When substituting new Lemforder lower ball joints, does one still use the original tab washers or some other locking scheme?
Rick OBrien
65 FHC in FL
Rick OBrien
65 FHC in FL
Mine came with new bolts pre-loaded with a Loctite compound. You can put it in with a drop of the red stuff if you’re worried. It will require heat to loosen.
As Erica, I just used medium Loktite.
Ok, thanks. I have a little extra length to use up with the grip of the bolts I ordered so I may throw in some split lock washers too. McMaster has a nice AN cad plated bolt that is 27/32" L with a 5/16" grip.
Rick
I use the lock tabs. I can’t see why Loctite wouldn’t be as good though.
