In reply to a message from EriktheAwful sent Tue 14 Sep 2010:
Erik:
Is there any on line footage on the Omaha LeMons?
130 F is cold, or did you mean 230 F or perhaps, yeah, 130C is aa
bit hot!!!
Johns cars offers a kit for the Big block Caddies into the XJ cars.
A tight fit likely, but doable.
The V12 Th400 is Jaguar specific. I’ve no idea as to tail shafts.
But, the trans mount is based on a flat steel plate for the GM to
Jaguar adaptations. Not too hard to cut one uot to fit the GM
rubber pad.
If the Cad engine mounts are up front on the block, it doesn’t seem
to big a task to transition to the Jag mounts.
It sure is going to be nose heavy, although the OHC is no light
weight.
The Jag shifter ends up close to where the GM unit is.
Andrew probably has a lever available to bolt right on.
One of the performance trans shops markets an infi nitely
adjustable lever that would likely do it.
Good luck with it.
Pics???
Carl–
We raced our '87 XJ6 in the 24 Hours of LeMons in Omaha and
blew the head gasket. Crossing the finish line the temp
gauge was pegged out at 130+ degrees. Since we’re endurance
racing, we’ve decided not to chance this motor and
transmission any more. I have a 472 Cadillac motor and a
short-tail BOP TH400 that we’re going to replace it with.
Since Jaguar used the TH400 behind the V-12s, is the TH400 a
relatively easy swap into the XJ6s? Which tail do the XJ-12
TH400s have? Short, Long, or Cadillac? Are the crossmembers
the same? What are the differences in the XJ6 and XJ12
driveshafts? Does the shifter bolt right up or will I need
Carl Hutchins 1983 Jaguar XJ6 with LT1 and 1994 Jeep Grand
Walnut Creek, California, United States
//please trim quoted text to context only
