Hi fellow infidels -
I’m a new lump owner (it’s a 1976 XJ12L - white with black interior - no
rust), and have a number of questions. I’m sure a lot of this has been
covered before (I’ve been to the archives, but some of it’s not covered).
I’m not sure what size engine is in my car. It was advertised as/supposed to
be a 350, has a tag on the door frame indicating it’s a 400, and my mechanic
has said it’s a 305. I’ve heard that one can get the number off the block
next to the water pump, and Chevy can decode the number. Is there a digit or
a series of digits in the block number that will tell me without me having to
piss off a guy at a parts counter?
Transmission - same problem. Supposed to be a 350TH, but the mechanic says
it’ got a square pan, and he says that this would indicate a 700R4. He said
that the O/D would have to be hooked up electronically, but even running as a
3-speed, the 700R4 is a good/better tranny than the 350TH. How would I find
out which tranny I have?
Various electrical problems: I know the folklore of the Lucas electrical
beast, but in the short time I’ve had the car, the wiring seems very heavy
duty, and the switches seem to be the weak links in the equation. Is there a
domestic source for switches? The switches I’m talking about are the 6-pole
rockers used for the windows. Is it the general felling that with new
switches, the windows will work correctly, or will the window motors need to
be rebuilt or replaced? The headlights/taillights/side marker lights don’t
work at all - what would be the proper sequence for determining the problem -
is there a separate fuse bank somewhere? The horn doesn’t work - is this a
common problem that has a usual cause that can be fixed by the average
schlub?
How do I connect the speedometer?
I also need some front signal lenses - any known source for these?
The a/c isn’t hooked up, but isn’t really a concern. How do I hook up the
wiring fromt the compressor to the climate control switches on the dash?
The dashtop pad is cracked (again, not a major concern) but are these
generally available?
What attracted me to the car was the “no rust” factor. I’ve been all over
the car and there really isn’t any. The paint is a little weak, but okay.
Mea Culpa/warning: I bough the car over the web, sight unseen. I know this
is extremely dangerous, and wouldn’t do it again, but I’m determined to make
this a great car (which it can be - no rust).
Any help would be great, and I’m glad to have my lump.
- Paul
Now is the perfect time to take a new look at Shaklee
Demetra & Paul Kane
Body & Soul Wellness
Shaklee.net - Body & Soul Wellness</
A>
