As some of you know I am prepping my 86 VDP for new paint. Doing a
complete ‘‘strip the car to bare metal’’ routine. Some say ‘‘Aw she’ll
be right mate’’ Just paint over the checked paint - ignore the
unusual stuff’ Yeah well,…dream on … So I had these strange rust
blemishes coming through the paint on the outer rear ‘‘flank’’ over
the rear passenger wheel. Do I putty the hell out of it, or find
out what the real problem is? So I got the dremel tool out and
fired it up. Well folks… here is the heads up warning for all of
you people thinking of popping several thousand bucks into a nice
paint job. My car had leaks at the corners of the both the front
and rear glass. Never suspected that the rear glass leak allowed
water to gain entry to the rear bulkhead panel and remain there
trapped until I came along with my dremel tool to see why the thing
was rusting. These cars are a series of boxes welded together and
therein lies the problem. If water gets into one of these boxes and
dribbles down to a point where it can not exit… SO if you are
going to do paintwork, I would recommend that you remove the gas
tanks and peer up into the cavity just forward of the location
where the tank neck goes through the body, there you will be able
to see the inside of the rear flank and any rust starting. I would
go so far as to recommend a good sized hole about 2 inches wide be
made to spray some sort of rust preventative stuff into the cavity
that exists in front of the rear bulkhead and then install one of
these rubber body plugs. The inner forward wheel well is the floor
of this cavity, and the bulkhead is the rear wall, while the
portion of the body that you see when the rear seats are removed
form the upper inside ‘‘wall’’ So if the back window leaks, and you
have water on the floor under the rear seats, there probably is
rust between the outer fender and the inner bulkhead support
waiting to come through your new shiney paint. So I have posted
some pics in the Photo album section under ‘‘86 VDP rescued’’ FWIW–
Alyn
Seattle WA, United States
//please trim quoted text to context only
