Well spring has almost sprung. I have a few outstanding
projects left on my lump and they’re biggies. At the top of
my wish list is a full repaint - new color entirely. I’ll
tackle that next fall when I put her to sleep for the
winter. there are a couple of reputable classic car
restoration shops nearby and know it will run me between
$15k and $20K. I’ll post that topic separately if anyone’s
interested.
This spring, I’m going to tackle the engine bay wiring
(clean up by removing what’s no longer needed, rerouting and
re-shielding etc.) I plan to start at the firewall as it
appears to be the most daunting. I haven’t mapped out the
tasks yet but have read several threads and also viewed a
few project car pics posted.
I’ve noticed a couple of different approaches folks have
taken to the firewall when viewing pics. Some have removed
the heat shield entirely, some left alone and I saw at least
one lump that appeared to have closed cell foam with
aluminum facing.
Since I intend to repaint and in a new color, I’ll remove
the firewall heat shield, at least temporarily. This will
allow me to clean the firewall and cut down on the labor
costs for the engine bay painting when I bring her in to the
restoration shop.
That thought led me to the task of cleaning up the wiring
and a few others.
I plan to route my ECM under the passenger seat, currently
in the engine bay.
I want to replace the battery as my local NAPA salesman
talked me into a gargantuan replacement for the Jag OEM and
it barely clears the hood. My mistake entirely.
I would love to get your input on a few things.
First, for those who have removed the firewall heat shield
and left it off - any noticeable difference in cabin temp
or sound?
Anything that can’t be rectified by adding heat shielding
and sound proofing to the interior?
Battery - for those who have moved theirs to the boot, any
issues, regrets, preferences?
For those who haven’t, do you have a battery make and model
that’s at least close to OEM size but with a little more
cranking power for the V8?
I guess my preference is to keep the battery in the engine
bay utilizing the OEM hold down, but still like to hear from
others.
Radiator header plate - I followed Andrew’s Radiator swap
and I’m thrilled with the results but will admit, the job I
did cutting the hole in the header plate for the cap is
nothing short of embarrassing. Does anyone have a spare
they care to sell? Better still, does anyone have one with
the hole ‘‘expertly and symmetrically’’ cut in it already?
Lastly, I’ll get new A/C lines to run them lower in the
engine bay and come up from the bottom to attach to the
compressor. Any advice or pics on what you’ve done in this
regard? My set up is an L98 crate engine with a March
Performance Revolver Serpentine set up and they do sell A/C
line adapters to accommodate this
Thanks for your thoughts as always.–
Sean 86 VDP
Prior Lake, Minnesota, United States
//please trim quoted text to context only
