it is my first post here but I was reading the forum and I hope you can help me.
I have Daimler LHD 1992. i am currently experiancing a issue with no light:
tail
side
glove box
cigatette lighters
hood.
relays seems to be fine. Fuses in box 1, 2 and 3 as well.
VCM is showing massage: Fuse 6.
update: i replaced 2x30A fuses near the inertia swith, failure still can be displayed after pressing VCM button.
I see that there areseperate 2 problems:
Not familiar with the XJ40 electrical schematic but just a suggestion - if you tested fuse 6 with an ohm meter and it tested as good, then check the fuse connections to make sure they are clean and secure enough to make good contact at the fuse/
i did bridge with paper clip on relay slot and light came on. Should I look for the problem in facia light switch than?
VCM - my mechanic told me to press the button before switchin ingnition. Doing this I have Fuse 6 and 5 failor but now I am thnking that this might not be correct. System requieres around 40 sec to check all elements. Simple quesstion is: when should VCM button pressed?
You folks that are new(er) to Jag-Lovers may not know there is a wealth of information available on the old site that is at jag-lovers.org (the current site being .com rather than .org). There is an e-book here: http://www.jag-lovers.org/ebooks/bookindex.php?Vbook=xj40
The answer to your simple question is in section 6.2. Hope this helps.
