In reply to a message from Roger Mabry sent Sun 3 Jun 2007:
I found out we cannot blame Jaguar or old age for my leaking heater
matrix. It did not leak until the new engine was installed. While
the engine was being installed, my friend and I totally rewired the
Jaguar under the hood. Unfortunately, we covered up the firewall
with BQuiet insulation material and covered up a critical mounting
hole for a wire bracket on the firewall. WE GUESSED = wrong by less
than 1/8 inch and made a hole with a screw into the previously good
matrix. We are paying dearly for that mistake!!!
Getting the leaking heater matrix out is a BIG JOB. It took two
good mechanics about (4) fours each to get the stuff out of the
car. The dash has to be totally removed, the dash pad has to come
off, the center braces to the top brace have to come out and
loosening the upper dash cross bar is required for room(from one
side of the car to the other needs to be loose). The steering wheel
and whole upper column has to be removed down to the U-joint at the
floor level. I did not remove the ignition switch per Jaguar - was
able to wiggle out the LH dash piece and only disconnected the
wires to the turn signal lever assembly. Easier than the Jaguar
manual.
Then the outer air vents on the L&R side have to be unscrewed, the
round vent tubes pulled out and the evaporator eight screws
removed. The fuse panels have to be removed from the evaporator top
sections and the attaching straps on the upper dash bent to allow
slack in the wiring harnesses. The harness connections need to be
uplugged on both sides. All the wiring has to be thrown up on top
to get the evaporator out.
The hardest part is the removal of the clips in the inside of the
vent on the outside of the car. Then the grill on the top of dash
has to be removed to get at those (2) clips that hold the vent rods
in place.
Then by carefully prying on the evaporator, keeping all the wires
out of the way, you can remove the evaporator. Try to save the
gaskets behind for samples - new ones have to be made to seal that
area or all the AC air will be lost behind the dash.
With the evaporator out, the matrix will be visible in it’s little
niche. If the hoses are removed, you can just pull it out of the
hole in the firewall bulkhead.
I will post pictures of all these steps on the Forum when we are
done doing the re-install portion. I need to make new seals for the
evaporator, the vent flaps and we are installing two extra cooling
vents while in there for this project - instead of just one. I am
remounting the radio to make it more secure, fixing a light that
was not working under the dash and cleaning all the ground
connections.
Even though we created the heater matrix leak, the extra two AC
vents, new vent flaps seals and good sealing on all the connections
will make it all worth while in the end.
Cold air and enough air volume to be happy and heat on demand!–
For once the Jaguar Service manual is correct. You must remove the
evaporator to get to the heater matrix that lives in a ‘‘depression’’
this quest to resolve the leaking heater matrix and the AC air flow
The heating problems are a leaking heater matrix - the spare has
'71 XJ6 383/200R, '74 XJ6 383/700R, '74 Nova SS Glendora, CA
//please trim quoted text to context only
