My 85 with an LT1 has about 9000 miles on it, runs like a top, but
has a very erratic oil pressure gauge. I’ve got nearly everything
on the car in great shape, so this is bugging me. It’s always done
it, so I know I have good oil pressure, but watching it bounce
around from less than 0 to around 40 lbs. is getting annoying.
Sometimes when I first crank her up, the gauge won’t even move
until I give it a good thump. Any help out there? Thanks, Tom
Nichols
Black and tan 85
XJ6
Yellow 59 Austin Healey lumped with 289 Cobra–
Tomcat2
Ruidoso N.M. USA, United States
In reply to a message from Tomcat2 sent Sat 20 Dec 2003:
Well Tom it may be that you have two problems in a common
circuit. 1 it sounds like the meter itself is sticking and 2 the
pressure transducer is on the blik also, this assumes that the
original Jag meters were retained. 1966 BJ8 convertibles.—GNB–
DAIMLER : V8 SALOONS SAFELY FAST IN AIR SMOOTH STYLE
In reply to a message from GNB sent Sat 20 Dec 2003:
Tom-Your gauge may also be losing its ground-it must be grounded
via the u-clip holding it in place.Try tightening the knurled nuts
holding it in place.This is assuming you have the stock gauge(s)–
Bruce Kimball
Columbus/NM, United States
