Torsion bar setting bolts… about how much of the threads are actually used in the process of setting the correct ride height? I ask this because the threads at the top 1/3 are unhealthy looking. Both shafts are somewhat bent at the upper part and I am concerned that once I straighten them the threads may become unusable. Thank you.
Hi John…one of mine was bent but not so much…i screwed on 3 standard size nuts…one at top, middle, bottom…got the flats to line up then between two thick plates and in the press…worked great…Steve
I haven’t seen fully threaded Grade 8 bolts with a square head.
I think yours can be straightened. I would try it in a bench vise with an O/A torch and hammer.
You could also get some out of a saloon. Try Jaguar Heaven in Stockton CA.
I cant see why you couldn’t use a grade 8 or higher if you can find one and have tops welded on…or try Coventry Auto …I would try to straighten what you have…but dont try to re cut the thread…you dont want to be removeing any metal…a thread chaser would be better Steve
Thank you, Tony. I cut off the heads from my old ones today and I’m going to see if I can weld them onto standard bolts. I’ll be in touch if I can’t pull it off.
Hi John…when i mentioned welding a top on to a bolt i was thinking more of a thick squarish shape dished washer to put your bolt through then welding on top to create a bolt similar to the original…Steve
I agree with Rob that welding some form of a top onto a threaded bolt shank will fail. The problem with this is that you’ll end up with a bolt that has a tensile strength of (at best) 30K PSI at the weld joint and up to 80K PSI along the rest of the bolt shank. The stresses will then concentrate in the weakest area.
If determined to make your own, a better route would be to obtain a Grade 8 bolt with a large enough head so that it could be profiled down to size on a mill using a rotary table. Shank threading to size would have been preceded with turning on a lathe. Maybe this is how the reproductions are made? The ones I last purchased from Coventry Auto sure looked as if their heads were milled and not forged.
Does the “T” bolt only see stress during ride height adjustment? Can someone tell me if I’m thinking this right? What gives me this notion is the 3/8" (horizontal) bolt that goes thru the fork then thru the chassis plate and locks the fork to the chassis once the optimum ride height is set. I’m surprised that they didn’t use a thicker bolt here, however. Thoughts?
