Hey guys
When i replace the left licence plate bulb (the right one work) both bulbs not working now.
Where is the fuse for those ???
Shahar,
my car is the same year as yours. Based on the schematic, the two license plate lights are fed separately from the two in-line fuses that supply power to the taillights. These fuses are in the trunk, close to the taillight housings. If the taillights are working, it isn’t a blown fuse!
Shahar,
I remember from your prior posts that a prior owner of your car installed a lot of aftermarket LED bulbs in it. Was the license plate light bulb that you removed from your car an LED or a conventional incandescent bulb? Was the replacement bulb that you just installed an LED bulb or an incandescent bulb? Is the bulb that you did not replace an LED or incandescent bulb?
Paul,
It have an oem bulbs…
The aftermarket led’s is for the headlights
