Ok kids to the left is the 185/70 way to small
Middle are the old Michelin’s xvs 185
To the right is Dunlop 205 70 15
All of these are on 5 inch wheels
I’m leaning towards the middle either in Michelin or vreds
I had 205 for 25 years a tad big but drives like a new car
Do I want that?
Lately 50 and chucking into turns is fun!
What I do like about the vreds the compound is soft to the touch.
I just looked at my mark 2 and forgot lastmonth I put the exact tire…Im leaning that way. For some reason they seem to give a jag the best of both worlds, looks and size but the ride is really good.
gtjoey1314
Joey,
Since you’re using the car as a dd and live in New York and plan on touring long distances in all seasons, if I were you I’d check the heated debate in archived threads here about the possible temperature limitations regarding Vreds. Just one example:
I’m not sure which way to come down on this argument but I think I’ll go with the Michelins when I time out in a couple of years.
Thats why Im asking …I couldnt sleep as I had David and Wiggles in front of me with my heater hose…God you guys are ugly in the middle of the night
Anyway, I ordered farm/diesel oil resistant hose . It should do the trick for the return blow pipe.
Anyone else on the tires?
I have to sort out the fan relay with the spal unit, I keep blowing fuses with MY HAYDEN adjustable switch I think the old style unit only goes to 25 amps and these new fans start at 30.
We shall see…
That’s the 18515
That’s what Dave and others were saying
It’s a good compromise if I don’t want 205s this time around
I’m gonna go through tired like pre corona toilet paper so we see
Wigs you kept me up all last night
Try the Michelins with 30psi front and 34 psi rear which I find the sweet spot for the 185 VR15. You can drop to 32psi at the rear if you are not carrying luggage.
Personally, I don’t think the heater hose breather would be all that much of a problem.
I “temporarily” used some 5/8” heater hose for the breather on my Mustang, and 5 years later, replacing it has never found its way back onto my to-do list, as the heater hose has worked fine.
I’m going back to Autosport tomorrow
They have these Porsche hoses for that purpose
Maybe the German technology will make it faster
Having fun…
Will report back.
Gtjoey1314
It’s almost time
I will have spares. Wheels. Relays
Pipes😀. Belts. Pulleys. Starters and so much more get your goody closets empty
Gtjoey1314
