In reply to a message from exer51 sent Thu 30 Nov 2006:
Hey guys,
I assure you my engine isn’t going anywhere! I am in fact using
two sets of engine adapters… I am using a Suncoast pedestal kit
and a set of Speed and Performance aluminum engine mount relocation
plates. The Suncoast pieces are well constructed and proven and
Speed and Performance parts have a lot of credentials. They are
very stout pieces! They allow me to put the LS1 exactly where the
older style SBC would sit.
For the trans crossmember I had my girfriend’s dad design me a
custom piece for my 4L80E and it is definitely overbuilt.
As far as the LS1/GenIII engines go, I think they are the way of
the future. Lighter, more power and better fuel economy. The
4L60E is a fine unit for more conventional setups and boy I wish I
had those 1st and 4th gear ratios. I am also using a beefier
transmission to reliably support the torque of a forced induction
setup. My shortblock is built to handle about 800hp at the crank
(honed block, forged rods and pistons, 8.5:1 compression ratio, ARP
main and head studs) so I want a transmission that will take some
serious abuse.
Anyway, I wouldn’t worry too much about the rear end itself. Like
it’s been noted already, you may want to brace the rear end unit
against the chasis and perhaps the traveling portion of the
suspension as well. If running a high HP/torque application, you
are going to have more of a challenge getting the power to the
ground (due to compliance in the independent suspension) than you
will making the rear end last.
As far as computers go, I would advise getting a whole pullout.
The Camaro Z28/Trans Am automatic trans pullouts are the best
because they come with the computer ready to run. Worst case is
that you will have to buy an aftermarket harness to cut out some of
the extra wiring. I think the intake manifold of the truck GenIII
engines is too high for an XJ6 so you may want to be careful with
those. One more thing… I have been measuring and it looks like
the A/C compressor will fit the XJ6 chasis in its stock location.
I will be updating my page sometime this week so keep an eye out!–
An LS1/2/6 however would be awesome. I was looking around on ebay,
and you can find LS v8s with 4L60 trannys for a reasonable price.
Only question is how easy is the engine going to be to bolt in…
The mounts were changed for the LS engines over the old SBC. I have
kept up with this guys project
Dave's Jaguar XJ6 LS1 Swap
Apparently he just used some mount adapters that bolt to the block
that make it fit the old SBC design. I just dunno if that would be
a good thing though, I mean 2 adapters for the engine mounts…
Sounds like a recipe for the engine just falling out of the car one
day when you’re revving it good.
1985 XJ6 LS1 turbo project
Pittsburgh, PA, United States
//please trim quoted text to context only
