieve the set temperature as rapidly as possible with the selected fan
speed. As the temperature nears this set temperature, the temperature of
the inlet air gradually changes towards the set temperature and the fan
speed reduces. The system then continues to blow in air at a temperature
which just maintains the set temperature. At face level, only cold air
comes through the centre vent (if the system is heating the car, this vent
is closed) and the temperature of the incoming air is varied by varying the
mix of air through the heater matrix and the AC evaporator. When only cold
air is required, a vacuum operated valve shuts off water to the heater
matrix. This valve is normally closed, opening only (if required) when the
water temperature is sufficient to heat. The rate of cooling is also
determined by what Jaguar describes as humidity settings, selected by
pressing buttons and illustrated by drops. Three drops means that the AC
compressor does not operate and only heating is available. Two drops is for
minimum cooling, 1 drop for intermediate and no drops for maximum cooling
rate - minimum evaporator temperature range. A slide control varies the
temperature at face level by comparison with that at foot level, but only by
a few degrees celsius and only downward. ie full right and the face level
air temp is just below that at foot level, full left and it is a few degrees
cooler. In the manual mode of operation, the inlet temperature of the air
is constant and depends on the humidity setting and the temperature setting.
I hope this helps. Alan.
Date: Mon, 16 Sep 1996 17:04:08 -0700 (PDT)
Subject: Engine Paint Recommendations?
Fellow Jaguar Lovers,
Our sedan is currently an XJ-11 (one of the injectors is not
clicking), and it occurred to me that relying on one british car for daily
transportation is kind of dumb anyway. So, I’m building a 2.5 litre
engine for the Spit-6 in order to have a backup british car.
I want an engine paint which is a little more robust than the
standard Krylon Engine Spray Paint. My first thought, (I’m a painting
newbie) is DP-80 followed by Centauri.
Responses can be private so as not to clog the list.
Thanks,
Greg
Greg Meboe meboe@atc.boeing.com
Date: Mon, 16 Sep 96 17:12:38 PDT
Subject: XJ40/Jaguar World
Somebody mentioned that he has already received the latest issue
of Jaguar World. Is there a big article in there on the XJ40?
What does it talk about?
Regarding sqare vs. round headlights on the XJ40, I have no particular
preferences, and I’ll stay with whatever came out of the factory (square
on my 91 VDP). I’m not particularly a big fan of XJ40 styling either
despite being an owner, and I don’t think either headlight style
will make the XJ40 look as good as a series III. Nevertheless, after
getting used to it, I think the XJ40 has got its own special character.
I still enjoy looking at them when I see them on the road.
It’s kind of like the Triumph TR7 and the Jaguar XJS. They look kind of odd
and “untraditional” at first, but eventually the look grows on you and,
you will appreciate it for what it is.
Another plug for the XJ40 is that it is more reliable than its
predecessors, and does drive very well. Even the series III, I
believe, has too many things that need servicing or go wrong
than is acceptable.
Roger Peng (408)765-7863
Intel Corporation
Design Technology, Physical CAD
End of jag-lovers-digest V2 #359
id for jag-lovers-digest-out; Tue, 17 Sep 1996 14:40:10 +0200 (MET DST)
Date: Tue, 17 Sep 1996 14:40:10 +0200 (MET DST)
Message-Id: 199609171240.OAA25927@ekeberg.sn.no
Subject: jag-lovers-digest V2 #360
Precedence: bulk
jag-lovers-digest Tuesday, 17 September 1996 Volume 02 : Number 360
Re: jag-lovers-digest Rubber Widgets
Re: Oil Weight
Re: S3 and XJ40 queries (The headlamp question)
Re: Series III ('85) XJ6 cylinder head off!
British Car Parts in Florida
72 xj6 SI
Re: Expensive over night parking (XJ6)
Internet resources
Majestic Specifications
Re: 89 XJ40 Air Conditioning
Subject: XJ6 bonnet opening.
Re: Bonnet openning (NOT XJS air Damn!)
Front subframe bushings XJ6 SIII
wont’t run
E-type S2, Interior rear view mirror
Possible SIII V12 purchase
Possible SIII V12 purchase (again!)
RE: Possible SIII V12 purchase (again!)
Dealership or Mechanic in Kansas City Area
Date: Mon, 16 Sep 1996 17:29:46 -0700 (PDT)
Subject: Re: jag-lovers-digest Rubber Widgets
Gentlemen:
FYI-I have just received a new catalogue with some weatherstripping (a
trunk seal) from Metro moulded parts, Inc. Minneapolis, Mn. USA. My old
one was 10 years+ old. Glad to see they have greatly expanded their Jaguar
line–even back to Mark IVs and Mark Vs, considerable XK-Es 120 etc.
stuff. Not just weather stripping but a lot of other stuff like stablizer
bushings, air filter to carb gaskets, window channels, headlight gaskets,
etc. etc.
Fortunately they have a www site:
www.metrommp.com
Thought I should pass this along–one of you more experienced types
(which admittedly is 99% of you!) might want to check them out
and consider adding them to the list of suppliers. I am pleased with
their service and product.
Another thing, as of next weekend, I will delist myself for 3-4 weeks
from Nick’s excellent column as I am dragged by my wife kicking and
screaming backpacking through Tuscany and Umbria in Italy. I will rejoin
ASAP.
(Anyone know good wrecking yards in Tuscany.?)
Tom Carney Vancouver Canada
1969 Mercedes 250C (daily driver)
1949 Jag Mark V drophead (under restoration)
Date: Mon, 16 Sep 1996 20:43:07 -0400
Subject: Re: Oil Weight
Jim,
It was suggeted by Juguar Services in Harvey, IL that I use Castrol 20-50 in
my '85 XJ6 VDP. I bought it three years ago, and so far it doesn’t burn or
leak any oil.
Steve Clements
Date: Mon, 16 Sep 1996 21:06:25 -0400
Subject: Re: S3 and XJ40 queries (The headlamp question)
Esthetically, the car was designed with the “square” lamps and I feel these
more in keeping with the rest of the design… The Squares say either “I
bought the cheaper car” or “USA spec–the unreliable years.”
Personally, I find the square lamps in my 1990 to be quite powerful, and if
seeing where you’re going at night is a priority, I would recommend them.
The fog lamps, by comparison, are quite dim.
I would also recommend checking out wrecking yards for parts such as these.
Robert MacLeay
1990 XJ40 VDP Majestic
Date: Mon, 16 Sep 1996 21:07:09 -0400
Subject: Re: Series III ('85) XJ6 cylinder head off!
I had this problem.
2) No compression (well not much) on number three - burnt exhaust valve (diagnosis confirmed!)
This one, too.
Yep.
4) A good de-coke while I'm in there. 5) Install bucket guide stake-down measures 6) Check head for flatness and skim if necessary.
Had this stuff done by a machine shop.
Yes, probably yes (I replaced all exhaust valves, reused my intakes),
probably yes (I cleaned but did not polish), and yes. I have the
benefit
of having my engine out of the car. I presume there is an order of
magnitude increase in effort required to perform above tasks in the
vehicle. Bonnet removal is recommended for timing chain kinds of
procedures. (If you will have the car inoperative for a while.)
I recommend replacing all the fuel supply and return rubber hoses.
Mine were leaking at most of the hose clamps. I recommend chrome
cylinder head nuts and cam cover nuts when you put everything back
together. Cosmetic only - no functional benefit.
traps laying waiting for the innocent DIY’er : you could lose a
valve sprocket bolt
Funny. I lost a cam sprocket bolt in the bowels of my timing cover.
Fortuneately I disassemble the whole engine so I could recover the
bolt. That wasn’t the only reason I took apart the whole engine!
Date: Mon, 16 Sep 1996 19:02:18 -0500
Subject: British Car Parts in Florida
I just got this off a vintage race list I belong to. Maybe it will be
usefull to someone.
Hi all,
I just have to share this find --[ insert usual disclaimers, i do not work
for this guy. ]
Tucked away in sunny Fort Lauderdale is a treasure throve of used British
Car parts. Over the years Joe Peters, of Imported Auto Emporium
bought\serviced\sold all makes and models of britcarsand has collected
a few various bits.
He has wooden steering wheels, mag wheels, carbies, seats, engines and
engine parts to name a few.
To the best of my knowledge he will even mail\ship parts.
Interested ? Contact JOE 954-561-1199ICEBERGnKADIR
Jim
Nance O’Neil
Date: Mon, 16 Sep 1996 21:36:21 -0400
Subject: 72 xj6 SI
What kind of money is a parts car worth, and is it worth it to even bother
with.
The body is straight, chrome, glass, rearend is good, no eng/ trans or
interior,
I’d like to get $ 350.00 for it any suggestions???
Date: Mon, 16 Sep 1996 19:44:27 -0500
Subject: Re: Expensive over night parking (XJ6)
I think if you had
applied the parking brake (if it is operational, and effective) first, then
you should have been able to use the park position on the tranny without out
probs. (and don’t forget to turn the wheel to the curb!!) I realize I’m now
just stating the obvious to you, but thought it might serve as a reminder
anyway to others.:-). Bye.
What you say is true, but why have a “Park” position on the tranny if it
cant be used. If the parking brake works, you DON’T NEED the transmission
park position. If the parking brake doesn’t work, you CAN’T USE the park
position on the tranny or it will get stuck. Its sort of a catch 22 isnt
it? Sounds like what an American company would do, no Jaguar.
Cadillac uses solid rods to shift the transmission and you can manhandle it
out no mater what.
Anyone ever try to replace the shift cable on the XJ6 or XJS with a solid
linkage?
Jim
Nance O’Neil
Date: Mon, 16 Sep 1996 21:55:06 -0400
Subject: Internet resources
Check out special.cars.com. There are three good Jag articles, including a
drive report on the XJ13.
http://www.specialcar.com/newsreports/index.html
Carburetor tuning tips available from the Triumph gang:
http://www.vtr.org/maintain/carbs.html
DIY wheel alignment from the same folks:
http://www.vtr.org/maintain/diy-alignment.html
Interesting racing enthusiast site (lump-oriented, but terrific none the less.)
Everything you ever want to know about gasoline:
http://miniweb.aspect.com.au/miniweb/gasoline.html
Or, for more on gasoline:
http://www.cs.ruu.nl/wais/html/na-dir/autos/gasoline-faq/.html
Mike Frank
1969 E-Type 2+2
Date: Mon, 16 Sep 1996 21:58:51 -0400
Subject: Majestic Specifications
Greetings All -
Interesting traffic on the Majestic specification of XJ40.
What exactly was the spec? Extra long wheelbase? How
much longer? What level of trim, headlamps, grille,
seats, carpet, wood, engine, model years, Europe vs. USA
differences, etc.?
Will anyone elucidate, please? Thanks.
Date: Mon, 16 Sep 1996 22:13:15 -0400 (EDT)
Subject: Re: 89 XJ40 Air Conditioning
Alan wrote up a pretty good description on the operation of the Delanair
system used in XJ40’s and later S’. However, as is obvious by the fact
that I’m replying, I have two minor corrections.
First off is the difference between manual and automatic modes. In
automatic mode, the system tries to get the cabin temp to the selected
temp, and then hold it there. This often requires starting out with a
discharge air temp quite different from that which is selected.
In manual mode, the system holds the discharge air at the selected
temp,and ignores actual cabin temp. This feature is much more useful
in the S convertible than it is in the sedans.
The other thing is the function of the water valve and temp cut out. The
water valve is normally open, not closed. It is closed only when the system
determines that it needs maximum cooling. The temp cut out monitors the
heater inlet water temp. It keeps the system shut down until the heater
temp goes over 104 F. This is overridden when the system needs full cooling
(water valve shut, so no heat in matrix), and I believe in defrost mode.
Other than the addition of the manual mode, the Delanair system has the
same logic and stratagies as the older electro-mechanic system used in
S II/III and S’.
Randy K. Wilson
randy@taylor.infi.net
Date: Mon, 16 Sep 1996 21:49:37 -0400 (EDT)
automatic transmission if the car is on a hill?Last night I parked on a slope and put the tranny in Park. When I got back
permanantly in Park.Jim
Come on, Jim. Park is for parking. Which car was this (i.e. which trans;
I believe you have a 350 and a 400)?
Randy K. Wilson
Date: Mon, 16 Sep 1996 21:55:55 -0600 (CST)
Subject: Subject: XJ6 bonnet opening.
Cosmo wrote:
The bonnet on my XJ6 SIII has started to open when on the move.
I have noted various solutions posted but nobody seems to have mentioned
moving the spring loaded striker plate forward (towards the radiator) so
that the latch more aggressively engages the bonnet pin recess. Observe
each striker plate and, if this is the problem, the one popping open will be
obscuring less of the aperture. On my car (1985 XJ6 Series III) the striker
plate, when properly adjusted, forms a half moon crescent which obscures
about fifty percent of the hole. Adjust by loosening the two bolts which
hold the mechanism (one on either side of the aperture through which the
bonnet pin travels). If there is no forward adjustment possible, remover
the bolts and elongate the slotted holes using a round file. Should the
bonnet pin be striking the aperture, and the pin is not bent, loosen the
three bolts that hold the bracket and reposition the entire assembly. Again
this may involve elongating the bolt holes in the bracket. If this doesn’t
work, the try the rubber mallet suggested in the earlier post - perhaps by
leaning out of the window and hitting it every time it pops up.
Tony Gardner
1986 XJ6 Series III
Date: Mon, 16 Sep 1996 21:58:32 -0500 (CDT)
Subject: Re: Bonnet openning (NOT XJS air Damn!)
On Fri, 13 Sep 1996 12:40:13 +0100 Cosmo wrote:
The bonnet on my XJ6 SIII as started to open when on the move.
This is a tad annoying and has now become serious as both sides now
do it occasionaly. The Fine Manual only mentions adjusting the release
cable and I can’t see any adjustment in the catch mechanism. Is
there any trick to this?After a local garage had fixed the hinges, the bonnet shut and opened
with no trouble, but occassionally the rhs would pop open out of its
catch. Rather than taking it back, I noticed that the bonnet was not
catching properly when it was should, although it appeared to do so.
A final press in the offending area made sure the bonnet catched, and
stayed shut.
There is another thing to check when an XJ’s bonnet won’t stay closed.
Be sure that the screws–particularly the Phillips head ones–holding the
latch mechanisms to the body are TIGHT. They have a tendency to work
loose, and an early symptom is for the bonnet to pop open. If they get
real loose, however, you will have trouble getting the bonnet to open at
all. For some reason–at least on my 1979 SII–Jaguar did not use lock
washers on these screws, even though there seem to be lock washers on
just about everything else! Needless to say, mine now have lock
washers, and they haven’t worked loose in a while.
Loose diagonal struts (from the firewall center to the fenders) can also
cause bonnet problems, but you should probably hear some “clunks” over
bumps or in turns.
One more thing. PLEASE don’t push one corner of your bonnet down to
secure it. That’s a real good way to warp it. Re-open it fully and then
close it from the front center (top of the grill) like Sir William intended.
Larry Lee
Date: Mon, 16 Sep 96 20:26:00 PDT
Subject: Front subframe bushings XJ6 SIII
Gunnar Helliesen writes:
>......I also replaced the steering rack bushes with the original
>Jaguar Sports bushes. I couldn't believe the difference! Anyone out
>there thinking about doing this - stop thinking and get to it right >
>away!
Agreed (though I used the XKU polyurethane bushes - 4 years ago and
still as new).
>.....more from Gunnar...
>bushes (one each side, of course) holding the whole front suspension
>to the car (or so it seems). Mine are shot. How much work is it to
>replace them? Does the weight of the engine also lie on these
>bushes? Recommended procedure and Real Life(tm) experiences?
I had my mechanic do this - it looked difficult to me..... If one of
you has done this in your own garage, my hat's off to you!
Date: Mon, 16 Sep 1996 22:01:27 -0600
Subject: wont’t run
I have a '77 Jaguar XJS. It runs fine when it’s cool. After it’s warm it
cuts out and quits. Seems like an old fashion vapor lock. Have to let it
sit several hours before I can get it started. Is it the fuel pump?
Thought it was the oil sending light - but that wasn’t it. Any help for
Hopeless in Wyoming?
Date: Tue, 17 Sep 1996 00:42:09 -0500
Gentlemen:
etc. etc.
www.metrommp.com
ASAP.
(Anyone know good wrecking yards in Tuscany.?)Tom Carney Vancouver Canada
Do you have the mailing address and phone number for Metro Moulded Parts?
Date: Tue, 17 Sep 96 10:23:00 PDT
Subject: E-type S2, Interior rear view mirror
A friend of mine owns an E-type Series 2. He`s having a hard time finding
a source for the original interior rear view mirror (used or new). The
colour was grey and it came with a dim function. Anybody out there who
can help him?
Are Lorentsen
82XJ6
From: brownd@filon.ml.com (Dave Brown - London Dev X1818)
Date: Tue, 17 Sep 96 09:33:23 BST
Subject: Possible SIII V12 purchase
Further to my previous post about a possible purchase of an 88 SIII V12
Sovereign…
First, thanks to all who replied. I gather that 6000 pounds is a good price for
a SIII V12! I’ve checked the car over more carefully now and it still seems a
pretty good buy. The only “faults” on the car I can find are:
pepperpot alloys are a bit oxidised;
slight pitting on one chrome door handle;
radio/cassette not working (garage believe just not connected as PO removed his
CD player);
Tiny paint chip next to boot lid;
er…that’s it, I think.
There’s not a spot of rust I can find (I’ve looked underneath on a ramp), and
she drives beautifully. The garage will only go down to 6250 but I still think
it’s a good buy.
As you can probably tell by the tone of this mail I think I’m smitten…
The only factor I’m still concerned about is that it won’t fit in my garage and
will therefore be exposed to the elements for the next few years (until I move
to a bigger house with a bigger garage!).
Unfortunately, I’ll have to sell my Daimler 250 V8. So if anyone is interested
in giving Daphne a good home, please get in touch (good mechanics, interior,
CWW’s, PAS, body needs some work).
I’ll keep the list informed as to what it’s like to own a V12.
Cheers,
David Brown
brownd@ml.com
///_/_/_/_/////_///______
/_/_//_/_/_/_/_/____
/_/_/_/_/______/_/_/_/______
/_/_/_/_/_/_/________/_/_____
___/_/_/////_/_/_/_/_/______
/_/___/_/_//_/_/_/____
///_/_/_/____/////_///_________
Date: Tue, 17 Sep 96 11:26:39 BST
Subject: Possible SIII V12 purchase (again!)
Sorry…
One think I forgot to mention. is there any specific thing I should check/ask
about before parting with my hard-earned ?
TIA,
David Brown
brownd@ml.com
Date: Tue, 17 Sep 1996 14:21 +0200
Subject: RE: Possible SIII V12 purchase (again!)
Yes David, insurance costs if your car has to stay outside.
Frans.
One think I forgot to mention. is there any specific thing I should=20
check/ask
about before parting with my hard-earned ?TIA,
DavidDavid Brown
brownd@ml.com
=20
=20
=20
=20
=20
=20
=20
///_/_/_/____/////_///_________=20
Date: Tue, 17 Sep 1996 06:57:33 -0500
Subject: Dealership or Mechanic in Kansas City Area
I will be in the KC area for a few days next month and am considering =
having some work done at the same time. Your recommendations or =
experiences would be greatly appreciated. Please respond privately. GO =
CHIEFS
End of jag-lovers-digest V2 #360
Return-Path: @owner-jag-lovers-di1
Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4)
id for jag-lovers-digest-out; Wed, 18 Sep 1996 01:22:35 +0200 (MET DST)
Date: Wed, 18 Sep 1996 01:22:35 +0200 (MET DST)
Message-Id: 199609172322.BAA01423@ekeberg.sn.no
X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f
To: jag-lovers-digest@sn.no
Subject: jag-lovers-digest V2 #361
Reply-To: jag-lovers@sn.no
Errors-To: @owner-jag-lovers-di1
Precedence: bulk
X-Newsgroups: mail.jag-lovers-digest
jag-lovers-digest Wednesday, 18 September 1996 Volume 02 : Number 361
Paint codes -Light blue 1970 E-type.
XJS twin turbo
Re: 72 Series I XJ parts car.
V12 motor for US$365
Jaguar Daimler Heritage Trust
cold start injectors on '85 XJ-S?
XJ-S Fuel Cutoff
Dead Cigar Lighter and Trip Computer on 83 XJ-6
Re: jagdigest #360 Rubber Widgets
Water Control Valve, '83 XJ-6 III
Questions re Early XJ-S
Body work
XJ6 Stake-down & Bumper to Bumper
NEW TV NETWORK
Re: cold start injectors on '85 XJ-S?
NEED XJS WOOD
[none]
re: Front suspension mounts etc
FTP site?
83 XJ-6 Front End ReBuild
XJS twin turbo
Date: Tue, 17 Sep 96 08:58:00 DST
Subject: Paint codes -Light blue 1970 E-type.
Recently, on the Jaguar list, I asked if anyone had the paint
codes for Jaguar Light Blue used on 1968 - 1972 E-type cars.
The responses I received were helpful for matching a part
of the car but as I have had the car stripped by Redi-strip in
1990, I don’t have any parts to match to. E-jag magazine had
a list of the paint codes for all the cars, along with the years of
usage in their Nov. 1985 issue, which I have. The codes are
for Dupont Lucite and Dulux paint. When my painter used
these codes, the colour was not proper ( it was much more of
a grey than a blue).
He has had no luck with the suppliers of 3 brands of paint.
Can anyone help with a paint code?
David Chiahotny '70 E-type ots
Hamilton, Ont. '71 Spitfire
E-mail : david_chiahotny@dofasco.ca
Date: 17 Sep 96 09:08:02 EDT
Subject: XJS twin turbo
XJS twin turbo - Yes, this has been done in Aus - at the behest of
Australia’s richest man (name of Packer) a few years ago. What details may be
available, I doubt. Whether it was regarded as a great success I am also not
sure.
By the way, we are told that the XK8 will appear at the Sydney display
day Oct 13th. Looking forward to that! It might even persuade the wife and
kids to come … Regards, John Elmgreen
Date: Tue, 17 Sep 1996 15:37:57 -0700
Subject: Re: 72 Series I XJ parts car.
Cindy!
I’d love to take it off your hands, it’s just that it would probably cost your
price tenfold for me to have it shipped home to Norway! #*$ "~
Bard
From: eugene.siciunas@utoronto.ca (Eugene Siciunas)
Date: Tue, 17 Sep 1996 09:45:11 -0400
Subject: V12 motor for US$365
Folks, I just received the September newsletter from Obsolete Automotive,
an MG/Triumph/Jag parts supplier.
In this flyer, they advertise a “Jaguar XJ12 V12 Engine” text follows:
“Yes, this is a complete V12 motor out of a late 70’s or early 80’s XJ12.
It has all the fuel injection parts still mounted, just like it was removed
from the car. We are told that the owner swapped this engine for a 350
Chevy. This is a fairly common swap for people who are not too concerned
about originality.
This engine is said to be in good condition but we are offering it for sale
‘cheap’ with no guarantee whatsoever. It has most of its ancillary
components still mounted, including the torque converter. It does not
include the starter or alternator.”
Price is $499 Canadian, or about US$365. They are located at 110 Kendall
Street, Point Edward, Ontario. This is just north of Detroit, on the
Canadian side. Their phone/fax numbers are: (519) 337-3232, fax (519)
336-5936.
Their Web page is http://www.sarnia.com, e-mail obsolete@ebtech.net
This may be interest to someone nearby for parts, the price sure is right.
I’d buy it myself, just to have a V12, but my '66 E-type FHC is a six.
I have no relationship nor interest in Obsolete Auto, other than as a
satisfied customer, etc…
Regards
| Eugene Siciunas | University of Toronto |
| Director, Computing & Networking Svcs.| 255 Huron St., Suite 350 |
| Eugene.Siciunas@UToronto.CA | Toronto, Ontario |
| Voice: (416) 978-5058 FAX: 971-2085 | CANADA, M5S 1A1 |
Date: Tue, 17 Sep 96 14:48:40 gmt
Subject: Jaguar Daimler Heritage Trust
Dear Jag-lovers.
There is more updated information (plus all the old) from the Jaguar Daimler
Heritage Trust at
http://www.jagweb.com/jdht/jdht.html
The link is there from Nick’s jag-lovers page
New information there comprises
Photographs from their 1996 Season (very much a Daimler affair)
The oldest Daimler, and an X300 Daimler
Daimlers in the Browns Lane Museum,
75 Earls Court XJS,
Last Cabriolet (Burgendy),
Last Convertible (White)
End of the XJS
XJS and XK8
XK8 Press Pictures,
P40 XJS and P60 XJS for the JDHT collection
A modern Daimler Century
The Daimler Corsica concept car
Information on contacts for a tour of the factory if you are visiting the UK
The XK8 engine and transmission details with graphics for techno-freaks. This
is reproduced with permission from the Jaguar Employees Topics Magazine.
Please note the graphics are fairly large to allow readibility, but the
originals are much better quality. If there is anything there you cannot be
sure about, please contact me.
This contains
AJ-V8 Powertrain Overview,
Mechanical Systems,
Innovative Air Intake System
Oil and Water Systems,
Accessory Drives,
Engine Management System,
New 5-speed Automatic Transmission,
Manufacturing Strategy & Process,
There is also information there on how to obtain the Heritage Certificates for
your car!
Finally, there is another message to us from Tony O’Keeffe, curator of the
Jaguar Daimler Heritage Trust, describing the 1996 season with the Trust.
- Alastair Lauener *
- 1964 3.4 S-Type http://www.sn.no/home/nick/alas.html *
Date: Tue, 17 Sep 1996 09:02:05 -0700
Subject: cold start injectors on '85 XJ-S?
I’ver read many an item regarding cold start injectors. My question is,
does my '85 XJ-S have them?
Date: Tue, 17 Sep 96 09:18:00 PDT
Subject: XJ-S Fuel Cutoff
The fuel cutoff switch ( on US versions anyway, well at least on my 88 ) is
that little black box just inside your door, mounted to the chassie under
the console. There is a little black plastic rod ( all you can see is the
cap ). If you pull this up, you will see the rod or shaft is painted red.
This is intended to be an inertia switch, that if you hit something hard
enough that this will “cut off” the fuel flow. You can easily test this
yourself by popping the switch up, & try and start the car. If your thief
does not know about it, it could be enough for them to leave the car, if
they do know about it, it will maybe 5 seconds to their theft time.
John Himes
88 XJ-S 97K Miles
Date: Tue, 17 Sep 1996 11:11:19 -0500
Subject: Dead Cigar Lighter and Trip Computer on 83 XJ-6
I’m an electrical guy by nature and trade, so this one realy hurts to ask,
but here goes…
83 XJ-6 Electrical: The Cigar Lighter and Trip Computer on 83 XJ-6 have no
power suddenly. I’ve traced circuitry back to the fuse box and found that
for the two fuses controlling these respective devices, there is no power at
the “line/battery” side of the terminals (!)?. The shop manual I have does
not cover the wiring harness, nor the routing, much less identifying any
fusible links which may be culprits(?).
The wiring diagram did make reference to fuses located on each side of the
console side casing, but these fuses checked out all right.
I even traced the circuits back to a fuse in the “ground” side of the
wiring, which is tied to a good solid ground in the left hand area of the
same console side casing.
Again, with no power available at the fuse block, I’m wondering where else
to check for problems?
Denny Alford
'83 XJ-6 III
Date: Tue, 17 Sep 1996 09:10:35 -0700 (PDT)
Subject: Re: jagdigest #360 Rubber Widgets
Bob Richardson asked for Metro Moulded Parts, Inc. phone/snail mail
address.
www.metrommp.com
Toll Free from Canada-USA: 1 800 878-2237
Fax: 1-612-757-2803
Phone: (information etc.) 1-612-757-0310
Snail mail:
11610 Jay St.
P.O. Box 48130
Minneapolis, Mn. 55448
USA
tom carney vancouver
'69 Mercedes 250C (“Brunhilda”)
49 Jag Mark V drophead (in various baskets)
Date: Tue, 17 Sep 1996 10:58:50 -0500
Subject: Water Control Valve, '83 XJ-6 III
Previous postings have addressed the substitution of a commonly available
Water Control Valve, and I wondered if anyone could volunteer a part number
for same to used on an '83 XJ-6 III?
Also, following Randy Wilson’s randy@taylor.infi.net post regarding the
same part on “XJ40’s and later S’” I’m currious as to whether this one is
intended to be normally open or closed?
Date: Tue, 17 Sep 1996 12:43:06 -0700
Subject: Questions re Early XJ-S
I have a 1977 XJ-S that I am trying to restore and a 1979 XJ-S bought
recently for parts. My first goal is to get the engines running as well
as possible in the vehicles and then to remove the engines. The best one
will go in the restored vehicle after any necessary reconditioning.
Both cars have GM 400 transmissions. My efforts so far have led to
several questions.
Engine numbers:
1977 - 8S8089LA
1979 - 8S13063LB
Do these engines have standard or low compression ratio? Do the numbers
tell anything else about the engines?
Air Filter Housing:
The 1977 has a hole about half an inch in diameter in the right
hand housing (which is bolted to the intake manifold) in the bottom left
corner. Was there once a plug in this hole or is something else missing?
The 1979 does not have this hole.
Both housings on both cars have a short pipe, covered with a
rubber cap, pointing towards the front of the intake manifold. From my
manuals I presume that these pipes are for overrun valves. Why do these
cars not have overrun valves? Should I plan to install them?
Any help will be much appreciated.
John Nuttall
Date: Tue, 17 Sep 1996 13:15:27 -0400 (EDT)
Subject: Body work
Has anyone used a weld-through zinc coating when restoring their
cars? I purchased a can of this material from Eastwood Co. and the
instructions state that it is not a primer and is not to be painted over. I
assume then that it is to be used only along the edges/flanges where pieces
join or overlap to be welded together. However, once welded, what do you do
with it? Does it still protect the metal at the seam? Must you remove any
excess that is outside of the weld area before you prime and paint? If there
is any along the edge of the seam, will the primer and paint adhere?
Another question. Replacement panels come with a black coating.
Should this coating be completely removed before priming or just sand
surface and prime?
Thanks for any information.
Alex H. Lindsay
Date: Tue, 17 Sep 1996 12:49:05 -0500
Subject: XJ6 Stake-down & Bumper to Bumper
Bumper to Bumper is the best thing since sliced bread. After reading =
Jim’s statement that his mechanic had determined that someone had =
already installed the stake-down kit in his XJ6 by looking and feeling =
through the oil filler cap, I decided to do same. Damn if it hadn’t been =
done to my car as well. I specifically asked PO about this and she owned =
the car from about 30K to 74K. She said no but then maybe she forgot or =
maybe it wasn’t called what I called it. Anyway, to all those who =
offered advice (i.e., Gregory Andrachuk, Ryan Border, Jim Isbell, & =
Lauren Pratt), thanks much. Frankly, the consensus was that you probably =
should have this $300 (US) job done professionally or at least remove =
the head to do it unless you’re experienced and confident.
If you’re not sure whether this has been done to your car, remove the =
filler cap (preferably with the engine cold) and look to see if there is =
a piece of metal running from the 6 to 5 guide with a screw of some type =
near each end. Use a paper towel to soak- up the oil for a better view. =
You should be able to feel the ends, side, etc. By using a flashlight =
you should be able to verify that there is not one running from 5 to 4. =
The kit consists of 6 plates that run from 6-5, 4-3, 2-1 on exhaust and =
intake sides. By the way, the exhaust side is the important side – =
problem due to heat – and it is the side visible through the oil filler =
cap.
Happy day, feel Jag maintenance withdrawal setting in after 6 months of =
projects.
Date: Tue, 17 Sep 1996 14:32:50 -0400
Subject: NEW TV NETWORK
IF ANYONE HAS A SATELITE IN THE U.S. YOU SHOULD TUNE INTO SPEEDVISION
NETWORK SAT F4 TRANS. 11, IF IT MAKES COMBUSTION YOU’LL SEE IT HERE.
MANY 50’S RACES LOTS OF OLD JAGS RUNNING AROUND THE TRACKS. YOU HAVE
HAVE TO PUT UP WITH LOTS OF NASCAR STUFF BUT IT’S WORTH THE WAIT. I’M
NOT SURE WHEN IT CAME ON PROBALLY A COUPLE OF MONTHS AGO. ENJOY.
FRANK 85 XJS
Date: Tue, 17 Sep 1996 15:03:08 -0005
Subject: Re: cold start injectors on '85 XJ-S?
Aaron Burnett:
No. They were eliminated somewhere along the line. My '83 has
blank-offs where they went, later models didn’t even have the hole.
– Kirbert | If anything is to be accomplished,
| - Palm’s Postulate
Date: Tue, 17 Sep 1996 15:07:42 -0400
Subject: NEED XJS WOOD
I WAS STUPID AND OVER SANDED MY OLD XJS WOOD THRU THE VENEER, ITS LOOKS
REALLY BAD. LIKE CHEAP PLY WOOD. I PRICED NEW KITS AT $600.00 I’D LIKE
TO SPEND ABOUT $100.00 FOR RE-VEENERING (IF THATS POSSIBLE ?) ALSO
ACCEPTING ANY SYMPATHY WOOD ANYONE HAS SO I CAN DELICATELY TRY IT AGAIN
(ESPECIALLY THE PIECE AROUND CENTER AIR VENT). THANKS.
1985 XJS FRANKP
Date: Tue, 17 Sep 96 11:13:00 DST
So sorry if this is already sent, it bounced back into my in
basket so I am resending it.
Date: Tue, 17 Sep 96 18:40:42 UT
Subject: [none]
I’m looking for help , I’m want to buy A 94xj6 but I’m hereing all kinds of
bad things about lucus elec. and was wondering if anyone can tell me if the
car is sound or im i going to have all kinds of trouble please RSVP
Date: Tue, 17 Sep 1996 17:52:02 -0400
Subject: re: Front suspension mounts etc
I apologize for doing what irritates me most - adding to an already
perfectly answered issue -
The job below is easier than changing spark plugs.
…more from Gunnar
Now for a question: Up front (way up front) there are two major
bushes? Recommended procedure and Real Life™ experiences?
I had my mechanic do this - it looked difficult to me… If one of
you has done this in your own garage, my hat’s off to you!
Next - oil pressure gauge:
Jim it is ‘gauge’ (hell! it is just the same as ‘gauze’!) and incidentally,
why couldn’t Kirby ask for himself?
Peter Carpenter
From: M.Cogswell@ccmail.mi04.zds.com (Mike Cogswell)
Date: Tue, 17 Sep 1996 10:09:00 -0500
Subject: FTP site?
OK, I'll try this again . . .
My internet mail gateway has only been operational for about 1 day out
of the last two weeks. I'd like to get the digest files for the days
I missed (and the three weeks I was down under), but I can't find
them. The web site doesn't contain recent digests. It suggests
getting the latest ones from the ftp site buts offers no address. I
tried the ftp site listed in the majordomo welcome, but the start
directory doesn't exist. Anyone know where I can get the digests?
Please reply quickly, before this #@$%! gateway vanishes again!
Thanks, MikeC
m.cogswell@zds.com
Date: Tue, 17 Sep 1996 10:49:35 -0500
Subject: 83 XJ-6 Front End ReBuild
First of all, thanks to all of you who offered advice regarding the front
end work I had inquired about earlier. This list and it’s participating
membership deserve a great deal of credit for your willingness to help
fellow enthusiasts!
The work I’ve had done involved replacing all shocks (front and rear), upper
and lower ball joints, control arm bushings, and rack bushes.
I ordered all necessary parts from H.D. Rogers & Sons of Bossier City, LA.
Very knowledgeable, helpful and great to work with. Prices were excellent.
(318)742-3651
Work was performed by Robert Knowles Enterprises of Stanley, KY. Very
competent and completed the work in a very timely manner. The charges for
labor reflected the fact that all work was done while the front end was
disassembled, consequently “Much less” than fees quoted for cumulative shop
time on each individual item.
(502)764-5512
The question I have, before back-tracking through front end alignment (done
elsewhere), involves the slight tendency for the tracking of the car to
“drift”, even though very slightly to one side or the other at highway
speeds. In addition, I notice slightly more “effort” at the steering wheel
when going around long radius turns in freeway driving, than had previously
been the case.
All things considered, the car drives beautifully, much tighter than before.
The alignment shop has double checked their work and says things are “right
on the money”. Could the symptoms be from uneven tire wear due to previous
miles, or what else could be considered “suspect”?
More questions to follow, as I’m getting aggressive with cold weather
approaching. ;o)
Date: Tue, 17 Sep 96 19:22:19 EDT
From: ** SHANE MANTOSZKO ** IBMA INVENTORY ANALYST **
*** Resending note of 09/17/96 23:37
*** SYDVM1(SHANEM) PH. (02) 354-4918 CUMBERLAND FOREST FE21
*** INTERNET - SHANEM@VNET.IBM.COM *** IBMMAIL - AUIBMSPM ****
- – XJS twin turbo - Yes, this has been done in Aus - at the behest of
- –Australia’s richest man (name of Packer) a few years ago. What details may b
- –available, I doubt. Whether it was regarded as a great success I am also not
- –sure.
- –kids to come … Regards, John Elmgreen
Gary Walker who owns Gary Walker Jaguar also has a 7 litre, twin turbo
XJS.
Back when I was a customer of his a few times, his front office guy told
me that it put out 1000 horsepower. He told me the engine cost over
A$50,000 and the crank alone cost A$25,000 (US$20,000).
I was all ‘oohh … aahhh’ when I heard it, but after being part of
this group, I start to have doubts about it being able to pump out so
many horses, when racing versions are only putting out 500hp-600hp.
Maybe it does have this much…who knows…
I know that he looks at this site, and maybe some of you other
aussie jag-lovers are customers of his, and get on with him. Maybe
you can comment on it and confirm what it puts out…I’ve dealt with
some of the racing fraternity who drag out at eastern creek, and they say
that they haven’t seen this car put on the track, so can’t confirm its
times…either way, a 7 litre V12 with twin turbo’s would be pretty
interesting to drive… …
End of jag-lovers-digest V2 #361
Received: by bagate.BELL-ATL.COM (O2)
id m0v3Gsm-0008cfa@bagate.BELL-ATL.COM; Wed, 18 Sep 96 03:17 EDT
id for jag-lovers-digest-out; Wed, 18 Sep 1996 08:30:35 +0200 (MET DST)
Date: Wed, 18 Sep 1996 08:30:35 +0200 (MET DST)
Message-Id: 199609180630.IAA16560@ekeberg.sn.no
Subject: jag-lovers-digest V2 #362
Precedence: bulk
jag-lovers-digest Wednesday, 18 September 1996 Volume 02 : Number 362
Re: Re: front suspension mounts etc.
89 XJ40 Air Conditioning.
RE: XJS twin turbo
Gary Walker Jaguar (Sydney)
Re: Series 3, XJ6, Starti
Re: NEED XJS WOOD
Supplier Experiences
Instrument Spring Cleaning
[Fwd: Jag Lovers]
RE: XJS twin turbo
Re: [SIII XJ6] Front subframe bushes
Re: XJS twin turbo
Lumenition electronic ignition
XJ6 bonnet latches
Re: Paint Codes -Light blue 1970 E-type
Sydney Jag Lovers Festival
Re: 83 XJ-6 Front End ReBuild
Re: wont’t run
Date: Tue, 17 Sep 1996 18:14:51 -0500
Subject: Re: Re: front suspension mounts etc.
Because he is bashful?
I never said I could spell, I just know Jaggeuers.
Jim
Nance O’Neil
Date: Wed, 18 Sep 1996 10:29:24 +1000 (EST)
Subject: 89 XJ40 Air Conditioning.
Thanks for the corrections, Randy. The water valve IS normally open and is
closed by vacuum when maximum cooling is required. Consequently, if it is a
stinking hot day and, despite having the system set for maximum cooling, the
incoming air is hot, this valve and its control equipment is worth checking.
Alan.
Date: Wed, 18 Sep 1996 08:28:00 ±800
Subject: RE: XJS twin turbo
If I’m not mistaken…the Lister also uses a twin turble setup. I don;t know if they sell this seperately or not…John Shuck
From: John Elmgreen[SMTP:100353.1733@CompuServe.COM]
Sent: Tuesday, September 17, 1996 9:08 PM
To: Jag Lovers
sure.
Date: Tue, 17 Sep 1996 21:01:51 EDT
Subject: Gary Walker Jaguar (Sydney)
Shane spake thusly
I thought he had victims not customers…
John
Level 1, 29-57 Christie St.
St Leonards NSW 2065
Ph: +61-2-9937-8063 Fax: +61-2-9937-8100
Mobile +61-419-617-619
Date: 18 Sep 96 12:22:21
Subject: Re: Series 3, XJ6, Starti
Dennis Smith : Using a short piece of electrical wire connect from
Your method is fine, but here’s a tip to make it easier: about eight inches
(from memory!) down and out from the relay, there’s a large brass screw
sticking out. This is a terminal for battery+; just touch the spade connector
on the heavy white+red wire to that…
- Jan
Date: 18 Sep 96 12:15:45
Jeffrey Gram : The Front suspension top wishbone bushes replacement is
not as easy as the Schocks.
Sorry, Jeff, I just have to butt in here, and not because I want to offend you
- it’s just important that members get the right advice. The lengthy procedure
you give for changing the upper wishbone pivot bushes is not necessary.
My own Gum Tree Garage method, which I have field-tested, is this:
Loosen the front wheel bolts as usual and jack the car up by the normal
jacking point, using the standard screw jack. -
Take the wheel off. Place your garage jack so it bears on the lower ball
joint, protecting the joint with a piece of rubber (the radiator mounting
washers are perfect). Make sure it’s secure and jack up until you’ve take the
weight off the screw jack.
The front suspension on that side is now close to the normal running position
and there is next to no load on the upper wishbone. You can now work freely on
the inner bushes, the upper ball joint, the camber and caster adjustments and
so on. NOTE: if you want to assess the condition of the upper wishbone pivots,
this is the only method that works, because a) the suspension is close to its
normal working position where the maximum wear is and b) the upper wishbone is
unloaded and you can push/pull on it to test for slack.
- Jan
Date: 18 Sep 96 12:30:21
Russ Lehman : I connected the wire to the switch, and found the car
wouldn’t go into third gear. I disconected it and the transmission worked fine
This is the kickdown switch for the GM400 gearbox; if you leave it
disconnected, you’ll simply have no full-throttle kickdown.
This mechanism seems to fail mechanically most of the time; what happens is
that the sheath of the throttle cable should move up against a hard spring when
you really floor the loud pedal and operate a roller lever on this switch.
The cable sheath may fail to move due to excessive slack in the cable (the
pedal bottoms out) or lack of lubrication, but more often the fault is simply
that the lever on the switch has been bent out of shape. This is simple to
correct. If the switch turns out to be faulty after all that, it’s a standard
Microswitch that you can get from Radio Shack or similar sources for a buck or
two.
- -Jan
Date: Tue, 17 Sep 1996 21:45:01 -0400 (EDT)
Subject: Re: NEED XJS WOOD
You can gett veneer and all of the other stuff you’ll need from
Constantine’s in the Bronx, New York. The address in in Kirby’s book.
John
1985 XJS FRANKP
Date: Tue, 17 Sep 1996 22:00:24 -0400 (EDT)
Subject: Supplier Experiences
Someone recently mentioed that they had had a good experience with HD
Rogers. Me, too.
I recently called Straight Six Jaguar about something I needed for my XJ-S
as a result of an ad I had seen in Hemmings. When I called them and told
them I had a 12, even tho the part I wanted was the same as for a 6, they
got very angry. “We don’t do 12s!”, angrily stated, and they hung up on
me. Weird.
I just got some miscellaneous dash parts from Jag Heaven in California.
(I am modifying my dash and want to keep my original pieces intact, so I
bought some boneyard extras.) Great service, fair prices, and as far as I
am concerned the stuff they shipped was in better shape than I asked for.
One pice was slightly damaged in shipment but I’ll work that out. But all
in all I recommend them as good guys to deal with.
John
Date: Tue, 17 Sep 1996 22:10:53 -0400 (EDT)
Subject: Instrument Spring Cleaning
I did the following a while ago but never posted it to the list. Progress
with my modified dash refreshed my memory so I thought I’d post it.
The instrument panels on the XJ-S and perhaps the other XJ’s build up dust
over time. If you want to detail the instrument pod, it is real easy and
requires an hour or so.
Remove the instrument pod. There are two (maybe more, I don’t recall)
screws acessible after pulling off the little plastic covers. Reach
behind and disconnect the speedo cable and the two electrical plugs. THe
whole pod can then be eased out – I did not have to pull the steering
wheel.
Disassemble the pod. Several screws and a little leverage in the right
places. Now you can clean the dust out of the idiot light ‘boxes’ and
from everywhere else.
If you also want to improve lighting, remove the four green lenses. The
instruments will be that more brightly lit at night. You can probably
also fit brighter bulbs, if you so desire.
Reassemble the plastic pieces. Tighten the mounting screws for the gauges
(they will be a little loose and the better connection does affect the
gauge reading!). Clean the el cheapo printed circuit tracings where the
two electrical plugs attach. And if any of the idiot light bulbs are
burnt out, you can swap them for some of the ones that are not used (like
the mysterious ‘trailer towing’ light).
Manuever the pod back in place, plug in the two connectors and reattach
the speedo cable (mine is mechanical). Screw it in and all done.
Gives the interior a little boost without the dust and brighter lights
too.
John
Date: Tue, 17 Sep 1996 22:23:23 -0700
Subject: [Fwd: Jag Lovers]
Message-ID: 323F5007.6EF8@ix.netcom.com
Date: Tue, 17 Sep 1996 18:27:35 -0700
Reply-To: beiss@ix.netcom.com
X-Mailer: Mozilla 3.0 (Win16; U)
MIME-Version: 1.0
To: majordomo@sn.no
CC: -
Subject: Jag Lovers
Content-Type: text/plain; charset=us-ascii
Content-Transfer-Encoding: 7bit
I would like to join your club. My name is Dennis Beisswanger and I
live in Mercerville NJ. I just got linked to the internet and this was
the first site I visited.
I purchased a 1982 4.2 liter XJ6 about 1 year ago from a private owner.
It had 27,000 miles on it when I purchased it (it now has 36,000). I
took it to a mechanic about a week after I purchased it who proceeded to
tell me that it had many more miles on it than the odometer indicated.
I was never so disappointed in my life. My mechanic of many years had
just died or else I would have taken it to him before I bought it. I
figured for $6700.00 I didn’t have too much to lose, besides, from a
non-mechanical point of view it looked like it only had 27,000 miles.
The thing that bothers me most is not knowing how many miles my car
actually has. The speedometer head was replaced (it’s the only gauge
without “SMITHS” on it) which seems obvious now, but not when I bought
it. I worry about my engine or transmission failing. Since I’ve had
it, I did, or had done the following: fixed small dent in the rear
fender along with a quick fix on the rust below the front and rear
windows, front brake pads, front brake rotors, rear brake pads, fuel
injection hoses replaced, emmission hoses replaced, rebuilt starter, new
master cylinder, front and back windows resealed, new front shocks, rear
pinion seal, transmission fluid and gaskets, spark plugs, distributor
cap and rotor, fuel filter, new battery, radiator flush, high pressure
hose on air conditioner ($400.00), electric cooling fan thermal switch,
new speedometer transducer, 2 sections of exhaust pipes, cam cover
gaskets.
My next adventure is to replace the brake servo. These are pretty
expensive new. I don’t know if rebuilt ones or kits are available. I
never bled brakes before, but I’ll give it my best. I have ramps and
jack stands and I’m not sure how to go about it. I have been using the
Haynes manual as my reference.
All in all I still love it and get great joy whenever I drive it.
Date: Wed, 18 Sep 1996 12:30:03 +1000 (EST)
yes, I was told the same. However, gossip has it that car was so unreliable
that Packer sent the thing back. He (Packer) is possibly the only victim
who managed to get away with it (For non Australians: Packer is not
only the richest man in the country but also an owner of a TV network)
Ned
To: Jag Lovers
Subject: XJS twin turboXJS twin turbo - Yes, this has been done in Aus - at the behest of
sure.
Date: Wed, 18 Sep 1996 04:35:31 +0200 (MET DST)
Subject: Re: [SIII XJ6] Front subframe bushes
Thanks to all who replied to my posting regarding replacing the front
subframe bushes on my '86 Series III XJ6.
I’ll get right to it and I think I’ll follow Kirbert’s advice of replacing
them all once I start.
As for the polyurethane vs. Jaguar Sports steering rack bushes I simply
followed the advice of Ray Ingman at Classic Spares in the UK who felt
that the poly bushes are a bit too firm, not quite right for a luxury
grand touring car like the XJ saloon.
I’ve never driven an XJ with the poly bushes so all I can say is that the
car now feels very responsive to steering input, the improvement was
beyond my wildest expectations. I don’t even mind if they only last for
five years or so, they were really quite easy to replace.
Thanks again.
Gunnar
Gunnar Helliesen | Bergen IT Consult AS | NetBSD/VAX on a uVAX II
Systems Consultant | Bergen, Norway | '86 Jaguar XJ6 4.2 Sovereign
gunnar@bitcon.no | http://www.bitcon.no/ | Vicki who? What .sig virus?
Date: Tue, 17 Sep 1996 23:06:38 -0400
Subject: Re: XJS twin turbo
SCI did a review of the lister twin turbo about 5 years ago. It was a
monster!!! they say it still felt like a Jag but it MOVED! they did a
convertable and a hard top. the hard top aproached 200 (not quite though).
These cars were sold to compete with the AMG Hammer and the Dinan BMWs
(mainly the Hammer)…anyway, I will have to go look and see if I can dig out
this issue. I also think Road and Track did a test of one years ago - Doug
Date: Wed, 18 Sep 1996 05:43:50 +0200
Subject: Lumenition electronic ignition
Did anybody ever fit a Lumenition system to a Mk1 3.4?
Its seems that there is no kit for this car, but maybe somebody found a
solution?
1.5 -59 Mk1 3.4
J�rgen Scheel
Sandvika - Norway
Date: Tue, 17 Sep 1996 21:21:39 -0700
Subject: XJ6 bonnet latches
I often thought of hood louvers on my XJ6 until someone on the list
mentioned that the heat would flow right back into the cowl inlets. Jim
Isbell reports that his engine runs a few degrees cooler with the
bonnet popped open and resting on the safety catch, wonder what that
does in terms of heat flowing back into the cowl?
Comment from Nevada: I have been told by the “olde factory
trained Jaguar mechanic who lives down the street” that popping the
bonnet, during a heavy snow or sleet storm, provides defroster
efficiency never dreamed of by our warm blooded English friends. So, I
guess it doesn’t all go in the cowl air duct.
Of course, I never drive my XJ6C in that kind of weather so who
knows.
Bob Rankin
Carson City, NV USA
1970 E Type
1975 XJ6C
1949 Triumph 2000 Rdstr
1959 TR3A
1980 TR8
1996 Toyota P/U
http://home.aol.com/jagbob
Date: Tue, 17 Sep 1996 21:35:53 -0700
Subject: Re: Paint Codes -Light blue 1970 E-type
David, I too am having problems matching paint for my 70 E-Type. So far,
the only paint store that I have found that can cross-reference the
color, (Regency Red in my case) has it in a two-pack catalyzed
polyurethane made by Glasurit of Germany. I believe Glasurit is a
division of Agfa Chemical Co. The stuff is around $350 USD per 4 liters!
I have been a little reluctant to try it because I’m not sure how close
the match is to the original color and at those prices, I don’t want to
make too many mistakes.
To be honest, I would prefer to find a match in something like PPG Delron
Acrylic enamel as this is something that I have experience using.
Unfortunately, the paint store cannot cross-reference to Dupont (PPG).
As a point of interest, what does it cost to have an E-type chemically
stripped? We used to have a Redi-strip franchise about a 100 miles away
but it appears that they have folded.
gwcohn@azstarnet.com
'70 E-Type OTS "Under Construction"
Date: Wed, 18 Sep 1996 00:58:17 -0005
…and incidentally,
I did once, got no response.
| some rules must be broken.
| - Palm’s Postulate
Date: Wed, 18 Sep 1996 15:10:40 +1000 (EST)
Subject: Sydney Jag Lovers Festival
Sydney Jag Lovers - the examples of the Marque will be on display at the
“Festival of Jaguar” on Sunday, October 13 at Rozelle Hospital Oval. This
is to replace the event which was washed out a few weekends ago.
I am posting this because the rescheduling of the event was not well
advertised, therefore, pls spread the word.
Ned Blagojevic
Environmental Science Division
Australian Nuclear Science Organisation
PMB 1 Menai, NSW 2234
Australia
email: nbx@ansto.gov.au
phone (w)int 61-2-717-3660
fax int 61-2-717-9260
Date: 18 Sep 96 16:57:29
Subject: Re: 83 XJ-6 Front End ReBuild
Denny Alford : …tracking of the car to “drift”, even though very
slightly to one side or the other at highway speeds. In addition, I notice
slightly more “effort” at the steering wheel when going around long radius
turns in freeway driving.
Without commenting specifically on the workshops involved, I experienced
“wandering” about an unstable middle position on my 240Z at speeds over 110
km/h (about 70mph). The cause turned out to be excessive toe-in.
There is a problem with having generic alignment shops work on Jaguars; I have
seen the reference books used by two of my local tyre dealerships, and they had
severely incorrect values registered for the XJ, namely 3-5 mm toe-in. Early
XJs (the cutoff was when the V12s got injection) had a small amount of toe-in;
later models have zero toe-in to (I think) max. 1.5 mm toe-out. I set mine on
zero, because it’s easy to check by eye - front and rear track are identical
and you simply line up the front and rear tyres.
The required toe-in relates to the suspension geometry and in particular to the
camber (sideways tilt) angle of the front wheels. Broadly, positive camber
(wheels tilting outwards at the top) requires toe-in to keep the tyres going
straight ahead and negative camber requires toe-out. From memory, the S2 XJ has
zero to 1/4 deg negative camber (those reference books I mentioned showed 1 deg
positive camber +/- 1/4 deg). I’m about to try -1 deg camber on my '77 XJC and
expect to find by experiment that around 1-2 mm toe out will be required.
Things may well have changed again with series 3 and 4, so check your workshop
manual. The best way to deal with this problem is to get the alignment shop to
measure the alignment only, making no adjustments. You can then apply the
adjustments yourself; the book tells you how many shims to add/subtract for a
given change.
- Jan
Date: 18 Sep 96 17:19:18
Subject: Re: wont’t run
Unfortunately, Diane, this symptom could have a multitude of causes. For
example, if the cooling water temperature sensor isn’t connected and your
system is adjusted seriously over-rich, you could get this. For another, an
earlier repair could have left a fuel pipe too close to the exhaust, so that
you indeed get vapour lock. And 'way out in left field, you could have an
intermittent break somewhere in the ignition system that opens when the engine
is hot (common ignition coil failure mode).
I’m afraid the only way to track the problem down is to check through both
ignition and fuel systems thoroughly, bit by bit. You can do a few simple tests
on the roadside. For example, watch the rev counter when the engine dies. Does
the needle drop instantly to zero, even while the car is rolling and the
gearbox is still turning the engine? If so, the ignition is faulty “upstream”
of the coil.
Another test is, after the engine stops, pull the centre lead out of the
distributor and arrange it so the brass ferrule on the end is maybe 1 mm
(0.04in) away from a metal part of the engine. If there is no visible spark
when you crank the engine, the fault is in the coil or its connections. If
there is a good spark, the problem is definitely in the fuel system…
Don’t forget that the injection system is electrically controlled, so you could
have an electrical fault in the fuel system. One way to track that down is to
bend and waggle section by section of the wiring; if the engine starts, you
have at least found the general area where the fault is.
Off the right front corner of the engine (if the harness is the same as the
XJ12), you’ll find three multi-pin connectors. One is very large and leads to
the engine; those are the leads to the injectors and are not implicated here
(however, when one or two cylinders are dead, it’s a different story). Another
has only four prongs; this is the one that could be involved in your fault,
because it carries power and signal to/from the ECU. Try “exercising” that
connector and waggling its wire…
- Jan
End of jag-lovers-digest V2 #362
id for jag-lovers-digest-out; Wed, 18 Sep 1996 17:33:53 +0200 (MET DST)
Date: Wed, 18 Sep 1996 17:33:53 +0200 (MET DST)
Message-Id: 199609181533.RAA22428@ekeberg.sn.no
Subject: jag-lovers-digest V2 #363
Precedence: bulk
jag-lovers-digest Wednesday, 18 September 1996 Volume 02 : Number 363
Re: Herring in the Lucus.
RE: Body work
XXK8 Electrical System
Lumenition for 3.4 Mk1
Re: 3 Topics – Alignment, Brake Bleeding, Jack and Stands
GM400 Throttle switch
XK Cyl. head work.
Lumenition
[To Michael Neal] - XJ-S Overheating and Radiators.
Support rec.autos.makers.jaguar
Re: Kirbys question on oil pressure senders.
Re: Support rec.autos.makers.jaguar
Date: Wed, 18 Sep 1996 09:08:56 -0700
Subject: Re: Herring in the Lucus.
Flipperman,
Don’t listen to them! Every marque of car has it’s own specialities, its own
soul. With Jaguar it’s electric, although looking at the statistics; people who
have ACTUALLY had problems with it, it becomes evident that it is mostly talk!
So go get your XJ, Philip! I personally would be very surprised if you end up
having all sorts of problems with the electrics!
Good luck!
Bard
______ _ ! Baard Th Hesvik, Telesoft AS
/ _ / _ _ _ / / ! Longhammarvn 7, N-5500 Haugesund
/ // / // /_ / / -/- -/- ! T: +47 52735000 F: +47 52717040
/ /_ / /_ / // / /_ ! E-mail: baard@telesoft.no
Date: Wed, 18 Sep 1996 09:23 +0200
Subject: RE: Body work
I don’t know anything about the zinc coating (it sounds like a good idea)=20
but be careful in removing the black paint entirely before priming your=20
panels. This coating adheres very little to the steel and is meant as a=20
temporary anti corrosion paint only.
Frans.
instructions state that it is not a primer and is not to be painted over.=20=
I
assume then that it is to be used only along the edges/flanges where=20
pieces
join or overlap to be welded together. However, once welded, what do you=20
do
excess that is outside of the weld area before you prime and paint? If=20
there
surface and prime?
Thanks for any information.Alex H. Lindsay
=20
Date: Wed, 18 Sep 96 09:44:30 gmt
Subject: XXK8 Electrical System
From Advert in Jaguar World
For any interested parties?
Friday 18 October 1996, IEE, Savoy Place, London
The Electrical System of the XK8
Presented by the Electrical/Electronic Engineering Department of Jaguar Cars, UK
Advances in engineering have pushed forward the state-of-the-art in automotive
technology, especially within the field of advanced electronics and computer
control.
As an example of this rapid progression Jaguar Cars and the Institution of
Electrical Engineers have joined together to organise a Seminar on ‘The
Electrical System of the XK8’. In a series of technical papers Jaguar Experts
will demonstrate the advanced technology they depend on and how it was
engineered for the Jaguar XK8 Sports Coupe.
Further Information
The IEE Colloquium Office
44 (0) 171 240 1871 Ext 2205/6
Fax 44 (0) 171 497 3633
EMail colloquia@iee.org.uk
Date: Wed, 18 Sep 96 09:53:27 gmt
Subject: Lumenition for 3.4 Mk1
Classic Spares
Unit 4,
Brook Road, B
ritannia Road,
Waltham Cross,
Herts
EN8 7NP
Tel 44(0) 1992 716326
Fax 44(0) 1992 788424
are suppliers for Lumenition. 95 UK pounds for XK engines.
Ask for Ray Ingram.
Date: Wed, 18 Sep 1996 05:55:58 -0500
Subject: Re: 3 Topics – Alignment, Brake Bleeding, Jack and Stands
Alignment – Here are the alignment specs from the original maintenance =
handbook for my 83 XJ6 S3: castor +2 1/4 plus or minus 1/4 degree, =
camber of +1/2 plus or minus 1/4 degree, toe-in of 1/16 to 1/8 inch. Yes =
the camber is slightly positive. Had mine done recently. I think it went =
well partly because I took with me a copy of the maintenance handbook =
settings and the pages from Kirby’s book that include facts like it =
looking like a standard American setup but being different. (Remember =
that I’m 120 miles from a Jag mechanic.) Anyway, my toe-in was way off =
and I suspect that it was because the person who set it before had bad =
numbers. By the way, serious previous misalignment should be reflected =
in abnormal wear.
Brake Bleeding – I bought a Mityvac with gauge for $30 (US) from =
Western Auto. I used it to replace the brake fluid by first sucking-out =
the old fluid, filling the reservoir with new stuff, and bleeding. It =
even came with an attachment that fit the bleed nipple. Could not have =
been easier. You might just bleed them, but I’ll bet that the fluid is =
a few years old and should be replaced.=20
Jack and Stands – The single tool that has made the most difference to =
my maintenance work has been a decent hydraulic floor jack. It only cost =
about $40 at Sam’s Wholesale and a pair of stands was about $20 more. It =
makes working on the car SO much easier because it only takes a minute =
to lift your car safely. This is especially true for an XJ6 because it =
was designed with central lift points to be lifted one end at a time. =20
Date: Wed, 18 Sep 1996 7:51:59 -0400 (EDT)
Subject: GM400 Throttle switch
Many thanks for the input on this. The fella must have hit it or something
during reassembly work. It simply needed a re-adjustment for the switch to
close only when completely floored (clever mechanism). Maybe it was a Friday
afternoon and they thought it easier to just disconnect it, or thought it
wouldn’t be used much…they don’t know how my wife utilizes her engine’s
capabilities!
Thanks
Russ Lehman
“nothing worthwhile is ever easy”
“pessimists are accurate; optimists live longer”
Internet: rlehman@npr.org
Date: Wed, 18 Sep 1996 13:51:33 +0100
Subject: XK Cyl. head work.
XK Cyl. head work.
It is always a question of far you should go. Go as far as you can afford bearing in mind the rest
of the engine block remains the same ?.
Valves and valve springs are cheap. Replace the lot. You get polished valves for inlet at 5
pounds a piece in England - peanuts. Some Old exhaust valves (at least from the mid sixties)
are so brittle that a wirebush will eat valve metal away !!! - I was amazed. XJ S2 and S3 valves
are hard.
Replace inlet valve stem seals (mandatory), exhaust valves dont have these.
Questionable item : tappet buckets. - I didn’t. bought them but didn’t put them in since the
tappet guides were not replaced.
Things to check :
Valve guides. If worn or within 1 thou of being at max size, replace the lot (lSpecialist).
Valve seats. If lose you obviously need them replaced.
Tappet guides. If lose when head is cold, you need to replace - stakedown kit is NOT sufficient.
If lose when warm (that special clicking), stakedown kit is sufficient.
check for corrosion around waterways. If serious consider scrapping head , get it welded up or
go for a COMPLETE rebuild (see later)
Flatness - always skim the head. - this is a specialist job (cheap).
decoke - leave to specialist if you don’t know how to do it. Decoke is to be done with a
non-metal part e.g a sharp cut piece of medium hard wood, operated by had only. Thinners and
other gum-solvent stuff is also allowed. Dont tell anyone, but I found I could use a well worn
cup-formed wire-brush on an electric drill !! Yes I know I said no metal parts and normally this
brush would be a killer on the hemispheres, so don’t try - better safe than sorry, but I am a
daredevil sometimes, and I tried it out first on a cracked B-head for scrap anyway.
Valve seats usually are good, just need recutting or at least regrinding. If you buy new valves
make absolutely sure the valve seat angles match otherwise…This is a specialist job (cheap)
The things missing by now is only what you should do on a complete rebuild :
New valve seats
New Tappet Guides
Lastly you need a new cylinderhead gasket, new exhaust gaskets, new inlet gasket, new
cobber rings for the valve cover, new oil breather gaskets., and valve cover gaskets.
The last two gaskets can be replaced by sealant of the right type (be sure…). I shall not start
another discussion by naming sil… OOPS, but blue Hylomar is not good enough.
You need new lock plates for the cam sprocket bolt too. Stuff a rag down before just in case you
drop a bolt or a plate. - if you do drop one, it is the engine out and dismantle…, or at lest front
subframe off and dismantle engine in situ - timeconsuming…and $$$
Chains:. Opinion vary. I’d say : If the car has less than 100000 km forget it unless there is a
noticable slack in the chain on the sprocket, not sidewards but in the running direction. In that
case I would buy a new chain, but not the sprockets.
If, With the new chain on the old sprockets,there is still noticable slack, you should consider
new sprockets . This is however not likely, and the sprockets are $$$$
If you change chain you have to get the chain cover off, waterpump off bonnet wide open or
removed etc, and you should exchange the complete chain tension mechanisms too as a
matter of course…
Now where was that flame retardent suit… Shield boosted to 100, Energy 121 and
arming my Descent-2 Fusion Gun and two smart bombs…
Regards Jeffrey Gram
Date: Wed, 18 Sep 1996 09:56:36 -0600
Subject: Lumenition
rom: “Jorgen og Gro” mediamix@sn.no
solution?
1.5 -59 Mk1 3.4
J�rgen Scheel
Sandvika - Norway
Jorgen,
Fitted one years ago to a Mk2,will have a look. Its a pretty standard
fitting ,I think the fitter had to cut a pin off or something to fit one
suitable for a later model Lucas distributor,otherwise you could fit a
later distributor.
regards DON TRACEY
Australia
50 mark5,58 XK150,59 Mk2
Date: Wed, 18 Sep 96 13:18:46 +0100
Subject: [To Michael Neal] - XJ-S Overheating and Radiators.
Michael, I’m not sure if this reply reached you or not, so I’m posting
it to the group. (Sorry guys).
If anyone else wants to add there =A30.02, please feel free !
- ------- Forwarded Message
In message 323A2CC5.59DF@wco.com you wrote: =
STOP!!! Don’t drive your car!!! This sounds like the power steering
cooler in the right side of the radiator or the trans cooler in the lef=
t
side is blown. You are getting extreme pressure in your cooling system=
that could blow the head gasket, heater core etc… and cause serious
problems. I had a restriction in the return line to the power steering=
reservoir that blew the cooler and pressurized the system to over 100
PSI. Needless to say the potential destruction was rather fascinating.=
BTW, the customer got cheap and just had me disconnect the power
steering cooler. I would not do this on the trans cooler, it would
shorten the life of the trans. An aftermarket cooler would probably do=
and just plug the radiator.
Michael, =
I just got you reply, and, well, WOW!
Three exclamation marks looks pretty serious ;{
First off, thanks for the response. I don’t know if
you noticed any others on the list, but I’ve included two here that
I would like to comment on/discuss if you have the time (and patience !).=
Stefan Schulz wrote:
If it’s really water in the cooling system, then that’s half your problem=
and the other half is the brown stuff. RUST.
Get some Barr’s FLUSH, fill up the cooling system with the
prescribed water/antifreeze mixture, add the flusher, and run the car nor=
mally for a week. (Ignore what the label says about 48 hours tops.) The=
n
flush the system again and fill with water/antifreeze again. Oh yes,
avoid Barr’s Leaks when you refill the system - never mind what Jaguar sa=
y.
Worked for me 2 years ago with a freshly-bought badly maintained V12 and
just did it again with wifey’s new 13-year-old Volvo.
If flushing doesn’t do the trick, do component elimination testing throug=
hout
the cooling system ;-(
and:
John Napoli wrote:
I have had this problem once or twice on non-Jags, but cars with alloy
engines. If you find the gunk in the water but the engine oil is OK, the=
n
you have someplace in the engine where engine oil under pressure finds it=
s
way into the coolant.
This persisted on one car for ten years and over 175,000 miles. No amoun=
t
of flushing solved the problem (would come right back) and there was neve=
r
any reverse infiltration into the oil (engine was never apart, so I never=
found the cause. Never knocked, blew a head gasket or burnt oil. Never
overheated or lost coolant, either.).
So, unless others know of specific dangers inherent in the Jag, I’d ignor=
e
it and feel good about all that extra water pump lubrication!
n
s
I am heavily inclined to take your advice. I think stefan may not quite =
realise the ‘magnitude’ of the gunk that is oozing out of the header tank=
and Mr Napoli’s mail does intrigue me. Perhaps he has been extremely luck=
y
to run an engine for this length of time in this condition - I am not
prepared to take that risk however.
To update the latest situation, I replaced the header tank at the weekend=
and the coolant (again :). A few test runs, no leaks, but after stopping,=
the dreaded milk shake started spewing again
I’m not going to bother replacing any more hoses until I sort out the
pressurisation I think - tackle the cause, not the symptom, as they say.
Someone else has suggested the transmission cooler may be causing the
problem. However, I have been led to believe that this would result in
more of a strawberry (milk-shake coloured sediment ( I use Dexron II
trans fluid) - would this not also be the case if the Power Steering =
cooler was the guilty party. (I’m hoping for a ‘not necessarily’ response=
here, as then at least I can be sure of the new parts I’m going to
be throwing my pay cheques on.:). In fact, are these two liquids actually=
water soluble or not ??
I followed with interest the thread about the radiator removal - I think
I’ll be testing this theory out soon myself , especially as I only
got the A/C recharged last month :(:(:(.
Sorry to drone on, I’m going for a lie down now
Thanks for your time (and the exclamation marks), and I look forward =
to hearing from you soon.
regards,
The_Tiger < bb@eagpde.co.uk >
Date: Wed, 18 Sep 1996 08:44:10 -0600 (MDT)
Subject: Support rec.autos.makers.jaguar
Fellow Jag-lovers,
There is a currently a call for votes on USENET for the creation of a
rec.auto.makers.jaguar (and .mg and .triumph).
I strongly feel that we should support the formation rec.auto.makers.jaguar
I’ve been on the net for almost 10 years now. During that period I’ve
been through the rise and fall of gopher and mosaic, helped form
numerous mail groups (including this one) and participated in broadening
of the net from a narrow medium for scientific exchange to the fantastic
resource which it is today.
The point I’m trying to make is that I’ve been around this game for
awhile and I didn’t come to the conclusion that we should support a
rec.auto.makers.jaguar USENET group lightly.
I seriously feel that it is time to help form a rec.auto.makers.jaguar
newsgroup and that it’s presence will add another dimension to Jaguars
on the net without taking anything away from what we’ve built here with
the jag-lovers e-mail list.
Below are my thoughts on the subject and simple instructions on how to
cast your vote in support of it.
Naturally, I gotta start my reply with an old quote:
“USENET is like a huge herd of elephants with diarrhea: it’s an awe
inspiring sight when you first see it, once it gets started it’s
exceedingly difficult to change direction and, finally, it’s capable
of generating the most unbelievable amounts of excrement when you
least expect it.”
The predecessor to this list was british-cars. Every couple years we
would get a call to form a british-cars USENET news group and we would
loudly shout down the suggestion for a number of reasons:
Some of us don’t like USENET and wouldn’t participate in a newsgroup.
The best description I heard of USENET was 4 years ago when someone
said that trying to find information on USENET was like scuba diving
for quarters in a cesspool. -
I personally like to know who’s getting my e-mail. With our mail-group
I have that sense, with a newsgroup I don’t. -
There is much more protection from flamers (bounce 'em off the list) and
mass marketers (filter 'em) on a mail list than on a newsgroup. You
have to make an effort to join the mail-group and that seems to be
enough of a hurdle to keep the “My Yugo can smoke your Jag” riff-raff
out. -
Back in the early days of the net, when not very many people were on,
newsgroups vs e-mail groups was often an either/or but not both
choice. E-mail groups usually need 50 participants to flourish and
establishing a similar USENET newsgroup could kill off a young
promising e-mail group.
I, for one, would not participate in a newsgroup. I prefer the amateur,
club-like atmosphere of the mail-group to the flames and anonymity of
mass-broadcast newsgroup.
But, I feel that at this point in time there are some good reasons for
forming a USENET newsgroup for jaguars, particularly for owners of the
newer models. Experience has shown that when healthy mail-groups spawn
newsgoups, both groups stay healthy. And that the newsgroups tend to be
populated by the owners of newer models seeking solutions to problems
that they are encountering with warrantees and dealers, while the owners
of the older models, who are on their own to solve their own problems,
stick with the original mail-group. Some reasons for supporting the
newsgroup are:
It doesn’t threaten jag-lovers. A newsgroup simply can’t generate
the feeling of community that a mail-list does. And newsgroups tend
not to have memory while, on the other hand, we have built extensive
archives and help pages. The sheer numbers of people joining
jag-lovers is an indication it’s continuing success. -
It broadens the offerings to jag owners on the net with no work or
outlay on our part beyond the initial startup. It would even serve
to take some of the load of the mail-list. -
It would funnel classic jag owners into the mysterious mail-list
where all the old jag tech gurus hang out, while giving the owners of
new Jaguars, who don’t get much support on jag-lovers, a forum. -
A jag newsgroup will eventually start, whether we support it or not.
If we help start the newsgroup and get it off the ground, it becomes
as yet another great service that jag-lovers has helped bring to the
jaguar owner community. If we don’t start it, it will start anyway
and there might not be quite as close of a relationship between the
mail and the news group. -
It will buy us time before we have to deal with the problem of the
jag-lovers mail list getting to big.
So my personal feeling is that that we should support the startup of a
USENET rec.autos.makers.jag (RAMJ) newsgroup, while continuing to
operate jag-lovers mail-list as it always has.
For those interested in seeing the complete CFV (Call for Votes) on the
formation of the rec.auto.makers.jaguar group, check the USENET group
news.announce.newgroups.
For those too lazy to wade through the announcement, below is a sample
ballot to vote in favor of the formation of the newsgroup. Please
read the instructions carefully, add your name to it and mail it
to jaguar-vote@netagw.com .
/\ Lawrence “Just why are we doing all this work, anyway?” Buja
_][ southern@ncar.ucar.edu National Center for Atmospheric Research
________________Boulder,Colorado___80307-3000
Mark the ballot and then MAIL it to: jaguar-vote@netagw.com
Just “replying” to this message should work, but check the “To:” line.
In order to properly record your vote, please provide your REAL NAME and
indicate your desired vote in the appropriate locations inside the ballot.
Examples of how to properly indicate your vote:
[ YES ] example.yes.vote
[ NO ] example.no.vote
[ ABSTAIN ] example.abstention
[ CANCEL ] example.cancellation
*** PLEASE ***
DO NOT alter, modify, or delete any other information in this ballot!
If you do, the voting software will probably reject your vote.
===== BEGINNING OF BALLOT: Delete everything BEFORE this line =====
rec.autos.makers.jaguar Ballot
(Do not remove this marker!)
Please provide your real name, or your vote may be rejected. Place
ONLY your name (ie. do NOT include your e-mail address or any other
information; ONLY your name) on the next line beside “Voter name:”.
Voter name:
Insert YES, NO, ABSTAIN, or CANCEL inside the brackets for each
newsgroup listed below (do not delete the newsgroup name):
Your Vote Newsgroup
[ YES ] rec.autos.makers.jaguar
===== END OF BALLOT: Delete everything AFTER this line ============
Date: Wed, 18 Sep 1996 10:42:51 -0500
Subject: Re: Kirbys question on oil pressure senders.
This is a Mime message, which your current mail reader
may not understand. Parts of the message will appear as
text. To process the remainder, you will need to use a Mime
compatible mail reader. Contact your vendor for details.
- –IMA.Boundary.476950348
Content-Type: text/plain; charset=US-ASCII; name=“RFC822 message headers”
Content-Description: cc:Mail note part
Received: from mis.mi04.zds.com by ccmail.mi04.zds.com with SMTP
(IMA Internet Exchange 1.04b) id 23f1f090; Tue, 17 Sep 96 16:58:34 -0500
Received: from cass.ma02.bull.com (cass.ma02.bull.com [128.35.32.1]) by mis.mi04.
zds.com (8.7.5/8.7.3) with SMTP id QAA01034 for M.Cogswell@zds.com; Tue, 17 Sep
1996 16:19:25 -0500
Received: from bull.com by cass.ma02.bull.com with SMTP
(5.65c/082396-1) id AA03806; Mon, 16 Sep 1996 20:25:17 EDT
Received: from ekeberg.sn.no by nc-17.ma02.bull.com with SMTP
(5.65c/061396-1) id AA66470; Mon, 16 Sep 1996 20:24:01 EDT
id for jag-lovers-out; Tue, 17 Sep 1996 01:09:04 +0200 (MET DST)
using -f
Received: from smtp.utexas.edu (smtp.utexas.edu [128.83.126.2]) by ekeberg.sn.no
(8.7.5/8.7.3/on4)
with SMTP id for jag-lovers@sn.no; Tue, 17 Sep 1996 01:09:02 +0200
(MET DST)
Received: (qmail-queue invoked by uid 0); 16 Sep 1996 23:08:59 -0000
Received: from unknown (HELO mail.utexas.edu) (128.83.126.1)
by smtp.utexas.edu with SMTP; 16 Sep 1996 23:03:10 -0000
Received: from slip-93-15.ots.utexas.edu (slip-93-15.ots.utexas.edu [128.83.249.4
7]) by mail.utexas.edu (8.6.9/8.6.6) with SMTP id RAA09285 for jag-lovers@sn.no
; Mon, 16 Sep 1996 17:49:14 -0500
Message-Id: 199609162249.RAA09285@mail.utexas.edu
X-Sender: JISBELLJR@mail.utexas.edu
X-Mailer: Windows Eudora Version 1.4.3
Mime-Version: 1.0
Content-Type: text/plain; charset=“us-ascii”
Date: Mon, 16 Sep 1996 16:45:17 -0500
Subject: Kirbys question on oil pressure senders.
Sender: owner-jag-lovers@sn.no
Precedence: bulk
Content-Description: cc:Mail note partI haven’t messed with the sender or gauge on my XJ-S, but I have spent
some time fiddling with the ones on my S3 E-Type. My original failed,
so I bought a replacement from SICP. Like you, I discovered that it
was a variable resister. The gauge did not read correctly with the
new sender, although the new sender was identical to the original
right down to all the original manufacturer’s part numbers and
markings. I had my gauge checked my Niosinger’s (who use an original
oil pressure gauge tester that has a multi-position switch to check
high, mid-point, etc.) The gauge was fine, so I borrowed the sender
from a co-worker’s XJ-12 which used the same p/n sender. Voila!
Worked correctly. Returned mine to SICP and got a replacement. Same
problem! Turns out that the S2 E-Types (and probably XJ-6s of the
same vintage) used 80 psi gauges while the V-12s used 100 psi gauges.
The gauges are identical except for the markings, but the senders are
different since they are the same resistance at different pressures.
A little calculating showed that I had an 80 psi sender that was
clearly marked 100! SICP checked their stock and contacted the
supplier, confirming that there was indeed an incorrectly marked batch
loose on the public. I also confirmed this by putting my sender on my
air compressor. I isolated it on a rubber hose and grounded the body
of the sender to the frame while connecting the sender terminal to the
gauge. My 100 psi guage read full scale at 80 psi and half scale at
forty, further confirming that I had an 80 psi sender.
______________________________ Reply Separator _________________________________
Author: JISBELLJR@mail.utexas.edu (James A. Isbell) at Internet
Date: 9/16/1996 4:45 PM
Kirby and I have been having a discussion off the list on the oil pressure
senders for the XJ6 and for the XJ-S. Apparently they suffer the same problems.
I have opened up one from a series 3 XJ6 and found a mechanical diaphram to
wirewound pot contraption. It essentialy acts as a variable resistor that
shows high resistance at low pressure and low resistance at high pressure.
This is in series with the guage which apparently just measures current.
The question was, “what is the resistance range required.” When I opened it
up the wilre was already broken, but by measuring the pieces I determined
that it was PROBABLY about 10 ohms at min scale. My ohm meter is very
inacurate, so this is not a definative answer.
However if anyone out there has an oil pressure guage that they could hook a
potentiometer up to and a 12 volt battery, they could determine the end
points empiricaly. Be carefull and start with a high resistance so you dont
dammage the guage.
Kirby is looking for the information so he can research other senders that
might substitute.
Jim
“Better an outlaw than not free.”
Nance O’Neil
- –IMA.Boundary.476950348–
Date: Wed, 18 Sep 1996 11:33:01 -0400
Subject: Re: Support rec.autos.makers.jaguar
In a message dated 96-09-18 10:47:42 EDT, southern@sol.cgd.ucar.EDU (Lawrence
Buja) writes:
<< There is a currently a call for votes on USENET for the creation of a
rec.auto.makers.jaguar (and .mg and .triumph). >>
Could you explain a bit more about what a USENET is , and what
rec.auto.makers.jaguar means?
Julian Mullaney
End of jag-lovers-digest V2 #363
Return-Path: @owner-jag-lovers-di1
Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4)
id for jag-lovers-digest-out; Thu, 19 Sep 1996 01:55:36 +0200 (MET DST)
Date: Thu, 19 Sep 1996 01:55:36 +0200 (MET DST)
Message-Id: 199609182355.BAA23847@ekeberg.sn.no
X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f
To: jag-lovers-digest@sn.no
Subject: jag-lovers-digest V2 #364
Reply-To: jag-lovers@sn.no
Errors-To: @owner-jag-lovers-di1
Precedence: bulk
X-Newsgroups: mail.jag-lovers-digest
jag-lovers-digest Thursday, 19 September 1996 Volume 02 : Number 364
Re: [To Michael Neal] - XJ-S Overheating and Radiators.
RE: Body work
XJ-S steering rack, shocks and springs
XJ front suspension upper bushes.
Cooling system service questions
XJS Problem
RE: [To Michael Neal]-XJ-S Overheating and Radiators ( long )
Carb problems
rec.autos.makers.jaguar (no jag content)
Spring Questions - XJ Rear
Tiffany Fixed ! 1984 XJ6 S-3 overheating
V12 engine FS…
XJ 6 Bonnet latches
RE: USENET Jag Newsgroup
XJS INTAKE HELP!
Date: Wed, 18 Sep 1996 16:14:20 GMT
Subject: Re: [To Michael Neal] - XJ-S Overheating and Radiators.
In message 9609181218.AA21131@eeyore.eagpde.co.uk The_Tiger writes:
I am heavily inclined to take your advice. I think stefan may not quite >
realise the ‘magnitude’ of the gunk that is oozing out of the header tank> ,
and Mr Napoli’s mail does intrigue me. Perhaps he has been extremely luck> y
In case of doubt, check out Michael’s suggestion first. He’s the
professional
trans fluid) - would this not also be the case if the Power Steering >
cooler was the guilty party. (I’m hoping for a ‘not necessarily’ response>
be throwing my pay cheques on.:). In fact, are these two liquids actually>
In mine the power steering cooler is separate from the radiator - it’s just
a couple of fins on a longish bit of pipe. And yes, power steering liquid
should be ATF, therefore be red. Have you looked into the reservoir on
yours to check the colour ?
If the cooling system is being pressurized by hydraulics, then that should
be a LOT higher pressure than the filler caps are designed to hold. Do you
actually have chocolate milkshake blowing out of the filler caps or do
you only see it when opening it up and looking inside ?
Stefan Schulz
jaguar@suaviter.demon.co.uk
Date: Wed, 18 Sep 1996 11:52:42 -0400
Hi Alex,
I've dealt with Easton many times, and to best answer your question, =
are you aware that Easton has a tech. help line to assist you? They are =
in the know about their products (of course) and have helped me many =
times. The questions you were asking should be forwarded to them - they =
also have a Web page for questions if you’d rather that route.=20
Good luck and try them out!
Mark Budd
1970 E-Type OTS (current)
1986 XJ6 (1994-1996)
From: ALEX H. LINDSAY[SMTP:alindsay@winnie.fit.edu]
Sent: Tuesday, September 17, 1996 9:15 AM
Subject: Body work
instructions state that it is not a primer and is not to be painted =
over. I
assume then that it is to be used only along the edges/flanges where =
pieces
join or overlap to be welded together. However, once welded, what do you =
do
with it? Does it still protect the metal at the seam? Must you remove =
any
excess that is outside of the weld area before you prime and paint? If =
there
surface and prime?
Alex H. Lindsay
Date: Wed, 18 Sep 1996 12:08:58 -0500
Subject: XJ-S steering rack, shocks and springs
I plan on overhauling the suspension of my '88 XJ-S (Hess & Eisenhardt
Convertible) this Winter. Although the car has been basically trouble
free, and the tires have nice even wear on all four corners, the
general handling is much sloppier than it was 8 years ago. (No big
surprise there!)
I definitely plan on replacing all the rubber bushings (using the
non-Jag hard bushings for the rack that everyone seems to love) and
the shocks. Ball joints too, if they are worn.
My questions:
1. What shocks have you tried on an XJ-S and what did you
like/dislike about them? Will you buy the same ones next time?
2. Has anyone replaced the springs with stiffer ones? If so, where
did you get them? How much stiffer? Are there JagSport springs for
the XJ-S?
3. Is there a steering rack available from a different XJ-S (or
other Jag) that has a quicker ratio. Compared to my E-Type, and even
my wife's Hondas, the XJ-S seems to have fairly slow steering.
4. What am I overlooking here that I'll really regret when I find
out about it?
Any and all input appreciated.
Thanks in advance
MikeC <m.cogswell@zds.com>
'74 E-Type OTS
'88 XJ-S (H&E Convertible)
'88 Honda Accord (340,000 miles and climbing)
'91 Chevy Suburban (when you really need the room)
'96 Honda Accord (hope it lasts as long as the '88)
Date: Wed, 18 Sep 1996 18:33:02 +0100
Subject: XJ front suspension upper bushes.
To list & Jan W, and Michael N,
Yes I agree the method I described is lengthy and not absolutely necessary if only the upper
bushes are to be renewed. I have however not tried the “quick” method basically because I have
great respect for the spring and I did not know for sure whether the upper inner pivot would be
completely under “zero gravity”. Not knowing that…
I could easily imagine me working there in cramped space and the upright complete with disc
“swinging” outwards “slipping” off the jack, a 500 pound spring released of prison… and a 500
pound car-corner skydiving over my knee…I’m overdoing it but any thought barely close to that
scenario is enough for me to take other routes.
I think in fact that now with my updated knowledge, I would still do it my way.
But thanks for the appropiate correction.
Regards Jeffrey “why do it quick if it can be done slower and better” Gram.
P.s. I DO have may unfinished projects in the cellar…
Date: Wed, 18 Sep 96 9:42:47 PDT
Subject: Cooling system service questions
I would like to change the coolant in my car (`91 XJ40),
and I need some advice.
The owner’s manual says when refilling the coolant, put in
some Barr’s Leak. Do you Jaguar Techs always do that? Is it
strictly necessary? I’ve heard somebody say that Barr’s Leak
serves as a waterpump lubricant; that’s why it’s needed. Is
this true? From what I see, Barr’s Leak contains some pea-sized
capsules (which is supposed to dissolve). Does it clog up
anything? If I put it in the header tank, would it be able
to circulate through the entire cooling system? -
When flushing, do I insert the water hose at the header tank?
Is it strictly necessary to remove the drain plug at the
cylinder block? or is it sufficient to just open the radiator
drain plug? Sorry, this is just a lazy man’s question!
Roger Peng (408)765-7863
Intel Corporation
Design Technology, Physical CAD
Date: Wed, 18 Sep 1996 09:49:28 -0700
Subject: XJS Problem
I have an 87 XJS V12. Iv’e only had it a year but already I have had to
put in a new water pump, fuel pump, transmission transducer, master
cylinder, and starter. Now being the first Summer I’ve had to drive it
I’ve noticed that in weather above 80 degrees the tempature gauge rises
slightly above normal after only a few minutes of city driving but will
drop a bit after I get back on the freeway. This is my first Jaguar so
Idon’t know what is normal or not. I do know that I don’t want to
overheat the engine because that will cost me a bundle. Any ideas?
Jana
treadwel@ieway.com
Date: Wed, 18 Sep 96 18:29:57 -0700
Subject: RE: [To Michael Neal]-XJ-S Overheating and Radiators ( long )
I’ve read the latest offering regarding the “dreaded milk shake” spewing from
the cooling system with some interest. I have recently gone through a similar
problem with my 1985 XJ6 4.2 and have also travelled down many roads toward a
cure. In my case the problem was an expensive list of parts + labour as follows:
- Flushed the system twice with Barrs Flush, NO CHANGE.
- Replaced slightly perished bottom radiator hose, System pressure increased and
overheating/overflowing occured more quickly. - Replaced radiator and refilled, WITHOUT BARRS LEAKS, overheat/overflow ceased
but engine still running a bit warm, foaming of coolant ceased. - Water pump started to leak, repaced that too.
- Replaced viscous coupling on fan, engine temperature dropped to 75 C normal
running.
During the diagnostics period my Jag specialist spent a long time pressure testing
and checking for exhaust fumes in the coolant, also steam in the exhaust on starting
an already hot engine. Fortunately none of these were present. Another check he
made was to run the engine at about 2000 rpm with the pressure cap off. He told
me that the most common problem was the head gasket having a very small leak that
would only show up when the engine was run above 1000 rpm. At these speeds a small
amount of oil would pass through the gasket and gradually build up in the water. It
wouldn’t show up for sometime but by the time it was noticed the head would surely
be warped. Unfortunately if oil has entered the system at anytime it can be years
before all traces have been removed, so you may think the gasket has gone but it
hasn’t. There may have been a gasket change earlier in the cars life you didn’t
know about, try to check with any previous owners. I suspect the V12 will exhibit
similar results when tested and probably the same after various replacements. If
the parts I changed have been done here then I would be looking toward the head
gaskets, the sooner the better.
Regarding leaks into the cooling system from steering pump/gearbox I would expect
“strawberry milkshake” also. If any of these systems are leaking into the coolant
I would also expect excessive topping up of oils. The steering would be noticably
heavy and gear changes would be late and erratic. When the gearbox got hot it
would be impossible to engage reverse as there wouldn’t be enough fluid to drive
the clutches. If you remove the gearbox dipstick the oil would smell burnt.
I think you have been running along, as I was, terrified the cause would be
hideously expensive when it may not be. Best of luck anyhow.
Barrie Dawson
1985 series III Jaguar Sovereign
Date: Wed, 18 Sep 96 18:07:12 +0100
professionalIn mine the power steering cooler is separate from the radiator - it’s just
yours to check the colour ?If the cooling system is being pressurized by hydraulics, then that should
I suspect mine is the same.
The pwer steering IS red ATF, and the milk-shake IS chocolate, and is
oozing out - through the overflow pipe rather than the filler cap. If
we ARE talking hydaulics - would this account for the number of blown
hoses and blown header tank I’ve had.
What else could be causing the milk shake to be chocolate (please suggest
something other than engine oil through the head gasket under load. :()
Date: 18 Sep 96 14:42:01 EDT
Subject: Carb problems
I’m having a problem adjusting the carbs on my '66 ‘E’ (three carbs) and I’m
hoping someone has some advice.
When I use ColorTune on cylinder 6 (front most) which is feed by the front carb
I have no problems adjusting to the proper color. But when I move ColorTune to
the adjacent cylinder, 5(also fed by the same carb), it shows a very rich
flame(orange). Adjusting the same carb has little to no effect on that
cylinder.
If I use ColorTune on cylinder 3 which is feed by the middle carb I also have no
problems attaining the proper color. But if I move ColorTune to the adjacent
cylinder 4, again I get a very rich reading.
I don’t know if the two rich cylinders being next to each other mean anything or
it’s just a coincidence. I don’t think the carbs are the problem since I can
adjust them fine and get good reading in their other cylinders.
Could I have an intake value adjustment problem? What else could be causing
this?
Thanks,
- -Ed-
Date: Wed, 18 Sep 1996 15:59:25 -0500
Subject: rec.autos.makers.jaguar (no jag content)
Julian Mullaney asked:
“Could you explain a bit more about what a USENET is , and what
rec.auto.makers.jaguar means?”
usenet is basically a collection of open forums containing public messages that
anyone on the internet can read or contribute to. Our comfy little mail list
simply reflects mail addressed to a jag-lovers to a specific list of subscribers
(yeah, Nick. I know it isn’t REALLY simple!) usenet really a protocol that
allows you to select one or more newsgroups from a list with probably thousands
of choices using a newsreader (software, included with virtually all internet
access software and/or web browsers and most e-mail packages. You point your
software to your provider’s news server. When you have picked a group you will
see a list of messages headers showing the sender, size and subject. When you
select a message to read the request is transmitted to the server where the
message lives and the text is downloaded from there.
The groups are organized into major categories. alt is for alternate
lifestyles, and a conglomeration of other things that didn’t neatly fall into
another category. rec is for recreation. There are rec. subgroups for autos
(rec.auto), sports (rec.sports) and many, many others. These are further broken
down into groups like rec.auto.race, rec.auto.sports, etc. There is further
division into things like rec.auto.race.nascar or rec.auto.makers.jag. Hence
the proposed group would be about recreation and autos by maker, specifically
about Jaguars.
There are binaries and pictures groups where you can find pictures of almost
anything. (You don’t necessarily want to know!)
The good news is they are worldwide, completely open and very easily located
since most internet users have newsreaders.
The bad news is the same as the good news. Because of their open nature they
attract a lot of people who hide behind “handles”. If you ask a question, such
as “I’d like some recommendations for new front shocks” the actual replies you
receive will be totally swamped by the quantity of replies that simply say “me
too!” Since newsgroups are threaded, the me toos will attract endless me toos
of their own and your message will live forever. Because anyone can drop in and
fire off a message and then vanish the groups also attract a lot of spam and
incited flame wars. Simply send a message saying that [pick any offensive
racial/religious/nationality/sexual preference label] all are [pick any matching
offensive stereotype or epithet] and enough bystanders will be incited to reply
to start a good war. Once it gets going, it takes on a life of its own and
consumes much of the list. Add in the vast quantities of commercial spam now on
the net, personal flame wars and the me-too idiots and the percentage of
relevant messages quickly drops. I abandoned recently newsgroups because most
had less than 20% real messages. Some even less.
Sorry I rattled on so long. You’re on AOL, so you can surely see the groups.
God knows there are so many AOL subscribers that the AOL versus non-AOL flame
wars are a major category all by themselves.
MikeC
Date: Wed, 18 Sep 1996 16:32:27 -0005
Subject: Spring Questions - XJ Rear
My catalogs seem to list three different springs for the rear of the
XJ:
C29978 XJ6 & XJ12
C39692 XJ-S
CBC2793 XJ-S Sportspak and 3.6
For those who want to make changes, it’d be really nice to actually
know what the differences are between these three. For example, one
might assume the CBC2793 is stiffer than the C39692 without
increasing ride height; but why would this spring be used on the 3.6,
a slower, lighter car?
I’m sure everyone can surmise as well as I. What I’m really looking
for here is some definitive data on these springs – ideally,
unloaded length and spring rate, etc.
One might assume the C29978 is stronger than the C39692, reflecting
the heavier rear on the sedan. Does it have a higher spring rate, a
longer unloaded length, or both?
One classic application of this info may be the H&E convertible. I
understand they tend to sit rather low in the rear, possibly because
of added weight of the conversion. Can it be fixed by putting in the
C29978 springs? Or would the CBC2793 be a better choice?
More useful info would be the weight on the rear axle of the various
cars. Since the suspensions are all similar, this should give good
indications of the differences between springs.
One more thing: There MIGHT be some value in discussing the springs
in EARLIER Jags with IRS, such as the E-type, which has the same
suspension with springs 13-0202 in the S1/S2 and 13-0212 in the S3.
Presumably, these cars are a LOT lighter in the rear than the XJ’s,
but comparing the data may be helpful. Perhaps someone would like
to shoehorn some XJ springs in the back of an E-type!
– Kirbert | If anything is to be accomplished,
| - Palm’s Postulate
Date: Wed, 18 Sep 1996 17:53:34 -0400 (EDT)
In my case there was no luck involved. The first thing I checked for was
for a leak in the auto trans cooler into the radiator. There was none.
In fact, car never ate a drop of trans fluid ever, and the installation of
a remote trans cooler eliminated any possibility of this!! So it was
engine oil and so slight that no oil consumption between changes was seen,
either. So while it could be bad news, don’t overreact before doing
simple diagnosis.
John
Date: Wed, 18 Sep 96 15:02:56 GST
Subject: Tiffany Fixed ! 1984 XJ6 S-3 overheating
Thanks for all the input on my ongoing repair of the Tiffany Mobile…
My 1984 XJ6 S-3 VDP is running much better and cooler, and the trick was replacing the thermostat again, the first one was defective, which serveral
of you pointed out ! Now the only problem is the air commpressor keeps
blowing the speciality fuse and I have no cool air again… bringing it back tonight and staying there till its fixed !
Thanks again !!
Christopher Howard
E-mail: christopher@netmanage.com
9/18/96 3:02:56 PM
Chameleon - The Best Windows TCP/IP applications
Chameleon - The Best MacOS TCP/IP applications
WebSurfer - The Best Web Browser
ECCO - The Best Workgroup productivity tool
Swift - The Best Terminal Emulation Suite
NewtWatch - The Best Desktop Management
Date: Wed, 18 Sep 96 15:35:04 PDT
Subject: V12 engine FS…
I thought this might be worth posting to the digest. As seen on
“Clasified Flea Market Ads” http://www.cfm.com/net13.html
82 V12;H.E.ENG C IT RUN I Pull w/Assys;$200 510-548-5410
This is in the SF bay area.
Dan Graves
Date: Wed, 18 Sep 1996 18:54:08 EDT
Subject: XJ 6 Bonnet latches
*** Resending note of 19/09/96 00:01
I got caught in 15km/hr bumper to bumper for about 1/2 an hour on Tuesday
evening, the temp. guage was showing 2 needle widths above 90 deg. when I
popped the bonnet catch. The temp dropped to about 2 needle widths below
90 deg within about 5 minutes. I’m not sure though if thats relevanttho
because the air flow through the cowl duct would be pretty minimal at
the snails pace I was travelling at.
I can believe the defrost affect though- I had the drivers side window
down and I could feel the hot air rolling over my hand (arm on sill).
knows.
Bob Rankin
Level 1, 29-57 Christie St.
St Leonards NSW 2065
Ph: +61-2-9937-8063 Fax: +61-2-9937-8100
Mobile +61-419-617-619
Date: Wed, 18 Sep 1996 19:43:43 -0400
Subject: RE: USENET Jag Newsgroup
Lawrence,
Thank you for the benefit of your experience and knowledge. I have
supported the creation of this newsgroup because I agree with you about the
appeal of different forums. Nonetheless, I too, would not get involved with
such a newsgroup. Whilst I have only been on the e-mail list for a few
months, I particularly appreciate the amount of Thinking that is apparent.
I would hate to lose the technical Curiosity and Competence of the list. I
am sure that the creation of the newsgroup would help to focus the J-L list
on what I like and want. That my car is a 420 does not mean I am not
intrigued by the discussions on modern Jags. But I do tire of long
drawn-out discussions of trivia.
Trivia to me - but, I hope, meat to a newsgroup…? (Please?)
I had been thinking of supporting others’ requests for a split in the list
to allow for those who want to focus only on older cars, but decided it
might just lead everyone to be on 2 lists instead of 1.
I hope no one takes offence, but some of the more ‘lumpy’ discussions have
meant that a few individuals have not received their deserved attention.
Sometimes I have thought that Nick might come in and say ‘HALT!’ - but the
list does seem to take care of itself in the end, and I hope it will
continue to do so.
Peter Carpenter
1967 420
UK
PS Hey Kirby, Maybe you didn’t get a reply because your question was just
too tricky?
PPS Hey Jim, What do you mean you can’t spell? All that time we were trying
to spell how we pronounced … Jaggeuer? And that’s exactly how it IS
in the UK!1
Date: Wed, 18 Sep 1996 19:49:17 -0400
Subject: XJS INTAKE HELP!
I RECENTLY TOOK OFF THE INTAKE MANIFOLDS,FUEL INJECTION RACK,AIR
INJECTION,VALVE COVERS AND SPARK PLUGS SO I COULD GET TO THAT A/C
CONNECTION ON THE FIRE WALL AND REPLACE MY EXPANSION VALVE. I TOOK MACRO
DETAILED PICTURES OF THE WHOLE EVENT. MURPHYS LAW STEPPED IN AND THE
FILM SNAPED IN THE CAMERA. SO I WINGED IT WITH HELP FROM MR. PALMS BOOK
AND HAINES I WAS ABLE TO REASSEMBLE WITH ALL NEW PARTS AND GASKETTS THE
ABOVE ITEMS. TODAY WAS THE DAY I DECIDED TO START THE MOTOR. I AS OF YET
DO NOT HAVE THE AIR CLEANER BOXES AND CONNECTING HOSES FITTED.I ALSO
HAVE ASSORTED VACCUM LINES THAT I HAVE PLUGGED FOR NOW. THE CAR BACK
FIRED WHILE CRANKING THEN STARTED SLOWLY AND EVENTUALLY BEGAN TO OVER
REV I SHUT IT DOWN WHEN IT HIT 4000RPM
I CHECKED THE MAJOR CONNECTIONS AT THE INTAKE IE. CROSS PIPE ETC.
AND TIGHTENED ALL. THE BUTTERFLIES ARE COMPLETELY SHUT. TWO QUESTIONS 1)
OBVIOSLY I’ M OPEN TO SUGGESTIONS 2) I NEED A WAY TO GET THE CAR TO IDLE
DOWN TO A LEVEL WERE I CAN STAND AND LISTEN FOR LEAKS WITH OUT THE CAR
OVER REVING, CAN I PULL A FUEL INJECTOR WIRE OFF ? I USED ALL NEW INTAKE
GASKETS BUT I DIDNOT REPLACE THE AIR INJECTION STUFF INSTEAD I FILLED IN
THE HOLES WITH HIGH TEMP COPPER SILICON (THE EXPENSIVE STUFF) I DID NOT
CAP THE BIG HOSE THAT FEEDS THE AIR RACK AT THE BACK, I DICONECTED THE T
AND JUST LEFT IT FOR NOW THIS DOES JUST BLOW RIGHT? I HOPE THE INTAKE
GASKETTS ARE OK ! THATS A PAIN. ALSO BLEW MY SOCKS OFF TRYING TO STOP
THE MOTOR BY PULLIN THE COIL WIRE OFF, WOW THOSE DOUBLE COILS ARE
STRONG. I HOPE I CAN SOLVE THIS PROBLEM SO I CAN GO BACK TO FIXING THE
WOOD ON THE DASH ( A LOT MORE RELAXING AND SAFER TOO.)THANKS.
FRANK P. & THE 4000RPM @ IDLE WONDER JAG
1985 XJS
End of jag-lovers-digest V2 #364
id for jag-lovers-digest-out; Thu, 19 Sep 1996 15:50:57 +0200 (MET DST)
Date: Thu, 19 Sep 1996 15:50:57 +0200 (MET DST)
Message-Id: 199609191350.PAA11680@ekeberg.sn.no
Subject: jag-lovers-digest V2 #365
Precedence: bulk
jag-lovers-digest Thursday, 19 September 1996 Volume 02 : Number 365
XJ40: Want to change headlamps?
Chocolate milk shake problem
Re: [To Michael Neal]-XJ-S Overheating and Radiators ( long )
Series I XJ Parts Car
[XJ12 SII] Fuel Injector Hoses
XJS Intake Help (not in caps)
USENET group
re: Supplier Experiences
Interior mirror E-type S2
XJ6 SIII water heater valve
KJS Air Filter Housing (hole in same)
Purchase of SIII V12
New Lister
Re: New Lister
Re: jag-lovers-digest V2 #364 - Rear Suspension Springs
I’m new here
Re: USENET group
Date: Wed, 18 Sep 1996 17:26:26 -0700
Subject: XJ40: Want to change headlamps?
Hi Jag-lovers!,
I was wondering if any XJ40 owners out there are looking to change
their headlamps. I have a 1989 XJ40 Vanden Plas (U.S. model), with the four
round headlamps. I was thankful for everyones replys and opinions on
headlamp preference, and MOST people prefer the ROUND headlamps, as opposed
to the square. I myself still favor the square lamps, and was wondering if
anyone out there with square lamps, would like to switch for my round
headlamps. My car is black, and I could have the Bezel painted to match the
paint code on your car. The bulb controllers would also need to be traded
(mine are in like-new condition as are the lamps). I assume the headlamps
are interchangeable between the U.S. and Australia/Europe, so this shouldn’t
be a problem with international models.
It’s very hard to find used headlamps in part-yards here in the
U.S., so if anyone knows of yards in the U.S., Europe, or Australia that has
these for a reasonable price, that would also be very helpful.
Thanks for any replys or info!,
-cobac@ix.netcom.com
1989 XJ40 VDP
Date: Wed, 18 Sep 1996 21:12:01 -0500
Please, dont put bars leaks in your radiator.
I have no idea why Jaguar reccomends that other than they own a radiator
repair shop.
I have cleaned many a Jaguar radiator from the effects of this idiocy.
You have heard of the tendency that Jaguars have to overheat? Its because
their radiators are clogged with bars leaks.
Dont do it.
Jim
Nance O’Neil
Date: Wed, 18 Sep 1996 21:12:04 -0500
Subject: Chocolate milk shake problem
What color is RED hydraulic fluid mixed with GREEN antifreeze?
Jim
Nance O’Neil
Date: Wed, 18 Sep 1996 20:40:58 -0700
Subject: Re: [To Michael Neal]-XJ-S Overheating and Radiators ( long )
I just wanted to go over a couple points. An XJS has an external cooler
for the power steering so it can’t leak into the cooling system. So
many different cars have been covered in this discussion that I’ve lost
track of what the original car was. An XJ40 has an internal cooler
in the radiator and will give a milkshake type residue. If your power
steering system has been neglected and your fluid is burnt and dirty you
may not get a strawberry type color. Unfortunately after reading all
the discussion it does seem to be a head gasket leaking under load.
snip
Date: Thu, 19 Sep 1996 00:44:07 -0400
Subject: Series I XJ Parts Car
Okay, I am intrigued, but perhaps didn’t understand the message.
Do you have a '72 XJ which you are selling as a parts car or selling parts
from?
Or do you have the opportunity to buy said car for parts?
There are parts I would be interested in, and perhaps the whole car…please
clarify the message for me, thanks!
- –David Quintana
1971 XJ6
1971 VW Squareback
Date: Thu, 19 Sep 1996 11:25:24 +1000
Subject: [XJ12 SII] Fuel Injector Hoses
All,
I arrived at work this morning to the faint smell of fuel from my
Daimler. Upon investigation I found that several injector hoses were
leaking around the clamps.
I think I remember someone recently talking about high fuel pressure
causing this problem. Can anyone help me out?
I want to find the cause of the problem, not just tighten the clamps and
pretend nothing is wrong
I have noticed a slight sound coming from one of the fuel pumps, however
this has been occurring since I bought the car (almost a year).
For information… I took the car for a drive up the freeway yesterday,
around 260 kms round trip. Everything appeared fine. When I returned
home, I could hear a clicking sound from the right hand bank of the
motor. I didn’t notice any fuel leaks though. This morning I made the
arduous journey to work, a distance of about 1km Then experienced
the problem.
Some related questions…
In Kirby’s XJS book, he mentions that the earlier V12s were recalled to
change the fuel rails from a round type (like mine) to a square type.
Does anyone know if this recall would still be available in Australia (I
would be very surprised after 20 years!). Has anyone in Australia had
this done?
I would like to replace all of the injector hoses, but they appear to be
crimped on to the injectors. Is there a way that a home mechanic can do
this? A part list and procedure would be appreciated.
Chris Sleeman
c.sleeman@praxa.com.au
Date: Thu, 19 Sep 1996 01:17:16 -0400
Subject: XJS Intake Help (not in caps)
I recently took off the intake manifolds, fuel injection rack,air
injection, valve covers and spark plugs so I could get to the a/c
connection on the firewall and replace my expansion valve. I took macro
detailed pictures of the whole event. Murphys law stepped in and the
film snapped in the camera. So I winged it with help from Mr.Palms book
and the haines manual I was able toreassemble with all new parts and
gasketts the above items . Today was the day i decided to start the
motor. I as of yet do not have the air cleaner boxes and connecting
hoses fitted. I also have assorted vaccum hoses that i have plugged for
now. The car back fired while cranking then started slowly and
eventually began to over rev. I shut it off at 4000 rpm and climbing. I
checked the major connections at the intakes IE. the cross over pipe
etc. and tightened them all. The butterflys are shut completely . Some
questions : I need to get the car to idle down to a speed that I can
stick my head under the hood and listen for vaccum leaks , can I pull a
fuel injector wire off ? I used all new intake gasketts, but I did not
replace the air injection stuff instead I filled in the holes with high
temp silcon (the expensive copper stuff). I did not cap the air injector
hose at the back yet, Instead I removed the T at the pipes end. I hope
this blows and not sucks. I blew my socks off tring to stop the motor by
removing the coil wire. Wow those double coils are strong.I hope I can
solve this problem so I can go back to fixing the wood on my dash( a lot
more relaxing and safer too.) thanks.
Frank P & the 4000 rpm at idle wonder Jag
1985 XJS
sorry about the caps to all those who E-mailed me let having to retype
this be my punishment and a hard earned leson in netiquette (do they
make spell checkers for these things ? )
From: David J Shield David_J_Shield@ccm.fm.intel.com
Date: Wed, 18 Sep 96 22:59:00 PDT
Subject: USENET group
Lawrence (and all),
I read your detailed description of pros/cons of forming a USENET
group rec.autos.jaguar, and I have a question and two observations
for your consideration.
Question is, how would the creation of a USENET group offload the
jag-lovers mailing list? I'm familiar with the utility of the
USENET, I just need to be educated (with examples) on how it would
function in this case. Would the USENET Jaguar group be a
different set of people, or a different set of topics, or?
Observation #1. I really don't want to go to two places to keep
current with discussions, that is, going to jag-lovers-digest (I
couldn't possibly keep up with individual messages) in my e-mail
and also checking the USENET. And I'd hate to be left out of one
or the other loop.
Internally at my company, I set up a USENET-like function that
captures and shows the contents of certain engineering mailing
lists. That is, the mailing list also posts the threaded messages
to a USENET-like forum. So you can just look at the USENET version
if you don't want to be on the mailing list. Maybe not a bad thing
for the jag-lovers - the discussions are threaded by subject line,
author, or date. I see this simply as a different, or secondary,
front-end for the jag-lovers. Is that what you're thinking?
Observation #2. I think in the old days, people knew to look for a
particular topic in the appropriate category of rec.whatever.etc..
Now, in these modern web times, we have search engines that help us
find things when we don't know where to look. This is how I found
the jag-web and jag-lovers, and I think many others will find it
this way also. John Elmgreen's article in Jaguar World has further
helped spread the word. Point is that times have changed and maybe
the need for a USENET group is less compelling? (It's a question
to consider.)
Anyway, Lawrence, please comment to these and then I can make an
educated vote.
Thanks!
David Shield
Owner of two Jaguars and admirer of many, even the decrepit SII XKE
OTS I saw today at British Car Service in Sacramento.
Date: Wed, 18 Sep 96 23:17:00 PDT
Subject: re: Supplier Experiences
John Napoli writes of his positive experiences with Jaguar Heaven
in Stockton, and since I'm keen on customer service I want to
second this. They've done right by me, and I've dealt with them in
person and purchasing parts sight unseen over the phone. Once I
didn't describe a part explicitly enough by phone, they shipped the
wrong part but took it back with zero hassle.
On the other hand, I bought an SII E-type hose set from a well-known supplier on the east coast of the U.S. I installed the set a hose at a time, and came to the end and had two hoses that I do not need, and still needed 3 more hoses for the intake manifold (1970 dual-Stromberg with seriously heated intake manifold). They insisted the set was complete, even though they had absolutely no clue what parts are supposed to be in the kit. The guy couldn't tell me the list. Later I checked with XKU, they don't supply those hoses in their kit - gotta buy them separately - but at least the guy knew their parts list. Way less expensive than the first vendor, btw. I'm done, thanks for the bandwidth. David From: Are Lorentsen <are@vinn.no> Date: Thu, 19 Sep 96 08:14:00 PDT Subject: Interior mirror E-type S2 Thank you to those who replied on my interior mirror (grey colour and with a dim function) question for my friends E-type S2. Bottom line from the US is; You can find it, but be prepared to pay more than $200 US for it. Isn't there any UK sources? I guess $200 in the US will be $300-400 before this mirror arrives in my friends mailbox (Norway). Are Lorentsen Narvik, Norway 82XJ6 From: David J Shield <David_J_Shield@ccm.fm.intel.com> Date: Wed, 18 Sep 96 23:32:00 PDT Subject: XJ6 SIII water heater valve Denny, The substitutions I've heard of are: ~'70s GM heater valve. Per Kirby's booklet, take your heater valve to your local parts store and say 'I want one like this'. Or, use a plastic one from a later model Jag (I guess you go to the dealer and say 'I want one like this but in plastic'). I'm preparing a parts-substitution guide to go inside Jim Isbell's XJ6 booklet. It'll be a start. David '84 XJ6 '70 XKE 2+2 From: David J Shield <David_J_Shield@ccm.fm.intel.com> Date: Wed, 18 Sep 96 23:40:00 PDT Subject: KJS Air Filter Housing (hole in same) John Nuttall writes: Air Filter Housing: The 1977 has a hole about half an inch in diameter in the right hand housing (which is bolted to the intake manifold) in the bottom left corner. Was there once a plug in this hole or is something else missing? The 1979 does not have this hole. John, My '84XJ6 has such a hole in the air intake nozzle (the long tube that captures incoming air from the front of the car). Per Nigel Thorley's book, 'XJ The Complete Companion', this hole was to reduce throttle noise - resonances or something were offending sensitive Jaguar owners. Probably that hole on yours is for the same thing. David Inoffensive '84 XJ6 VandenPlas Offensive to Driveways '70 XKE 2+2 From: brownd@filon.ml.com (Dave Brown - London Dev X1818) Date: Thu, 19 Sep 96 09:10:04 BST Subject: Purchase of SIII V12 Hi, Just thought I'd let the list know that I have gone and bought the V12. I only hope I don't live to regret it!! Thanks for all the advice. I'll post my initial impressions once I've driven it a bit. Regards, David David Brown, '67 Daimler V8 250 (now for sale - bargain!!) '88 Jaguar SIII V12 Sovereign brownd@ml.com _______/\/\/\__________/\_____/\__________/\__/\/\/\/\/\____/\/\/\_________ _______/\____/\_______/\/\_____/\________/\_______/\________/\____/\_______ _______/\_____/\_____/\__/\_____/\______/\________/\________/\_____/\______ _______/\______/\___/\____/\_____/\____/\_________/\________/\______/\_____ _______/\_____/\___/\/\/\/\/\_____/\__/\__________/\________/\_____/\______ _______/\____/\___/\________/\_____/\/\___________/\________/\____/\_______ _______/\/\/\____/\__________/\_____/\________/\/\/\/\/\____/\/\/\_________ From: "James Udall (APR)" <JAMESU@apricot.mee.com> Date: Thu, 19 Sep 96 09:39:00 GMT Subject: New Lister Hi all, Just a quick mail to say hi to everyone as I'm new member to the list. My name is James Udall, I'm from the Midlands in the UK, unfortunatley I havn't actually had the pleasure of owning my own Jaguar yet, but plan do so as soon as I can afford one, prohibitive insurance costs for the under 30's in the UK......... Rgds James Email jamesu@apricot.mee.com The following binary file has been uuencoded to ensure successful transmission. Use UUDECODE to extract. begin 600 WINMAIL.DAT M>)\^(A$(`0:0"``$```````!``$``0>0!@`(````Y`0```````#H``$(@`<` M&````$E032Y-:6-R;W-O9G0@36%I;"Y.;W1E`#$(`0V`!``"`````@`"``$$ M@`$`"P```$YE=R!,:7-T97(`O0,!!8`#``X```#,!PD`$P`)`"<`#P`$`#(! M`2"``P`.````S`<)`!,`"0`5`",`!``T`0$)@`$`(0```#$T1D%#-S<P-C0Q M,40P,3%!,S<Q,#`P,#0Y,C`Y044W`-`&`020!@!@`0```0````T````#```P M`@````L`#PX``````@'_#P$```!(``````````!@E&1@0;@!"``K*XHI``#[ MMR$`9``:`#<`$0```!0`)VIA9RUL;W9E<G-`<VXN;F\G`&IA9RUL;W9E<G-` M<VXN;F\`'@`",`$````%````4TU44``````>``,P`0```!$```!J86<M;&]V M97)S0'-N+FYO``````,`%0P!`````@'Y#P$````_`````````($K'Z2^HQ`9 MG6X`W0$/5`(```$`:F%G+6QO=F5R<T!S;BYN;P!33510`&IA9RUL;W9E<G-` M<VXN;F\```,`_@\&````'@`!,`$````3````)VIA9RUL;W9E<G-`<VXN;F\G M```"`0LP`0```!8```!33510.DI!1RU,3U9%4E-`4TXN3D\````#```Y```` M``L`0#H``````@'V#P$````$`````````E!!`0.0!@#X`@``$0````L`(P`` M`````P`F```````+`"D```````,`-@``````0``Y`$`8#`H&IKL!'@!P``$` M```+````3F5W($QI<W1E<@```@%Q``$````6`````;NF!@H$<,?Z%1%D$="C M<0``22":YP```P`&$`QHFAH#``<0&`$``!X`"!`!````90```$A)04Q,+$I5 M4U1!455)0TM-04E,5$]305E(251/159%4EE/3D5!4TE-3D57345-0D525$]4 M2$5,25-435E.04U%25-*04U%4U5$04Q,+$E-1E)/351(14U)1$Q!3D1324Y4 M2$4``````@$)$`$```"[`0``MP$``'P"``!,6D9U%>?GX/\`"@$/`A4"I`/D M!>L"@P!0$P-4`@!C:`K`<V5T;C(&``;#`H,R`\4"`'#<<G$2(`<3`H,S`\83 MY?Y]"H`(SPG9`H`*@0VQ"V#D;F<!T#4W"OL4@@'0D"!(:2`'0&PL"H41"H5* M=7,%0&$@<6!U:6-K(`#``Q%T@&\@<V%Y(&@9P*D<(65V!)!Y`B!E&=#A!"!) M)VT@'5`'X`>`IP;0!)`<$G1H'6!L!`"4="X*A4T<<&YA!X">(`0`&O`@$00@ M5609XD<=HP-2'L--:607\60G!"`+@![#54LA,'5NAP(0`"`C8&%T;&4<<$)) M'(!A=FXG&S%C9R.P&>$<<6%D'L,+4&6G'8`(<!U@;V8F8'<#`-\8$!O`''`F MH2!Q9R4`!<#F>1(`(3!B=05`"U$#H'YD'#$<,!V!*0`"(!US(/IC`Y%A#=`% ML"6`'4$A,(43D&\<D&)I=&D=`/<BH28A`'!C'6`%H!L@!"`/(X$>PR-@!($@ M,S`GG2*9+BZ&&BP*A5)G(H!7&I8@D@J%11O3:B"2=6Q`81.0&Y!O'T`'@&5: M+@6@;1HL%8$`-+```P`0$``````#`!$0`````$``!S`@MTV2`Z:[`4``"#`@ AMTV2`Z:[`1X`/0`!`````0`````````#``TT_3<```W! ` end From: brownd@filon.ml.com (Dave Brown - London Dev X1818) Date: Thu, 19 Sep 96 11:12:05 BST Subject: Re: New Lister Hi, Welcome to the list (I thought the title was about a new Lister Jag atfirst :-)) As a help to your achieving your Jag, Have you tried Footman James (0121-561 4196) or Firebond (01223 566020) for your insurance? Both offer good rates on classic and more modern Jaguars. For example, I've been quoted 270 pounds fully comp for my V12 SIII (5000 miles a year). Could be worth a try. Chhers, David David Brown, brownd@ml.com _______/\/\/\__________/\_____/\__________/\__/\/\/\/\/\____/\/\/\_________ _______/\____/\_______/\/\_____/\________/\_______/\________/\____/\_______ _______/\_____/\_____/\__/\_____/\______/\________/\________/\_____/\______ _______/\______/\___/\____/\_____/\____/\_________/\________/\______/\_____ _______/\_____/\___/\/\/\/\/\_____/\__/\__________/\________/\_____/\______ _______/\____/\___/\________/\_____/\/\___________/\________/\____/\_______ _______/\/\/\____/\__________/\_____/\________/\/\/\/\/\____/\/\/\_________ From: Mark Kral <mkral@ozemail.com.au> Date: Thu, 19 Sep 1996 22:13:02 +1000 Subject: Re: jag-lovers-digest V2 #364 - Rear Suspension Springs Kirbert wrote:
Subject: Spring Questions - XJ RearMy catalogs seem to list three different springs for the rear of the
XJ:C29978 XJ6 & XJ12
C39692 XJ-S
a slower, lighter car?I’m sure everyone can surmise as well as I. What I’m really looking
unloaded length and spring rate, etc.One might assume the C29978 is stronger than the C39692, reflecting
longer unloaded length, or both?One classic application of this info may be the H&E convertible. I
C29978 springs? Or would the CBC2793 be a better choice?More useful info would be the weight on the rear axle of the various
indications of the differences between springs.One more thing: There MIGHT be some value in discussing the springs
to shoehorn some XJ springs in the back of an E-type!– Kirbert | If anything is to be accomplished,
| some rules must be broken.
| - Palm’s Postulate
Rear springs on the MK 10
Part Number Free Length
C18101 12.725"
C20104 13.35"
C21280 12.525"
The MK10 was heavier than the E-type and the XJ(S) and so these with the
E-type might give you end points to interpolate between.
Mark Kral
Date: Thu, 19 Sep 96 8:48:03 EDT
Subject: I’m new here
Hi all, I’m new to this list. I don’t have a Jag yet but
I’m working on it. I grew up in an XK120 that my
grandfather had. I’ve never quit thinking about it. My
grandparents went to Europe with 30 or so couples in the
early 50’s. As a package they all got TR2’s (I think) and
drove around Europe for a month or so. The cars came back
on a boat and my grandparent’s fell in the harbor in NYC.
They took the insurance money and kicked in a bit and got
the Jag. It got sold when he died. Now it’s my turn. I want
an XKE and I’m looking for advice. I can only scrape 10-15
kilobucks. Am I in for a big disapointment? It looks like
a 2+2 will give me the most bang for the buck. I’m an
engineer pushing 40 so I’m not poor but not rich. I’m a
pretty good mechanic and I have done lots of work on previous
British cars, Spitfire, MGB, TR250, Sprite. Any advice?
Discouragement? (unlikely on this list I guess) Encouragement?
Thanks!!
Dave P (in Cincinnati)
Date: Thu, 19 Sep 1996 07:50:16 -0600 (MDT)
Subject: Re: USENET group
David Shield asks…
{ Question is, how would the creation of a USENET group offload the
{ jag-lovers mailing list?
My feeling is that it will help reduce future growth of the list. But,
for all I know, it may increase the membership of Jag-lovers by
channelling new enthusiasts to the list. I suppose it all depends on
how we advertise the Jag-lovers list on the newsgroup. If we post the
Jag-lovers intro to it every month, it will serve as a recruitment
office for interested Jag-owners to the Jag-lovers list. If we say
nothing, than the impact would be minmal.
And, who knows, maybe it will be the channel for the next Micheal Neal,
Randy Wilson, Robert Dingli, Kirby Palm, Tony Parkinson or TezFair to
join Jag-lovers.
In any case, I feel that the newgroup will become, first and foremost, a
place for owners of newer Jaguars to trade information/help.
The example I’ll give is rec.autos.makers.chrysler. A few years ago I
was considering buying a muscle car, a '70 Challenger, so I signed onto
the Mopar list. Most of the traffic was about the classic Mopars with a
mix of modern stuff. Then r.a.m.c formed and the list became much more
focused on the classic Mopars while the newsgroup catered to the new
cars (i.e. those still under warrentee). In this case both groups
became stronger. The new car owners didn’t feel like they were posting
into a black hole and the old car owners didn’t have to wade through
questions about mini-van hatches.
{ Observation #1. I really don’t want to go to two places to keep
{ current with discussions, that is, going to jag-lovers-digest (I
{ couldn’t possibly keep up with individual messages) in my e-mail
{ and also checking the USENET. And I’d hate to be left out of one
{ or the other loop.
That’s a dilemma, but I don’t really consider it to be a big problem.
Personally, I’d rather have the problem of too many sources of
information than too few. And, with DEJANEWS, you can do occasional
history searches of the newsgroup rather than wading thru it each day.
{ Internally at my company, I set up a USENET-like function that
{ captures and shows the contents of certain engineering mailing
{ lists. That is, the mailing list also posts the threaded messages
{ to a USENET-like forum. So you can just look at the USENET version
{ if you don’t want to be on the mailing list. Maybe not a bad thing
{ for the jag-lovers - the discussions are threaded by subject line,
{ author, or date. I see this simply as a different, or secondary,
{ front-end for the jag-lovers. Is that what you’re thinking?
No, not at all. I would strongly oppose echoing the jag-lovers mail to
a global USENET group. If someone want’s to be part of the jag-lovers
group, then let them go thru the effort to join the list. I see the
USENET group as an alternative, entry-level, forum for Jaguar owners,
not as a different front-end for Jag-lovers. The two should be very
separate.
{ Observation #2. I think in the old days, people knew to look for a
{ particular topic in the appropriate category of rec.whatever.etc…
{ Now, in these modern web times, we have search engines that help us
{ find things when we don’t know where to look. This is how I found
{ the jag-web and jag-lovers, and I think many others will find it
{ this way also. John Elmgreen’s article in Jaguar World has further
{ helped spread the word. Point is that times have changed and maybe
{ the need for a USENET group is less compelling? (It’s a question
{ to consider.)
Perhaps. I think that the USENET group will be of little utility to
most of us who are already on Jag-lovers. But for others, USENET is a
primary source of net information. Particularly for newbies. And
USENET has some advantages over mail-lists. For example, a newsgroup
may be a more appropriate place for some of the non-Jaguar specific, yet
automotive related, stream-of-consciousness threads which we
occasionally see here.
Finally, a Jaguar USENET group will also serve as an emergency backup to
the Jag-lovers list in case the list goes offline for some reason.
{ Anyway, Lawrence, please comment to these and then I can make an
{ educated vote.
The bottom line is that establishing rec.autos.makers.jaguar
- provides an alternative source for jaguar information on the net.
- will be an emergency backup for us.
- is a free resource.
I feel that we have much to gain and little to lose from this.
Once again, a sample ballot is below. Voting closes Oct 2.
/\ Lawrence Buja http://www.cgd.ucar.edu/cms/southern/
*** PLEASE ***
Voter name:
Your Vote Newsgroup
End of jag-lovers-digest V2 #365
X-UIDL: 7211aac581c4c4bc089353df539499ea
id for jag-lovers-digest-out; Thu, 19 Sep 1996 19:07:30 +0200 (MET DST)
Date: Thu, 19 Sep 1996 19:07:30 +0200 (MET DST)
Message-Id: 199609191707.TAA24849@ekeberg.sn.no
Subject: jag-lovers-digest V2 #366
Precedence: bulk
Status: RO
X-Status:
jag-lovers-digest Thursday, 19 September 1996 Volume 02 : Number 366
Message-Id: 96Sep19.100328edt.61459@gw.wcsr.com
Re: [XJ12 SII] Fuel Injector Hoses
Re: Tiffany Fixed ! 1984 XJ6 S-3 overheating
empty envelope
Formal introduction of '85 XJ-S to list
Re: jag-lovers-digest V2 #363
SIII V12 - First question!
Re: XJS INTAKE HELP!
Air Cond.
Re: USENET group
Date: Thu, 19 Sep 1996 09:20:26 -0400
Subject: Message-Id: 96Sep19.100328edt.61459@gw.wcsr.com
I have just acquired an '88 XJS. Although new to Jaquar ownership, I’m
a long-time admirer. A couple of questions:
Has anyone reworked the headliner? If so, any tips? Mine is
sagging some in the back and has come loose in a couple of places. -
The radio requires the code every time the car is started. I suppose
a wire is loose that should supply electricity constantly. Any pointers? -
I’ve ordered the owner’s manual and am looking for a good repair
manual. I’ve read Kirby’s reviews more than once, but would appreciate
any suggestions and opinions before I drop the dollars.
The car is fantastic. How could one not become addicted? I think I’m in
for the long haul. My e-mail is s_draper@wcsr.com. Thanks, Steve.
Date: Thu, 19 Sep 1996 10:28:33 -0400
Subject: Re: [XJ12 SII] Fuel Injector Hoses
this? A part list and procedure would be appreciated.Regards,
Chris Sleeman
I just did this procedure on my 1985 XJS as part of a minor overhaul, I
didn’t have the benefit of this site but my injectors don’t leak. I
first pulled the rack off, then using a ruler measured the length of
hoses, front two are longer I then went to the auto parts store and
bought small hose clamps and fuel injection hose of the proper diameter
then using tiny red snips available at radio shack, I cut the old clamps
off. You need a strong cutter with a flat tip for this,Shack # 64-1833 5
inch nippy cutter worked well. I cut a slit up to the top in the crimp
the twisted the cutters it comes off like and apple peel.Then I cut off
the hose. Age really sticks the hoses on good. Before reassembling I
looked inside the injectors for any junk in the small filter screen.
I ordered the gasket set locally in about a day. you need 3 sets there
are 4 in a bag. Three end gaskets and Three larger gaskets for the body
witch need to be pried off and replaced. Note what side the connectors
connect to and reconnect. Make sure the rack seats in the intake
properly. dont over tighten the injector hold down plates. The studs
break easy ! ( I know). I hope some one will read this and correct any
errors I made. This procedure was from a local import shop that
specializes in Jaguar. My car still is not running but it does not leak
around injectors. See intake help. good luck Frank Perrick 1985 XJS.
(I have sqaure rack)
Date: Thu, 19 Sep 1996 07:45:57 -0700 (PDT)
Subject: Re: Tiffany Fixed ! 1984 XJ6 S-3 overheating
Chris-
As I understand it (from personal experience), the fuse will blow if the
freon level drops too far. This fuse trips when the case temperature of the
compressor exceeds some threshold.
Hunt
back tonight and staying there till its fixed !Thanks again !!
Christopher Howard
9/18/96 3:02:56 PMChameleon - The Best Windows TCP/IP applications
Date: Thu, 19 Sep 1996 11:31:49 -0400
Subject: empty envelope
For some reason today the digests I received were empty, only the headers.
Something wrong?
Date: Thu, 19 Sep 1996 08:55:55 -0700
Subject: Formal introduction of '85 XJ-S to list
After thoroughly enjoying the past few weeks on this list, I thought I
might introduce myself (and my car). I have an '85 XJ-S (BR Green
w/biscuit interior). I’ve had the car for about 1 1/2 yrs and have both
thoroughly loved and hated the car. Since purchase I have:
rebuilt the distributor (to fix centrifugal advance)
rewired the fuel injection harness, including new injector connectors
rewired the charging system to fix multiple faults that caused 4
alternator failures in less than 1 year
replaced the front crankshaft oil seal
replaced every belt and hose on the car, including all vacuum lines
replaced spark plug wires and plugs
replaced exhaust manifold gaskets
replaced induction manifold gaskets and fuel injector O-rings
replaced several microswitches
replaced the non-return and diverter valves for the air-injection system
rebuilt rear disc brake calipers and replaced E-brake pads
replaced ambient temperature sensor for passenger cabin heating/ A/C
system
replaced heating system hot water valve
rewired ignition circuit from switch to coil
plenty of general maintenance
replaced Pirelli P5s with P4000s (the P5s started to split at the
sidewall)
My car was hit about six weeks ago (low speed, T-bone to drivers side).
The repairs are nearing completion and I am hopeful about the results.
The body and paint work is great, but I have been fighting with the
insurance company regarding some damage to the suspension. The
differential cage was slightly bent and misaligned in the accident and
now flexes when turning to the right (feels like the rear end has
disappeared). The insurance estimator doesn’t seem to understand how
important this component is and at first, didn’t want to pay for any
repair. Now they are trying a four-wheel alignment (which I think is
ridiculous!) but have promised to replace the cage if the alignment
doesn’t work.
Before my car was hit (and immediately upon its return) I am doggedly in
pursuit of silky smooth idle and acceleration (hence, all the
rewiring!). I also am grappling with a problem with the air injection
system that is allowing exhaust to expel through the passenger’s side
air filter housing. I have replaced both the non-return and diverter
valves, but the problem continues. I suspect either
- another faulty non-return valve (not very likely)
- a partially blocked catalytic converter causing exhaust pressure to
build up in engine and expel through air injection system(maybe?) - a faulty air injection pump
In his XJ-S handbook, Kirby mentions that the air injection pump can be
replaced with a standard GM pump. Anyone have a part number for this or
a suggestion on how to source?
Also, any other ideas regarding my air injection quandary are
appreciated.
Thanks again for all the great information on this list.
Aaron
'85 XJ-S
Date: Thu, 19 Sep 1996 12:07:40 -0400
Subject: Re: jag-lovers-digest V2 #363
prepared to take that risk however.
To update the latest situation, I replaced the header tank at the weekend=
and the coolant (again :). A few test runs, no leaks, but after stopping,=the dreaded milk shake started spewing again
I’m not going to bother replacing any more hoses until I sort out the
pressurisation I think - tackle the cause, not the symptom, as they say.Someone else has suggested the transmission cooler may be causing the
problem. However, I have been led to believe that this would result in
more of a strawberry (milk-shake coloured sediment ( I use Dexron II
trans fluid) - would this not also be the case if the Power Steering =cooler was the guilty party. (I’m hoping for a ‘not necessarily’ response=
here, as then at least I can be sure of the new parts I’m going to
be throwing my pay cheques on.:). In fact, are these two liquids actually=water soluble or not ??
I followed with interest the thread about the radiator removal - I think
I’ll be testing this theory out soon myself , especially as I only
got the A/C recharged last month :(:(:(.Sorry to drone on, I’m going for a lie down now
Thanks for your time (and the exclamation marks), and I look forward =
to hearing from you soon.
regards,
The_Tiger < bb@eagpde.co.uk >
Date: Wed, 18 Sep 1996 08:44:10 -0600 (MDT)
Subject: Support rec.autos.makers.jaguarFellow Jag-lovers,
rec.auto.makers.jaguar (and .mg and .triumph).I strongly feel that we should support the formation rec.auto.makers.jaguar
I’ve been on the net for almost 10 years now. During that period I’ve
been through the rise and fall of gopher and mosaic, helped form
numerous mail groups (including this one) and participated in broadening
of the net from a narrow medium for scientific exchange to the fantastic
resource which it is today.The point I’m trying to make is that I’ve been around this game for
awhile and I didn’t come to the conclusion that we should support a
rec.auto.makers.jaguar USENET group lightly.I seriously feel that it is time to help form a rec.auto.makers.jaguar
newsgroup and that it’s presence will add another dimension to Jaguars
on the net without taking anything away from what we’ve built here with
the jag-lovers e-mail list.Below are my thoughts on the subject and simple instructions on how to
cast your vote in support of it.
Naturally, I gotta start my reply with an old quote:
“USENET is like a huge herd of elephants with diarrhea: it’s an awe
inspiring sight when you first see it, once it gets started it’s
exceedingly difficult to change direction and, finally, it’s capable
of generating the most unbelievable amounts of excrement when you
least expect it.”The predecessor to this list was british-cars. Every couple years we
would get a call to form a british-cars USENET news group and we would
loudly shout down the suggestion for a number of reasons:
Some of us don’t like USENET and wouldn’t participate in a newsgroup.
The best description I heard of USENET was 4 years ago when someone
said that trying to find information on USENET was like scuba diving
for quarters in a cesspool.I personally like to know who’s getting my e-mail. With our mail-group
I have that sense, with a newsgroup I don’t.There is much more protection from flamers (bounce 'em off the list) and
mass marketers (filter 'em) on a mail list than on a newsgroup. You
have to make an effort to join the mail-group and that seems to be
enough of a hurdle to keep the “My Yugo can smoke your Jag” riff-raff
out.Back in the early days of the net, when not very many people were on,
newsgroups vs e-mail groups was often an either/or but not both
choice. E-mail groups usually need 50 participants to flourish and
establishing a similar USENET newsgroup could kill off a young
promising e-mail group.I, for one, would not participate in a newsgroup. I prefer the amateur,
club-like atmosphere of the mail-group to the flames and anonymity of
mass-broadcast newsgroup.But, I feel that at this point in time there are some good reasons for
forming a USENET newsgroup for jaguars, particularly for owners of the
newer models. Experience has shown that when healthy mail-groups spawn
newsgoups, both groups stay healthy. And that the newsgroups tend to be
populated by the owners of newer models seeking solutions to problems
that they are encountering with warrantees and dealers, while the owners
of the older models, who are on their own to solve their own problems,
stick with the original mail-group. Some reasons for supporting the
newsgroup are:
It doesn’t threaten jag-lovers. A newsgroup simply can’t generate
the feeling of community that a mail-list does. And newsgroups tend
not to have memory while, on the other hand, we have built extensive
archives and help pages. The sheer numbers of people joining
jag-lovers is an indication it’s continuing success.It broadens the offerings to jag owners on the net with no work or
outlay on our part beyond the initial startup. It would even serve
to take some of the load of the mail-list.It would funnel classic jag owners into the mysterious mail-list
where all the old jag tech gurus hang out, while giving the owners of
new Jaguars, who don’t get much support on jag-lovers, a forum.A jag newsgroup will eventually start, whether we support it or not.
If we help start the newsgroup and get it off the ground, it becomes
as yet another great service that jag-lovers has helped bring to the
jaguar owner community. If we don’t start it, it will start anyway
and there might not be quite as close of a relationship between the
mail and the news group.It will buy us time before we have to deal with the problem of the
jag-lovers mail list getting to big.So my personal feeling is that that we should support the startup of a
USENET rec.autos.makers.jag (RAMJ) newsgroup, while continuing to
operate jag-lovers mail-list as it always has.For those interested in seeing the complete CFV (Call for Votes) on the
formation of the rec.auto.makers.jaguar group, check the USENET group
news.announce.newgroups.For those too lazy to wade through the announcement, below is a sample
ballot to vote in favor of the formation of the newsgroup. Please
read the instructions carefully, add your name to it and mail it
to jaguar-vote@netagw.com ./\ Lawrence “Just why are we doing all this work, anyway?” Buja
_][ southern@ncar.ucar.edu National Center for Atmospheric Research
________________Boulder,Colorado___80307-3000Mark the ballot and then MAIL it to: jaguar-vote@netagw.com
Just “replying” to this message should work, but check the “To:” line.In order to properly record your vote, please provide your REAL NAME and
indicate your desired vote in the appropriate locations inside the ballot.Examples of how to properly indicate your vote:
[ YES ] example.yes.vote [ NO ] example.no.vote [ ABSTAIN ] example.abstention [ CANCEL ] example.cancellation *** PLEASE ***
DO NOT alter, modify, or delete any other information in this ballot!
If you do, the voting software will probably reject your vote.===== BEGINNING OF BALLOT: Delete everything BEFORE this line =====
rec.autos.makers.jaguar Ballot
(Do not remove this marker!)
Please provide your real name, or your vote may be rejected. Place
ONLY your name (ie. do NOT include your e-mail address or any other
information; ONLY your name) on the next line beside “Voter name:”.
Voter name:
Insert YES, NO, ABSTAIN, or CANCEL inside the brackets for each
newsgroup listed below (do not delete the newsgroup name):Your Vote Newsgroup
[ YES ] rec.autos.makers.jaguar
===== END OF BALLOT: Delete everything AFTER this line ============
From: M.Cogswell@ccmail.mi04.zds.com (Mike Cogswell)
Date: Wed, 18 Sep 1996 10:42:51 -0500
Subject: Re: Kirbys question on oil pressure senders.This is a Mime message, which your current mail reader
may not understand. Parts of the message will appear as
text. To process the remainder, you will need to use a Mime
compatible mail reader. Contact your vendor for details.
- –IMA.Boundary.476950348
Content-Type: text/plain; charset=US-ASCII; name=“RFC822 message headers”
Content-Transfer-Encoding: 7bit
Content-Description: cc:Mail note partReceived: from mis.mi04.zds.com by ccmail.mi04.zds.com with SMTP
(IMA Internet Exchange 1.04b) id 23f1f090; Tue, 17 Sep 96 16:58:34 -0500
Received: from cass.ma02.bull.com (cass.ma02.bull.com [128.35.32.1]) by
mis.mi04.
zds.com (8.7.5/8.7.3) with SMTP id QAA01034 for M.Cogswell@zds.com; Tue,
17 Sep
1996 16:19:25 -0500
Received: from bull.com by cass.ma02.bull.com with SMTP
(5.65c/082396-1) id AA03806; Mon, 16 Sep 1996 20:25:17 EDT
Received: from ekeberg.sn.no by nc-17.ma02.bull.com with SMTP
(5.65c/061396-1) id AA66470; Mon, 16 Sep 1996 20:24:01 EDT
Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4)
id for jag-lovers-out; Tue, 17 Sep 1996 01:09:04 +0200 (MET DST)
X-Authentication-Warning: ekeberg.sn.no: majordom set sender to
owner-jag-lovers
using -f
Received: from smtp.utexas.edu (smtp.utexas.edu [128.83.126.2]) by
ekeberg.sn.no
(8.7.5/8.7.3/on4)
with SMTP id for jag-lovers@sn.no; Tue, 17 Sep 1996 01:09:02
+0200
(MET DST)
Received: (qmail-queue invoked by uid 0); 16 Sep 1996 23:08:59 -0000
Received: from unknown (HELO mail.utexas.edu) (128.83.126.1)
by smtp.utexas.edu with SMTP; 16 Sep 1996 23:03:10 -0000
Received: from slip-93-15.ots.utexas.edu (slip-93-15.ots.utexas.edu
[128.83.249.4
7]) by mail.utexas.edu (8.6.9/8.6.6) with SMTP id RAA09285 for
jag-lovers@sn.no
; Mon, 16 Sep 1996 17:49:14 -0500
Message-Id: 199609162249.RAA09285@mail.utexas.edu
X-Sender: JISBELLJR@mail.utexas.edu
X-Mailer: Windows Eudora Version 1.4.3
Mime-Version: 1.0
Content-Type: text/plain; charset=“us-ascii”
Date: Mon, 16 Sep 1996 16:45:17 -0500
To: jag-lovers@sn.no
Subject: Kirbys question on oil pressure senders.
Sender: owner-jag-lovers@sn.no
Precedence: bulk
Content-Description: cc:Mail note partI haven’t messed with the sender or gauge on my XJ-S, but I have spent
some time fiddling with the ones on my S3 E-Type. My original failed,
so I bought a replacement from SICP. Like you, I discovered that it
was a variable resister. The gauge did not read correctly with the
new sender, although the new sender was identical to the original
right down to all the original manufacturer’s part numbers and
markings. I had my gauge checked my Niosinger’s (who use an original
oil pressure gauge tester that has a multi-position switch to check
high, mid-point, etc.) The gauge was fine, so I borrowed the sender
from a co-worker’s XJ-12 which used the same p/n sender. Voila!
Worked correctly. Returned mine to SICP and got a replacement. Same
problem! Turns out that the S2 E-Types (and probably XJ-6s of the
same vintage) used 80 psi gauges while the V-12s used 100 psi gauges.
The gauges are identical except for the markings, but the senders are
different since they are the same resistance at different pressures.
A little calculating showed that I had an 80 psi sender that was
clearly marked 100! SICP checked their stock and contacted the
supplier, confirming that there was indeed an incorrectly marked batch
loose on the public. I also confirmed this by putting my sender on my
air compressor. I isolated it on a rubber hose and grounded the body
of the sender to the frame while connecting the sender terminal to the
gauge. My 100 psi guage read full scale at 80 psi and half scale at
forty, further confirming that I had an 80 psi sender.______________________________ Reply Separator
Author: JISBELLJR@mail.utexas.edu (James A. Isbell) at Internet
Date: 9/16/1996 4:45 PMKirby and I have been having a discussion off the list on the oil pressure
senders for the XJ6 and for the XJ-S. Apparently they suffer the same
problems.I have opened up one from a series 3 XJ6 and found a mechanical diaphram to
wirewound pot contraption. It essentialy acts as a variable resistor that
shows high resistance at low pressure and low resistance at high pressure.
This is in series with the guage which apparently just measures current.The question was, “what is the resistance range required.” When I opened it
up the wilre was already broken, but by measuring the pieces I determined
that it was PROBABLY about 10 ohms at min scale. My ohm meter is very
inacurate, so this is not a definative answer.However if anyone out there has an oil pressure guage that they could hook a
potentiometer up to and a 12 volt battery, they could determine the end
points empiricaly. Be carefull and start with a high resistance so you dont
dammage the guage.Kirby is looking for the information so he can research other senders that
might substitute.
Jim
“Better an outlaw than not free.”
Nance O’Neil
- –IMA.Boundary.476950348–
Date: Wed, 18 Sep 1996 11:33:01 -0400
Subject: Re: Support rec.autos.makers.jaguarIn a message dated 96-09-18 10:47:42 EDT, southern@sol.cgd.ucar.EDU (Lawrence
Buja) writes:<< There is a currently a call for votes on USENET for the creation of a
rec.auto.makers.jaguar (and .mg and .triumph). >>Could you explain a bit more about what a USENET is , and what
rec.auto.makers.jaguar means?Julian Mullaney
End of jag-lovers-digest V2 #363
Date: Thu, 19 Sep 96 17:22:40 BST
Subject: SIII V12 - First question!
Hi all,
One “problem” the garage I’m buying the Sovereign from said they would take care
of before I pick up the car is a tendancy to “surge” on cold start. The guy
suggested it would be a small fix like tightening a hose or some such thing.
Could this be a major problem??
Cheers,
David Brown,
brownd@ml.com
///_/_/_/_/////_///______
/_/_//_/_/_/_/_/____
/_/_/_/_/______/_/_/_/______
/_/_/_/_/_/_/________/_/_____
___/_/_/////_/_/_/_/_/______
/_/___/_/_//_/_/_/____
///_/_/_/____/////_///_________
Date: Thu, 19 Sep 1996 12:56:07 -0400 (EDT)
Subject: Re: XJS INTAKE HELP!
I don’t know why you disassembled so much! THe expansion valve is
replaceable without pulling off all of this stuff.
Sounds like you have a major vaccuum leak. Did you reconnect the vacuum
line from the intake manifold crossover tube that sends vacuum to the ECU?
And I suspect that just dumping in sealant to the air rail sockets is not
a good idea. These tubes each have 2 o-rings – have you created a direct
air or exhaust path into the intake runners?
I am sure that others will respond with additional suggestions. Your leak
sounds so bad that it might not be the intake manifolds (although they
might be leaking a little) unless you forget to put in the gaskets! I
would check all the basics first.
John
1985 XJS
Date: Thu, 19 Sep 96 11:54:58 CST
Subject: Air Cond.
FWIW There is a new drop-in refrigerant on the market which is suppose
to increase the performance of your air conditioner by 5% if your car
had R-12 in it and about 15% if your car has R-134A in it. ICOR
International Inc. is the mfg. and Hotshot-A is the name of it. Another
benefit is the system uses 20% less by weight than R-12 and it is a lot
less expensive. I have no connections with this company but I am
presently trying it out in a commercial application. It is to early to
completely say try it out, but, so far we have had a positive outcome
with it. There is light on the horizon. More later when the final tests
are completed.
Date: Thu, 19 Sep 1996 13:05:19 -0400 (EDT)
The USENET group is inevitable. Time and progress march on. Maybe we’ll
regard this time as the ‘golden age’ of the Jag list.
John
On Thu, 19 Sep 1996, Lawrence Buja wrote:
David Shield asks…
{ jag-lovers mailing list?My feeling is that it will help reduce future growth of the list. But,
nothing, than the impact would be minmal.And, who knows, maybe it will be the channel for the next Micheal Neal,
join Jag-lovers.In any case, I feel that the newgroup will become, first and foremost, a
place for owners of newer Jaguars to trade information/help.The example I’ll give is rec.autos.makers.chrysler. A few years ago I
questions about mini-van hatches.{ Observation #1. I really don’t want to go to two places to keep
{ or the other loop.That’s a dilemma, but I don’t really consider it to be a big problem.
history searches of the newsgroup rather than wading thru it each day.{ Internally at my company, I set up a USENET-like function that
{ front-end for the jag-lovers. Is that what you’re thinking?No, not at all. I would strongly oppose echoing the jag-lovers mail to
separate.{ Observation #2. I think in the old days, people knew to look for a
{ to consider.)Perhaps. I think that the USENET group will be of little utility to
occasionally see here.Finally, a Jaguar USENET group will also serve as an emergency backup to
the Jag-lovers list in case the list goes offline for some reason.{ Anyway, Lawrence, please comment to these and then I can make an
{ educated vote.The bottom line is that establishing rec.autos.makers.jaguar
(Do not remove this marker!)Please provide your real name, or your vote may be rejected. Place
Voter name:Insert YES, NO, ABSTAIN, or CANCEL inside the brackets for each
End of jag-lovers-digest V2 #366
X-UIDL: 3f9a2d250f8cc8fb7585e50b7f8df4db
Return-Path: @owner-jag-lovers-di1
id for jag-lovers-digest-out; Fri, 20 Sep 1996 05:19:45 +0200 (MET DST)
Date: Fri, 20 Sep 1996 05:19:45 +0200 (MET DST)
Message-Id: 199609200319.FAA20811@ekeberg.sn.no
X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f
To: jag-lovers-digest@sn.no
Subject: jag-lovers-digest V2 #367
Reply-To: jag-lovers@sn.no
Errors-To: @owner-jag-lovers-di1
Precedence: bulk
Status: RO
X-Status:
X-Newsgroups: mail.jag-lovers-digest
jag-lovers-digest Friday, 20 September 1996 Volume 02 : Number 367
Paint Codes
Communicating with Heritage Trust
News from the Factory
Re: Chocolate milk shake problem
Re[2]: USENET group
Fixed Intake
Air bladders
Fixed Intake
Re: Communicating with Heritage Trust
XK8 raffle in the U.S.
RE MESSAGE ID 88XJS
Price reduced drastically! [XJ6-III] Must sell
Bit by a bleeding E Jaguar
Re: I’m new here
Re: [To Michael Neal] - XJ-S Overheating and Radiators.
Re: KJS Air Filter Housing (hole in same)
RE: Majestic Specifications
[XK Engines] Piston Scuffing
Date: Thu, 19 Sep 1996 13:54:47 -0400 (EDT)
Subject: Paint Codes
There was a recent discussion of paint codes for an E-Type.
I am new to this list and am interested in repainting my XK 150-S.
Is there a source for paint codes for Jaguars? I have been to
several local paint dealers and you should see the looks you get
when you start talking about the proper paint codes for a 59 Jag.
I just contacted Karen Miller at Jaguar and got the original
paint color from her. I verified it by removing three different
color coats that have been applied since! in order, they are:
Mist Gray (the original), Cream (Old English White), British
Racing Green and Imperial Maroom.
George Dodson
1959 XK150-S On the road at last.
1978 MGB Daily Driver
Date: Thu, 19 Sep 1996 13:53:40 -0400 (EDT)
Subject: Communicating with Heritage Trust
Mr. Lauener,
I sent you this message through the JDHT home page, but the a got a
message that made me unsure that it had been sent. The only method to
contact Ann Harris to request a form is a phone number. certainly there
must be a fax no. or e-mail address or is ones only alternative to write?
Bill Graham
68 XKE FHC
Date: Thu, 19 Sep 1996 14:00:20 -0400
Subject: News from the Factory
Hi Gang,
I thought you may be interested to read the following…
Top quality products and productivity improvements have won luxury car-marker
Jaguar a prestigious industry award.
The company which makes the XK8 sports car has been voted Manufacturer of the
Year at the Manufacturing Industry Achievements Awards.
Jaguar won the award for improving quality standards and imposing
best-in-class productivity levels in all its plants, particularly those
working on the luxurious XK8 sports car.
Judges said “Jaguar has worked hard to bring in new working practises and
improve quality standards, and has achieved these changes very quickly. The
accolade of the Manufacturer of the Year is thoroughly deserved.”
Nick Scheele, Jaguar chairman and chief executive, said “This is excellent
news. It is particularly encouraging for everyone at Jaguar that we have been
selected as Britain’s leading manufacturer immediately before our new XK8
model goes on sale at the beginning of October. The award recognises the
sustained and impressive progress Jaguar has made in product quality and
manufacturing efficiency over the last few year and particularly the
commitment of all our employees.”
(Feeling proud)
Terry Fairbrother
Date: Thu, 19 Sep 96 11:25:01 +0100
Subject: Re: Chocolate milk shake problem
good point, but in the few hours it took to build up the
milk-shake levels again, their was ONLY pure water in the
system.
Date: Thu, 19 Sep 96 14:55:43 EST
Subject: Re[2]: USENET group
I guess I can throw in my 2 cents worth here.......
I am the owner of a newer ( '93 - still under warranty) XJ-S.
I have found that
A. Much of the information posted on the mail list is
completely relevant to me and my car.
B. When I do post an issue to the list I get an excellent
response.
So - I'm going to vote NO - I have no need or interest in yet
another flood of stuff to wade through. I don't think the news
group will be of any more interest to me than the jag-lovers
list is.
Also, because of the amount of space that news groups consume
on the local server, many companies limit the number of
newsgroups that the companies server will support. I know
that I would have a difficult time convincing my MIS group
that the alt.rec.autos.makes.jag is somehow relevanrt to my
business when I am in the office.
I think the news group will get formed no matter what we think
- but I gotta call it the way I see it.
see 'ya.
- mclaus ('93 XJ-S convertible)
Date: Thu, 19 Sep 1996 15:09:40 -0400
Subject: Fixed Intake
I feel stupid but I thought I would tell everone that first of all you have to pull 6 fuel injector wires off
to idle a V-12 down secondly the air cleaner boxes are secured with bolts that go straight thru into the air
cavity hence on just checking to see if the car will run before reasembling the air boxes will cause it to
over rev from all the air entering the intake. Just like opening the accelerator. Thanks to everyone who
responded with tecnical stuff but fourtunately it was simple stupid mistake ! Thanks.
Frank Perrick 1985 XJS @ 600rpm
PS. some concern over hose clamps on fuel rack vs. crimped clamps, Hose clamps holding just fine.
Date: Thu, 19 Sep 1996 12:31:44 -0700
Subject: Air bladders
No… I am not talking about anyone here…
I am talking about air bladders in the front seats. I was recovering the
front seat of my XJ12 last night and was surprised to see that there was
no air bladder (that I recognized).
What I saw on top was a leasther-like pad on top of a great amount of
seat foam that had deep holes in it. This all sat on a thinner layer of
foam and then on the frame. I found no place to put in an air bladder.
Did the early XJs have the bladders? Where exactly would they be if they
were there?
Dave Covert
‘Very funny Scottie… now beam down my clothes…’
From: Frank Perrick frankp%mscnet.net@vm1.cc.nps.navy.mil
Thanks Frankk.
<accelerator. Thanks to everyone who
<responded with tecnical stuff but fourtunately it was simple stupid mistake !
< Thanks.
That’s one less stupid mistake I’ll make.
My newly painted “E” bonnet fell about 6 inches off a tire support onto the
cement floor last night. Just the front part, but I haven’t looked yet to see
what damage was done, still got a couple places to touch up on the top part.
LLoyd - URUuuUUUggGGHH !! -
Date: Fri, 20 Sep 1996 09:09:56 -0700
Subject: Re: Communicating with Heritage Trust
Bill Graham wrote:
Mr. Lauener,
The fax number is +1203-405581
Shane Gibson
Wellington, New Zealand
1968 Daimler V8 250
Date: Thu, 19 Sep 1996 17:40:31 -0400 (EDT)
Subject: XK8 raffle in the U.S.
The Global Technology Exchange Foundation is raising funds by raffling off
a fully equipped 1997 Jaguar XK-8 Coupe. The funds raised will be used to
further the foundation’s mission of distributing computers to teachers and
researchers throughout the world.
Information for entering the raffle can be obtained from the foundation’s
web page at
http://www.ism.net/~globetech/foundation/raffle/rafflehome.html
Date: Thu, 19 Sep 1996 18:55:43 -0500
Sleeman, Chris wrote:
All,
The pressure of the fuel line cause the cold rubber to provide an
inadaquate seal. Upon heating for a few minutes the rubber softens and
seals. I believe the tightening of the clamps is the required fix.
Bob Johnson
Brattleboro, Vt.
XJS, XJ12L
Date: Thu, 19 Sep 1996 16:04:58 -0700
Subject: RE MESSAGE ID 88XJS
Assuming your radio is a Blaupunk made in Korea you will need to cut a coat
hanger into 2 pieces like a pair of "U’s to push into the front plate holes
to remove radio from bracket. when you pull the radio out of the dash watch
for ground strap on left side as bolt protrudes into bracket once out you
will find 2 live input wires with fuses one is for clock and code function
the other for radio, tape, antenna,probable fuse blown in code wire input.
good luck.
Steve Broady
86 xj-6
87 xj-6
acmevfsl@direct.ca
Date: Thu, 19 Sep 1996 19:12:10 +0000
Subject: Price reduced drastically! [XJ6-III] Must sell
As those of you who have visited my web page know, my 1987 Jaguar XJ6 is
for sale. This car is in exceptional condition - you can see for
yourself at:
http://www.cyberenet.net/~atlantic
I originally had it listed at $8500 and hoped to get $8000 for the car.
I have turned down offers of $7500 and $7800. One prospective buyer
brought a Jaguar mechanic with him who found the engine and body sound -
except for a small spot of surface rust behind the left front fender.
No problems with leaking, no electrical problems. Leather and wood in
excellent condition. Paint and chrome are pristine.
After growing weary of being in the used-car and Jaguar museum business,
I accepted an offer of only $7000. Now my prospective buyer is having
trouble getting financing (2nd mortgage) and I’m back on the market
again. I will take any offer greater than or equal to $7000. Check out
the pictures on the web page and call me for info, but I will sell this
car to the first person who brings cash. This is a terrific opportunity
for a Jaguar enthusiast.
Thanks for your consideration.
Dave
atlantic@cyberenet.net
(609) 951-3298 daytime (EST)
(609) 795-8225 evenings
From: rrichardson@eurekanet.com (Robert J. Richardson)
Date: Thu, 19 Sep 1996 19:13:18 -0500
Subject: Bit by a bleeding E Jaguar
I finally was able to remove both master cylinders on my Series 1 E-Type
after spending hours on just one lower bolt for which its locknut could not
be secured with any spanner or socket available on this planet. It took
Liquid Wrench and heat from a propane torch to finally free that blasted
bolt. And then I had the clevis pin to contend with. How skillfully some
Brit engineer managed to place it so that only a wee child could touch that
wicked pin. But I succeeded and just how I did will remain a secret until I
am on my death’s bed.
Further complication: While reading the instructions on the “One-Man” Brake
Bleeding Kit, it said that if the master cylinders are removed (I’m having
both resleeved in stainless steel by Imperial even though the top one was
rebuilt back in the mid eighties and is functioning properly) then they,
too, must be bled while the car is not on an angle as they must be
horizontal to forces of gravity. the question is, why can’t they be purged
of air in the brake fluid must by bleeding the brakes at the calipers? And
if they are bled without pipes attached, how, then, can they be reattached
to the reservoirs and the brake pipes without injesting air? Imperial will
take two to three weeks to resleeve them ($60 a master cylinder plus
shipping). Final query: Will they come back fitted with new sleeves, etc.,
and rubber dust extruders or will I have to order two bleed kits and
reassemble them as per the service manual. Hope to hear from someone soon
that’s been through this process on early E-Types.
Date: Thu, 19 Sep 1996 19:26:45 -0500
Subject: Re: I’m new here
Discouragement? (unlikely on this list I guess) Encouragement?Thanks!!
Great story. I got my first Jag, and XK120M in the mid Fifties and may have
run into your grandfather as I am from Hillsboro, but lived in Warren at
the time. Mine got totaled by a kid I sold it to down in Aruba. $15,000
should buy you a decent 64 FHC or possibly a 65 4.2 FHC. You won’t get a
OTS at that price and don’t expect to find one for 15 big ones that is in
concours condition. I have a good running 64 Series 1 FHC that’s as good as
new almost except for the interior. It needs to be done at a bottom price
of $3,500 including about 90 hours labor. Personally, like the Brits, I
favor the FHC for looks as well as practicalityj, although I do drool when
I spot a clean Open Two Seater. I live in Athens, Ohio, now (retired OU
prof) and my biggest problem is service. All the mechanics in these parts
will bend over backwards to change engines in a pickup, but give me strange
looks when I try to get a brake bleed or lube job.
Date: 20 Sep 96 11:35:38
Subject: Re: [To Michael Neal] - XJ-S Overheating and Radiators.
On the matter of colour:
Do you actually have chocolate milkshake blowing out of the filler caps
Dexron = red dye
Anti-freeze = green dye
red+green = brown.
Sounds like the transmission cooler, all right.
- -Jan
Date: 20 Sep 96 11:53:45
Subject: Re: KJS Air Filter Housing (hole in same)
>Air Filter Housing:
My 1978 four-door has a rubber grommet in this hole, holding a hose to a
thermostatic vacuum control valve on the rear cooling water fitting behind it.
This is an anti-pollution thingy to do with retarding the ignition while the
engine is cold. The hose is to provide clean vacuum-killing air as needed. I
believe this system was fitted to Australia and California models.
- -Jan
Date: 20 Sep 96 13:01:59
Chris Sleeman :
Hi, Chris,
What happens is that the rubber settles, gradually reducing the pressure
exerted by the clamps. The day comes when some small movement (such as resting
a hand on the injection rail while pulling the oil dipstick, or just vibration)
is enough to break the seal, and the hose starts leaking. Tightening the clamp
again does fix the problem, until the rubber settles some more in a year or so.
The same does not seem to happen to the crimped end, probably because the crimp
exerts far more pressure than a clamp can, especially the crappy el cheapo
clamps used by Jaguar. Stainless steel Jubilee-pattern clamps, tightened with a
small socket spanner, are much stronger and don’t “bottom out”.
You’re welcome to pop in at the Gum Tree Garage and have a look at my machines;
the four-door has had the crimps replaced with screw clamps (because hoses were
perished), which is quite easy to do.
Warning: treat petrol smell like a large, red revolving light and a siren.
Tigthen those clamps immediately; even a small leak can start a fire, and once
you have a fire that eats through one of the hoses, you are in deep smelly
stuff. I have an HE engine that I bought cheaply because just that had happened
to it…
Date: Thu, 19 Sep 1996 22:35:32 -0400
Subject: RE: Majestic Specifications
B.J. Kroppe kroppe@mich.com
Interesting traffic on the Majestic specification of XJ40.
What exactly was the spec? Extra long wheelbase? How
much longer? What level of trim, headlamps, grille,
seats, carpet, wood, engine, model years, Europe vs. USA
differences, etc.?
Will anyone elucidate, please? Thanks.
Well…
I’ve owned mine just 3 months and I’m not sure of all this because I haven’t
found any proper literature, but the Majestic was apparently a model for
those customers who would spend anything for a car that was more special than
someone else’s.
According to NADA Used Car guide, the model was available in 1990 and 1992
only.
The 1990 USA model lineup:
XJ6 $39,700 MSRP
Sovereign 43,000
VanDenPlas 48,000
Majestic 53,000
The Majestic came in one color scheme only, Regency Red with Magnolia hides.
The upholstry is a pattern unique to the Majestic. Instead of full tuck and
roll, the pattern is sort of like a square toilet seat, with t&r insert for
seat and backrest. Piping is dark red, very attractive. The leather is,
nevertheless, beginning to pucker with age as so many other Jag interiors are
prone to.
My car has the following equipment, some of which it shares with the VDP:
Fog lamps
“Square” headlamps
Daimler front grille and trunk eyebrow
monster gold leaper
Full length chrome eyebrows over all four wheel wells
special wheels, similar pattern to then-current XJS but color keyed to
body color
model plates on rear read “VanDenPlas” on left and “Majestic” on right
load leveling rear suspension
Gold trim on wood as per VDP
Lighted vanity mirrors in both sun visors
Picnic tables
Bucket seats in rear with storage compartment under center rear seat pad
fold down center rear armrest with storage compartment
Mini console on rear floor (extension of main console)
Red lambswool floor mats over better grade carpeting
headrests for front seat contain courtesy lights for rear passengers
rear seat headrests
adjustable reading lamps built into c pillars fro rear passengers
Standard engine, radio, wheelbase.
My car has a telephone mounted in the front center arerest, I believe by
PO.
My person reaction to car: The exterior borders on being gaudy, but they
chose a great color scheme, and I think the interior is what all Jaguars
should be blessed with. (IMHO, the person responsible for Barley as an
interior color should be shot!)
Check out a photo of my car at my pitiful web site,
http://members.aol.com/rmac/Jaguar.html
Date: Thu, 19 Sep 1996 23:19:36 -0400
Subject: [XK Engines] Piston Scuffing
Greetings All -
My machine shop called to tell me my pistons are “pretty bad”.
So I dropped by to see what they meant. They were right.
Three pistons had vertical scoring (scuffing) on the front
and rear faces of the piston skirt, at 90 degrees to
the gudgeon pin.
The guy at the shop speculated that it could be from oil
beomg washed off the walls of the cylinder caused by fuel or
coolant on the cylinder walls. I did blow a head gasket,
but the blow was only on one cylinder, as far as I could
tell. That explains only one of the three bad pistons.
What it means to me is ~$400US for new +0.020" pistons.
Anyone else seen piston scuffing on XK engines before?
Mine is an '82 4.2L fuel injection, 8:1 compression
ratio, running unleaded. I used premium fuel, but
who knows about the POs.
Thanks for any and all replies.
B.J. Kroppe - '82 XJ6
p.s. No one knows the specs on Majestic?
End of jag-lovers-digest V2 #367
id for jag-lovers-digest-out; Fri, 20 Sep 1996 17:45:42 +0200 (MET DST)
Date: Fri, 20 Sep 1996 17:45:42 +0200 (MET DST)
Message-Id: 199609201545.RAA24199@ekeberg.sn.no
Subject: jag-lovers-digest V2 #368
Precedence: bulk
jag-lovers-digest Friday, 20 September 1996 Volume 02 : Number 368
A little wine, a little cheese, a little XK8!!!
Need Good Book
Mk IV drum plating
JDHT
E’66 triple Carb adj. problem
Re: XJ Series I parts car
RE: Mk IV drum plating
Clutch change on 4.2 E type.
rec.autos.makes.jaguar(no jag content)
Re: JDHT
Arggg!! Brake Dust on my XJ40!!
UK - Top Gear tv programme last night
Top Gear programme
XJ40 audio upgrade
Re: XJ40 audio upgrade
Re: Spring Questions - XJ Rear
XJS purchase questions??
XJ6 Steering Rack and Gas Tanks
SIII F.E. Align, FRANCE trip
Date: Thu, 19 Sep 1996 23:56:17 -0400
Subject: A little wine, a little cheese, a little XK8!!!
I would like to tell you all that it’s because I
own/disown/drive/can’tdrive/love/hate my '62 E-Type, ots, white, etc. but I
think it’s because I once bought a $19. horn relay from a jag dealer; point
is;
today I received an very interesting/exciting/black/red invitation from the
president (no, not Bill!) of Jaguar Canada to attend a cocktail party,
introducing the 1997 XK8. It includes a very sexy pix of a very red XK8!
Zloz, Gregory, Michael, Glueman, et al…eat your hearts out!
Best,
Charles Daly, Toronto, Canada
'62 E-Type, ots
Oh, yeah, it’s October 8th, if y’all wanna come!
Date: Fri, 20 Sep 1996 02:05:52 -0400
Subject: Need Good Book
I’m sure this will spark a flood of E-mail, But I would like to buy a
book If I could write it I’d call it the complete book of Jaguars and
I’d have commentary from Sir Lyons and others, I’d Tell how each car was
made and the rational behind the design (racing, luxury etc) then I
would fill it with pictures from the first Jag to the newest. I’d also
say why Jaguar has a Jaguar on the hood and what they did during the
war. I’d like a book like this so I can see a picture of all the Jags I
read about here. Does a book like this exist ?
Thanks ! Frank Perrick 1997 XK8 ( hey I can dream) 1985 XJS (for real)
From: “Arnold, Dave Dr.” davearno@sandton.senchem.co.za
Date: Fri, 20 Sep 96 09:03:00 PDT
Subject: Mk IV drum plating
Calling all old-jag lovers (or old jag-lovers or old lovers-jags).
A friend has taken my Mk IV brake drums to “face” the contact surface to
get rid of some grooves worn in over the years. No problem. BUT…he
asks me if I want him to cadmium plate them also. Can anyone tell me if
this is a good thing to do? If I want to bring the car to concourse
level later, will the plating be a disadvantage? Anybody ever heard of
such a thing? Be interested to see any response at all.
Dave
80 XJ6 II
47 Mk IV
etc.
Date: Fri, 20 Sep 96 08:48:00 gmt
Subject: JDHT
A number of you have written to me re communicating with the Jaguar Daimler
Heritage Trust.
Seems like I forgot to include the fax number in the most prominent position.
I will update the appropriate pages.
The main communication numbers are as follows.
Ann Harris, Archivist, +44(0)1203 202141,
Fax +44(0)1203 405581.
Additions soon will be to have an e-mail address which will be for messages,
requests to them, forwarded by us by fax. The JDHT as yet have no electronic
technology!
Regards, Alastair Lauener
Date: Fri, 20 Sep 1996 10:15:24 +0100
Subject: E’66 triple Carb adj. problem
Hi Ed Scripps73200.2362@compuserve.com
It seems we are the carburettor problem guys at present. I’ve let a keen Garageman have go
at mine. He is not splitting the carbs in atoms… I’ve done that already 4 times.
I’ve been speculating a bit on
your problem and quite frankly this is most puzzling, but of course there will be a perfect
scientific explanation, just finding it …
I don’t know if the two rich cylinders being next to each other mean anything or
it’s just a coincidence. I don’t think the carbs are the problem since I can
adjust them fine and get good reading in their other cylinders.
This must be a coincidence, unless the problem lies in a symmetrical layout of the inlet
manifold, which are split in three separate ?? - I don’t have my Haynes E-type manual handy.
However such speculation is not supported by the fact that cylinder 1 & 2 work allright.
The carbs are SU HD8 's, each feeding into a double inlet ports and where the two tracts
“meet” in the middle on the inside of the ports , they create a sharp edged
wall right in front of of the carb throttle disc (butterfly). As such there should be a hopefully
near perfect slpit of the gaseous stream assuming the fuel “fog” raising out of the jet around
the needle is also perfectly homogeneous in distribution. To me the problem could not lie here.
I think the inlet tract to cylinder 5 & 6 (and 1&2) is curved differently from the middle one,
however since the problem lies only in cylinder 4 and 5 not fed by the same carb I cannot
imagine a problem in layout of tracts, unless of course ALL etype suffer this.
Another thing I speculate about just now is that if there is a secondary tract to the inlet
manifold supplying false air the cylinders would lean out where the air enters
Since you have too fat mixture I think it is more likely that your auxiliary carb (starter carb) is
“leaking” air and very fat mixture, and If I remember right they feed in exactly between
cuylinder 4 & 5, and on the rear at between 2 & 3.
If this is the problem It would be nice if you could find out why the carbs 2 & 3 are supplied with
fat mixture also (assuming trhese were OK ?) Maybe the supply pipes are clogged.
Could I have an intake value adjustment problem?
Yes, but not causing the described problem
The auxiliary carb is electrically operated to pull a plunger with a disc to close the orifice of the
suction pipes from the manifolds. There is a little spring which keeps the disc closed when the
aux carb is not in (intended) operation. If there is something wrong here, like spring gone (rusted
away) or disc not closing properly, the constant suction from the inlet manifolds would supply a
small amount of fat mixture.
Hey - I wish my Carb problem would be equally “simple”. Lets hear some feedback after the
weekend
Regards Jeffrey Gram
Date: Fri, 20 Sep 1996 11:22:10 -0700
Subject: Re: XJ Series I parts car
David Quintana;
I understand Cindy has got the XJ S1 and wants to sell it, but I’m sure she’ll
tell you all about it herself.
What I want to say is that whoever buys the heep for parts may; I’m interested
in certain parts of it!
Cheers.
Bard
______ _ ! Baard Th Hesvik, Telesoft AS
/ _ / _ _ _ / / ! Longhammarvn 7, N-5500 Haugesund
/ // / // /_ / / -/- -/- ! T: +47 52735000 F: +47 52717040
/ /_ / /_ / // / /_ ! E-mail: baard@telesoft.no
Date: Fri, 20 Sep 1996 11:48 +0200
Subject: RE: Mk IV drum plating
Hello Dave, the melting point of Cadmium is only 321 degrees C. and the=20
boiling point is 765. This is too low for brake drums and it would simply=20
disappear after a few hard brakings. I’ve never seen brake drums Cd plated=20
nor zinc plated as an anti corrosion treatment. They simply have a rusty=20
appearance. This would probably be the only obligatory rust for a concours!
Frans.
A friend has taken my Mk IV brake drums to “face” the contact surface to=20
get rid of some grooves worn in over the years. No problem. BUT…he=20
asks me if I want him to cadmium plate them also. Can anyone tell me if=20
Dave
80 XJ6 II
47 Mk IV
etc.=20
Date: Fri, 20 Sep 1996 12:44:32 +0200
Subject: Clutch change on 4.2 E type.
I am interested in knowing the most convenient way of changing clutch
in a 4.2 XKE. (Dropping the gearbox under the car?)
Any information or advice is welcomed.
thanks,
Trond V. Olsen
Date: Fri, 20 Sep 1996 13:30:50 +0100
Subject: rec.autos.makes.jaguar(no jag content)
HI
- USENET groups
- Should we (I) support the startup ?
I must support Mike Cogswells description of the usenet groups. There is ENDLESS junk
between the good stuff, and it is such a shame that this worl dcontains so many run-aways
(you know when God handed out brains to people and momentarily went to the store to get
brains quite a number of the people in the queue ran away…).
When I started reading a bit of usenet in November 1993 there were 1400 groups - an
asthonishing amount. Today there are 15.000 !!!.
I have already left the Bass-list group a year ago - a group which was a relatively small
group of audio buffs with a number of very knowlegdable people, but it just became too
much in the end about a year later, swamped with an insane number of newcomers (sorry)
who obviously hadn’t got a clue even to ask politely, who never ever spent a second on the
FAQ,which requires mucho work , for the benefit of those who dont know, and for the benefit of
those who do know and thus do not have to answer the same questions over and over again.
id for jag-lovers-digest-out; Sat, 21 Sep 1996 04:45:57 +0200 (MET DST)
Date: Sat, 21 Sep 1996 04:45:57 +0200 (MET DST)
Message-Id: 199609210245.EAA02369@ekeberg.sn.no
Subject: jag-lovers-digest V2 #369
Precedence: bulk
jag-lovers-digest Saturday, 21 September 1996 Volume 02 : Number 369
RE: UK - Top Gear tv programme last night
Re: Top Gear programme
xj6 sIII speedo problem
Re: Majestic Spec
XJ-S Head liner…
Winter prep
Re: XJ-S Head liner…
RE: XJ-S Head liner…
Re: Clutch change on 4.2 E type.
Jaguar XJ6 Series3
reply - Head liner, take option 4
XJ6 radiator drain
Electric Fan XJS
HS 8 carbs for sale
Re[2]: Majestic Specifications
Re: rec.autos.makes.jaguar(no jag content)
Re: Electric Fan XJS
Date: Fri, 20 Sep 1996 08:36:24 -0700
Subject: RE: UK - Top Gear tv programme last night
Yes, I saw it. Quick summary is that the XJ6 S3 is getting better by the
year, but is largely un-noticed. Prices are just starting to edge up
now, but it should be possible to get a fully loaded 1986 machine in
good nick for under ?3000, which was considered to be a real lot of
machine for the money. about 1986 was also considered to be about the
best year.
Of course , we knew all that anyway, didn’t we …
-----Original Message-----
From: brownd@filon.ml.com [SMTP:brownd@filon.ml.com]
Sent: Friday, September 20, 1996 3:42 PM
Subject: UK - Top Gear tv programme last night
Did anyone happen to catch the item on SII/III Jags on the BBC TV
programme Top
Gear last night? Someone told me it was rather complimentary. I wish I’d
seen it
as I’ve just bought one!
David Brown
brownd@ml.com
/_/_//_/_/_/_/_/_
/_/_/_/_/_/____/________/_/__
/_/___/////_/_/_/_/___/___
Date: Fri, 20 Sep 1996 12:04:15 -0400 (EDT)
system.
All the speculation in the world will not answer this question.
The most likely explanation is oil and looking at the exhaust
does not rule that out. Do a compression test.
Thomas
Date: Fri, 20 Sep 1996 12:11:40 -0400
Subject: Re: Top Gear programme
In a message dated 20/09/96 15:56:55, you write:
Something wrong with that car he bought. He said it was a Sovereign,
yet it was badged as an XJ6. Also, for that year’s model all litre
markings were dropped, yet that car had a 4.2 badge.
It was a Sov, you can tell by the pepper pot wheels. All the Saloons were
known as XJ6 and not all the badges were dropped.
Just think, I could have fitted the sunroof to that car!!
Terry
Date: Fri, 20 Sep 1996 12:24:35 -0400
Subject: xj6 sIII speedo problem
Just bought an 85 XJ6 in Ct. and drove it home to Maine. During the trip
the speedo quit. It’s not totally dead, it sometimes rises and works for a
few seconds. Have replaced both the speedo and the sender in the tranny
without success. The trip computer and cruise control are also not
functioning.
I have been told two look for two inline fuses. One behind the trip
computer and the other under the right hand ashtray. So far I have not
been successful. Did find one under the left ashtray (2 amp). Any ideas
would be helpful.
Date: Fri, 20 Sep 1996 17:30:38 PDT
Not true - pepperpots were an option on XJ6 - as was the leather and
air conditioning. There is also nothing to stop a PO buying the wheels
(as on my XJ6).
All the Saloons were known as XJ6
Maybe - but the Sovereigns had an identifying badge on the back, not
an XJ6 badge
Mine is a September 1985 car (early C reg) - and it has no litre
markings. Also consistent with the notes in Nigel Thorley’s book as
to when they were dropped.
Hmm…you might have fitted mine as well!! Still leak free after 11
years…
Cheers,
Dave Wood.
Date: Fri, 20 Sep 96 10:23:33 PDT
Subject: Re: Majestic Spec
It is indeed true that the Majestic was only offered in 90 and 92
(I have Jag brochures from 90-96). However, the Majestic was not only
offered in Regency Red. In the 92 brochure the Majestic is shown in dark purple (a gorgeous color, by the way). Also the
92 has VDP
wheels. The “chrome eyebrows” over the four wheels are not standard,
and neither is the leaper. The Majestic has a special remote control
that lets you lock/unlock doors and trunk, and raise the windows
and sunroof from up to 20 feet away.
Could you tell me if you can raise the seat headrests in your car? In
my car the 4 headrests all appear to be fixed (my car is a `91 VDP).
Roger Peng (408)765-7863
Intel Corporation
Design Technology, Physical CAD
From: “Connie Vloutely” connie_vloutely@macmail.git.gulfaero.com
Date: 20 Sep 1996 13:56:43 -0500
Subject: XJ-S Head liner…
I think I have a new subject to discuss.
The headliner cloth, in my 1990 XJ-S is seperating from whatever it’s bonded
to Its starting over the driver seat. About 20% of the total area.
I have 4 questions:
Should I wait until more of it seperates…
Is the headliner hard to get down.
What type of glue/adhesive do you use.
Should I get professional help…
Any help would be appreciated.
Date: Fri, 20 Sep 1996 13:59:00 -0400 (EDT)
Subject: Winter prep
In the latest JC Whitney catalog they have “Tank-type” coolant heaters to warm
the engine before starting. Will a 1500w heater be enough for the V12s (it
says 2-3hours to heat up a V8) $26, or should I go for the 2000w heater $40?
What will these heaters do to the coolant? Will they produce air as the
coolant contacts the heating coil, or affect the coolant at all?
Are coolant heaters the way to go (vs. oil heaters)?
Russ Lehman
"nothing worthwhile is ever easy"
"pessimists are accurate; optimists live longer"
Internet: rlehman@npr.org
Date: Fri, 20 Sep 1996 15:29:10 -0400 (EDT)
Subject: Re: XJ-S Head liner…
- Should I wait until more of it seperates…
It probably doesn’t matter much. Usually the headliner
separates due to dry-rotting of the foam rubber layer
between the fabric and the backing board. Once this
starts it is just a matter of time before the whole liner
is down. You generally cannot repair this without
replacing the fabric so waiting will not hurt since you
have to replace the fabric regardless. Glue will not help at this
point since the foam just falls apart. Headliner
fabric is supplied with this foam backing attached.
- Is the headliner hard to get down.
It is difficult to get the headliner assembly out of the
vehicle without damaging the backing board. The backing
is a fibrous material that is very brittle. Manuals
recommend removing this board through the windshield
opening so you are supposed to remove the windshield.
Fortunately the fabric can be replaced with the backing
board in place.
- Should I get professional help…
If you have to ask, then probably so. I believe the job can be
done for $200-$300.
Thomas E. Alberts
Date: Fri, 20 Sep 1996 12:46:51 -0700
Subject: RE: XJ-S Head liner…
Coincidently, I am in the midst of replacing the headliner in my '85
XJ-S. The headliner is adhered to a rigid fibre board form of some
sort. I have found a very reputable interior specialist who often works
on Jags who will redo the headliner and all other fabric trim for $285.
I have chosen to seek professional help because this repair is due to an
accident (not my fault) and therefor, is covered by insurance.
Aaron
'85 XJ-S
From: Connie Vloutely[SMTP:connie_vloutely@macmail.git.gulfaero.com]
Sent: Friday, September 20, 1996 11:56 AM
Subject: XJ-S Head liner…I think I have a new subject to discuss.
bonded
to Its starting over the driver seat. About 20% of the total area.I have 4 questions:
Date: Fri, 20 Sep 1996 13:24:11 PDT
Subject: Re: Clutch change on 4.2 E type.
Hi Trond!
Now that you’ve finished restoring your 356, have you decided to move
on to an even more challenging car?
Sorry to give you bad news, but the only way to get to the clutch is
to pull the engine, which I have recently discovered is a very
time-consuming operation!! It isn’t possible to pull the transmission
separately.
Greg DesBrisay
'70 Jaguar Series-II 4.2-liter FHC E-type
'67 Porsche 912
Date: Fri, 20 Sep 1996 22:04:22 +0100
Subject: Jaguar XJ6 Series3
I’m 25 years old currently live in UK(London) and just got my british
driving license. My dream was about Big Cat series3 as long as I remember,
but it was every time too expensive for me, so I almost lost my hope. Now
dream can began be true, because it possible to find in UK 1985-86 XJ6 mk3
with 70-80 000 miles in good condition for �3000-4000. But I’m not rich and
cannot afford pay running cost of thousands pounds per year just to keep
car running. Nobody around cannot talk to me how much it typically cost to
maintain Jag, true reliability , durability, fuel efficiency, rust
resistance etc.How long last their engines and gearboxes with carefill
services? Is it true, that 85- cars got much more reliable mechanics and
rust proof paint? Some magasines write, that Mk3 can get classic insurance
in UK. Does somebody have such experience? How much it cost? And by the
way, is it suitable for everyday car (apart from petrol bill)? I have
little experience of mechanic job, can I DIY elementary maintenance job?
I’ve would be very appreciate any opinions, expirience, from XJ6 Mk3
past/present owners. What engine and trim level was best?
Help me please, because I afraid to buy Cat which can ruine me financialy,
but cannot find right answers myself.
I can be e-mailed at: haruko@vossnet.co.uk
Thank everybody
Bob
Date: Fri, 20 Sep 1996 16:15:12 -0500
Subject: reply - Head liner, take option 4
Multiple choice is always easy - don’t wait, it’ll quickly get worse (the foam
rubber backing has perished) and annoy you unnecessarily - select choice 4
(replacement). The experts do this in their sleep, cost is usually reasonable
and its not a nice job. I did detach the head lining once, then didn’t know
what to do with it as I lay on my back in the car with the fibreglass panel
balanced on my hands and one foot - I put it back in place and drove to the
upholsterer the next day. Get a quote - I think you’ll find its the best
option. Get any other things fixed at the same time like dash board, seats,
door trim.
connie_vloutely%macmail.git.gulfaero.com @ Internet
20/09/96 10:36 PM
To: jag-lovers%sn.no @ Internet
cc:
I have 4 questions:
Date: Fri, 20 Sep 1996 16:23:30 -0500
Subject: XJ6 radiator drain
Here I was, all set for a big day of routine maintenance. Oil change I
did, without trouble, having done it before–I even decided to go for
synthetic stuff after reading Jim Isbell’s XJ6 book (great job–many
thanks). I was stymied, however, when I got the cooling system. I
could not for the life of me find a drain plug on the radiator. I found
the engine plug–its location is illustrated in the Maintenance Book and
the Service Manual. I was all ready with my radiator flush and my
absence of Barr’s Leaks–what a disappointment. Would someone tell me
how to drain the radiator on this car (1987 XJ6)?
Steve Coleman, Gadsden, AL
1987 XJ6 x2
Date: Fri, 20 Sep 1996 14:12:13 -0500
Subject: Electric Fan XJS
Someone posted to the list that they had removes the mechanical fan and
replaced it with an electric fan on an XJS
I cant remember who it was.
I am interested in the possibilitys and would like to know the size fan used
and the results.
JIM I.
“Prefiero morir de pie que vivir de rodillas.”
Gen. Emiliano Zapata
1879-1919
Date: Fri, 20 Sep 1996 18:29:17 -0400
Subject: HS 8 carbs for sale
We have a used set of HS 8 carbs. these will fit the early XJ6’S. Please
give David a call for more info.
British Car Specialist 2060 N. Wilson Way Stockton Ca 95205
209-948-8767 (fax# 948-1030) Healey Doc@aol.com
Technical books by Norman Nock avalilable for the MG and Healey.
Date: Fri, 20 Sep 1996 18:33:10 -0500
Subject: Re[2]: Majestic Specifications
I wonder if the monster gold leaper and the chrome eyebrows over the wheel
wells were inflicted by the PO?
MikeC
______________________________ Reply Separator _________________________________
Author: RMac@aol.com at Internet
Date: 9/19/1996 10:35 PM
<snip>
Fog lamps
“Square” headlamps
monster gold leaper
body color
Picnic tables
rear seat headrests
PO.
Date: Fri, 20 Sep 1996 18:55:40 -0500
Subject: Re: rec.autos.makes.jaguar(no jag content)
However, while I myself probably would only attend the usenet group until the
noise level became intolerable (estimated time < 1 week) I did vote in favor of
it. Hopefully it will serve as a buffer between this cherished mail list and
the ugly world the internet it becoming. (I certainly hope we don’t advertise
this list on usenet.) In addition, it might serve as a useful forum for
Jag-lovers who are uninterested in classic Jags or technical discussions.
Finally, by slowing the growth here it may delay or even prevent this list from
splintering into multiple lists.
MikeC
Author: Jeffrey Gram Gram@eumetsat.de at Internet
Date: 9/20/1996 1:30 PM
rec.autos.makes.jaguar(no jag content) HI
- USENET groups
ENDLESS junk between the good stuff
Contra’s are :. I am frightened of the obvious link to this list, and hordes of
Jaguar freaks of the bad bad kind could disturb our daily lives on this list.
Difficult to jugde - I guess that is just where it is going to go - no matter
what I, you or we say, feel or do.
As Lawrence quoted the herd of elephants…
But halfheartedness doesn’t bring anything (of value), so in the naive? hope
Lawrence has his jugdement just right, I will support the new group by my vote,
and promise to read it often.
So to you all out there : make your standpoint (not necessarily publicly…help
…swamped again…) and send that vote off
Date: Fri, 20 Sep 1996 21:57:02 -0400 (EDT)
Subject: Re: Electric Fan XJS
I did this to my XJ-S. I know that others on the list have as well.
I used a 17" S-blade electric fan I purchased from a mail order street rod
source – Southern Rods or somesuch. I think their number is
800-strt-rds.
I removed all of the mechanical fan stuff. Found it easier to do this by
removing the top plate over the radiator. Then you can also clean the
detritus that accumulates in there.
Two bolts from the original fan mount casting have to be replaced. I
think that one must be longer than the other and these are fiine thread
bolts. THese two help secure the water pump.
I mounted the new electric fan within the shroud from the original
mechanical fan. Drilled four holes and made two spacers to match it all
up. I would not recommend mounting the new fan to the Jag radiator using
those stupid little plastic whozits, because as Kirby points out is his
book, the stock radiator is a ‘vibration sink’ for the rest of the car.
Introducing any kind of vibration onto the rad results in a very shaky
Jaguar (I know because I tried this as a quick and dirty – changed the
mounting after a couple of days).
To control it, I hung a relay off the circuit that energizes the little
stock fan.
Works great.
John
replaced it with an electric fan on an XJSI cant remember who it was.
and the results.JIM I.
Gen. Emiliano Zapata 1879-1919
Date: Fri, 20 Sep 1996 22:40:50 -0400 (EDT)
system.All the speculation in the world will not answer this question.
does not rule that out. Do a compression test.Thomas
If I remember correctly, the problem car here is an XJS. However, I can
not remember which engine it has.
If it is a V12, I doubt that the oil is getting in to the cooling system
via a bad head gasket. In order for oil to get into the cooling system,
especially to pressurize it as described, the source would have to be
from a pressurized oil galley. There are no oil feed galleys passing
through the V12 head gasket (same for the XK engine). There are only oil
drains. All pressurized oil is fed to the cams via the tubes on the
back of the engine. If it is a V12, the logical suspect would be the
transmission cooler.
The AJ6 engine (3.6/4.0 L) does pass pressurized oil through the head
gasket. The early engines were known for the sealing ring around these
passages to shink/collapse. The standard failure is for it to leak oil
out between the head and block, just even with the front of the exhaust
manifold. I suppose it is possible for one of these to leak inwards to a
water passage rather than, or in addition to, the common external point.
Randy K. Wilson
randy@taylor.infi.net
End of jag-lovers-digest V2 #369
id for jag-lovers-digest-out; Sat, 21 Sep 1996 18:18:00 +0200 (MET DST)
Date: Sat, 21 Sep 1996 18:18:00 +0200 (MET DST)
Message-Id: 199609211618.SAA28550@ekeberg.sn.no
Subject: jag-lovers-digest V2 #370
Precedence: bulk
jag-lovers-digest Saturday, 21 September 1996 Volume 02 : Number 370
Re: XJ6 radiator drain
Re: Arggg!! Brake Dust on my XJ40!!
Re: xj6 sIII speedo problem
Re: XJ6 Steering Rack and Gas Tanks
recap of responses to: 64 S-type shifting hard
Re: Connie Vloutely’s “XJ-S Head liner…” questions
RE: xj6 sIII speedo problem
Re: Winter prep
Re: [XK Engines] Piston Scuffing
XJ6 parts interchange list
RE:Arggg!!Brake Dust on my XJ40!!
RE: Steering Rack and Gas Tanks
1980 XJ6 Exhaust
Re[2]: Arggg!!Brake Dust on my XJ40!!
XJ-S steering rack, shocks and springs
Date: Fri, 20 Sep 1996 22:45:56 -0500
Subject: Re: XJ6 radiator drain
- –IMA.Boundary.764472348
Disconnect the lower radiator hose at the radiator end.
MikeC
Author: scoleman@pcl.net at Internet
Date: 9/20/1996 4:23 PM
1987 XJ6 x2
- –IMA.Boundary.764472348–
Date: Fri, 20 Sep 1996 21:53:43 -0500
Subject: Re: Arggg!! Brake Dust on my XJ40!!
Michael Powers would like to clean his wheels less often. I recently =
purchased KleenWheels for my XJ6 and they made a world of difference. =
The product is similar to a pie tin and fits inside the wheel between =
the rotor and the wheels face. My car has XJS lattice wheels that are a =
true pain to clean but not as bad as wire wheels. The fit was good, but =
I did have to reform the dust shield a bit to clear the brake calipers. =
KleenWheels are malleable. Now I only use a spray that I hose off. I =
know that others on the list have them as well and they might want to =
chime in. You can order them at PEP Boys or through JC Whitney. They =
come by the pair and you only need one pair – for the front – as the =
rear brakes are well inboard. I’m sorry that I don’t remember the price. =
P.S. I can state with certainty that Jaguar is not overly selective in =
its invitation to a private showing of the XK8, and other 97’s, as mine =
arrived today.
Date: Fri, 20 Sep 1996 23:42:59 -0500
Subject: Re: xj6 sIII speedo problem
functioning.I have been told two look for two inline fuses. One behind the trip
would be helpful.
I have seen these symptoms caused by wear in the techometer drive
spool. The wear is in the ‘square cut’ socket in the spool. Replacing
the gear is possible from outside the transmission, as I remember it.
Unbolting the techometer exposes the spool, that can be than pulled
from the transmission.
Hope this helps,
Bob Johnson
Brattleboro, Vt.
XJS, XJ50
Date: Fri, 20 Sep 1996 23:51:57 -0500
Subject: Re: XJ6 Steering Rack and Gas Tanks
KEATING, SCOTT wrote:
I have an '85 XJ6 and two problems:
- I think the gas in my two tanks is leveling out. If I draw gas from the
right tank, say, until it is near empty, and the left tank is full, and leave
the car parked for a couple of day, when I go to use the car again I find
both tanks are about half full. Should this be happening? If not, what
might be wrong and how can I fix it. (I removed the two gas tanks recently
to re-line them because they were starting to leak.
Scott Keating
I would bet that the problem is caused by particles of rust set free
when the tanks were serviced. This rust lodged in the non-return
valves that control the flow of gas from the two tanks. If one of
these two valves does not close the fuel will seek a constant level.
Bob Johnson
Brattleboro, Vt.
XJ12L, Mk X
Date: Fri, 20 Sep 1996 15:56:00 -0400
Subject: recap of responses to: 64 S-type shifting hard
In message “Re: 64 3.8 S-type automatic transmission shifting hard”,
Mario James writes:
If that particular transmission has a govenor, I would replace
that part first.
Good point. I’d asked if the valves had been changed and it turns out they
hadn’t. I didn’t know to ask about the governor, but it makes sense to check
that. So - to recap the points I’m going to pass to the owner:
Mario James suggests changing the governor if the DG250 has such a part.
Alastair Lauener suggested:
- check the throttle-transmission linkage to be sure that the
transmission 'knows' about the throttle setting. Use the manual
for the adjustment procedure.
- ensure that the re-build was done properly. 8-< This is not going
to be popular, but if the adjustments don't help ...
- ATF amounts quoted in the literature may be for a 'fill from change'
as opposed to 'fill from dry'. Comments on the list from E-type
owners about filling the transmissions in their cars indicate the
same sort of confusion exists for other cars. In any case, there is
an internal dipstick in the DG250 that is more accurate.
Regards - Albert Cohoe
Voice: 393-3440 or 613-763-3440 Email: cohoe@nortel.ca
Date: Wed, 18 Sep 1996 21:18:07 -0700
Subject: Re: Connie Vloutely’s “XJ-S Head liner…” questions
I re-did the head-liner in my 85 XJ-S early this year as part of a “renewal”
effort. I did it all myself even though I had not done anything like this
before. I am pleased with the end result and found it to be relatively
straightforward; however, it took some time and patience. I thought that
other people in the group might be interested in my experience so here are
my comments to Connie’s questions…:
1.The liner will continue to separate unless it is reglued or replaced; I
know this first hand!!! Re-gluing may be possible but will require removing
the headliner out and carefull spreading of glue (probably with a brush) to
re-attach the liner. However, you may end up with a residual “crease”
and/or a different “look” to the re-gluewd portion of the liner.
2.The headliner shell is not hard to get down but it requires taking apart a
fair amount of the interior trim/upholstery. This inlcudes the back shelf,
back seat, the front and rear “posts”, the rear quarter panels (also covered
with liner), and the “crash roll bars” at the top of the windows (also
covered with liner). You also will need to dissasamble three lights (two at
the back panels and one over the driver’s console). You will also need the
help of another person to maneuver the headliner shell out of the car. This
will take half a day worth of tinkering for the slow methodical types like me.
3.The glue is “auto trim adhesive”. 3-M makes cans and spray-cans of the
stuff and you can find it (or a comparable product) at hardware stores or
home improvement places. I used the spray can stuff to do the headliner
shell itself (the largest, size wise, amount of gluing). However you will
need some glue in a can to do the smaller quarter panels and the roll bars
(you’ll also need a brush and lots of “adhesive thinner”; sold at the same
places as the glue).
The headliner material can be trimmed with scissors; however you will need
a “razor” knife in order to fine trim and to make cuts/notches that are
necessary to fit the liner around curves in the smaller pieces.
Also, the quarter panels are tricky to fit correctly. The liner has to be
stretched over the panels and glued only around the backside of the edges.
Otherwise, a very bothersome large bolt found in the middle of the area that
the panels cover will poke right through the liner. Trust me…I know!!!
Putting the newly re-lined shell back in is for some reason trickier than
getting it out. It will take a little contorting and two people at a minnimum.
Taking the liner off, gluing the new one on, doing the smaller pieces and
letting the whole thing dry for a day, and puttiong this hard worked-on
piece of art back in will span the better part of two days!!!.
The two most important piece of advice regarding this whole lengthy and
complex endeavor…:
a)use glue sparingly!!!
b)do not press the liner down after it is glued. Gently let it down
over the shell and “mold” any parts that need to fit contours by
using a light finger touch. Otherwise, bumps and creases in the shell will
show through.
4.In order to do this yourself, you can expect to spend about $50 to $70 for
headliner material and an additional $30 for glue, thinner and brush. You
may also have to rent a steamer in order to separate the rest of the
headliner material from the shell that it is glued onto (on my car it is a
pressed fiberglass material that would peel off if the liner was strongly
attached to it; the steamer softens the old glue and allows it be pulled off
without peeling); I didn’t have to do that since my liner literally fell
right off the shell. I am going to guess that it will add another $20-30 to
the cost.
As you can see you are looking at the possibility of investing about
$100-130 and a couple to three days to do it yourself. By contrast, I was
quoted between $180 and $240 to have it done by three reputable upholstery
shops.
The choice is a personal one. I enjoyed the experience of doing it myself.
However unless you want to try doing this yourself the price differential
may not warrrant it.
Good Luck and feel free to contact me if you need some additional
explanations, information, or help.
Rob W-M
85 XJ-S
Date: 21 Sep 96 00:21:59 EDT
Subject: RE: xj6 sIII speedo problem
Bruce,
I had a similar problem on the Series III I used to have. Also tried replacing
the same parts, but to no avail. However, on this list a few weeks ago there
was a comment that the problem may be caused by the shaft of the speedo cable
wearing round at the point that it enters the sender unit.
Good luck.
Sent: Friday, September 20, 1996 11:46 AM
To: INTERNET:JAG-LOVERS@SN.NO
Sender: jag-lovers-owner@sn.no
Received: from ekeberg.sn.no (ekeberg.sn.no [194.143.8.8]) by
arl-img-5.compuserve.com (8.6.10/5.950515)
id NAA01026; Fri, 20 Sep 1996 13:40:52 -0400
Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4)
id for jag-lovers-out; Fri, 20 Sep 1996 18:25:01 +0200 (MET
DST)
using -f
Received: from mint.mint.net (mint.mint.net [204.254.98.2]) by ekeberg.sn.no
(8.7.5/8.7.3/on4)
with ESMTP id for jag-lovers@sn.no; Fri, 20 Sep 1996
18:24:57 +0200 (MET DST)
Received: from [169.244.8.3] (bsawyer.reeds-brook.sad22.k12.me.us [169.244.8.3])
by mint.mint.net (8.7.5/8.6.9) with SMTP id MAA03220 for jag-lovers@sn.no;
Message-Id: 199609201624.MAA03220@mint.mint.net
Mime-Version: 1.0
Content-Type: text/plain; charset=“us-ascii”
Sender: owner-jag-lovers@sn.no
Precedence: bulk
functioning.
would be helpful.
Date: Sat, 21 Sep 1996 00:41:02 -0400 (EDT)
The brake dust is transported to the wheels via the air flow. The air
flow meant to cool the brakes. These things block that air flow. They
will cause premature brake overheating. On a car as heavy as a Jag,
especially if it’s driven, ummm, spiritedly, it doesn’t take much.
Look under the nose of a XJ40. Those two big (3x4 inch) holes lead in to
nicely sculpted ducts that point directly at the brakes. Jaguar went
through all this trouble to get air to the brakes. Block the exit path
at your own risk.
Randy K. Wilson
Date: Sat, 21 Sep 1996 01:12:14 -0005
Subject: Re: Winter prep
Perhaps we should start with the definition of “enough”. In theory,
your car should start in ANY weather WITHOUT such a heater. Just
what is considered “enough”, therefore, would depend on the condition
of your engine, starter, and battery.
However, most people who use such heaters claim more benefits than
easier starting. Supposedly, running a very cold engine – with the
accompanying very rich mixture required – is not good for engine
wear. Therefore, the warmer the engine is to begin with, the less
time it spends running in this harmful condition.
And, of course, you didn’t mention just where your car will be. Are
you parking it outdoors in the Klondike?
Uh – they heat it.
I don’t think “producing air” is a possibility – we’re not talking a
nuclear reactor here. If it produces steam, it will probably
condense again shortly – but may cause deposits on your heater in
the process.
If you’re concerned about this, there are models that fit into
a radiator hose that include a pump. These have the advantage of
keeping the entire cooling system warm, not just a local spot. They
have the disadvantage of needing more watts – you are circulating
through the radiator!
Compared to, say, contact with a toasty cylinder liner?
Personally, I’d go coolant heater first, add the oil heater later if the
coolant heater isn’t enough.
– Kirbert | If anything is to be accomplished,
| some rules must be broken.
| - Palm’s Postulate
Kinda steep. I had it done for a little over $100 a few years back.
| - Palm’s Postulate
Date: Fri, 20 Sep 1996 22:32:57 -0700
Subject: Re: [XK Engines] Piston Scuffing
It was probably coolant washing down the walls causing the scuffing.
Several times now I’ve had the pan off a Series 3 XJ6 with the cooling
system pressurized and had coolant leaking past the headgasket and
dripping on me. To me it looks like the cut between the cylinder bores
causes a loss of sealing area.
Kroppe wrote:
Greetings All -
the gudgeon pin.The guy at the shop speculated that it could be from oil
tell. That explains only one of the three bad pistons.What it means to me is ~$400US for new +0.020" pistons.
who knows about the POs.Thanks for any and all replies.
Michael P. Neal ASE Master Technician, Jaguar Certified
'93 Ducati 900SS '83 Porsche 944 '85 Jaguar XJS
Home (707) 829-8464 Work (707) 577-0101
http://www.wco.com/~mneal (always under construction:-)
From: David J Shield David_J_Shield@ccm.fm.intel.com
Date: Fri, 20 Sep 96 23:26:00 PDT
Subject: XJ6 parts interchange list
Jag-lovers,
As you may remember, I’ve been quetly toiling away at a
parts-interchange guide for the XJ6. Much of the data comes from
captures from the jag-lovers list. Jim Isbell will include it in his
(excellent) XJ6 booklet in the next release. I’ve posted it to my web
page, so please have a look and let me know additions/errors.
http://www.ns.net/~dshield
I’ve handed the fuel-injection section to my local Bosch/Lucas parts
dealer, he’s got his own data on a lot of these items, and promises to
fill in as many blanks as he can in the next few days. I’ll be out of
town for the next week, and far away from e-mail, so when you send me
mail just be patient if you expect a response from me.
Anyone going to the XK’s Unlimited Open House on Oct. 5th? I’m planning
to connect up with Bill Clark and his colleagues for the drive down
there.
Date: Sat, 21 Sep 96 10:03:19 -0700
Subject: RE:Arggg!!Brake Dust on my XJ40!!
I have had brake dust problems with my series III and I agree it’s a drag.
What I found was the previous owner had the car serviced just before he sold it,
the garage replaced the pads with non-standard parts. These pads were considerably
cheaper than the Jaguar pads and didn’t last very long either because they were
made from a softer material. I solved the problem by replacing with Jaguar
parts but I guess any GOOD quality pads will do.
Yet another case of after market short cuts in manufacture, don’t use cheapies!
Barrie Dawson
1985 series III Jaguar Sovereign
Date: Sat, 21 Sep 96 11:55:00 GMT
Subject: RE: Steering Rack and Gas Tanks
The Gas tanks problem looks like return valves being blocked. Remove pipes
and clean out, if dirt/rust has got into the valves they cannot be repaired.
I’d
also check the venting of the tanks you may have got them wrong.
Are you sure the steering rack is leaking and not the pump, Ive noticed the
fan is powerfull enough to blow fluids around the engine bay quite well.
This
has caught me out before and you may find this to be the case. If not a
complete
overhaul/replacement is needed.
Barrie Dawson
Chatham, Kent England
1985 Series III Jaguar Sovereign
------------------------------ End of forwarded message 1
Date: Sat, 21 Sep 1996 10:43:35 -0400
Subject: 1980 XJ6 Exhaust
Hey All Good Jaggers:
Bought a stainless steel exhaust system for a 1980 XJ6 Series 3 from =
Double S Exhaust. It’s manufactured in the U.K. and distributed in =
Canada by an English chap named Malcom Ives operating as the Phyllis May =
Corporation. Seems like a super guy.
However, I can’t get the damn over axle pipes to fit properly. The =
brackets that are welded on the new stainless steel pipes that hold the =
pins that insert into mating brackets on the IRS cage are on the inboard =
sides. But the existing over axle pipes from the car (original, I =
believe) have brackets on the outboard sides of the pipes to coincide =
with the mating brackets on the cage.=20
So what’s going on? I’ve got the two pairs of over axle pipes sitting =
next to each other on my shop floor, the new stainless steel RH pipe and =
the old RH pipe, same with the left side, and the brackets are not =
welded in the same area on the same side pipes!
Malcom, from Double S, assures me he’s had no complaints from others, =
and he’s been distributing them for two years. The manufacturer assures =
him it’s not a manufacturing defect. Just in case, they sent me two more =
over axle pipes but it’s the same problem.
Is it possible that the 1980 XJ6 I’m working on is the only one that =
these over axle pipes won’t fit?
Has anybody out there had a similar problem? Any words of wisdom, before =
I lose it?
Thanks in advance.
Date: Sat, 21 Sep 1996 11:59:05 -0500
Subject: Re[2]: Arggg!!Brake Dust on my XJ40!!
My '88 XJ-S generated enormous amounts of black brake dust on the front
wheels (five-spoke) from the first day. So, at least in my case, Jag pads
wern’t a good solution. I bought a pair of Kleen Wheels, which was the
dealer’s recommended solution, back in '88. Once I got them unpacked and
saw how tiny the slots were I decided I would rather cope with dust instead
of badly overheated rotors. Consequently, they’re still on the shelf in my
garage. (Next to my stockpile of spare E-Type fuel pumps and fan relays.)
With my anti-social driving habits the front brakes are already too hot
more than they should be.
MikeC
Author: Barrie Dawson DAWSONB@btcec3.agw.bt.co.uk at Internet
Date: 9/21/1996 10:03 AM
drag. What I found was the previous owner had the car serviced just
before he sold it, the garage replaced the pads with non-standard
parts. These pads were considerably cheaper than the Jaguar pads and
didn’t last very long either because they were made from a softer
material. I solved the problem by replacing with Jaguar parts but I
cheapies!
Barrie Dawson
Date: Sat, 21 Sep 1996 12:04:31 -0500
Subject: XJ-S steering rack, shocks and springs
I'm resending this, since I haven't received any replies so far. I
have followed the messages on various rear springs with interest, but
unless the installed height and spring rate is known the free length
isn't particularly useful. I still would like to get some input from
people who have overhauled and/or upgraded their suspensions.
I plan on overhauling the suspension of my '88 XJ-S (Hess & Eisenhardt
Convertible) this Winter. Although the car has been basically trouble
free, and the tires have nice even wear on all four corners, the
general handling is much sloppier than it was 8 years ago. (No big
surprise there!)
I definitely plan on replacing all the rubber bushings (using the
non-Jag hard bushings for the rack that everyone seems to love) and
the shocks. Ball joints too, if they are worn.
My questions:
1. What shocks have you tried on an XJ-S and what did you
like/dislike about them? Will you buy the same ones next time?
2. Has anyone replaced the springs with stiffer ones? If so, where
did you get them? How much stiffer? Are there JagSport springs for
the XJ-S?
3. Is there a steering rack available from a different XJ-S (or
other Jag) that has a quicker ratio. Compared to my E-Type, and even
my wife's Hondas, the XJ-S seems to have fairly slow steering.
4. What am I overlooking here that I'll really regret when I find
out about it?
Any and all input appreciated.
Thanks in advance
MikeC <m.cogswell@zds.com>
'74 E-Type OTS
'88 XJ-S (H&E Convertible)
'88 Honda Accord (340,000 miles and climbing)
'91 Chevy Suburban (when you really need the room)
'96 Honda Accord (hope it lasts as long as the '88)
End of jag-lovers-digest V2 #370
Return-Path: @owner-jag-lovers-di1
id for jag-lovers-digest-out; Sun, 22 Sep 1996 11:39:27 +0200 (MET DST)
Date: Sun, 22 Sep 1996 11:39:27 +0200 (MET DST)
Message-Id: 199609220939.LAA20906@ekeberg.sn.no
X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f
To: jag-lovers-digest@sn.no
Subject: jag-lovers-digest V2 #371
Reply-To: jag-lovers@sn.no
Errors-To: @owner-jag-lovers-di1
Precedence: bulk
X-Newsgroups: mail.jag-lovers-digest
jag-lovers-digest Sunday, 22 September 1996 Volume 02 : Number 371
[SIII XJ6] Sovereign equipment
Re: Winter prep
V-12 stumbling
XJ-S Airflow Experiment
Re: Jaguar XJ6 Series3
Bodywork on XJ6 in NYC?
Re: Majestic Spec
XJ40: Factory Alarm
New to list → Introducing …
Re: Need Good Book
Jag XJ6 Series III
Re: Winter prep
1997 Jaguar line
Re: Cooling system service questions
Re: XJS Problem
Date: Sat, 21 Sep 1996 19:26:37 +0200 (MET DST)
Subject: [SIII XJ6] Sovereign equipment
All this talk about the Series III XJ Sovereign has made me wonder if the
Sovereign designation meant different things in different markets?
My '86 XJ6 Sovereign was sold new in Norway in November of '85 by Oslo
Jaguar Service. I’ve talked to them and they confirm that my car is
indeed a Sovereign. However, it lacks:
- Pepper Pots (instead its got standard steel wheels with large, chrome
“hubcaps” that cover the entire wheel)
- Sunroof (but it has got the climate control system)
- Computer (instead, just a very cheap looking clock)
- Cruise control
On the rear of the car it says “Jaguar” on the left and just “Sovereign” on the right. The interior is very nice with veneer and leather all over the place, rear seat headrests and reading lamps on the C pillars. Gunnar Gunnar Helliesen | Bergen IT Consult AS | NetBSD/VAX on a uVAX II Systems Consultant | Bergen, Norway | '86 Jaguar XJ6 4.2 Sovereign gunnar@bitcon.no | http://www.bitcon.no/ | Vicki who? What .sig virus? From: Gunnar Helliesen gunnar@bitcon.no Date: Sat, 21 Sep 1996 19:42:55 +0200 (MET DST) Subject: Re: Winter prep RLehman x2576 RLEHMAN@npr.org wrote:
warm
(it
$40?
In the Scandinavian countries coolant heaters are very common. The PO had
one installed in my car. It is a very good idea if you live in a climate
where the temperature sometimes drops below freezing and you still want to
use your car. They normally don’t heat the coolant all the way to normal
operating temperature, but even so they are said to reduce cold start
wear on the engine, cold start pollution from the engine and of course
the heater works right away helping you defrost the windshield.
My car even has a 220V outlet in the passenger compartment allowing the
use of a small electric oven to heat the inside of the car as well.
As for the power of the element I’m not sure, but even 1500W seems an awful
lot to me. I’m afraid I have no idea how powerful the element in my car
is, but I could check how powerful the “normal” elements sold around
these parts are.
Gunnar
Date: Sat, 21 Sep 1996 13:50:25 -0700
Michael Powers/TEIR/Thomson wrote:
As a new 89 XJ40 owner, I have begun to notice an exorbitant amount
of brake dust being produced by the car!! I have to clean my wheels
every 3-4 days to keep them looking sharp. Has anyone come up with a
solution to this problem?
The XK’s UNLIMITED parts catalog says, “Girling Metal Master brake pads
deliver less fade and longer life than organic pads. They produce
no dust and less noise, and show no significant decrease in stopping
power in the wet.” They are listed for $85.00 for your car (part
#06-GPX3083).
I haven’t tried them but would be interested to know if anyone has.
Date: Sat, 21 Sep 1996 15:18:56 -0400
Subject: V-12 stumbling
About two years ago my V-12 E-type had a series of dying/fainting spells
…after running for 10-20 minutes the engine would begin to misfire, run
rough and refuse to rev above 1000 rpm. After much mucking about it turned
out the fuel pump was overheating and jamming … cured by a new fuel pump.
About 1 year ago I had a series of similar but less pronounced episode
where when hot it would briefly run rough for 10-15 seconds and then be
fine (this would occur at any RPM). After doing this for a couple of
months, one day it just cut out completely … diagnosis was cooked ignition
amplifier which was an original, bolted to the engine between the two heads
… cured by replacing the amplifier, and moving the new one (a Crane
XR-700 amplifier) to the bulkhead.
Yesterday while cruising along a busy highway at 3000 rpm I noticed that
the engine temperature was a little high (a little to the right of the “L”
in normal whereas it is usually at the “M” or “A”)…ambient air temp =
22oC, road surface temp perhaps = 28oC. Suddenly I had that horrible
feeling of running rough and loss of power again (ignition or fuel
starvation again?). Pulled off, checked sparkplug leads, vacuum hoses, fuel
pump => spark to all cylinders, no loose hoses, puel pump was clicking
normally. Took five minutes out to control those dark thoughts (the one’s
about wrecking yards and car eating metal crushers and the ultimate destiny
of cars which piss me off once too often), the climbed back in, turned the
ignition key, fired up great, temperature fell back to normal range and no
further problems for the next 2 hours in stop and go traffic with RPM
ranging from 1000 - 3500 rpm. Fickle beast!
These mystery fainting spells piss me off because they’re difficult to
describe, worse to find, and kill the joy of the machine because you figure
it’s going to leave you in the lurch in an embarrassing situtation (busiest
intersection in town) or worse a dangerous situation (power-out 30 feet in
front of a 16-wheel tractor trailer laden to the gunnels with steel ingots
and closing those 30 feet at 120 kph)
Any suggestions as to what to do to find it
Could it be the ignition coil (at least ten years old)?
Could it be the fuel pump dying again — when I replaced the fuel pump two
years ago, I was told that the twin pumps made by Lucas frequently fried
themselves, but there was no other available replacement and one had to put
up with it (is this true or are there other makes of more reliable pumps)?
Peter
Date: Sat, 21 Sep 1996 15:20:33 -0400 (EDT)
Subject: XJ-S Airflow Experiment
A recent thread debated the airflow and temperatures in the underhood area
of the XJ-S. I volunteered to do some testing.
As soon as I did, our area was treated to a week of cool temps and rain –
not the best ambient conditions for the test – and since then I’ve been
travelling. I will get to it when things settle down, but it will be
another week or so at best.
But I didn’t forget and I will perform the tests.
John
Date: Sat, 21 Sep 1996 21:46:37 +0000
Subject: Re: Jaguar XJ6 Series3
Bob,
I live in London also, and bought an XJ6 SIII about a year and a half ago for a lot less than you mentioned
(about �1500). Its not in amazing condition buts its not bad as its only 10 years old (ie 1986 car). I think I
probably like it the most out of all the cars I have owned, old and new.
It can be expensive to get work done on it, but if you can do the simple stuff yourself it is affordable, apart
from the fuel costs. I have found the car to be pretty reliable, it hasn’t let me down yet (maybe I shouldn’t
have said that!).
As far as insurance goes, it will be expensive at your age. Look through the classic car magazines, there are
lots of ads for insurers. Phone several of them as you will find the price will vary enormously. I had qoutes
ranging from �500 to �2000.
Let us know how you get on.
Regards
Pete Hamel
but cannot find right answers myself.I can be e-mailed at: haruko@vossnet.co.uk
Thank everybody
Bob
Date: Sat, 21 Sep 1996 15:19:42 -0400
Subject: Bodywork on XJ6 in NYC?
I’ve had some trouble finding a good place in the New York area to have
some straightforward bodywork done on a 1983 XJ6. Most generic body-shops
are reluctant to work on Jaguars (I think they are intimidated) and the
Jag-specific places I know of don’t do body work.
Does anyone have any suggestions? I just need to reinforce the underbody –
particularly the right forward jacking point – it is rusting through. I am
fully aware that you can never really get rid of a rust problem like that,
but I’d like to not be spraying water throughout the cabin whenever I run
over a puddle. There are a few other patches I’d like to deal with, but the
floor is the most pressing and, I think, is simple enough to use as a gauge
of a shop’s quality.
I actually have a welding torch and gear and would be willing to attempt
this myself, if I could only raise the car up.
Does anyone know where, in the New York City area, I could have something
like this done? I can go a fair distance for this job, but as my “regular”
guy is in Boston, I’d love to find something convenient for all the many
things which will crop up beyond my abilities.
Thanks for any help.
- -Jon
Jonathan Young
jyoung@gonzo.turner.com http://albert.astro.williams.edu/~93jay
http://cnn.com http://cnnfn.com
Date: Sat, 21 Sep 1996 18:20:43 -0400
Roger Peng commented:
(I have
offered in
Regency Red. In the92 brochure the Majestic is shown in dark purple (a gorgeous color, by the way). Also the
92 has VDP
wheels. The “chrome
my
Interesting about the Purple. I have never seen it but would like to. Could
you tell me if there is any Majestic-specific sales literature for which I
should be hunting?
My headrests also appear to be fixed. Because of the electrical wiring in
them I have been reluctant to pull too hard.
My car also has the remote; I thought this was standard alarm capability.
Don’t believe that 20 foot specification. Depending on what side of the car
I approach from, I must be from six feet to close enough to touch to be
received. Incidentally, while the remote has only one button visible, when I
changed the battery recently I discovered two switches inside. Makes one
wonder what the other one was meant to do. Logic seems different from newer
Jags:
first push: unlock doors and trunk
second push: unlatch trunk
I find this quite convenient, as I use my trunk daily.
I would love to remove the leaper, but not enough to repaint the hood.
An acquaintance of mine wants me to “Daimlerize” it to make it “legit.”
Date: Sat, 21 Sep 1996 16:44:21 -0700
Subject: XJ40: Factory Alarm
Hi all,
I’ve been reading all this talk lately about the “Majestic”,
gorgeous car by the way! And I was particularly interested about the
Factory remote entry/alarm system the car was equipped with in 1990.
My 1989 Vanden Plas has the Little “white eye” by the rear view
mirror, the manual says there’s a remote to unlock the doors (not roll
up windows) that goes with the “infra-red eye”. I went to buy a
remote, I discovered someone had removed the “eye” when they installed
a cheap after-market alarm (the remote is also missing for that!).
Also, $250 to replace the facory remote unlock system w/no alarm
system!
Question: Can a factory alarm from the dealer be installed in the
car, maybe a newer “eye” from a '90 and up model? I assume '90 had an
alarm with the remote unlock system. I’m also not sure about the “2
pushes” to pop open the trunk mentioned in the “Majestic spec” string,
I thought that was reserved for the X300 model.
Thanks for any insight, or reply of how your Fac. alarm works!
“Still hunting for Square Headlights!”
cobac@ix.netcom.com
Date: Sat, 21 Sep 1996 20:58:30 -0500
Subject: New to list → Introducing …
Hello all!
I’m new to the list but not to Jaguars. I’m on my second XJ-6. After owning
a '69 Spitfire, a '79 Midget and a '74 TR-6, I faced having to buy a family
car upon the happy occasion of the birth of my daughter. I bought the first
after my father-in-law suggested buying a '78 XJ-12 that he had sold to
someone else years ago who was now ready to sell it. We couldn’t agree on a
reasonable price. But after talking to some Jag owners and mechanics I
learned that the 12 engine was horribly expensive to replace. Anyway, I’d
been bitten. I found a black 87 Vanden Plas. Loved the car. Eventually had
to replace the steering rack and added the urethane bushings. Later had to
get new transmission. Then the rust started. My mechanic, who works out of
his house on just jaguars, gave me an estimate to get the car back in tip
top shape — about six grand. Ouch! I told him it would have to be time to
go back to a normal boring car. Then he remembered a little old lady who
wanted to sell hers. What a beauty! She lived in a luxury condo so the car
was always garaged. Plus she also had a big Lincoln and she spent the
winters in Florida. The bottom line was that I bought the 1986 BRG with
biscuit interior car three years ago and it only had 26,000 miles on it!
Everything worked … even the cruise control. Now it has 33,000 miles and
is going strong. The cruise control quit … but who cares.
Happy trails,
Jim Sherman
Prairie Village, Kansas USA
Date: Sat, 21 Sep 1996 20:59:19 -0500
Subject: Re: Need Good Book
Try Jaguar the Complete Illustrated History. It is written by Phillip
Porter and published by Haynes. ISBN 0-85429-750-2. Library of Congress No.
89-85898. It is a great looking “coffee table” type book with the leaper on
the front. Good history of jaguar from the swallow side cars through the
XJ-40. And, I believe newer editions cover the new Ford era. Enjoy!
Date: Sat, 21 Sep 1996 22:48:17 -0400
Subject: Jag XJ6 Series III
Bob,
I shared your lust for a Jag sedan. The series III is the last great Jag and I just had to have one. An opportunity arose about 5 years ago to get one, I needed a car and strangely enough, at the time I could afford it. I paid a wholesaler “friend” $5500 for an 84 four door that had a stackof reciepts from the previous owner. One of these was for a recent engine rebuild for $5000! He had also had a rear hub replaced, and a what I thought was a really great paint job in black with clear coat. The interior was pretty ragged andthe headliner was sad, but love is blind … A short test drive and Iwas hooked.
I do all the work on this car myself. If I didn’t, I’d be in the poor house. Here’s a list of the events which have transpired in my relationship with this monster:
Rebuilt the front end. Upper and lower ball joints, and outer tie rod ends. I noticed that the steering rack was leaking, but hey, who has time?
Differential drive flange seals bad and leaking gear lube on rear brake disks. A brave home mechanic can do this himself, but to do it right, you really need to pull the whole rear suspension subassembly. While I had it apart, I found that some clown had really bollixed up the emergency brake calipers, so I replaced them.
As I worked on this car, it became apparent that something was really strange about the car in general. After some research, I found that what I had was a gray-market car, that is, one that someone had imported from Europe and, to some degree, made to meet that DOT and EPA specs at that time. The big hints were the fact that it had 7 inch outer headlamps and what are called OGLE wheels. All this just made the car more charming.
After a while, the transmission started getting kind of strange. 200 miles from home, it kind of lost track of second gear. Fortunately, it would finally go into third, so we were able to limp home, but some time later, it finally locked up in a parking lot and would not roll forward or backward. I had it towed home on a roll back. My research prior to buying the car had warned me that the Borg Warner tranny was the biggest failing of the car and it never had been a real performer even when it was working right. I got various estimates, all around $1500, for rebuilding the BW, but I had read in Hemmings Motor News about a kit which would allow you to install a GM turbo 350 in its place. I’m a fool for weird projects, so I ordered the Quarterbreed kit from John’s Cars in Texas to the tune of about $800. I also got a rebuilt T350 tranny from a local shop for $350. Bottom line: nicely built kit, mediocre instructions, but the whole thing worked! Truned out the tranny I got was a 5 on a scale of 10. First gear whines, and I think the torque converter is making a clunking noise, but this thing kicks butt! Shifts are very positive and you feel like you have a much more direct connection between the engine and the back wheels. Total cost with all of the ancillary parts, about the same $1500 I would have spent on the BW, but if the tranny goes bad in the middle of nowhere, I can get a replacement dirt cheap. No points for originality, but plenty for practicality. Downside is that you lose the massive rear trans mount and the smoothness it imparts; the GM mount is a block of rubber.
Had a local upholsterer redo the seats in leather for about $1500 and I re-did the headliner. Putting the new material on the inside of the sunroof was MAJOR. I still have nightmares about holding the sunroof assembly in place with my feet while I struggled to put the attaching hardware in place. Yeah, it looked as silly as it sounds. The headliner shell is very difficult to remove when the windshield or back light is in place, but it can be done.
Turned out whoever replaced the rear hub felt some of the spacers were unimportant and left them out, so the rear wheel was kind of wallowing around. The Jag rear suspension is very sophisticated and precise, but only if properly assembled.
Warped rear rotor. You have to safety wire the caliper mounting bolts. It’s very hard to do, but they just won’t stay in otherwise.
Bad outboard u-joint. Pretty easy to fix, but I have a hydraulic press I bought some time ago. Good investment.
Rebuilt alternator. Happens to all cars.
All this time, I’m fighting handling problems. The car wants very expensive V-rated tires, but I settle for H-rated. I’m lucky if I ever get to do 65.
When I find myself putting fluid in the power steering once a week, I decide it’s time to replace the rack. Prices vary wildly for rebuilt units and core charges are way out there, but my local supplier had one for $250. Not hard to install and the difference in the steering is amazing! Light, precise, delicate; this is what Jags are all about… but… the pinion seal leaks. This is what Jags are all about. Went back and got another unit under warranty - binds turning to the right. Binds bad! Breathe deeply. Relax. You are the proud owner of one of the world’s finest motorcars. Still unresolved.
Oil supply tube to cams breaks. Nicely coated underside of entire car with synthetic oil.
Best of all - fuel return valve went bad. Scavenged fuel was being returned to wrong fuel tank (the full one). It would overflow into the emission control system and force raw gas into the carbon canister and onto the hot exhaust pipes. We’re having fun now!
Power aerial motor burned out. I rewound the motor field coil and put it back in action, but about two months later the plastic cable that raises and lowers the antenna broke. These are cruel cars.
Sunroof drive motor fell apart. I mean the screws came out and it fell apart!. I put it back together.
Most of the time, the power door locks work, but not always. My wife thinks it’s based on the weather.
Windshield leaks. Drips on your foot. Soaks the wool carpeting and the foam under it. Inside of the car fogs up. Floorboards rust out. Did I mention it drips on your foot? Actually goes in your shoe!
At some point during this saga, I decided it would be interesting to contact the previous owner and get his perspective on the car. When I told him why I was calling, there was a long silence. He finally said he was hoping he would never hear from the car again. He said he had been assured by the dealer who bought it that the car was leaving the country for good. He said he was still paying off bills he had built up maintaining the car, and I had had the car for about three years at this point!
This thing is a heartbreaker, but it’s also one of the most beautiful cars ever made. I love it.
Mark Anderton
72 TR6
66 Morris Minor
67 Daimler V8 250
84 XJ6
Date: Sat, 21 Sep 1996 23:35:16 -0400
To change the subject just slightly, I have been enjoying this thread,
however I no longer live in a winter climate (i now live in florida). I do
however let one of my cars sit for long periods of time (the opposite of you
guys. My porsche is a convertable and in the summer it is to hot and sunny to
drive, so it sits for the most part. it also rains a lot due to the
humidity). anyway, what advice would you have for a car that is going to sit
say 2 - 6 weeks (average of maybe 3 weeks). I have a cigarette lighter
trickle charger. what other advice if any. thanks - Doug
Date: Sat, 21 Sep 1996 22:11:49 -0700
Mike,
I also have this annoying problem on my 1989 XJ40 VDP! I did a
recent brake job on a wheels. I used ALL Genuine dealer parts, brake
pads AND all 4 rotors, and despite what others have said the factory
pads also create lots of brake dust (and they also squeak once in a
while!).
To assist in cleaning the wheels, I had all four “teardrop” style
wheels repainted in the original silver, then EVERYTIME I clean/wax the
car I also apply a quality car wax to the fresh painted wheels. Now
the dust just glides off very easily, when the car is washed (rarely do
they need scrubbing).
Oh, by the way, the car is black and in my case the car gets
dirtier then the wheels now! So, now I can go about a week before both
the car and wheels need to be cleaned, providing the weather is good.
And the wheels still maintain a light shine when they are dirty.
Later,
cobac@ix.netcom.com
Date: Sun, 22 Sep 1996 00:28:33 -0800
Subject: 1997 Jaguar line
I just got a brochure for the 1997 Jaguar line in the mail today. It
appears they now have 6 models for the US market:
XK8 Conv., XK8 Coupe, XJ6, XJ6 L, Vanden Plas, and XJR.
There was also a note tucked into the brochure saying the local dealer will
have their official unveiling of the XK8 on Oct 3.
Date: Thu, 19 Sep 1996 14:01:01 GMT
Subject: Re: Cooling system service questions
In message 9609181642.AA26714@cad655.sc.intel.com rpeng@cadev6.intel.com writes:
I would like to change the coolant in my car (`91 XJ40),
and I need some advice.
- The owner’s manual says when refilling the coolant, put in
some Barr’s Leak. Do you Jaguar Techs always do that? Is it
strictly necessary?
IMHO it’s not only unnecessary but actually detrimental. There was a
discussion about this on the list a while back. Have a look in the
archives for “V12 cooling system”
Stefan Schulz
jaguar@suaviter.demon.co.uk
'88 XJ-S V12 without Barr’s Leaks
Date: Thu, 19 Sep 1996 13:51:26 GMT
Subject: Re: XJS Problem
In message 32402818.2C8D@ieway.com Jana writes:
I have an 87 XJS V12. Iv’e only had it a year but already I have had to
put in a new water pump, fuel pump, transmission transducer, master
cylinder, and starter.
Par for the course. Next are diff, brakes all round, steering rack,
cooling fan, a few rust repairs, shocks, you get the idea.
Now being the first Summer I’ve had to drive it
I’ve noticed that in weather above 80 degrees the tempature gauge rises
slightly above normal after only a few minutes of city driving but will
drop a bit after I get back on the freeway. This is my first Jaguar so
Idon’t know what is normal or not
Slightly above normal in stop and go traffic on a hot day with the air
condition on full blast, yes. Otherwise something needs fixing.
Check:
fan belt condition and tension
cooling fan clutch
operation of electric fan
radiator and a/c condenser for blockage by dirt and suicidal bugs
correct antifreeze mixture strength
fuel/air ratio
radiator and engine block for flow restriction
The only one of the above items that didn’t need fixing on mine was the
cooling fan clutch.
Stefan Schulz
'88 XJ-S V12
End of jag-lovers-digest V2 #371
id for jag-lovers-digest-out; Mon, 23 Sep 1996 06:37:57 +0200 (MET DST)
Date: Mon, 23 Sep 1996 06:37:57 +0200 (MET DST)
Message-Id: 199609230437.GAA05787@ekeberg.sn.no
Subject: jag-lovers-digest V2 #372
Precedence: bulk
jag-lovers-digest Monday, 23 September 1996 Volume 02 : Number 372
RE:[SIIIXJ6] Sovereign equipment
XJ12 - oil leak questions.
ad for 1977 XJ-6 engine & tranny
Re: [SIII XJ6] Sovereign equipment
XJ models (was: [SIIIXJ6] Sovereign equipment)
Lumenition on my MK1 update
Re[2]: Cooling system service questions
[none]
[none]
4.2 XK Top Timing Chain Tensioning
Re: ad for 1977 XJ-6 engine & tranny
Re: 1980 XJ6 Exhaust
Re:
Date: Sun, 22 Sep 96 11:01:00 GMT
Subject: RE:[SIIIXJ6] Sovereign equipment
I found an extract from a web page at
http://home.sn.no/home/nick/jaguar.html, Model Guides, which briefly details
the Series III changes to the XJ6. This shows the standard as applied to
the sovereign.
Series III XJ6: (1979-1986) XJ12: (1981-93)
XJ6 : Pininfarina subtly redesigns body.
- 3.4L and 4.2L straight 6 engines, 4.2 is fuel-injected, 3.4 with
carbs…
202bhp @ 5000rpm; 227ft/lb @ 1000rpm
0-60 in 10.0sec, 127mph max, 16.8mpg
- 112.8in wheelbase, 3978 lbs unladen.
- Bars on grill are vertical,
- Door handles are flush with the body,
- Tail lights are bigger.
- Roof is raised slightly
- Alloy wheels of various designs
- Big black bumpers
- Sovereign: add alloy wheels, trip computer, AC,
electric mirrors, carpeted boot, rear head rests.
- The dash/console was updated in '83. Less plastic, more
wood. Controls are silver on black instead of black
on silver. Trip computer added. This interior is
much nicer than the previous one.
Barrie Dawson
1985 Series III Sovereign
Date: 22 Sep 96 11:29:03 EDT
Subject: XJ12 - oil leak questions.
I had the Xj12 on the lift yesterday at the DIY garage, checking out
some rocking at the right rear wheel. This apparently in the inboard
bearing in the final drive, lots of oil around the area too . I realise
the diff needs overhaul at 153.000 km only
However the oil does not only leak from the diff. The engine leaks
around the oil pan, which I guess is a small uncomplicated job to fix
with a new gasket and hylosil.
The engine however has a major oil leak up front on the right (alternator
side). I cant see where exactly it comes from, however it is not from the
cam cover, not from the cylinder head gasket , so I guess it is the
chain cover ? anything here which is prone to leak ?
If I need to exchange the timing cover gasket, well lets check the book…
ArgHHHH… engine out, remove cylinder heads…
I’m paralysed by the thought - dont know whether to laugh
silly or cry hysterically or see a shrink…
Why - WHY did I ever sell my Fiat 500R -
engine out is a 30 minute job with two men and no engine hoist…
Checking with the Jaguar V12 book of Kirby mercy fall onto my
Jaguar battered checque book…
Anything In this area I should do while I’m there ? New chain
tensioners as a matter of course ?
When looking from beneath a small amount of oil seems to leak from the
headgasket on each side. It’s not really “wet” of oil, rather a dryed out
looking “stuff”, baked oil maybe ?. Is this perfectly normal ? Should it
be fixed ? (Arrg…
Amazing that jaguar can fit a V12 in less than a minute. Ain’t no room left…
I took the Torque converter cover off to check if the rear main bearing is
leaking.
Apparently not !! dry - completely dry in there. Is there something wrong :-).
Regards Jeff
The
Date: Fri, 20 Sep 1996 11:29:59 -0700
Subject: ad for 1977 XJ-6 engine & tranny
Just saw an ad in the local paper for a 1977 XJ-6 engine and tranny. I
thought I would post the information in case anyone out there is looking for
something like this (I have no personal connection to this ad and have no
idea who the owner is!!!). The ad reads: “complete motor and transmission,
can hear run, $900. Call (602) 939-4467 or 937-1182”
Also while on the subject of ads, has the group ever thought about setting
up a “parts exchange/available” type of section? I think that it would be
useful for many of us. Any comments/feelings on this?
Rob W-M
85 XJ-S
Date: Sun, 22 Sep 1996 13:02:42 8
Subject: Re: [SIII XJ6] Sovereign equipment
if the Sovereign designation meant different things in different
markets?
Without a doubt…
My '86 XJ6 SIII (not Sovereign or Vanden Plas) was sold new in the
USA.
It includes the pepper pots wheels, sunroof & the climate control
system, computer & cruise control. On the rear of the car it says
“Jaguar” on the left and (my wife swears) XJ6 on the right (I’d
look, but the car is in Jaguar hospital get by-pass surgury). The
interior is very nice with veneer and leather, but it feels like the
leather is only on the seat cushion tops and front facing upper seat
backs There are only front seat headrests (which don’t feel like
leather), and no reading lamps on the C pillars.
It’d be interesting to hear from more of us owners and the various
levels of luxury associated with the model/name/year in the country
your car was sold.
Peter Morris
Date: Sun, 22 Sep 1996 17:39:02 -0500
Subject: XJ models (was: [SIIIXJ6] Sovereign equipment)
We all need to be careful when describing the features and specifications
of our beloved Jags. The models are quite varied from country to country.
While there are the expected differences to meet various safety and
emissions standards, there are even greater differences for what appear to
be pure marketing reasons. For example, the XJ-S was V-12 only in the U.S.
until very, very late in its life. The VDP specs for the various
generations of XJ-6/12s are tremendously different between markets and
years. Of course the Brits have Daimlers, which have never existed here in
the U.S. (except as “true” Daimlers prior to the takeover or as “gray
market” cars imported from their real marketplace.) I surmise from the
pictures I’ve seen of Daimlers that the fluted grill used here on VDP
models is really the UK Daimler grill.
As far as I know the Sovereign didn’t exist here in the U.S. until the
introduction of the Lexus and Infinity. The standard XJ in the U.S.
appears to have been roughly equal to the UK Sovereign, while the only step
up here was the VDP. The Sovereign name was applied to what was the
standard XJ here, and a new decontented (market-speak for stripped) XJ was
introduced as the basic XJ to establish a lower entry price to compete with
the new Japanese luxury cars. The “new” XJ lacked a sunroof and some other
options. I gather that the new one was more equivalent to the standard UK
XJ-6. The Sovereign name disappeared again (with the coming of the XJ-40?)
here in the US.
It would be interesting to try and come up with a table that shows the
differences from country to country.
The only brochure I have handy here is for a 1993 XJ-40, but I offer the
following as a start. If you can contribute for any year XJ, I’ll be happy
to try and add it to something that can be used in the XJ-6 book or on the
web site. All the descriptions come straight from the brochure, so these
are Jag’s words (at least Jag North America’s) and not mine, except items
in parentheses where I used a description commonly used on the list. (e.g.
AJ-6 instead of “Aluminum alloy, in-line 6-cylinder with double overhead
camshafts and four valves per cylinder.”) Options listed at the end are
the only ones in the brochure. Many other dealer installed options are in
the Jaguar Accessories catalog. Feel free to add any feature that varies
by market.
Specifications
1993 XJ-6 (project XJ-40)
Feature U.S Models
Engine (AJ-6)
Displacement 4.0 L
Horsepower 223 @ 4,750 rpm (DIN)
Torque 278lb-ft @ 3,650 rpm
Transmission ZF 4HP-24E four-speed/
overdrive automatic
Final Drive 3.58
Brakes ABS
Wheels
XJ-6 Radial style alloy
VDP Roulette style alloy
Tires P4000 225/65ZR15
Sunroof
XJ-6 Optional
VDP Standard
Headlights (square) halogen
Mirrors Outside dual heated w/
power adjust
Grill/Plinth
XJ-6 (smooth)
VDP Fluted (Daimler style)
Interior Trim
XJ-6 Burl walnut fascia, door
inserts and console. (ski
slope)
VDP Burl walnut fascia, door
slope) Leather handbrake
grip, console, sun visors,
armrests, and map pockets.
Walnut rear picnic tables.
Retractable rear shades.
(front console extends to
rear seat)
Seats
XJ-6 Leather faced. (fully fluted)
VDP Full leather, five flute
inserts w/ contrasting
piping.
Seats, Front
XJ-6 12-way power adjust, power
head rest and lumbar.
VDP 12-way power w/ 2 position
memory, power headrest and
lumbar.
Seats, Rear
XJ-6 (Bench) w/ center armrest.
VDP Leather covered, contoured
(bucket) w/ large center
armrest/storage compartment.
Rear reading lights
XJ-6 (Two, back of front seats
VDP (Four, two on back of front
seats and two on C-pillar)
Steering Wheel Leather, 6-way tilt
Air bags (Driver and front passenger)
Locks (Electric with RF remote entry,
panic button on console raises
windows, locks doors and trunk.)
Floor mats
XJ-6 (dealer mats, carpet type)
VDP Sheepskin footwell rugs
Options:
All Electrically heated windshield.
Front seat heaters.
CD changer (dealer installed,
trunk mounted)
VDP only Bumper mounted headlamp washers.
Date: Sun, 22 Sep 1996 23:51:26 +0200
Subject: Lumenition on my MK1 update
Thanks for responding to my question (several did…). But the solution is
not as easy as to order a kit. There is no kit for the distributor in the
MK1 3.4 (or early MK2).
This even though Lumenition used half a page in Jaguar World (page 52
sep/oct) to place an add picturing an E-type and a MK1…
Well the question is:
Can I get hold of a MK2 3.4 (later) distributor and just replace the one I
have? Will vacuum advance and so on be correct?
Would be nice to have the original ready to go with points right of the
shelf to, just for back-up.
1.5 -59 Mk1 3.4
J�rgen Scheel
Sandvika - Norway
Date: Sun, 22 Sep 1996 17:48:50 -0500
Subject: Re[2]: Cooling system service questions
I’m with Stefan. I’ve never used any kind of leak preventer in my '74
E-Type or my '88 XJ-S. Neither has shown any tendency to overheat, even in
heavy summer traffic, temperature as high as 100F and the A/C on. (Except
when the @#$%! Bosch fan relay on my E died. Even then the car didn’t
overheat, but only because I caught the needle starting to rise and
instantly switched from A/C to full heat. I count that one against the
electrical system and not the cooling system.)
MikeC
Author: jaguar@suaviter.demon.co.uk at Internet
Date: 9/19/1996 2:01 PM
Stefan Schulz
Date: Mon, 23 Sep 96 20:27 CST
Subject: [none]
Subject: Was Re: [XK Engines] Piston Scuffing
[Michael P. Neal ASE Master Technician, Jaguar Certified] wrote…
Michael, what do you mean ‘looks like the cut between’…the inclusion
of the extra water passage between the bores DOES reduce the sealing area
and is why series III engines blow head gaskets every 80,000 km / 60,000
mi. The solution is to use flanged cylinder liners which overlap into
the water passage to some extent reclaiming some of that valuable
real estate (sp?). I was told the extra water gallery was A) To be
“me too” copying the design of the competition, B) Solve the tendency
for the cracks between bores. If you look at the history of pre and
post Series III XK engines, pre crack bores, post blow HG more often
than each other.
Regards Scott.
Scott Fisher [sfisher@sola.com.au] PH: +61 08 329-28341.
_--_|\ N
SOLA / \ W + E
International Holdings Research Center _.–_/ S
Adelaide, South Australia. v
Joy ia a Jaguar XJ6 with a flat battery, a blown oil seal and an
unsympathetic wife, 9km outside of a small remote town, 3:15am on
a cold wet winters morning.
SOLA?- Opthalmic Lens Manufacturer, unless all those transparent disks
we make are part of some secret conspiracy to make transparent disks!
Date: 23 Sep 96 11:47:54
Having seen some of the contra arguments (to supporting a newsgroup) I think I
can suggest a way to have the cake and eat it, too. As some have said, a
newsgroup would be more interesting to those who aren’t really deeply
enamoured of Jaguars, and we should support one - but the link back to
jag-lovers might swamp us in excrement.
Since it does take a certain amount of bucks to keep the list going, and the
load should be evenly distributed, why not set the system up such that anyone
can read Jag-lovers but posting privileges come only if you pay, say, $20 a
year. That would raise enough funds to provide glorious amounts of server space
(and leave enough over for the occasional bottle of selected beverage to
reward Nick for his toil) while discouraging the worst lightweights.
There ain’t no such thing as a free lunch, even on the Internet.
- Jan
Date: Mon, 23 Sep 96 20:33 CST
Subject: [none]
Gunnar writes…
deleted…
Gunnar
In Australia Series III Sovereigns got…
Pepper-pot wheels
Cruse control
Leather
Rear seat Head-rests
Air-Con (climate control)
Jaguar XJ6 Sovereign 4.2 Badges
Sun Roof
A bit more wood trim here and there line on the doors etc
The Standard XJ6 got
Steel wheels with covers
Leather
Jaguar XJ6 4.2 badges
Regards Scott.
_--_|\ N
SOLA / \ W + E
From: “Rennick, Kim (AS01)” KRennick@p03.as01.honeywell.com.au
Date: Mon, 23 Sep 96 09:22:00 EST
Subject: Arggg!! Brake Dust on my XJ40!!
especially if it’s driven, ummm, spiritedly, it doesn’t take much.Look under the nose of a XJ40. Those two big (3x4 inch) holes lead in to
at your own risk.
I second Randy’s comments! The other side effect of blocking the air flow
to the brakes is the greatly increased risk of warping the disks. Combine
that with the increased wear on both the pads and the rotors (since the
whole system is running at too high a temperature). Not to mention the
decreased braking performance…
I think I will stick to individual cleaning of the 20 holes per wheel every
weekend - I even make a point of cleaning out the ‘nicely sculpted ducts’
that Randy refers to! It beats repainting the bathroom, after all.
Kim Rennick
| XJ40 3.6L Sovereign -
| Citroen BX 19 GTI -
| …(English and French rapprochement in my garage!)
|__________________________________________________
Date: Mon, 23 Sep 1996 13:19:49 +1000 (EST)
XJ40 brake discs (rotors) wear very much faster than those on the S3. This
also becomes worse when owners, thinking to save on pad replacement, fit
harder pads. Since the pads cost a hell of a lot less than discs, I would
be very wary about replacing the pads with harder ones, just to reduce the
dust. I find that cleaning of wheels, etc is very easy with a high pressure
washer, which is not a very expensive item and is also great for cleaning up
parts, etc. Alan
Date: Sun, 22 Sep 1996 13:56:48 -0400
Subject: 4.2 XK Top Timing Chain Tensioning
Hello,
I’ve a 67 4.2 engine which has not been rebuilt, and which I do not
particularly want to rebuild just at present, and I thought that a pleasant
1/2 hour Sunday job would see the top timing chain tensioned correctly.
1: The spring loaded plunger has been depressed and will not return. (It
wouldn’t depress easily to start with, so I thought (in true
Carpenter-bodge-job style) that a wallop with a hammer might just loosen
things up. It is stuck.)
What do I do, chaps? If I try to ‘grip’ it out (bodge!), is the probability
that it or the spring will go down the engine greater than or equal to
0.95?
2: Just supposing we get the above sorted (Hmmm), the actual tensioner is
very stiff. If I just wind it round with grips (Joy! another bodge) until
it stops, what is the probability that I have overtightened it?
3: In my buggering around I removed the locknut and then serrated washer:
The washer disintegrated and perhaps (I didn’t see - it all happened so
fast, officer) a quarter of it went inside. Is this likely to be a problem,
or will it just get stuck in my blackmange of sludge?!
Oh - it all looked so easy in the book.
Regards
Peter Carpenter
1967 420
UK
Date: 23 Sep 96 15:18:14
Scott Keating : Steering fluid is leaking out of the steering rack. Do
I need a new rack
or can I just replace the bushings? What are the best bushings to use? How
long will it take?
Assuming that the leaks are not in the plumbing, you need to replace the seals
in the rack; a kit is available. The job is not difficult if you understand
seals; one of them has to be passed over the teeth on the steering rack and
it’s very easy to damage it. These seals don’t last long at the best of
times; I’ve overhauled two racks, and both started leaking slightly after about
a year. Maybe others are made of sterner stuff, but I simply accept a certain
amount of leakage - I think of it as the Big Cat marking its territory… As
long as I don’t need to top up the PS pump between 10,000 km services I’ll
refrain from doing another overhaul. As a matter of fact, the leakage on the
coupe is so small that although it’s noticeable, I expect to go 30,000 km be
tween top-ups.
Taking the rack out for overhauling is a lot easier on the 6 than on the 12 due
to better access, but it still requires a certain amount of juggling when it
goes back in. The standard Jaguar bushings require a U-shaped multi-thickness
shim affair at the pinion end, which is an utter bitch to line up - at least on
the 12. If you use the orange after-market mounts - which I strongly recommend,
as they sharpen the steering without adding roughness - no shims are needed and
you can turf the silly thing out.
As for the fuel tanks, I agree with the answers posted.
- -Jan
Date: Mon, 23 Sep 1996 00:18:52 -0400
Subject: Re: ad for 1977 XJ-6 engine & tranny
In response to this post, I also have a '77 XJ-6 4.2L and automatic trans,
which is still in the car that is for sale.
I would like to get $500.00US for it, anyone please respond via e-mail
P.S. hte engine is complete with the carbs, intake manifold, exh. man., all
brackets, air and a/c pumps,etc…
Date: 23 Sep 96 15:22:37
Subject: Re: 1980 XJ6 Exhaust
The brackets definitely point to the outside, Tommy; there is no space for
pipes between the subframe and the outside of the hangers. I don’t want to be
silly, but have you tried swapping the pipes over? If you do, and they don’t
fit, you’re entitled to your money back…
- -Jan
Date: Sun, 22 Sep 1996 21:34:40 -0700
Subject: Re:
Scott,
The cut between cylinder bores is really an afterthought. Take a
close look at them and you’ll see that it looks to be hand cut. The
cuts are not uniform and are very crude. It leaves very little material
for the liner to be supported in. Personally I would risk a crack in
few blocks rather than let all of them flex excesssively in this area.
In the last 3 or 4 years that I worked at independent shops I saw the
same cars alot. Most of them needed headgaskets on a regular basis.
Many of them also had erosion problems on the thin area of block surface
between the liner and the cut. For this reason I also required the
block to be surface on a rebuild. I didn’t see more than one or two of
the early cars that didn’t have the cuts though the blocks didn’t crack
between the cylinders. I think a series of holes drilled near the area
between the cylinders and not a cut would have been a better solution.
Subject: Was Re: [XK Engines] Piston Scuffing[Michael P. Neal ASE Master Technician, Jaguar Certified] wrote…
causes a loss of sealing area.Michael, what do you mean ‘looks like the cut between’…the inclusion
than each other.Regards Scott.
_--_|\
End of jag-lovers-digest V2 #372
id for jag-lovers-digest-out; Mon, 23 Sep 1996 15:32:16 +0200 (MET DST)
Date: Mon, 23 Sep 1996 15:32:16 +0200 (MET DST)
Message-Id: 199609231332.PAA29829@ekeberg.sn.no
Subject: jag-lovers-digest V2 #373
Precedence: bulk
jag-lovers-digest Monday, 23 September 1996 Volume 02 : Number 373
Re: V-12 stumbling
Re: Arggg!! Brake Dust on my XJ40!!
Re: rec.autos.makes.jaguar(no jag content)
Re: XJ12 - oil leak questions.
Re: Need Good Book
Re: XJ6 Radiator draining.
Re: Majestic Specifications
RE: Arggg!! Brake Dust on my XJ40!!
Solution: XJ6 bonnet opening.
Re: Jag: Mk2 electrics - heated rear window
Re: XJ-S Radio Code & boot lights
E-type windshield manufacturers ?
Re: Hot Shot freon
Date: 23 Sep 96 15:42:48
Subject: Re: V-12 stumbling
I feel for you, Peter, having just beaten a challenge by both my V12s - same
symptoms, intermittent as you please and, yes, striking at the most
inconvenient moments (I hate rolling to a stop just after overtaking a
hoonmobile full of tattooed beer bellies…). Turned out to be a batch of
various bad contacts in the ignition on and around the ballast resistor and
ignition coil, mainly caused by age-slackened and dirty Lucas connectors.
However, after laboriously finding and curing one at a time, it turned out that
both suffered from the same main fault: fatigue break in one of the three
wires to the amplifier where they pass out of the distributor.
It turns out - my conclusion - that when Lucas shifted the amplifier to above
the radiator, they didn’t alter the wiring to the sensor in the distributor but
instead left the big, heavy three-pin Lucar connector dangling back and forth
from long, loose wires - eventually causing the fatigue break. Since you’ve
just modified this connection, I suggest that you tie the wires down to prevent
the same thing happening in a couple of years.
I can’t advance any guess about the cause of your present trouble, unless it’s
something to do with a fault in the instrument voltage regulator (a simple
zener diode, I think). The reason for mentioning that is that your temperature
gauge reading seems extremely high; both my 12s indicate between the “n” and
“o” in “normal” when their 90-deg C thermostats open and rarely go past the
“o”. Past the “l” is very close to boiling even with the system pressurised
(around 115 deg C by my guess), yet you don’t mention overheating, so I’d
assume that the gauge reads too high.
You mention ticking from the fuel pump; I assume this means you have a
carburetted model, as the injection pump whines rather than ticking.
- -Jan
1977 XJ5.3C
1978 XJ5.3L
Date: Sun, 22 Sep 1996 21:43:24 -0700
Subject: Re: Arggg!! Brake Dust on my XJ40!!
Jaguar seems to think that KleenWheels don’t cause a problem. All of
the '93 and '94s that I have been certifying as Select Editions seem to
have them. I’m not sure if they came from the factory like that but
every one of them I’ve seen has them. If they did cause a problem you
can be sure Jaguar would restrict their use.
Rennick, Kim (AS01) wrote:
Michael Powers would like to clean his wheels less often. I recently =
purchased KleenWheels for my XJ6 and they made a world of difference. =
The product is similar to a pie tin and fits inside the wheel between =
the rotor and the wheels face. My car has XJS lattice wheels that are a =The brake dust is transported to the wheels via the air flow. The air
at your own risk.I second Randy’s comments! The other side effect of blocking the air flow
decreased braking performance…I think I will stick to individual cleaning of the 20 holes per wheel every
that Randy refers to! It beats repainting the bathroom, after all.Kim Rennick
| Citroen BX 19 GTI -
Date: Sun, 22 Sep 1996 17:32:28 -0400
I have found that brake dust has increased as a problem after getting the
‘new’ non-asbestos pads. On a Ronge Raver, TVR, Peugeot and now the 420, it
seems that the discs are wearing away in tune with the pads. I used to
think that pads were consumable and the discs were for life - but the TVR
has used a pair of discs to a set of pads…
Do we drive faster and brake later, or is the dust is different these days?
Peter Carpenter
1967 420
UK
Date: Sun, 22 Sep 1996 22:54:32 +0700
Subject: Re: rec.autos.makes.jaguar(no jag content)
Jan Wikstroem’s snippet:
I second Jan’s proposal. If we can afford Jags, then 20 bucks or so
per year won’t kill us. This may make Nick’s life more bearable, not to
mention our own, if it serves to limit our incoming email to
only those messages pertaining to our Jags (not that all of our
discussions pertain strictly to Jags )
I value the people and resources on this list, and I wouldn’t like to
see this list chummed up by spammers and marketeers intent on quick
fortune or disruption vis-a-vis the USENET groups.
Nick, do you take Visa?
Greg Price
'85 VdP
Date: 23 Sep 96 16:01:01
Subject: Re: XJ12 - oil leak questions.
A certain amount of oil seepage can’t be escaped, but there shouldn’t be actual
dribbles. Let’s hope your timing chain cover merely has a couple of loose
screws that you can tighten up…
Even if it’s more serious than that, you do not need to take engine out, nor
lift the cylinder heads. If you remove the bonnet, take out the radiator and
remove all the ancillaries from the front of the engine, you can remove the
timing chain cover after loosening the sump plate and lowering it a couple of
mm. I haven’t done this myself, but was told of the procedure by a Jag
mechanic. You need to use silicon rather than conventional gaskets at top and
bottom when you put it back together, I was told.
If you do take the timing chain cover off, you should indeed replace the timing
chain tensioner. My impression from admittedly limited experience is that they
last something like 100,000 km (60,000 mi.)
- -Jan
Date: Sun, 22 Sep 1996 22:26:20 -0700
When reassembling the timing cover I’ve found that several sheets of
.003 thousandths shim stock do wonders to get everything back together
without damaging the head gaskets or sandwich plate gasket.
screws that you can tighten up…Even if it’s more serious than that, you do not need to take engine out, nor
bottom when you put it back together, I was told.If you do take the timing chain cover off, you should indeed replace the timing
last something like 100,000 km (60,000 mi.)-Jan
Date: Mon, 23 Sep 1996 05:26:06 GMT
Frank wrote “I’m sure this will spark a flood of E-mail, But I would like to buy a
book If I could write it I’d call it the complete book of Jaguars…”
A good overall book is “JAGUAR PERFORMANCE AND PRIDE” by Pete Lyons and the Auto
Editors of Consumer Guide. ISBN: 0-88176-983-5, Library of Congress card number
91-61371. It’s has some good basic information and pictures along with some
nice sideline stories. Does a good job of covering all the models.
Thats my 2 cents worth but believe me, you’ll never get by with just one book.
Craig Hastings
88 VDP
?? E-Type (Looking, anybody got one for sale???)
Date: Mon, 23 Sep 1996 03:51:01 -0005
Jan Wikstroem:
year.I second Jan’s proposal. If we can afford Jags, then 20 bucks or so
All in all, perhaps a workable plan. However, I would object to the
establishment of said fees BEFORE the creation of the Jaguar
newsgroup! There needs to be a free option.
| - Palm’s Postulate
Date: Mon, 23 Sep 1996 03:51:00 -0005
flow meant to cool the brakes. These things block that air flow. They
will cause premature brake overheating.I second Randy’s comments!
Hold your horses. Has anyone here actually had brake trouble due to
the installation of KleenWheels or whatever? Or are you all workin’
on theory?
Seems to me that blocking the airflow OUT through the wheels does NOT
block airflow through the vented disks – that airflow comes from the
inside at the ID of the disk, flows radially outward, and ends up
within the wheel itself. At this point it can go inward and out
under the car, or outward through the wheel. If there is a lot of
pressure under the car (front air dam missing?) maybe the first
option is poor, but otherwise it would seem that blocking the second
would not have a significant effect on brake cooling.
The various ducts provided on some cars usually provides an airflow
IN to the ID of the rotors, and is a separate issue from getting the
air OUT of the brakes.
| - Palm’s Postulate
Date: Mon, 23 Sep 1996 10:20:30 -0700
Subject: Re: XJ6 Radiator draining.
Steve Coleman:
Would someone tell me how to drain the radiator on this car (1987 XJ6)?
On my XJ Series I there is a valve on the lower right hand side, with an extended lever/handle operated from the top right hand side of the radiator. There is also a drain plug at the bottom of the radiator, which can be reached through a hole in the lower valance panel. Cheers! Bard ______ _ ! Baard Th Hesvik, Telesoft AS / _ / _ _ _ / / ! Longhammarvn 7, N-5500 Haugesund / // / // /_ / / -/- -/- ! T: +47 52735000 F: +47 52717040 / /_ / /_ / // / /_ ! E-mail: baard@telesoft.no From: “Alastair Lauener” a.lauener@napier.ac.uk Date: Mon, 23 Sep 96 09:56:26 gmt Subject: 4.2 XK Top Timing Chain Tensioning Peter Carpenter said I’ve a 67 4.2 engine which has not been rebuilt, and which I do not particularly want to rebuild just at present, and I thought that a pleasant 1/2 hour Sunday job would see the top timing chain tensioned correctly. 1: The spring loaded plunger has been depressed and will not return. (It wouldn’t depress easily to start with, so I thought (in true Carpenter-bodge-job style) that a wallop with a hammer might just loosen things up. It is stuck.) What do I do, chaps? If I try to ‘grip’ it out (bodge!), is the probability that it or the spring will go down the engine greater than or equal to 0.95? Peter, the spring loaded plunger often sticks. Amazing considering the amount of oil about in there. Pack the area with good cloths, so falling bits get caught. Usually WD40 / 3-in-one will free it, but you need to be able to manouvre it a little bit. Don’t start the engine unless the plunger is ‘out’ The cam timing could move if the serrated wheel moved. 2: Just supposing we get the above sorted (Hmmm), the actual tensioner is very stiff. If I just wind it round with grips (Joy! another bodge) until it stops, what is the probability that I have overtightened it? Yes, that would be too tight. The true and correct adjuster (I have one, from the JEC, 5-6 UK pounds) allows very litle torque on the adjuster, it should need none. There is an oil hole above the adjuster that oil is supposed to fall through. It gets clogged. Try and unclog, and again use thin oil, and move the adjuster back and forth. It should be easy to turn. 3: In my buggering around I removed the locknut and then serrated washer: The washer disintegrated and perhaps (I didn’t see - it all happened so fast, officer) a quarter of it went inside. Is this likely to be a problem, or will it just get stuck in my blackmange of sludge?! Don’t leave things with the nut off. Too much danger of the whole serrated wheel dropping down the engine. The quarter washer if you are lucky will stay behind the oil screen in the sump and come out if you drain the oil. Next stop fot it is the oil pump.! Put plenty of rags in round there reduces the chance of anything falling down. ************************************************************************ * Alastair Lauener * * 1964 3.4 S-Type http://www.sn.no/home/nick/alas.html * ************************************************************************ From: Donald McGregor Donald.McGregor@snl.co.uk Date: Mon, 23 Sep 1996 10:36:22 +0000 (GMT) Subject: Re: Majestic Specifications I have a card brochure on the UK XJ40 Majestic at home. I’ll try and remember to bring it in tomorrow and email you the spec. Donald.McGregor@snl.co.uk From: Graham Watson grahamw@microsoft.com Date: Mon, 23 Sep 1996 03:35:48 -0700 Subject: RE: Arggg!! Brake Dust on my XJ40!! … and what about my wheels, which are the standard old steel things, with plastic covers with only a few small holes in them. Jaguar don’t seem to have any problems with reducing the air flow through the wheels … Original Message----- From: Kirbert [SMTP:palmk@gcn.scri.fsu.edu] Sent: Monday, September 23, 1996 3:56 AM To: jag-lovers@sn.no Subject: Re: Arggg!! Brake Dust on my XJ40!! The brake dust is transported to the wheels via the air flow. The air flow meant to cool the brakes. These things block that air flow. They will cause premature brake overheating. I second Randy’s comments! Hold your horses. Has anyone here actually had brake trouble due to the installation of KleenWheels or whatever? Or are you all workin’ on theory? Seems to me that blocking the airflow OUT through the wheels does NOT block airflow through the vented disks – that airflow comes from the inside at the ID of the disk, flows radially outward, and ends up within the wheel itself. At this point it can go inward and out under the car, or outward through the wheel. If there is a lot of pressure under the car (front air dam missing?) maybe the first option is poor, but otherwise it would seem that blocking the second would not have a significant effect on brake cooling. The various ducts provided on some cars usually provides an airflow IN to the ID of the rotors, and is a separate issue from getting the air OUT of the brakes. Kirbert | If anything is to be accomplished, | some rules must be broken. | - Palm’s Postulate From: Cosmo simond@informix.com Date: Mon, 23 Sep 1996 12:58:12 +0100 Subject: Solution: XJ6 bonnet opening. Cosmo wrote:
The bonnet on my XJ6 SIII has started to open when on the move.
Thanx for all the suggestions for the bonnet closure problem. After
a few days of playing with them the final solution was the rubber
mallet. A few taps to knock the bottom of the pin further towards
the rear of the car and presto! All other attempts to close the
bonnet corectly, adjust the spring, adjust the cable, clean the
mechanism didn’t work.
Thanx again,
Cosmo
Date: Mon, 23 Sep 1996 13:04:22 +0100
Subject: Re: Jag: Mk2 electrics - heated rear window
I’ll check for you. I know heated rear windows were an option on MKIIs.
Ian
On Sep 13, 1996 10:31:05, ‘ejt@wg.icl.co.uk (Ted Trim)’ wrote:
Fellow Jag-lovers,
I need to share my astonishment with some sympathetic folk…
Setting the scene: I have recently been refitting the instrument panels
and
bulkhead wiring on my 1966 Mk2. This car, 170906, is a late Mk2 and
incorp-
orates a number of 340 type features, but the wiring doesn’t match either
Mk2 or 340 diagrams - and the heated rear window doesn’t feature on
either.
The window heater is operated by a push/pull switch at the right hand end
of
the dashboard (rhd car); there is a small warning light by the switch.
When
stripping the dash assembly I found a 6RA relay mounted at the lefthand
end
of the bulkhead panel. (There is only one other relay on the car, which
is
the horn relay in the engine bay fusebox assembly - neither relay is
fitted
in early Mk2s). I assumed this second “mystery” relay controlled the hrw.
Now, I’ve got used to return wires being smaller gauge than feed wires on
this
car (probably fits with the Lucas “smoke” theory!), but the sole purpose
of this relay appears to be to…control the hrw warning light, enabling
it
only when the lights are on. Honestly. A heavy duty relay and several
lengths
of wire for what seems an unnecessary purpose.So is this how it’s meant to work? I always thought the bulb was just too
dim to see in daylight! Can anyone see any sense in this? Any owners of
similar era Jags got any insight (or better wiring diagrams)?Cheers,
Ted
Date: Mon, 23 Sep 1996 08:39:17 -0400
Subject: Re: XJ-S Radio Code & boot lights
John Himes provided the answer. A 2 amp inline fuse under the left
side ashtray was the culprit, should anyone hit the same snag.
One more question. The boot lights do not come on. Does anyone
know where the hidden fuse (or other possible glitch) resides? I’ve
bypassed the lid switch, so I know it’s not that. Thanks.
Steve Draper
'88 XJ-S
Date: Mon, 23 Sep 1996 14:48:42 +0100
Subject: E-type windshield manufacturers ?
Hi group,
As work progresses on the bodywork of my 63-E coupe I am planning for
(expensive) things to come. I will probably need to replace the front
windshield as it has a rather deep scratch in it. I would like to replace
it with a tinted version (sundym ?). Also a heated tailgate window would
increase driving pleasure in our climate. My neighbour, who works in the
field of industrial glass coating, volunteerd to try and get a set with
some discount. Did any of you you Series 1 E-type owners recently (last
few years) fit a new tinted windshield ? . If so, it should have a stamp
on it with the manufacturers name. Please look and let me know who makes
them.
Thanks a lot, Eric
1963 E-type FHC (“Over 1200 pieces”), but now zinc-sprayed and in the
process of re-assembling again.
Eric F.P.M. Vuurman
staf psychiatrie
Academisch Ziekenhuis Maastricht
P Debeyelaan 25
6202 AZ Maastricht
tel +31 433 876147
Fax +31 433 881046
e-mail Eric.vuurman@spsy.azm.nl
Date: Mon, 23 Sep 1996 09:30:59 -0400
Subject: Re: Hot Shot freon
KENNETH M GILSON" <kgilson@ccmail.unl.edu wrote:
FWIW There is a new drop-in refrigerant on the market which is suppose
to increase the performance of your air conditioner by 5% if your car
had R-12 in it and about 15% if your car has R-134A in it. ICOR
International Inc. is the mfg. and Hotshot-A is the name of it
If possible, check the ingredients of this (and any “miracle freon”)- if one
of the major ingredients is Propane, then do a 180 and walk away quickly-
My A/C man warned me that there are some people marketing Propane as a
substitute for Freon. Works pretty good, but can be dangerous to an
unsuspecting technician later on.
Brian Sherwood
'85 XJ6, '84 XJ-S
End of jag-lovers-digest V2 #373
Return-Path: @owner-jag-lovers-di1
Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4)
id for jag-lovers-digest-out; Tue, 24 Sep 1996 00:16:00 +0200 (MET DST)
Date: Tue, 24 Sep 1996 00:16:00 +0200 (MET DST)
Message-Id: 199609232216.AAA04874@ekeberg.sn.no
X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f
To: jag-lovers-digest@sn.no
Subject: jag-lovers-digest V2 #374
Reply-To: jag-lovers@sn.no
Errors-To: @owner-jag-lovers-di1
Precedence: bulk
X-Newsgroups: mail.jag-lovers-digest
jag-lovers-digest Tuesday, 24 September 1996 Volume 02 : Number 374
RE: Completed: XJ40 audio upgrade
[General] Engine coolant heaters
Re: Lumenition on my MK1 update
87 XJ-S Starter Delay when hot
Jaguar XK8 Raffle in the U.S.
RE: V-12 stumbling
REFRIGERANT
Re: 87 XJ-S Starter Delay when hot
RE: Jaguar XK8 Raffle in the U.S.
Re: Jaguar XK8 Raffle in the U.S.
Re: Engine coolant heaters (Minor Jag content)
RE: Need Good Book (A picture is worth 1000 words)
From: Michael Powers/TEIR/Thomson Michael_Powers@teir.com
Date: 23 Sep 96 9:58:41
Subject: RE: Completed: XJ40 audio upgrade
After hearing from several parties on this issue, I decided to do it myself. I
figured I would use a little more care and diligence to ensure the job was done
right.
Anyway, it was pretty straightforward. The hardest part was snaking the cables
from the trunk up to
the CD unit under the dash. The back-seat unit had to be removed, and finding
a good place to run the wire
proved difficult. But luckily several small metal covers were riveted to the
were the back seat is mounted. I pried one off, and sure enough, a nice little
opening to get to the trunk!
Thanks for the help,
Mike
89 XJ6
grahamw @ microsoft.com (Graham Watson)
09/20/96 08:39 AM
To: Michael_Powers @ teir.com (“‘Michael Powers/TEIR/Thomson’”) @ Internet
cc:
Subject: RE: XJ40 audio upgrade
Spend the rest of your money, and get the right combo of radio and cd
player. If you have an XJ40, the Alpine CD unit may well fit straight
onto your head unit. If you’ve got the same setup as I have, the cable
even goes right into the boot (trunk ?) so you can just plug it in - ten
minutes work !
G
-----Original Message-----
From: Michael Powers/TEIR/Thomson [SMTP:Michael_Powers@teir.com]
Sent: Friday, September 20, 1996 10:58 AM
To: jag-lovers
Subject: XJ40 audio upgrade
Hello all:
This weekend, I plan on having a 10 CD changer installed in my 89 XJ6.
It is
the type that
installs in the trunk and then, through an RF modulation unit, connects
to the
antennae lead
on the radio.
Since my local audio shop (Best Buy) is having a free installation sale,
I
figured I’d have them do it.
Any warnings or caveats that I should take heed to before having this
done?
Thanks in advance,
Mike
| mpowers@teir.com
| (703) 736-1832
| On my block, a lot of people walk their dogs and I always see them
| walking along with their little poop bags. This, to me, is the lowest
| activity in human life. Following a dog with a little scooper.
Waiting
| for him to go so you can walk down the street with it in your bag.
| If aliens are watching this through telescopes, they’re going to
think
| the dogs are the leaders of the planet. If you see two life forms,
| one of them’s making a poop, the other one’s carrying it for him,
| who would you assume is in charge?
| -Jerry Seinfeld
Date: Mon, 23 Sep 1996 16:55:10 +0200 (MET DST)
Subject: [General] Engine coolant heaters
Folks,
I just checked with a local shop that sells a lot of these coolant
heaters. They say that the “normal” power of an engine block coolant
heater is 550W. They also claim that unless the volume of coolant in the
engine block is a lot more than 10-15 liters this should be sufficient.
The recommended procedure is to switch on the heater approx. two hours
before starting the car. If it gets very cold during the night (below
- -10 degrees C) it could be a good idea to run the heater for 15-30
minutes in the middle of the night as well. All this is of course
controlled with a timer that automatically switches the heater on and off
at the programmed intervals.
The mounting procedure is to remove one of the engine block’s core plugs
(on one side of the engine block) and install the heater element in the
hole. The whole thing is held in place by a special screw that expands on
the inside of the hole as the screw is tightened (like opening an
umbrella (only without the fabric!) You get the idea).
The most popular system around these parts is made by a company called
DEFA (Swedish?). Price:
(US $1 = Norwegian Krone (NOK) 6.5)
Basic system, 550W heater element for the engine block including the
necessary cables and stuff: NOK 995 incl. VAT (23%). -
800W oven for heating the inside of the car including the necessary
cables and stuff: NOK 1200 incl. VAT.
Gunnar
Gunnar Helliesen | Bergen IT Consult AS | NetBSD/VAX on a uVAX II
Systems Consultant | Bergen, Norway | '86 Jaguar XJ6 4.2 Sovereign
gunnar@bitcon.no | http://www.bitcon.no/ | Vicki who? What .sig virus?
From: brownd@filon.ml.com (Dave Brown - London Dev X1818)
Date: Mon, 23 Sep 96 09:42:22 BST
In answer to your question about classic insurance for SIII - Yes, you can but
only on a limited mileage policy. Try Footman James or Firebond. However, if
you’ve only just passed your test, it still could be prohibitively expensive!
Good Luck,
David Brown,
brownd@ml.com
///_/_/_/_/////_///______
/_/_//_/_/_/_/_/____
/_/_/_/_/______/_/_/_/______
/_/_/_/_/_/_/________/_/_____
___/_/_/////_/_/_/_/_/______
/_/___/_/_//_/_/_/____
///_/_/_/____/////_///_________
Date: Mon, 23 Sep 1996 11:23:19 -0400 (EDT)
Subject: Re: Lumenition on my MK1 update
If you wanted to go with a newer, better quality distributor, Mallory=20
maves a dual point(about USD200) and an electronic(about USD300) distributo=
r=20
for the XK. The advance curve is adjustable, so you should be able to fit=
=20
it to a mkI. I have the dual point, and I can find points for it at just=
=20
about any parts store. I don’t know what the situation would be like=20
where you are. If I was going to do it over, I’d convert to negative=20
ground and go for the electronic one. I had some problems with the points=
=20
burning up, but it turned out I just needed a bit larger ballast resistor,=
=20
and I have had no problems since. It is a very high quality unit. Let me=20
know if you want more info.=20
Braman Wing
1963 mkII
1966 Land Rover 88"=C5
Date: Mon, 23 Sep 1996 11:51:16 -0400 (EDT)
Subject: 87 XJ-S Starter Delay when hot
Every morning my V-12 roars to life without hesitation at the
twist of the key. I’ve noticed however, that when the engine
is warmed up (it runs below N) the starter doesn’t respond to
the ignition switch right away. If I hold the key in the start
position long enough it eventually kicks in. I would estimate
that the delay is around 10 seconds at the longest, and only
when the engine is warmed up. Any theories?
Thomas E. Alberts
1987 XJ-S
Date: Mon, 23 Sep 1996 12:13:23 -0400 (EDT)
Subject: Jaguar XK8 Raffle in the U.S.
I thought the group might be interested in this raffle, which is for a good
cause.
The Global Technology Exchange Foundation is raising funds by raffling off
a fully equipped 1997 Jaguar XK8 Coupe. Delivery will be provided by the
foundation within the continental U.S. and southern provinces of Canada.The
funds raised will be used to further the foundation’s mission of
distributing computers to teachers,
researchers, and educational institutions throughout the world.
6000 tickets total. $50.00 for a single ticket, two for $75.00.
Information for entering the raffle can be obtained from the foundation’s
web page at
http://www.ism.net/~globetech/foundation/raffle/rafflehome.html
Good luck.
From: “Connie Vloutely” connie_vloutely@macmail.git.gulfaero.com
Date: 23 Sep 1996 13:14:05 -0500
Subject: RE: V-12 stumbling
Hi Peter,
The only thing you can do is monitor fuel pressure and the ignition.
I once had a problem with my Austion Healey Sprite, 1968. Car needed new
points in the distrubutor, I replaced them. I broke one of my own rules. I
changed the condenser too. Took the car for a test hop. Car ran good a idle
but when I gave it some gas the engine would die.
I figured it was either fuel or ignition problem. So I took my timing lite
hooked it to the car and went for a ride. As soon as I pressed on the gas
pedal The timing lite stopped flashing. So I knew I had a ignition problem.
I turns out The condenser I put in was bad: spade lug was not crimped to wire
end… Moral of story if it ain’t bad don’t change it.
So Peter monitor ignition and/or fuel pressure…
good luck,
Connie V.
Subject: V-12 stumbling
About two years ago my V-12 E-type had a series of dying/fainting spells
…after running for 10-20 minutes the engine would begin to misfire, run
rough and refuse to rev above 1000 rpm. After much mucking about it turned
out the fuel pump was overheating and jamming … cured by a new fuel pump.
About 1 year ago I had a series of similar but less pronounced episode
where when hot it would briefly run rough for 10-15 seconds and then be
fine (this would occur at any RPM). After doing this for a couple of
months, one day it just cut out completely … diagnosis was cooked ignition
amplifier which was an original, bolted to the engine between the two heads
… cured by replacing the amplifier, and moving the new one (a Crane
XR-700 amplifier) to the bulkhead.
Yesterday while cruising along a busy highway at 3000 rpm I noticed that
the engine temperature was a little high (a little to the right of the “L”
in normal whereas it is usually at the “M” or “A”)…ambient air temp =
22oC, road surface temp perhaps = 28oC. Suddenly I had that horrible
feeling of running rough and loss of power again (ignition or fuel
starvation again?). Pulled off, checked sparkplug leads, vacuum hoses, fuel
pump => spark to all cylinders, no loose hoses, puel pump was clicking
normally. Took five minutes out to control those dark thoughts (the one’s
about wrecking yards and car eating metal crushers and the ultimate destiny
of cars which piss me off once too often), the climbed back in, turned the
ignition key, fired up great, temperature fell back to normal range and no
further problems for the next 2 hours in stop and go traffic with RPM
ranging from 1000 - 3500 rpm. Fickle beast!
These mystery fainting spells piss me off because they’re difficult to
describe, worse to find, and kill the joy of the machine because you figure
it’s going to leave you in the lurch in an embarrassing situtation (busiest
intersection in town) or worse a dangerous situation (power-out 30 feet in
front of a 16-wheel tractor trailer laden to the gunnels with steel ingots
and closing those 30 feet at 120 kph)
Any suggestions as to what to do to find it
Could it be the ignition coil (at least ten years old)?
Could it be the fuel pump dying again — when I replaced the fuel pump two
years ago, I was told that the twin pumps made by Lucas frequently fried
themselves, but there was no other available replacement and one had to put
up with it (is this true or are there other makes of more reliable pumps)?
Peter
- ------------------ RFC822 Header Follows ------------------
Received: by macmail.git.gulfaero.com with SMTP;21 Sep 1996 15:32:00 -0500
Received: from ekeberg.sn.no by gulfaero.com (AIX 3.2/UCB 5.64/4.03)
id AA17209; Sat, 21 Sep 1996 16:29:42 -0400
id for jag-lovers-out; Sat, 21 Sep 1996 20:57:37 +0200 (MET DST)
owner-jag-lovers using -f
Received: from bureau-de-poste.utcc.utoronto.ca
(bureau-de-poste.utcc.utoronto.ca [128.100.132.11]) by ekeberg.sn.no
(8.7.5/8.7.3/on4)
with SMTP id for jag-lovers@sn.no; Sat, 21 Sep 1996 20:57:28
+0200 (MET DST)
Received: from [128.100.204.251] ([128.100.204.251]) by
bureau-de-poste.utcc.utoronto.ca with SMTP id <803119(6)>; Sat, 21 Sep 1996
14:57:09 -0400
X-Sender: p.hyslop@mailbox12.utcc.utoronto.ca
Mime-Version: 1.0
Content-Type: text/plain; charset=“us-ascii”
Date: Sat, 21 Sep 1996 15:18:56 -0400
Message-Id: <96Sep21.145709edt.803119(6)@bureau-de-poste.utcc.utoronto.ca>
Sender: owner-jag-lovers@sn.no
Precedence: bulk
Date: Mon, 23 Sep 96 12:44:55 CST
Subject: REFRIGERANT
In one of my past postings I stated that a refrigerant is available that
is a “drop-in” for R-12. That statement is still correct and our piece
of equipment is functioning just fine. The trade name is “Hotshot” made
by ICOR International Inc. in Indianapolis, Indiana USA. In their MSDS
sheet the contents of the refrigerant is R-22, which will go out of
production in 2020, R-142b, R-124 and R-600a, the last item is
isobutane. The content of isobutane is 1.5% which when combined with the
other refrigerants makes “The material not flammable and does not
support combustion.” If R-12 is still available in the small containers
in your locale then I would be tempted to use it. One item, if any
system ruptures the mineral oil used to lubricate the compressor can
support combustion if there is an ignition source. I have no affiliation
with the mfg. I am only a “user” and we try to make sure all gases are
approved by the E.P.A. and are safe for the technicians.
Kenny Gilson '64 OTS
Date: Mon, 23 Sep 1996 14:01:50 -0400
Subject: Re: 87 XJ-S Starter Delay when hot
In a message dated 96-09-23 12:00:18 EDT, talberts@aero.odu.edu (Thomas
Alberts) writes:
<< Every morning my V-12 roars to life without hesitation at the
the ignition switch right away >>
Had the exact same problem w/ my '87 XJS too. Turned out to be a borderline
engine ground which evidently got worse when things heated up. You can check
for this by looking for a spark between engine block and chassis when running
(use jumper cables).
Similarly, the negative battery connection to the chassis can be the culprit.
I fixed the corrosion on mine with a wire brush on a drill, and lots of
torque on the nut wjhen re-tightened.
Of course, I could hear the relay and solenoid clicking, but the starter
itself wouldn’t turn.
Julian Mullaney
Date: 23 Sep 96 13:44:29 EDT
Subject: RE: Jaguar XK8 Raffle in the U.S.
Rick and list,
Does anybody know anything about this group? I am all for supporting
educational causes and I would love to own an XK8, but when I called
the 800 number I got an answering service who knew very little (almost
nothing) about the raffle or the foundation. When I asked for some
pertinent information such as the phone number for the foundation I was
told the gentlement setting up the raffle was from Missoula, the phone
number I was given (609-737-6375) ended up being an answering machine
in New Jersey. The message on the machine led me to believe I was
reaching an individual, not a philanthropic foundation.
I know many people who have been burned by raffles that are less than
they appear to be. I do not have a good feeling about this one and I
would urge all to investigate the foundation first and think twice
before entering a credit card number on the web order screen.
If you decide to enter the raffle I wish you the best of luck and if
you know this to be a legit cause please post what you know.
Robert Woodling
'84 XJ-S
Cc: Rick Batlan
Date: Monday, September 23, 1996 12:13PM
cause.
web page at
Good luck.
Date: Mon, 23 Sep 1996 16:02:02 -0400
Subject: Re: Jaguar XK8 Raffle in the U.S.
Just wondering which are the southern provinces (of Canada)?
Oh, yeah…Florida, I forgot!
Charles Daly, Toronto, Canada
'62 E-Type, ots
Date: Mon, 23 Sep 1996 16:33:09 -0400 (EDT)
the ignition switch right away >>Had the exact same problem w/ my '87 XJS too. Turned out to be a borderline
Julian Mullaney
The case described by Julian sounds different than mine. The
relay does not click untile after the delay period. The power
comes up, there is no click, I hold the key in start position,
after the delay it kicks in. Wierd huh?
Thomas
Date: Mon, 23 Sep 96 15:31:31 CST
Subject: Re: Engine coolant heaters (Minor Jag content)
Be very careful to make sure that the heater will fit in a freeze plug before
you pop the plug. There are several listed as working on a 4.2 engine in
the US BUT THEY DO NOT FIT!!! Putting a freeze plug back in is not easy.
A lot of cars use heaters in the winter here and they are very effective.
Generally, we leave them on all night and the cost per year is quite trivial.
On very big V8’s,(six/ seven litres) people use 1000watts, but 600 is fine
for most cars. The cost is well offset by the lower wear on the engine and
starter.
A freeze plug heater is best but most people us one that fits in the lower radiator hose
as it is far easier to install. There is a type that replaces the dipstick but it
heats the oil which doesn’t seem to be vey effective in helping it start.
If your car is in a garage a night, then need for any heater is dubious as
much of the problem of the cold (it gets down to -40C/-40F here
occasionally) is the wind chill and not the air temp. A good battery, clean terminals,
and a tune up will get most cars started in almost any cold. Fuel injected
cars seem to be far easier to start in the cold. I presume this to be
because they will start at a lower cranking speed.
My old XJ12 (may he rest in peace) started all winters and was parked out
side without any heater.
at the programmed intervals.The mounting procedure is to remove one of the engine block’s core plugs
Roger Langley
Date: Tue, 24 Sep 1996 09:34:32 +1200
Subject: RE: Need Good Book (A picture is worth 1000 words)
From: hastings@frodo.eucom.mil[SMTP:hastings@frodo.eucom.mil]
Sent: Monday, 23 September 1996 05:26
Cc: frankp@scnet.net
Subject: Re: Need Good BookFrank wrote “I’m sure this will spark a flood of E-mail, But I would
like to buy a
book If I could write it I’d call it the complete book of Jaguars…”Just a thought
Could the list members assist in compiling a photographic almanac of
Jaguar models.
Maybe a history of model types could be assembled from photo images
submitted
by members with simple caption stating the vital statistics only. Only
one example of each
year / model / country / variant to be included; selected from the best
submitted.
It would be a sense of honour to have your Jaguar featured so it such
bring out the best
examples worldwide.
Not sure where this could be published but maybe somewhere like the
JDHT web pages
would like to host such an presentation.
As I said “Just a thought”Regards JKS-XJS
john_setters@eagle.co.nz
settron@iconz.co.nz
Date: Mon, 23 Sep 1996 17:55:03 -0400
Here’s the part with the strongest stench :
<The
researchers, and educational institutions throughout the world.>
Yeah, right.
These “kinds of” schemes often require the active invovement of students and
teachers all to the aggrandizement of the supposed benefactor and in the end
nothing much for the workers. ( Campbell soup labels for example in exchange
for ancient over-stock AV equipment. ) Remember Christopher Wittle’s cynical
intrusion into poor school systems during the last several years wherein
students’ minds were exchanged for mediocre computers the community refused
to buy.
I am not offering a conclusion here, only my skepticism based on too much
experience. Do let me know if my doubts are misplaced; I’ll by a ticket too.
( If this is not enough about Jaguars, please skip my p.s. and accept my
apologizes.)
P. S. I have in front of me a copy of “The Milwaukee Journal Sentinel -
Waukesha edition.” A front page story headline reads CREDIT CARDS TO HELP
LOCAL STUDENTS. You see, First Federal of Waukesha bank has come up with the
idea - they are very proud of it - whereby the bank issues a credit card. It
agrees to “donate” a percentage of the take from the use of the credit card
to high school scholarship funds. The bank officials ( their advertising
already saturates the schools’ field houses ) , as if to show the depth,
bredth, and relentlessness of their concern for an educated citizenry,
reminded those citizens emphatically that we are all in this together, as a
community, and that the success of this act of educational beneficence
depends on folks getting out there and charging stuff. The more we borrow,
the longer we borrow, the better educated we will be.
And so, lets all wise up, be role models for youth, and support education by
borrowing lots of money at obscene interest rates. Like the man whispered in
“The Graduate”,… “plastic”
It worked during the 80’s I am told by some.
Date: Mon, 23 Sep 1996 17:59:03 -0400 (EDT)
I have wondered whether it is easier to yank the V12 out from the top or
to drop it down out the bottom with the subframe. Anyone done this?
John
Date: Mon, 23 Sep 1996 18:15:30 -0400 (EDT)
This is one of the failure modes I had on my 82 XJ-S when the inhibit
relay was on its way out.
John
End of jag-lovers-digest V2 #374
id for jag-lovers-digest-out; Tue, 24 Sep 1996 16:04:39 +0200 (MET DST)
Date: Tue, 24 Sep 1996 16:04:39 +0200 (MET DST)
Message-Id: 199609241404.QAA26842@ekeberg.sn.no
Subject: jag-lovers-digest V2 #375
Precedence: bulk
jag-lovers-digest Tuesday, 24 September 1996 Volume 02 : Number 375
Re: E-type windshield manufacturers ?
Jaguar XK8 Raffle Legitimacy
Battery for XKE: Follow-up
Jaguar “Swap Meet Postings”
Jaguar Paint Codes
Re: Jaguar “Swap Meet Postings”
Jaguar Part-Yards
XJ40: Part numbers - for front lamps
<Arggg!! Brake Dust on my XJ40!!> two more bits…
Headliner adhesive
Headliners
RE: Jaguar Part-Yards
88 VDP starting problem
1990 XJ-S Auto Coupe
Re: Headliner adhesive
steering wheel wobble (at certain times)
SIII V12 Engine surge
pie in the sky jag
Re: Arggg!! Brake Dust on my XJ40!! now : KleenWheel where?
Re: Jaguar Part-Yards
From: rrichardson@eurekanet.com (Robert J. Richardson)
Date: Mon, 23 Sep 1996 20:17:53 -0500
Subject: Re: E-type windshield manufacturers ?
Hi group,
them.Thanks a lot, Eric
Eric F.P.M. Vuurman
staf psychiatrie
P Debeyelaan 25
6202 AZ Maastricht
tel +31 433 876147
Fax +31 433 881046
I purchased the windshield for my 1964 E-Type Series I FHC from NOS
Locaters, 587 Pawtucket Ave., Pawtucket, RI 02860 Phone 401-721-5000. The
ad usually is in Hemmings. The tinted windshield is part no. NW206T. Price
is $119.99 plus container cost, etc. They also have a shaded (blue band at
top) glass. The NW206T is a green tint throughout. This infomation is from
an old Hemmings so you might give them a call before ordering.
Date: Mon, 23 Sep 1996 21:33:28 -0400 (EDT)
Subject: Jaguar XK8 Raffle Legitimacy
The Global Technology Exchange Foundation was organized this past March by
myself, an academic editor; the vice president of a bank in Pennsylvania;
and three history professors who travel extensively in less developed areas
of the world and are aware of the needs for computers by their less
fortunate counterparts.
The foundation is legitimate, but fledgling. It has a 501 (c) 3 tax
exemption from the IRS. This is its first fundraiser and is being conducted
exclusively via its web page so as to reach a large audience that may have
some interest in its cause.
I appreciate the concerns expressed in the group, especially regarding the
foundation’s legitimacy and its potential to achieve its goals. The
foundation was incorporated in New Jersey and now operates out of a corner
of my office in New Jersey. Unfortunately, New Jersey raffle law is such
that it prohibits advertising in any media, presumably including the
Internet. The raffle is being conducted in Montana because of that state’s
less restrictive regulation of nonprofit raffles.
The XK8 Coupe is on order at Brad Benson Jaguar in South Brunswick New Jersey.
Rest assured that should we sell enough tickets (about 1,500) to purchase
the XK8, the winner of the drawing will get it. Otherwise, everybody gets
their money back.
If you have any further questions, you may call me at 609/737-6375.
Rick Batlan
Chairman
Date: Mon, 23 Sep 1996 21:36:12 -0400 (EDT)
Subject: Battery for XKE: Follow-up
Group:
I have found a reasonable replacement for the battery in my E-Type. As a
recap, I was looking for something a bit more attractive than the usual
Interstate. I considered a Lucalike from New Castle Battery, but this
battery is an approximation of the Lucas tar-top found in older Jags. It
seemed foolish to pay twice the normal price for a battery which would be
almost as inappropriate as the one it replaced.
I checked out a number of modern batteries, including Exide, Optima, Johnson
Marine, Interstate, Energizer, and Diehard. (I believe that there are only
one or two actual manufacturers on this list: when you take a hard look,
they all seem more or less the same.) Big problem is that modern batteries
have flanges to accept a bottom-edge clamp. The E-Type battery shelf is
deceptively small, and these flanges shift the battery into a bad position.
The battery I finally ended up with is made by Exide, and was recommended by
someone on the list. Exide makes an ‘International Series’, which it claims
is a drop-in replacement for OEM batteries. I found that the Size 34 in this
series was closest to being correct, but did not allow enough space for the
clamp rods. So I used the Size 35, which is a tad too small, but looks fine
none the less. Don’t try to use the standard line of Exide batteries, as the
sizes are just wrong for the E-Type.
The Exide 35 battery produces 675 CCA, which should be adequate. The SKU
number is 1189208. I bought mine at Mongomery Ward for $65US, and it comes
with a 75 month warranty.
Once the Exide labels are peeled off, I will have a featureless black
battery to which I can affix a Lucas sticker. Very nice.
Mike Frank
1969 E-Type 2+2
Date: Mon, 23 Sep 1996 18:51:21 -0700
Subject: Jaguar “Swap Meet Postings”
I would also vote for a place to be able to trade excess Jag goodies for
stuff you really need. I currently have a few bits and pieces and some
manuals that I know someone could use and in return I need some odds and
ends in my E restoration. If Nick could figure out a way to do this so
it wouldn’t become too commercial and yet maybe we could pay a small bit
toward the space it required?
Date: Mon, 23 Sep 1996 18:57:23 -0700
Subject: Jaguar Paint Codes
Is there some definitive source for Jaguar paint codes? I’ve noticed
several people have asked about specific paint codes. I’m also running
into a bit of trouble in that only one local paint supplier can come up
with my original color, “Regency Red”, and thats only in Glasurit brand
paint. Perhaps if we could go to the paint dealer and say give me 4
litres of BVLH 265 or something similar, then they could mix the
appropriate paint.
If nothing likes this exists, then perhaps we should compile something
for the benefit of all those doing a re-paint. I would be willing to put
something together if it would be useful.
Date: Mon, 23 Sep 1996 21:58:28 -0400
Subject: Re: Jaguar “Swap Meet Postings”
In a message dated 96-09-23 21:52:18 EDT, gwcohn@azstarnet.com (George W.
Cohn) writes:
<< I would also vote for a place to be able to trade excess Jag goodies for
stuff you really need… If Nick could figure out a way to
do this so
toward the space it required? >>
Yes!
I support this as I may be requiring some bits for my XJS convertible.
Wouldn’t it simply be an improvement to “market efficiency”.
Julian Mullaney
Date: Mon, 23 Sep 1996 19:37:11 -0700
Subject: Jaguar Part-Yards
Hi all Jag Lovers!,
Was just wondering if anyone knows of any good part-yards in the
U.S., U.K., or Australia? Particulary interested in finding parts for
an XJ40, namely the two front headlamps and bulb fail/controllers.
Very hard to find these lamps used! All scrap-yards will only sell the
whole front-end of the car.
If anyone has the Name, Number, and location of the place, I’d
greatly appreciate it!
Thanks for any help!
Eric
cobac@ix.netcom.com
1989 XJ40 VDP
Date: Mon, 23 Sep 1996 19:48:57 -0700
Subject: XJ40: Part numbers - for front lamps
Hi all Jag-lovers!,
Been struggling a bit trying to locate square headlamps for the
XJ40, and I’m willing to try and buy them outside the U.S., if
possible. I was wondering if the part numbers are the same for the
headlights around the world, thus making them fit in a U.S. version
car.
U.S. version “square” headlamps '90-'94 XJ40
Assembly= R) DBC 11464 $500.00
L) LMB 4511AA $500.00
Lens & Housing= R) JLM 2012 $225.00
L) JLM 2013 $225.00
Bulb Controllers= ?? approx $250.00 each
I hope someone with a European/Aussie model can verify these are the
same part numbers in their car or the numbers are different (maybe,
because of import regulations?)
Thanks a lot for any help you can offer!
Eric
cobac@ix.netcom.com
'89 VDP
Date: Mon, 23 Sep 1996 22:56:05 -0400
Hi all,
I sure could have used such a site while restoring my E.
If posts were kept short and to the point, I don’t see any
reason why they could not be posted here. (?)
Certainly apropos, no? (well, at least it rhymes!)
Good idea, George.
BTW, I’m still looking for '62 (era) heater box, core, etc.
I also have boxes of trash…er…very expensive jag-u-war stuff!
'62 E-Type, ots
Date: Sat, 21 Sep 1996 20:05:23 -0700
Subject: <Arggg!! Brake Dust on my XJ40!!> two more bits…
Seems to me that the discussion on the “heating” of brakes due to dust
shields is missing some basic facts of thermodynamics and reality…
The brakes (read brake rotors here) heat up because they absorb the heat of
friction. If you consider the mass of metal represented by the rotors it
becomes obvious that air flow over their surface is a minor dissipator of
heat; particularly in stop and go traffic which is where the great majority
of us will excersise our brakes.
The primary dissipators of heat in this setting are radiant heat (has
nothing to do with air flow), and the transfer of heat from the rotors to
the other metal components that the rotors are hooked up to (also not
affected by air flow). You might remember from physics that fast absorbers
are also fast radiators of heat.
I agree that fully enclosing the brakes with no air flow at all would
accelerate heat build up; however this is far from the actual circumstances
even with dust shields on. Unless you have a hell of an air dam up-front
and shields surrounding the inside of the wheel wells there is air flow down
there. IMHO it is more than adequate to prevent build up of dead hot air.
Best to all,
Rob W-M
85 XJ-S
Date: Mon, 23 Sep 1996 22:06:17 -0600 (CST)
Subject: Headliner adhesive
Rob W-M wrote:
The glue is “auto trim adhesive”. 3-M makes cans and spray-cans of the
stuff and you can find it (or a comparable product) at hardware stores or
home improvement places.
I recall what I used the second time was “3 M - General Trim Adhesive”.
The first time I was sold a “comparable product” from a hardware store.
What they did not tell me was that it could be expected to hold up a
headlining for up to a couple of weeks.
Tony Gardner
XJ6 Seried III 1985
Date: Mon, 23 Sep 1996 22:31:06 -0400 (EDT)
The one thing I have not seen mentioned (yet anyway… about 60 more to
read still) is the tensioner access hole plug. It’s not much more than a
rubber bung that gets hard and shrinks with time. It’s located on the
right front, just a bit below the head gasket joint.
Randy K. Wilson
randy@taylor.infi.net
Date: Tue, 24 Sep 1996 00:52:34 -0400
Subject: Headliners
buzzing the list today it looks like somebody is trying toput in a
headliner, I did this my self on a old Lincoln the trick is to buy only
3m spray adhesive and read the can there is only one 3m adhesive
recomended for this job. The wrong can will say not for head liners, and
the first hot day you will be wearing your headliner. Headliner kits
including fabric and clips are available at local auto parts stores. In
Florida they go for $29.99 w/o adhesive. Good luck.
Frank P. 1985 XJS
Date: Tue, 24 Sep 1996 02:47:40 -0400
I also support this idea as I need some parts for a 77 XJ-6 as well.
Date: Tue, 24 Sep 1996 00:27:46 -0700
Subject: RE: Jaguar Part-Yards
There are loads of them in the UK. Here are a few, pulled at random from
the August Jaguar Enthusiast magazine…
David Manners 0121 544 5558
Just Jags 01922 37779
Classic Components 01325 722777
Steve Hunt 0121 777 0071
Norman Motors 0171 431 0940
Classic Spares 01992 716236
David Kelly 01978 843253
The Jag Shed 01793 523112
XJS Breakers (XJ40 too) 01992 768007
And then from an old AutoTrader
? 01483 723596
Premier Jaguars 01582 882358
JagNuts 01256 862364
Steve ! 01959 533305
? 0181 845 2650 / 8550
? 01324 825654
PLEASE note, that all I’ve done here is go though a couple of Mags for
you. I’ve never tried many of these numbers, and no recommendation
should be implied, and all that stuff …
From: cobac@ix.netcom.com [SMTP:cobac@ix.netcom.com]
Sent: Tuesday, September 24, 1996 2:37 AM
Hi all Jag Lovers!,
Eric
cobac@ix.netcom.com
1989 XJ40 VDP
Date: Tue, 24 Sep 1996 08:47:52 GMT
Subject: 88 VDP starting problem
Jag-lovers,
Recap of problem: Turn key, all power available but starter won’t engage.
Starter and Solidnoid switch check out fine. If switch is held to start
position and gear shift is hit car starts.
Just to let all know that I was able to track the culprit for the starting
problem. It was the Linear Switch which mounts to the housing around the gear
shift. I took the old one apart and checked all connections and cleaned the
points but problem still existed. Finally broke down and bought a new part from
Terrys Jag. When I put it in all was fine. Just a note though that the mount
points are adjustable about 1/4" back and forth so some tuning was required to
make sure that the gear shift was in the proper place to activate the switch
when it was put in park. Thanks to all for their advice.
Back on the Road again
Craig Hastings
88 VDP
4.2 E-type (looking to buy)
From: Derek.Dohren@sinbad.nsc.com (Derek Dohren - National Semiconductor)
Date: Tue, 24 Sep 1996 11:11:53 +0100
Subject: 1990 XJ-S Auto Coupe
Can anyone furnish me with the following info regarding the XJ-S, 1990
model Auto Coupe ?
Engine capacity, bhp, mpg, 0-60, max speed…
… and any other related info. I am finding conflicting figures in various
magazines / publications and would like a definitive reference.
Thanking you in advance,
Derek
Date: Tue, 24 Sep 1996 07:56:49 -0400
Subject: Re: Headliner adhesive
home improvement places.I recall what I used the second time was “3 M - General Trim Adhesive”.
headlining for up to a couple of weeks.Tony Gardner
XJ6 Seried III 1985
I tried doing this myself twice. First with the “general adhesive” from
3-M, and then a week later with the “super adhesive” version of the 3-m
product.
In both cases, the spray adhesive was hard to control, and the rotted
foam behind the material produced a shoddy look.
I then paid someone $180.00 to do the headliner and trim. That was over
a year ago, and it still looks great! btw, this car is in Florida, and
is subjected to considerable inside temperatures and humidity (rain).
Date: Tue, 24 Sep 1996 08:05:19 -0400
Subject: steering wheel wobble (at certain times)
Hello all.
I have an '83XJS that has a steering wobble (left to right vibration)
only when accelerating, or braking through a zone of 20-30 MPH.
I have just replaced the bushings on the front anti-roll bar, with no
noticable change.
the tires that are on the car now are smaller than normal, because they
came with the alloy wheels. Could undersized tires cause this problem?
P195-60/R15
Thoughts?
Date: Tue, 24 Sep 96 13:53:52 BST
Subject: SIII V12 Engine surge
Quick question about my newly purchased SIII V12. On cold starting the engine
tends to “surge” between 1200 and 1500 revs, only for a minute or two. I’ve been
told (not by the garage that sold me the car) that this is actually quite normal
for these cars and is due to the ignition cut out operating at zero throttle
with more than 1500 revs, and the “cold start” process boosting the idle on
start. Any comments??
BTW, it is such a lovely car to drive!!
TIA,
David Brown,
brownd@ml.com
Date: Tue, 24 Sep 1996 19:13:58 ±800
Subject: pie in the sky jag
I’m sure every state has regs to control raffles. I know Connecticut =
does…pretty tough ones too. the party has to print a specific number =
of numbered tickets, the number can’t change, they have to be dated, the =
drawing has be printed on the ticket, etc. All has to registered with =
state in unobtainum number of forms and these all have to signed by the =
local coppers, etc…need I say more…John Shuck, Beijing…
Date: Tue, 24 Sep 1996 14:43:57 -0700
Subject: Re: Arggg!! Brake Dust on my XJ40!! now : KleenWheel where?
Sound like a nice to have product to me.
Has anyone seen KleenWheels for sale in the UK?
/Espen
Date: Tue, 24 Sep 1996 10:13:15 -0400 (EDT)
Subject: Re: Jaguar Part-Yards
Jaguar Heaven in California, 800 969-4524
Thomas E. Alberts
End of jag-lovers-digest V2 #375
X-UIDL: 778e03259e112e21658d1cfea90ecbe1
id for jag-lovers-digest-out; Tue, 24 Sep 1996 20:19:37 +0200 (MET DST)
Date: Tue, 24 Sep 1996 20:19:37 +0200 (MET DST)
Message-Id: 199609241819.UAA06045@ekeberg.sn.no
Subject: jag-lovers-digest V2 #376
Precedence: bulk
Status: RO
X-Status:
jag-lovers-digest Tuesday, 24 September 1996 Volume 02 : Number 376
Jaguar Accessories
Re: steering wheel wobble (at certain times)
Re: REFRIGERANT
MK X Purchase
swap meet postings
Re: swap meet postings
RE: Raffle
RF Modulation CD Player units ( long )
Engine Heaters
RE: steering wheel wobble (at certain times)
Ct Jaguar Club Car Show
Pronouncing the name.
Re: [SIII XJ6] Sovereign equipment
Re: MK X Purchase
Re: XJ40: Part numbers - for front lamps
Date: Tue, 24 Sep 96 15:45:02 BST
Subject: Jaguar Accessories
I noticed in the handbook for my new SIII that it mentions that Jaguar have
various child safety devices for sale as after-market accessories.
I got to thinking about what a Jaguar child seat would look like…
Does it have claws instead of safety straps?
Does it have electrical adjustments (which keep blowing fuses…) ?
Is it upholstered in matching leather?
Has anyone on the list actually seen/purchased one of these items?
Just curious…
David Brown,
brownd@ml.com
Date: Tue, 24 Sep 1996 09:43:57 -0500
Subject: Re: steering wheel wobble (at certain times)
I doubt its just 'cause the’re undersize. How old are the tyres? Where do
you live? What is the normal range of air temperatures?
If the answers go something like 2 years+, Somewhere hot, 30-40c through summer
then take my experience from the Middle East. Here, we never wear the tread
off the tyres; instead they fail with heat stress. The first signs are
perishing type fine cracks in the walls and tread grooves. When they really go
the tread will form a large blister type bump on the surface of the tyre. Go
and have a look at yours, it’ll be obvious. If this is the case you can feel
the bumps through the steering wheel at low speed. This turns to a general
vibration at higher speeds. Tyre fails within one or two days.
That’s one idea; easy to check. Everyone else tell you about ball joints,
track rod ends, steering bushes, crossmember mounts etc.
Date: Tue, 24 Sep 1996 08:52:39 MDT
Subject: Re: REFRIGERANT
I have also used FR-12 marketed by Penzoil. All is well after
several months. There are also several local aircon service garages
that have begun installing this substitute and they report no
problems. But, they are charging the same price as regular freon -
thus making a killing on the sale of the stuff (bought for 8$US/lb
and sold for 40$US/lb). That ought to be a crime.
Kind Regards,
Jim Cantrell
Date: Tue, 24 Sep 1996 08:00:04 +0000
Subject: MK X Purchase
There is a early 60’s MK X for sale that I am going to look this
afternoon. According to the seller it has a Ford 5.0 L conversion.
He said that it has had an engine fire, but that it didn’t appear
to be too serious. “Probably might just need a new wiring harness”.
He said that the interior is vinyl and that the wood is a ‘7’ on a
scale of 1 to 10. Door has a dent and the paint is mediocre- “not
Jaguar quality”.
Asking price is USD 2200.
As a complete ignoramus as to Jaguars, am I perhaps heading down
the slippery path to financial bankruptcy and marital discord by even
considering buying this beast?
I do have a spare low milage Ford 5.0 engine and matching Ford auto tranny “thanks” to a recent
crash by my son.
BTW this would be his commuting vehicle!
Thanks,
John
Date: Tue, 24 Sep 96 08:12:03 PDT
Subject: swap meet postings
Interesting and valuable idea, but I can see it getting out of hand. How
about if we set aside Tuesday, Friday or any other day to be the “swap meet”
posting day. Use “swap meet” or something as a subject header.
I expect it would be quite heavy at first, but taper off over time.
What 'ya think, guys (and gals)?
LLoyd
Date: Tue, 24 Sep 1996 11:26:19 -0400
Subject: Re: swap meet postings
What about a list of items needed (with name email address etc.) and a list
of items for sale/swap. Couldn’t this be section of the Jag home page where
folks could submit requests anytime?
Being pretty ignorant of the technicalities of how such a thing would
actually work, I pre-apologise if this is a silly or unrealistic notion.
Julian Mullaney
Date: Tue, 24 Sep 1996 11:27:54 -0400
Subject: RE: Raffle
Jumping on the sceptical bandwagon, I reviewed the Foundation’s
webpage, and have a couple of comments. The Foundation was
incorporated in 1996. Unless it was around under another name before,
it probably hasn’t had time to develop a track record of success if legit,
or to be debunked if not. This also must be the “first” annual raffle.
Further, having an office in New Jersey and Montana sounds a bit odd.
No matter how bad one may want an XK8, especially for $50, I say let
this one ride for a few weeks until we shake more out.
Even if the whole thing is properly set up, if you buy tickets now and
bankruptcy is declared later, you won’t see your money again. Just my
opinion.
Date: Tue, 24 Sep 96 09:29:00 PDT
Subject: RF Modulation CD Player units ( long )
Michael Powers asked about any caveats about Best Buy installing a RF CD
player.
I assume you want the CD player installed in your trunk. They will then
have to run several cables through the trunk ( power connections, antenna
lead, unit control cable ). They then will need to get to the back of your
radio, un-hook the antenna from the radio, plug the antenna into a “box” (
like a relay ), plug this box into your radio antenna conn. They then need
to place a display unit for the CD ( no your radio will NOT control a RF
type CD player ) somewhere via stickum / Velcro, or cut a place in your dash
to fit this unit.
If your unit is like the Pioneer unit I have, you will notice a slight, but
noticeable signal strength drop. To use the CD, you tune your radio to 1 of
2 frequencies. Use the remote of the unit, to power up the CD player, this
triggers the “relay” your antenna lead is connected into to trigger, greatly
attenuating your FM signal while the player is now playing on that FM
channel. As a FM radio signal is better then AM for sound, it still does
not have the same upper frequency ( cuts off around 10KHz per left & right
channel. I know I will be corrected, but I am trying to simply my
description ) limit as your tape deck or CD’s ( 22 - 27 KHz ) have so your
sound will be a little flatter then a CD player that connects directly
through your radio. If you try and listen to other stations while the CD
unit is on, you will notice even more of a signal strength loss.
I am with the others, if your XJ40 has the Alpine radio unit, why not spend
that extra few $$$ and get an alpine CD unit that will plug directly into
your unit and can be controlled from the radio.
( On my CD, I was able to get an adapter that hooks my CD player into the
same control jack that a newer CD unit plugs into that the radio can
control. I still can not use the radio to control the unit, but it no
longer goes through the antenna. )
John Himes
88 XJ-S 97K Miles
Date: Tue, 24 Sep 96 09:43:00 PDT
Subject: Engine Heaters
Last year when I was looking for an engine heater ( we have a one car garage
& my wife uses this, my car will barely fit & with 2 large dogs, it is safer
outside, at least it is not parked on the street, just under a large pine
tree and in back of a large bush. The birds seem to like where I park
though ), most shops I went to, when they checked their books, it
there was one referenced for my V12, it was a freeze plug heater. After
looking at where the freeze plugs are & that I did not want to go to that
much trouble, I got one of the heaters that fits into the lower radiator
hose. Works great for me. There was LOTS of posts on this sometime during
the end of last year or the first few months of this year. Maybe check the
digests from then if interested. It is VERY hard to find a dip-stick heater
that will fit down the long tube & make it into the oil. Only the bottom
inch or so of these heaters actually heat the oil. Do you really want to
“boil” your oil to try and heat the engine? Besides, you can not close the
hood / bonnet with these things in there.
John Himes
88 XJ-S 97K Miles
Date: 24 Sep 96 10:54:38 EDT
Subject: RE: steering wheel wobble (at certain times)
I have experienced this problem with my '84 XJ-S. Replacing the on the
stabilizer bar had some effect but did not cure the problem. The
wobble was greatly diminished when I replaced the wheel bearings and
brake shoes. The job is not difficult and can easily be accomplished
in an afternoon.
Robert Woodling
'84 XJ-S
Cc: sadler@docexpress.com
Date: Tuesday, September 24, 1996 8:05AM
Hello all.
noticable change.
P195-60/R15
Thoughts?
Date: Tue, 24 Sep 96 18:03:00 GMT
TYRE CHANGE ESSENTIAL RIGHT NOW!!!
I’ve had this and spent hours trying to find the fault, turned out to be
twisted belting in a rear tyre, get them ALL checked including the spare.
Usual cause is being run under inflated for long periods or driving
technique too hard for the tyres being used.
This WILL progress to " at constant speeds around 40" then onto “severe
vibration at all times”
You will be left looking for all sorts of problems from loose wheel nuts to
subframe mountings when all that’s wrong is duff tyres, replace them. Go
for the best for your driving needs though no cheap stuff.
Barrie Dawson
Chatham, Kent England
1985 series III Sovereign
To: ata%netsrq.com
Cc: jag-lovers
Date: 24 September 1996 09:43
summer
go
Go
feel
Date: Tue, 24 Sep 1996 13:09:43 -0400
Subject: Ct Jaguar Club Car Show
Classification:
Prologue:
Epilogue:
There will be a Ct Jaguar Club show in Litchfield, Ct on Sun Oct 6th from 11 to
5 pm.
It will be at the Litchfield Inn. Should be a great weekend of Fall
folliage, cool Fall
days and Jaguars… what more could one ask for? If anyone needs more info,
Email me… Todd
Date: Tue, 24 Sep 1996 12:51:57 -0500
Subject: Pronouncing the name.
Since this is supposedly written to indicate pronunciation of the name
Jaguar I thought I might share some information I recently aquired.
At a recent Jag Club meeting they showed a video of the history of Jaguar
from the Swallow to the present. I was most interested to so how the owners
and perpetrators of the Jaguar company pronounced it. There were several
old voice interviews and I listened very carefully every time one of them spoke.
The pronunciation I got from those interviews was Jag- u- wer. I think
the people who invented it must know how to pronounce it.
JIM I.
“Prefiero morir de pie que vivir de rodillas.”
Gen. Emiliano Zapata
1879-1919
Date: Tue, 24 Sep 96 19:01:00 GMT
Subject: Re: [SIII XJ6] Sovereign equipment
My XJ6 series III Sovereign was sold new in the UK in October 1985 and came
equipped with the following:
Climate control
Trip computer
Pepperpot alloys fitted with silver on black jaguar head centre caps
Headlamp wash/wipe
Electric mirrors - both sides
Walnut dash and door cappings
Leather seat cushion tops and front facing upper seat backs - including
rear centre armrest
Leather look front centre armrest, seat squabs and door trims
Electric height adjustment on both front seats
Lumbar support adjustment on both front seats
Boot compartment carpet - to match interior carpet
Tool kit in plastic case and jack in pouch to match boot carpet
Curtesey lights in the centre pillars and all four doors
Reading lights for back seat passengers
Adjustable front head rests
Fixed rear head rests
Seat belts all round - three in the back
Clarion stereo radio/cassette - with leaping cat logo on cassette door
Jaguar on left and Sovereign 4.2 on the right of the boot lid
Leaping cat badges on the side of both front wings
Leaping cat mascot on the bonnet
By the time I got the car the customary engine oil leak, blocked cooling
system, defective headlamp wipers and doubtful air/con system had been
added, all of which have been fixed. There is some rust around the front
and rear screens but nothing too dramatic. Regular servicing and cleaning
keeps her looking and running like new.
Barrie Dawson
To: Jag Lovers; Gunnar Helliesen
Date: 22 September 1908 13:02
On 21 Sep 96 at 19:26, Gunnar Helliesen wrote:
All this talk about the Series III XJ Sovereign has made me wonder
if the Sovereign designation meant different things in different
markets?
Without a doubt…
My '86 XJ6 SIII (not Sovereign or Vanden Plas) was sold new in the
USA.
It includes the pepper pots wheels, sunroof & the climate control
system, computer & cruise control. On the rear of the car it says
“Jaguar” on the left and (my wife swears) XJ6 on the right (I’d
look, but the car is in Jaguar hospital get by-pass surgury). The
interior is very nice with veneer and leather, but it feels like the
leather is only on the seat cushion tops and front facing upper seat
backs There are only front seat headrests (which don’t feel like
leather), and no reading lamps on the C pillars.
It’d be interesting to hear from more of us owners and the various
levels of luxury associated with the model/name/year in the country
your car was sold.
Peter Morris
From: “Patrick O’Neill” patrick.oneill@premierusa.com
Date: Tue, 24 Sep 1996 11:09:30 -0700
Subject: Re: MK X Purchase
I think that you need to find another car to look at, $2,200 would be fair
if the wiring harness was not burnt and it had the correct engine in it.
About 12 years ago my Uncle had a Mk2 that had a similar small engine fire
and the insurance company totaled the car and gave him $7,000 USD for it.
You would be better off finding a nice Mk2 or anything other than this Mk
X.
Cheers,
Patrick D. O’Neill
1963 Mk2 3.8L MOD
Date: Tue, 24 Sep 1996 13:43:49 -0500
Subject: Re: XJ40: Part numbers - for front lamps
You certainly can’t use Aussie, Brit or Japanese market headlamps, they dip
to the other side of the road than U.S. ones! (RHD vs LHD)
I don’t know about various Continental European, Scandinavian or Canadian
lights for the XJ-40, but the parts book for my '74 E-Type has quite a
variety of headlamps for different markets. And that was back when they
were all 7" round lights! Maybe Europe has finally standardized with the
coming of the EU.
MikeC
______________________________ Reply Separator _________________________________
Author: cobac@ix.netcom.com (Eric J Faber ) at Internet
Date: 9/23/1996 7:48 PM
Hi all Jag-lovers!,
car.
L) JLM 2013 $225.00
Eric
cobac@ix.netcom.com
'89 VDP
Date: Tue, 24 Sep 1996 13:57:35 -0500
This topic comes up fairly often. The following was posted by Greg Meboe
back in '95. There was another lengthy technical post that basically said
the same thing. Too bad I didn’t know the difference between 8080 and 8090
when I started glueing my E-Type interior back together. I can certainly
vouche for the uselessness of 8080 on the various vinyl-like interior
materials in a Jag. (e.b. Ambla)
MikeC
"---------- Forwarded message ---------- From: ccamley@mmm.com
Greg,
Following is a note I received on gluing LBCs…I hope you find it
informative. I’ve always wondered why there are so many kinds of
adhesives. This gives a little idea of why that might be.
Let me know if there’s anything more I can do for you. Regards,
Chris
I received some info from you via Diana Fasbender concerning a message from
Greg Meboe and his dissatisfaction with some 3M Aerosol Adhesives.
I am the product marketeer for the ITSD Industrial Aerosol Adhesives and I
formerly was the product marketeer for Auto Trades Aerosol Adhesives.
Here are some comments I would have on the results which Mr Meboe had:
- 74 Foam Fast Adhesive is an excellent foam bonding adhesive which
performs well up to about 120 degrees F. Above that temp, the adhesive
will soften, and with sufficient stress, you can pull the foam apart. It
is possible to experience up to 150+ degrees in a closed car, and the seat
part does see
a fair amount of stress when a person is sitting on it.
Another 3M product which is a good foam bonder and has 160 degree temp
resistance is General Trim Adhesive, pn 08080, which is sold by the
Automotive Trades Division. This would be a better product to try for seat
bottoms.
- 76 is a good product—but does NOT have very good plasticizer
resistance. Vinyl material is typically loaded with plasticizing oils, and
in time these plasticizers migrate from the vinyl to the adhesive, and they
soften the adhesive to the point the adhesive becomes very soft and gummy
and “lets go”.
76 has 160 degree F temp resistanceand would work on foam bonding, but
vinyl bonding would not be a long term success.
A better product for bonding vinyl is Super Trim Adhesive, pn 08090, also
sold by Automotive Trades Division. Super Trim is a neoprene-based contact
adhesive in an aerosol can. It has 200 degree F temp resistance, and is
plasticizer resistanct. In fact, Super Trim is very good for reattaching
vinyl tops, vinyl trim,etc in auto restoration projects.
I hope this info is of some help. Please feel free to pass on this info to
Mr Meboe. As we do not have actual substrate samples to test, it would be
advisable for Mr Meboe to test with the products indicatedbeforehand
in order to judge how adequate the adhesives would be for his restoration
project.
Best Regards,
Timothy J. Hesse"
Author: “A. Gardner” gardnera@SLUVCA.SLU.EDU at Internet
Date: 9/23/1996 10:06 PM
I recall what I used the second time was “3 M - General Trim Adhesive”. The
first time I was sold a “comparable product” from a hardware store. What they
did not tell me was that it could be expected to hold up a headlining for up
Tony Gardner
XJ6 Seried III 1985
End of jag-lovers-digest V2 #376
X-UIDL: d6a2475361fb66e2611777eeb0046e18
id for jag-lovers-digest-out; Wed, 25 Sep 1996 05:25:15 +0200 (MET DST)
Date: Wed, 25 Sep 1996 05:25:15 +0200 (MET DST)
Message-Id: 199609250325.FAA01827@ekeberg.sn.no
Subject: jag-lovers-digest V2 #377
Precedence: bulk
Status: RO
X-Status:
jag-lovers-digest Wednesday, 25 September 1996 Volume 02 : Number 377
Re: Pronouncing the name.
Jaguar specialists on the Web
Re: Engine Heaters
FW: XJ12 - oil leak questions.
83 XJS Steering wobble
V12 turbos
Jaguar - The worlds most accurate car!
Re: Engine Heaters
Fwd: Headliner adhesive
Paint Codes
85 XJ6 Horn Won’t Quit
RE: PAINT CODES
Automatic Transmission Problems '83 XJ6
Jaguar Part-Yards
Re: Engine Heaters
First 5K-(1992 XJ40) and other stuff
Noisy exhaust
Re: MK X Purchase
Date: Tue, 24 Sep 1996 15:18:23 -0500 (CDT)
Subject: Re: Pronouncing the name.
What is this video, is it any good, and where can one obtain a copy of it?
I agree. That’s how just about all those I know of the British persuasion
pronounce it.
Larry Lee
Date: Tue, 24 Sep 1996 23:08:29 +0200
Subject: Jaguar specialists on the Web
Just to let you all know that there is now a web-site
dedicated to the promotion of Jaguar specialists
worldwide. It’s a pretty new venture, but slowly gaining
in size. Currently there are pages from the following:
- The Jaguar Daimler Heritage Trust
- Jaguar World magazine (with back-issue and subs info)
- Vicarage
- Guy Broad Parts (mainly XK)
- The Hutson Motor Company (E-type panels and parts)
- Moores Classic Cars Interiors
- Burlen Fuel Systems (the SU people)
- Double ‘S’ exhaust systems
- Autostyle (Jaguar woodwork and XJS bodykits)
- Southern Classics (Restorations)
Plenty more will be up over the next weeks. Stop by, and if
you get in touch, let them know you saw them on the web!
Find JagWeb.com at http://www.jagweb.com/
Nick
Nick Johannessen // nick@jagweb.com // http://www.jagweb.com/
Date: Tue, 24 Sep 1996 19:33:28 GMT
Subject: Re: Engine Heaters
Can someone enlighten me ?
A couple of folks mentioned engine block heaters that are mounted in the lower
radiator hose. How do these things heat up all the coolant, considering that
when they start the thermostats are closed and they only have thermal
convection to circulate the heat ? Is that really enough to get
to the thermostats, open them, and generate convetion throughout block and
radiator ?
Sceptically,
Stefan Schulz
jaguar@suaviter.demon.co.uk
Date: Tue, 24 Sep 1996 14:49:03 -0700
Subject: FW: XJ12 - oil leak questions.
I’m getting into this thread late in the game, I apologize if this
already has been mentioned. I recently went through a serious bout of
V-12 leakage at the front of my engine and also believed initially that
it was related to the timing chain cover. The leak seemed to have
started abrubtly and, before I caught it, had coated the alternator and
caused it to fail. Turned out to be the front crankshaft oil seal – an
inexpensive part and a fairly easy repair.
Aaron
'85 XJ-S
Sent: Monday, September 23, 1996 7:31 PM
To: jag
Subject: Re: XJ12 - oil leak questions.The one thing I have not seen mentioned (yet anyway… about 60 more
to
a
right front, just a bit below the head gasket joint.Randy K. Wilson
Date: Tue, 24 Sep 96 16:16:00 PDT
Subject: 83 XJS Steering wobble
ata@netsrq.com asked:
noticable change.
Did you check the rack mount bushings ( 3 sets of them )? If these are
worn, when you turn the steering wheel, the rack will slide if the bushings
are wearing or are worn out and the wheels will not turn until the rack is
pressed against the mounts. The steering can also wobble or wonder. ( I
know from experience ) If the wobble happens when braking only, could be a
warped disk. If it only happens during execration, could be a broken mount
on the drive axle, but my experience with that is the car will really shake,
at least on a 4x4. My uneducated guess would be to check the rack mount
bushings, or any other rubber parts in the steering / front wheel mount
components.
John Himes
88 XJ-S 97K Miles
Date: Wed, 25 Sep 1996 08:34:50 +1100
Subject: V12 turbos
There was a recent thread about this subject so I went back to my copies
of “Australian Jaguar” magazine which featured the ex Kerry Packer car
back in 1986. He was sick of being hosed off on the local expressways
by 930 Porsches apparently so had a Sydney turbo expert put twin IBIs
in. The result was not happy and the car caught fire. The wreck was
obtained by Roley Walker in Sydney and the car was sprayed black and had
twin Rajay turbos installed, the D type diff was already there, a
Ferrari formula 1 flat 12 engine management, 7.8 compression, Cosworth
pistons, high lift cams, Getrag 5 speed gearbox and obvious mods to
suspension and brakes. The car was said to be capable of 340kph and the
author of the article saw close to 300 kph. The engine apparently
produced 740bhp at 9psi boost and it was thought that it might get
1000bhp at 14psi. There was no mention that the engine had been
enlarged. I saw the car at the Syndey motor show and the engine bay was
certainly crowded.
Regards Peter Smith
Date: Wed, 25 Sep 96 18:23 CST
Subject: Jaguar - The worlds most accurate car!
In the April 27 (96) issue of New Scientist (The Australian version anyway)
the following quote from a recent Jaguar marketing blurb appeared…
Speaking of the 1996 XJ6 it says…
“No car in the world receives a more testing technological start in life than
a Jaguar. The geometry and alignment of the wheels are defined by computers
to an accuracy of 0.00000176 of a degree which makes for more responsive control
and longer lasting tyres.”
This accuracy apparently equates to the width of a single atom. Typical, of
Jaguar, says the article, once you do something that removes a few atoms from
the tyres such as braking or even driving in a straight line you should call
into a Jaguar service centre to have the wheel alignment adjusted
Regards Scott.
Scott Fisher [sfisher@sola.com.au] PH: +61 08 329-28341.
_--_|\ N
SOLA / \ W + E
International Holdings Research Center _.–_/ S
Adelaide, South Australia. v
Joy ia a Jaguar XJ6 with a flat battery, a blown oil seal and an
unsympathetic wife, 9km outside of a small remote town, 3:15am on
a cold wet winters morning.
SOLA?- Opthalmic Lens Manufacturer, unless all those transparent disks
we make are part of some secret conspiracy to make transparent disks!
Date: Tue, 24 Sep 1996 20:24:25 -0400 (EDT)
A handy trick to keep birds away from cars or boats left outside is to
place a plastic owl or falcon nearby. I got tired of the birds using my
boat cover for a target and placed a plastic peregrine falcon (Northern
Hydraulics sells them - they have an 800 #) on top. Looks real and works
like a charm.
John
Date: Tue, 24 Sep 1996 20:54:32 -0400
Subject: Fwd: Headliner adhesive
In a message dated 96-09-24 07:57:30 EDT, ata@netsrq.com writes:
jag-lovers@sn.no
I agree that Headliners on an XJS are best left to professionals. I
tinker around a good bit but tried unsuccessfully to install one on Ford.
There was much effort involved and poor results. Learning from this
experience, I had a professional install one in my XJS two weeks ago. The
results are superb and the cost was $150. (I had estimates for as low as
$125 but had past experience with the shop I eventually chose).
Tony
85 XJS-HE
Forwarded message:
Reply-to: sadler@docexpress.com
To: jag-lovers@sn.no
Date: 96-09-24 07:57:30 EDT
XJ6 Seried III 1985
product.
Date: Tue, 24 Sep 1996 21:04:07 -0400
Subject: Paint Codes
There was a thread about Paint codes. Does anyone know the official name for
“CDJ.”
The car is an 85 XJS (Red). A local Jaguar dealer told me that “No 85 XJS’s
were Red” (my car has the original paint) and furthermore, “the paint code
stamped on my VIN was never used by Jaguar”. Gee, if this is accurate I
wonder if my car really is a Jaguar ?. I hope it doesn’t turn out to be a
Yugo !
Tony
Date: Tue, 24 Sep 1996 20:32:52 -0500
Subject: 85 XJ6 Horn Won’t Quit
The other day I started my Jag and headed to work. After turning a =
corner my horn beeped a couple of times while I was turning the steering =
wheel. A few more turns and now the horns continuously operate when I =
turn on the ignition switch.
I am thinking something may have fallen of inside the steering column =
which is ‘grounding’ the circuit. From the wiring diagrams it appears =
the horns operate when the circuit is grounded by pressing the horn.
Am I on the right track and has anyone had this experience that could =
help me as to where to look?
Any help would be appreciated.
Date: Wed, 25 Sep 1996 01:44:36 GMT
Subject: RE: PAINT CODES
Tony,
I believe the CDJ paint code is actually “Sebring Red”…
At least that’s what I was told when I went to get paint for a
respray…
Tom Walpole
Date: Tue, 24 Sep 1996 21:02:31 -0500
Subject: Automatic Transmission Problems '83 XJ6
Hi Guys,
I appear to have a problem with my transmission.
The car was sitting for a couple of weeks and now has a problem shifting =
up in gear.
I checked the fluid and added some fluid :).
That seemed to help at the lower speeds but the problem was still =
apparent at around 30 mph. I took it to the independant jag repairer =
who said he adjusted some things but it made no difference ( at no =
charge I may say).
I have since moved it to a transmission shop recommended by the jag shop =
and he reckons it is the clutch. Unfortunately we having been playing =
phone tag so I have not spoken to him personally.
Anyone have any thoughts or gotchas regarding this scenario. If this =
sounds like a likely cause, any ideas on cost, or should I be looking at =
replacement. I read some things in the past regarding the TH350 should =
this be considered at this point.
Appreciate your time as always.
Thanks, Gavin ('83 XJ6)
Date: Wed, 25 Sep 1996 12:09:01 +1000 (EST)
British Cat Components of Brisbane, Australia normally sell the square
headlamps, but are out of stock with some stock probably coming in late
November. However, they buy from England and suggest that is the best
source. They tell me that the square headlamp cars generally didn’t go to
the US, mainly to England and Australia. Also, the square headlamps are
very expensive at about A$450 each for used ones, whereas the round ones are
cheap. I don’t imagine that this helps much. Alan
Date: Tue, 24 Sep 1996 22:43:44 -0400 (EDT)
Any ideas about how to keep cats off the car when it is in the
garage?
Date: Tue, 24 Sep 96 21:03:08 -0500
Subject: First 5K-(1992 XJ40) and other stuff
Thank you all for your help and responses to my questions. I would also vote no on the usenet issue. I have only been here for a short time but the help and personal attention are outstanding. I feel that we would lose some of the personality of this group in the usenet setting.
The mud flaps have been installed on both the front and rear. What a difference they make. They have been on for the last 1K miles and I really like not having all the tar and bugs appended to the side of the car. The flaps take all the abuse. Now if I can only find an easy way to clean them…
The cell phone issue was decided when I was introduced to a product called a PROFIT. This device is a custom clamp, made for Jaguar cars, which is installed along side the center console it has a couple of bends in it so that the bolt holes and bolts are installed under the veneer of the console the PROFIT then protrudes out of the console and a “phone cup” is attached to it. The rest of the installation is straight forward from there. I choose this method since it spared the top of the console (for me to rest on) and provided me the option of replacing the console top when I finally decide on the cup holders.
An afternoon in the boot (truck) found all sort of interesting thingee’s. David Brown was very right, there on the same side as my gas filler tube there was a very nice DIN connection for my CD. The connector was about a third of the way down and in its own little plastic clamp. Once the tire was removed and the back panel removed it was very visible. My hunt for the perfect CD player is a separate post in and of itself. For now three down and still looking. I also found a tube running in parallel to another tube coming from the gas tank. one tube was connected to a fitting which then ran to the outside. The other tube was kinked and was directed into the boot. It was bent against the spare tire. I unkinked it as best I could and placed it along side the other tube in the connector leading to the outside. I’m not sure but it seems that this was some sort of gas tank vent. I was unable to locate any cellular connection sources in the rest of that area.
The car has been flawless for the first 5,000 miles I have driven it. I have now had it in for 7,500 recommended service with only two complaints. The light on the clock went out on when headlights were turned on. The console was torn apart and the bulbs replaced under warranty. The second item was an alignment of the windscreen spray nozzle velocity and direction. So far its great. I’m still working on the gas gauge problem.
Lou
Date: Tue, 24 Sep 96 21:15:23 -0500
Subject: RE: XJ40 audio upgrade
Hi Mike,
Hold on, I just have gone through a similar hunt and education. First off my XJ40, 1992 had a eight pin DIN connector in the trunk which allowed my radio to control the CD changer directly. Take a look in your trunk, I found the connector in the lower third of the back wall as you face the wall. I had to remove my spare tire and the back panel to locate this connector. As for the unit that YOU will like or will work for you. I have found a local audio shop who was willing to install their various demo units into the car as a trial. I was really surprised at the differences. (Brand names omitted at this time) Maybe you can find a shop willing to do the same for you. The frequency transmission method of control really was very inconsistent. Sometimes it worked and other times it would not react. Also the location of the transmitter became a nuisance. Just some thoughts. Let me know if I can provide you with any additional info.
Lou
From: Michael Powers/TEIR/Thomson Michael_Powers@teir.com
Sent: Friday, September 20, 1996 10:58 AM
To: jag-lovers jag-lovers@sn.no
Subject: XJ40 audio upgrade
Hello all:
This weekend, I plan on having a 10 CD changer installed in my 89 XJ6. It is
the type that
installs in the trunk and then, through an RF modulation unit, connects to the
antennae lead
on the radio.
Since my local audio shop (Best Buy) is having a free installation sale, I
figured I’d have them do it.
Any warnings or caveats that I should take heed to before having this done?
Thanks in advance,
Mike
| mpowers@teir.com
| (703) 736-1832
| On my block, a lot of people walk their dogs and I always see them
| walking along with their little poop bags. This, to me, is the lowest
| activity in human life. Following a dog with a little scooper. Waiting
| for him to go so you can walk down the street with it in your bag.
| If aliens are watching this through telescopes, they’re going to think
| the dogs are the leaders of the planet. If you see two life forms,
| one of them’s making a poop, the other one’s carrying it for him,
| who would you assume is in charge?
| -Jerry Seinfeld
Date: Sun, 22 Sep 1996 20:17:11 -0700
Subject: Noisy exhaust
I need some advice regarding a noisy exhaust system…
The exhaust in my 85 XJ-S makes a hissing type of noise that appears to be
coming from the exhaust pipe joints (just before the catalytic converters).
It becomes louder on acceleration, but it is noticeable at all times. I’ve
had this “fixed” a couple of times before (I was told that they re-coupled
the joints); however, this sems top be a recurring problem. Any tips or
suggestions as to how this could be fixed permanently? (at least so it
doesn’t hasppen every 10k miles or so?). Thanks,
Rob W-M
85 XJ-S
Date: Tue, 24 Sep 1996 23:25:20 -0400
to be too serious. “Probably might just need a new wiring harness”.He said that the interior is vinyl and that the wood is a ‘7’ on a
Jaguar quality”.Asking price is USD 2200.
IMHO, this is way too much for a car like this. for $2200, you could get a
MKX with good standard engine, decent interior and good body. And I doubt
that the Ford 5.0 has the low end torque of the 4.2 XK(correct me if I’m
wrong). Also, the wiring in this car is a nightmare, especially if the PO
has messed with it. I think MkXs are some of the more undervalued(and
under-respected) Jags around, pound for pound. However, I would think twice
about paying that kind of money for what you describe.
regards,
Braman
Date: Tue, 24 Sep 1996 18:00:48 -0005
Jim Isbell:
There were several
old voice interviews and I listened very carefully every time one of them spoke.The pronunciation I got from those interviews was Jag- u- wer. I think
Good theory. However, Sir William supposedly named the car line
after the animal – so perhaps we need to go back further yet, maybe
THEY got it wrong!
Of course, this could go back to the definition of a name. My wife
teaches Spanish, and she and I had a discussion about the habit of
Spanish teachers translating names: if your name is Joe, then in
Spanish your name is Jose. I’m sorry, but if my name is Joe, then in
Spanish my name is Joe – names don’t change. Similarly, if Sir
William pronounced it Jag-u-wer, then the name is Jag-u-wer,
regardless of what the puddy tat is called or what country you’re in.
– Kirbert | If anything is to be accomplished,
| some rules must be broken.
| - Palm’s Postulate
End of jag-lovers-digest V2 #377
Return-Path: @owner-jag-lovers-di1
Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4)
id for jag-lovers-digest-out; Wed, 25 Sep 1996 15:23:02 +0200 (MET DST)
Date: Wed, 25 Sep 1996 15:23:02 +0200 (MET DST)
Message-Id: 199609251323.PAA00243@ekeberg.sn.no
X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f
To: jag-lovers-digest@sn.no
Subject: jag-lovers-digest V2 #378
Reply-To: jag-lovers@sn.no
Errors-To: @owner-jag-lovers-di1
Precedence: bulk
X-Newsgroups: mail.jag-lovers-digest
jag-lovers-digest Wednesday, 25 September 1996 Volume 02 : Number 378
RE: Oil Weight
XJ6 Performance
Wife says it’s got to go !
Re: Engine Heaters
Re: Engine Heaters
61 E-Type flat floor outside bonnet lock.
Re: SIII V12 Engine surge
Re: RF Modulation CD Player units
Re: MK X Purchase
Re: Keeping cats off the cat.
RE: 61 E-Type flat floor outside bonnet
re: parts list
Wood Veneer Supplier
cats on the cat
SIII V12 status report
Re: 61 E-Type flat floor outside bonnet lock.
Date: Tue, 24 Sep 96 21:38:02 -0500
Subject: RE: Oil Weight
Scott,
Thanks for your reply. I think I am going to go to 10W40 in winter. Still haven’t decided. I have to drive 500 miles or more some cold winter days and the car would then be left out in the open, so I have both issues to consider. I will keep the group posted on information I get.
Lou
Sent: Saturday, September 21, 1996 7:42 AM
To: Lou Sabovic lsabovic@execpc.com
At 11:16 PM 9/11/96 -0500, you wrote:
Scott,
As a new Jag owner I have been looking for additional information on oil
used for the winter. Here in Wisconsin I have always changed from a 20W50 to
a 10W30 for winter. But 5W10 ? Do you do freeway driving with that weight oil ?
Lou, sorry for the delay in responding. Yes, I do limited, not hard freeway
driving. I must admit that with how whimpy the winters have been the last
couple of years I have been able to stay with 10W30
Scott Phillips
'88 XJ40
Minnetonka,mn,usa>
Date: Tue, 24 Sep 1996 22:33:47 PST
Subject: XJ6 Performance
I am interested in any advice / comments regarding tuning or
modifications for my wifes 1979 Series III XJ6.
I believe the car performs very nearly as it did when new and after
100,000+ mile I don’t expect too much but would like to improve
performance and mileage a bit.
Thanks all,
Kory Krofft
Date: Wed, 25 Sep 1996 01:30:41 -0400
Subject: Wife says it’s got to go !
My 1985 Jaguar XJS Must go.So say my wife (hater of Jaguars)
I dont Know what to ask so heres what I got:
79k miles on original motor just redid all gasketts valve covers
up,including fuel & vaccumm lines, New pirelli P5’s, new alpine cd, new
a/c compressor lines and conectors(needs condensor still to work) new
air pump (disconnected) new belts hoses, spark plugs(bosch plats.),new
bumper front,headlights,headlight bucketts & bezels. Car needs body work
in all usaul spots (rear pillars, quarters and trunk-hood)Car green
repaint, Ford motor color 8080 matches oddly well.Operation: front oil
seal leaks strange leak above rear pan seal??,runs well slight stumble
when hot, had to 160+ mph plus no problems. needs trans mount makes
noise in heavy turns. all else is well car is daily driven 30+ miles.
considering asking $4,500 and taking $4000 for it. I’ll miss it alot but
the drain on the wallet is to much for my pizza making job. Plus I got
another kid onthe way and need a fifth seat. Thanks, Frank Perrick
1985 XJS Green Ext., Grey int.
Date: Tue, 24 Sep 1996 21:58:46 -0800
Similarly, if Sir
Of all the postings I’ve seen on this subject, the line above makes the
most sense.
Date: Wed, 25 Sep 1996 16:12:06 +1000
garage?
This is going to sound a bit obvious but my advice would be to not to let
the cat into the garage in the first place…
Date: Wed, 25 Sep 1996 01:08:05 -0500
garage?
Let the dog sleep in the garage.
Date: Wed, 25 Sep 1996 06:15:41 GMT
Subject: 61 E-Type flat floor outside bonnet lock.
Jag Lovers,
Thought I’d open up a can of worms this morning. I have been looking for an E-Type for a
short while and have mostly looked in the 4.2L Coupe area because of available money and it
seems it would be the better tourer. However last night I talked with a gentleman who has
a 1961 3.8 Roadster outside bonnet lock car that has been partially restored. Since there
were so few of these made I am hard pressed to pass it up. However, I have a few questions
for the group to see how popular opinion runs. They are:
The original color of the car was red, but it has been painted a Silver blue and the top
switched for a Dark Blue one. While this makes for a pretty car in my opinion. I was
wondering if it was a negative that it wasn’t original. Some people that I talk to say that
the original color is only important if the car has the original paint or possibly in
Concourse competition. Others say that you should always paint a car the original color. So
what does the group think. Is the fact that a car is painted in other then the original
color a negative. -
Since this is an early 61 car it has the welded louvers. Or atleast it should. It
appears that somewhere along the line the center section of the bonnet was replaced with one
which had the pressed louvers in it. It has been suggested that these could be cut out, put
a frame around them and then weld them back to have the look of the original. What’s the
opinion of the group. Is it worth the work to do this? I know that painting would be
required but then if I was going back to the original color I would be painting anyway. -
Now for the age old question. 3.8 vs 4.2. Being 6Ft I’m a little concerned about all that
is written about the flat floor cars not being big enough for ‘tall’ drivers. Having only
ever been in 4.2 cars and not having a flat floor 3.8 handy I can’t speak from experience.
So for those who have the flat floor cars. Is there really that much less room? Or is this
just a point that car critics jumped on when the cars were new but now make them that much
more special.
By the way the car would certainly not be a daily driver but I do plan on driving it often
and hopefully far as we spend some time touring Europe after it’s back on the road and
running. I know this is rather long and I’m sorry to overload the system but am curious what
this group has to say.
Thanks to all and I’ll await your advice and opinions.
Craig Hastings
88 VDP
E-Type (soon, I hope)
Date: 25 Sep 96 02:47:24 EDT
Hi Julian and List
I find this a terribly good idea, if it is technically possible,
and if it can be somehow automatically maintained,
in order to not load Nick.
We had such a facility at my previous work, we called it the
electronic pinboard. It had several grougp such as to distinguish
between them. Messages would appear time ordered and automatically
perish after 1 month.
It would also offload the list a bit, however I dont find the occasional “for
sale”
adverts disturbing.
Regards Jeff
Date: 25 Sep 96 02:47:22 EDT
Hi
Swap meet list day is also an alternative, however I’m
constantly up against my Compuserve limit of a 100 messages
at anyone time. And that is all from the Jag-list…
Well what about a separate list… Oopus , sorry chaps…
Jeffrey Gram
Date: 25 Sep 96 02:47:18 EDT
Subject: Re: SIII V12 Engine surge
Hi John,
First problem eh ?
What you were told is not correct. V12 shall not surge - ever.
The fuel cut out is a economic and emmissions
feature which cuts out fuel when the throttle is released
completedly and the revs are above 1500 I think it was, i.e when cruising.
This circuit is thus not active at idle also not cold - or rather should not be.
If your V12 idles above 1500 theres is also something else wrong.
V12 cold idle should be about 1000 RPM.
Get back to that dealer and give him a hard time.
Regards Jeffrey Gram
Date: 25 Sep 96 02:47:16 EDT
Subject: Re: RF Modulation CD Player units
I see this subject of add-on CD changers is coming up again.
While it is possible to get it to play this really is a half-hearted solution.
Considerin\g the amount of work will be equally great compared to a
whole-hearted solution - a new radio which is built to accept the CD directly,
To this comes that there must be made room for an extra display and control
panel to the CD - Ugly and wher would you fit it ?
Alpine is not the only radio that is useful for Jags.
Depending on taste, and in my case also the astetic appearance and the
quality of the radio unit, there are for example also the BECKER radio’s from
Germany.
High quality, and operable with ease. Best radio in 1996 in Germany. The
display is
simple and functional, whith is quite a difference from the Alpine
Razor-sharp super hightech "multifunction " displays with
LCD displays of how the facder and balance is adjusted - utterly
useless crap to put in radio’s. You are supposed to use your Ears
not your eyes - Eyes should be at the road.
Alpine is not the only one with all these useless features.
Other good and well designed Rasios are the GRUNDIG radio Also from
Germany. I happen to live in Germany at the moment, and while the market
is flooded with masses of Car-hi-fi, the Germant built continues to be
the leader on this partical field, at least to my taste.
BECKER is expensive. 750 - 1000 US$ for the top models, add 750 for the CD
changer. The Alpine however gets up there as well.
Oh well just my opinion.
Regs Jeff. Jaguars and divine Audio, can nirvane come closer ?
Date: 25 Sep 96 02:47:19 EDT
John,
A MK 10 is a beaitiful big beast, but do you really want such a
Frankenstein where some “smart” bogder has given it another heart ?
and a different make also - pfui, Concentrated disgrace.
Engine bay fire - not a good starter.
But sure - fine car when restored to original specification. If so sell
that lump engine to a hot-rodder.
Date: Wed, 25 Sep 1996 10:07:10 -0700
Subject: Re: Keeping cats off the cat.
Thomas Alberts asked:
garage?
As a matter of fact, yes! Before I moved into an area with a (large) number of
cats, I would probably recommend purchasing a car cover from me. After having
used one through the summer though, I’ve seen what the cats’ claws can do to
fabric normally considered tough and durable.
PEPPER! Yes, pepper is the thing. Cats hate it =( For a garage I’d suggest some
.250Kg spread out on the garage floor around the car, perhaps with a higher
concentration around the area where the cats enter the garage.
A combination of the above measures should be absolutely ideal, as cars in
garages often collect masses of dust, and with changing temperatures and
humidity the paintwork will suffer. When my car is prepared; cleaned and waxed,
it stays perfectly clean under the cover. When I take it out, I do so with a big
smile around my face behind the wheel of a beautiful classic car that looks like
it just left the shop
Aaaatchooooo!
Bard
______ _ ! Baard Th Hesvik, Telesoft AS
/ _ / _ _ _ / / ! Longhammarvn 7, N-5500 Haugesund
/ // / // /_ / / -/- -/- ! T: +47 52735000 F: +47 52717040
/ /_ / /_ / // / /_ ! E-mail: baard@telesoft.no
Date: Wed, 25 Sep 1996 10:27:50 -0700
Hi again,
Hmm… I wonder if the design of the alluminium wheels, the “pepperpots” has
something to do with this? :-\ It seems that the cats prefer to make their
entrance on the corners of the vehicle :-/ I havn’t seen a pepper reservoir to
fit inside the wheels advertised anywhere, though…
Just a thought.
Bard
Date: Wed, 25 Sep 1996 11:06 +0200
Subject: RE: 61 E-Type flat floor outside bonnet
- The original color of the car was red, but it has been painted a=20
Silver
blue and the top
opinion. I was
wondering if it was a negative that it wasn’t original. Some people that=20=
I
talk to say that
possibly in
original color. So
what does the group think. Is the fact that a car is painted in other=20
then
the original
color a negative.
If such a car is restored to “concours” condition it definitely is a minus,=20=
price wise. If restored to a condition to be enjoyed on the road, what the=20
h**l do you care?
- Since this is an early 61 car it has the welded louvers. Or atleast=20
it
should. It
replaced with one
which had the pressed louvers in it. It has been suggested that these=20
could
be cut out, put
a frame around them and then weld them back to have the look of the=20
original.
What’s the
opinion of the group. Is it worth the work to do this? I know that=20
painting
would be
painting anyway.
Only worth it if done exactly as the original and only for a concours car.
- Now for the age old question. 3.8 vs 4.2. Being 6Ft I’m a little
is written about the flat floor cars not being big enough for ‘tall’=20
drivers.
Having only
from experience.
room? Or is this
just a point that car critics jumped on when the cars were new but now=20
make
them that much
more special.
The hollowed out floor doesn’t help much with leg space as the throttle foot=20=
still has the heel on the higher part of the floor. On the other hand the=20
later cars have a hollowed out rear bulkhead which makes it possible to=20
adjust the seat a couple of inches further backwards. If you are 6 feet tall=20=
you will not be very comfortable driving this car.
Frans.
driving it often
and hopefully far as we spend some time touring Europe after it’s back on=20=
the
road and
running. I know this is rather long and I’m sorry to overload the system=20=
but
am curious what
this group has to say.Thanks to all and I’ll await your advice and opinions.
Craig Hastings
88 VDP
E-Type (soon, I hope)=20
Date: Wed, 25 Sep 1996 09:17:13 GMT
Subject: re: parts list
Jag Lovers,
Well I guess I might as well put my 2 cents worth in on the parts list issue. I personally
like the idea but think it could be a headache to manage and would hate to see it pushed off
on Nick who seems to work very hard providing us what we have already. Nick we do appreciate
you even if you don’t here it often. SO with that said how would something like this:
A data base which is available for search through e-mail. This means that if you required a
part or parts you would send an e-mail to an address which was in a pre-determined format and
a response would be returned to you via e-mail. This format would be something like:
want=headlight year=61 model=e-type
the system would then notify you of the contact information for any parts that meet your
request. You could also through e-mail add parts that you have available.
I have an application that I think I can modify to be usable as a parts data base. I will
have to check on availability of a server but I have a line on that. If this is something
that some would be interested in, I wouldn’t mind digging into it since this is what I do
when I can’t drive my Jaguar. So, is this something we could use?
Craig Hastings
88 VDP
E-Type (someday soon I hope)
P.S. Please excuse my spelling. I’m a programmer not an English major as I’m sure you can
tell.
Date: Tue, 24 Sep 1996 19:28:24 GMT
In message 9609241253.AA18744@filon.filon.ml.com brownd@filon.ml.com (Dave Brown - London Dev X1818) writes:
the engine
told [snip] that this is actually quite normal
for these cars
[snip]
Any comments??
Horsesh*t. The V12 should idle MUCH lower than this (=<900rpm) at all
times. Idle mixture adjustment and fuel pressure would be the first
two things I’d check.
Stefan Schulz
Date: 25 Sep 96 06:38:52 EDT
Subject: Wood Veneer Supplier
I am about to order wood veneers for the ski-slope and radio surround on my
1985 Series III Sovereign V-12. I talked to Autostyle of Rochester, Kent, U.K.,
who advertise in Jaguar Enthusiast magazine and was wondering if anyone has any
experience of this company. Do they do good work? Does the veneer match
properly? Does anyone have any other company to recommend, preferably in the
U.K.? Thanks in advance, and happy motoring!
Date: Wed, 25 Sep 1996 12:53:49 PDT
Subject: cats on the cat
garage?
I’ve always parked our most important car in the garage. The trouble
is, this is also where the cat has his food and where the washing
machine is. The result is that the bonnet is used as both a cat-bed
and a resting ledge for washing baskets full of laundry. Previous
experience told me that over time the bonnet ended up with many
tiny scratches on it.
When I got my Jaguar (Jim Isbell - slight different in accent — Ja - gu
- wer) I insisted that these practices stop. Well, that didn’t get very
far. So I use some old, and very heavy, curtains as a bonnet cover.
So far, no scratches.
Cheers,
Dave Wood.
From: brownd@filon.ml.com (Dave Brown - London Dev X1818)
Date: Wed, 25 Sep 96 13:45:47 BST
Subject: SIII V12 status report
Hi all,
Sorry to bore the list with my witterings about my new purchase but I’M JUST SO
EXCITED!!!
I had the car professionally inspected and it received a favourable report.
The only two things of “major” (and this is relative) note were:
- Cracked aluminium rear hub housing;
- Oil leak from front crankshaft oil seal.
There were one or two minor points which are really service items that can be
taken care of at it’s next service.
The cracked housing is, apparently, a common problem, particularly on cars
fitted with the housing that can accomodate the ABS sensor. Although it is not
likely to completely collapse under normal use, and would probably outlast the
car) if the wheel was to take a heavy knock (such as hitting a kerb hard, etc)
there is a chance it may completely break causing the wheel to “collapse”.
As to the oil leak - well, it IS a Jaguar!
I’m fairly sure the garage I’m purchasing the car from will replace the housing
and we’ll see about the oil leak.
As to driving it…
Two things of immediate note: The smoothness and the quiet. Oh, and the power.
And the refinement. And the comfort. And the…
I did make a post yesterday about engine surging on cold start but I think our
mail system has been a bit funny. Does anyone have any experience of this on
their fuel injected engines ? I was told (not by the seller) that it’s quite
normal and due to the ignition cutting out at zero throttle and 1500 revs (which
is meant to happen) and the revs rising to 1500 due to the “cold start” help.
Any comments?
Thanks for your time and help,
P.S. I still have my 250 V8 Dailer for sale if anyone is interested.
David Brown,
'88 SIII Sovereign
'67 Daimler 250 V8 (for the time being!)
brownd@ml.com
///_/_/_/_/////_///______
/_/_//_/_/_/_/_/____
/_/_/_/_/______/_/_/_/______
/_/_/_/_/_/_/________/_/_____
___/_/_/////_/_/_/_/_/______
/_/___/_/_//_/_/_/____
///_/_/_/____/////_///_________
Date: Wed, 25 Sep 96 09:18:28 EST
Subject: Re: 61 E-Type flat floor outside bonnet lock.
Craig -
Here my opinions - take them as you will.
1. Originality is only as important as you think it is. Me,
I like to drive my cars, and having them up an running is what
really counts. Of course, if you intend to do concourse with
the car - then originality is pretty important. You gotta
make up your own mind how much it means to you.
2. If the car is pretty, I don't care that's its not the
original color. I'm a little bored with red E's - almost
every one I see is red - the blue sounds great.
3. Spend time and money to put back the original louvers? No
way - you must be kidding.
4. I have never owned an E - but have driven several different
ones quite a bit. Frankly, both the 4.2 and the 3.8 seem a
little cramped to me. I'm 6'1".
Good luck - let us know what you decide to do.
- mclaus ('93 XJ-S)
Author: hastings@frodo.eucom.mil (Craig R. Hastings) at WG-RAL-SMTP
Date: 9/25/96 3:42 AM
Jag Lovers,
E-Type for a
money and it
gentleman who has
Since there
few questions
and the top
I was
to say that
possibly in
original color. So
original
color a negative. -
should. It
replaced with one
which had the pressed in it. It has been suggested that these could be cut out,
put
What’s the
would be
anyway. -
about all that
Having only
experience.
Or is this
that much
more special.
driving it often
road and
curious what
Craig Hastings
88 VDP
End of jag-lovers-digest V2 #378
id for jag-lovers-digest-out; Wed, 25 Sep 1996 23:51:47 +0200 (MET DST)
Date: Wed, 25 Sep 1996 23:51:47 +0200 (MET DST)
Message-Id: 199609252151.XAA09023@ekeberg.sn.no
Subject: jag-lovers-digest V2 #379
Precedence: bulk
jag-lovers-digest Wednesday, 25 September 1996 Volume 02 : Number 379
Re: Wife says it’s got to go !
Re: Original color/paint in concours.
Horn problem
XJ-S Seat Mounts
Re: 1990 XJ-S Auto Coupe (Also XJ40 Majestic info)
s111 for sale
Testing Catalytic Converters
Re: Vehicle Dynamics (Was XJ Rear Suspension Behavior) [Very Long]
Reply to $4000 XJS & Wife for sale
Re: Engine Heaters/cats
Re:Cats on cats
[No Jag content] Names and places
film star? - tiny bit of jag content
jag-lovers-digest V2 #352
Re: swap meet postings - Suggestion
Date: Wed, 25 Sep 1996 13:27:44 GMT
Subject: Re: Wife says it’s got to go !
Keep the cat, sell the wife!
Glue Man
glueman@collano.ch (former address: gleuma@dial.eunet.ch)
Date: 25 Sep 96 9:52:11
My thoughts on this matter:
Unfortunately, my XJ6 had the standard issue Jag radio/cassette deck.
It is the type that can pick up CB channel 19 (basically useless). Anyway, the
radio itself does a reasonably good job, so I figured why bother investing
the money in a whole new stereo. Afterall, some of us are saving for
2 square headlamps
But I ended up purchasing the JVC 12 CD changer/RF Modulator Unit.
It is a little more compact than the Sony, and IMHO, does as good
a job with skip protection as the Pioneer. Installation was relatively easy,
and
so far, it works like a charm. No adverse affects on radio reception, or any
other
electrical components. The control unit itself looks somewhat out of place on
the
console, but not horribly so.
I only have 2 complaints about the unit: The control unit buttons don’t light
up, which
is a pain at night. Also, it doesn’t have a Fast Forward through a specific
track (like the Sony). It only increments
one song at a time.
-Mike
89 XJ6101454.2570 @ CompuServe.COM (Jeffrey Gram)
09/25/96 02:47 AM
To: jag-lovers @ sn.no @ Internet
cc:
Germany.
display is
Date: Wed, 25 Sep 1996 16:03:43 -0700
Subject: Re: Original color/paint in concours.
Craig,
I have one comment to your posting (I shan’t get into the issue of originality
this time).
If you consider entering the car in a concours competition it is of some
importance that the car has the original paint. However, the color is more
important, although it doesn’t have to be the original color, it should have the
right period color, for the year or at least for the series. As far as I know,
Series I E-types didn’t come in light blue metallic, whereas the series II did.
Apart from that, I second Mike’s opinion that you decide what you want to the
with car.
Bard
Date: Wed, 25 Sep 1996 10:46:26, -0500
Subject: Horn problem
TO: Jim Campbell
There should be a (purple I think) wire that is connected to the horn
press button, then on to the horn relay. From the sound of it I would
guess that this wire is shorted in the steering column.
Date: Wed, 25 Sep 96 09:31:00 PDT
Subject: XJ-S Seat Mounts
Yesterday I decided to finally adjust my emergency brake so it would
actually do something. In doing this I also decided to remove the drivers
seat to clean out any debris that was down there I could nor reach by hand &
between the seat & center console. My chrome holder for the seat belt had
also fallen off. After doing all this it was time to replace the drivers
seat. Now I have an problem. 3 of the 4 so called nuts that the drivers
seat mounts to are not connected. These are basically rectangular pieces of
metal with threading in them that are attached by glue(if at all) to the
under side of some sheet metal. The rear right mount can only move a little
under the metal, so I can still screw into it. Both of the front ones came
off. There is no room to try and use a wrench to hold then them place and
plenty of room for the nuts to move WAY out the way, then you need a
magnetic screwdriver or something to retrieve them.( oh yea, also remove the
carpeting around it so you can get them out also ) What a piss poor design,
if I do say so. ( and I do ) Well, by using a finger and the screws, I got
the nuts held in place & added a little glue to hold them in place. It was
getting late, dark & the glue was not set, so off to work this morning in my
reliable, clunker, eye sore 72 convertible Mustang that still has the
studded snow tires from 4 years ago. ( normally my bad weather car ). I
really miss the smooth quite ride of my XJ-S. At least I will get it back
together tonight.
John Himes
88 XJ-S 97K Miles
Also, this is the first car I have noticed that the seat belts are connected
to the seat, not the chassis. ( and the seat is held in place by 4 torx
screws attached to plain sheet metal. Hummm… )
Date: Wed, 25 Sep 1996 16:56:28 +0000 (GMT)
Subject: Re: 1990 XJ-S Auto Coupe (Also XJ40 Majestic info)
Derek,
I have a 1990 XJS spec brochure in the office today, what info
would you like?
3.6 coupe 0-60 7.4s (man) 8.4s (auto)
3.6 coupe top speed 142 (man) 140 (auto)
fuel consumption (UK gallons)
urb 56mph 75mph
manual 18.6 37.1 32.0
auto 18.2 36.4 30.6
5.3 V12 0-60 7.7s
5.3 V12 top speed 150mph
urb 56mph 75mph
15.2 26.7 22.4
Hope some of the above is of use...
Unfortunately, the XJ40 majestic brochure only has the usual
dimensions etc. NO speed ratings or definitive option spec. As
far as
I can see, the XJ40 majestic was very much made to order so
specification sheets are unlikely to have been printed.
Donald.McGregor@snl.co.uk
Date: Wed, 25 Sep 96 17:22:52 BST
Thanks for replies stating that this should not happen.
However, one point I’m still not clear on: does this just mean that the problem
is really the car is idling too high on a cold start therfore the ignition
cutout is coming into play as a result of this, or is it that the ignition
cutout is coming into play when it shouldn’t irrespective of what RPM the car
idles at?
(I hope this makes sense as a question!)
TIA,
David Brown,
brownd@ml.com
Date: Wed, 25 Sep 1996 16:20:30 +0000 (GMT)
Subject: s111 for sale
i am not sure if this is against protocol for this list . i am sure that i will
find out in a hurry if it is so. anyway , a friend of mine who is a lawyer has
a series 3 e-type for sale as part of an estate settlement, it is a 1974
convertible with both soft and hard tops, manual transmission [very rare in the
u.s.], has only 23,000 miles on te clock, two owners from new. i haven’t seen
the car personally but i understand that it has been stored the last few years
and may need a repaint job. if anyone is interested send me an e-mail at
cooper_robin_D@lilly.com and i will give you his phone number. it is located
in the indianapolis area of the u.s.
cheers, robin cooper
Date: Wed, 25 Sep 1996 09:33:35 -0700
Subject: Testing Catalytic Converters
I have an '85 XJ-S and would like to test the catalytic converters to
ensure that each is not constricted in any way. Anyone know of a good
way to do this? I have removed the converters that bolt directly to the
exhaust manifolds and inspected the honeycombs --all looked intact with
no blockage or “meltdown”.
All help is appreciated.
Aaron
'85 XJ-S
Date: Wed, 25 Sep 96 12:43:33 EDT
Subject: Re: Vehicle Dynamics (Was XJ Rear Suspension Behavior) [Very Long]
What you are talking about is roll steer. This one third of the
phenomenon known as “understeer” or “oversteer”. The other two thirds
of under/oversteer are compliance steer and tire grip (adhesion).
According to the book “New Directions in Suspension Design”, the
target with a racing suspension is to have the roll influence the
camber such that the outside wheels are near vertical at ultimate grip.
This usually implies that there is substantial camber in the no-roll
condition. The effect of this on steering power is substantial, and not
directly related to the steering effects that Jan mentioned. The steering
effects, which are toe related, are almost negligible by comparison
to proper contact-patch orientation. Steering effects, desireable or not,
can be compensated for easily (by adjusting the steering wheel during the
turn), while the camber effects must be dealt with by adjusting spring
and swaybar stiffness, and suspension arm geometry so that at ultimate
grip, you get just the right amount of roll to put the camber where you
want it. The little toe-in, toe-out and caster adjustments (such as from
Ackermann or anti-Ackermann geometry) are effected primarily in the
interest of stability under transient conditions.
John R. Lupien
lupienj@wal.hp.com
Date: Wed, 25 Sep 1996 12:57:10 -0400
Subject: Reply to $4000 XJS & Wife for sale
I guess I will keep the wife contrary to all the e-mails to sell her and
keep the car. The local car lot said Jags trade in for $800 to $1000
depending on condition ,They trade higher if they have a chevy
conversion !! I shot him and left in tears. I guess I will formally sell
the car at $4500 but it will have a Jaguar radio instead of the alpine.
Taking offers if it’s not worth that. I have owners manual but little
other documentation because I did all the work. This is no dream car and
needs body work and wood work. I do honestly drive it every day and it’s
never let me down. (yes i’m knocking on wood)
Call me at 407-574-6758 or if no answer call me at work 904-738-1500
(Domino’s Pizza ) This car is located in Deltona, Florida 30 miles north
of orlando off Interstate 4, will trade for Volvo or Benz 84 to 87 ish,
need 5 seats and a/c. Car is not paid off but dealer holds title and can
have quickly. Thanks for all the E-mail, I posted this instead of
replying all. This price is fair to me and won’t make me feel
responsible for the cars shape.
Frank Perrick
1985 XJS
Date: Wed, 25 Sep 1996 13:17:41 -0005
Just a side note: Have you guys noticed that portable CD players are
now available for under $200 that come with 10-second buffers and a
kit to connect to a car stereo? Just plug in, set on the seat,
console, floor or in the glovebox. Plus, take the player WITH YOU to
another car or to the beach or whatever. Sure, it won’t play 10
CD’s, but you don’t have to stop at the gas station to change them
either.
| - Palm’s Postulate
Date: Wed, 25 Sep 1996 09:52:50 -0900
Subject: Re: Engine Heaters/cats
Perhaps it’s in the realm of urban legend, but something I always think
about before turning the key is the observation an owner had about cats and
E-Types…he said that in his neighborhood when he parked outside, the warm
radiator attracted cats looking for a warm place to nap. The lack of a
grille on the E, and its proximity to the street makes entry a snap.
Unfortunately there is the problem of the fan…a nasty experience for all
concerned he said…
Bill Spear bill@wmspear.com
227 7th Street. Juneau, Alaska 99801
907/586-2209 v 907/586-6858 f
Live every day as it were your last, for one day you are sure to be right.
Lieutenant Harry “Breaker” Morant
Talismen, amulets and charms for an uncertain world.
http://www.carmelnet.com/spearpins
Date: Wed, 25 Sep 1996 14:52:46 -0400
Craig,
I’m sure you’ll get tons of opinions on your interesting post,
and here comes my 2 cents (CDN-prob. $15. US) worth.
First of all, don’t even buy the thing, they’re terrible cars,
instead, send it directly to me! You have no idea how much this
approach will save you in dollars :>)
You didn’t mention cost so I assume price is no object (in which
case you should really look at my E!
My car is also not the original color and since I don’t like the original
colour anyway, I wouldn’t dream of reversing that.
Absolutely if you’re really that interested in Concours d’elegance then you
might consider it, but what about those bonnet louvers? To cut and paste
louvers would hardly be/look original.
A purist (none on this list :), would wrinkle their bonnets at the lact of
originality, but I don’t expect that their…ah…arousal…would be much
diminished!
The question of leg room viz a viz your height is the easiest
to answer -jump in! Go for a drive! Does it fit comfortably?
Then go park somewhere with someone special…naw, forget it,
that part won’t fit!
I’d say go for it, it’s only (your) money!
Good luck!
At 06:15 AM 25/09/96 GMT, you wrote:
Jag Lovers,
for an E-Type
Charles Daly, Toronto, Canada
'62 E-Type, ots
Date: Wed, 25 Sep 1996 14:58:45 -0400
Glue Man
A true jag man.
Amen.
'62 E-Type, ots
Date: Wed, 25 Sep 1996 15:03:32 -0400 (EDT)
Subject: Re:Cats on cats
garage?This is going to sound a bit obvious but my advice would be to not to let
Clearly not written by an owner of a four-legged type cat. Anyone who has
ever owned a cat would tell you that it is the cat’s choice whether or not
people can use the garage.
Mike Frank
1969 E-Type 2+2
1991 Fat Black Cat
Date: Wed, 25 Sep 1996 22:23:39 +0200 (MET DST)
Subject: [No Jag content] Names and places
I just wish everybody would feel that way. IMHO it’s M�nchen not Munich,
Venezia not Venice, Milano not Milan, Firenze not Florence and so on.
Gunnar
Gunnar Helliesen | Bergen IT Consult AS | NetBSD/VAX on a uVAX II
Systems Consultant | Bergen, Norway | '86 Jaguar XJ6 4.2 Sovereign
gunnar@bitcon.no | http://www.bitcon.no/ | Vicki who? What .sig virus?
Date: Wed, 25 Sep 1996 17:00:49 -0400
Subject: film star? - tiny bit of jag content
Hi gang,
Only a week before the launch of the new baby.
Its all excitement here, there has been loads of film crews all over the
place, mainly in the area that I work, (known as the loop or stuff-up) So if
you watch the TV and you see the factory, look out for me, I fit
engines/propshafts and exhaust near the stuff up. I’m the one wearing glasses
LOL
I would love you to see me, please let me know if you did
Terry
Date: Wed, 25 Sep 1996 14:07 -0700 (PDT)
Subject: jag-lovers-digest V2 #352
Frank,
I also live in the San Francisco area and own a Mark II. Jim griffin
upgraded my Mark II to rack and pinion steering, you can probably
get the details from him. Let me know if you are interested in his
number.
Rolando Mark II '62
Date: Wed, 25 Sep 1996 23:47:10 +0200 (MET DST)
Subject: Re: swap meet postings - Suggestion
Folks,
I’ve discussed this a bit with Nick and we have come up with the following:
I’ve already installed and configured a Web based conferencing (or
bulletin board) system called HyperNews on our Web server. It would be
relatively easy to add a new conference. To see how this looks and works
please check out the similar conference I made for Ford enthusiasts at:
http://www.bitcon.no/HyperNews/get/customline.html
I would of course make a completely separate conference for the Jaguar
“swap meet” application. The system is very configurable, besides the
general design and layout we have the following options:
- Conference can be open to everybody (like the current Ford conference)
- Only people with valid usernames and passwords can access the
conference (with usernames and passwords provided by me)
I would administer the conference (thus relieving Nick). Nick could add a
link from the JagWeb web page in case we wanted to make this forum
“public”.
So, what do you all think? Take a look at the existing Ford conference
and let me know if this could be of value to the Jag Lovers group.
If many of you are in favor I could have it up and running this weekend.
Gunnar
End of jag-lovers-digest V2 #379
id for jag-lovers-digest-out; Thu, 26 Sep 1996 11:57:29 +0200 (MET DST)
Date: Thu, 26 Sep 1996 11:57:29 +0200 (MET DST)
Message-Id: 199609260957.LAA11915@ekeberg.sn.no
Subject: jag-lovers-digest V2 #380
Precedence: bulk
Status: O
X-Status:
jag-lovers-digest Thursday, 26 September 1996 Volume 02 : Number 380
Re: 85 XJ6 Horn Won’t Quit
83 XJ6 S3 – BW Auto Transmission Band Adjustment
Re: steering wheel wobble (at certain times)
Re: film star? - tiny bit of jag content
re: [Even less Jag content] Names and places
XJ40 Stumble (long)
Re: Engine Heaters
re: jaguar part yards
re: Craig Hasting’s re: parts list
Re: [Even less Jag content] Names and places
Ignition Amplifier
Re: [No Jag content] Names and places
Re: XJ-S Seat Mounts
Re: Ignition Amplifier
Introduction (induction?) and E-type saga!
Date: 25 Sep 96 14:23:24 EDT
Subject: Re: 85 XJ6 Horn Won’t Quit
The horn works by closing the ground circuit on a center contact on a plactic
“nut” with a brass-rod which fits down
the centernut. Sometimes this “rod” will cause a shortcircuit somewhere
down the steering coloumn. Maybe it is also just the lug on the centerpiece
activating the horn when it shouldn’t.
To get the centerpiece off there are two screws from the rear as far as I
remember.
I had this problem some years ago, I fiddled a bit fit everything, maybe
insulated part of the rod -
can’t remember exactly. This was my XJ6 SII.
Date: Wed, 25 Sep 1996 17:54:59 -0500
Subject: 83 XJ6 S3 – BW Auto Transmission Band Adjustment
How do I know if this needs to be done? My transmission seems fine, but =
I have no other Jag to compare it to. In fact, my car makes me wonder =
what all the BW 66 slushbox talk is about. Mine shifts firmly =
(distinctly?) under acceleration, and since I replaced the transmission =
mount, there is no shaking.=20
Date: Tue, 24 Sep 1996 19:25:13 GMT
Subject: Re: steering wheel wobble (at certain times)
In message 3247CE7F.2946@netsrq.com ata@netsrq.com writes:
I have an '83XJS that has a steering wobble (left to right vibration)
only when accelerating, or braking through a zone of 20-30 MPH.
One or both front tyres unbalanced ? Worn out shocks ? Both ?
the tires that are on the car now are smaller than normal, because they
came with the alloy wheels. Could undersized tires cause this problem?
P195-60/R15
I’m not an expert on '83s, have an '88 myself. Sounds like the tyres ARE too
small, though. 215/70R15 or 235/60R15 is what the manual says for mine.
Check with a Jag dealer.
Stefan Schulz
Date: Wed, 25 Sep 1996 20:17:19 -0400
Gunnar,
So, you’re more than just a pretty face!
Excellent site you’ve built (Ford) and I support
this idea, 100 %.
Good job!
'62 E-Type, ots
Date: Wed, 25 Sep 1996 20:19:43 -0400
Subject: Re: film star? - tiny bit of jag content
Re: from Terry;
Terry
I
guess ham is better than spam!
Good luck on the launch!
'62 E-Type, ots
Date: Thu, 26 Sep 96 10:29:22 +60000
Subject: re: [Even less Jag content] Names and places
This argument is okay for Indo-European languages but breaks right down in
Asia. Bangkok’s real name has over 100 letters, and I guess if we are to be
pedantic, shouldn’t even be expressed in anything but the Thai character set.
Many Chinese people from Hong Kong and Singapore are appointed both English
and Chinese names in recognition of potential difficulties - efforts to
pronounce the Chinese name can be akin to pronouncing Muenchen as “Munchin’”'.
Moreover English speakers generally cannot pronounce the ‘chen’ as ‘hee-yen’
so it doesn’t sound too good in German anyway (as my German girlfriend
incessantly reminds me).
Time to scurry into my hole
Tchuess
Peter
PS Note words such as ‘weekend’, ‘boss’ and ‘computer’ are replacing their
native equivalents…
Gunnar Helliesen gunnar@bitcon.no Wrote:
| name. My wife=20
| the habit of=20
| then in=20
| Joe, then in=20
| M=FCnchen not Munich=
| ,=20
| and so on.
| Gunnar
| a uVAX II
| XJ6 4.2 Sovereign
| What .sig virus?
Date: Wed, 25 Sep 1996 20:50:32 -0400 (EDT)
Check the wheels for runnout: a wheel can be dynamically balanced, even
if there is some side-to-side wobble.
Mike Frank
1969 E-Type
Date: Wed, 25 Sep 1996 19:03:59 -0700
Subject: XJ40 Stumble (long)
Hi all,
I have an 87 1/2 XJ40 Sovereign (Canadian Version). I have been reading the mail for the past two weeks, and thought I’d try and see if anyone has had this problem.
First on the issue of Sovereign – mine says Sovereign in two places only: the vehicle registration, and in hand writing (felt tipped marker, I think) under the passenger side dash liner! No badge on the back, except XJ6. Car has Pepperpots, Four round headlights, leather, cruise, air, sunroof.
The main problem is that it has a erratic idle, and an more-than-occasional miss at speed. It seems to be affected more on windy and/or rainy days! It always starts when cold, but then it will idle from 500 to 1200 rpm, up and down. After 30 seconds or so, it settles down to about 700-800, but it still “stumbles” – almost sounds like it’s going to stall, but it doesn’t. It accelerates well, but it will miss when I back off the accelerator. Occasionally it will surge – rpm will increase by 500 or so. Then it cuts back just as quick. No problem with hot starts, no overheating (according to temp gauge), no engine error codes.
I have replaced the O2 sensor, Idle speed control valve and Coolant sensor, plus spark plugs, and spark plug leads. Cap and rotor are in good condition. I suspected the air mass sensor, and I also suspect that it has been played with by the PO. The manuals say that there is no adjustment, but on one end is a hole with an allen head screw accessable. I have another allen head screw accessable on the intake manifold next to the Idle Speed Control Valve. I suspect that they were capped originally, and that the PO removed the caps. I also have a short piece of vacuum hose cappped with a screw – it’s located right next to the hose that goes to the fuel pressure regulator. All other vacuum hoses appear in good condition.
Any ideas? Also – if anyone has the voltage settings for the Air Mass Sensor it would be appreciated. Playing with the allen screw (my other hobby is computers – big surprise – see a screw, turn it!) I noticed that the voltage on the far right terminal goes up or down, whilst the third terminal from the left varies with the air flow. I don’t know what the voltages should be. I do know that the 1k ohm variable resistor in the air mass sensor was set all the way to 1k ohm – something I thought strange.
Once last thing – the dealer said that he couldn’t diagnose it without a “Check Engine” error code. I don’t get any error on the VCM, (my manual says the error should be “Fueling Failure”), even when I disconnect items like the air mass sensor or the coolant sensor. Faulty computer, or PO disguising fault, perhaps? All the other VCM stuff works, like door open, ABS failure, etc.
Thanks in advance for any help,
Mike Everatt
Kamloops, BC, CANADA
1987 1/2 XJ40 “The Experimental Years”
Date: Wed, 25 Sep 1996 22:51:07 -0400 (EDT)
How about a Model T spark coil?
John
garage?
From: “Peter Rebbechi (03) 9275 3374” <"REBBECHI PETER"@A1.MEOC02.SNO.mts.dec.com>
Date: Thu, 26 Sep 1996 02:21:00 +0000 (GMT)
Subject: re: jaguar part yards
Was just wondering if anyone knows of any good part-yards
in the U.S., U.K., or Australia?
Thanks for any help!> Eric cobac@ix.netcom.com
I have used H & H Prestige in Australia for 3 yrs, and they
are both honest, and have lots of parts (rare).
They buy cars from Endland regularly, and are willing to
separate parts if required.
Eugene Terrace, Ringwood, VIC 3134,
ph 03 9870 0542 fax 03 9879 6603
Int’l (613) 9870 0542 or fax (613) 9879 6603
regards
Date: Mon, 23 Sep 1996 20:01:27 -0700
Subject: re: Craig Hasting’s re: parts list
Craig Hastings posted that he might be able to set-up:
if you required a
something like:
that meet your
request. You could also through e-mail add parts that you have available.I have an application that I think I can modify to be usable as a parts
data base… So, is this something we could use?>
A strong yes vote from me on this one!!!
Rob W-M
85 XJ-S
Date: Wed, 25 Sep 1996 23:04:00 -0400
Subject: Re: [Even less Jag content] Names and places
Re: this and that, names, jaguwer, Indo-European-Asian, etc.
Yes, fine, but remember,
if you see a fork in the road,
take it!
Yoggi Berra
(mulit threads deleted as to do otherwise would be cruel
and (un)usual punishment!
Date: Wed, 25 Sep 1996 23:14:00 -0400 (EDT)
If money is a problem, then we should subscribe to the list and you
control access. If money is not a problem, then open it to all so there
is more diversity in what is available and who might buy it.
John
Date: Wed, 25 Sep 1996 23:58:22, -0500
Subject: Ignition Amplifier
Whilst browsing through Michael Neal’s excellent technical pages at
the JagWeb site I came across an issue that somewhat befuddled me. In
the section on ignition amplifiers he states that when replacing an
ignition amplifier one must also replace the distributor pickup as a
faulty pickup is usuually the cause of a dead amp. I recently had the
ign. amp on my '86 Series III XJ-6 replaced at a Jaguar dealership.
As I was actually in the forcourt of a Jaguar dealer when my original
amp died (I just stopped in to pickup some Hide Food and when I went
back to leave my amp was on the fritz) The tech there replaced my amp
with a new one and I thought that the pickup wire came with the new
amp. The invoice does not list a seperate distributor pickup. My
question is: Is there another distributor pickup that Mr. Neal is
refering to? and if there is what is the part number ?
Date: 26 Sep 96 18:56:36
Subject: Re: [No Jag content] Names and places
Gunnar Helliesen : IMHO it’s M|nchen not Munich,
Unfortunately, few people have the education to cope with a really foreign
language. I find this especially with English speakers, who usually seem to be
under the impression that French pronunciation rules apply to anything that
isn’t English. Our present NSW health minister, the Barely Honourable Mr.
Refshauge, for example, is pronounced “Ref-SHAW-gi” with the emphasis in the
middle - even by himself. Which has all the Scandihoovians ROTFL; it’s
Norwegian and should be “REFS-how-geh”. And of course “Porsche” becomes “Pawsh”
out of the same mistaken francophilia.
Another commonly slaughtered name is Rotschild - it’s commonly pronounced
“Roths-child” (with a lithp) by Anglos but it’s German and should be
“Rawt-schilt”.
Our recently immigrated boxing world champion Kostya Tsyu gets mangled by every
TV announcer without exception; they say “Costa Zu”, whereas it should be
“costya” as in “it’ll cost ya plenty” and “tsyou” as in “Oh, it’s you”. But
I’ve given up trying to get that across.
This is why English speakers refer to Sweden, not Sverige; Germany, not
Deutschland; Switzerland, not Schweiz; Holland, not Nederland. Italians don’t
go to Stuttgart, they go to Stoccarda, and Swedes don’t go to Britain, they go
to England - even when their destination is Cardiff - and the French call the
same destination l’Angleterre.
So names do change, simply because different languages use different sounds,
differently symbolised by the same letters (but try to read a road sign in
Russia or Greece, not to mention China). We deal differently with the names of
persons; it becomes necessary to imitate the sound, however mangled the result
(my own name is often written Yarn by Australians), because there is no
equivalence known to all as there is between, say, Austria and Oesterreich (or
Autriche if you’re French…).
So what, if you say tomayto, I say tomahto, you say “Jag-oo-ar” and I say
“Jag-you-are” (not sounding the “r”); we both know what we’re talking about, so
let’s call the whole thing off. It’s not as if we’re dealing with some sort of
sacrament…?
- -Jan
Date: Thu, 26 Sep 96 10:11:13 BST
Excelent suggestion from Gunnar!
I hope it doesn’t prove too difficult to set up and administer.
Well done.
David Brown,
brownd@ml.com
Date: Thu, 26 Sep 1996 07:43:01 GMT
Subject: Re: XJ-S Seat Mounts
In message 32495C67@dwmsgate.dw.att.com “Himes,John W.” writes:
[a complaint about how badly designed the XJ-S seat mounts are]
A year or so ago I posted a warning about this in my report on repairing
the seat heater. I found that it is easier to put the seats back on if
you omit the rectangular washers that rest between the seat rails and the
bolts.
In mine the outboard rear nut was actually welded in place and the other
three could be moved. If you align them very carefully beforehand, it’s
possible to refit the seat first time.
Stefan Schulz
jaguar@suaviter.demon.co.uk
'88 XJ-S V12 97K miles, no seat mounting washers
Date: 26 Sep 96 19:43:51
Subject: Re: Ignition Amplifier
If the ignition on the 6 is based on the same principles as that on the 12, I
can’t see how a fault in the distributor pickup could damage the amplifier (but
I’m prepared to be enlightened - my infallibility is not yet complete…). My
own ignition troubles with both V12s have been mainly due to broken connections
between pickup and amplifier (where the wires issue from the distributor) with
no damage to either amplifier or pickup. I exchanged one amplifier for a used
spare, but found afterward that there was nothing wrong with the original
amplifier except a break in the wiring just inside the amplifier housing.
- -Jan
Date: Thu, 26 Sep 1996 09:36:26 GMT
Gunnar wrote: I’ve already installed and configured a Web based conferencing (or
I would say that HyperNews looks like a winner. Similar to what I proposed but already available. Looks good to me.
Craig Hastings
88 VDP
E-Type (looks like the 61)
Date: Thu, 26 Sep 1996 11:40:51 +0200 (MET DST)
conference (with usernames and passwords provided by me)If money is a problem, then we should subscribe to the list and you
No, money is not a problem (sorry for not mentioning this in my first
post). I also agree with you, I think the system should be open to all.
BTW, so far four emails in favor and one email suggesting a different
setup using a “chat room” on the web.
Gunnar
Date: Thu, 26 Sep 96 10:56:36 +0100
Subject: Introduction (induction?) and E-type saga!
Dear Jag-Lovers,
I have been reading this list for a couple of months now and find it
extremely interesting. Its not always completely relevant – but that
doesn’t matter to me at the moment as I am just trying to learn and
absorb all information. As this will be my first active participation
I guess that I ought to introduce myself. My name is David White, age
31 (very nearly – eeek), and I work in the Institute of Astronomy,
University of Cambridge, as a research scientist (X-ray astronomy in
particular).
For the past few months I have been serious considering the
possibility that I may be able to attain my dream car :-))). I seem to
be getting a little sentimental about the 60’s and 70’s (don’t laugh
- – I guess this might be a feature of getting older). I have a
fascination with the E-type, although I’m not really quite sure why,
apart from the obvious – that it’s one of the sexiest icons of man’s
motoring achievements ever (and it’s British and you can’t say that
about too many things nowerdays). I also have this vague memory of a
toy car which fascinated me, which I remember as being an E-type (was
it ?). Now I just want a bigger one now (I remember a discussion about
whether Jaguars could be considered toys – well maybe you can see my
opinion in this case!). Anyhow with the aid of a non-negligible bank
loan and some savings it appears that I may finally be able to achieve
my dream.
As I cycle to work, and don’t need a daily driver, I relatively
recently sold my `new’ car because the depreciation was depressing
me. I decided that a classic car would be the answer which would
satisfy my sentimental yearnings and not be a sure-fire financial
loss. When I was much younger than I am now I remember we’d had a
Triumph 2000TC and various Rovers (P6, coupe and then an 80’s
disaster). So, I mused over what could I afford and liked. Well I
liked the looks and sound of the Triumph Stag, TR6 and 5. After
driving back from seeing a Triumph Stag I decided to just call, from a
phone box, a guy who was advertising a midnight blue Series III. Bad
move, I was hooked and the Triumph’s never got another look
in. Fortunately I maintained some perspective and decided to look
around and get a feel for various E-types around (aided in this
decision that I couldn’t buy anything without first getting rid of the
current car).
I carried on trying to get the feel of the market and saw several
SIIIs but hadn’t seen any earlier ones. I also went to the E-Type
centre in the Midlands (UK) to have a look at earlier models – in all
honesty I couldn’t really afford them and thought that they were
expensive for what they were. By this time I had also joined the
Jaguar Enthusiast Club, on the advice of a classic car friend. So, I
decided to continue to bide my time and look at the JEC classifieds.
Then a big dose of fate (hmm that reminds me of Prof. Fate from the
movie `The Great, Great, Great Race’ with Terry Thomas (?) and Tony
Curtis) arrived. It events like the following which make you wonder
about such things as fate.
Anyhow, the morning before I was due to fly to a conference in Israel,
Helen (my girlfriend) phoned from her parents in the West Country' (England). She had gone home for the weekend and her brother had noticed an advert in the local paper proclaiming the sale of a '61, flat floor, 6th RHD FHC, BRG, and
interesting history’ … all for
the bargain (?) price of 15,000 pounds. Wow! My heart started `a
thumping’. Mild panic ensued, and I tried to contact the vendor
before the bus to the airport. Thankfully, I got through and indicated
that I was very interested in seeing the car, but that I would away
for a week. I also expressed my worry that it would be sold before I
got back, and he kindly said he would give me first refusal. In the
meantime I sent my girlfriend and her brother (he knows a bit about
modern cars) to have a look. Her verbal report when I got back was
very encouraging and I was dying to have a look.
That same weekend we drove down to have a look. As we drove into the
vendor’s gravel drive. There she was – crouched and ready to pounce
(this is getting silly :-)). Anyhow, I had a huge grin from ear to
ear, while Helen was rolling her eyes at me saying things like `oh
dear’ :-} – I’m sure some of you know what I mean. Well I was
determined to have a proper look at her (although I’m not yet an
expert in cars), with at least one foot in the stratosphere. Time to
get serious. First the vendor took me inside to show-off the history
which he was obviously attaching some premium to.
As the advert claimed, this car one is the 6th right-hand drive FHC,
but no external bonnet locks as these disappeared by the 5th (although
the bulkhead shows indications that it also had fixing points for the
internal lock design). The owner showed me a Daimler-Heritage
certificate which seemed to back up its authenticity, and also Philip
Porter’s encyclopedia' on E-types which had a paragraph which described the car. For those of you who don't have this monolithic book, the first owner was Col. Ronnie Hoare, the head of Marinello Concerns (i.e. Ferrari racing?). He apparently collected the car, along with no. 7 by the Duke of Kent, after lunch with Sir William! Unfortunately there don't appear to be many photographs of Col. Hoare and this car as Ferrari were none too happy about this
indiscression’
- – that’s what the vendor told me anyhow. Well she seemed to have
quite a pedigree, but what was her condition?
I had a check list of items to look at that I’d off the SOL WWW page
which I was trying to work my way through. The only things of
particular note were: the engine seemed to be noisy at the front/top
end (more on this concern later), the oil pressure was only 20, and
there was a bit of rust just at the rear underneath and on the
bulkhead end of the bonnet top. The interior was great and so were the
wheels. It had been in storage for a year and so the brakes needed
looking at, and things like the wipers and lights needed fixing
(obviously the Prince of Darkness had been busy in the garage!), but
these should be fixed before the MOT. Although some bits didn’t appear
to be original: header tank, radiator, bonnet – anyone know which
chassis number they changed from the welded to punched-in louvres. I
continued to have a good look around. Then a `mild’ disaster occurred.
I had just had brief discussion with the vendor, pointing out the rust
close the the nearside louvre which was separating paint and filler
(!?) from the metal (which he hadn’t noticed). I then tried to open
the bonnet again, but the vendor had locked the bonnet without my
noticing, and so suddenly a large chunk of paint and filler came off
the bonnet in my hand! Ooops, oh dear — you vandal' came to mind (as did
better now than later!‘). I creeped inside and dragged him
out to see my destruction. He seemed to control himself rather well
(as of course he should being British :-P), but he did look rather
like a boiler with broken pressure-release valve. After a couple of
minutes of deep breathing, things returned to a more level-headed
conversation. I indicated that I was still very interested in the car
and he suggested that he would have the bonnet paintwork seen to and
the we should talk again after it had been done. I must say that the
vendor has been very reasonable on honorable in his dealings with me.
He had previously quite keen to make a deal there and then as another
person, who had known the car before it had gone out to S. Africa (it
was probably out there from the mid 60’s until the late 80’s), had
offered him the asking price on the phone without viewing. However, he
stuck to his promise of giving me first refusal. I’m not sure how many
vendors would have just passed it on and said `sorry’!
Anyhow, the car went in for its paintjob, I went on holiday, then he
went on holiday, and so we haven’t progressed too much further. The
only major thing to happen was that I phoned the JEC to see if they
had anyone who knew about early E-type who could have a look for
me. They had a guy in Cardiff who kindly agreed to have a look (with a
friend who knew about early E-type mods). The only charge would be to
cover expenses – much cheaper than the 365 pounds that the RAC had
quoted me (although I guess I would have some comeback with the RAC).
The inspection occurred whilst I was on holiday, but I now have the
report. The inspector was apparently `very taken’ with the car, and
pointed out, and that the only major thing that really ought to be
fixed before purchase would be the noise at the front of the engine.
I believe this could be due to worn bearing on the cam or a slack
timing chain. However, as the vendor had only had the original head
refurbished, at a cost of more than 1,000 pounds, less than 500 miles
ago, my inspector was inclined to think the timing chain may just need
tensioning rather than it being due to poor machining or wear. Despite
the low oil pressure reading there seemed to be adequate oil flow into
the cam area and so the gauge may be misreading. Exhaust seems to
indicate slight wear which is not serious.
The latest update is that the car has passed its MOT and that the
engine noise has been much reduced by tensioning the timing chain.
The vendor also decided that he’d had enough of the clutch pedal
failing to return to the proper position, and ordered a new master
cylinder etc. Despite promises from the courier, the parts failed to
turn up before last weekend and so I abandoned my intended visit.
However the time is fast approaching that I will have to decide what
to do :-). Buy or not? I’ve more or less made up my mind, but if I
don’t I guess I might as well give up and look at the Triumph’s again!
Any opinions :-)? The only other thing left to worry over is what to
call it. I think that it will have to be named `Ronnie’ – despite the
fact that I think the earlier cars look feminine compared to the later
ones.
Well, I’ve waffled too much. I hope you don’t mind its length, but I
often find the anecdotal stories the best read. Any opinions on my
potential purchase would be welcome (as long as they aren’t negative
David White
End of jag-lovers-digest V2 #380
id for jag-lovers-digest-out; Thu, 26 Sep 1996 20:33:26 +0200 (MET DST)
Date: Thu, 26 Sep 1996 20:33:26 +0200 (MET DST)
Message-Id: 199609261833.UAA19548@ekeberg.sn.no
Subject: jag-lovers-digest V2 #381
Precedence: bulk
jag-lovers-digest Thursday, 26 September 1996 Volume 02 : Number 381
V12 catalyst retrofit, ECU and SS exhausts
RE: Introduction (induction?) and E-type
Re: Introduction (induction?) and E-type saga!
Series I dash question
E-type on the Nike Commercial
Names&places (Jag-content=zero)
RE: s111 for sale
Re: V12 catalyst retrofit, ECU and SS exhausts
[none]
Re: cats for a Cat retrofit
New List Member Questions
Prononuciation & Price (Irrelevant jag content)
Fuel
Re: Prononuciation & Price (Irrelevant jag content)
[General] Jaguar swap meet
88 XJ-S seat mounts Follow up
Date: Thu, 26 Sep 1996 12:35:15 +0100
Subject: V12 catalyst retrofit, ECU and SS exhausts
Hi List
I am in the process of finding out how to convert my XJ12 S3
into a closed-loop control catalyst version. The car is a late
1983
production HE model.
I need modification to the ECU, a 6CU model to have the
Lamda sensor input, and need the sensors and the catalysts
of course. I have contacted AJ6 engineering in UK who can
supply parts. Roger Bywater of AJ6 tell me because I have a
European 12.5 : 1 compression ratio, the later ECU (digital
microprocessor type) is “easier” to program to take into
consideration the higher compression. The 6CU can also be
altered, however not equally easy.
Before I leap into this what about the catalysts. I hardly
believe Jaguar Standard Exhaust restrictor cats are stainless
which I would prefer. Does anyone know who makes and
delivers Stainless Steel Catalysts , possibly with insignificant
flow restriction , which are to Jaguar Specification such that
the car will pass a German MOT (called TUV here).
Does anyone know who delivers stainless exhaust manifolds
possibly a tuned length “banana” manifold that bolts straight
onto the “standard” SS exhaust systems for the S3 V12.
The engine is not a blue smoker , but will sometimes give a
Puff. Wil such damage the sensors or the catalyst ?.
Suppliers from UK (or europe) is preferred but if Australia, or
US has something to offer please tell me.
Date: Thu, 26 Sep 1996 13:45 +0200
Subject: RE: Introduction (induction?) and E-type
Yes David, a very good story. I wouldn’t hesitate with such an opportunity!
Frans.
).David White
=20
Date: Thu, 26 Sep 96 08:22:15 EST
Subject: Re: Introduction (induction?) and E-type saga!
David -
Great story!
Clearly your mind is already made up. Buy the darned car and enjoy it!
best of luck
- mclaus
______________________________ Reply Separator _________________________________
Author: daw@ast.cam.ac.uk at WG-RAL-SMTP
Date: 9/26/96 7:17 AM
Dear Jag-Lovers,
particular).
my dream.
current car).
I carried on trying to get the feel of the market and saw several SIIIs
but hadn’t seen any earlier ones. I also went to the E-Type centre in
the Midlands (UK) to have a look at earlier models – in all honesty I
couldn’t really afford them and thought that they were expensive for
what they were. By this time I had also joined the Jaguar Enthusiast
Club, on the advice of a classic car friend. So, I decided to continue
to bide my time and look at the JEC classifieds. Then a big dose of
fate (hmm that reminds me of Prof. Fate from the movie `The Great,
Great, Great Race’ with Terry Thomas (?) and Tony Curtis) arrived. It
events like the following which make you wonder about such things as
fate.
indiscression’
- – that’s what the vendor told me anyhow. Well she seemed to have quite
engine noise has been much reduced by tensioning the timing chain. The
vendor also decided that he’d had enough of the clutch pedal failing
to return to the proper position, and ordered a new master cylinder
etc. Despite promises from the courier, the parts failed to turn up
before last weekend and so I abandoned my intended visit. However the
time is fast approaching that I will have to decide what to do :-).
Buy or not? I’ve more or less made up my mind, but if I don’t I guess
I might as well give up and look at the Triumph’s again! Any opinions
:-)? The only other thing left to worry over is what to call it. I
think that it will have to be named `Ronnie’ – despite the fact that
I think the earlier cars look feminine compared to the later ones.
David White
Date: Thu, 26 Sep 1996 08:26:42 -0400
Subject: Series I dash question
Has anybody replaced a dashboard on a series i xj-6? There’s one for
sale down the street that I’m thinking of buying, but it will need a dash
(old one is split). Posted price on the car is 3200US. Any comments are
greatly appreciated.
Steve Draper
'88 XJ-S
Possible XJ-6
Date: Thu, 26 Sep 96 08:27:07 EST
Subject: E-type on the Nike Commercial
I say for the first time last night the Nike Commercial with
an E-Type OTS being pursued by some other vehicle. The
occupant of the two vehicles are playing tennis with each
other. Very cute!
Anybody else seen the advert? What vintage E is it?
- mclaus
Date: Thu, 26 Sep 1996 15:01:28 -0700
Subject: Names&places (Jag-content=zero)
Just a comment to Jan’s posting on you know what…
the Barely Honourable Mr. Refshauge, for example, is pronounced “Ref-SHAW-gi”
with the emphasis in the middle - even by himself. Which has all the
Scandihoovians ROTFL; it’s Norwegian and should be “REFS-how-geh”.
Interesting… If your barely honourable health minister is indeed Norwegian,
his name is more probably Refshaug or Refshaugen, the au-part being prenounced
like a right honourable English gentleman (or lady) would prenounce the Oh-part
of “Oh, dear!”; Au dear. Anyway, Refs meaning for instance punishment (typically
in the Military), and haug meaning hill, his name could translate to Punishment
Hill.
TTFN
Bard
Date: Thu, 26 Sep 1996 15:37:35 ±800
Subject: RE: s111 for sale
Brian Sherwood…tap tap tap…Brian…wake up lad.
From: COOPER ROBIN D[SMTP:COOPER_ROBIN_D@Lilly.com]
Sent: Thursday, September 26, 1996 12:20 AM
To: jag-lovers@sn.no
Date: Thu, 26 Sep 1996 09:31:33 -0400 (EDT)
Subject: Re: V12 catalyst retrofit, ECU and SS exhausts
1983
Do you care to explain why you want to add catalytic converters
to a car that they are not required on?
Thomas E. Alberts
Date: Thu, 26 Sep 1996 16:35:35 +0100
Subject: [none]
Hi Thomas,
Do I have to JUSTFY my projects ?. Need is a relative term. No-one within the next years will
demand that the car has catalysts, but in Germany cars will most probably be banned from the
road on summerdays with high OZone content, and later the cars will be banned completely.
Meanwhile the German goverment will push the roadtax up to the double amount , possibly from
January 1997. For a V12 jag with 5.3 litre that means 2038 DM or about 1400 US dollars per
year.
The investment itself for cats are in Germany at the local Jag-dealer just under 6600 US $
including the fitting, which is about the value of the car. The investment is thus straight out of the
window, unless the car is driven for another 10 years. However it is not only about money - what
is the point of having the car if it is banned ?.
Alternative is to get the car registered in another country, and drive it in Germany - which is
illegal and will probably be fined heavily, especially the second and third time ?.
However as said in the previous note I am considering making use of AJ6 Engineerings wide
knowledge on the field and expect to arrive at a cheaper solution, but still within the emission
requirements.
I Hope this answer the question of why I want to consider cats on the Cat.
Date: Thu, 26 Sep 1996 11:10:10 -0400 (EDT)
Subject: Re: cats for a Cat retrofit
Do I have to JUSTIFY my projects ?
Jeffrey,
Sorry if my question seemed like challenge. I am probably
not the only one that was curious as to why someone would
add cats to their non-cat Cat. I was particularly interested
because you had mentioned updating to a closed-loop system
and seemed to imply that cats and closed-loop operation
go hand in hand. If that is so then I would be interested
in learning more about it.
Re: your reason for wanting to add cats, I had forgotten
that you are in Europe. Now I understand.
THomas E. Alberts
From: “Richard G. Ried” riedr@osuergo.eng.ohio-state.edu
Date: Thu, 26 Sep 1996 12:11:00 -0400
Subject: New List Member Questions
Hello All:
I have recently joined the list and have been lurking
around for a few days, reading the various posts on
the XJ6 Series III.
I have never owned a Jaguar, my last British car was
a '77 MGB, that I sold back in '89. Since then I have
owned a variety of cars: Jeeps, Saabs, and BMWs.
I know of few cars that match the beauty of the
Jaguar, and keep considering getting one.
I have read the excellent on-line books from the
Jag-Lovers web site, but am still a little concerned
about a few things. Hopefully the list members may
be able to shed a little light on the following items:
Rust - I live in Columbus, OH. Our winters are
not bad, but the city dumps piles of salt all over the
roads each winter and the temperature fluctuates
from just below freezing to just above. Is the XJ6
(series III) a car that will rust out from under you if
driven in these conditions? -
Cost and availability of parts. I am used to paying
through the nose on trim and other “special order” bits,
but do the normal wear items cost a fortune?
(Will it break the bank to keep it running?) From the
great XJ6 book, it sounds like most common items are
generally in stock in major cities. -
Can anyone recommend a reputable shop in the
Central Ohio (USA) area that could inspect a car for
me prior to purchase? There are a few Jaguar
specialists in the phone book, but I hate to blindly
trust someone without a recommendation.
Thanks for you time! Private e-mail replies to any of the
above questions, or on Jaguar ownership in general
are greatly appreciated.
–Rick (riedr@osuergo.eng.ohio-state.edu)
Richard Ried
Associate Editor and Lab Manager
Biodynamics Lab
Industrial, Welding, and Systems Engineering
The Ohio State University
210 Baker Systems, 1971 Neil Avenue
Columbus, OH 43210
Tel: (614) 292-2016
From: “Preferred Customer” lang0080@gold.tc.umn.edu
Date: Thu, 26 Sep 1996 10:01:33 -0000
Subject: Prononuciation & Price (Irrelevant jag content)
(1) pronunciation
In the US the animal “jaguar” can be prounounced both ways though jag-war
is the prefered on.
Since we don’t say “paree” for Paris or “may-hee-ko” for Mexico or “koln”
(can’t do an umlaut!) for Cologne
unless we are being pretentious, I see no reason not to USA-ize the cars
nameand say jag-war. After all, one should try to communicate with the
masses first; education can come second.
Incidentally, my father worked for Jag and Rover and he thought the US
pronunciation was an abomination.
(2) price
I like seeing car ads on this Web but please include a price.
Also, to get comparisons “www.autotrader.com” (Ithink that’s correct) lets
you search for cars and you need not pay (it’s only $1.00) to see the ownrs
names and phones and names.
Roger Langley
Date: Thu, 26 Sep 1996 09:14:43 -0700
Subject: Fuel
I live in the United States and drive an 87 XJS. I fill it up with
unleaded fuel, 87 octane. Should I go the extra buck and start using the
premium fuel or are these cars better at regular unleaded fuel.
JANA
treadwel@ieway.com
Date: Thu, 26 Sep 1996 13:00:18 -0000
Subject: Re: Prononuciation & Price (Irrelevant jag content)
You are very correct. I should have prefaced all my remarks with "In the
USA . . . "
I apologize to the net for my provincialism.
Well Roger, one reason not to USA the pronunciation, is that a great
many members on the list are not Americans! In fact, American
pronunciation
of this and other words is an anomaly, since most other English speaking
nations pronounce things (accent aside) as the English do.
Date: Thu, 26 Sep 1996 14:17:03 -0400
In a message dated 96-09-26 11:42:31 EDT, lang0080@gold.tc.umn.edu (Preferred
Customer) writes:
<< unless we are being pretentious, I see no reason not to USA-ize the cars
nameand say jag-war. >>
By logical deduction, you are implying that the only way to avoid
pretentiousness is to be ignorant.
Julian Mullaney (not being too serious)
Date: Thu, 26 Sep 1996 19:16:59 +0200 (MET DST)
Subject: [General] Jaguar swap meet
I’ve received no negative comments so far so I’ll get right to it. I’m
pretty busy this week, but I should be able to have it running sometime
during this weekend.
I’ll let you all know when it’s ready for testing.
Now for a very important question: What should we call it? “JagLover’s
swap meet”? “Jag Lovers’ used parts exchange”?
Suggestions?
Gunnar
Date: Thu, 26 Sep 96 12:36:00 PDT
Subject: 88 XJ-S seat mounts Follow up
In a message by Stefan Schulz replied to my message ( abbreviated )
bolts.
I do not remember your post from a year ago, I may not have been around then
anyway. ( joined the list late last year, I think… )
Not using the washers may have given me just that extra length needed to
engage the nuts. On my left hand drive, the only nut that stayed in place
would have the been the outboard rear nut, as you stated. The inboard rear
would SPIN in place, not engaging against the sides of the mount as the
front 2 nuts did. I had to pry the mounting rail upward while I tightened
the screw so it would stay in place while tightening. ( don’t need or want a
loose seat , in my car that is ) My quickie glue job did not hold the front
2 nuts, so instead I used a fat, flathead screwdriver to hold the nuts in
place while I started the screws.
I would expect this kind of piss poor engineering on a Yugo, not a $40K +
car built in 3/87.( its price back then ) My 72 mustang has better seat
mounts then this. Oh well, I still love the car.
John Himes 88 XJ-S 97K miles
End of jag-lovers-digest V2 #381
Return-Path: @owner-jag-lovers-di1
Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4)
id for jag-lovers-digest-out; Fri, 27 Sep 1996 00:20:54 +0200 (MET DST)
Date: Fri, 27 Sep 1996 00:20:54 +0200 (MET DST)
Message-Id: 199609262220.AAA26373@ekeberg.sn.no
X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f
To: jag-lovers-digest@sn.no
Subject: jag-lovers-digest V2 #382
Reply-To: jag-lovers@sn.no
Errors-To: @owner-jag-lovers-di1
Precedence: bulk
X-Newsgroups: mail.jag-lovers-digest
jag-lovers-digest Friday, 27 September 1996 Volume 02 : Number 382
English Only
xj-6 purchase
Re: RF Modulation CD Player units ( long )
Re: [General] Jaguar swap meet
Car Show, speech, S1 to S2
Re: Fuel
Re: xj-6 purchase
Re: Fuel
Re[2]: Engine Heaters/cats
Re: Pronouncing the name.
RE: Series I dash question
Re: xj-6 purchase
Re: English Only
Re: xj-6 purchase (No jag content)
Re: Fuel (No Jag content)
Change V-12 Head Gaskets Every 30,000!!!???
Re: Fuel
Humour (?) No jag content
Re: Fuel
Re: Re[2]: Engine Heaters/cats
From: bill%wmspear.com@vm1.cc.nps.navy.mil (Bill Spear)
Bill Spear reminds me;
<Perhaps it’s in the realm of urban legend, but something I always think
<about before turning the key is the observation an owner had about cats and
<E-Types…he said that in his neighborhood when he parked outside, the warm
<radiator attracted cats looking for a warm place to nap. The lack of a
Not only cats, but bird nests too.
LLoyd
Date: Thu, 26 Sep 1996 14:36:27 -0400
Subject: English Only
I suggest an English Only movement here. ahem.
Date: Thu, 26 Sep 1996 13:43:52 -0400
Subject: xj-6 purchase
O.k., so I’m hearing 3200US is high for a series I. The body is in great
shape; the car has been repainted to a brighter red than I would pick
myself. Tan interior. I’m hearing the dashboard replacement is not a
disaster. I just learned the car has been converted to a 350 chevy. Is
this fatal to the purchase, or would this car, for the right price, be a
good intro to jaguar sedans, and thus worth further inquiry? Your
opinions and wisdom are desired.
(Unfortunately, I have to drive past it on the way to and fro work; so I
have this on my mind.) Thanks!
Date: Thu, 26 Sep 1996 13:14:13 -0500
Subject: Re: RF Modulation CD Player units ( long )
Your '88 XJ-S has a radio that controls a CD and was prewired for the
CD in the trunk? Interesting. Are you the original owner? Is it the
original radio?
My '88 XJ-S has an AM/FM/Cassette radio that lacks any support for CD
players. Original owner and radio.
MikeC
Subject: RF Modulation CD Player units ( long )
Author: “Himes;John W.” jwh@mime.dw.lucent.com at Internet
Date: 9/24/1996 9:29 AM
( On my CD, I was able to get an adapter that hooks my CD player into the
same control jack that a newer CD unit plugs into that the radio can
control. I still can not use the radio to control the unit, but it no
longer goes through the antenna. )
John Himes
88 XJ-S 97K Miles
Date: Thu, 26 Sep 96 12:54:02 PDT
Subject: Re: [General] Jaguar swap meet
Gunnar,
Used parts exchange seems more clear to me. The use of the English language
is so obtuse and varys so much around the world, the next thing you know we’ll
be argueing about how to pronounce Jaguar.
LLoyd (L oi d)
Date: Tue, 24 Jan 95 15:58:13 EST
Subject: Car Show, speech, S1 to S2
For those of you in the Philadelphia area there is an anything British
car show Sat. Sept 28, 1996 at Graeme Park, County Line Rd, Horsham, PA
215-343-0965. This is a pretty low key event but if you’ve got some time=
between
10am and 4 pm it might be fun. Admission is $5 adult , $2 6yrs-12yrs, =
and
under 6 years old no charge. Admission includes tour of provincial Gov. =
William Keith’s 1722 mansion.
Now regarding speech. Do I now have to say any aluminum parts in my
car are now made of Al -U- min- knEE- um? It really just boils down to =
local
dialect regarding how to pronounce Jaguar. I’m constantly correcting =
my
wife’s Boston pronounciations (she tahks so funny ; ) ) Whereas my =
'Jersey accent we all know is proper.
Item 3. Has anybody ever taken the front fenders (wings?) and hood (bonn=
et?)
off of a Seriesd II XJ6 and put them on a SI XJ6? Aren’t they the same
under carriage? So the SII should “bolt” right on?
I’ve always been curious about this. I like the SI’s except for that =
giant grill,
maybe I could graft a SII nose on the front.
Some of you may remember I was agonizing over buying SI XJ6 a couple
weeks ago. Well it’s still available and got me thinking about my last =
(item 3)
question.
TTFN
eric
henning@fp.com
Eric Henning
henning@fp.com
these are only my opinions
Date: Thu, 26 Sep 1996 16:28:49 -0400 (EDT)
Subject: Re: Fuel
They are not better on 87 octane, but if it runs OK on 87,
i.e. doesn’t ping or diesel, then there is no reason I know of
to change to higher octane. There was a big discussion of this
issue on the list just about 2 months ago.
Thomas E. Alberts
Date: Thu, 26 Sep 1996 16:25:13 -0400
Subject: Re: xj-6 purchase
A guy here in Michigan just spent $17,000 for a near perfect series 1 XJ6 -
this may be a record.
Mark
Date: Thu, 26 Sep 1996 16:36:34 -0400 (EDT)
Could you be more specific please? I was asking about doing this
very thing on my 87 XJ-S back in June or so, but noone had any better
advice than to go by a new radio or settle for RF Modulation. I
gave up the whole idea eventually. I would be very interested
in knowing whether the same this could be done with my car.
Thomas E. Alberts
Date: Thu, 26 Sep 96 16:26:31 EST
Subject: Re: Fuel
The owners manual for my car clearly states I should use 93
octane. There is also 'Unleaded Premium Only' stenciled into
the gasket around the gas cap. I think Jaguar is pretty
serious about recommending premium fuel.
- mclaus ('93 XJ-S)
Subject: Fuel
Author: Jana treadwel@ieway.com at WG-RAL-SMTP
Date: 9/26/96 3:35 PM
JANA
treadwel@ieway.com
Date: Thu, 26 Sep 96 16:29:43 EST
Subject: Re[2]: Engine Heaters/cats
Gee - bird nests? You gotta leave your car parked for quite a
while to get a birds nest in there. I treat my car pretty
good, but I sure drive it more often than that.
- mclaus
Author: LLoyd 3030P@vm1.cc.nps.navy.mil at WG-RAL-SMTP
Date: 9/26/96 9:07 AM
Message was resent – Original recipients were:
To:
jag-lovers@sn.no----------------------------------------------------------------
LLoyd
Date: Thu, 26 Sep 1996 15:16:03 -0500
Subject: Re: Pronouncing the name.
If my visit to the UK (including the factory) was any indication, the
pronunciations you heard more likely reflect their place of birth and
socio-economic status. Sort of like here in the US, where accents vary
widely. The common thread seems to be in the UK it is a three sylable
word, while here in the US it is only two syllables. If you look in any
decent dictionary here in the US, “official” pronunciations are given for
both. I wonder if UK dictionaries include both.
MikeC
Subject: Pronouncing the name.
Author: JISBELLJR@mail.utexas.edu (Jim Isbell) at Internet
Date: 9/24/1996 12:51 PM
At a recent Jag Club meeting they showed a video of the history of Jaguar
from the Swallow to the present. I was most interested to so how the owners
and perpetrators of the Jaguar company pronounced it. There were several
old voice interviews and I listened very carefully every time one of them spoke.
The pronunciation I got from those interviews was Jag- u- wer. I think
the people who invented it must know how to pronounce it.
JIM I.
Date: Thu, 26 Sep 1996 12:58:33 -0700
Subject: RE: Series I dash question
I pulled the old split dash top out of my S1 XJ12 and had it recovered
by ‘Just Dashes’ in Van Nuys CA (800/247-3274). It cost about $350 to do
and took 6 or 8 weeks to get it back, but:
It is guaranteed for as long as I own the car
It looks perfect (they guaranteed concours quality)
Expensive, but it is awfully good looking now…
Dave Covert
‘Very funny Scottie… now beam down my clothes…’
dash
are
Steve Draper
'88 XJ-S
Possible XJ-6
Date: Thu, 26 Sep 1996 16:47:08 -0400
this fatal to the purchase, or would this car, for the right price…
Kip Euing’s XJ6 SWB (the car that I was thinking of buying) just sold to
another friend for $3500 - the body was very good but the dif was toasted. Like
the car you are looking at, this one also has a V-8. Charles, the guy who
bought it, was quite happy with the car at that price and he will soon replace
the dif. Charles also has a very nice XJ40 and a very, very, nice Mark 2 - both
with real Jag motors :-).
Mark
Date: Thu, 26 Sep 1996 15:58:40 -0000
Excuse me correcting a net-fellow, but the name “LLoyd” is not pronounced
“L oi d” by the Welsh.
(Just kidding)
we’ll
be argueing about how to pronounce Jaguar.LLoyd (L oi d)
Date: Thu, 26 Sep 1996 15:46:00 -0000
Subject: Re: English Only
Language or heritage?
I qualify either way since I seak both USA and English and was born in
England.
To: Roger Langley
Date: Thursday, September 26, 1996 6:36 PMI suggest an English Only movement here. ahem.
Date: Thu, 26 Sep 1996 16:03:26 -0000
Subject: Re: xj-6 purchase (No jag content)
. . . or an idiot purchaser!
Mark
Date: Thu, 26 Sep 1996 16:08:46 -0000
Subject: Re: Fuel (No Jag content)
I think you will find that the defintion of “premium” varies around the
world so Jaguar is being cautious.
Consumer Reports has always maintained that as long as the car does not
knock (ping, detonate)
then the lower octane makes more sense. This ignores any worthwhile
additives the higher octane may have that the lower octane does not.
The owners manual for my car clearly states I should use 93 octane. There is also 'Unleaded Premium Only' stenciled into the gasket around the gas cap. I think Jaguar is pretty serious about recommending premium fuel. - mclaus ('93 XJ-S)
Date: 26 Sep 96 17:21:59 EDT
Subject: Change V-12 Head Gaskets Every 30,000!!!???
A friend of mine told me this afternoon that on V-12’s you should change the
cylinder head gaskets every 30,000 miles! Can this be true? He said that if you
leave it longer than that you risk warping the aluminium cylinder heads. Is
there any truth to any of this? (My car has 32,000 miles on it, hence my special
interest.)
Daniel Kagan
1985 UK-Spec Jaguar Sovereign (V-12) HE (Series III)
Date: Thu, 26 Sep 1996 17:54:30 -0400 (EDT)
Subject: Re: Fuel
The 1987 manual prescribes regular unleaded.
Thomas E. Alberts
Date: Thu, 26 Sep 1996 10:12:33 -0000
Subject: Humour (?) No jag content
The local paper ran an ad for a 75 MGB painted “British Racing Orange. . .”
Makes the pronunciation issue seem moot.
Date: Thu, 26 Sep 1996 11:23:56 -0500
- ----Roger wrote:
(1) pronunciation
is the prefered on.
name and say jag-war.
I would like to know how people at Ford pronounce Jaguar. After all,
let us not forget, Jaguar is Ford – the owner makes the rules…
Also, does any one know of any head to head tests/comparisons of
XJS and Mark VIII. I test drove Mark VIII, and, IMHO, the only thing
Jaguar has going for it, is a vision of a leisurely drive along a country
road. In all other respects, Mark VIII wins.
Vlad
85 XJS
Date: Thu, 26 Sep 1996 18:20:37 -0005
Subject: Re: Fuel
The owner’s manual for my '83 XJ-S recommends 89 octane, which
corresponds to the mid-grade or “plus” fuel sold here in Florida.
If you don’t knock on 87, chances are your timing is retarded too
much – mine knocks when I get marginal 89 octane! To operate as
intended, you should check the timing and start using higher octane
fuel.
– Kirbert | If anything is to be accomplished,
| some rules must be broken.
| - Palm’s Postulate
Date: Thu, 26 Sep 1996 18:20:36 -0005
Subject: Re: Re[2]: Engine Heaters/cats
Gee - bird nests? You gotta leave your car parked for quite a while to get a birds nest in there. I treat my car pretty good, but I sure drive it more often than that.
Yet another reason for Jaguar’s reputation for overheating?
| - Palm’s Postulate
End of jag-lovers-digest V2 #382
X-UIDL: 641089b8467bd0562a2aaceb53ca367f
id for jag-lovers-digest-out; Fri, 27 Sep 1996 04:10:56 +0200 (MET DST)
Date: Fri, 27 Sep 1996 04:10:56 +0200 (MET DST)
Message-Id: 199609270210.EAA01711@ekeberg.sn.no
Subject: jag-lovers-digest V2 #383
Precedence: bulk
Status: RO
X-Status:
jag-lovers-digest Friday, 27 September 1996 Volume 02 : Number 383
fuel tank repair
Engine Heater - What is it?
xjs sunroof
XK-8 in Stockholm on Oct 6
Lower Hose Heaters (no Jag content)
SII LWB front seat mounting position
Series III rough take off and idle.
HyperNews
Re: xj-6 purchase
Picture of SIII XJ Sovereign
RE: Introduction (induction?) and E-type saga!
Changing V-12 Head Gaskets Every 30,000 Miles
The Name’s the Thing (no discernable Jag content)
Re: Names&places (Jag-content=zero)
Re: Car Show, speech, S1 to S2
New Member
Date: Thu, 26 Sep 1996 18:23:51 -0400
Subject: fuel tank repair
I had a guy look at my 1985 XJS today he was giong to buy it for $4,000
U.S. The test drive went well(he was alittle heavy footed for my taste)
but nothing major went wrong. Upon parking he opened the trunk to look
at the extent of the rust and a strong gas smell was evident. I spotted
the leak coming from underneath right side of the fuel tank. I explained
that I just pulled sanded and patched the tank with marine-tex , A very
powerful and expensive epoxy for marine use, I’ve used this stuff for
years to patch fuel holes in tanks. This leak however was in a differnt
spot. The guy was turned off saying that it’s true jags do have fuel
leak problems. Wow what a @#%^&!. My question is once( pre Jag times)
I was watching a car show and they showed this stuff that poured into a
empty fuel tank and it coated the indide of the tank ,by sloshing it
around, with a thin hard shell that sealed all the little pin hole
leaks. Dad an ex mechanic says a bar of soap is the best thing on the
market to seal up a fuel tank. O.K. whatever Dad. Any suggestions I’m
pulling the tank on Friday Thanks. Frank Perrick 1985 XJS.
Also visit: vision.traderonline.com/auto for a searchable “for sale”
data base including prices. A posting earlier lead me to find this site
tele #'s report is a buck if you see one you like.
Date: Thu, 26 Sep 1996 15:39:35 -0700
Subject: Engine Heater - What is it?
Hi gang!,
Forgive me for probably sounding like a complete moron, but what exactly
is this Engine Heater (plug/valve/etc.) I’ve been hearing so much of?
I have an '89 XJ40 VDP, with the ‘cold package’ (Limited slip, heated
seats, headlamp wash, heated washer nozzels, and large washer reservior).
I’ve been reading that '93’s came with an “engine heater” as part of the
package. What is this thing, I assume I don’t have? Where is the dealer
part located? It doesn’t plug into an electrical outlet, does it? (funny, a
jag with an electric cord coming out of the grill
Just wondering if I should invest in this, to keep the engine well in the
approaching winter. Any idea on dealer part cost?
Thanks!,
cobac@ix.netcom.com
Date: Thu, 26 Sep 1996 18:36:20 -0400
Subject: xjs sunroof
I have an 85 xjs with factory sunroof.The roof works fine but the seal
around the edges is leaking
air.It hasn’t been in the rain long enough(since I’ve owned it)for me to see
if it leaks water.The noise
drives me crazy.Anyone know if the seal can be replaced and where I might
find replacment seal.
Any suggestions will be appreciated.
jag-lover
Larry
85 xjs-he
92 gmc yukon
with turpentine kisses,
jenN
enmitylove@aol.com
love, peace, empathy, desire, mischief, and gladness
Date: Thu, 26 Sep 1996 15:47:54 -0700
let us not forget, Jaguar is Ford – the owner makes the rules…Also, does any one know of any head to head tests/comparisons of
road. In all other respects, Mark VIII wins.Vlad
85 XJS
Vlad,
Not sure on that, but on some commercials, everyone speaks with a british
accent. The intro of the LWB Vanden Plas it was pronounced Jag-u-are (a
woman speaking). Now for the commercial of the “1st payment compliments of
Jaguar” it is pronounced Jag-whar (I’m not good at the spelling of phonetics
(It’s a man with a brit accent, but americanizing the word Jaguar) Seems
the company hasn’t solved the difference yet.
IMHO I prefer the Jag-u-are, it’s more sophisticated and adds to the
sexiness of the cars personality. Try saying Jag-u-are to American friends,
and watch them smile when you say it in the British tone.
cobac@ix.netcom.com
Date: Fri, 27 Sep 1996 00:58:55 +0200
Subject: XK-8 in Stockholm on Oct 6
The new XK-8 will be presented at a event in Stockholm, Sweden
on October 6. On peculiar ways I have managed to become invited to the
preview. Well, my wife have a colleague which got invited…and eehh,
hmm. I will report my impressions to the list afterwards.
Gunnar Forsgren gunnar@medial.se
MEDIAL Maskin & Data http://www.medial.se
�ngsvik 2 24 hour phone/fax +46 8 570 25056
S-139 50 V�rmd�, Sweden “XJ 4.2 S1 '72 Now stored outside the garage”
Date: Thu, 26 Sep 1996 10:10:08 -0000
Subject: Lower Hose Heaters (no Jag content)
They are not block heaters. They don’t open the thermostat but rely mostly
on conduction to keep the engine warm. That is why they go in the lower
hose not the upper hose which, as you correctly note, wouldn’t do diddly)
They are usually low powered (150 watts?) and do need to be on all night to
be effective. In the UK you shouldn’t need any kind of heater. All these
gadgets are for extreme climates.
A couple of folks mentioned engine block heaters that are mounted in the
lower
radiator hose. How do these things heat up all the coolant, considering
that
when they start the thermostats are closed and they only have thermal
convection to circulate the heat ? Is that really enough to get
to the thermostats, open them, and generate convetion throughout block
and
radiator ?
Date: Fri, 27 Sep 96 9:18:42 +60000
Subject: SII LWB front seat mounting position
Hi…
Does anyone know whether there is the option of remounting the front seats in
a SII Daimler or LWB Jaguar to provide more driver legroom? So far I’ve been
having so much fun the legroom hasn’t bothered me, but I could do with an
extra inch or two for my pins. Will this compromise the ability of the
driver’s seat to accommodate a vertically-challenged girlfriend @ 170 cm/5’ 8"
? Will it impinge significantly upon rear seat legroom (I know if the seat’s
moved 1" back that’s 1 fewer inch of legroom - I’m more after a perception).
Thanks in advance for your thoughts
Peter Brown
Lobotomised SII double six VDP
Date: Thu, 26 Sep 1996 10:30:31 -0000
Subject: Series III rough take off and idle.
My '83 III has started to be extremely rough when accelerating from a
standing position. It is almost like very bad U joints. I let the
tranmission get quart + low and initially thought I had damaged it. How
ever, the odd thing is that sometimes the roughness isn’t there at all
(from one traffic light to the next). There also seems to be a slight
uneveness when running at speed like a small surging but not a roughness.
Occasionally, I get a slight popping on heavy acceleration like too rich a
mixture. At standstill the roughness diminishes considerably from in gear
(700-800 rpm on the tach) to neutral (1100 rpm) but is still there. The
car does not over heat at all and has new plugs and bits of that ilk.
There seems to be no correlation between the outside temperature or engine
temperature with the problem. The car has 107,000 miles on it and normally
runs very well.
I am at a loss on how to troubleshoot this and would welcome any advice.
Roger Langley
Date: Thu, 26 Sep 1996 19:18:59 -0400
Subject: HyperNews
I like what Gunnar Helliesen did with HyperNews for Ford. I think it would
be an asset for the Jag list. Go for it.
Jack Bednarski
71 XKE V12
90 XJ6 VDP
95 XJS V12
Date: Thu, 26 Sep 1996 19:24:44 -0400
We still have this 1972 SI for sale @ $350.00US
If interested E-mail me @ cindys 4u@aol.com for details
From: brownd@filon.ml.com (Dave Brown - London Dev X1818)
Date: Thu, 26 Sep 96 17:11:59 BST
Subject: Picture of SIII XJ Sovereign
Wondering if anyone knows of a reasonably large (8 inches by 6 inches?) picture
of a SIII XJ on the Web? I’ve seen the ones on the jaglovers site but they’re a
bit small.
TIA,
David Brown, Merrill Lynch
brownd@ml.com
///_/_/_/_/////_///______
/_/_//_/_/_/_/_/____
/_/_/_/_/______/_/_/_/______
/_/_/_/_/_/_/________/_/_____
___/_/_/////_/_/_/_/_/______
/_/___/_/_//_/_/_/____
///_/_/_/____/////_///_________
Date: Thu, 26 Sep 1996 13:33:58 -0400
Subject: RE: Introduction (induction?) and E-type saga!
Hi David,
Great reading your e-mail, and it actually wasn't long enough! (I am a =
fellow E-Type lover…) This car has your name all over it, and you =
should see that! Would you want to look back on this moment and regret =
it? The car needs some TLC and it has found you - buy it. Take care of =
it, and enjoy the rewards!!
Mark Budd
Montreal Canada
1986 XJ6 (1994-95)
1970 E-Type Roadster (1995-current)
Sent: Thursday, September 26, 1996 5:56 AM
Cc: daw@ast.cam.ac.uk
Subject: Introduction (induction?) and E-type saga!=20
Dear Jag-Lovers,
particular).
my dream.
current car).
indiscression’
ones.
David White
Date: Thu, 26 Sep 1996 17:18:28 -0700
Subject: Changing V-12 Head Gaskets Every 30,000 Miles
Daniel Kagan asked about the need to change head gaskets on the V-12s every
30,000 miles.
My '84 XJS has gone 130,000 miles without removal of the heads or ANY major
engine work.
It still runs strong and doesn’t leak oil.
Dan Jensen
'81 & '83 XJ6
'84 XJS
Date: Thu, 26 Sep 1996 20:18:34 -0400
Subject: The Name’s the Thing (no discernable Jag content)
The argument over the name is indeed abstract. Most of us, I suspect
will never HEAR each other say “Jaguar.” We are all agreed on the
spelling, aren’t we?
Sometimes, believe it or not, it is pronounced here (in the american
South) as “Jagwire,” but not by people who own one. Our two-syllable
american prono of “Jag-whar” is simply more efficient than that of the
mother country (but then, every word in the South has two syllables).
Now, back to that head gasket…
Date: Thu, 26 Sep 1996 20:35:34 -0400
Subject: Re: Names&places (Jag-content=zero)
Hi all,
Could someone please ask the Barely Honourable Mr. Refshauge,
or Mr. Refshaug or Mr. Refshaugen, et al, how the hell they
pronounce the name of the car? You know, -the car this is all
about! I forget which car we’re talking about!
Must be the only car group that can’t agree on the name of the car!
BTW, is it Looo-kas, or Lukus?
Charles Daly, Toronto, Canada
'62 E-Type, ots
Date: Thu, 26 Sep 1996 21:16:55 -0400
Suggestions? >Gunnar
I was afraid you’d ask that question, Gunnar!
Methinks we shall grow old together!
'62 E-Type, ots
Date: Thu, 26 Sep 1996 21:23:00 -0400
Subject: Re: Car Show, speech, S1 to S2
Eric,
A lead for you, if you’re serious about that bodywork,
Monty Python’s Body Shop & Cheese Emporium.
Item 3. Has anybody ever taken the front fenders (wings?) and hood (bonnet?)
I like the SI’s except for that giant grill, maybe I could graft a SII nose
on the front.
'62 E-Type, ots
Date: Thu, 26 Sep 1996 21:22:19 -0500
Subject: New Member
Very interesting reading! I have been reading the web pages and have decided
to give this a try. Allow me (to bore you with) to present my past & present
history with Jaguars.
I got the Jaguar bug back in 1983. I was looking for a car at the time that
was different. I did not want to drive just a GM or Ford. A friend(?), who
is a Jaguar nut but didn’t own one, convinced me that Jags were different,
unusual, and beautiful. I started looking at want-ads.
My first look (literally) ended with a purchase of a rather poor condition
1956 XK140 OTS. The car had been parked under a tree with leaves, mud, etc.
up to the bottom of the car. Major rust was evident and the engine and
gearbox were frozen. Nothing worked on the car except for the ignition
light! I spent the next year taking the car apart.
In 1984, I decided that a parts car would be of major benefit to the
pocket-book and so started looking at want-ads. On my first excursion I
looked at a 1952 XK120 OTS in the middle of the night using a failing
flashlight. I verified that the body panels were in excellent shape and made
an offer. The fellow accepted the offer a week later and offered to
transport the car to me! I accepted.
Once I got the car and inspected it in the daylight, I realized that the
XK120 was an unrusted and straight car which differed greatly from the
XK140. The XK140 was then made into a parts cars for the XK120!
The engine was out of the XK120 and in a hundred pieces. I did not want to
use the XK140 motor. It was a matching number engine with the XK140 body,
such as it was. A XK150 3.4L engine was available at a shop in town. The
engine was purchased and placed into the car. The car was placed into daily
service until 1986 when the car was painted and a new interior was
installed. The car was painted yellow with a black interior. The reliability
of the car was as good as any new car of the time! Very enjoyable!
The XK140 was restored once the XK120 was done. In 1988, I had decided not
to break-up the car. It did its first drive in 1991 after sitting since 1970
under trees, my garage, etc. Very little of the car was untouched. It can
get 99+ at a concours. The color (colour?) is red with a black interior.
My next project is still ongoing. Its a 1962 E-type OTS. I found it sitting
outside at a mechanics shop. A rear-end rebuild, carb rebuild, brake system
and front suspension rebuild were required to get the car really drivable.It
presently needs paint and some bodywork. Money is being saved up for this
activity.
My finial project is also ongoing. Its a 1965 3.4S. The car was saved from a
junkyard before it could be dismantaled. It just needed a battery and a carb
cleaning to run and drive. Bodywork had been started on the car before I got
it and had to be completed before it could rust. This car took my E-type
body and paint money!
I still have all of these cars and drive the XKs on weekends. The orginial
XK120 motor was rebuilt and put in the car the past year. The XK150 motor
was used as a donor for the crank and rods.
I have had good times and bad, but overall, the experience is positive. The
cars seem to want to be driven and have a lot less problems when they are.
Hope I didn’t bore you too much!
By the way:
I’m from Texas and can mangle English and American English with the best of
them!
Bye Y’all!
Cleo Bay
End of jag-lovers-digest V2 #383
id for jag-lovers-digest-out; Fri, 27 Sep 1996 13:16:39 +0200 (MET DST)
Date: Fri, 27 Sep 1996 13:16:39 +0200 (MET DST)
Message-Id: 199609271116.NAA18737@ekeberg.sn.no
Subject: jag-lovers-digest V2 #384
Precedence: bulk
jag-lovers-digest Friday, 27 September 1996 Volume 02 : Number 384
'88 XJ-S V12 (UK) afterthought to steering rack replacement
Re: jag-lovers-digest V2 #382
Sanscontentjag
Substitute throttle potentiometer for V12 EFI
1 more post on CD changers ( long & if not interested, move along )
Dumb Things
RE: jag-lovers-digest V2 #382
Re: Jaguar Part-Yards
Front oil seal
XK8 V.I.P. sneak preview, Oslo Oct. 9th
S-I to S-II and dash roll.
Re: Series III rough take off and idle.
Re: Fuel
Re: Change V-12 Head Gaskets Every 30,000!!!???
Date: Thu, 26 Sep 1996 23:35:12 GMT
Subject: '88 XJ-S V12 (UK) afterthought to steering rack replacement
While I was underneath the car today, contemplating the leak from the
rack which will make a replacement necessary I noticed that the high-
pressure pipe chafed against a rather sharp-edged bolt head on the
rack.
(The pipe in question is a composite assembly of metal-rubber-metal.)
I have in the past two years lost two pipes to this failure mechanism.
This time I thought the garage had taken care of the problem and mounted
the pipe a little away from the bolt head. Apparently the only thing that
holds this pipe and the return line in place are two large hose clips
running around the two pipes and the body of the steering rack. Over time
the mounting will creep and the problem repeat itself.
Since a rack renewal is on the cards anyway, and because the chafe was
only very slight, I have put a sacrifical hose clip around the affected
area of the pipe, expecting that now the hose clip will chafe against the
bolt head and that I’ll be under there again, tearing it all apart before
the clip is chafed through.
Does anyone else have the probelm ? Is this the reason why these pipes have
a reputation for dying like flies ?
Stefan Schulz
Date: Thu, 26 Sep 1996 22:17:20 -0400
Subject: Re: jag-lovers-digest V2 #382
I work at Ford and I pronounce it “Jag-you-are”. Many Americans I
work with say “Jag-war”, while the many Brits stationed in Dearborn,
and those visiting from the UK prounounce it in the expected way
“Jag-u-ah” or “Jag-u-eh”, depending on where in the UK they come
from (Wales, Scotland, Midlands, London, etc.). Similar to American
accents from the south, east coast, midwest, etc.
Cheerio.
B.J. Kroppe - '82 XJ6
p.s. I have been seeing lots of XK8s around my workshops. Just
waiting for the right opportunity to beg for a ride/drive!
Date: Thu, 26 Sep 1996 23:08:06 -0400
Subject: Sanscontentjag
[Must be the only car group that can’t agree on the name of the car!]
So, do you suppose then that Porsche, Lancia, Renault, Citroen, Ferrari,
Iso, and other car owners all agree on the pronunciation of their cars? BTW,
is there agreement on the spelling of “pronunciation”? How about the
pronunciation of pronounce? Perhaps one should be allowed to modify language
as some do cars.
What in language would be the equivalent of a Chevy Lump?
Date: Thu, 26 Sep 1996 23:09:48 -0400
Subject: Substitute throttle potentiometer for V12 EFI
My '84 XJ-S V12 had suffered from an intermittent surge at cruise speeds;
I’d tried for a couple
of months to locate the cause. The throttle potentiometer (TPS) was one of
the first things I had suspected,
but it checked OK with a meter. To shorten a long story, I finally ran
wires from the TPS to the inside
of the car so I could monitor the voltage while driving the car. And I found
when the car was surging,
the voltage was erratic, so a new TPS was in order. ( I took the old one
apart first to see if it was
repairable. It’s not- the resistance coating was worn down to the bare
plastic).
Rather than spend 150 USD for a new one, I tried something else instead-
from my spare parts pile I
found a TPS from a Ford, an '83 3.0L V-6, I think; part number E7DF-9B989-AA.
It turned in the proper
direction, same degree of travel (90 degrees), and had the same resistance as
the original at both ends
of it’s travel (from .05 to 3.5K ohms). But no, it doesnt bolt right up. I
cut a slots in a steel bushing to fit the
drive lugs inside the Ford TPS. The other end of the bushing I crimped down
to fit the D shape of the shaft on the bottom of the throttle pedestal, that
the old TPS used to fit over. A piece of aluminum strap was used to clamp
the Ford TPS to the bottom of the pedestal. The TPS fits snugly in the
recess underneath, and loosening the strap allows adjustment. I cut the wire
and plug from the old one, crimped on some female
spade lugs to fit the terminals of the Ford unit (would have been neater to
use the proper Ford plug, too,
but I couldn’t find that.) Red wire=wiper, green=high side of pot,
yellow=low side of pot. With new TPS
plugged in and igntion on, I adjusted the TPS to give .36 volts measured
between red and yellow wires,
at idle position. Bolted everything down, and went for a test drive- worked
great. Only difference from the original is that now it doesn’t surge at
cruise anymore!
I expect a new Ford TPS would cost about 30 dollars, if you bought a generic
one. There might even be
something out there that would fit better, this was just convenient for me.
BTW- I also replaced both Oxygen sensors this week- used Bosch universal
sensor p/n 11025-
cost 20 dollars each at the local discount parts place! They also work
great. I have a homemade digital
bar-graph voltmeter, and the new sensors react quicker and have a better
voltage swing than the old ones.
Cheers-
Brian Sherwood
'84 XJ-S
'85 XJ6
Next project: adapting a Pontiac window motor to a screw drive for the
sunroof
Date: Thu, 26 Sep 96 19:34:00 PDT
Subject: 1 more post on CD changers ( long & if not interested, move along )
I have gotten several questions about my CD changer hookup. I hope this will
clarify things. If you don’t remember the big stink I raised not too long
ago about selling my stock radio to a fellow Jag-Lover,( yes, the stink was
my fault ) well anyway I do not have the stock radio in my XJ-S. So here
goes what I know about them.
A RF CD changer will work on ANY car that has a radio. What it does is
connect to your radio’s antenna jack in the back. The antenna lead then
plugs into an adapter of some sort, depending on the MFG. You can normally
set this to broadcast through your antenna lead on 1 of 2 channels ( like
choosing channel 3 or 4 on your VCR ). To listen to your CD’s, you tune
into the station you chose & by using a separate display / controller,
listen to your music. On my RF unit, it reduces the signal strength
slightly when the changer is off, and more noticeable when the changer is
on. The installation includes mounting the changer, hooking up the power
leads, the cord & adapter that connects to your radio antenna lead at the
radio & a cable for the display / control unit.
There are other radio / CD changers on the market where the changer is
controlled by the radio via a direct cable, not through the antenna lead.
This has many advantages in sound quality, astestics among other things.
The NON STOCK radio I have in my Jag will control a CD changer that is
designed to be controlled by my type of unit. That does not include a RF
model, as it is designed to operate independently of the radio and takes the
long way to get to your radio. ( the FM signal through the antenna )
The adapter I mentioned allows me to connect my RF CD changer to the same
connection as a CD changer that is designed to be controlled by the radio.
I CAN NOT control the changer functions through the radio, but with the
changer no longer connected to my antenna lead, I no longer have the signal
loss or need to give up one of my station pre-sets and the sound is a little
better as there is not as much loss in sound frequency as there is on a FM
station.
If you have one of the stock non ALPINE units, or a stock unit that does
not have any capability of controlling a CD changer & want to keep the stock
radio in place, then your only option is a RF unit. ( or a portable CD with
the tape deck adapter ) If you have the ALPINE or other stock unit that will
control a CD changer, then you should be able to get a CD changer that is
designed to be used with that radio. If the XJ-40 or other models have this
type of unit & is pre-wired, then getting that unit & installing it should
be very easy to do and cost much less then a new radio / CD changer.
Ok, everybody can wake up now…
John Himes
88 XJ-S 97K Miles
Date: Thu, 26 Sep 1996 23:49:22 -0005
Subject: Dumb Things
I’m sitting here reading e design, a newsletter dealing with energy
conservation issues (I’m a mechanical engineer, this is junk mail
for us). There’s a section on a specialist in Indoor Air Quality
named Joe Lstiburek who, along with the rest of us, is fed up with
the enforced application of Northern building standards on Florida,
and this guy has created a list he calls “The Top Ten Dumb Things to
Do in the South”. It’s a compendium of bad building designs, mostly
based on ideas that work just fine in colder, drier climates.
Bear with me here. So, I’m just scanning this newsletter, and the
following sentence catches my eye: “Joe’s ‘Top Ten List’…addressed
only building-related dumb things, avoiding any mention of other dumb
things such as grits-flavored ice cream or pronouncing jaguar as if
it rhymed with quagmire.”
Well, whattaya know. Jag content!
| - Palm’s Postulate
Date: Fri, 27 Sep 1996 16:04:50 +1200
Subject: RE: jag-lovers-digest V2 #382
How do you pronunce fawd ?
Sent: Friday, 27 September 1996 02:17
Subject: Re: jag-lovers-digest V2 #382zavadsky@austin.ibm.com (Vlad Zavadsky) wrote:
let us not forget, Jaguar is Ford – the owner makes the rules…I work at Ford and I pronounce it “Jag-you-are”. Many Americans I
accents from the south, east coast, midwest, etc.Cheerio.
Date: Thu, 26 Sep 1996 22:36:29 +0100
Subject: Re: Jaguar Part-Yards
Was just wondering if anyone knows of any good part-yards in the
U.S., U.K., or Australia? Particulary interested in finding parts for
an XJ40, namely the two front headlamps and bulb fail/controllers.
Very hard to find these lamps used! All scrap-yards will only sell the
whole front-end of the car.
Found these Jaguar pars ads in (UK) Exchange & Mart,
hope they are of some use…
Just Jags +44 1922 37779
David Manners jag/daimler parts +44 121 544 4040
Classic components Europe Ltd +44 1325 72777
FB components +44 1865 724646
Jaguar Specialist Breakers +44 115 927 7602
SC Parts Group Ltd +44 1293 547841
Just Jaguars Kent +44 1634 296860
Leicester Jaguar Spares +44 116 253 2021
Regards
Gordon
1990 Sovereign 4.0
Date: Thu, 26 Sep 1996 23:46:44 +0700
Subject: Front oil seal
So what’s the deal with these front crankshaft oil seals on XK-type
engines? Why do they die regularly? Is it the seal that dies or the crank
that kills it? Since I have to replace mine, is there a better
solution than the stock oil seal?
BTW, while I have the engine out of the car (for more than the oil
seal) I’m going to replace the injector harness. Any suggestions on
sources?
TIA
Greg Price
'85VdP
Date: Thu, 26 Sep 1996 23:51:04 GMT
In message 199609261331.JAA01328@gemini.aero.odu.edu Thomas Alberts writes:
Guessing:
Because Germany will tax non-cat cars incredibly highly from next year ?
(I don’t live there anymore
Regards
Stefan Schulz
jaguar@suaviter.demon.co.uk
Date: 27 Sep 96 02:56:21 EDT
Subject: Re: XJ-S Seat Mounts
John,
You have just experienced another of the impossibilities that jaguar
has engineered - the nuts that can be unscrewn, but not be put back!!
Anyway a 72 Ford mustang Cabrio is one of the most beatiful Mustangs ever made.
Since the seventies American cars have progressively become so ugly it is
impossible to understand for a European why they continue to sell. The later
style mustangs are ugly too
Although a Mustang is not the same as a Jaguar, treat that mustang well, or sell
it to me!.
Regards Jeffrey Gram
Date: Fri, 27 Sep 1996 10:24:36 -0700
Subject: XK8 V.I.P. sneak preview, Oslo Oct. 9th
Hi all,
The new XK-8 will be presented at a event in Oslo, Norway on October 9th. I have
also been invited to the V.I.P. (sneak) preview.
I live on the opposite side of the country, and on that particular day I’m
leaving for Finland. Incidently we are passing through Oslo on our way, but
unfortunately I won’t have time to pop by the dealer :.(
'twas fun to get invited though, and a very nice invitation it was too. It kinda
makes you feel like you’re part of something special, something private, but
hey, that’s what we all are; privileged, and willing to make sacrifices to
remain among the few permitted to convey themselves in such a luxurious way…!
(The rain is pouring down this morning, and I’m getting all sentimental while my
Jaguar, in spite of 1st class cover, is getting wet and cold and… O h c’mon,
snap out of it!)
Bard
______ _ ! Baard Th Hesvik, Telesoft AS
/ _ / _ _ _ / / ! Longhammarvn 7, N-5500 Haugesund
/ // / // /_ / / -/- -/- ! T: +47 52735000 F: +47 52717040
/ /_ / /_ / // / /_ ! E-mail: baard@telesoft.no
Date: Fri, 27 Sep 1996 09:35:58 +0100
(Tongue firmly in cheek)
…only when you start spelling aluminium properly as well?
Mark
Mark Stiles - Academic Development Manager
IT Services
Staffordshire University
01785 353410
Date: Fri, 27 Sep 1996 10:56:21 -0700
Eric,
Without any further ado, it doesn’t; a Series II nose does not bolt right on a
Series I front end. Also, it would be sacrilege! Who would want to destroy a
beautifully sculptured front as the one of the Series I XJ Saloon?
Steve,
The dash roll is a piece of cake, whereas the #$ing conversion is a disaster.
If it’s a Jaguar you want, fitting an XK engine is essential. There was one
posted on this list not long ago…, complete with transmission and all!
Have a nice day
Bard
Date: Fri, 27 Sep 1996 10:59:35 -0700
Subject: S-I to S-II and dash roll.
Eric,
Steve,
Have a nice day
Bard
Date: Fri, 27 Sep 1996 10:45:16 +0100
Subject: Re: Series III rough take off and idle.
I wondered about a similar scenario with my 83 XJ6 S3 with 115k on the clock.
When cold it occasionally felt really rough if one wanted to accelerate, ie
on to a motorway. I put it down to the fuel filter being choked (again).
Anyway it all got resolved when I did a 1100 mile trip this week up to
Inverness in the north of Scotland. Car was running like a dream, mile after
mile at 85-90. Then I noticed a miss in the beat of the engine when I gave
the car a little more throttle. I slowed down to 70 tried to accelerate but
the engine went down to 3 cylinders, but OK if I carried on with an even
throttle setting. The car then started slowing down on its own accord, so
tried giving a burst of full throttle - the engine died, shortly followed
by an enormous bang with a huge black cloud coming from the exhausts.
B****r it I thought, and coasted to the next motorway emergency phone.
The RAC arrived with 20 minutes, diagnosed a failed ignition coil. Repleaced that and I was on my
way again. Total down time 40 minutes, and 21 pounds
for the new coil, not bad eh?
Did the 500 miles to Inverness in 7 hours driving time so the old beast
does behave overall.
Back to the original posting, I now find that I have no roughness whatsoever
when cold, so presumably I have been suffering from a faulty coil for some
years.
As a matter of interest for those of you who keep inquiring about fuel
economy. The entire run was 1,078 miles of which I guess that 700 were
fast motorway miles. Unleaded petrol was used ( as is always ) and
55 gallons ( 252 litres ) consumed giving an mpg of 19.6.
Normal running around ( 10 miles at a time ) gives 15.5 mpg.
Roly
runs very well.I am at a loss on how to troubleshoot this and would welcome any advice.
Roger Langley
Roly Alcock, (Postmaster) Principal Systems Engineer
Redac Systems Ltd, Tel: 01684 294161 ext. 211
Zuken-Redac Group, Fax: 01684 298902
Green Lane,
Tewkesbury, E-mail: roly@redac.co.uk
Gloucestershire, GL20 8HE, UK Web: http://www.redac.co.uk
Jaguar Enthusiasts Club representative in the UK for Three Counties Region
Date: Fri, 27 Sep 96 12:19:00 GMT
Subject: Re: Fuel
My owners handbook and the Haynes manual are quite clear on the fuel to use.
They both quote 98 Octane (leaded fuel) for the UK and 87-89 Octane
(unleaded fuel) for the US. I have checked this with my local Jaguar agent
and they suggested I use the unleaded plus fuels. The truth of the matter
is this: so long as the engine doesn’t knock/ping carry on regardless. I
expect in the future I will have to re-tune for unleaded use but until then
it’s unleaded plus.
As an addition to this has anyone added catalysts to a non-catalyst series
III 4.2, if so what’s involved and how much does it cost, UK prices only
please.
Barrie Dawson
Chatham, Kent England
1985 Series III Sovereign (77,000 miles)
To: jag-lovers
Subject: Re: Fuel
Date: 26 September 1996 18:20
fuel.
| - Palm’s Postulate
Date: Fri, 27 Sep 1996 07:20:20 -0400 (EDT)
Subject: Re: Change V-12 Head Gaskets Every 30,000!!!???
No. Cylinder head warping is attributed to severe over heating. If you
blow a head gasket and drive it a real long time without fixing it, then
you might be risking warping. You don’t have to change head gaskets
as a precautionary measure.
Thomas E. Alberts
End of jag-lovers-digest V2 #384
id for jag-lovers-digest-out; Fri, 27 Sep 1996 23:25:58 +0200 (MET DST)
Date: Fri, 27 Sep 1996 23:25:58 +0200 (MET DST)
Message-Id: 199609272125.XAA03580@ekeberg.sn.no
Subject: jag-lovers-digest V2 #385
Precedence: bulk
jag-lovers-digest Friday, 27 September 1996 Volume 02 : Number 385
Valve Seat Recession
Date of '61 Geneva Show
MkII Project Wanted.
Re: Wood Veneer Supplier
Re: Jag: Mk2 electrics - heated rear window
Tachometers and turn signals
Re: swap meet postings -
Re: Front oil seal
Re: Valve Seat Recession
Re: Lower Hose Heaters (no Jag content)
Re: xj-6 purchase
Re: uh-LUM-in-um (zero Jag content)
Re[2]: Fuel
Re:Cats on cats
XJ-40 Tires
Re: 88 XJ-S seat mounts Follow up
Date: Fri, 27 Sep 1996 20:21:56 +0900
Subject: Valve Seat Recession
Japan is completely unleaded. Premium is 100+ octanes and regular
is 90+ octanes. Does a Mark 2 valve seat have to be stainless
steel coated to avoid valve seat recession, or isn’t it necessary?
An independent Jag mechanic here claims that the valves used in the
Mark 2s were made of good quality metal, and valve seat recession
wasn’t a problem so long as I stuck to premium. Does any of you
have any thoughts on this subject?
Regards
Makoto Honjo
Date: Fri, 27 Sep 1996 09:04:52 -0400 (EDT)
Subject: Date of '61 Geneva Show
What day of the year was the E-type introduced at the '61 Geneva Auto
Show?
John Middlesworth
(not on the jag list, so please e-mail me)
From: “Kirbert” palmk%gcn.scri.fsu.edu@vm1.cc.nps.navy.mil
…yup,
It only takes an over-nighter to aquire a bird nest. Two days is more than
sufficient. I guess some birds know a quality neighborhood when they see it.
LLoyd
Date: Fri, 27 Sep 1996 09:08:11 -0600 (MDT)
Subject: MkII Project Wanted.
Fellow Jag-lovers,
Grossman and I are going to be helping a longtime friend
build a MkII Sedan for his wife as a winter project.
We’re looking for a a reasonably priced Jaguar MkII Sedan:
3.8L, 4 spd overdrive - body and interior good, no rust,
disk wheels preferred, PS, no AC equipped models, prefer
leather interior, color and condition of paint unimportant,
mechanicals, suspension and brakes are not of concern.
If you know of any available MkII’s which fit this
description, please give me a call at 303-499-9454
/\ Lawrence Buja http://www.cgd.ucar.edu/cms/southern/
_][ southern@ncar.ucar.edu National Center for Atmospheric Research
________________Boulder,Colorado___80307-3000
Date: Fri, 27 Sep 1996 11:12:34 -0500
Subject: Re: Wood Veneer Supplier
This isn’t plastic. There is no way the veneers match exactly unless you
replace every speck in the car with a matched set.
When the dealer damaged the ski slope in my '88 XJ-S (back in '88), they
ordered four ski slopes to replace it. There was a significant difference
in color and figuring among the four. The dealer was smart enough to order
four so I could pick the one I thought was the closest match instead of
just ordering one and sticking in the car. He returned the other three and
wound up with a happy customer (Made me so happy with how they handled the
replacement I completely forgot they screwed it up in the first place!)
MikeC
Subject: Wood Veneer Supplier
Author: Daniel Kagan 101360.256@CompuServe.COM at Internet
Date: 9/25/1996 6:38 AM
I am about to order wood veneers for the ski-slope and radio surround on my
Does the veneer match properly?
Date: Fri, 27 Sep 1996 17:13:18 +0100
Subject: Re: Jag: Mk2 electrics - heated rear window
Hokay -
In the supplement to the “Electrical and Instruments” section in the shop
manual,
we have details of the heated backlight (window). It’s permanently on in
early cars,
but stating with chassis:
RHD LHD
2.4 119902 127998
3.4 170565 180398
3.8 235046 224417
they have a switch and light, and relay. The relay seems to drop the
current for
the window as well as control the light. Mail me your fax number and I’ll
try
to send it.
…and if anyone in the UK has a spare heater rear window I’d like to buy
it!
Ian
On Sep 13, 1996 10:31:05, ‘ejt@wg.icl.co.uk (Ted Trim)’ wrote:
Fellow Jag-lovers,
I need to share my astonishment with some sympathetic folk…
Setting the scene: I have recently been refitting the instrument panels
and
bulkhead wiring on my 1966 Mk2. This car, 170906, is a late Mk2 and
incorp-
orates a number of 340 type features, but the wiring doesn’t match either
Mk2 or 340 diagrams - and the heated rear window doesn’t feature on
either.
The window heater is operated by a push/pull switch at the right hand end
of
the dashboard (rhd car); there is a small warning light by the switch.
When
stripping the dash assembly I found a 6RA relay mounted at the lefthand
end
of the bulkhead panel. (There is only one other relay on the car, which
is
the horn relay in the engine bay fusebox assembly - neither relay is
fitted
in early Mk2s). I assumed this second “mystery” relay controlled the hrw.
Now, I’ve got used to return wires being smaller gauge than feed wires on
this
car (probably fits with the Lucas “smoke” theory!), but the sole purpose
of this relay appears to be to…control the hrw warning light, enabling
it
only when the lights are on. Honestly. A heavy duty relay and several
lengths
of wire for what seems an unnecessary purpose.So is this how it’s meant to work? I always thought the bulb was just too
dim to see in daylight! Can anyone see any sense in this? Any owners of
similar era Jags got any insight (or better wiring diagrams)?Cheers,
Ted
Date: Fri, 27 Sep 1996 12:34:56 -0400
Subject: Tachometers and turn signals
Hi Gang. Long time no type. I’ve got a question for the troups and a
rebuild
note. Here goes:
Tachometer question:
Do any of you have or know of a conversion circuit for running an original
electric tachometer (circa. 1966) from the ignition system? As you may
know, my '66 “S” Type is now a Chevy-u-war – not that I like that solution
but it is one that works.
I want to use the original electric tachometer. The circuit was originally
a gauge connected to an AC alternator attached to the back of one of
the camshafts. I don’t want to modify the instrument as I intend to
replace the Jaguar engine some day. I would just like to build/buy a
converter that could read the contacts pulses and write the correct
AC voltage for the instrument. High precision is not important as I
never push the red line. Thanks.
Turn signal switch note:
Last evening I rebuilt the turn signal switch for the “S” Type. These
are expensive to replace so rebuilding is an attractive option. The
project was “fiddley” in that there are a lot of springs and contacts.
I drew pix of everything first to aid in reassembly. With the help of
my wife’s steady hands, functioning as a kinda “soft vice” (Boy,
there’s more in that statement that meets the eye!), the reassembly
went well. The only hitch was the (lack of) quality of the replacement
nylon “spring/latch/clip/thing”. The brass contact for one of the
connections
fit too snugly (read: the hole in the nylon “thing” was too small). I had
to ream the hole slightly to allow the contact to move. While fiddling
with this problem I trashed the frail little spring that moves the contact.
Fortunately, I have a box of odd springs where I found a suitable
replacement. The switch now works beautifully.
Rick Lindsay
Date: Fri, 27 Sep 1996 09:44:16 -0700
Subject: Re: swap meet postings -
So, what do you all think? Take a look at the existing Ford conference
and let me know if this could be of value to the Jag Lovers group.If many of you are in favor I could have it up and running this
weekend.
Gunnar,
This looks GREAT…you do a wonderful job keeping us all up to
date and connected. Thank you again for your efforts on our behalf.
I look forward to the additional conference if others find it as
interesting and very useful.
Don Farr
Donald R. Farr
Paradise Valley, AZ 85253
(602) 948-7499 - fax
91 Sovereign
d.farr@phx.cox.com - e-mail
http://people.phx.cox.com/dfarr/dfarr.htm - Don’s Homepage
http://people.phx.cox.com/dfarr/jetta1.htm - Jetta Notebook Computers
http://people.phx.cox.com/dfarr/march10.htm - Wireless products
http://people.phx.cox.com/dfarr/ncs1.htm - National Consulting Services
Date: Fri, 27 Sep 1996 10:04:20 MDT
Subject: Re: Front oil seal
These seals ride on the harmonic balancer and although it may be hard
to believe, the rubber seal wears a groove into the metal rotating
surface. If you have a groove, even a small one, the seal will
either not seal at all in severe cases or begin to leak prematurely.
The standard fix is to go to your local auto machine shop and order a
harmonic balancer “sleeve kit”. This is a thin walled sleeve that
press fits over the harmonic balancer and provides a good clean
sealing surface. I have done this several times with very good
results. Oh yeah, if you are really uptight, you could simply buy a
new balancer. the sleeve kit cost roughly 15$US and the balacer
sertainly 10-20 times more. Your choice.
Kind Regards,
Jim Cantrell
Date: Fri, 27 Sep 1996 16:19:35 GMT
Subject: Re: Valve Seat Recession
I think your mechanics advice is entirely sound. The XK engine head is
made of aluminum, with valve seat inserts of high quality steel. They
should survive use of unleaded very well. Valve seat recession has nothing
to do with octane rating as such, but I think you should also stick to
premium, especially if you have a 9:1 compression engine.
Egil
Email: egilk@sn.no Voice: +47 22523641, 92022780 Fax: +47 22525899
Snail: Egil Kvaleberg, Husebybakken 14A, 0379 Oslo, Norway
URL: http://www.sn.no/home/egilk/
Date: Fri, 27 Sep 1996 16:08:53 GMT
Subject: Re: Lower Hose Heaters (no Jag content)
be effective.
Nah, half an hour up to maximum one hour does it. People with regular habits
(not me use an ordinary electrical timer for controlling it.
The prime point about the engine heater is that the strain on the engine
and various ancillaries will be greatly reduced compared to starting the
engine from freezing. This is probably a good point, and you get the added
benefit that the heater will start working much earlier.
Egil
Date: Fri, 27 Sep 1996 19:18:56 +0200 (MET DST)
On Fri, 27 Sep 1996, Donald R. Farr wrote:
Gunnar,
Donald,
Thanks, but I think you’re confusing me with Nick Johannessen who’s the
person behind the JagWeb web pages and the JagLovers email list. All I’ve
done for the Jaguar/Daimler community so far is to ask a lot of stupid
questions on JagLovers. I plan to change this now though, with the
creation of the “Jaguar/Daimler used parts exchange” (thanks for the
name, Kirbert!)
Nick does a great job with the list and the web pages and deserves our deep
gratitude.
Gunnar
Gunnar Helliesen | Bergen IT Consult AS | NetBSD/VAX on a uVAX II
Systems Consultant | Bergen, Norway | '86 Jaguar XJ6 4.2 Sovereign
gunnar@bitcon.no | http://www.bitcon.no/ | Vicki who? What .sig virus?
Date: Fri, 27 Sep 1996 13:05:08 -0500
Well, now you’ve gone and done it for sure! Your innocent question (you
are innocent, aren’t you?) will surely ignite another round of purist
versus lump-lovers. (Jag-lumpers@ns.no?? Naw, Jag-Lepers@ns.no!)
Anyway, here’s my pint of petrol on the flames . . .
Some people, including some on this list, will say that a Chevy V-8 in a
Jag increases its value. Many regard it as an unseemly social error,
unworthy of the class of gentleperson we presume to be associated with
these fine motorcars. The rest would just tie the perpetrator to a stake
and toss on the torches.
Regardless of my personal opinion, I would say that an XJ-6 with a Chevy
V-8 will not serve as any form of useful introduction to Jag sedans.
That’s not to say that you might not have a long happy relationship with
it. If it makes you happy, then by all means buy and enjoy it. But it
will never be a Jaguar, it will be an Jaguar body with a Chevy engine.
MikeC
______________________________ Reply Separator _________________________________
Author: Steve Draper s_draper@wcsr.com at Internet
Date: 9/26/1996 1:43 PM
I just learned the car has been converted to a 350 chevy. Is this fatal to
the purchase, or would this car, for the right price, be a good intro to
jaguar sedans, and thus worth further inquiry? Your opinions and wisdom
are desired.
Date: Fri, 27 Sep 1996 13:19:06 -0500
Subject: Re: uh-LUM-in-um (zero Jag content)
This is a Mime message, which your current mail reader
may not understand. Parts of the message will appear as
text. To process the remainder, you will need to use a Mime
compatible mail reader. Contact your vendor for details.
- –IMA.Boundary.525548348
Content-Type: text/plain; charset=US-ASCII
Content-Transfer-Encoding: 7bit
Content-Description: cc:Mail note part
Only if you spell it correctly. The Brits (Pommeys?) and Americans both
pronounce it the way it is spelled. We just spell it different.
uh-LUM-in-um is spelled aluminum
al-u-MIN-e-um is spelled aluminium
(probably a different alloy . . .)
The Brits clearly have a large surplus of vowels (e.g. colour instead of
color). Personally I think they should load all the extra vowels in large
cargo planes and drop them over Bosnia which is suffering from a massive
vowel deficit. if the people and place names that crop up in my newspaper
are any indication.
MikeC
Author: Eric Henning henning@fp.com at Internet
Date: 1/24/1995 3:58 PM
Do I now have to say any aluminum parts in my car are now made of
eric
henning@fp.com
- –IMA.Boundary.525548348–
Date: Fri, 27 Sep 1996 13:23:41 -0500
Subject: Re[2]: Fuel
Actually, I think the correct answer is to read your owner’s manual and use
the recommended octane.
Most modern ECUs can compensate for lower octane fuel, but at the expense
of performance and economy.
On the other hand, it is generally worthless to use higher than recommended octane fuel without reprogramming the ECU. MikeC ______________________________ Reply Separator _________________________________ Subject: Re: Fuel Author: Thomas Alberts talberts@aero.odu.edu at Internet Date: 9/26/1996 4:28 PM I live in the United States and drive an 87 XJS. I fill it up with unleaded fuel, 87 octane. Should I go the extra buck and start using the premium fuel or are these cars better at regular unleaded fuel. They are not better on 87 octane, but if it runs OK on 87, i.e. doesn’t ping or diesel, then there is no reason I know of to change to higher octane. There was a big discussion of this issue on the list just about 2 months ago. Thomas E. Alberts From: Gunnar Helliesen gunnar@bitcon.no Date: Fri, 27 Sep 1996 20:15:07 +0200 (MET DST) Subject: Re:Cats on cats Michael Frank mfrank@westnet.com wrote:
This is going to sound a bit obvious but my advice would be to not to let
the cat into the garage in the first place…Clearly not written by an owner of a four-legged type cat. Anyone who has
ever owned a cat would tell you that it is the cat’s choice whether or not
people can use the garage.
I’m sure you meant “Anyone who has ever been owned by a cat”.
I’m currently owned by two cats, Whisky who has four legs and Alexandra
who has four wheels. Both are female.
They have many similarites, including the tendency to purr when they are
properly fed and treated with TLC. One step out of line though and they
both bite.
Gunnar
Date: Fri, 27 Sep 96 16:15:08 CDT
Subject: XJ-40 Tires
I need to replace the tires on my 1988 XJ-40 real soon. Any recommendations
as to the best choice would be greatly appreciated. I know the list has hit
this and similar topics in the past, but I cant remember if we ever came to a
conclusion. Is there an inexpensive but good solution, rather than buying
the expensive Pirellis.
Again, any help greatly appreciated.
Paul Lacey, Texas
Date: Fri, 27 Sep 1996 14:38:00 -0500 (CDT)
Whereas my 'Jersey accent we all know is proper.
Obviously, you really meant to say “Joy-sey.”
Larry Lee
Date: Fri, 27 Sep 1996 15:22:31 -0400 (EDT)
On Thu, 26 Sep 1996, Gunnar Helliesen wrote:
Now for a very important question: What should we call it? “JagLover’s
swap meet”? “Jag Lovers’ used parts exchange”?
How about Jag-u-parts?
If we can agree on how to pronounce it.
John
Date: Fri, 27 Sep 1996 15:26:23 -0400 (EDT)
Subject: Re: 88 XJ-S seat mounts Follow up
the screw so it would stay in place while tightening. ( don’t need or want a
loose seat , in my car that is ) My quickie glue job did not hold the front
2 nuts, so instead I used a fat, flathead screwdriver to hold the nuts in
place while I started the screws.
On my car, I substituted regular hex nuts. Taped them into a regular box end wrench (punched a hole in the tape so the bolt would start) and the tape keeps the nut from dropping out of the wrench while you snug things up. John End of jag-lovers-digest V2 #385 ******************************** Return-Path: @owner-jag-lovers-di1 Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4) id for jag-lovers-digest-out; Sat, 28 Sep 1996 02:10:50 +0200 (MET DST) Date: Sat, 28 Sep 1996 02:10:50 +0200 (MET DST) Message-Id: 199609280010.CAA15457@ekeberg.sn.no X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f From: @owner-jag-lovers-di1 To: jag-lovers-digest@sn.no Subject: jag-lovers-digest V2 #386 Reply-To: jag-lovers@sn.no Errors-To: @owner-jag-lovers-di1 Precedence: bulk X-Newsgroups: mail.jag-lovers-digest jag-lovers-digest Saturday, 28 September 1996 Volume 02 : Number 386 The 1986 XJ Innovations, A/C & Kickdown Re: Series III rough take off and idle. Introduction Re: Wood Veneer Supplier Re: [SIII XJ6] Rust? Re: Car Show, speech, S1 to S2 Part Yard info - Thanks! Re[2]: Fuel (No Jag content) Re: Date of '61 Geneva Show Re[2]: Fuel Re: New List Member Questions [JAGSWAP] The Jaguar/Daimler used parts exchange is open for business! XJ6,SIII seat wires ? Correction on ‘1986’ Innovations Re: Front oil seal ‘88 XJ-S V12 (UK) steering rack replacement Re[2]: Prononuciation & Price (Irrelevant jag content) From: Daniel Kagan 101360.256@CompuServe.COM Date: 27 Sep 96 16:40:25 EDT Subject: The 1986 XJ Innovations, A/C & Kickdown When no lesser an authority than Nigel Thorley disagrees with my mechanic, David, I have to sit up and take notice. So I noticed when my mechanic disparaged as insignificant the 1986 innovations in the Series III V-12 XJ Saloon. That was when the HVAC (heating, ventilation, a/c) system changed to the Mark 3, and when the GM-400 automatic transmission’s shift points were adjusted to give the car more overtaking oomph (which is, no doubt, the correct technical term). Thorley’s book, The XJ Companion, implied the 1986 changes were great improvements both to the XJ’s climate control and to the V-12’s GM-400 auto ‘box. The innovation in the HVAC was the move to a computer controlled system, but David says it works no better than the 1985 system, and in any case, apart from the troublesome computer, it uses all the same hardware from the previous year. As for the auto tranny, whose 1986 recalibration so impressed Thorley, David said that the perception of power was hardly changed; you’d be hard pressed to tell, he said, whether or not you were driving a recalibrated GM-400. Who’s right? Are these changes worth having, and worth paying more for when shopping for Series III cars? From: JimJag@aol.com Date: Fri, 27 Sep 1996 14:53:42 -0400 Subject: Re: Series III rough take off and idle. if i understand the symptoms you described correctly, my 85 xj6 vdp did the same thing (138,000 miles). what was the cause, you ask? a faulty fuel injector. basically, the car ran on only five cylinders with occasional surges when the sixth cylinder fired. the injector was replaced and now the car idles and runs fantastic!!! From: “Makoto & Ann Sado Honjo” fm7m-hnjy@asahi-net.or.jp Date: Sat, 28 Sep 1996 06:43:07 +0900 Subject: Introduction Fellow Jaglovers: I am a soon to be Mark 2 owner in Tokyo, Japan, who has determined to lay himself prostrate at the altars of that Seductive Feline God instead of at the altars of that Japanese businessman’s qualification, the Scottish links game (both are time consuming, can’t do both). Some history on my affection to the Jag. This is a love that has been slowly burning ever since I spent a year in Canterbury (the original where the Archbishop sits, not its namesakes) in the early =9170s. I could have become a S series owner about ten years back, but an acquaintance of mine (who owned a Mercedes 500SE) warned me of the unreliability of Jags in general and kept me from taking the plunge. Subsequent inputs (of which a fair extent is confirmed in the writings within these Web Pages) have confirmed this aspect about the Jags. Actually the ultimate statement on this front must have come from a Jag salesman I met recently who said, "gone are the unreliable days; now the Jags’ quality is approaching (I need to italicize =91approaching’) Toyota quality." I digress. This summer Jaguar Japan had a sales promotion campaign where they lent out new XJ6-3.2s to some people for a week for free (that’s when I met the aforementioned salesman). I applied and got the right of free use. Flames were rekindled, but not enough to shell out big money for a brand new XJ6. Let’s face it. I think the Jag design hit a low point with their ugly square lights version. The latest series shows recovery in the right direction but probably one more molt is necessary (assuming it’s successful) until the folks in Coventry get things back on track. I started looking at used car catalogues, and turning up at used car dealerships. I felt then the pangs of that unrequited love within me that would make me kill for the Mark 2 and S series, Series 1, 2, and 3 in that order, stir within me. Unlike some other wives, my wife Ann wasn’t too helpful in cooling down my infatuation. Actually she fanned it by telling me the tales of her dad’s perpetual romance with her mom that caused him to stretch to purchase one of the earlier versions of the Ford T-bird. She has yet to regret having fanned my interest, I state I would sincerely hope would continue. Without the common sense feminine restraints, I started my prowl in earnest. In a short while, I came across Yoshida-san, a car broker here who specializes in Jags (yes, Tokyo is big enough to support several of them). He pushed me into the Mark 2, committed to hold my hands till death do we part, and that’s how a Jaguar Mark II chassis no. P2392118W engine no. LE3981-8 will end up on these shores in a couple of months. This is of course a tale of sight unseen impulse buying on a major scale pure and simple. But, as many of you would agree, there is something irrational, driving, and sensuous (need I say masochistic) about Jag ownership, especially the ownership of the classic variety. Fellow Jaglovers, the experience has just started for me. Pray accommodate this humble initiate amongst thine ranks, pray with me together at the altars of that Seductive Feline God’s Temple that mine travails with the Mark II be relatively minor so that the experiences of its ownership be not so punishing as to try my love for the Jag. Hold my hands when the problems do get serious. Amen. Makoto Honjo Makoto Honjo Phone/Fax +81-3-3473-1848 From: cobac@ix.netcom.com Date: Fri, 27 Sep 1996 12:16:14 -0700 Subject: Re: Wood Veneer Supplier At 11:12 AM 9/27/96 -0500, you wrote:
replacement I completely forgot they screwed it up in the first place!)MikeC
Thats funny, when I mentioned to my dealer that my Ski slope was damaged and
I wanted to buy a new piece, he told me that the new piece was $500 (XJ40),
and that I should send it to a place in Arizona for refurbishment instead of
buying new. There work should cost around $100, and the piece looks like
brand new, and supposedly matches the rest of the wood in the car. I
haven’t tried the dealer advice out yet though, sounds like I’ll save a lot
of money if I do.
cobac@ix.netcom.com
Date: Fri, 27 Sep 1996 21:10:49 +0200 (MET DST)
Subject: Re: [SIII XJ6] Rust?
“Richard G. Ried” riedr@osuergo.eng.ohio-state.edu wrote:
- Rust - I live in Columbus, OH. Our winters are
not bad, but the city dumps piles of salt all over the
roads each winter and the temperature fluctuates
from just below freezing to just above. Is the XJ6
(series III) a car that will rust out from under you if
driven in these conditions?
Very good question! I believe the answer is a resounding “YES” unless
you’re prepared to take very good care of it. I live in Bergen Norway,
where the climate is very similar to what you describe and where the
city also dumps piles of salt at the slightest hint of freezing weather.
I own a Series III XJ6 from 1986 that spent most of it’s life in Oslo.
Two years ago the PO (previous owner) had the car stripped to the bare
metal, some rust removed and the whole car resprayed. Already it’s showing
alarming signs of deterioration around the wheel arches, the lower edges
of the doors and also around the grille. Don’t misunderstand me, it’s not
falling apart but the paintwork has alarming “bubbles” in it that are the
tell-tale signs of rust.
I suspect the body shop that did the work two years ago didn’t do a very
good job of it. I’m taking no chances when it comes to rust, I’m having a
body shop I trust go over the car from front to rear with a standing
order to remove every hint of rust they can find. This of course means
ruining a perfectly good paintjob as I can’t afford to have the whole car
resprayed at this point. Neither can I afford a second car so I’ll have
to drive the Jaguar all through the winter regardless of sleet, snow and
salt.
If “my” body shop manages to stop the rust (no signs of re-emerging
bubbles by this time next year) and I can afford it then, I plan on having
the car resprayed. If not, I’ll simply let them go over the car every
year around this time in preparation for the winter and postpone the
respray until I can afford a second car.
The problem is that I don’t want just any old car as alternative
transport, I want a newer Jaguar! I mean, after all, what did I buy a
Jaguar for? To only look at it for 4 months (or more) of the year while I
have to endure driving around in some vastly inferior car?
NO!
I bought a Jaguar because I want to drive it. If the car can’t take it
then that’s too bad. I’ll do my very best to keep it free from rust and
in perfect mechanical order, but if I finally have to give in to the rust
then so be it. I sincerely hope not and I won’t give up without a fight.
The Series III XJ6/12 is the most beautiful machine I know of, it gives
me great pleasure to drive (and own) one. It’s a shame Jaguar didn’t
rust-proof it properly.
Gunnar
Date: Fri, 27 Sep 1996 23:29:50 +0200
[ Eric Henning henning@fp.com ]
| off of a Seriesd II XJ6 and put them on a SI XJ6? Aren’t they the same
| under carriage? So the SII should “bolt” right on?
| I’ve always been curious about this. I like the SI’s except for that giant grill,
| maybe I could graft a SII nose on the front.
Wouldn’t a series 1 with a series 2 front end look just like
a series 2? Why go to all the trouble? Of course, with a
series 2 you wouldn’t get the cool wings-badge on the trunk.
Nick
Nick Johannessen (nick@sn.no) http://www.sn.no/~nick/
XJ6 4.2 '70 SWB Manual/OD BRG LHD - daily driver all year
XJ6 4.2 '82 Auto Regents Grey RHD - Wifes daily driver
Visit JagWeb.enthusiast at http://www.sn.no/~nick/jaguar.html
Visit JagWeb.com at http://www.jagweb.com
Date: Fri, 27 Sep 1996 12:24:23 -0700
Subject: Part Yard info - Thanks!
Hi jag lovers!,
Thanks for everyones info on part yard numbers that I requested. I
found a lot of interesting places who had a lot of parts. No one had
american version headlamps though, but the yards told me the round lamps
look nicer on the XJ40 and are cheaper to replace if broken. So, I guess I
can live with the round lamps, considering almost everyone seems to prefer
them. I appreciate all locations around the world everyone replied with.
Most places had a lot of other useful and hard to find parts also.
Thanks again!
cobac@ix.netcom.com
Date: Fri, 27 Sep 1996 13:40:54 -0500
Subject: Re[2]: Fuel (No Jag content)
Bad advice. Many cars have knock sensors so that the ECU can avoid pinging
with lower than recommended octane fuel. I suspect CR might have actually
recommended not using higher than the factory recommended octane, which is
a waste of money. Using ping as a useful indicator is pretty obsolete
these days. (Unless, of course, you’re working with an old car.)
MikeC
Subject: Re: Fuel (No Jag content)
Author: “Preferred Customer” lang0080@gold.tc.umn.edu at Internet
Date: 9/26/1996 4:08 PM
Consumer Reports has always maintained that as long as the car does not
knock (ping, detonate)
then the lower octane makes more sense.
Date: Fri, 27 Sep 1996 15:00:23 -0500
Subject: Re: Date of '61 Geneva Show
- –IMA.Boundary.945458348
According to Porter’s definitive history of the E-Type, the car was
shown to the press in Geneva on Press Day, Wednesday, March 15th. That
is the day before the show officially opened. So it’s official
introduction at the show was Thursday, March 16th.
MikeC
John asked:
Show?
John Middlesworth
- –IMA.Boundary.945458348–
Date: Fri, 27 Sep 1996 13:32:26 -0500
What market was the car built for? There are two basic numbers
formerly used in the US. Now the Federal government requires that the
average of the two be the number posted on the pump. Naturally, the
rest of the world doesn't follow US Government regulations, generally
preferring to remain independent and screw their own citizens using
homegrown bureaucracies and regulations.
You are doing the right thing. Follow the manual. Other manuals in
other countries or for different years may well have different
numbers.
MikeC
Subject: Re: Fuel
Author: “Claus; Mike” claus@wg.com at Internet
Date: 9/26/1996 4:26 PM
The owners manual for my car clearly states I should use 93
octane. There is also 'Unleaded Premium Only' stenciled into
the gasket around the gas cap. I think Jaguar is pretty
serious about recommending premium fuel.
- mclaus ('93 XJ-S)
Subject: Fuel
Author: Jana treadwel@ieway.com at WG-RAL-SMTP
Date: 9/26/96 3:35 PM
JANA
treadwel@ieway.com
From: rrichardson@eurekanet.com (Robert J. Richardson)
Date: Fri, 27 Sep 1996 18:17:31 -0500
Subject: Re: New List Member Questions
Hello All:
I have recently joined the list and have been lurking
around for a few days, reading the various posts on
the XJ6 Series III.I have never owned a Jaguar, my last British car was
a '77 MGB, that I sold back in '89. Since then I have
owned a variety of cars: Jeeps, Saabs, and BMWs.I know of few cars that match the beauty of the
Jaguar, and keep considering getting one.I have read the excellent on-line books from the
Jag-Lovers web site, but am still a little concerned
about a few things. Hopefully the list members may
be able to shed a little light on the following items:
driven in these conditions?Cost and availability of parts. I am used to paying
through the nose on trim and other “special order” bits,
but do the normal wear items cost a fortune?
(Will it break the bank to keep it running?) From the
great XJ6 book, it sounds like most common items are
generally in stock in major cities.Can anyone recommend a reputable shop in the
Central Ohio (USA) area that could inspect a car for
me prior to purchase? There are a few Jaguar
specialists in the phone book, but I hate to blindly
trust someone without a recommendation.Thanks for you time! Private e-mail replies to any of the
above questions, or on Jaguar ownership in general
are greatly appreciated.–Rick (riedr@osuergo.eng.ohio-state.edu)
Richard Ried
Associate Editor and Lab Manager
Biodynamics Lab
Industrial, Welding, and Systems Engineering
The Ohio State University
210 Baker Systems, 1971 Neil Avenue
Columbus, OH 43210
Tel: (614) 292-20
Richard. I don’t have an XJ6 to offer you a comparison, but I do have a Jag
that has spent many of its winters here in Athens, Ohio, which is about 75
miles southeast of you. It’s a 1964 Series I E-Type FHC and I had it here
in Athens from 1968 to 1972 and it then weathered in the salt air of
Naples, Fla., until we returned to Athens in 1980. The moist Gulf air got
to it in Florida and I had the other sills replaced, the under bonnett
sheet metal and the pan under the gas tank. Other than that, I think if one
keeps a car washed fairly often in winter, the salt on the roads won’t
affect a Jag any more than other makes of autos. I don’t usually squirm
when I have to buy parts (I guess I would if I had to replace the bonnet)
and I have it serviced regularly at the local BP station.
There’s a jag dealer in Columbus. I’d check with them. After all, they may
view you as the buyer of a new Jag one of these days. Good luck.
Date: Sat, 28 Sep 1996 00:16:19 +0200 (MET DST)
Subject: [JAGSWAP] The Jaguar/Daimler used parts exchange is open for business!
Folks,
I’m pleased to announce that the “Jaguar/Daimler used parts exchange” is
now open for business. You’ll find it at the following URL:
It is of course open to everyone free of charge.
Have fun with it!
Gunnar
Date: Fri, 27 Sep 1996 21:59:55 +0000
Subject: XJ6,SIII seat wires ?
Only a quick question:
My '86 SIII UK car has two wires, brown and purple I think, coming from
the bottom of the passenger seat (none on drivers side) going into the
floor underneath it.
Does anyone know what they are for ?
I don’t have anything fancy like electric seat adjustment or anything
like that, its just a plain XJ6 not a Sovereign. The wiring looks like
its orginal, not an add on.
Thanks
Pete Hamel
Date: 27 Sep 96 17:55:34 EDT
Subject: Correction on ‘1986’ Innovations
Oops. A correction to my earlier post about what I called (wrongly) ‘the 1986
innovations’. I checked with Thorley, which I should have done BEFORE I wrote my
post, and discovered that the GM-400 recalibration was in 1989, not 1986. I also
discovered that my mechanic was not literally correct in saying that ALL the
HVAC hardware except the computer stayed the same from 1985 to 1986; Nigel
Thorley notes that from 1986 a new protection clutch system for the compressor
was used. Lastly, Thorley’s book is not called, as I said, ‘The XJ Companion’;
it’s proper title is Jaguar XJ, The Complete Companion. Sorry, Nigel.
Date: Fri, 27 Sep 1996 18:31:48 -0400 (EDT)
sertainly 10-20 times more. Your choice.Kind Regards,
Jim Cantrell
Sorry, this is the second time I’ve seen this info posted, but I simply can
not believe you have done this on an XK engine. The reason is the seal
does not touch the harmonic balancer in any way. Nor it’s locating cone.
The seal has it’s own distance piece it rides on. What’s needed to do the
job correctly, in addition to the seal, is:
C40147 distance piece
EAC8101 O-ring
And, if you are unlucky, a pan gasket set.
The two parts should be under $30 from the dealer.
Randy K. Wilson
randy@taylor.infi.net
Date: Thu, 26 Sep 1996 23:22:41 GMT
Subject: '88 XJ-S V12 (UK) steering rack replacement
Greetings,
Could some of the list.members who recently replaced their steering racks
and/or enthused about the aftermarket bushings have a look at the questions
below please ? Looks like I’ll need the answers soon…
The service manual specifies the use of the Jaguar ball joint separator
JD24 and Steering Rack checking fixture JD36A. Is it possible to use any
other ball joint separator and ignore the checking fixture, aligning the
rack by look and feel instead ? -
Anyone have a UK supplier and part number for the aftermarket bushings
WITH WHOM THEY HAD GOOD EXPERIENCES ? -
How difficult is it really ? Any non-obvious caveats ?
Stefan Schulz
Date: Fri, 27 Sep 1996 13:46:23 -0500
Subject: Re[2]: Prononuciation & Price (Irrelevant jag content)
So, if the owner makes the rules does that mean that a Jag with a small
block Ford V-8 will now be socially acceptable? And the ones with Chevy
lumps are automatically excommunicated?
How do the Brits say “lump”
MikeC
Subject: Re: Prononuciation & Price (Irrelevant jag content)
Author: zavadsky@austin.ibm.com (Vlad Zavadsky) at Internet
Date: 9/26/1996 11:23 AM
I would like to know how people at Ford pronounce Jaguar. After all,
Vlad
85 XJS
End of jag-lovers-digest V2 #386
id for jag-lovers-digest-out; Sat, 28 Sep 1996 20:16:35 +0200 (MET DST)
Date: Sat, 28 Sep 1996 20:16:35 +0200 (MET DST)
Message-Id: 199609281816.UAA29369@ekeberg.sn.no
Subject: jag-lovers-digest V2 #387
Precedence: bulk
jag-lovers-digest Saturday, 28 September 1996 Volume 02 : Number 387
Lead additives for old V12s
European License Plates
Re: [JAGSWAP] The Jaguar/Daimler used parts exchange is open for business!
XJ40 Stumble (long)
diagnostic on XJSIII?
[XK8] UK XK8 on Top Gear next week
XJ40 rear struts
'90 XK40 oil leak
JAGSWAP
Re: The 1986 XJ Innovations, A/C & Kickdown
Re: '88 XJ-S V12 (UK) steering rack replacement
Re: XJ6,SIII seat wires ?
XJ-S Help Book
Re: '90 XK40 oil leak
Request for Closure & Location
only for jag/ford website owners. no jag content what so ever
maintainance/repair manual
Re: XJ40 rear struts
Re: cd changer
Re: Service Manuals
Date: Fri, 27 Sep 1996 16:14:13 -0700
Subject: Lead additives for old V12s
Hello All,
Does anyone have any experience with lead additives for fuel to protect
from burning valves in old V12s? I use CD-2 Lead Additive for my '75 TR6
which used to burn a valve every year or so. It is only an ounce per 10
US gallons and seems to work. Will this work well with the aluminum V12?
Is there a better solution short of hardened seats? Do I even need to
use it, i.e. are the seats already hardened?
I am only a couple days work away from driving my XJ12. It’s been many
months of polishing everything in the engine compartment and fitting new
hoses, wires and wire guard. Bated breath…
DAVE A. OXENREIDER
'73 XJ12 SWB
'75 TR6
Audio Visual Imagineering, Inc.
Orlando, FL USA
http://www.gate.net/~laser3d
Date: Fri, 27 Sep 1996 18:24:52 -0700
Subject: European License Plates
Hi fellow jag lovers!,
I remember seeing a string of mail regarding the purchasing of European
License Plates by people here in the U.S… This plates were only
decorative, and for states were the front license plates are not required.
Any sources or numbers how to purchase such things legally in the United
States? Maybe even replica plates, that aren’t original?
I own an XJ40 and I’m looking for something to fill up the blank spot
on the front of the car. I really don’t care what the plate says, so long as
it is the elongated yellow or white with black letters European plate, often
seen in the U.K…
Thanks again for any help!
cobac@ix.netcom.com
Date: Fri, 27 Sep 1996 21:25:31 -0700
Subject: Re: [JAGSWAP] The Jaguar/Daimler used parts exchange is open for business!
Folks,
now open for business. You’ll find it at the following URL:http://www.bitcon.no/HyperNews/get/jagswap.html
Have fun with it!
Gunnar
It’s only Friday her in Ontario, Canada, Regardless, I just signed on
yesterday and read all the messages. Very interesting reading!!!
I’ve learned lots already. 87 xjs 87 vdp v12
Date: Fri, 27 Sep 1996 22:34:41 -0400
Subject: XJ40 Stumble (long)
Mike,
<First on the issue of Sovereign – mine says Sovereign in two places only:
the <vehicle registration, and in hand writing (felt tipped marker, I think)
under the <passenger side dash liner! No badge on the back, except XJ6. Car
has Pepperpots, <Four round headlights, leather, cruise, air, sunroof.
Mine has a Sovereign badge on the RH side of the trunk. Except for the
picnic trays, reading lights in rear corners and pull-down sunshade, it seems
to have everything on it - even a bonnet leaper.
<The main problem is that it has a erratic idle, and an more-than-occasional
miss at <speed. Etc, etc. -----
Sounds a lot like mine when I bought it a year ago. Service records showed
that the dealer had tried to fix it twice, but, of course, without the “Check
Engine” code, he found nothing. My un-sophisticated troubleshooting found
that a piece of the intake manifold gasket at the very rear of the engine had
broken/fallen out, creating a vacuum leak, and #6 cylinder was leaning out.
I simply cleaned the area with solvent and smeared a bit of RTV (room
temperature vulcanizing) silicone into the crack. It runs perfectly now.
Ron Miller
Seattle, WA
1993 XJ40 Sovereign
Date: Fri, 27 Sep 1996 22:38:47 -0400
Subject: diagnostic on XJSIII?
My BRG friend is sick, and any help you can offer will be
appreciated. It died in a parking lot, although I finally did
coax it home. It will start, but then will die. It will do that
again and again – and after sitting for a while it will run.
This is an 85 fuel injected 4.2 Series III, with about 60,000
miles.
A month or so ago it began to stall when at a cool (not yet
heated up but not cold) state. It always re-started and ran fine
after such an incident. But today, it stalled and then we wnet
through the start-die, start-die routine. Incidently, iwas
running on the reserve (read left) tank at the time, and it
was low. The left tank doesn’t register and so i have no idea
how low. I may have sucked up some bottom-of the tank junk?
Any suggestions as to where to begin will be appreciated.
Bob Sack
85 XJ6
50 XK 150
Robert J. Sack
phone 804 924 4814
fax 804 924 4859
Date: 27 Sep 96 09:43:38 EDT
Subject: [XK8] UK XK8 on Top Gear next week
I just caught the end of Top Gear last night (Screaming TWINS preventing proper
hearing!) on BBC 2, I think they said they have a road test of the XK8 next
week, can anyone confirm or deny?
Regards
Date: Fri, 27 Sep 1996 23:58:39 -0700
Subject: XJ40 rear struts
I have just removed the load-levelling rear struts from my '90 XJ40 and
replaced them with the Jaguar conventional shock kit. What a difference in
the ride!
Before I chuck the old struts into the trash, does anyone out there have a
need for them? They are free to anyone who wants them and will pay for the
cost of shipping. As far as I know, they were working fine.
Dave
Date: Sat, 28 Sep 1996 00:01:16 -0700
Subject: '90 XK40 oil leak
This is a 4.0 liter engine with an oil leak that runs down over the bell
housing and right onto the hot exhaust. Smells lovely!
Is the leak from the cam cover seal or the head gasket?
Dave
Date: Sat, 28 Sep 1996 17:04:23 -0700
salt.If “my” body shop manages to stop the rust (no signs of re-emerging
If you are not worried about appearance then try painting the new metal
with POR 15. This should stop it rusting.
Shane Gibson
Wellington, New Zealand
1968 Daimler V8 250 (restoration 65% complete, 185% over budget and
growing)
Date: Fri, 27 Sep 1996 22:17:29 -0700
Subject: JAGSWAP
Incredible Job! Where was something like this six months ago when I
started my E restoration? BTW, do you do programming for a living?
Date: Sat, 28 Sep 1996 02:15:58 -0005
Subject: Re: The 1986 XJ Innovations, A/C & Kickdown
'box. The innovation in the HVAC was the move to a computer controlled system,
Cannot speak with authority on the GM400 mods, although methinks you
can do much with either by recalibrating them yourself! The problem
is not with overtaking, it’s with start from standstill.
From what I hear about the newer HVAC, though, the comments about the
computer being the only change are most certainly false. The entire
system was changed, right down to the casing itself – the older was
sheet steel, the newer plastic. Reports are that the operation is
largely unchanged, but nothing is interchangeable, the older system
is apparently more reliable, and parts for the newer are a LOT more
expensive – but replacing the heater core is a snap.
– Kirbert | If anything is to be accomplished,
| some rules must be broken.
| - Palm’s Postulate
Subject: Re: '88 XJ-S V12 (UK) steering rack replacement
Stefan Schulz:
- The service manual specifies the use of the Jaguar ball joint separator
other ball joint separator…
On the tie rod ends, just about any old tie rod separator will do.
On the bottom ball joints, a particular type is necessary – but that’s another issue. However, you should also note that it’s not necessary to disconnect the tie rod ends at all to replace the rack bushings. …and ignore the checking fixture, aligning the rack by look and feel instead ? I did. Fact is, I more or less positioned it where it was before. Would be GREAT, though, if someone comes up with a better way to make sure it’s right. 2. Anyone have a UK supplier and part number for the aftermarket bushings WITH WHOM THEY HAD GOOD EXPERIENCES ? Sorry, only the second half – bought mine from John’s Cars in Texas, they have been great. These are polyurethane, I understand some others are Delrin. 3. How difficult is it really ? Any non-obvious caveats ? It’s an absolute cakewalk. The worst part is getting the old bushings out, which are press fit, but a pair of 3/8" sockets and a long 5/16" bolt and nut will do the trick. Have some spare 5/16" fender washers on hand, it’s better to fill to fit than to try to pull structural members in. You might find it helpful to remove the oil filter. And therefore, you might wanna have a NEW oil filter on hand before you start. Kirbert | If anything is to be accomplished, | some rules must be broken. | - Palm’s Postulate From: “Kirbert” palmk@gcn.scri.fsu.edu Date: Sat, 28 Sep 1996 02:15:58 -0005 Subject: Re: XJ6,SIII seat wires ? My '86 SIII UK car has two wires, brown and purple I think, coming from the bottom of the passenger seat (none on drivers side) going into the floor underneath it. Does anyone know what they are for ? I think these were originally for a seat belt buzzer. The buzzer would operate whenever the driver’s seat belt wasn’t fastened, assuming there MUST be someone in the driver’s seat. However, the passenger’s seat had a broad, flat switch to sense when a passenger was present in order to buzz only when there IS a passenger there and his belt isn’t fastened. Kirbert | If anything is to be accomplished, | some rules must be broken. | - Palm’s Postulate From: “Kirbert” palmk@gcn.scri.fsu.edu Date: Sat, 28 Sep 1996 02:15:57 -0005 Subject: XJ-S Help Book Some time back, the issue of my using people’s submissions to jag-lovers for inclusion in my XJ-S help book was discussed, and I asked if anyone objected. Nobody did, and I have been proceeding accordingly since. However, I have come to the realization that the membership of this group is anything but fixed, and that perhaps some NEW members might object – or at least want to know what’s up. The XJ-S book, “Experience in a Book: Help for the Jaguar XJ-S Owner” began with me listing the various tricks and nuances of XJ-S ownership and maintenance that I learned on my '83. However, with membership in this illustrious group, there have been a great many more problems solved, solutions found, gimmicks derived and disasters avoided discussed than I could possibly face on one car alone. Hell, if I had ALL these problems, it’d be a terrible car indeed! So while the book began as one man’s experience, it has grown into more a collection of this group’s experience. In short, with each and every message that comes to jag-lovers that appears to be the kind of thing that should be included in this book, I save the message and hopefully eventually get around to putting it in. Whereever possible, I give credit where credit is due. The point is: if you are posting comments I might use, and you DON’T want me to quote you or use your material, please let me know. If it’s something in the past, speak up anyway, I’ll go back and edit things back out. I do not wanna misuse anybody’s trust on this list. However, I haven’t been asking permission on each and every message, and hope that that doesn’t prove necessary. I also have a suggestion for Nick: It might be a good idea to make some note of this in the introductory message. There’s no way I can send this notice to all new members, but the introductory message goes to them – and that way there will be no surprises. If necessary, I can write something to cut-and-paste into the introduction, or everything necessary can probably be extracted from THIS message. I have made my book available for minimal cost (barely printing and postage) to other owners, and more recently have posted it on my WWW page for anyone to download free of charge. It certainly cannot be considered a profitable enterprise on my part. I hope nobody objects on the grounds that I am making money off their input. One final confession: I am using Pegasus these days, and when you save a message to a text file, it automatically saves the headers, which USUALLY provide a decent basis for quotes. Formerly, however, I was using Eudora Lite – which can also save the headers in text files, but doesn’t unless you tell it to, and I didn’t discover that right away. There were a bunch of messages like, a year ago, that if the signature didn’t have the writer’s name, I had no idea who sent it. And if it was something important, I used it anyway, although I avoided any direct quotes since I couldn’t say who I was quoting. If anyone has noticed they’ve been slighted accordingly, you are welcome to send a claim for credit and I’ll try to correct the book as best I can. Kirbert | If anything is to be accomplished, | some rules must be broken. | - Palm’s Postulate From: David Hallam D.Hallam@mailbox.uq.oz.au Date: Sat, 28 Sep 1996 17:04:44 +1000 (GMT+1000) Subject: Re: uh-LUM-in-um (zero Jag content) Just remember the french discovered the stuff and called it aluminium. So obviously the US stuff must be a different and defective stuff. Its missing an I at least so it can mot be as strong or corrosion resistive. David Hallam Senior Scientist Materials Conservation Queensland Museum *** Without treatment Development our past can only rot *** From: Randy Wilson randy@taylor.infi.net Date: Sat, 28 Sep 1996 02:52:17 -0400 (EDT) Subject: Re: '90 XK40 oil leak This is a 4.0 liter engine with an oil leak that runs down over the bell housing and right onto the hot exhaust. Smells lovely! Is the leak from the cam cover seal or the head gasket? Tis most likely the cam cover gasket. Specificly, the half moon seal behind the exhaust cam (used to fill the semicircle left from machining the cam saddles. the oil galleys through the head gasket are at the front. When the head gasket leaks the oil streams out just in front of the front of the exhaust manifold. Dave Randy K. Wilson randy@taylor.infi.net From: Kyle Chatman kchatman@mail.coin.missouri.edu Date: Sat, 28 Sep 1996 08:03:52 -0500 Subject: Request for Closure & Location When your request for mechanical advice has been especially challenging = or controversial, please report on the final outcome. And to all in = general, please share your geographic location. If unimportant for any = other reason, it is fun to find that someone else in your area is a = jag-lover. BTW, my son’s school has the Jaguar as a mascot and its newsletter is = the JagWire. Don’t you just love it? Columbia, MO, USA From: TezFair@aol.com Date: Sat, 28 Sep 1996 09:42:16 -0400 Subject: only for jag/ford website owners. no jag content what so ever Hi folks, I got the following snotty letter and although I have permission to use logos on my sites, have any of you received a similiar letter? Subj: Your use of Ford/Jaguar corporate logos Date: 28/09/96 04:56:22 From: XQVV76B@prodigy.com (MRS CAROL C GODWIN) To: TezFair@aol.com I noted that your Employees home page uses Ford and Jaguar trademark logos. That use should be discontinued immediately, since your homepage is not sponsored, endorsed or controlled by those Companies. If it continues, I will forward the information to the Jaguar legal office for their attention. Tez From: ttalimon@mail.win.org Date: Sat, 28 Sep 1996 10:28:31 -0500 Subject: maintainance/repair manual I am a new owner of a 88 xj40, looking for a source for repair and maint. manuals. Also looking for info on replacing rear struts. From: hdrsons@iamerica.net (Hal Rogers) Date: Sat, 28 Sep 1996 11:25:14 -0600 Subject: Re: XJ40 rear struts At 11:58 PM 9/27/96 -0700, David Hurlston wrote:
the ride!Before I chuck the old struts into the trash, does anyone out there have a
cost of shipping. As far as I know, they were working fine.Dave
That’s a great offer! SOMEONE should take you up on that! I sell these parts
all the time and they are expensive.
REgards,
Hal
Hal Rogers
H.D. Rogers & Sons
Import Auto Specialists
3418 Barksdale Blvd.
Bossier City LA 71112
(318) 742-3651 voice
(318) 742-5044 fax
Serving Auto Enthusiasts since 1959
Date: Sat, 28 Sep 1996 12:24:05 -0400
Subject: Re: cd changer
Having followed this debate for the last couple of months, I must put my two
cents worth in. I bought and had installed a Kenwood (KRC-301) am\fm
cassette deck and in the trunk put a Kenwood (KDC-603) 10 cd changer. This
covered all angles both cassette and cd. To install it the service men (yes
more than one!) had to drill a small hole between the back seat and the
trunk. Yes, they had done this before and knew where to drill to miss the gas
tank. The total cost including the installation was $486.00 The sound is
great and the ability to have 10 cds in a safe place is worth the time and
money. The face plate is also detatchable. If one has gone to the cost of
buying and maintaining such an auto as we all have then why not do the sound
right. Having intalled many stereos in the past the $50.00
I paid to these guys was well worth it. No wires showing and a great sound.
Yes one can do it cheaper, but a great car and a great sound go together like
fish and chip or tea and crumpets. Thank you for the chance to express my
thoughts.
Bruce Battles
85 XJS
Date: Sat, 28 Sep 1996 11:15:01 -0700 (PDT)
Subject: Re: Service Manuals
Michael Powers/TEIR/Thomson wrote:
Has anyone used the factory service manual set for the 89 XJ6?
Is it worth the money? Any recommendations for better 3rd party service
books that contain wiring diagrams?My local Jag dealer wants $185 for the complete set of manuals. Not a bad
price, but I hate to pay that much for something which may not
get used very often.
Bob Johnson replied:
I have had the updated 88 XJ6 (XJ40) factory manual. It is quite good.
Five volumns cover all aspects. When I received mine, I got two sets
of many pages. The changes were typically minor. I consider the
presentation redundant. Also, I would like to see more explanation of
function to help in diagnosis.
A while back, Roly Alcock wrote about a “condensed” version of the manual
set for the XJ40 that is apparently available from the JEC in England. I
haven’t noticed any posts from anyone that actually HAS this manual.
Roly’s original post goes:
RA> Thelma Brotton Jaguar Enthusiats Club C/O Stoneycroft Moor Lane
RA> Birdwell Barnsley South Yorkshire S70 5TZ UK Telephone +44 1226
RA> 740754 Fax +44 1226 293581
RA>
RA> I rang Thelma Brotton, who looks after the JEC sales and asked her
RA> about the content of this new service manual. She did not have any
RA> great detail that she could give me, but here are the salient
RA> points.
RA>
RA> 1. It is like a condensed edition of the factory manual. 2. It is
RA> not a factory publication. 3. It is of a better standard than the
RA> average Haynes manual. 4. They are selling well, with no adverse
RA> comments coming back.
I’d also like to hear from anyone that actually HAS this manual before I go
to the trouble of importing a book like that.
-Steve A.
'67 E Type Coupe
'76 XJ6C
'91 XJ40
End of jag-lovers-digest V2 #387
id for jag-lovers-digest-out; Sun, 29 Sep 1996 21:22:19 +0200 (MET DST)
Date: Sun, 29 Sep 1996 21:22:19 +0200 (MET DST)
Message-Id: 199609291922.VAA04623@ekeberg.sn.no
Subject: jag-lovers-digest V2 #388
Precedence: bulk
jag-lovers-digest Sunday, 29 September 1996 Volume 02 : Number 388
Re: '61 E Alternator Conversion, 2nd installment (Success!)
Re: 61 E-Type flat floor outside bonnet lock.
winter storage
Re: winter storage
'62 flat floor E-type roadster for sale
Re: only for jag/ford website owners. no jag content what so ever
Re: Request for Closure & Location
Restore or replace, SIII XJ-6
Multiple Cat Bites
Re: Multiple Cat Bites
RB310 voltage regulator
Re: jag-lovers-digest V2 #387
Fuel Tank Repair
RE: XJ-S Help Book (as applies to XJ6 book also)
XJ-S help needed
Date: Sat, 28 Sep 1996 11:15:13 -0700 (PDT)
Subject: Re: '61 E Alternator Conversion, 2nd installment (Success!)
At 01:45 PM 9/6/96 -0005, Kirbert wrote:
If heat is a concern – and if an electrical item is near a Jaguar
exhaust manifold, then heat IS a concern – then the thing to do is
provide a heat shield. Just fashion a piece of sheet metal to block
the line of sight between the manifold and the part being protected.
Hunt Dabney shot back:
Sounds good to me. I saw a wonderful little mod at the Monterey Historics,
by a fellow named Malcom Adams. He had fabricated a stainess shield,
louvered as the bonnet is, which mounted about 1" below the louvers, to
prevent damage to the bonnet paint. Worked great and looked right, too.
My 67 had a heat shield added for its alternator that looks pretty good &
seems to work as well. At least it does no harm so I’ve left it. POs
sometimes DO do a few things right! It’s fabricated from two pieces of
sheet metal that are welded together & painted an appropriate shade of
gray. I can provide measurements if anyone’s interested and I’d expect it
to work on most ANY XK engine.
-Steve A.
'67 E Type Coupe
'76 XJ6C
'91 XJ40
Date: Sat, 28 Sep 1996 15:39:02 -0400
Subject: Re: 61 E-Type flat floor outside bonnet lock.
On Sep 25, 6:15am, Craig R. Hastings wrote:
Subject: 61 E-Type flat floor outside bonnet lock.
- The original color of the car was red, but it has been painted a Silver
blue
A BIG IMHO on the following;
- -3.8 Etypes had the widest range of available colors, I’m sure Op Lt Blue was
one of them, however, I think that Etypes look best in medium to dark colors
(White and Primrose being the exception) - darker value colors show off the
form and highlights best. And yes, I do think that there are too many red
Etypes, but red is not a bad color for the car…
Is the fact that a car is painted in other then the original
color a negative.
Maybe. It is easy to tell the original color on an Etype, just drop the
center instrument panel and look through to the inner bulkhead, I’ve NEVER
known anyone that has painted back there, (too tough to get in there to paint
it!). Most everyone knows this trick and on a car like a flat floor ots (where
collector value is important) any future buyer is likely to check.
- Since this is an early 61 car it has the welded louvers. Or at least it
should. It
appears that somewhere along the line the center section of the bonnet was
replaced with one
which had the pressed louvers in it. It has been suggested that these could
be cut out, put
a frame around them and then weld them back to have the look of the original.
I would do it, maybe not right away, but I would do it. These early cars are
(to me anyway) historicly significant, they are unique - a lot of little
peculiarities, sort of like an alloy XK120. Is this car RHD? If ever there was
an Etype that should be put to original, it is the outside bonnet latch, flat
floor cars. The first races (and wins!) for the Etype where by nearly stock
flat floor cars, no other Etype won serious races in stock condition. The flat
floor cars beat Ferrari 250SWBs and Aston DB4 GTs!
The center sections of the bonnet are available, Robey sells them. You may
want to find out why it was replaced, accident damage???
I would not worry about it being too small inside. There is a fine line
between pleasure and pain, and you will in happyness suffer.
If you have the means, by all means BUY 1… (reg of the first flat floor
E…)
Mark McChesney
'65 Etype ots
“We are lead to believe a lie if we see with and not though the eye…”
William Blake
Date: Sat, 28 Sep 1996 15:44:01 -0400
gray.
An alternator heat shield came on the car from the factory - late '65 on. Mine
does not have one :-/.
Mark McChesney
'65 Etype ots
Date: Sat, 28 Sep 1996 22:20:40 +0000 (GMT)
Subject: winter storage
in this part of the world the winters can be bloody awful and i have two cats
who refuse to get their paws wet and dirty after nov 1st so i have to try and
find some winter storage for them each year. the last few years i ahave had to
use my own garage which is a two car one with the consequence that my wifes car
has had to remain outside exposed to all the elements-so you can see my
political problem. well i have had the following idea and wanted to get advice
on its practicality and feasability. the problem is basically not one of
temperature but of moisture so how about constructing a thich plastic frame
which can be closed by either zipper or velcro to cocoon the car for the
winter. one would have to seal various openings i.i. exhaust pipe etc and
probably include inside this cocoon some dessicant such as silica gel. any
ideas if this would work as my only other alternative would be to cocoon my
wife… now that’s a thought!! thanks, robincooper
Date: Sun, 29 Sep 1996 09:36:57 +1000 (GMT+1000)
Subject: Re: winter storage
Yes moisture is your problem but so is condensatino on the surface.
You would need so much silica gel it is not practical. Also silica gell
can absorb abd desorb water so it keeps it in the “system” not what you
want! A better system is to use a dehumidifier. At temps below 10
centigrade refrigetant dehumidifiers do not work well (they Freeze) so
absorbtion devices such as the cargocare (Munters) system are the go. They
work and are used extensivly by the military and in storage environments.
But they are not a cheap fix.
Another byt not as successfull approach is to use waxy based corrosion
inhibitors on a more masssive scale than normal. Look at the Dinol range
of products used for shipping new cars.
you could more the cars to the simpson desert its nice and dry!
Hope it helps.
/dlh.
David Hallam http://www.uq.edu.au/`qmdhalla
Senior Scientist
Queensland Museum d.hallam@mailbox.uq.edu.au
*** Without Treatment Development our past can only rot ***
____ Daimlers can be fun too! _____
Date: Sat, 28 Sep 1996 16:36:49 -0700
Subject: '62 flat floor E-type roadster for sale
Hi all,
The time has finally come to part with my kitten.
62 flat-floor E-type roadster, unrestored and completely
original, even have the original badge bar from the front.
Was my daily driver until a few years ago, still runs
like a turpentined cat. Everything original except
it is missing the original air cleaner and the vinyl
from the dash top. Has original 3.54 differential but
also have a spare 3.07 diff for it.
I’ve had it for the past 20 years and it has been garaged
since new. Zero rust and only one minor ding where
a softball bounced off the rear fender.
Contact kenh@teleport.com or phone me at
USA 503.636.7188
As a courtesy to other internet afficionados, please
email me directly instead of gobbling bandwidth by
replying through the majordomo server.
Thanks
Ken
Date: Sat, 28 Sep 1996 20:20:05 -0400
Subject: Re: only for jag/ford website owners. no jag content what so ever
Obviously somebody’s mother-in-law!
(Pity him)
Really pleased to hear you were intelligent enough to
get permission to use the logo - I guess the best advice
is to feel pity for the sort of life the good Mrs Godwin
must have.
She prob. pronounces it “jag wahhhhh”
Best to you for all you efforts, past and to come.
Charles Daly, Toronto, Canada
'62 E-Type, ots
Date: Sat, 28 Sep 1996 21:03:01 +0700
Subject: Re: Request for Closure & Location
challenging or controversial, please report on the final outcome.
To expand on this, please report on the final outcome of anything you
do which has been challenging or controversial, whether you request
advice or not.
Has anyone begun a diagnostic guide for Jags? The repair manuals are
fine, once you know what’s broken.
Greg.
'85 VdP
Date: Sat, 28 Sep 1996 20:17:28 -0700 (PDT)
Steve-
I’d be real interested!
Thanks!
Hunt
the line of sight between the manifold and the part being protected.Hunt Dabney shot back:
prevent damage to the bonnet paint. Worked great and looked right, too.My 67 had a heat shield added for its alternator that looks pretty good &
-Steve A.
'67 E Type Coupe
'76 XJ6C
'91 XJ40
Date: Sat, 28 Sep 1996 20:17:32 -0700 (PDT)
Subject: Restore or replace, SIII XJ-6
Hi all-
I’ve reached a semi-crisis with my '85 XJ-6. It’s at that “everything’s
going at once” point. I have my '62 e toy, and prefer my XJ-6 to be more of
the daily-driver-looks-good-for-clients-and-always-works car. So, a few
questions for those of you more brave than I’ve been so far:
The situation:
- It has really started to leak. Trans. fluid onto the exhaust system
when I come off the freeway, driveway needs cleaning daily… 151k miles,
runs really great, trans shifts great, but every seal seems to be bad. - Leaking fluids have killed all the mounts. Blow back onto rear brakes,
too, I think, so pulls during breaking. Could also be suspension mounts. - Needs suspension & rack rebushing…
- Leather has started to go, both front seats (tearing at seams - needs new
inserts). Oh - needs door seals, too. And that fuzzy stuff around the doors
(great headliner, though!). - Paint not so great, rust around rear window…
So, I can gut it and go through it completely, but time is a problem. Also,
if I dump lots-o-bucks into it, it’s new enough that insuring to full value
may prove challenging.
I really like SIIIs. I like the looks a lot more than XJ-40, but a
relatively new (2-3 year) XJ-40 is appealing from a maintenance point of
view. I know that quite a few of you have both cars, or have had both. I
would really appreciate input as to the relative merits of either car. I
guess I could buy a really good replacement SIII, too.
Is it possible to pull the transmission with the engine in place in a SIII
XJ-6? Have any of you tried the John’s Quarterbreed kit, if so, how big a
job and how do you like it?
How big a job is installing an upholstery kit?
How about suspension rebushing?
Sorry - I’m just having trouble deciding if I should throw money at the
problem, or lots of work and money! (How hard a choice can this be, anyway?)
It occurred to me I could buy an XJ-S as a temporary driver while having the
XJ-6 done, but I’m out of storage space.
Thanks for your patience!
Hunt
Date: Sat, 28 Sep 1996 23:35:03 -0400
Subject: Multiple Cat Bites
Boring story here, stupidity content high, continue at your own risk…
OK, so I thought I’d finally go have a closer look at the 1965 420 I had
asked the list about a few weeks ago. Turns out there is no such thing as a
1965 420, except this one, and only in the state of Pennsylvania. When the
current owner bought the car, there was no title, so after much trouble he
finally received a title from the state, incorrectly marked 1965 instead of
1967 and he decided to keep it that way.
The car is in fair shape, is available for $3500, and would take another
$10k to be brought into a condition where I would want it. Not so bad. So I
left this shop thinking seriously about it, but since I had some free time,
I thought I’d spin by the Jag dealer to see what was on the lot.
Then it hit me, a 92 Sovereign, Brooklands Green with Barley. Available at
a mere $24k and the salesman “could work on that”. Three year/36000 mile
warranty, bumper to bumper. No waiting for paint job/interior
work/mechanical work.
What’s a man to do? I’m leaning heavily toward the 92, so heavily my wife
as already started with “OK dear, whatever, just shut up about it!”.
Opinions appreciated,
Clayton B.
85 XJ-S
Clayton Betlyon cbetlyon@lumcorp.com
Software Engineer (717) 543-4994
Luminous Corporation
Date: Sun, 29 Sep 1996 00:25:04 -0700
Subject: Re: Multiple Cat Bites
Available at a mere $24k and the salesman “could work on that”.
I’ve owned or been owned by an 85 XJ6 and a 91 Sovereign, and
while I loved the styling on the 85, the 91 has been much more
gentle on my pocketbook…
I’d go the 92 myself, but I’m holding out for a 96 when my 91
odometer hits 60,000 in two more years.
Good luck in your choices…let us know what you decide to do.
Don Farr
Donald R. Farr
Paradise Valley, AZ 85253
(602) 948-7499 - fax
91 Sovereign
d.farr@phx.cox.com - e-mail
http://people.phx.cox.com/dfarr/dfarr.htm - Don’s Homepage
http://people.phx.cox.com/dfarr/jetta1.htm - Jetta Notebook Computers
http://people.phx.cox.com/dfarr/march10.htm - Wireless products
http://people.phx.cox.com/dfarr/ncs1.htm - National Consulting Services
Date: Sun, 29 Sep 1996 07:50:31 GMT
In message 960928094216_319360178@emout06.mail.aol.com TezFair@aol.com writes:
Were the above two lines written by yourself of Mrs Carol C Godwin ? The
quote marks didn’t make that clear.
When you say that you have permission, do you mean that you have permission
form the car makers concenerned to use THEIR logos or from your internet
service provider to use any logo at all ?
I’m not a lawyer, but I believe that if you have permission from Jaguar
Cars Ltd or Ford Motor Co to use their logos, then there’s no problem.
In that case, I’d write back to the originator of that letter along the
lines of “Go ahead, punk.”
However, if you don’t have that permission from Jaguar or Ford, then you’ll
either need to get it or discontinue use of the logos. Then again, as a
Jaguar employee who does his company a service with the website, you
shouldn’t have too many problems doing that
Check with your company if necessary, then write a snotty letter back to
Mrs Busybody.
Stefan Schulz
jaguar@suaviter.demon.co.uk
Date: Sun, 29 Sep 1996 06:30:11 -0400
Subject: RB310 voltage regulator
I have a 62 MK2 with a Lucas RB310 voltage regulator and I am hoping
someone can answer the following questions.
- What is the correct air gap setting.
One of the screws has come loose and my Jag manual does not cover this. - How can the regulator be fully adjusted off of the car.
Thank You
Fred Phelps
flphelps@erols.com
Date: Sun, 29 Sep 1996 09:54:38 -0400
Subject: Re: jag-lovers-digest V2 #387
Uhh, the way I remember, it was “discovered” by a Prussian, Johann
Pott, who produced alumina from alum. He believed it to be a compund
consisting of oxygen and an “unknown” metal. Sir Humphrey Davy gave the
unknown metal its name, first calling it “alumium” and later changing it
to “aluminum”. I don’t know where the “aluminium” name came from…
sounds like it might have simply been a confusion brought about by the
first two “official” names.
BTW, it was a Dane (Hans Oersted) who produced the first pure sample…
Some 30 years later (1854) a Frenchman got around to “improving” the
refining process, but I think that’s about all the involvement they had
in its “discovery”.
Bill Frenchu |“Back when I was a
Mail: wrf@pluto.njcc.com (609) 466-2604 | boy, we carved our
Web: http://ourworld.compuserve.com/homepages/wrf | own IC’s out of
wood.”
Date: Sun, 29 Sep 1996 12:00:32 -0400
Subject: Fuel Tank Repair
On 26 Sep 1996,
Frank Perrick Wrote:
I was watching a car show and they showed this stuff that poured into a
empty fuel tank and it coated the indide of the tank ,by sloshing it
around, with a thin hard shell that sealed all the little pin hole
leaks.
Frank,
I have used gas tank sealer, from Bill Hirsch Automotive (1-800-828-2061 or
201-642-2404), with great success. I put it in the fuel tank of my '67 XKE
which had a number of pin hole size leaks. Previous attempts to coat the
outside of the tank were not as successful. The the tank sealer is
gasoline and alcohol resistant with a quart of it selling for $19 USD (w/
shipping). A quart can is sufficent as only a thin film is coated to the
inside of the tank. I am not sure of the products chemistry, but it dries
to a white, Teflon like, film. Bill Hirsch has sold this product for a
number of years and advertizes heavily to automotiive restorer types (see
Hemmings Motor News magazine).
Good Luck,
John
'67 XKE (a rocket)
'87 XJ6 (grace w/ pace)
'92XJS (thirsty cat)
Date: Sun, 29 Sep 1996 11:51:27 -0500
Subject: RE: XJ-S Help Book (as applies to XJ6 book also)
I want to say that the XJ6 Book, “The XJ6 Jaguar from Bumper to Bumper” is
the same type of publication as the XJ-S Help Book that Kirby wrote. and I
want to echo his comments as they apply to the XJ6 Book.
Please send any corrections, or complaints to me and I will rectify the
situation.
Jim
“Better an outlaw than not free.”
Nance O’Neil
Date: Sun, 29 Sep 1996 13:15:49 -0500
Subject: XJ-S help needed
I am on the way back together with the cooling system on the XJ-S and have
five questions.
No one responded to my question about the wire harness (two wires in a
cloth sheath) that comes from below the right (sitting in the drivers seat
facing forward) side intake manifold then crosses in front of the engine to
the left side near the thermostat housing. It is not connected to anything
and it probably should be connected. -
What is the effect of the air cleaners being mounted backwards in the
housings? When I removed them I noticed that the PO had them installed
backwards (with the “front” arrow pointing to the rear). Maybe he drove in
reverse alot. -
What is the rubber stopper in the front of the block on the right
(sitting in the drivers seat facing forward) side of the engine just above
the water pump mounting surface? Should the rubber stopper be replaced
occasionaly? -
The two hoses from the thermostat housings to the crossover pipe have
diferent sizes on either end (smaller on the crossover pipe) Does this
require a custom hose or can I use the larger size and squeez down the front
end on the crossover pipe with a hose clamp? -
I plan on using a gasket sealer on the water pump gasket as the
instructions that came with the pump call for it. Should I also use it on
the hose ends or will this just make it harder to dissasemble. There doesnt
seem to have been any on it the last time the hoses were replaced and it
made removing the hoses much easier than normal.
Jim
Nance O’Neil
End of jag-lovers-digest V2 #388
X-UIDL: b9267e6d541bc7737a51d8ed905a4478
id for jag-lovers-digest-out; Mon, 30 Sep 1996 05:47:00 +0200 (MET DST)
Date: Mon, 30 Sep 1996 05:47:00 +0200 (MET DST)
Message-Id: 199609300347.FAA05814@ekeberg.sn.no
Subject: jag-lovers-digest V2 #389
Precedence: bulk
Status: RO
X-Status:
jag-lovers-digest Monday, 30 September 1996 Volume 02 : Number 389
re: Craig Hasting’s re: parts list
XJ40 Rear Struts
Re: winter storage
Restore or Replace (XJ6)
Re: Restore or replace, SIII XJ-6
Re: Restore or Replace (XJ6)
Re: XJ-S help needed
Re: Engine Heaters/cats
Jag shops in ohio
Re: winter storage
Re: European License Plates
Start/stop xj6
Re: XJ40 Rear Struts
Re: winter storage
Metal-Master pads (old brake dust thread)
Re: Ignition Amplifier
Date: Sun, 29 Sep 1996 14:45:21 -0500 (CDT)
Subject: re: Craig Hasting’s re: parts list
On Mon, 23 Sep 1996, Weiss-Malik wrote:
Craig Hastings posted that he might be able to set-up:
A data base which is available for search through e-mail. This means that
if you required a part or parts you would send an e-mail to an address
I have an application that I think I can modify to be usable as a parts
data base… So, is this something we could use?>A strong yes vote from me on this one!!!
Rob W-M
85 XJ-S
Another strong yes vote from me. This would be great!
Larry “needing a European front bumper in the USA” Lee
1979 XJ4.2, Series II
Date: Sun, 29 Sep 96 17:17:17 -0400
Subject: XJ40 Rear Struts
I seem to have lost the original message about someone willing to part
with the rear self leveling struts for the price of shipping… Could
the kind person who posted that note originally contact me directly
since I would be very interested… Bob Bagramian 88XJ40
Date: Mon, 30 Sep 1996 08:54:02 -0700
so how about constructing a thich plastic frame which can be closed by >either zipper or velcro to cocoon the car for the winter. one would have > to seal various openings i.i. exhaust pipe etc and
There is a product being advertised in NZ called the Carcoon.
It is basically a big plastic bag the you drive your car onto and the
zip up around the car. It also has two fans that circulate (and
extract?) the air within the carcoon. This results in the plastic bag
inflating and the removal of all moisture (or so they claim).
Let me know if you want more details and I will drag the advert out and
fax it to you.
Shane Gibson
1968 Daimler V8 250
Date: Sun, 29 Sep 1996 15:32:21 -0500
Subject: Restore or Replace (XJ6)
Hunt,
Everything you address is in my book “The XJ6 Jaguar from Bumper to Bumper”
which is available off the web for free or from me for a nominal fee to
cover costs.
I just went through a complete restoration and up date of my '82 XJ6 to an
'85 XJ6. Wife totaled the '82 and we took the engine, transmission all the
running gear and the interior from the old car and transplanted it into an
'85 that had just been painted. The cost was just $6200 less the insurance
money ($3500). I am insuring it for $9400. I got an indepentent appraisal
and am insuring it for “stated value”. The best book price on it would
have been $8400.
Is it worth it to restore?
- transmission seals about $400 ( a good jag mechanic )
- engine oil seals about $300 ( the same guy as above )
- paint job about $2000 ( a realy nice paint job )
- Interior leather about $1300 ( genuine jaguar parts )
Labor about $250 ( almost any good leather shop ) - Misc trim about $200 ( SICP )
$4550
Now, tell me, where could you get a car to replace it for anywhere near that
price?
Add $2000 to that and you could have a complete engine overhaul, but it
doesnt seem like you need it.
Add $1200 to it and you could have a GM TH 350 transmission (the quarter
breed kit) but again I dont think you need that since yours is only leaking.
Your old transmission is probably worth $400 (but you have to find a buyer)
the kit, installation , and a rebuilt TH350 transmission is $2000 and you
wouldnt need the transmission seals replaced in the BW66 (-$400 from above).
But if all you need on the BW66 is seals, why replace it. Even a complete
overhaul would be less than $1000. I have a GM TH350 in mine but the BW66
transmission was not rebuildable and I use my car for towing which the BW66
is not strong enough for.
But even if you went for the whole enchilada you are only out $7750. What
could you get for that money, a Ford Escort ? Do you want a Ford Escort?
Jim
Nance O’Neil
Date: Sun, 29 Sep 1996 15:02:56 -0700
Subject: Re: Restore or replace, SIII XJ-6
You wrote:
Hi all-
We have seen 26 of them so far … all solved…
It takes 4 months…
Also,
value
No no problem insured for the value of $26,000
of
view.
Included is a one year comprehensive warrantee taken care of but your
local Jaguar dealer on my behalf…
speak to dave covert of the list …
several on the list have done … we do it as a matter of course using
the modern bush kits…Sorry - I’m just having trouble deciding if I should throw money at
the
No work at all just $22,000 for your car to be made brand new again and
that is including a new car warrantee.
all the best
tony
VICARAGE JAGUARS…Restoration & Enhancement Specialists
USA-Holland-UK Original parts - Exclusive Upgrades
tel 305 444 8759 World Class Concours Restorations
fax 305 443 6443
http://paradise.net/vicarage e-mail to: vicarage@ix.netcom.com
http://www.oslonett.no/home/nick/vicarage.html
Date: Sun, 29 Sep 1996 15:34:09 -0700 (PDT)
Subject: Re: Restore or Replace (XJ6)
Hi Jim!
You’re probably right (throughout). If an XJ-40, I figured on dropping about
$20K, wheras I guestimate the SIII at need about $10K. I’ll download your
book - that occurred to me this morning. As I said, I really prefer the
SIII, but am curious how those who have both rate them against each other. I
think I need to find non-usurous Jag mechanics, too, as I really expect
seals to be much more (as in, they will charge an engine pull even if not
absolutely required to do the job, and if the book says $X to do the trans
and $Y to do the seals, they will cahrge X+Y, although much of the prep work
is common. So, I half expect to hear more like $2000 the pair. I guess I’m
just a bit gun-shy: we are in the middle of a full restoration on the home
Hunt
At 03:32 PM 9/29/96 -0500, James A. Isbell wrote:
Hunt,
cover costs.I just went through a complete restoration and up date of my '82 XJ6 to an
have been $8400.Is it worth it to restore?
Labor about $250 ( almost any good leather shop )- Misc trim about $200 ( SICP )
$4550Now, tell me, where could you get a car to replace it for anywhere near that
price?Add $2000 to that and you could have a complete engine overhaul, but it
doesnt seem like you need it.Add $1200 to it and you could have a GM TH 350 transmission (the quarter
is not strong enough for.But even if you went for the whole enchilada you are only out $7750. What
could you get for that money, a Ford Escort ? Do you want a Ford Escort?Jim
Nance O’Neil
Date: Sun, 29 Sep 1996 15:34:14 -0700 (PDT)
Tony-
Thanks! Anything’s possible, but not just yet! My wife is restoring our
home, so I’m data gathering!
Hunt
At 03:02 PM 9/29/96 -0700, Anthony Parkinson wrote:
You wrote:
Hi all-
I’ve reached a semi-crisis with my '85 XJ-6.We have seen 26 of them so far … all solved…
It takes 4 months…
Also,
value
may prove challenging.No no problem insured for the value of $26,000
of
view.Included is a one year comprehensive warrantee taken care of but your
local Jaguar dealer on my behalf…How big a job is installing an upholstery kit?
the
problem, or lots of work and money!No work at all just $22,000 for your car to be made brand new again and
that is including a new car warrantee.all the best
tonyVICARAGE JAGUARS…Restoration & Enhancement Specialists
fax 305 443 6443
Date: Sun, 29 Sep 1996 19:21:56 -0400 (EDT)
Subject: Re: XJ-S help needed
Jim: The wires may be the air temp wires,if so some people like to use
them others not, makes little difference, the plug plugs into the left
air horn, if wire is already there, then it would be the temp sensor for
the ECU, and would plug into the water hsg on the left side.
Air filter being backwards, always wondered that myself, though I think
that the metal portion of the filter assy was suppose to be infront of
the air valve, incase of a backfire, would not blow out the filter or
maybe set it on fire.
The rubber plug in the front of the block is the timing chain tensioner
release access hole, ALWAYS REPLACE WHEN DOING WATER PUMP JOB, soooo easy
then but sooooo hard when it leaks and the water pump is in place.
Gasket sealer on water hoses, and bypass lines, I use a sealer sold by GM
that never hardens. I clean the pipes well then a dab of the sealer. The
line that goes from the water pipe on right side has two different sizes,
the part number is CAC5093/1, as for the other ones, I think you can use
cut hose there.
Chad Bolles Jaguar South 306 Valcour Rd Columbia SC 29212On Sun, 29 Sep
five questions.
and it probably should be connected.What is the effect of the air cleaners being mounted backwards in the
reverse alot.What is the rubber stopper in the front of the block on the right
occasionaly?The two hoses from the thermostat housings to the crossover pipe have
end on the crossover pipe with a hose clamp?I plan on using a gasket sealer on the water pump gasket as the
Jim“Better an outlaw than not free.”
Nance O’Neil
Date: 30 Sep 96 12:20:07
Subject: Re: Engine Heaters/cats
Lloyd : Not only cats, but bird nests too.
My #2 car only gets driven enough to keep it “current”, i.e., once a week,
while waiting for a buyer; once when I popped the bonnet for a preflight check
I found a rat’s nest in the vee of the engine, complete with offspring… The
delights of living in the bush!
- -Jan
Date: Sun, 29 Sep 1996 21:52:17 -0400 (EDT)
Subject: Jag shops in ohio
Try:
Welsh Jaguar Enterprises, in Steubenville. 614 282-8649.
Also try
Earl Gibbs. W65th St @ Clark, Cleveland. 651-5512.
Mike Frank
1969 E-Type 2+2
Date: Sun, 29 Sep 1996 21:52:27 -0400 (EDT)
There is a commercial product called “Carcoon”, or something like that,
which is exactly what you describe. It is a mylar tent, fully sealed on all
sides. There is an air valve which allows air out, but not in. A small
electric blower slowly keeps fresh air circulating, while silica gel packets
keep the car dry. I have seen this advertised in Hemmings, in the US, and in
various British magazines.
Mike Frank
1969 E-Type 2+2
Date: Sun, 29 Sep 1996 21:52:24 -0400 (EDT)
Subject: Re: European License Plates
Custom, replica license plates are available from:
Eurosign
1469 Banks Rd
Margate, FL 33063 USA
(954) 979-1448 tel
(954) 970-0430 fax
They can make up anything you like.
Mike Frank
1969 E-TYpe 2+2
seen in the U.K…Thanks again for any help!
cobac@ix.netcom.com
Date: 29 Sep 96 21:51:56 EDT
Subject: Start/stop xj6
I recently read a post from Bob Sack in which he’s describes
how his car will start and the minuets latter it will die.
This is the same problem I have been going through
for two months. Car starts cold fine ( although a slight
miss after 30 seconds. Cold start injector?)
but after about 2 min it suddenly dies. If it stays running
and I’m able to drive it, I may go 20 miles stop and go, suddenly
it dies as if it ran out of gas or the ignition were switched off.
I can only restart with the gas pedal to the floor, runs 20 sec.
and dies. I’ve played with this for months to no avail. I’ve
replaced almost everything except the “CAR” and that may happen.
I have become frustrated enough that next week it will be tow
to the Grim Reaper (Jag mechanic) Any thoughts before we go ??
Date: Sun, 29 Sep 1996 22:24:15 -0400 (EDT)
Subject: Re: XJ40 Rear Struts
Robert: You would be MUCH better off going with the kit to replace the
self leveling system, around $480. Never have to worry about a mistake
that Jag admitted doing.
Chad Bolles Jaguar South 306 Valcour Rd Columbia SC 29212 803 798 3044On
Date: Sun, 29 Sep 1996 22:33:39 -0400 (EDT)
Jim: I hope the price for the TH 350 was a mistake $2000, lets hope not,
$350-500 around here rebuilt any day.
By the way in my note to you about your XJ-S, I forgot to say ALWAYS, ALWAYS
replace the front seal, soooo easy to get to with water pump off, that
will also give you a chance to retorque the balancer to the proper 150lb
that it is suppose to have, and I have found more than a few that are loose.
Very important that balancer be torqued properly,cause loose balancer
will eat up key and keyway in balancer.
Date: Mon, 30 Sep 1996 15:17:37 +1300
I’ve seen the Carcoon running it works as already described but its definately an
indoor product (and i thing Robin wanted something for outdoors)as the plastic is thin
and you also need a power soucre.I believe they are approx USD700.
From: David J Shield David_J_Shield@ccm.fm.intel.com
Date: Sun, 29 Sep 96 20:43:00 PDT
Subject: Metal-Master pads (old brake dust thread)
I'm back from vacation and am wading through the digests - one more
to go. I didn't see a resposnse to the question about metal-master
brake pads, so here's my input. I'm using them on my Volvo 745TGA,
they stop the car very nicely and produce much less brake dust than
OEM. My Jag-specialist mechanic recommends them on Jags as well.
When I do the brakes on the E I plan to use these (unless someone
has info to the contrary...).
'70XKE 2+2
'84XJ6 VDP
'87Volvo 745TGA
Date: Sun, 29 Sep 1996 20:45:28 -0700
Subject: Re: Ignition Amplifier
Well let’s see. An intermittent open in the distributor pickup can
cause a voltage spike that could fry the amp. Jaguar also had a
bulletin specifying replacement of both units.
Jan Wikstroem wrote:
If the ignition on the 6 is based on the same principles as that on the 12, I
can’t see how a fault in the distributor pickup could damage the amplifier (but
I’m prepared to be enlightened - my infallibility is not yet complete…). My
own ignition troubles with both V12s have been mainly due to broken connections
between pickup and amplifier (where the wires issue from the distributor) with
no damage to either amplifier or pickup. I exchanged one amplifier for a used
spare, but found afterward that there was nothing wrong with the original
amplifier except a break in the wiring just inside the amplifier housing.-Jan
Michael P. Neal ASE Master Technician, Jaguar Certified
'93 Ducati 900SS '83 Porsche 944 '85 Jaguar XJS
Home (707) 829-8464 Work (707) 577-0101
http://www.wco.com/~mneal (always under construction:-)
End of jag-lovers-digest V2 #389
Return-Path: @owner-jag-lovers-di1
Received: (from majordom@localhost) by ekeberg.sn.no (8.7.5/8.7.3/on4)
id for jag-lovers-digest-out; Mon, 30 Sep 1996 11:50:39 +0200 (MET DST)
Date: Mon, 30 Sep 1996 11:50:39 +0200 (MET DST)
Message-Id: 199609300950.LAA02498@ekeberg.sn.no
X-Authentication-Warning: ekeberg.sn.no: majordom set sender to owner-jag-lovers-digest using -f
To: jag-lovers-digest@sn.no
Subject: jag-lovers-digest V2 #390
Reply-To: jag-lovers@sn.no
Errors-To: @owner-jag-lovers-di1
Precedence: bulk
Status: O
X-Status:
X-Newsgroups: mail.jag-lovers-digest
jag-lovers-digest Monday, 30 September 1996 Volume 02 : Number 390
Re: Front oil seal
Re: Euroupean License Plates
Re: Fuel
Re: SII LWB front seat mounting position
Re: XJ40/Jaguar World
Fred Phelps voltage reglator
Re: Metal-Master pads (old brake dust thread)
re: Re: SII LWB front seat mounting position
Fuel rating
swap name
Re: Start/stop xj6
UK- DVLA Auction of number plates
RE: Re[2]: Prononuciation & Price (Irrelevant jag content)
Re: Pronouncing the name.
Re: Lower Hose Heaters (no Jag content)
Re: fuel tank repair
Re: Change V-12 Head Gaskets Every 30,000!!!???
Date: Sun, 29 Sep 1996 20:52:39 -0700
Subject: Re: Front oil seal
It sounds like we have too many lump specialists on the list. Please
take Randy’s advice. A sleeve on a removable distance piece, help me
up I’m rolling on the floor laughing uncontrollably. Is there an
internet smiley face for that?
Randy Wilson wrote:
These seals ride on the harmonic balancer and although it may be hard
to believe, the rubber seal wears a groove into the metal rotating
surface. If you have a groove, even a small one, the seal will
either not seal at all in severe cases or begin to leak prematurely.
The standard fix is to go to your local auto machine shop and order a
harmonic balancer “sleeve kit”. This is a thin walled sleeve that
press fits over the harmonic balancer and provides a good clean
sealing surface. I have done this several times with very good
results. Oh yeah, if you are really uptight, you could simply buy a
new balancer. the sleeve kit cost roughly 15$US and the balacer
Jim Cantrell
job correctly, in addition to the seal, is:C40147 distance piece
EAC8101 O-ring
And, if you are unlucky, a pan gasket set.The two parts should be under $30 from the dealer.
Randy K. Wilson
Date: Sun, 29 Sep 1996 21:09:37 -0700
Subject: Re: Euroupean License Plates
There’s an ad in the current issue of Hemmengs Motor News in the Jaguar
parts section for a company called Manhattan Mini that’s selling English
license plates for $9.95 USD for one, $7.95 for the second + $5.95
postage. They do not give a voice phone number but their fax number and
address are: Fax (212) 719-5313 P.O. Box 271, Ridgewood NJ, 07451. I
don’t know anything about them other than seeing their ad. Hope this
helps! GWC
Date: 30 Sep 96 16:02:08
Subject: Re: Fuel
Jana : …87 XJS. I fill it up with
unleaded fuel, 87 octane. Should I go the extra buck and start using the
premium fuel?
It’s very much a matter of compression ratio and driving style. Of my two
pre-HE V12s, one has the low compression ratio (7.8:1) and the other has the
high ratio (9:1). The low compression model runs just fine on regular unleaded
throughout its performance envelope; the high-compression one demands Super or
high-octane unleaded if you ever use more than 1/2 throttle (and feels
“inhibited” at smaller throttle openings).
I don’t know what CR variations were available in the US in 1987, or even if
yours is a privately imported car from another market, such as Canada or
Mexico. I also don’t know what part of the HE or post-HE V12 engine number
signifies the compression ratio; in pre-HE, it’s 7P(number)LB for the low
compression and 7P(number)SA for the high compression type. If you’re sure that
you have the right user’s manual for that particular car, I’d follow its
instructions; otherwise, it’d be nice if somebody who knows HE and post-HE
numbers could come to the party.
- -Jan
Date: 30 Sep 96 16:24:26
Subject: Re: SII LWB front seat mounting position
Don’t worry about the rear seet leg-room, Peter - even if you take away eight
inches of it, you’re only down to the SWB leg-room, which I regard as more than
ample (I’m exactly 6 ft). On the other issue, I’d suggest letting your
girlfriend (If 5’8" is vertically challenged, how tall are you?) set the seat
to the position she’s comfortable with, then checking how many notches forward
travel there’s left. That’ll give you the maximum distance you can move the
seat mount back without putting the driver’s seat off limits to her. I’d allow
one notch as a margin for error…
- Jan
Date: Sun, 29 Sep 1996 22:33:40 -0700 (PDT)
Subject: Re: XJ40/Jaguar World
Roger Peng wrote:
…I’m not particularly a big fan of XJ40 styling either
despite being an owner, and I don’t think either headlight style
will make the XJ40 look as good as a series III. Nevertheless, after
getting used to it, I think the XJ40 has got its own special character.
I still enjoy looking at them when I see them on the road.
It’s kind of like the Triumph TR7 and the Jaguar XJS. They look kind of odd
and “untraditional” at first, but eventually the look grows on you…
Roger’s mostly on the mark about the XJ40. While it may look a bit like a
cross between an 80’s Buick and a Rolls Royce at first, it isn’t without
its own boxy charm - it’s been growing on me. I recollect a lot of nasty
comparisons between the XJS and the Chevrolet Camaro back in the 70’s.
Even the E Type got made fun of by Road & Track in an April Fool’s issue
when they talked about the hood-mounted camera option for the longer bonnet
needed with the mythical straight 12 engine.
What’s more important, the XJ40 is FAR superior as an automobile to ANY
previous mainstream XJ (including the S). The AJ6 engine is EXACTLY what
Jaguar needed to get us away from the XK engine. The transmission’s light
years better than the BW boxes. The car is roomier in every way (except
for that durn sunroof) than my XJ-6C. The trunk’s useful. The car’s
actually rust resistant. None of that filling of two tiny fuel tanks.
Criminey, even the electrical system works right most of the time!
The only places the XJ40 didn’t outpace its predecessor were in the rear
suspension and those stupid mouse track shoulder belts. The headlights?
Well, the car was DESIGNED with the rectangular lights in mind and the
round ones look like some bodged British effort to accommodate the American
market, just like the XJS “glow worm” headlamps that were sluffed off on
the US for many years due to lighting rules. Jaguar made a real and
successful effort to break new ground with the XJ40 as they did with the
original XK120, as they did with the Mark I and VII, as they did with the E
Type, and as I hope they’ve done with the XK8. I like the looks of my
XJ6C, but I’d rather DRIVE the XJ40. It’s the only car that’s made me
think of selling the XJ6C in spite of its beautiful looks, engine, and
ride. It’s primitive by comparison - only its looks have saved it so
far…
While I appreciate Jaguar’s retro efforts on the X300, I don’t agree that
making the XJ6 look more like a “Series” XJ6 is making it any better than
if it was restyled to look like a “retro Mark II.” If Jaguar wanted to
make it better, they should have taken 500 lbs out of the weight rather
than trying to ape a 30 year-old success. The cup holders are nice, but
otherwise I’ll take an original XJ40 over paste jewelry any day. Remember,
the XJ40 was JAGUAR’s LAST volume production car. The newest cars are like
pre-WWII Bentleys after the RR takeover. The cars are certainly nice, some
may even be great, but it was a different Bentley company that did them.
-Steve A.
'67 E Type Coupe
'76 XJ6C
'91 XJ40
PS: That doesn’t mean I won’t be keeping a close eye on XK8’s - after all,
that E Type of mine turns 30 next year!
Date: Mon, 30 Sep 1996 15:35:26 +1100
Subject: Fred Phelps voltage reglator
Air gap! Half the problem is that the damned things have too many
electical air gaps. Now I find out the’re in there on purpose. That sure
explains a lot!
Regards Peter Smith
Date: Mon, 30 Sep 1996 02:22:25 -0005
Subject: Re: Metal-Master pads (old brake dust thread)
David:
I didn't see a resposnse to the question about metal-master brake pads, so here's my input. I'm using them on my Volvo 745TGA, they stop the car very nicely and produce much less brake dust than OEM. My Jag-specialist mechanic recommends them on Jags as well. When I do the brakes on the E I plan to use these (unless someone has info to the contrary...).
I would like to point out an understanding I have from years ago,
but cannot really vouch for its truth: When you increase the amount
of metal in brake pad lining, you improve its performance under hard
use due to improved heat conduction away from the contact surface.
However, you also increase the wear rate on the ROTOR. Therefore,
if you are the type who doesn’t use brakes very hard, you are better
off with NON-metallic pads, since the rotor will need less or no
turning at pad replacement time, while the metal pads may require
rotor replacement as well.
How all this changes with the abolition of asbestos and the
introduction of Kevlar, I dunno. I also dunno if MetalMaster pads
actually HAVE any metal in them, or the name is merely left over from
the old days. And, of course, I dunno if metal content has anything
whatsoever to do with dirtying wheels.
| - Palm’s Postulate
Date: Mon, 30 Sep 96 16:40:42 +60000
Subject: re: Re: SII LWB front seat mounting position
Thank you, Jan.
I’ll try the notch method.
I guess one could also position the seat such that it was impossible for
one’s better half to drive.
Perish the thought!
Regards
Peter
| you take away eight inches of it, you’re only down to the
| SWB leg-room, which I regard as more than ample (I’m
| your girlfriend (If 5’8" is vertically challenged, how
| tall are you?) set the seat to the position she’s
| you can move the seat mount back without putting the
| driver’s seat off limits to her. I’d allow one notch as a
| margin for error…- Jan
From: Volker Nadenau nadenau@ipers1.e-technik.uni-stuttgart.de
Date: Mon, 30 Sep 1996 08:05:32 +0100 (MET)
I own an XJ40 and I'm looking for something to fill up the blank spot
on the front of the car. I really don’t care what the plate says, so long as
it is the elongated yellow or white with black letters European plate, often
seen in the U.K…
I think the easiest way to get European looking licence plates is to buy
them in Europe. I am living in Germany and the system works like the
following. First you have to go to a private shop, who will print you the
set of licence plates with the required number on it. In your case you
could freely select the number. If you want to use the plates for use on
your car in Germany you will need the official stamp from the MOT … on
it, but not in your case. I do not know the british sytem, but I am shure
sombody will tell you.
In case you are interested in a german plate (white with black numbers
and a blue strip on the site (EU sign), let me know.
Volker>
Volker Nadenau Phone: ++49 711 685 7200
University of Stuttgart Fax : ++49 711 685 7143
Institute for Physical Electronics Internet: nadenau@ipers1.e-technik.uni-stuttgart.de
Pfaffenwaldring 47
70569 Stuttgart
Germany
Date: Fri, 27 Sep 1996 17:43:45 +0100
Subject: Fuel rating
Fuel rating
The 87 Octane petrol does not contain less energy than 98 octane. It is the difference in
Thermodynamic efficiency of the combustion with is higher in car with higher compression ratio,
which can allow high compression car to run more efficient.
The reason for low compression cars (and Jags) in the US is the other requirements on low
emmission on Nox’es. Nox content raises with the average combustion temperature which is
higher for high compression cars.
Here you have also the reason for that Exhaust gas recirculation system in the US. The idea is
the reuse “used” gas thereby reducing the amount of combustible gases which lower the
combustion average temperature further.
In short : run the lowest octane fuel permitted.
My V12 12.5:1 runs currently on 98 octane here in Germany, Europe.
Dont know if lower octane would be acceptible
Regards Jeffrey Gram
Date: Fri, 27 Sep 1996 17:50:03 +0100
Subject: swap name
swap name
I vote for the last more informative name, but something more “cathing” would be appropiate.
what about,
Jag-lovers spares corner ?
The Cats Corner ?
The Jaguar Junk Yard
Jag-lover parts bin ?
Jag-lover parts stock exchange ?
The Wild Cats corner ?
Excellent idea Gunnar,
Regards JEffrey Gram
Date: 30 Sep 96 18:47:33
Subject: Re: Start/stop xj6
Assuming that the XJ6 injection ECU operates on much the same lines as that of
the V12, it appears that your mixture setting is so leaned out that the engine
can’t run when the cold start enrichment drops out (after a variable time
according to ambient temperature, but two minutes is in the ballpark).
If this is indeed the case, the fault has to be one of three things (apart from
a wiring/connector fault, which is always the most likely):
- The ECU has an internal problem (unlikely)
- The fuel pressure is marginal
- The manifold vacuum sensor/air flow sensor (depending on age of car) has
developed an electrical fault.
The easy way to test (1) is to plug in another ECU; if you have a friend with
the same model car you might twist his arm…
It’s also easy to test (2); all you need is a pressure gauge with a hose tail.
Check your workshop manual for the method and the right pressure.
The workshop manual will also have a method for the basic testing of (3).
- -Jan
Date: 30 Sep 96 19:06:01
Jim Isbell :
2) What is the effect of the air cleaners being mounted backwards in the
housings…
3) What is the rubber stopper in the front of the block on the right…
diferent sizes on either end (smaller on the crossover pipe)… -
- There’s a metal plate opposite the throttle butterfly to prevent damage to
the filter paper under extreme conditions, when the filter is turned the right
way round. - Access to timing chain tensioner lock. Replace if it leaks seriously, but
it’s a nasty job. - I can’t tell you what the hose size is, but I’ve used bits of standard hose
that are a very hard fit on the thermostat housings and just nice on the
crossover pipe. - It can’t do any harm. When those hoses need to be replaced due to old age,
they’re likely to be baked on so hard you have to cut them off anyway.
- -Jan
From: brownd@filon.ml.com (Dave Brown - London Dev X1818)
Date: Mon, 30 Sep 96 08:37:37 BST
Subject: UK- DVLA Auction of number plates
This is really for UK jaglovers…
Just noticed that in the next DVLA (DVLC ?) auction of unissued numbers two
particularly relevant ones for jags are for sale:
1 XJS
1 XJR
God knows how much they’ll go for…
(There’s also “123 DB” for auction but I think it might be out of my price
range!!)
David Brown,
brownd@ml.com
///_/_/_/_/////_///______
/_/_//_/_/_/_/_/____
/_/_/_/_/______/_/_/_/______
/_/_/_/_/_/_/________/_/_____
___/_/_/////_/_/_/_/_/______
/_/___/_/_//_/_/_/____
///_/_/_/____/////_///_________
Date: Mon, 30 Sep 1996 01:50:23 -0700
Subject: RE: Re[2]: Prononuciation & Price (Irrelevant jag content)
If it’s in a Jaguar, the correct pronunciation of “lump” is either
“mistake” or “abomination”.
Graham Watson
Managing Consultant (Finance)
Enterprise Services
Microsoft Limited ECU
Tel: UK(+44) 1734 270 431
Mobile: UK(+44) 802 881806
mailto:grahamw@microsoft.com
http://www.microsoft.com/UK/support/serv_ad.htm
-----Original Message-----
Sent: Friday, September 27, 1996 6:46 PM
Cc: jag-lovers@sn.no
Subject: Re[2]: Prononuciation & Price (Irrelevant jag content)So, if the owner makes the rules does that mean that a Jag with a small
block Ford V-8 will now be socially acceptable? And the ones with Chevy
lumps are automatically excommunicated?How do the Brits say “lump”
MikeC
______________________________ Reply Separator
Subject: Re: Prononuciation & Price (Irrelevant jag content)
Author: zavadsky@austin.ibm.com (Vlad Zavadsky) at Internet
Date: 9/26/1996 11:23 AMI would like to know how people at Ford pronounce Jaguar. After all,
let us not forget, Jaguar is Ford – the owner makes the rules…Vlad
85 XJS
Date: Mon, 30 Sep 1996 04:06:15 -0500
Subject: Re: Pronouncing the name.
OK, let’s agree to differ. I think we’ve covered the full range of opinions on
this one. I move the gag. Do I need a seconder?
As the editor of the mail bag in my local paper often says “This subject is now
closed”
Robert Bradley, Owner of four “Jags”.
Date: Mon, 30 Sep 1996 11:42:34 +0200 (MET DST)
Subject: Re: Lower Hose Heaters (no Jag content)
They are not block heaters. They don’t open the thermostat but rely mostly
on conduction to keep the engine warm. That is why they go in the lower
hose not the upper hose which, as you correctly note, wouldn’t do diddly)
They are usually low powered (150 watts?) and do need to be on all night to
be effective. In the UK you shouldn’t need any kind of heater. All these
gadgets are for extreme climates.
A couple of folks mentioned engine block heaters that are mounted in the
lower
radiator hose. How do these things heat up all the coolant, considering
that
when they start the thermostats are closed and they only have thermal
convection to circulate the heat ? Is that really enough to get
to the thermostats, open them, and generate convetion throughout block
and
radiator ?
I plan to install a heater just to reduce fuel consumption after a cold
start. Last time in the US I had checked for a hose heater (this was
in the summer time …) and the only available where block heaters. You need
to remove a freezing plug in the engine to install them.
A block heater for a V12 was about $30.
I think there are also heatered including a small pump, but I have lost this
email.
- Matthias
Date: 29 Sep 96 09:20:12 EDT
Subject: Re: fuel tank repair
Sandblast - access level of pinholes, weld in new metal.
paint, rusttreat, back in - really easy actually,
or buy a new one, then sandblast, paint… etc.
Forget about paddy -puddy stuff, thats not a decent solution for a Jag.
Date: 29 Sep 96 09:20:16 EDT
Subject: Re: Change V-12 Head Gaskets Every 30,000!!!???
bullshit
Was that your local garage-freind ??
You dont ever “have” to. As long as the engine is treated and maintained
properly there is no need for regular swap of head gasket.
The head warps only if overheated i.e. driving with less that normal coolant.
Regarfs Jeffrey Gram
End of jag-lovers-digest V2 #390
id for jag-lovers-digest-out; Mon, 30 Sep 1996 18:54:33 +0200 (MET DST)
Date: Mon, 30 Sep 1996 18:54:33 +0200 (MET DST)
Message-Id: 199609301654.SAA07161@ekeberg.sn.no
Subject: jag-lovers-digest V2 #391
Precedence: bulk
jag-lovers-digest Monday, 30 September 1996 Volume 02 : Number 391
Re: Substitute throttle potentiometer for V12 EFI
Re: '88 XJ-S V12 (UK) steering rack replacement
Replace the ECU as preventative maintenance?
Re: Front oil seal
Re: [JAGSWAP] The Jaguar/Daimler used parts exchange is open for business!
usenet and parts lists.
missing person!
Weekend trip in the cat - XJ-S convertible roof question
Alternators and Dynamos
Block heater
nice new jag - need answers
brake pad info.
SIII FI stalling
Re: Alternators and Dynamos
Date: 29 Sep 96 09:20:04 EDT
Subject: Re: Substitute throttle potentiometer for V12 EFI
Brian,
I find it quite remarkable that you took the trouble to find an
alternate solution to the Throttle Pot. My V12 surges as well.
The ultimate solution would be a non-wearing pot of course ,
but if they last 10 years -not too bad i guess.
A small mirror and and a LED-Laser and pick-up sensors packed around
a perimeter of 180 degrees would do the job together with a
array of gates to electronically switch resistances in / out. To overcome
coarseness a Pentium 200 based or other small microprocessor could time
interpolate and average over the signals from adjacent LASER detectors and
switch
a secondary bank of fine adjustment resistors in and out.
When you think about it the Mechanical Lucas Injection system from 1954 D-type
Racers,
the Alfa Romeo 70’ties spider US Fuel Injection (BOSCH), were actually small
mechanical
wonders. Technically advanced in mechanical terms but now far too expensive.
A replacement injection pump of the mechanical type can be very expensive -
Porsche about 14.000 US $.
The Electronic versions are technologically more advanced, take account of
temperature and air
pressure and other factors, but rely on mechanical to electrical conversion of
parameters, and it is here that wear and the teeth of Time gnaws on the sensors
and
connections , causing so many of the faults in an injection system.
I have just bought the latest book from AJ6 engineering on EFI, an impressive
work,
and fairly pricey (Fifty pounds) , but invaluable info
Date: Mon, 30 Sep 1996 12:01:49 +0200 (MET DST)
Subject: Re: '88 XJ-S V12 (UK) steering rack replacement
- The service manual specifies the use of the Jaguar ball joint separator
JD24 and Steering Rack checking fixture JD36A. Is it possible to use any
other ball joint separator and ignore the checking fixture, aligning the
rack by look and feel instead ?
I used a “super market” ball joint separator and it just worked fine. My garage
is very small and when removing the second ball joint, I managed to damage
the rubber. A new ball joint is already waiting for fitment …
I’m not sure why you would need to check the alignement. I just refitted it
and it seems to be ok.
- Anyone have a UK supplier and part number for the aftermarket bushings
WITH WHOM THEY HAD GOOD EXPERIENCES ?
I got mine from Barret’s and they are black. They fit well, but the there
is a little metallic sleeve in the middle. When the rack moves in the fittings
you can feel (barely) the sleeve touching the mounting. I don’t know the
other fittings, but a “full” plastic fitting might be better.
- How difficult is it really ? Any non-obvious caveats ?
There has been an excellent description a while back on this list. I guess
it’s best to remove the rack from the car. I had a hard time to press out
the old fittings (yesterday I cleaned up the garage and found a old heavy
duty press which would have done the job in seconds ). If at all possible
get the extractor tool. Check if you have a leak at the tower seal once the
rack is out. Make sure you remove the bold which connects to the tower
to the steering column, otherwise it won’t come off
- Matthias
Date: Mon, 30 Sep 1996 12:06:31 +0200 (MET DST)
My '84 XJ-S V12 had suffered from an intermittent surge at cruise speeds;
I’d tried for a couple
of months to locate the cause. The throttle potentiometer (TPS) was one of
the first things I had suspected,
but it checked OK with a meter. To shorten a long story, I finally ran
wires from the TPS to the inside
of the car so I could monitor the voltage while driving the car. And I found
when the car was surging,
the voltage was erratic, so a new TPS was in order. ( I took the old one
apart first to see if it was
repairable. It’s not- the resistance coating was worn down to the bare
plastic).
I repaired mine by opening the pot, cutting off the copper connections to the
contact and resoldering them so that the contact point on the resistance
would be about 1mm off the worn area. Works fine since then. Took me about
1 1/2 hrs.
- Matthias
Date: Mon, 30 Sep 1996 05:10:50 -0000
Subject: Replace the ECU as preventative maintenance?
On an older car (above 100 000 miles) would it make sense to forestall
problems by replacing the ECU. What about other sensors and the injectors?
Is there any evidence that after market parts are better or worse than the
original.
I have a 1983 XJ6 but I think the questions is valid for all older Jags.
Roger Langley
Date: Mon, 30 Sep 1996 12:16:07 +0200 (MET DST)
- What is the effect of the air cleaners being mounted backwards in the
reverse alot.
I think there is a protection in the filter just in front of the throttle
to avoid damage when the engine back-fires and for this reason “front”
is marked on the filter
- Matthias
Date: Mon, 30 Sep 1996 12:20:53 +0200 (MET DST)
When I got my V12 front oil seal the sleeve was included with the seal
(original Jagaur spare part)
- Matthias
Date: 30 Sep 96 02:40:00 EDT
Well, if it is only a matter of dishing out money in either direction,
go for the car you like the best. Even the 420 could turn out quite
magnificently, when throwing 20.000 $ at it.
Date: Mon, 30 Sep 96 12:54:21 BST
Subject: Re: [JAGSWAP] The Jaguar/Daimler used parts exchange is open for business!
Gunnar,
Whenever I try and look at your newly-created used parts conference my Netscape
crashes! Is this just me or is anyone else having difficulty?
I’m running Netscape 2.01 on Sunos.
I managed to view your Ford example OK.
Cheers,
David Brown,
brownd@ml.com
Date: Thu, 26 Sep 96 12:18:00 DST
Subject: usenet and parts lists.
My comments are as follows. I have access only to E-mail.
I don’t have full internet access and therefore, the new
proposals are not of value to me. The cost of full internet
access here is about $30 per month which I don’t feel is
money well spent, so I am not currently subscribing. I
like the present format of the Jag Lovers group and I
think Nick is doing a marvelous job.
David Chiahotny '70 E-type ots
Hamilton Ont. Can. '71 Spitfire
E-mail: david_chiahotny@dofasco.ca
Date: Mon, 30 Sep 1996 07:04:29 -0500
Jim, can’t help with question 1 but here are a few hints in the others.
reverse alot.
I believe/think it is because there is a metal backing plate on one end of the
air filter which lines up with the intake opening to stop the filter paper
being sucked in - that was my best guess.
- What is the rubber stopper in the front of the block on the right
occasionaly?
It is just that - a stopper which plugs up the hole used for access when you
need to lever the timing chain tensioner out of the way. The stopper will
eventually go hard and leak. It’s a cheap part (last time I did it it was) so
you might want to change it while access is easy - but conversely it is also
not that hard to change later in situ.
- The two hoses from the thermostat housings to the crossover pipe have
I wasn’t aware that they were different size ends (mine’s 87 XJ-S). I blew
these two hoses a week apart and the local garage man replaced them without any
trouble - “from Nissan sir” was his response (or Mazda/Mitsubishi - can’t
remember but you get the idea). Both parts are still fine after 8 months. P.S.
I don’t think they are actually conected to the thermostat housing but it
doesn’t change my answer.
- I plan on using a gasket sealer on the water pump gasket as the
Personal opinion - Never used it, never needed it (on hoses). Others may
differ but I would just clean up the pipes before fitting the new hoses.
Robert Bradley
82 XJ6, 82 Daimler, 87 XJ-S
Date: Mon, 30 Sep 1996 09:01:06 -0400
Subject: missing person!
Sorry for the shotgun blast to the entire list;
David at DCHIAHOT@DQC2C.dofasco.ca,
(Hamilton, Ontartio) several mails to you have been returned to me
undelivered. Could you please send your correct
e-mail address.
'62 E-Type, ots
Date: Mon, 30 Sep 96 10:16:49 EST
Subject: Weekend trip in the cat - XJ-S convertible roof question
This weekend I made the approximately 300 mile round trip from
my home in Raleigh, NC to Williamsburg, Va. Included an
excellent early morning (5AM) highway ride on Sat. morning -
no traffic - cruise control @ 100 mph. Great ride. Chose
back roads from the return trip on Sunday afternoon - winding
roads, small hills, few lights or traffic - another great run.
This is the first chance my cat has really had to stretch his
legs since I was adopted. He performed flawlessly. Overall,
a very satisfactory weekend.
I did notice that I can change the amount of wind noise by
adjusting the tension on the roof clamps for the convertible
top. Above about 8o mph or so the noise is loud no matter
what, but at lesser speeds, the roof tension seems to make a
big difference.
Does anybody know just how tight the clamps ought to be? If I
make them too tight, do I risk damaging the roof or the
insulating material around the roof frame? How will
tightening these clamps effect the water seal? I had the
insulating stuff replaced recently because the roof was
leaking - now I wonder if it was just that the roof was too
loose.
Anybody have any knowledge on this topic?
- mclaus
'93 XJ-S Convertible
Date: Mon, 30 Sep 1996 09:57:40 -0400 (EDT)
On Sat, 28 Sep 1996, Hunt Dabney wrote:
The situation:
My XJ-S had leaky cooler lines. Replaced the rubber hoses with fuel
injection hose and fuel injection clamps. Could you be as lucky? Also
check the seal around the speedo drive.
Take a deep breath and install a set of decent seat covers.
Live with it.
XJ-40s are really ugly. The only Jag I would never want to own. Your
car has a classic design.
For some reason the kits themselves are extremely expensive… If you can
rationalize their cost, pay the incremental amount to have it
professionally installed.
I am a great believer in this. Very easy and inexpensive and restores the
feel of the car (that degraded so slowly over time that you often don’t
realize how bad things have gotten).
Sounds like the the whole thing has been triggered by the trans leak. Fix
it or replace the trans with a TH350 and proceed from there.
John
From: “Makoto & Ann Sado Honjo” fm7m-hnjy@asahi-net.or.jp
Date: Mon, 30 Sep 1996 23:38:55 +0900
Subject: Alternators and Dynamos
A very simple minded question. What’s the difference between an
alternator and a dynamo? Is one American and the other English for
the same thing, or is there some kind of a distinction?
Makoto Honjo
Phone/Fax +81-3-3473-1848
Date: Mon, 30 Sep 1996 10:07:29 -0400 (EDT)
Subject: Block heater
I noticed a msg talking about a block heater. For the XJ-S you would need
parts C41103 hose torad, C34403 heater element 110 volt C36996 elbow for
heater element and C41099 hose to water pump. The XJ-6 4.2 engine uses
parts C34403 heater element 110 volt and C29037 adaptor. The C29037 may
come with the heater element which is also called a Bray heater.
Chad Bolles Jaguar South 306 Valcour Rd Columbia SC 29212 USA 803 798 3044
803 798 4512 FAX
Date: Mon, 30 Sep 1996 11:37:08 -0400
Subject: nice new jag - need answers
I have found a 1991 ultra-mint XJS V12 Convertible to replace my 1987 that
was destroyed. One owner, all receipts, flawless, only 35K miles.
Two questions before signing the cheque though:
It was a bit low on coolant and I want to make sure it’s not leaking or
(perish the thought) small head gasket leak into exhaust despite the low
mileage. What’s the best way to figure it out???
The temperature guage never rose above mid point (N) despite repeated
thrashings in very hot climate. However, when cruising at speed in a more
subdued manner, the temp.guage dropped a little bit. Is this normal or
should I be concerned???
Please respond quick before I buy it anyway.
Thanks Julian Mullaney
Date: Mon, 30 Sep 96 08:45:15 PDT
Subject: brake pad info.
With all the talk about brake pads I will add my tupence worth.
Softer pads of course wear out quicker, but they stop the car with less
pedal pressure. They are less likely to squeek.
A hard pad will last longer, but requires more pedal pressure and will
wear out the disks faster.
My common sence tells me that a softer pad is better for those who do not
drive the hell out of their cars. But, I have always replaced with a bit hard-
er pad, and driven them for a hundred thousand plus miles before they need
replacing. (Of course this is with standard tranny’s)
After 150-180,000 miles, disks need turning. This figure comes from adding
30-40,000 miles on factory pads, then replacing with a harder pad, which tend
to last 120-140,000 miles. Then I change pads and have the disks turned. I’ve
not put enough miles on a car to change them again, that is I sell it before
it needs pads again.
LLoyd
Date: Mon, 30 Sep 96 08:58:26 PDT
Subject: SIII FI stalling
I need some urgent help. my 4.2 fuel-injected Series III has developed
an alarming problem. On the weekend I changed the coolant, running clear
water through the rad to flush. (By the way, the easy way to drain a
post 81 Series III is to remove a) the plug on the bottom of the trans.
cooler pipe, which runs below the rad. Careful! not too much force!, and
b) the plug to drain the block, located on the left side of the engine
just behind and below the manifold. Be sure to have the AC in DEFROST mode
or the heater core will not drain). On the first run after this, the car
started and idled normally, but after 4-5 minutes, as the enrichment
tapered off, it would idle normally, but giving it any fuel made it
stall immediately. As this happened at an intersection, it was quite frightenin
.As soon as the temperature rose to about 75 celcious, the car pulled away
normally. The identical secenario occurred yesterday.
The rad flushing may be a red-herring. I see the possibilities as a) a
fault in the coolant temperature sensor (NOT in the cold start system, since
it starts and idles correctly), b) a sticking butterfly valve in the airflow
system c) a defect in the auxiliary air valve. The problem is symptomatically
identical to a lack of choke in a carburretted car until warm up.
Have I missed anything? All electrical connections are secure, and have
not been disturbed. Up to now there has been a very slight flat spot
or hesitation under these circumstances. With cooler weather, I need to sort
this out. God knows what might have happened if my wife had been driving
when the car stalled in an intersection! HELP from those with FI experience
please!!!
Gregory Andrachuk
Date: Mon, 30 Sep 1996 09:51:19 -0700 (PDT)
Subject: Re: Alternators and Dynamos
Hi-
Dynamo is the UK word for Generator. Generators are DC devices, producing DC
by the switching action of the brushes on the commutator. An alternator (the
more modern of the two), uses slip rings and brushes and generates AC, which
is then rectified with semiconductor diodes.
Regards-
Hunt
the same thing, or is there some kind of a distinction?Regards,
Makoto Honjo
Date: Mon, 30 Sep 1996 09:50:47 -0700 (PDT)
John-
As you just finished restoring your home, I’m sure you can appreciate that
I’m in restoration (read that remodel) hell at the moment, so am inclined to
a)whine, b)panic at the thought of more work to do on anything, c) have a
low tolerance for dumb problems, d)all of the above. I chose “d”.
Besides being the ugliest Jag ever made (this is rapidly becomming the
consensus – no offense to you XJ-40 drivers out there!), Jim Isbell informs
me that Jag “improved” it by putting in an American Luxury car type of
suspension. Enough said!
I plan to find a local “rent a lift” DIY garage and get the beast up on a
rack for close inspection. Will survey what it needs and go from there.
Thanks for the reality check!
Hunt
The situation:
when I come off the freeway, driveway needs cleaning daily… 151k miles,My XJ-S had leaky cooler lines. Replaced the rubber hoses with fuel
(great headliner, though!).Take a deep breath and install a set of decent seat covers.
Live with it.
car has a classic design.How big a job is installing an upholstery kit?
professionally installed.How about suspension rebushing?
realize how bad things have gotten).Sounds like the the whole thing has been triggered by the trans leak. Fix
it or replace the trans with a TH350 and proceed from there.John
End of jag-lovers-digest V2 #391
