I am making good progress on my series 1 XJ6 here. I finally got it all
certed and legal. I am going through and replacing lots of worn out
parts now.
I see a split subframe V mounts at the front. I have heard that you can
solid mount these. I dont mind a bit of extra road noise as this is my
“fun car” Has anyone done this? I may as well hard mount the front and
rear to make the whole thing stiffen up.
Any advice about hard mounting a series 1 XJ6 would be appreciated.
I finally got hold of a rear swaybar that I will be fitting soon too, yay.
Keith
//please trim quoted text to context only
In reply to a message from Keith Colson sent Mon 23 May 2016:
Not sure about hard mounting subframe? If you do, expect
some more vibration from engine to your interior.
What rear sway bar are you using? I have been hunting for a
XJS one for my series 2 XJ6. Have not found one yet.–
Pat Opsahl
Tracy, CA, United States
Keith,
Alternative to solid mounts on my 77XJ12L:
Front
New engine carriage/suspension mounts
Urethane ft control arm bushings and stabilizer links
KYB gas shocks
stock 12 cylinder sway bar
Rear
all new fulcrum bearings
Urethane bushing in the front and rear of the trailing arm
Heavy duty (4) cage mounts
KYB gas shocks
XJS rear sway bar
New addition:
Nitto 555 G2’s 245/45/17 on 17’’ x 8’’ XJR cast rims
Original springs. rides nice, handles like a slot car.
Car is lighter in front - BBC & 700R4.–
Clyde, '77 XJ12L, '60 MK2
Canton, OH, United States
