Among their offerings are higher spline-count stub axles, a 4-
piston Wilwood vented disc conversion, a 9’’ Ford differential, and
even a quick-change rear rated to 750 hp!
I’m sure none of this is particularly cheap, but it sure is fun to
look at…–
Steve Ellingson '83 XJS V-12, '83 XJS LT1, '86 XJS parts,
Yelm Washington, United States
In reply to a message from Why? sent Wed 20 Jan 2010:
I’m working on a 32 Ford pick up right now that has their 9’’
Ford, jag style rear end in it. Biiiig bucks! Nice piece though!–
Rob Wade
Windsor Ontario, Canada
In reply to a message from Rob Wade sent Wed 20 Jan 2010:
I’m at least semi-interested in the Wilwood brake conversion, as it
features both vented discs and separate e-brake calipers and may be
in reach price-wise.
The other intriguing part is their tube lower control arms that
appear to eliminate the trailing arms. Check out the Camero rear
they built…–
