In reply to a message from Doig sent Mon 29 Jun 2009:
No, it is only the Jaguar gauges ‘‘indicated’’ pressure, unless
independently confirmed with another mechanical gauge. If you
purchased three different senders, the results would probably vary
a lot.
Meaning = approximate oil pressure to be used ‘‘as a guide’’. My S1’s
both show the same ‘‘on the move’’ pressure. The idle pressure is
lower than those shown on both cars with totally different age and
types of SBC engine.
Pressure can be dependent on the weight oil you are using, good
quality filter and the temperature outside and the engine
temperature.–
there any problem with mine having much higher oil pressure.
Great, then I understand your relief. Use the gauge as trend
reference; zero should be big convern and overall lower at times
might mean ‘‘something’’.
I have mapped the water temps from the Jaguar gauge, post the new
stabilizer, and they match the readings from the Autoxray scanner
reading in real time mode.
N = 180 These are plus/minus 5 - 10 degrees as the Jag
O = 185 gauge mvoes so slowly - up and down.
R = 190
M = 200
A = 210
L = ??? never seen that high on the gauge as the LT1 fan comes on
at 215 water temp which appears to be around the A-L.
When the car is moving slowly in traffic, N-O is the ‘‘normal’’ spot
or even lower at highway speeds.–
In reply to a message from Roger Mabry sent Mon 29 Jun 2009:
Thats about what my temp gauge sits at to. Good to have an idea
what it indicates.
I have reached the L myself once while waiting in a queue for a
ferry for about 40mins. The temperature dropped pretty quickly once
the car was on the move again though. A shroud for the engine
driven fan or an electric fan conversion are also on the to do list.–
R = 190
M = 200
A = 210
Depends what you are doing. 15-20 PSI at hot idle is normal
for a small block at hot Idle. 50-60 psi is high. Usually
these pumps go with a 6-8 qt pan. Normal driving probably fine.
