I have a LHD 1958 Jaguar XK150 DHC. The question is, can I swap the old steering column felt bushes for the newer MK2 plastic bushes?
I am currently converting to RHD and whilst I have the column out of the car I have fully dismantled it ready for rebuilding - so far so good.
I was surprised to find that it ran on felt bushes but there have been a lot of surprises with my car and its still only early days yet.
I was a little dubious about the felt bushes and thought that the existing bushes must need replacing after 60 years on the car but is that really the case? When I did a bit of reading I discovered that once you replace the felt bushes with new ones the column becomes a lot tighter to the extent that it can end up difficult to turn.
I did read somewhere that you could use the MK2 plastic bushes but again it was just hearsay with no pics, no comparisons or confirmation from someone who had successfully done the swap themselves.
Please can anyone shed any light on this for me before I rebuild with felt?
The Mk2 plastic bushes look a lot thicker than the felt and have lugs on the outside from what i can see in photos…im assuming you have to trim the lugs off but do you also have to ream out the inside?..interested on how you get on fitting them Andy…please put up a post when you fit them…cheers…Steve
Yes all of what you have said has run through my mind too ha ha.
I will of course post about my progress. I intend to post updates on everything that I have asked the forum about to help others like myself who follow in the future.
I must say that this is a lovely forum to be on and everyone is so very helpful and pragmatic. Its a pleasure to be on here and a real step up from other forums that I have been on.
My 1965 3.8S came with plastic bushings, virtually the same as the replacements. I lubed them as best I could with some oil after I had it all back together and found the wheel would not self center easily. Seems to have worked OK (and lasted so far) as I was NOT about to take that overly complex steering column out a second time!
