[Lumps!] front end problem
putting in new bushings on the beast but having problem with the
lower fulcrum shaft on the bottom.I don’t want to beat the hell out
of it,so anybody tell me an easy way to get it off ?–
sparkster
//please trim quoted text to context only
In reply to a message from sparkster sent Thu 30 Aug 2007:
jam two nuts on one end and try turning it with a wrench to free it
up - alternatively, but a sacrificial nut on the end and beat
away…
These parts are often bent in crashes and left in place after the
repair - this makes them harder (but not impossible) to get out.
Put anti-sieze compound on them when you re-install.
Cheers, Andrew Robertson, New Zealand
Xj s1 454tt, Xj s1 383–
Andrew Robertson
Sparkster,
Sadly, there is no easy way. Please read Kirby’s book on the XJ-S. It
will tell you that:
a) you must beat the hell out of the lower fulcrum bolts
b) as a result of the beating, you must replace the lower fulcrum bolts
c) as a lump owner, you have it easy. Those of us with V12 engines in
our XJ-S’s have to raise the engine in order to gain sufficient
clearance to withdraw the bolts.
Dave Harvey
Los Angeles, Ca.
89 XJ-S V12 Marelli
sparkster
