Oh, me. I replaced mine with the engine in the car, but before I installed the radiator and bonnet. Even then, a formidable task. Included removal of the water pump. Careful there, the drive off the cam is brittle, donāt askā¦
I was lucky, one of my āpullersā fit the dampener and it came off smoothly. Odd no woodruff tyoe key??
My Opti has a āpinā drive. A bit quizical on my part as to the fit to the cam nose. I got it right as it ran!!!
Odd that the coil would fire sans a āmake and breakā. of the 12v !!! Only a working Opti and an engine. crank seems to be the only way to fire a plug.
Son and I diagnosed āsparkā as the issue by taking off a plug wire and putting it on my ātest plugā. I have one in my ātune boxā.
Merely clamped on a wire with an alligator on itās end.
First crank. No spark!!! Swapped in spare coil and module and cleaned the corroded coil wire. Test again, engine fired on 7!!!
Quandry??? Bad coil wire and/or coil/module !!
Solution. New coil wire and leave the swapped in coil/module in place. label the original. toss the old coil wire.
So far, it fires perfectly.
My guess would be that your OPTI served for just over 100K.
Were I you, and I am clearly not, Iād look hard for a NOS OPTI. Just too much work to swap in a āfixedā one. And hope it lasts a long time.
Just thought. It can be tested in situ, before all the other stuff is replaced, WP, damper, belt, bonnet, radiator, etc!!!
An odd thought. A VIzio You Tube piece depicted an LT1 sans OPTI. Older tech HEI distributor providing the fire. The installment in a battered early Corvette. Up for auction in a ājunk yardā.
Keep the few of us that still read here postedā¦
Good luckā¦
Carl
