I need this Jaguar Adjustable spacer cbc950523 But there isn’t anywere
… InEurope?
not sure, but…
The people that write the catalogs are generally clueless. I assume they mean rear wheel bearing ADJUSTMENT spacer.
I wrote to Germany… it’s incredible if there isn’t…maybe if I know the diameter I could search something
sng is not responding, now what? does anyone have the technical specifications such as diameter? I’ll build it…
All the rear hub bearing spacers were SPECIAL ORDER and the dealer will NOT take back if you want to return it/them.
When I worked at the dealer I asked our parts dept if I ordered a range of sizes, could I return the unused? NO NO NO NO!!! (you order and buy them, they are YOURS)
This is the reason I buy a salvage part and use everything except the bearings if the aluminum hub is damaged. (I replace with new bearings)
The hub spacing and preload is already setup at the factory so just the bearings are needed.
If I am JUST replacing the bearings, then I use the original spacer and shim.
ok…now I understand, but I have now bought the parts to rebuild the hub… obviously I don’t have these spacers…but is it possible that there isn’t something adaptable on the market? you don’t have the diameter specifications to let me build it exactly?..basically I’m simulating a wheel that has exaggerated play. when we open it we will know exactly what is missing, even though I already know that this ring is not there.
it might be a day of two but I am rebuilding a LH rear now and I can measure the spacer I have. Not sure what material it is made from.
The little ‘spacer/shim’ usually sticks to the bearing and is discarded.
After discovering the shim is missing, the opportunity to measure it is lost.
A dial indicator could help the get close to the correct size?
Had you time to control this diameter?
