Ok thanks! Going to order a set. I’ve always been worried that someone’s not going to see the dim bulbs of the original setup. Would not be a pretty thing to be at the end of a rear ender.
Two pictures, the first shows the tail lights, LED on the left, conventional bulb on the right. The second picture shows the 4 way flashers on, again LED on the left. Pictures were taken in daylight, just before noon.
Does anyone know if these would fit into a series 1 light fixture? Or have a recommendation for a Series 1 rear light LED bulb? I’ve seen XK’s set , but it’s quite expensive
The fronts I listed in the original post should fit, unless Series I front parking/turn signal fixtures are different than Series 1-1/2. The rears? I don’t know.
I just ordered the front and rear flashers and rear taillights plus flasher unit this morning from superbright. They have a 15% discount through tomorrow. Here is the order with p/n.
I took them out and numbers before I ordered. But I have a clear front lens. Not sure if yours is amber. If so you should order an amber bulb. I did red on the rears per John Walker
One more thing. My old flashers worked fine with LEDs in front and filament bulbs in back. There was enough load to trigger the flasher cans. After putting LEDs in back, the signals and 4-way flashers didn’t work. So I went to the store and bought two electronic flashers that the package said would work with LEDs. No joy when I installed them. I wound up taking them back and getting a pair of Sylvania Load equalizers. I installed those on the front turn signal wiring. Now everything works as it should with the original flashers.
John are the load equalizers resisters? I went ahead and ordered a LED flasher so I hope it works. Why two? Its been 20 years since I did my car but I thought there was only one.
Installation is simple for the 1156 bulb since there is only one filament, so one wire to the bulb. Connect one wire on the equalizer to the hot wire going to the bulb and ground the other wire. I used a machine screw and nut to secure the equalizer to the backside of the lamp housing and also used that as the grounding point.
Edit: It’s dark now and I checked. These things look astoundingly bright in the dark, much brighter than stock. and the sharp “on” and “off” gets your attention.
