I’ve got a strange issue with only one bulb of my RHF turn signal working. It isn’t the bulb, have swapped out a known good one; it is not getting any power, but only to one side of a 2 bulb lamp assembly. The result is that I have a working signal, although it’s a bit more dim than the left side, and I get a “bulb fail” warning light and double speed blinker everytime I use the right signal.
My assumption is the module, and I have a known good to swap out. I know it could possibly be a broken wire in the circuit, but that seems unlikely.
The fundamental question after all this is: where in the heck is that module located? The RHF module. I know where the rear one is (trunk, right behind battery mount)… but where are the front ones? Because they sure aren’t located anywhere easy to find (I’ve been searching around the engine compartment area)… is it inside the vehicle somewhere? Under the dash?
