Hi everybody, i’ve been trying to start my xj6 Series 3 1986 today and no luck. It will crank, and crank, but no fire.
I’ve done all the following procedures:
1- New battery
2- New sparkplugs
3- Both fuel tank empty, and now 1/4 tank on left one, and 10liters on right one.
4- Checked fuel pump (noise heard in the boot) when 12v applied to white/green wire at the firewall.
5- Fuel coming to fuel rail, checked when disconnected fuel hose at rail, fuel coming from both hose and metal rail (can’t check pressure).
6- Fuel pressure air hose replaced (old one cracked).
7- Have spark.
8- Injectors should be working because before changing spark plugs, and after some tries, some of the spark plugs where flooded with fuel, so i think fuel is coming through injectors.
I can crank, and crank till battery declares low voltage and it will not move the starter.
Only on time today i could get a start condition, the car will climb in RPM, and keep a high idle of 1200RPM (not a problem right now). But after that, i switched the car off, and here we are, no more start. Tried like 20 times, and no start, nothing happens.
Tried with bot tanks, but prefer left one because the selection valve works with the left one when not energized, by the way when i click the button at the dash, i can hear a “click”, so i guess it’s working.
Also, fuel relay is out of the car, just a jump between white/green and 12v at the relay base to reduce possible problems.
Any ideas???
Thanks a lot!!
Ariel
