I have a problem with lower bush in rear absorbers, they need replacement, but according to the data I poses there is no original replacement. Do you know if there is an alternative solution? I dont want to buy new shocks just because there is a bush issue. Pls help.
I am open for mods, etc. If you have any ideas for modifications / use of smth which just fits and does the job, it will be great too.
I replaced mine in the front and used a EURO part from RockAuto had a tough time pressing them out… make sure the through bold fits the bushing with minimal play my lower bolt must have been replaced as lower bolt was a sloppy fit and old bush and new bush identical specs.
ÜRO PARTS Jag part number = CAC75851 URO # = URO005308 — cheap and work well
Good luck
Brad
