I have rebuilt the engine (new valves and rings) in my 1968 Series 1.5 E Type. I have never seen the engine run before and the car I bought had a lot of engine parts missing (carbs, distributor, alternator etc.).
It had good cylinder pressure when I tested it. All.The parts I added are either new or in very good condition. But I.have been unable to get it started or even fire.
I think the problem is very low or no vacuum when engine is cranking. By contrast, the green Jag manual says cranking vacuum should be 16-18 inches mercury.
My list of possible causes for the lo/no cranking vacuum are:
Vacuum leaks but I can’t find any
Hole in Stromberg carb diaphragm but again I can’t find any
Incorrect crank, can and valve synchronization but I was very careful when I assembled the engine and good compression tests suggest this is not the problem
So I have 2 or 3 questions:
Is it correct that cranking vacuum should be similar to when engine is running?
Which item in my list of possible faults in list above is likely to be my problem?
What are other possible causes that I have not listed
And thanks for your patience if you have managed to get to the end of my long story.
If you have good compression, I would not suspect a mechanical problem. Have you tried spraying in a shot of staring fluid. If it fires on that you can discount a ignition/ timing problem. If nothing happens with the starting fluid, I would assume an ignition problem. Check for spark at your plugs. Good spark? You have a timing problem. No spark at plugs, check for spark at coil. Good spark at coil? Check your distributer and rotor. No spark at coil? Check for 12v at the low voltage side of coil. No 12v at coil? You might have an ignition switch problem. Try a direct wire from the battery. Have good 12v to the coil? You have a points problem or a bad coil.
Thanks for the advice but can others focus on the specific questions I ask about a sense of manifold vacuum.
I have already checked other issue such as spark and all is ok.
To add to the evidence of low manifold vacuum, I have observed that the piston do not rise off the base with my Stromberg carbs when cranking the engine. If there was a good vacuum, the piston would be higher.
I must admit I have never checked vacuum while cranking an engine, I wouldn’t imagine there would be much as the engine revs are very low. When the manual says it should be 16-18 inches at what revs does it say that should be measured?
Matt
Edit:
Also does that engine have a pcv valve going to the manifold, or any other devices such as brake booster, etc. Block every hose going to the manifold as well.
Matt- page 750 in the big green manual is explicit that “cranking vacuum” should be “16-18 inches Hg”. Google may be right about 3" but I find jag manual is trustworthy .
There has to be a good vacuum or the ZS carb won’t work and air and fuel won’t flow into the cylinders.
Robin- Frightening thought but my good compression tests suggest this is not the case. But I will double check.
May I ask anyone else who wants to comment to please assume that my cranking vacuum is lower than it should be and then speculate on what is causing this. Thanks
If the Engine has proper compression, and you don’t have proper vacuum at the carburetors there can only be one reason: a massive vacuum leak somewhere.
Look for a crooked manifold, or a missing pipe on the intake such as the takeoff for the vacuum brake assist.
Do you have the large crossover plenum intake system that goes over and back to the exhaust side? Replaced all the gaskets in that and carefully tightened the flanges?
Years ago a friend replaced a starter motor , and a few other parts , car would not start ,
Took him and a m8 2 days to find the fault , the starter motor was the wrong polarity , was turning the engine the wrong way
Was not a jag mind !
I too am having trouble overlooking my prejudice that the vacuum target range quoted looks like “idle” rather than “cranking”. A search of the broader interweb provides some support for this, but I’m having trouble overlooking that any view can get support there…
Several days have passed and I have made more tests including pressure testing to check for leak s - and found none.
I now accept that vacuum of around 3 inches is ok and jag manual is misleading But still engine won’t start. I have double checked ignition and it seems ok. Injecting starter fluid in the carbs gives strange reaction but no cylinders firing. Instead, there seems to be back firing on the exhaust and some back flow of air from the carbs. Again cylinder pressure seems good.
Given all this, what else should I check, especially re the Stromberg carbs?
I did a test on my 3.4 XK150 to see if the brake servo was leaking. Vacuum at idle was 13. I plugged the servo line and it remained unchanged. If you are a 4 you have a leak.
I concur.
I had vacuum gauges in many of my cars, including my V12, never saw more than 3 - 5 inches vacuum while cranking.
18 - 20 inches is on idle, on a perfectly tuned and fully warmed engine, with A/C off and no electric loads.
