Hi Slawek,
I think that’s great progress.
You can enter all that at www.saloondata.com and add photos as you like. I like those sites and do contribute every now and then.
I’m pretty sure that if the gearbox number is SH1075 that it would be original to that MKIV and not the engine T9019.
Just like Tim wrote, it was the normal procedure for these cars that the distributors (Hornburg in LA and Brysons in AUS) to change the engines if cylinder head or main bearings needed attention.
Did you check the damper and water pump (and generator mountings) if they are MKIV or MKV style? On mine everything was like MKIV except the oil filter and carbs. But I have changed it all to MKV style over the 18 years of ownership, except the generator mountings.
There are small differences in details, so if you do an engine rebuild, the flywheel, both ends of crankshaft etc. are slightly different (no problem, but good to know), what I find funny is that valve timing is supposed to be slightly different, but I did not find a part number on my camshaft nor did I notice any difference to the MKV ROM data.
Oh, but now it’s all back together and runs. We just got about 25cm (10") of new snow so I don’t think I’ll be driving again anytime soon.
Quite striking original colours, what I have been told, is that “Ivory” was quite a rare colour on both MKIV and MKV, the white cellulose paint dried slowly. In the 1930’s Silver and White were available at extra cost only.
A bit odd that they say (or have recorded) “Brown” for the interior colour, usually they called the “brown” they had for “Pigskin” or “Tan”, or officially “Pigskin Grain Tan”, Connolly VM.3280 (Tan).
AFAIK there was no other “brown” interior available in 1946-1952.
And a “Dark Sand” (brown) hood too.
Ps. Now if someone would be able to find out which car originally had my engine #SL2199 ???
