Sorry, not the same, but similar backing plates. The first four are factory originals as found inside my MKV DHC trunk lid:
The large one is for a luggage strap and the three small ones are for the trunk lid tool tray cover hinges (3 pcs) one clearly has half a hole, a drilling due to being very close to something else, I think the folding stay-up mechanism on the LH side.
The rest are backing plates I made for the DHC door check straps as they were completely missing on my car when bought, this was about seven years ago. The small ones are the backing plates for (5/16 BSF IIRC) setscrews for the door hinges that align with the window channel. this is MKV but I think the hinges and windows channel are the same as on a MK IV at the rear of the door. The front of the door is different on the MKV with the NDV (âNon Draft Ventilatorâ as named by the factory).
Ps. The last one is of new repro door trim panel catches I got form Ed Nantes, they were laser cut in Australia, and they are the same on SS Jaguar and MK IV DHCâs, they are âtackedâ (attached with small âtackâ nails to the plywood and the large holes lock with the round head screws on the wooden door frames so as originally, there will be no screws visible when everything is correctly mounted (the veneer covered door top capping hides the top part of the door trim panel screws),
