So I had another go at this Windtone WT618 "H"horn
I believe it is the same as in XK120, this one was from a '51 MK7, and had been lost in pieces deep in my garage, so due to its fine decor look, I was loath to throw it away
turned out my dumb, as when I inspected it under good light and magnification, I could see the wires went to each coil end, and this time it measured about 3.0 Ohms, suggesting a coil resistance of ~2.7 Ohms
I observed that the end of the positive and negative terminal are within 1/8"of my each other, and my probe had probably slipped down to short the circuit…it looks like in the pic
So that brings me tho the wiring. It has two wires running inside connected to each terminal, and a separate earh wire on the mount ( as pictured)
The separtate earth wire appears to searve no function, as it is electrically insulated from the other two terminals insides
I have two wires emerging from the dome, and they are activated, sounds very loud
Thing that’s got me fooled is felt certain I had “tested” it before resto by applying 12v to earth wire/body, and one terminal, so unless i put it back together wrong, I must be dreaming
Do XK120 owners have one or two wires emerging from bowl grommet ?
here is how it went together
This horn was in poor condition
taking them apart is easy, I soaked all parts ib CLR for a few days, then painted and lubed all parts
The points need to be drawn across a points file, they arc a lot, and pull big current, up to 10A
Once I had it all working beautifully, I decided to panel beat the dents and creases out of the bowl, did a pretty good job, file finished it sand, etch & prime, the alloy is not conducive to paint adhering wel
It is a appreciably louder than the smaller OEM 420G horns, which I am just overhauling as well
Evey one I have come across has points failure, which can be revived with a file, or eveb wet & dry in most cases
